RTEMS 6.3
spec:/rtems/intr/req/vector-disable
file  testsuites/validation/tc-intr-vector-disable.c
struct  RtemsIntrReqVectorDisable_Entry
struct  RtemsIntrReqVectorDisable_Context
 Test context for spec:/rtems/intr/req/vector-disable test case. More...
struct  RtemsIntrReqVectorDisable_Context::[struct].Map
typedef RtemsIntrReqVectorDisable_Context Context
enum  RtemsIntrReqVectorDisable_Pre_Vector { RtemsIntrReqVectorDisable_Pre_Vector_Valid , RtemsIntrReqVectorDisable_Pre_Vector_Invalid , RtemsIntrReqVectorDisable_Pre_Vector_NA }
enum  RtemsIntrReqVectorDisable_Pre_IsEnabled { RtemsIntrReqVectorDisable_Pre_IsEnabled_Yes , RtemsIntrReqVectorDisable_Pre_IsEnabled_No , RtemsIntrReqVectorDisable_Pre_IsEnabled_NA }
enum  RtemsIntrReqVectorDisable_Pre_CanDisable { RtemsIntrReqVectorDisable_Pre_CanDisable_Yes , RtemsIntrReqVectorDisable_Pre_CanDisable_Maybe , RtemsIntrReqVectorDisable_Pre_CanDisable_No , RtemsIntrReqVectorDisable_Pre_CanDisable_NA }
enum  RtemsIntrReqVectorDisable_Post_Status { RtemsIntrReqVectorDisable_Post_Status_Ok , RtemsIntrReqVectorDisable_Post_Status_InvId , RtemsIntrReqVectorDisable_Post_Status_Unsat , RtemsIntrReqVectorDisable_Post_Status_NA }
enum  RtemsIntrReqVectorDisable_Post_IsEnabled { RtemsIntrReqVectorDisable_Post_IsEnabled_Nop , RtemsIntrReqVectorDisable_Post_IsEnabled_No , RtemsIntrReqVectorDisable_Post_IsEnabled_Maybe , RtemsIntrReqVectorDisable_Post_IsEnabled_NA }
 T_TEST_CASE_FIXTURE (RtemsIntrReqVectorDisable, &RtemsIntrReqVectorDisable_Fixture)
