RTEMS 6.3
stm32h7xx_hal_sd.h File Reference
Header file of SD HAL module. More...
struct  HAL_SD_CardInfoTypeDef
 SD Card Information Structure definition. More...
struct  SD_HandleTypeDef
 SD handle Structure definition. More...
struct  HAL_SD_CardCSDTypeDef
struct  HAL_SD_CardCIDTypeDef
struct  HAL_SD_CardStatusTypeDef
#define HAL_SD_CARD_READY   0x00000001U
#define HAL_SD_CARD_IDENTIFICATION   0x00000002U
#define HAL_SD_CARD_STANDBY   0x00000003U
#define HAL_SD_CARD_TRANSFER   0x00000004U
#define HAL_SD_CARD_SENDING   0x00000005U
#define HAL_SD_CARD_RECEIVING   0x00000006U
#define HAL_SD_CARD_PROGRAMMING   0x00000007U
#define HAL_SD_CARD_DISCONNECTED   0x00000008U
#define HAL_SD_CARD_ERROR   0x000000FFU
#define SD_InitTypeDef   SDMMC_InitTypeDef
#define SD_TypeDef   SDMMC_TypeDef
#define BLOCKSIZE   ((uint32_t)512U)
#define HAL_SD_ERROR_NONE   SDMMC_ERROR_NONE
#define HAL_SD_ERROR_CMD_CRC_FAIL   SDMMC_ERROR_CMD_CRC_FAIL
#define HAL_SD_ERROR_DATA_CRC_FAIL   SDMMC_ERROR_DATA_CRC_FAIL
#define HAL_SD_ERROR_CMD_RSP_TIMEOUT   SDMMC_ERROR_CMD_RSP_TIMEOUT
#define HAL_SD_ERROR_DATA_TIMEOUT   SDMMC_ERROR_DATA_TIMEOUT
#define HAL_SD_ERROR_TX_UNDERRUN   SDMMC_ERROR_TX_UNDERRUN
#define HAL_SD_ERROR_RX_OVERRUN   SDMMC_ERROR_RX_OVERRUN
#define HAL_SD_ERROR_ADDR_MISALIGNED   SDMMC_ERROR_ADDR_MISALIGNED
#define HAL_SD_ERROR_BLOCK_LEN_ERR   SDMMC_ERROR_BLOCK_LEN_ERR
#define HAL_SD_ERROR_ERASE_SEQ_ERR   SDMMC_ERROR_ERASE_SEQ_ERR
#define HAL_SD_ERROR_BAD_ERASE_PARAM   SDMMC_ERROR_BAD_ERASE_PARAM
#define HAL_SD_ERROR_WRITE_PROT_VIOLATION   SDMMC_ERROR_WRITE_PROT_VIOLATION
#define HAL_SD_ERROR_LOCK_UNLOCK_FAILED   SDMMC_ERROR_LOCK_UNLOCK_FAILED
#define HAL_SD_ERROR_COM_CRC_FAILED   SDMMC_ERROR_COM_CRC_FAILED
#define HAL_SD_ERROR_ILLEGAL_CMD   SDMMC_ERROR_ILLEGAL_CMD
#define HAL_SD_ERROR_CARD_ECC_FAILED   SDMMC_ERROR_CARD_ECC_FAILED
#define HAL_SD_ERROR_CC_ERR   SDMMC_ERROR_CC_ERR
#define HAL_SD_ERROR_GENERAL_UNKNOWN_ERR   SDMMC_ERROR_GENERAL_UNKNOWN_ERR
#define HAL_SD_ERROR_STREAM_READ_UNDERRUN   SDMMC_ERROR_STREAM_READ_UNDERRUN
#define HAL_SD_ERROR_STREAM_WRITE_OVERRUN   SDMMC_ERROR_STREAM_WRITE_OVERRUN
