RTEMS 6.3
Test context for spec:/rtems/intr/req/vector-disable test case. More...
| struct | [struct].Map |
Data Fields | |
| bool | interrupt_occurred |
| If this member is true, then an interrupt occurred. | |
| rtems_vector_number | vector |
| This member contains the current vector number. | |
| bool | valid_vector |
| If this member is true, then the vector parameter shall be valid. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_interrupt_vector_disable() call. | |
| struct | Map |
