RTEMS 6.3
stm32h7xx_hal_tim.h File Reference
Header file of TIM HAL module. More...
struct  TIM_Base_InitTypeDef
 TIM Time base Configuration Structure definition. More...
struct  TIM_OC_InitTypeDef
 TIM Output Compare Configuration Structure definition. More...
struct  TIM_OnePulse_InitTypeDef
 TIM One Pulse Mode Configuration Structure definition. More...
struct  TIM_IC_InitTypeDef
 TIM Input Capture Configuration Structure definition. More...
struct  TIM_Encoder_InitTypeDef
 TIM Encoder Configuration Structure definition. More...
struct  TIM_ClockConfigTypeDef
 Clock Configuration Handle Structure definition. More...
struct  TIM_ClearInputConfigTypeDef
 TIM Clear Input Configuration Handle Structure definition. More...
struct  TIM_MasterConfigTypeDef
 TIM Master configuration Structure definition. More...
struct  TIM_SlaveConfigTypeDef
 TIM Slave configuration Structure definition. More...
struct  TIM_BreakDeadTimeConfigTypeDef
 TIM Break input(s) and Dead time configuration Structure definition. More...
struct  TIM_HandleTypeDef
 TIM Time Base Handle Structure definition. More...
#define TIM_CLEARINPUTSOURCE_NONE   0x00000000U
#define TIM_CLEARINPUTSOURCE_ETR   0x00000001U
#define TIM_DMABASE_CR1   0x00000000U
#define TIM_DMABASE_CR2   0x00000001U
#define TIM_DMABASE_SMCR   0x00000002U
#define TIM_DMABASE_DIER   0x00000003U
#define TIM_DMABASE_SR   0x00000004U
#define TIM_DMABASE_EGR   0x00000005U
#define TIM_DMABASE_CCMR1   0x00000006U
#define TIM_DMABASE_CCMR2   0x00000007U
#define TIM_DMABASE_CCER   0x00000008U
#define TIM_DMABASE_CNT   0x00000009U
#define TIM_DMABASE_PSC   0x0000000AU
#define TIM_DMABASE_ARR   0x0000000BU
#define TIM_DMABASE_RCR   0x0000000CU
#define TIM_DMABASE_CCR1   0x0000000DU
#define TIM_DMABASE_CCR2   0x0000000EU
#define TIM_DMABASE_CCR3   0x0000000FU
#define TIM_DMABASE_CCR4   0x00000010U
#define TIM_DMABASE_BDTR   0x00000011U
#define TIM_DMABASE_DCR   0x00000012U
#define TIM_DMABASE_DMAR   0x00000013U
#define TIM_DMABASE_CCMR3   0x00000015U
#define TIM_DMABASE_CCR5   0x00000016U
#define TIM_DMABASE_CCR6   0x00000017U
#define TIM_DMABASE_TISEL   0x0000001AU
#define TIM_EVENTSOURCE_UPDATE   TIM_EGR_UG
#define TIM_EVENTSOURCE_CC1   TIM_EGR_CC1G
#define TIM_EVENTSOURCE_CC2   TIM_EGR_CC2G
#define TIM_EVENTSOURCE_CC3   TIM_EGR_CC3G
#define TIM_EVENTSOURCE_CC4   TIM_EGR_CC4G
#define TIM_EVENTSOURCE_COM   TIM_EGR_COMG
#define TIM_EVENTSOURCE_TRIGGER   TIM_EGR_TG
#define TIM_EVENTSOURCE_BREAK   TIM_EGR_BG
#define TIM_EVENTSOURCE_BREAK2   TIM_EGR_B2G
#define TIM_INPUTCHANNELPOLARITY_RISING   0x00000000U
#define TIM_INPUTCHANNELPOLARITY_FALLING   TIM_CCER_CC1P
#define TIM_INPUTCHANNELPOLARITY_BOTHEDGE   (TIM_CCER_CC1P | TIM_CCER_CC1NP)
#define TIM_ETRPOLARITY_INVERTED   TIM_SMCR_ETP
#define TIM_ETRPOLARITY_NONINVERTED   0x00000000U
#define TIM_ETRPRESCALER_DIV1   0x00000000U
#define TIM_ETRPRESCALER_DIV2   TIM_SMCR_ETPS_0
#define TIM_ETRPRESCALER_DIV4   TIM_SMCR_ETPS_1
#define TIM_ETRPRESCALER_DIV8   TIM_SMCR_ETPS
#define TIM_COUNTERMODE_UP   0x00000000U
#define TIM_COUNTERMODE_DOWN   TIM_CR1_DIR
#define TIM_COUNTERMODE_CENTERALIGNED1   TIM_CR1_CMS_0
#define TIM_COUNTERMODE_CENTERALIGNED2   TIM_CR1_CMS_1
#define TIM_COUNTERMODE_CENTERALIGNED3   TIM_CR1_CMS
#define TIM_UIFREMAP_DISABLE   0x00000000U
#define TIM_UIFREMAP_ENABLE   TIM_CR1_UIFREMAP
#define TIM_CLOCKDIVISION_DIV1   0x00000000U
#define TIM_CLOCKDIVISION_DIV2   TIM_CR1_CKD_0
#define TIM_CLOCKDIVISION_DIV4   TIM_CR1_CKD_1
#define TIM_OUTPUTSTATE_DISABLE   0x00000000U
#define TIM_OUTPUTSTATE_ENABLE   TIM_CCER_CC1E
#define TIM_AUTORELOAD_PRELOAD_DISABLE   0x00000000U
#define TIM_AUTORELOAD_PRELOAD_ENABLE   TIM_CR1_ARPE
#define TIM_OCFAST_DISABLE   0x00000000U