#define HAL_SD_ERROR_CID_CSD_OVERWRITE   SDMMC_ERROR_CID_CSD_OVERWRITE
#define HAL_SD_ERROR_WP_ERASE_SKIP   SDMMC_ERROR_WP_ERASE_SKIP
#define HAL_SD_ERROR_CARD_ECC_DISABLED   SDMMC_ERROR_CARD_ECC_DISABLED
#define HAL_SD_ERROR_ERASE_RESET   SDMMC_ERROR_ERASE_RESET
#define HAL_SD_ERROR_AKE_SEQ_ERR   SDMMC_ERROR_AKE_SEQ_ERR
#define HAL_SD_ERROR_INVALID_VOLTRANGE   SDMMC_ERROR_INVALID_VOLTRANGE
#define HAL_SD_ERROR_ADDR_OUT_OF_RANGE   SDMMC_ERROR_ADDR_OUT_OF_RANGE
#define HAL_SD_ERROR_REQUEST_NOT_APPLICABLE   SDMMC_ERROR_REQUEST_NOT_APPLICABLE
#define HAL_SD_ERROR_PARAM   SDMMC_ERROR_INVALID_PARAMETER
#define HAL_SD_ERROR_UNSUPPORTED_FEATURE   SDMMC_ERROR_UNSUPPORTED_FEATURE
#define HAL_SD_ERROR_BUSY   SDMMC_ERROR_BUSY
#define HAL_SD_ERROR_DMA   SDMMC_ERROR_DMA
#define HAL_SD_ERROR_TIMEOUT   SDMMC_ERROR_TIMEOUT
#define SD_CONTEXT_NONE   ((uint32_t)0x00000000U)
#define SD_CONTEXT_READ_SINGLE_BLOCK   ((uint32_t)0x00000001U)
#define SD_CONTEXT_READ_MULTIPLE_BLOCK   ((uint32_t)0x00000002U)
#define SD_CONTEXT_WRITE_SINGLE_BLOCK   ((uint32_t)0x00000010U)
#define SD_CONTEXT_WRITE_MULTIPLE_BLOCK   ((uint32_t)0x00000020U)
#define SD_CONTEXT_IT   ((uint32_t)0x00000008U)
#define SD_CONTEXT_DMA   ((uint32_t)0x00000080U)
#define CARD_NORMAL_SPEED   ((uint32_t)0x00000000U)
#define CARD_HIGH_SPEED   ((uint32_t)0x00000100U)
#define CARD_ULTRA_HIGH_SPEED   ((uint32_t)0x00000200U)
#define CARD_SDSC   ((uint32_t)0x00000000U)
#define CARD_SDHC_SDXC   ((uint32_t)0x00000001U)
#define CARD_SECURED   ((uint32_t)0x00000003U)
#define CARD_V1_X   ((uint32_t)0x00000000U)
#define CARD_V2_X   ((uint32_t)0x00000001U)
#define __HAL_SD_RESET_HANDLE_STATE(__HANDLE__)
 Reset SD handle state.
#define __HAL_SD_ENABLE_IT(__HANDLE__, __INTERRUPT__)
 Enable the SD device interrupt.
#define __HAL_SD_DISABLE_IT(__HANDLE__, __INTERRUPT__)
 Disable the SD device interrupt.
#define __HAL_SD_GET_FLAG(__HANDLE__, __FLAG__)
 Check whether the specified SD flag is set or not.
#define __HAL_SD_CLEAR_FLAG(__HANDLE__, __FLAG__)
 Clear the SD's pending flags.
#define __HAL_SD_GET_IT(__HANDLE__, __INTERRUPT__)
 Check whether the specified SD interrupt has occurred or not.
