RTEMS 6.3
| #define | IS_TIM_CLEARINPUT_SOURCE(__MODE__) |
| #define | IS_TIM_DMA_BASE(__BASE__) |
| #define | IS_TIM_EVENT_SOURCE(__SOURCE__) |
| #define | IS_TIM_COUNTER_MODE(__MODE__) |
| #define | IS_TIM_UIFREMAP_MODE(__MODE__) |
| #define | IS_TIM_CLOCKDIVISION_DIV(__DIV__) |
| #define | IS_TIM_AUTORELOAD_PRELOAD(PRELOAD) |
| #define | IS_TIM_FAST_STATE(__STATE__) |
| #define | IS_TIM_OC_POLARITY(__POLARITY__) |
| #define | IS_TIM_OCN_POLARITY(__POLARITY__) |
| #define | IS_TIM_OCIDLE_STATE(__STATE__) |
| #define | IS_TIM_OCNIDLE_STATE(__STATE__) |
| #define | IS_TIM_ENCODERINPUT_POLARITY(__POLARITY__) |
| #define | IS_TIM_IC_POLARITY(__POLARITY__) |
| #define | IS_TIM_IC_SELECTION(__SELECTION__) |
| #define | IS_TIM_IC_PRESCALER(__PRESCALER__) |
| #define | IS_TIM_CCX_CHANNEL(__INSTANCE__, __CHANNEL__) |
| #define | IS_TIM_OPM_MODE(__MODE__) |
| #define | IS_TIM_ENCODER_MODE(__MODE__) |
| #define | IS_TIM_DMA_SOURCE(__SOURCE__) |
| #define | IS_TIM_CHANNELS(__CHANNEL__) |
| #define | IS_TIM_OPM_CHANNELS(__CHANNEL__) |
| #define | IS_TIM_PERIOD(__HANDLE__, __PERIOD__) |
| #define | IS_TIM_COMPLEMENTARY_CHANNELS(__CHANNEL__) |
| #define | IS_TIM_CLOCKSOURCE(__CLOCK__) |
| #define | IS_TIM_CLOCKPOLARITY(__POLARITY__) |
| #define | IS_TIM_CLOCKPRESCALER(__PRESCALER__) |
| #define | IS_TIM_CLOCKFILTER(__ICFILTER__) |
| #define | IS_TIM_CLEARINPUT_POLARITY(__POLARITY__) |
| #define | IS_TIM_CLEARINPUT_PRESCALER(__PRESCALER__) |
| #define | IS_TIM_CLEARINPUT_FILTER(__ICFILTER__) |
| #define | IS_TIM_OSSR_STATE(__STATE__) |
| #define | IS_TIM_OSSI_STATE(__STATE__) |
| #define | IS_TIM_LOCK_LEVEL(__LEVEL__) |
| #define | IS_TIM_BREAK_FILTER(__BRKFILTER__) |
| #define | IS_TIM_BREAK_STATE(__STATE__) |
| #define | IS_TIM_BREAK_POLARITY(__POLARITY__) |
| #define | IS_TIM_BREAK2_STATE(__STATE__) |
| #define | IS_TIM_BREAK2_POLARITY(__POLARITY__) |
| #define | IS_TIM_AUTOMATIC_OUTPUT_STATE(__STATE__) |
| #define | IS_TIM_GROUPCH5(__OCREF__) |
| #define | IS_TIM_TRGO_SOURCE(__SOURCE__) |
| #define | IS_TIM_TRGO2_SOURCE(__SOURCE__) |
| #define | IS_TIM_MSM_STATE(__STATE__) |
| #define | IS_TIM_SLAVE_MODE(__MODE__) |
| #define | IS_TIM_PWM_MODE(__MODE__) |
| #define | IS_TIM_OC_MODE(__MODE__) |
| #define | IS_TIM_TRIGGER_SELECTION(__SELECTION__) |
| #define | IS_TIM_INTERNAL_TRIGGEREVENT_SELECTION(__SELECTION__) |
| #define | IS_TIM_TRIGGERPOLARITY(__POLARITY__) |
| #define | IS_TIM_TRIGGERPRESCALER(__PRESCALER__) |
| #define | IS_TIM_TRIGGERFILTER(__ICFILTER__) |
| #define | IS_TIM_TI1SELECTION(__TI1SELECTION__) |