#define TIM_OCFAST_ENABLE   TIM_CCMR1_OC1FE
#define TIM_OUTPUTNSTATE_DISABLE   0x00000000U
#define TIM_OUTPUTNSTATE_ENABLE   TIM_CCER_CC1NE
#define TIM_OCPOLARITY_HIGH   0x00000000U
#define TIM_OCPOLARITY_LOW   TIM_CCER_CC1P
#define TIM_OCNPOLARITY_HIGH   0x00000000U
#define TIM_OCNPOLARITY_LOW   TIM_CCER_CC1NP
#define TIM_OCIDLESTATE_SET   TIM_CR2_OIS1
#define TIM_OCIDLESTATE_RESET   0x00000000U
#define TIM_OCNIDLESTATE_SET   TIM_CR2_OIS1N
#define TIM_OCNIDLESTATE_RESET   0x00000000U
#define TIM_ICPOLARITY_RISING   TIM_INPUTCHANNELPOLARITY_RISING
#define TIM_ICPOLARITY_FALLING   TIM_INPUTCHANNELPOLARITY_FALLING
#define TIM_ICPOLARITY_BOTHEDGE   TIM_INPUTCHANNELPOLARITY_BOTHEDGE
#define TIM_ENCODERINPUTPOLARITY_RISING   TIM_INPUTCHANNELPOLARITY_RISING
#define TIM_ENCODERINPUTPOLARITY_FALLING   TIM_INPUTCHANNELPOLARITY_FALLING
#define TIM_ICSELECTION_DIRECTTI   TIM_CCMR1_CC1S_0
#define TIM_ICSELECTION_INDIRECTTI   TIM_CCMR1_CC1S_1
#define TIM_ICSELECTION_TRC   TIM_CCMR1_CC1S
#define TIM_ICPSC_DIV1   0x00000000U
#define TIM_ICPSC_DIV2   TIM_CCMR1_IC1PSC_0
#define TIM_ICPSC_DIV4   TIM_CCMR1_IC1PSC_1
#define TIM_ICPSC_DIV8   TIM_CCMR1_IC1PSC
#define TIM_OPMODE_SINGLE   TIM_CR1_OPM
#define TIM_OPMODE_REPETITIVE   0x00000000U
#define TIM_ENCODERMODE_TI1   TIM_SMCR_SMS_0
#define TIM_ENCODERMODE_TI2   TIM_SMCR_SMS_1
#define TIM_ENCODERMODE_TI12   (TIM_SMCR_SMS_1 | TIM_SMCR_SMS_0)
#define TIM_IT_UPDATE   TIM_DIER_UIE
#define TIM_IT_CC1   TIM_DIER_CC1IE
#define TIM_IT_CC2   TIM_DIER_CC2IE
#define TIM_IT_CC3   TIM_DIER_CC3IE
#define TIM_IT_CC4   TIM_DIER_CC4IE
#define TIM_IT_COM   TIM_DIER_COMIE
#define TIM_IT_TRIGGER   TIM_DIER_TIE
#define TIM_IT_BREAK   TIM_DIER_BIE
#define TIM_COMMUTATION_TRGI   TIM_CR2_CCUS
#define TIM_COMMUTATION_SOFTWARE   0x00000000U
#define TIM_DMA_UPDATE   TIM_DIER_UDE
#define TIM_DMA_CC1   TIM_DIER_CC1DE
#define TIM_DMA_CC2   TIM_DIER_CC2DE
#define TIM_DMA_CC3   TIM_DIER_CC3DE
#define TIM_DMA_CC4   TIM_DIER_CC4DE
#define TIM_DMA_COM   TIM_DIER_COMDE
#define TIM_DMA_TRIGGER   TIM_DIER_TDE
#define TIM_CCDMAREQUEST_CC   0x00000000U
#define TIM_CCDMAREQUEST_UPDATE   TIM_CR2_CCDS
#define TIM_FLAG_UPDATE   TIM_SR_UIF
#define TIM_FLAG_CC1   TIM_SR_CC1IF
#define TIM_FLAG_CC2   TIM_SR_CC2IF
#define TIM_FLAG_CC3   TIM_SR_CC3IF
#define TIM_FLAG_CC4   TIM_SR_CC4IF
#define TIM_FLAG_CC5   TIM_SR_CC5IF
#define TIM_FLAG_CC6   TIM_SR_CC6IF
#define TIM_FLAG_COM   TIM_SR_COMIF
#define TIM_FLAG_TRIGGER   TIM_SR_TIF
#define TIM_FLAG_BREAK   TIM_SR_BIF
#define TIM_FLAG_BREAK2   TIM_SR_B2IF
#define TIM_FLAG_SYSTEM_BREAK   TIM_SR_SBIF
#define TIM_FLAG_CC1OF   TIM_SR_CC1OF
#define TIM_FLAG_CC2OF   TIM_SR_CC2OF
#define TIM_FLAG_CC3OF   TIM_SR_CC3OF
#define TIM_FLAG_CC4OF   TIM_SR_CC4OF
#define TIM_CHANNEL_1   0x00000000U
#define TIM_CHANNEL_2   0x00000004U
#define TIM_CHANNEL_3   0x00000008U
#define TIM_CHANNEL_4   0x0000000CU
#define TIM_CHANNEL_5   0x00000010U
#define TIM_CHANNEL_6   0x00000014U
#define TIM_CHANNEL_ALL   0x0000003CU
#define TIM_CLOCKSOURCE_INTERNAL   TIM_SMCR_ETPS_0
#define TIM_CLOCKSOURCE_ETRMODE1   TIM_TS_ETRF
#define TIM_CLOCKSOURCE_ETRMODE2   TIM_SMCR_ETPS_1
#define TIM_CLOCKSOURCE_TI1ED   TIM_TS_TI1F_ED
#define TIM_CLOCKSOURCE_TI1   TIM_TS_TI1FP1
#define TIM_CLOCKSOURCE_TI2   TIM_TS_TI2FP2
#define TIM_CLOCKSOURCE_ITR0   TIM_TS_ITR0
#define TIM_CLOCKSOURCE_ITR1   TIM_TS_ITR1
#define TIM_CLOCKSOURCE_ITR2   TIM_TS_ITR2
#define TIM_CLOCKSOURCE_ITR3   TIM_TS_ITR3
#define TIM_CLOCKSOURCE_ITR4   TIM_TS_ITR4
#define TIM_CLOCKSOURCE_ITR5   TIM_TS_ITR5
#define TIM_CLOCKSOURCE_ITR6   TIM_TS_ITR6
#define TIM_CLOCKSOURCE_ITR7   TIM_TS_ITR7
#define TIM_CLOCKSOURCE_ITR8   TIM_TS_ITR8
#define TIM_CLOCKPOLARITY_INVERTED   TIM_ETRPOLARITY_INVERTED
#define TIM_CLOCKPOLARITY_NONINVERTED   TIM_ETRPOLARITY_NONINVERTED
