RTEMS 6.3
Files | |
| file | testsuites/validation/tr-object-ident.c |
| file | testsuites/validation/tr-object-ident.h |
| struct | RtemsReqIdent_Entry |
| struct | RtemsReqIdent_Context |
| Test context for spec:/rtems/req/ident test case. More... | |
| struct | RtemsReqIdent_Context::[struct].Map |
| void | RtemsReqIdent_Run (rtems_id id_local_object, rtems_name name_local_object, rtems_status_code(*action)(rtems_name, uint32_t, rtems_id *)) |
| Runs the parameterized test case. | |
| void RtemsReqIdent_Run | ( | rtems_id | id_local_object, |
| rtems_name | name_local_object, | ||
| rtems_status_code(* | action )(rtems_name, uint32_t, rtems_id *) ) |
| id_local_object | is the identifier of an active object of the class under test. |
| name_local_object | is the name of the active object of the class under test. |
| action | is the action handler. |
