RTEMS
6.3
Toggle main menu visibility
bsps
include
libchip
i2c-rtc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2023-2024 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBCHIP_I2C_RTC_H
37
#define LIBCHIP_I2C_RTC_H
38
39
rtems.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
84
85
rtems.h
86
rtems/thread.h
87
#include <libchip/rtc.h>
88
#include <stdint.h>
89
90
#ifdef __cplusplus
91
extern
"C"
92
#endif
/* __cplusplus */
93
94
extern
const
rtc_fns i2c_rtc_fns;
95
bool
i2c_rtc_probe(
int
minor);
96
98
struct
i2c_rtc_base
100
rtems_mutex
mutex
101
103
const
char
i2c_bus_path
104
106
uint8_t
i2c_addr
107
109
bool
initialized
110
116
int (*
hw_init
struct
i2c_rtc_base
*ctx);
117
119
size_t
clock_offset
120
122
struct
123
size_t
year;
124
size_t
month;
125
size_t
wkday;
126
size_t
day;
127
size_t
hour;
128
size_t
min;
129
size_t
sec;
130
} order;
131
132
138
int
i2c_rtc_read
struct
i2c_rtc_base
*ctx, uint8_t addr, uint8_t *buf,
139
size_t
len);
140
146
int
i2c_rtc_write
struct
i2c_rtc_base
*ctx, uint8_t addr,
const
uint8_t *buf,
147
size_t
len);
148
149
#define I2C_RTC_ORDER_sec_min_hour_wkday_day_month_year \
150
{ .sec = 0, .min = 1, .hour = 2, .day = 4, .wkday = 3, .month = 5, .year = 6 }
151
152
#define I2C_RTC_ORDER_sec_min_hour_day_wkday_month_year \
153
{ .sec = 0, .min = 1, .hour = 2, .day = 3, .wkday = 4, .month = 5, .year = 6 }
154
155
#define I2C_RTC_INITIALIZER(i2c_path, i2c_address, offset, reg_order, \
156
driver_name, hwinit)\
157
158
.mutex = RTEMS_MUTEX_INITIALIZER(driver_name), \
159
.i2c_bus_path = i2c_path, \
160
.i2c_addr = i2c_address, \
161
.initialized = false, \
162
.hw_init = hwinit, \
163
.clock_offset = offset, \
164
.order = reg_order, \
165
166
167
#define I2C_RTC_TBL_ENTRY(dev_name, i2c_rtc_ctx) \
168
169
.sDeviceName = dev_name, \
170
.deviceType = RTC_CUSTOM, \
171
.pDeviceFns = &i2c_rtc_fns, \
172
.deviceProbe = i2c_rtc_probe, \
173
.pDeviceParams = (void *)i2c_rtc_ctx, \
174
.ulCtrlPort1 = 0, \
175
.ulDataPort = 0, \
176
.getRegister = NULL, \
177
.setRegister = NULL, \
178
179
181
182
#ifdef __cplusplus
183
184
#endif
/* __cplusplus */
185
186
#endif
/* LIBCHIP_I2C_RTC_H */
i2c_rtc_read
int i2c_rtc_read(struct i2c_rtc_base *ctx, uint8_t addr, uint8_t *buf, size_t len)
Definition
i2c-rtc.c:112
i2c_rtc_write
int i2c_rtc_write(struct i2c_rtc_base *ctx, uint8_t addr, const uint8_t *buf, size_t len)
Definition
i2c-rtc.c:149
rtems.h
i2c_rtc_base
Definition
i2c-rtc.h:98
i2c_rtc_base::clock_offset
size_t clock_offset
Definition
i2c-rtc.h:119
i2c_rtc_base::initialized
bool initialized
Definition
i2c-rtc.h:109
i2c_rtc_base::i2c_addr
uint8_t i2c_addr
Definition
i2c-rtc.h:106
i2c_rtc_base::mutex
rtems_mutex mutex
Definition
i2c-rtc.h:100
i2c_rtc_base::hw_init
int(*) hw_init(struct i2c_rtc_base *ctx)
Definition
i2c-rtc.h:116
i2c_rtc_base::i2c_bus_path
const char * i2c_bus_path
Definition
i2c-rtc.h:103
thread.h
This header file provides the API of Self-Contained Objects.