#define TIM_CLOCKPOLARITY_RISING   TIM_INPUTCHANNELPOLARITY_RISING
#define TIM_CLOCKPOLARITY_FALLING   TIM_INPUTCHANNELPOLARITY_FALLING
#define TIM_CLOCKPOLARITY_BOTHEDGE   TIM_INPUTCHANNELPOLARITY_BOTHEDGE
#define TIM_CLOCKPRESCALER_DIV1   TIM_ETRPRESCALER_DIV1
#define TIM_CLOCKPRESCALER_DIV2   TIM_ETRPRESCALER_DIV2
#define TIM_CLOCKPRESCALER_DIV4   TIM_ETRPRESCALER_DIV4
#define TIM_CLOCKPRESCALER_DIV8   TIM_ETRPRESCALER_DIV8
#define TIM_CLEARINPUTPOLARITY_INVERTED   TIM_ETRPOLARITY_INVERTED
#define TIM_CLEARINPUTPOLARITY_NONINVERTED   TIM_ETRPOLARITY_NONINVERTED
#define TIM_CLEARINPUTPRESCALER_DIV1   TIM_ETRPRESCALER_DIV1
#define TIM_CLEARINPUTPRESCALER_DIV2   TIM_ETRPRESCALER_DIV2
#define TIM_CLEARINPUTPRESCALER_DIV4   TIM_ETRPRESCALER_DIV4
#define TIM_CLEARINPUTPRESCALER_DIV8   TIM_ETRPRESCALER_DIV8
#define TIM_OSSR_ENABLE   TIM_BDTR_OSSR
#define TIM_OSSR_DISABLE   0x00000000U
#define TIM_OSSI_ENABLE   TIM_BDTR_OSSI
#define TIM_OSSI_DISABLE   0x00000000U
#define TIM_LOCKLEVEL_OFF   0x00000000U
#define TIM_LOCKLEVEL_1   TIM_BDTR_LOCK_0
#define TIM_LOCKLEVEL_2   TIM_BDTR_LOCK_1
#define TIM_LOCKLEVEL_3   TIM_BDTR_LOCK
#define TIM_BREAK_ENABLE   TIM_BDTR_BKE
#define TIM_BREAK_DISABLE   0x00000000U
#define TIM_BREAKPOLARITY_LOW   0x00000000U
#define TIM_BREAKPOLARITY_HIGH   TIM_BDTR_BKP
#define TIM_BREAK2_DISABLE   0x00000000U
#define TIM_BREAK2_ENABLE   TIM_BDTR_BK2E
#define TIM_BREAK2POLARITY_LOW   0x00000000U
#define TIM_BREAK2POLARITY_HIGH   TIM_BDTR_BK2P
#define TIM_AUTOMATICOUTPUT_DISABLE   0x00000000U
#define TIM_AUTOMATICOUTPUT_ENABLE   TIM_BDTR_AOE
#define TIM_GROUPCH5_NONE   0x00000000U
#define TIM_GROUPCH5_OC1REFC   TIM_CCR5_GC5C1
#define TIM_GROUPCH5_OC2REFC   TIM_CCR5_GC5C2
#define TIM_GROUPCH5_OC3REFC   TIM_CCR5_GC5C3
#define TIM_TRGO_RESET   0x00000000U
#define TIM_TRGO_ENABLE   TIM_CR2_MMS_0
#define TIM_TRGO_UPDATE   TIM_CR2_MMS_1
#define TIM_TRGO_OC1   (TIM_CR2_MMS_1 | TIM_CR2_MMS_0)
#define TIM_TRGO_OC1REF   TIM_CR2_MMS_2
#define TIM_TRGO_OC2REF   (TIM_CR2_MMS_2 | TIM_CR2_MMS_0)
#define TIM_TRGO_OC3REF   (TIM_CR2_MMS_2 | TIM_CR2_MMS_1)
#define TIM_TRGO_OC4REF   (TIM_CR2_MMS_2 | TIM_CR2_MMS_1 | TIM_CR2_MMS_0)
#define TIM_TRGO2_RESET   0x00000000U
#define TIM_TRGO2_ENABLE   TIM_CR2_MMS2_0
#define TIM_TRGO2_UPDATE   TIM_CR2_MMS2_1
#define TIM_TRGO2_OC1   (TIM_CR2_MMS2_1 | TIM_CR2_MMS2_0)
#define TIM_TRGO2_OC1REF   TIM_CR2_MMS2_2
#define TIM_TRGO2_OC2REF   (TIM_CR2_MMS2_2 | TIM_CR2_MMS2_0)
#define TIM_TRGO2_OC3REF   (TIM_CR2_MMS2_2 | TIM_CR2_MMS2_1)
#define TIM_TRGO2_OC4REF   (TIM_CR2_MMS2_2 | TIM_CR2_MMS2_1 | TIM_CR2_MMS2_0)
#define TIM_TRGO2_OC5REF   TIM_CR2_MMS2_3
#define TIM_TRGO2_OC6REF   (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_0)
#define TIM_TRGO2_OC4REF_RISINGFALLING   (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_1)
#define TIM_TRGO2_OC6REF_RISINGFALLING   (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_1 | TIM_CR2_MMS2_0)
#define TIM_TRGO2_OC4REF_RISING_OC6REF_RISING   (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_2)
#define TIM_TRGO2_OC4REF_RISING_OC6REF_FALLING   (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_2 | TIM_CR2_MMS2_0)
#define TIM_TRGO2_OC5REF_RISING_OC6REF_RISING   (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_2 |TIM_CR2_MMS2_1)
#define TIM_TRGO2_OC5REF_RISING_OC6REF_FALLING   (TIM_CR2_MMS2_3 | TIM_CR2_MMS2_2 | TIM_CR2_MMS2_1 | TIM_CR2_MMS2_0)
#define TIM_MASTERSLAVEMODE_ENABLE   TIM_SMCR_MSM
#define TIM_MASTERSLAVEMODE_DISABLE   0x00000000U
#define TIM_SLAVEMODE_DISABLE   0x00000000U
#define TIM_SLAVEMODE_RESET   TIM_SMCR_SMS_2
#define TIM_SLAVEMODE_GATED   (TIM_SMCR_SMS_2 | TIM_SMCR_SMS_0)
#define TIM_SLAVEMODE_TRIGGER   (TIM_SMCR_SMS_2 | TIM_SMCR_SMS_1)
