RTEMS 6.3
Rate_monotonic_Control Struct Reference
The following structure defines the control block used to manage each period. More...
#include <ratemondata.h>
Objects_Control Object
Watchdog_Control Timer
rtems_rate_monotonic_period_states state
Priority_Node Priority
 A priority node for use by the scheduler job release and cancel operations.
uint32_t next_length
Thread_Control * owner
Timestamp_Control cpu_usage_period_initiated
Timestamp_Control time_period_initiated
Rate_monotonic_Statistics Statistics
uint32_t postponed_jobs
uint64_t latest_deadline
State changes are protected by the default thread lock of the owner thread. The owner thread is the thread that created the period object. The owner thread field is immutable after object creation.
Field Documentation
◆ cpu_usage_period_initiated
Timestamp_Control Rate_monotonic_Control::cpu_usage_period_initiated
This field contains the cpu usage value of the owning thread when the period was initiated. It is used to compute the period's statistics.
◆ latest_deadline
uint64_t Rate_monotonic_Control::latest_deadline
This field contains the tick of the latest deadline decided by the period watchdog.
◆ next_length
uint32_t Rate_monotonic_Control::next_length
This field contains the length of the next period to be executed.
◆ Object
Objects_Control Rate_monotonic_Control::Object
This field is the object management portion of a Period instance.
◆ owner
Thread_Control* Rate_monotonic_Control::owner
This field contains a pointer to the TCB for the thread which owns and uses this period instance.
◆ postponed_jobs
uint32_t Rate_monotonic_Control::postponed_jobs
This field contains the number of postponed jobs. When the watchdog timeout, this variable will be increased immediately.
◆ state
rtems_rate_monotonic_period_states Rate_monotonic_Control::state
This field indicates the current state of the period.
◆ Statistics
Rate_monotonic_Statistics Rate_monotonic_Control::Statistics
This field contains the statistics maintained for the period.
◆ time_period_initiated
Timestamp_Control Rate_monotonic_Control::time_period_initiated
This field contains the wall time value when the period was initiated. It is used to compute the period's statistics.
◆ Timer
Watchdog_Control Rate_monotonic_Control::Timer
This is the timer used to provide the unblocking mechanism.