| #define | IS_TIM_DMA_LENGTH(__LENGTH__) |
| #define | IS_TIM_DMA_DATA_LENGTH(LENGTH) |
| #define | IS_TIM_IC_FILTER(__ICFILTER__) |
| #define | IS_TIM_DEADTIME(__DEADTIME__) |
| #define | IS_TIM_BREAK_SYSTEM(__CONFIG__) |
| #define | IS_TIM_SLAVEMODE_TRIGGER_ENABLED(__TRIGGER__) |
| #define | TIM_SET_ICPRESCALERVALUE(__HANDLE__, __CHANNEL__, __ICPSC__) |
| #define | TIM_RESET_ICPRESCALERVALUE(__HANDLE__, __CHANNEL__) |
| #define | TIM_SET_CAPTUREPOLARITY(__HANDLE__, __CHANNEL__, __POLARITY__) |
| #define | TIM_RESET_CAPTUREPOLARITY(__HANDLE__, __CHANNEL__) |
| #define | TIM_CHANNEL_STATE_GET(__HANDLE__, __CHANNEL__) |
| #define | TIM_CHANNEL_STATE_SET(__HANDLE__, __CHANNEL__, __CHANNEL_STATE__) |
| #define | TIM_CHANNEL_STATE_SET_ALL(__HANDLE__, __CHANNEL_STATE__) |
| #define | TIM_CHANNEL_N_STATE_GET(__HANDLE__, __CHANNEL__) |
| #define | TIM_CHANNEL_N_STATE_SET(__HANDLE__, __CHANNEL__, __CHANNEL_STATE__) |
| #define | TIM_CHANNEL_N_STATE_SET_ALL(__HANDLE__, __CHANNEL_STATE__) |
| #define IS_TIM_AUTOMATIC_OUTPUT_STATE | ( | __STATE__ | ) |
| #define IS_TIM_AUTORELOAD_PRELOAD | ( | PRELOAD | ) |
| #define IS_TIM_BREAK2_POLARITY | ( | __POLARITY__ | ) |
| #define IS_TIM_BREAK2_STATE | ( | __STATE__ | ) |
| #define IS_TIM_BREAK_FILTER | ( | __BRKFILTER__ | ) |
| #define IS_TIM_BREAK_POLARITY | ( | __POLARITY__ | ) |
| #define IS_TIM_BREAK_STATE | ( | __STATE__ | ) |
| #define IS_TIM_BREAK_SYSTEM | ( | __CONFIG__ | ) |
| #define IS_TIM_CCX_CHANNEL | ( | __INSTANCE__, | |
| __CHANNEL__ ) |
| #define IS_TIM_CHANNELS | ( | __CHANNEL__ | ) |
| #define IS_TIM_CLEARINPUT_FILTER | ( | __ICFILTER__ | ) |
| #define IS_TIM_CLEARINPUT_POLARITY | ( | __POLARITY__ | ) |
| #define IS_TIM_CLEARINPUT_PRESCALER | ( | __PRESCALER__ | ) |
| #define IS_TIM_CLEARINPUT_SOURCE | ( | __MODE__ | ) |
| #define IS_TIM_CLOCKDIVISION_DIV | ( | __DIV__ | ) |
| #define IS_TIM_CLOCKFILTER | ( | __ICFILTER__ | ) |
| #define IS_TIM_CLOCKPOLARITY | ( | __POLARITY__ | ) |
| #define IS_TIM_CLOCKPRESCALER | ( | __PRESCALER__ | ) |
| #define IS_TIM_CLOCKSOURCE | ( | __CLOCK__ | ) |
| #define IS_TIM_COMPLEMENTARY_CHANNELS | ( | __CHANNEL__ | ) |
| #define IS_TIM_COUNTER_MODE | ( | __MODE__ | ) |
| #define IS_TIM_DEADTIME | ( | __DEADTIME__ | ) |
| #define IS_TIM_DMA_BASE | ( | __BASE__ | ) |
| #define IS_TIM_DMA_DATA_LENGTH | ( | LENGTH | ) |
| #define IS_TIM_DMA_LENGTH | ( | __LENGTH__ | ) |
| #define IS_TIM_DMA_SOURCE | ( | __SOURCE__ | ) |
| #define IS_TIM_ENCODER_MODE | ( | __MODE__ | ) |