#define TIM_SLAVEMODE_EXTERNAL1   (TIM_SMCR_SMS_2 | TIM_SMCR_SMS_1 | TIM_SMCR_SMS_0)
#define TIM_SLAVEMODE_COMBINED_RESETTRIGGER   TIM_SMCR_SMS_3
#define TIM_OCMODE_TIMING   0x00000000U
#define TIM_OCMODE_ACTIVE   TIM_CCMR1_OC1M_0
#define TIM_OCMODE_INACTIVE   TIM_CCMR1_OC1M_1
#define TIM_OCMODE_TOGGLE   (TIM_CCMR1_OC1M_1 | TIM_CCMR1_OC1M_0)
#define TIM_OCMODE_PWM1   (TIM_CCMR1_OC1M_2 | TIM_CCMR1_OC1M_1)
#define TIM_OCMODE_PWM2   (TIM_CCMR1_OC1M_2 | TIM_CCMR1_OC1M_1 | TIM_CCMR1_OC1M_0)
#define TIM_OCMODE_FORCED_ACTIVE   (TIM_CCMR1_OC1M_2 | TIM_CCMR1_OC1M_0)
#define TIM_OCMODE_FORCED_INACTIVE   TIM_CCMR1_OC1M_2
#define TIM_OCMODE_RETRIGERRABLE_OPM1   TIM_CCMR1_OC1M_3
#define TIM_OCMODE_RETRIGERRABLE_OPM2   (TIM_CCMR1_OC1M_3 | TIM_CCMR1_OC1M_0)
#define TIM_OCMODE_COMBINED_PWM1   (TIM_CCMR1_OC1M_3 | TIM_CCMR1_OC1M_2)
#define TIM_OCMODE_COMBINED_PWM2   (TIM_CCMR1_OC1M_3 | TIM_CCMR1_OC1M_0 | TIM_CCMR1_OC1M_2)
#define TIM_OCMODE_ASYMMETRIC_PWM1   (TIM_CCMR1_OC1M_3 | TIM_CCMR1_OC1M_1 | TIM_CCMR1_OC1M_2)
#define TIM_OCMODE_ASYMMETRIC_PWM2   TIM_CCMR1_OC1M
#define TIM_TS_ITR0   0x00000000U
#define TIM_TS_ITR1   TIM_SMCR_TS_0
#define TIM_TS_ITR2   TIM_SMCR_TS_1
#define TIM_TS_ITR3   (TIM_SMCR_TS_0 | TIM_SMCR_TS_1)
#define TIM_TS_ITR4   (TIM_SMCR_TS_3)
#define TIM_TS_ITR5   (TIM_SMCR_TS_0 | TIM_SMCR_TS_3)
#define TIM_TS_ITR6   (TIM_SMCR_TS_1 | TIM_SMCR_TS_3)
#define TIM_TS_ITR7   (TIM_SMCR_TS_0 | TIM_SMCR_TS_1 | TIM_SMCR_TS_3)
#define TIM_TS_ITR8   (TIM_SMCR_TS_2 | TIM_SMCR_TS_3)
#define TIM_TS_ITR9   (TIM_SMCR_TS_0 | TIM_SMCR_TS_2 | TIM_SMCR_TS_3)
#define TIM_TS_ITR10   (TIM_SMCR_TS_1 | TIM_SMCR_TS_2 | TIM_SMCR_TS_3)
#define TIM_TS_ITR11   (TIM_SMCR_TS_0 | TIM_SMCR_TS_1 | TIM_SMCR_TS_2 | TIM_SMCR_TS_3)
#define TIM_TS_ITR12   (TIM_SMCR_TS_4)
#define TIM_TS_ITR13   (TIM_SMCR_TS_0 | TIM_SMCR_TS_4)
#define TIM_TS_TI1F_ED   TIM_SMCR_TS_2
#define TIM_TS_TI1FP1   (TIM_SMCR_TS_0 | TIM_SMCR_TS_2)
#define TIM_TS_TI2FP2   (TIM_SMCR_TS_1 | TIM_SMCR_TS_2)
#define TIM_TS_ETRF   (TIM_SMCR_TS_0 | TIM_SMCR_TS_1 | TIM_SMCR_TS_2)
#define TIM_TS_NONE   0x0000FFFFU
#define TIM_TRIGGERPOLARITY_INVERTED   TIM_ETRPOLARITY_INVERTED
#define TIM_TRIGGERPOLARITY_NONINVERTED   TIM_ETRPOLARITY_NONINVERTED
#define TIM_TRIGGERPOLARITY_RISING   TIM_INPUTCHANNELPOLARITY_RISING
#define TIM_TRIGGERPOLARITY_FALLING   TIM_INPUTCHANNELPOLARITY_FALLING
#define TIM_TRIGGERPOLARITY_BOTHEDGE   TIM_INPUTCHANNELPOLARITY_BOTHEDGE
#define TIM_TRIGGERPRESCALER_DIV1   TIM_ETRPRESCALER_DIV1
#define TIM_TRIGGERPRESCALER_DIV2   TIM_ETRPRESCALER_DIV2
#define TIM_TRIGGERPRESCALER_DIV4   TIM_ETRPRESCALER_DIV4
#define TIM_TRIGGERPRESCALER_DIV8   TIM_ETRPRESCALER_DIV8
#define TIM_TI1SELECTION_CH1   0x00000000U
#define TIM_TI1SELECTION_XORCOMBINATION   TIM_CR2_TI1S
#define TIM_DMABURSTLENGTH_1TRANSFER   0x00000000U
#define TIM_DMABURSTLENGTH_2TRANSFERS   0x00000100U
#define TIM_DMABURSTLENGTH_3TRANSFERS   0x00000200U
#define TIM_DMABURSTLENGTH_4TRANSFERS   0x00000300U
#define TIM_DMABURSTLENGTH_5TRANSFERS   0x00000400U
#define TIM_DMABURSTLENGTH_6TRANSFERS   0x00000500U
#define TIM_DMABURSTLENGTH_7TRANSFERS   0x00000600U
#define TIM_DMABURSTLENGTH_8TRANSFERS   0x00000700U
#define TIM_DMABURSTLENGTH_9TRANSFERS   0x00000800U
#define TIM_DMABURSTLENGTH_10TRANSFERS   0x00000900U
#define TIM_DMABURSTLENGTH_11TRANSFERS   0x00000A00U
#define TIM_DMABURSTLENGTH_12TRANSFERS   0x00000B00U
#define TIM_DMABURSTLENGTH_13TRANSFERS   0x00000C00U
#define TIM_DMABURSTLENGTH_14TRANSFERS   0x00000D00U
#define TIM_DMABURSTLENGTH_15TRANSFERS   0x00000E00U
#define TIM_DMABURSTLENGTH_16TRANSFERS   0x00000F00U
#define TIM_DMABURSTLENGTH_17TRANSFERS   0x00001000U
#define TIM_DMABURSTLENGTH_18TRANSFERS   0x00001100U
