RTEMS 6.3
TIM Callbacks functions. More...
void HAL_TIM_PeriodElapsedCallback (TIM_HandleTypeDef *htim)
 Period elapsed callback in non blocking mode.
void HAL_TIM_PeriodElapsedHalfCpltCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_OC_DelayElapsedCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_IC_CaptureCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_IC_CaptureHalfCpltCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_PWM_PulseFinishedCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_PWM_PulseFinishedHalfCpltCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_TriggerCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_TriggerHalfCpltCallback (TIM_HandleTypeDef *htim)
void HAL_TIM_ErrorCallback (TIM_HandleTypeDef *htim)
◆ HAL_TIM_PeriodElapsedCallback()
void HAL_TIM_PeriodElapsedCallback ( TIM_HandleTypeDef * htim)
Note
This function is called when TIM6 interrupt took place, inside HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment a global variable "uwTick" used as application time base.
Parameters
htimTIM handle
Return values
None
