RTEMS 6.3
Test context for spec:/rtems/req/ident test case. More...
| struct | [struct].Map |
Data Fields | |
| rtems_status_code | status |
| rtems_name | name |
| uint32_t | node |
| rtems_id * | id |
| rtems_id | id_value |
| rtems_id | id_remote_object |
| rtems_id | id_local_object |
| This member contains a copy of the corresponding RtemsReqIdent_Run() parameter. | |
| rtems_name | name_local_object |
| rtems_status_code(*) | action (rtems_name, uint32_t, rtems_id *) |
| struct | Map |