#define TIM_DMA_ID_UPDATE   ((uint16_t) 0x0000)
#define TIM_DMA_ID_CC1   ((uint16_t) 0x0001)
#define TIM_DMA_ID_CC2   ((uint16_t) 0x0002)
#define TIM_DMA_ID_CC3   ((uint16_t) 0x0003)
#define TIM_DMA_ID_CC4   ((uint16_t) 0x0004)
#define TIM_DMA_ID_COMMUTATION   ((uint16_t) 0x0005)
#define TIM_DMA_ID_TRIGGER   ((uint16_t) 0x0006)
#define TIM_CCx_ENABLE   0x00000001U
#define TIM_CCx_DISABLE   0x00000000U
#define TIM_CCxN_ENABLE   0x00000004U
#define TIM_CCxN_DISABLE   0x00000000U
#define TIM_BREAK_SYSTEM_ECC   SYSCFG_CFGR2_ECCL
#define TIM_BREAK_SYSTEM_PVD   SYSCFG_CFGR2_PVDL
#define TIM_BREAK_SYSTEM_SRAM_PARITY_ERROR   SYSCFG_CFGR2_SPL
#define TIM_BREAK_SYSTEM_LOCKUP   SYSCFG_CFGR2_CLL
#define __HAL_TIM_RESET_HANDLE_STATE(__HANDLE__)
 Reset TIM handle state.
#define __HAL_TIM_ENABLE(__HANDLE__)
 Enable the TIM peripheral.
#define __HAL_TIM_MOE_ENABLE(__HANDLE__)
 Enable the TIM main Output.
#define __HAL_TIM_DISABLE(__HANDLE__)
 Disable the TIM peripheral.
#define __HAL_TIM_MOE_DISABLE(__HANDLE__)
 Disable the TIM main Output.
#define __HAL_TIM_MOE_DISABLE_UNCONDITIONALLY(__HANDLE__)
#define __HAL_TIM_ENABLE_IT(__HANDLE__, __INTERRUPT__)
 Enable the specified TIM interrupt.
#define __HAL_TIM_DISABLE_IT(__HANDLE__, __INTERRUPT__)
 Disable the specified TIM interrupt.
#define __HAL_TIM_ENABLE_DMA(__HANDLE__, __DMA__)
 Enable the specified DMA request.
#define __HAL_TIM_DISABLE_DMA(__HANDLE__, __DMA__)
 Disable the specified DMA request.
#define __HAL_TIM_GET_FLAG(__HANDLE__, __FLAG__)
 Check whether the specified TIM interrupt flag is set or not.
#define __HAL_TIM_CLEAR_FLAG(__HANDLE__, __FLAG__)
 Clear the specified TIM interrupt flag.
#define __HAL_TIM_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified TIM interrupt source is enabled or not.
#define __HAL_TIM_CLEAR_IT(__HANDLE__, __INTERRUPT__)
 Clear the TIM interrupt pending bits.
#define __HAL_TIM_UIFREMAP_ENABLE(__HANDLE__)
#define __HAL_TIM_UIFREMAP_DISABLE(__HANDLE__)
#define __HAL_TIM_GET_UIFCPY(__COUNTER__)
#define __HAL_TIM_IS_TIM_COUNTING_DOWN(__HANDLE__)
 Indicates whether or not the TIM Counter is used as downcounter.
#define __HAL_TIM_SET_PRESCALER(__HANDLE__, __PRESC__)
 Set the TIM Prescaler on runtime.
#define __HAL_TIM_SET_COUNTER(__HANDLE__, __COUNTER__)
 Set the TIM Counter Register value on runtime. Note Please check if the bit 31 of CNT register is used as UIF copy or not, this may affect the counter range in case of 32 bits counter TIM instance. Bit 31 of CNT can be enabled/disabled using __HAL_TIM_UIFREMAP_ENABLE()/__HAL_TIM_UIFREMAP_DISABLE() macros.
#define __HAL_TIM_GET_COUNTER(__HANDLE__)
 Get the TIM Counter Register value on runtime.
#define __HAL_TIM_SET_AUTORELOAD(__HANDLE__, __AUTORELOAD__)
 Set the TIM Autoreload Register value on runtime without calling another time any Init function.
#define __HAL_TIM_GET_AUTORELOAD(__HANDLE__)
 Get the TIM Autoreload Register value on runtime.
#define __HAL_TIM_SET_CLOCKDIVISION(__HANDLE__, __CKD__)
 Set the TIM Clock Division value on runtime without calling another time any Init function.
#define __HAL_TIM_GET_CLOCKDIVISION(__HANDLE__)
 Get the TIM Clock Division value on runtime.
#define __HAL_TIM_SET_ICPRESCALER(__HANDLE__, __CHANNEL__, __ICPSC__)
 Set the TIM Input Capture prescaler on runtime without calling another time HAL_TIM_IC_ConfigChannel() function.
#define __HAL_TIM_GET_ICPRESCALER(__HANDLE__, __CHANNEL__)
 Get the TIM Input Capture prescaler on runtime.
#define __HAL_TIM_SET_COMPARE(__HANDLE__, __CHANNEL__, __COMPARE__)
 Set the TIM Capture Compare Register value on runtime without calling another time ConfigChannel function.
#define __HAL_TIM_GET_COMPARE(__HANDLE__, __CHANNEL__)
 Get the TIM Capture Compare Register value on runtime.