| #define IS_TIM_ENCODERINPUT_POLARITY | ( | __POLARITY__ | ) |
| #define IS_TIM_EVENT_SOURCE | ( | __SOURCE__ | ) |
| #define IS_TIM_FAST_STATE | ( | __STATE__ | ) |
| #define IS_TIM_GROUPCH5 | ( | __OCREF__ | ) |
| #define IS_TIM_IC_FILTER | ( | __ICFILTER__ | ) |
| #define IS_TIM_IC_POLARITY | ( | __POLARITY__ | ) |
| #define IS_TIM_IC_PRESCALER | ( | __PRESCALER__ | ) |
| #define IS_TIM_IC_SELECTION | ( | __SELECTION__ | ) |
| #define IS_TIM_INTERNAL_TRIGGEREVENT_SELECTION | ( | __SELECTION__ | ) |
| #define IS_TIM_LOCK_LEVEL | ( | __LEVEL__ | ) |
| #define IS_TIM_MSM_STATE | ( | __STATE__ | ) |
| #define IS_TIM_OC_MODE | ( | __MODE__ | ) |
| #define IS_TIM_OC_POLARITY | ( | __POLARITY__ | ) |
| #define IS_TIM_OCIDLE_STATE | ( | __STATE__ | ) |
| #define IS_TIM_OCN_POLARITY | ( | __POLARITY__ | ) |
| #define IS_TIM_OCNIDLE_STATE | ( | __STATE__ | ) |
| #define IS_TIM_OPM_CHANNELS | ( | __CHANNEL__ | ) |
| #define IS_TIM_OPM_MODE | ( | __MODE__ | ) |
| #define IS_TIM_OSSI_STATE | ( | __STATE__ | ) |
| #define IS_TIM_OSSR_STATE | ( | __STATE__ | ) |
| #define IS_TIM_PERIOD | ( | __HANDLE__, | |
| __PERIOD__ ) |
| #define IS_TIM_PWM_MODE | ( | __MODE__ | ) |
| #define IS_TIM_SLAVE_MODE | ( | __MODE__ | ) |
| #define IS_TIM_SLAVEMODE_TRIGGER_ENABLED | ( | __TRIGGER__ | ) |
| #define IS_TIM_TI1SELECTION | ( | __TI1SELECTION__ | ) |
| #define IS_TIM_TRGO2_SOURCE | ( | __SOURCE__ | ) |
| #define IS_TIM_TRGO_SOURCE | ( | __SOURCE__ | ) |
| #define IS_TIM_TRIGGER_SELECTION | ( | __SELECTION__ | ) |
| #define IS_TIM_TRIGGERFILTER | ( | __ICFILTER__ | ) |
| #define IS_TIM_TRIGGERPOLARITY | ( | __POLARITY__ | ) |
| #define IS_TIM_TRIGGERPRESCALER | ( | __PRESCALER__ | ) |
| #define IS_TIM_UIFREMAP_MODE | ( | __MODE__ | ) |
| #define TIM_CHANNEL_N_STATE_GET | ( | __HANDLE__, | |
| __CHANNEL__ ) |
| #define TIM_CHANNEL_N_STATE_SET | ( | __HANDLE__, | |
| __CHANNEL__, | |||
| __CHANNEL_STATE__ ) |
| #define TIM_CHANNEL_N_STATE_SET_ALL | ( | __HANDLE__, | |
| #define TIM_CHANNEL_STATE_GET | ( | __HANDLE__, | |
| __CHANNEL__ ) |
| #define TIM_CHANNEL_STATE_SET | ( | __HANDLE__, | |
| __CHANNEL__, | |||
| #define TIM_CHANNEL_STATE_SET_ALL | ( | __HANDLE__, | |
| #define TIM_RESET_CAPTUREPOLARITY | ( | __HANDLE__, | |
| __CHANNEL__ ) |
| #define TIM_RESET_ICPRESCALERVALUE | ( | __HANDLE__, | |
| __CHANNEL__ ) |
| #define TIM_SET_CAPTUREPOLARITY | ( | __HANDLE__, | |
| __CHANNEL__, | |||
| __POLARITY__ ) |
| #define TIM_SET_ICPRESCALERVALUE | ( | __HANDLE__, | |
| __CHANNEL__, | |||
| __ICPSC__ ) |