#define __HAL_SD_CLEAR_IT(__HANDLE__, __INTERRUPT__)
 Clear the SD's interrupt pending bits.
typedef uint32_t HAL_SD_CardStateTypeDef
enum  HAL_SD_StateTypeDef {
  HAL_SD_STATE_RESET = ((uint32_t)0x00000000U) , HAL_SD_STATE_READY = ((uint32_t)0x00000001U) , HAL_SD_STATE_TIMEOUT = ((uint32_t)0x00000002U) , HAL_SD_STATE_BUSY = ((uint32_t)0x00000003U) ,
  HAL_SD_STATE_PROGRAMMING = ((uint32_t)0x00000004U) , HAL_SD_STATE_RECEIVING = ((uint32_t)0x00000005U) , HAL_SD_STATE_TRANSFER = ((uint32_t)0x00000006U) , HAL_SD_STATE_ERROR = ((uint32_t)0x0000000FU)
HAL_StatusTypeDef HAL_SD_Init (SD_HandleTypeDef *hsd)
HAL_StatusTypeDef HAL_SD_InitCard (SD_HandleTypeDef *hsd)
HAL_StatusTypeDef HAL_SD_DeInit (SD_HandleTypeDef *hsd)
void HAL_SD_MspInit (SD_HandleTypeDef *hsd)
void HAL_SD_MspDeInit (SD_HandleTypeDef *hsd)
HAL_StatusTypeDef HAL_SD_ReadBlocks (SD_HandleTypeDef *hsd, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks, uint32_t Timeout)
HAL_StatusTypeDef HAL_SD_WriteBlocks (SD_HandleTypeDef *hsd, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks, uint32_t Timeout)
HAL_StatusTypeDef HAL_SD_Erase (SD_HandleTypeDef *hsd, uint32_t BlockStartAdd, uint32_t BlockEndAdd)
HAL_StatusTypeDef HAL_SD_ReadBlocks_IT (SD_HandleTypeDef *hsd, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks)
HAL_StatusTypeDef HAL_SD_WriteBlocks_IT (SD_HandleTypeDef *hsd, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks)
HAL_StatusTypeDef HAL_SD_ReadBlocks_DMA (SD_HandleTypeDef *hsd, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks)
HAL_StatusTypeDef HAL_SD_WriteBlocks_DMA (SD_HandleTypeDef *hsd, const uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks)
void HAL_SD_IRQHandler (SD_HandleTypeDef *hsd)
void HAL_SD_TxCpltCallback (SD_HandleTypeDef *hsd)
void HAL_SD_RxCpltCallback (SD_HandleTypeDef *hsd)
void HAL_SD_ErrorCallback (SD_HandleTypeDef *hsd)
void HAL_SD_AbortCallback (SD_HandleTypeDef *hsd)
HAL_StatusTypeDef HAL_SD_ConfigWideBusOperation (SD_HandleTypeDef *hsd, uint32_t WideMode)
HAL_StatusTypeDef HAL_SD_ConfigSpeedBusOperation (SD_HandleTypeDef *hsd, uint32_t SpeedMode)
HAL_SD_CardStateTypeDef HAL_SD_GetCardState (SD_HandleTypeDef *hsd)
HAL_StatusTypeDef HAL_SD_GetCardCID (SD_HandleTypeDef *hsd, HAL_SD_CardCIDTypeDef *pCID)
HAL_StatusTypeDef HAL_SD_GetCardCSD (SD_HandleTypeDef *hsd, HAL_SD_CardCSDTypeDef *pCSD)
HAL_StatusTypeDef HAL_SD_GetCardStatus (SD_HandleTypeDef *hsd, HAL_SD_CardStatusTypeDef *pStatus)
HAL_StatusTypeDef HAL_SD_GetCardInfo (SD_HandleTypeDef *hsd, HAL_SD_CardInfoTypeDef *pCardInfo)
HAL_SD_StateTypeDef HAL_SD_GetState (SD_HandleTypeDef *hsd)
uint32_t HAL_SD_GetError (SD_HandleTypeDef *hsd)
HAL_StatusTypeDef HAL_SD_Abort (SD_HandleTypeDef *hsd)
HAL_StatusTypeDef HAL_SD_Abort_IT (SD_HandleTypeDef *hsd)
Author
MCD Application Team
Attention