#define __HAL_TIM_ENABLE_OCxPRELOAD(__HANDLE__, __CHANNEL__)
 Set the TIM Output compare preload.
#define __HAL_TIM_DISABLE_OCxPRELOAD(__HANDLE__, __CHANNEL__)
 Reset the TIM Output compare preload.
#define __HAL_TIM_ENABLE_OCxFAST(__HANDLE__, __CHANNEL__)
 Enable fast mode for a given channel.
#define __HAL_TIM_DISABLE_OCxFAST(__HANDLE__, __CHANNEL__)
 Disable fast mode for a given channel.
#define __HAL_TIM_URS_ENABLE(__HANDLE__)
 Set the Update Request Source (URS) bit of the TIMx_CR1 register.
#define __HAL_TIM_URS_DISABLE(__HANDLE__)
 Reset the Update Request Source (URS) bit of the TIMx_CR1 register.
#define __HAL_TIM_SET_CAPTUREPOLARITY(__HANDLE__, __CHANNEL__, __POLARITY__)
 Set the TIM Capture x input polarity on runtime.
#define __HAL_TIM_SELECT_CCDMAREQUEST(__HANDLE__, __CCDMA__)
 Select the Capture/compare DMA request source.
#define TIM_CCER_CCxE_MASK   ((uint32_t)(TIM_CCER_CC1E | TIM_CCER_CC2E | TIM_CCER_CC3E | TIM_CCER_CC4E))
#define TIM_CCER_CCxNE_MASK   ((uint32_t)(TIM_CCER_CC1NE | TIM_CCER_CC2NE | TIM_CCER_CC3NE))
#define IS_TIM_CLEARINPUT_SOURCE(__MODE__)
#define IS_TIM_DMA_BASE(__BASE__)
#define IS_TIM_EVENT_SOURCE(__SOURCE__)
#define IS_TIM_COUNTER_MODE(__MODE__)
#define IS_TIM_UIFREMAP_MODE(__MODE__)
#define IS_TIM_CLOCKDIVISION_DIV(__DIV__)
#define IS_TIM_AUTORELOAD_PRELOAD(PRELOAD)
#define IS_TIM_FAST_STATE(__STATE__)
#define IS_TIM_OC_POLARITY(__POLARITY__)
#define IS_TIM_OCN_POLARITY(__POLARITY__)
#define IS_TIM_OCIDLE_STATE(__STATE__)
#define IS_TIM_OCNIDLE_STATE(__STATE__)
#define IS_TIM_ENCODERINPUT_POLARITY(__POLARITY__)
#define IS_TIM_IC_POLARITY(__POLARITY__)
#define IS_TIM_IC_SELECTION(__SELECTION__)
#define IS_TIM_IC_PRESCALER(__PRESCALER__)
#define IS_TIM_CCX_CHANNEL(__INSTANCE__, __CHANNEL__)
#define IS_TIM_OPM_MODE(__MODE__)
#define IS_TIM_ENCODER_MODE(__MODE__)
#define IS_TIM_DMA_SOURCE(__SOURCE__)
#define IS_TIM_CHANNELS(__CHANNEL__)
#define IS_TIM_OPM_CHANNELS(__CHANNEL__)
#define IS_TIM_PERIOD(__HANDLE__, __PERIOD__)
#define IS_TIM_COMPLEMENTARY_CHANNELS(__CHANNEL__)
#define IS_TIM_CLOCKSOURCE(__CLOCK__)
#define IS_TIM_CLOCKPOLARITY(__POLARITY__)
#define IS_TIM_CLOCKPRESCALER(__PRESCALER__)
#define IS_TIM_CLOCKFILTER(__ICFILTER__)
#define IS_TIM_CLEARINPUT_POLARITY(__POLARITY__)
#define IS_TIM_CLEARINPUT_PRESCALER(__PRESCALER__)
#define IS_TIM_CLEARINPUT_FILTER(__ICFILTER__)
#define IS_TIM_OSSR_STATE(__STATE__)
#define IS_TIM_OSSI_STATE(__STATE__)
#define IS_TIM_LOCK_LEVEL(__LEVEL__)
#define IS_TIM_BREAK_FILTER(__BRKFILTER__)
#define IS_TIM_BREAK_STATE(__STATE__)
#define IS_TIM_BREAK_POLARITY(__POLARITY__)
#define IS_TIM_BREAK2_STATE(__STATE__)
#define IS_TIM_BREAK2_POLARITY(__POLARITY__)
#define IS_TIM_AUTOMATIC_OUTPUT_STATE(__STATE__)
#define IS_TIM_GROUPCH5(__OCREF__)
#define IS_TIM_TRGO_SOURCE(__SOURCE__)
#define IS_TIM_TRGO2_SOURCE(__SOURCE__)
#define IS_TIM_MSM_STATE(__STATE__)
#define IS_TIM_SLAVE_MODE(__MODE__)
#define IS_TIM_PWM_MODE(__MODE__)
#define IS_TIM_OC_MODE(__MODE__)
#define IS_TIM_TRIGGER_SELECTION(__SELECTION__)
#define IS_TIM_INTERNAL_TRIGGEREVENT_SELECTION(__SELECTION__)
#define IS_TIM_TRIGGERPOLARITY(__POLARITY__)
#define IS_TIM_TRIGGERPRESCALER(__PRESCALER__)
#define IS_TIM_TRIGGERFILTER(__ICFILTER__)
#define IS_TIM_TI1SELECTION(__TI1SELECTION__)
#define IS_TIM_DMA_LENGTH(__LENGTH__)
#define IS_TIM_DMA_DATA_LENGTH(LENGTH)
#define IS_TIM_IC_FILTER(__ICFILTER__)
#define IS_TIM_DEADTIME(__DEADTIME__)
#define IS_TIM_BREAK_SYSTEM(__CONFIG__)
#define IS_TIM_SLAVEMODE_TRIGGER_ENABLED(__TRIGGER__)
#define TIM_SET_ICPRESCALERVALUE(__HANDLE__, __CHANNEL__, __ICPSC__)
#define TIM_RESET_ICPRESCALERVALUE(__HANDLE__, __CHANNEL__)
#define TIM_SET_CAPTUREPOLARITY(__HANDLE__, __CHANNEL__, __POLARITY__)
#define TIM_RESET_CAPTUREPOLARITY(__HANDLE__, __CHANNEL__)
#define TIM_CHANNEL_STATE_GET(__HANDLE__, __CHANNEL__)
#define TIM_CHANNEL_STATE_SET(__HANDLE__, __CHANNEL__, __CHANNEL_STATE__)
#define TIM_CHANNEL_STATE_SET_ALL(__HANDLE__, __CHANNEL_STATE__)
#define TIM_CHANNEL_N_STATE_GET(__HANDLE__, __CHANNEL__)
#define TIM_CHANNEL_N_STATE_SET(__HANDLE__, __CHANNEL__, __CHANNEL_STATE__)
#define TIM_CHANNEL_N_STATE_SET_ALL(__HANDLE__, __CHANNEL_STATE__)
enum  HAL_TIM_StateTypeDef {
  HAL_TIM_STATE_RESET = 0x00U , HAL_TIM_STATE_READY = 0x01U , HAL_TIM_STATE_BUSY = 0x02U , HAL_TIM_STATE_TIMEOUT = 0x03U ,
  HAL_TIM_STATE_ERROR = 0x04U
 HAL State structures definition. More...
enum  HAL_TIM_ChannelStateTypeDef { HAL_TIM_CHANNEL_STATE_RESET = 0x00U , HAL_TIM_CHANNEL_STATE_READY = 0x01U , HAL_TIM_CHANNEL_STATE_BUSY = 0x02U }
 TIM Channel States definition. More...
enum  HAL_TIM_DMABurstStateTypeDef { HAL_DMA_BURST_STATE_RESET = 0x00U , HAL_DMA_BURST_STATE_READY = 0x01U , HAL_DMA_BURST_STATE_BUSY = 0x02U }
 DMA Burst States definition. More...
enum  HAL_TIM_ActiveChannel {
  HAL_TIM_ACTIVE_CHANNEL_1 = 0x01U , HAL_TIM_ACTIVE_CHANNEL_2 = 0x02U , HAL_TIM_ACTIVE_CHANNEL_3 = 0x04U , HAL_TIM_ACTIVE_CHANNEL_4 = 0x08U ,
  HAL_TIM_ACTIVE_CHANNEL_5 = 0x10U , HAL_TIM_ACTIVE_CHANNEL_6 = 0x20U , HAL_TIM_ACTIVE_CHANNEL_CLEARED = 0x00U
 HAL Active channel structures definition. More...
HAL_StatusTypeDef HAL_TIM_Base_Init (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_Base_DeInit (TIM_HandleTypeDef *htim)
void HAL_TIM_Base_MspInit (TIM_HandleTypeDef *htim)
void HAL_TIM_Base_MspDeInit (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_Base_Start (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_Base_Stop (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_Base_Start_IT (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_Base_Stop_IT (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_Base_Start_DMA (TIM_HandleTypeDef *htim, const uint32_t *pData, uint16_t Length)
HAL_StatusTypeDef HAL_TIM_Base_Stop_DMA (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_OC_Init (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_OC_DeInit (TIM_HandleTypeDef *htim)
void HAL_TIM_OC_MspInit (TIM_HandleTypeDef *htim)
void HAL_TIM_OC_MspDeInit (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_OC_Start (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_OC_Stop (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_OC_Start_IT (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_OC_Stop_IT (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_OC_Start_DMA (TIM_HandleTypeDef *htim, uint32_t Channel, const uint32_t *pData, uint16_t Length)
HAL_StatusTypeDef HAL_TIM_OC_Stop_DMA (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_PWM_Init (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_PWM_DeInit (TIM_HandleTypeDef *htim)
void HAL_TIM_PWM_MspInit (TIM_HandleTypeDef *htim)
void HAL_TIM_PWM_MspDeInit (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_PWM_Start (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_PWM_Stop (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_PWM_Start_IT (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_PWM_Stop_IT (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_PWM_Start_DMA (TIM_HandleTypeDef *htim, uint32_t Channel, const uint32_t *pData, uint16_t Length)
HAL_StatusTypeDef HAL_TIM_PWM_Stop_DMA (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_IC_Init (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_IC_DeInit (TIM_HandleTypeDef *htim)
void HAL_TIM_IC_MspInit (TIM_HandleTypeDef *htim)
void HAL_TIM_IC_MspDeInit (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_IC_Start (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_IC_Stop (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_IC_Start_IT (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_IC_Stop_IT (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_IC_Start_DMA (TIM_HandleTypeDef *htim, uint32_t Channel, uint32_t *pData, uint16_t Length)
HAL_StatusTypeDef HAL_TIM_IC_Stop_DMA (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_OnePulse_Init (TIM_HandleTypeDef *htim, uint32_t OnePulseMode)
HAL_StatusTypeDef HAL_TIM_OnePulse_DeInit (TIM_HandleTypeDef *htim)
void HAL_TIM_OnePulse_MspInit (TIM_HandleTypeDef *htim)
void HAL_TIM_OnePulse_MspDeInit (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_OnePulse_Start (TIM_HandleTypeDef *htim, uint32_t OutputChannel)
HAL_StatusTypeDef HAL_TIM_OnePulse_Stop (TIM_HandleTypeDef *htim, uint32_t OutputChannel)
HAL_StatusTypeDef HAL_TIM_OnePulse_Start_IT (TIM_HandleTypeDef *htim, uint32_t OutputChannel)
HAL_StatusTypeDef HAL_TIM_OnePulse_Stop_IT (TIM_HandleTypeDef *htim, uint32_t OutputChannel)
HAL_StatusTypeDef HAL_TIM_Encoder_Init (TIM_HandleTypeDef *htim, const TIM_Encoder_InitTypeDef *sConfig)
HAL_StatusTypeDef HAL_TIM_Encoder_DeInit (TIM_HandleTypeDef *htim)
void HAL_TIM_Encoder_MspInit (TIM_HandleTypeDef *htim)
void HAL_TIM_Encoder_MspDeInit (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_Encoder_Start (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_Encoder_Stop (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_Encoder_Start_IT (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_Encoder_Stop_IT (TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_Encoder_Start_DMA (TIM_HandleTypeDef *htim, uint32_t Channel, uint32_t *pData1, uint32_t *pData2, uint16_t Length)
HAL_StatusTypeDef HAL_TIM_Encoder_Stop_DMA (TIM_HandleTypeDef *htim, uint32_t Channel)
void HAL_TIM_IRQHandler (TIM_HandleTypeDef *htim)
HAL_StatusTypeDef HAL_TIM_OC_ConfigChannel (TIM_HandleTypeDef *htim, const TIM_OC_InitTypeDef *sConfig, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_PWM_ConfigChannel (TIM_HandleTypeDef *htim, const TIM_OC_InitTypeDef *sConfig, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_IC_ConfigChannel (TIM_HandleTypeDef *htim, const TIM_IC_InitTypeDef *sConfig, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_OnePulse_ConfigChannel (TIM_HandleTypeDef *htim, TIM_OnePulse_InitTypeDef *sConfig, uint32_t OutputChannel, uint32_t InputChannel)
HAL_StatusTypeDef HAL_TIM_ConfigOCrefClear (TIM_HandleTypeDef *htim, const TIM_ClearInputConfigTypeDef *sClearInputConfig, uint32_t Channel)
HAL_StatusTypeDef HAL_TIM_ConfigClockSource (TIM_HandleTypeDef *htim, const TIM_ClockConfigTypeDef *sClockSourceConfig)
HAL_StatusTypeDef HAL_TIM_ConfigTI1Input (TIM_HandleTypeDef *htim, uint32_t TI1_Selection)
HAL_StatusTypeDef HAL_TIM_SlaveConfigSynchro (TIM_HandleTypeDef *htim, const TIM_SlaveConfigTypeDef *sSlaveConfig)
HAL_StatusTypeDef HAL_TIM_SlaveConfigSynchro_IT (TIM_HandleTypeDef *htim, const TIM_SlaveConfigTypeDef *sSlaveConfig)
HAL_StatusTypeDef HAL_TIM_DMABurst_WriteStart (TIM_HandleTypeDef *htim, uint32_t BurstBaseAddress, uint32_t BurstRequestSrc, const uint32_t *BurstBuffer, uint32_t BurstLength)
HAL_StatusTypeDef HAL_TIM_DMABurst_MultiWriteStart (TIM_HandleTypeDef *htim, uint32_t BurstBaseAddress, uint32_t BurstRequestSrc, const uint32_t *BurstBuffer, uint32_t BurstLength, uint32_t DataLength)
HAL_StatusTypeDef HAL_TIM_DMABurst_WriteStop (TIM_HandleTypeDef *htim, uint32_t BurstRequestSrc)
HAL_StatusTypeDef HAL_TIM_DMABurst_ReadStart (TIM_HandleTypeDef *htim, uint32_t BurstBaseAddress, uint32_t BurstRequestSrc, uint32_t *BurstBuffer, uint32_t BurstLength)
HAL_StatusTypeDef HAL_TIM_DMABurst_MultiReadStart (TIM_HandleTypeDef *htim, uint32_t BurstBaseAddress, uint32_t BurstRequestSrc, uint32_t *BurstBuffer, uint32_t BurstLength, uint32_t DataLength)
HAL_StatusTypeDef HAL_TIM_DMABurst_ReadStop (TIM_HandleTypeDef *htim, uint32_t BurstRequestSrc)
HAL_StatusTypeDef HAL_TIM_GenerateEvent (TIM_HandleTypeDef *htim, uint32_t EventSource)
uint32_t HAL_TIM_ReadCapturedValue (const TIM_HandleTypeDef *htim, uint32_t Channel)
void HAL_TIM_PeriodElapsedCallback (TIM_HandleTypeDef *htim)
 Period elapsed callback in non blocking mode.
void HAL_TIM_PeriodElapsedHalfCpltCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_OC_DelayElapsedCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_IC_CaptureCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_IC_CaptureHalfCpltCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_PWM_PulseFinishedCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_PWM_PulseFinishedHalfCpltCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_TriggerCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_TriggerHalfCpltCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_ErrorCallback (TIM_HandleTypeDef *htim)
HAL_TIM_StateTypeDef HAL_TIM_Base_GetState (const TIM_HandleTypeDef *htim)
HAL_TIM_StateTypeDef HAL_TIM_OC_GetState (const TIM_HandleTypeDef *htim)
HAL_TIM_StateTypeDef HAL_TIM_PWM_GetState (const TIM_HandleTypeDef *htim)
HAL_TIM_StateTypeDef HAL_TIM_IC_GetState (const TIM_HandleTypeDef *htim)
HAL_TIM_StateTypeDef HAL_TIM_OnePulse_GetState (const TIM_HandleTypeDef *htim)
HAL_TIM_StateTypeDef HAL_TIM_Encoder_GetState (const TIM_HandleTypeDef *htim)
HAL_TIM_ActiveChannel HAL_TIM_GetActiveChannel (const TIM_HandleTypeDef *htim)
HAL_TIM_ChannelStateTypeDef HAL_TIM_GetChannelState (const TIM_HandleTypeDef *htim, uint32_t Channel)
HAL_TIM_DMABurstStateTypeDef HAL_TIM_DMABurstState (const TIM_HandleTypeDef *htim)
void TIM_Base_SetConfig (TIM_TypeDef *TIMx, const TIM_Base_InitTypeDef *Structure)
void TIM_TI1_SetConfig (TIM_TypeDef *TIMx, uint32_t TIM_ICPolarity, uint32_t TIM_ICSelection, uint32_t TIM_ICFilter)
void TIM_OC2_SetConfig (TIM_TypeDef *TIMx, const TIM_OC_InitTypeDef *OC_Config)
void TIM_ETR_SetConfig (TIM_TypeDef *TIMx, uint32_t TIM_ExtTRGPrescaler, uint32_t TIM_ExtTRGPolarity, uint32_t ExtTRGFilter)
void TIM_DMADelayPulseHalfCplt (DMA_HandleTypeDef *hdma)
void TIM_DMAError (DMA_HandleTypeDef *hdma)
void TIM_DMACaptureCplt (DMA_HandleTypeDef *hdma)
void TIM_DMACaptureHalfCplt (DMA_HandleTypeDef *hdma)
void TIM_CCxChannelCmd (TIM_TypeDef *TIMx, uint32_t Channel, uint32_t ChannelState)
Author
MCD Application Team
Attention
