macros to handle interrupts and specific clock configurations
More...
◆ __HAL_SD_CLEAR_FLAG
| #define __HAL_SD_CLEAR_FLAG |
| __HANDLE__, |
| __FLAG__ ) |
Value:
#define __SDMMC_CLEAR_FLAG(__INSTANCE__, __FLAG__)
Clears the SDMMC pending flags.
Definition stm32h7xx_ll_sdmmc.h:866
Clear the SD's pending flags.
- Parameters
| __HANDLE__ | SD Handle. |
| __FLAG__ | specifies the flag to clear. This parameter can be one or a combination of the following values:
- SDMMC_FLAG_CCRCFAIL: Command response received (CRC check failed)
- SDMMC_FLAG_DCRCFAIL: Data block sent/received (CRC check failed)
- SDMMC_FLAG_CTIMEOUT: Command response timeout
- SDMMC_FLAG_DTIMEOUT: Data timeout
- SDMMC_FLAG_TXUNDERR: Transmit FIFO underrun error
- SDMMC_FLAG_RXOVERR: Received FIFO overrun error
- SDMMC_FLAG_CMDREND: Command response received (CRC check passed)
- SDMMC_FLAG_CMDSENT: Command sent (no response required)
- SDMMC_FLAG_DATAEND: Data end (data counter, DATACOUNT, is zero)
- SDMMC_FLAG_DHOLD: Data transfer Hold
- SDMMC_FLAG_DBCKEND: Data block sent/received (CRC check passed)
- SDMMC_FLAG_DABORT: Data transfer aborted by CMD12
- SDMMC_FLAG_BUSYD0END: End of SDMMC_D0 Busy following a CMD response detected
- SDMMC_FLAG_SDIOIT: SDIO interrupt received
- SDMMC_FLAG_ACKFAIL: Boot Acknowledgment received
- SDMMC_FLAG_ACKTIMEOUT: Boot Acknowledgment timeout
- SDMMC_FLAG_VSWEND: Voltage switch critical timing section completion
- SDMMC_FLAG_CKSTOP: SDMMC_CK stopped in Voltage switch procedure
- SDMMC_FLAG_IDMATE: IDMA transfer error
- SDMMC_FLAG_IDMABTC: IDMA buffer transfer complete
- Return values
◆ __HAL_SD_CLEAR_IT
| #define __HAL_SD_CLEAR_IT |
| __HANDLE__, |
| __INTERRUPT__ ) |
Value:
#define __SDMMC_CLEAR_IT(__INSTANCE__, __INTERRUPT__)
Clears the SDMMC's interrupt pending bits.
Definition stm32h7xx_ll_sdmmc.h:926
Clear the SD's interrupt pending bits.
- Parameters
| __INTERRUPT__ | specifies the interrupt pending bit to clear. This parameter can be one or a combination of the following values:
- SDMMC_IT_CCRCFAIL: Command response received (CRC check failed) interrupt
- SDMMC_IT_DCRCFAIL: Data block sent/received (CRC check failed) interrupt
- SDMMC_IT_CTIMEOUT: Command response timeout interrupt
- SDMMC_IT_DTIMEOUT: Data timeout interrupt
- SDMMC_IT_TXUNDERR: Transmit FIFO underrun error interrupt
- SDMMC_IT_RXOVERR: Received FIFO overrun error interrupt
- SDMMC_IT_CMDREND: Command response received (CRC check passed) interrupt
- SDMMC_IT_CMDSENT: Command sent (no response required) interrupt
- SDMMC_IT_DATAEND: Data end (data counter, DATACOUNT, is zero) interrupt
- SDMMC_IT_DHOLD: Data transfer Hold interrupt
- SDMMC_IT_DBCKEND: Data block sent/received (CRC check passed) interrupt
- SDMMC_IT_DABORT: Data transfer aborted by CMD12 interrupt
- SDMMC_IT_BUSYD0END: End of SDMMC_D0 Busy following a CMD response detected interrupt
- SDMMC_IT_SDIOIT: SDIO interrupt received interrupt
- SDMMC_IT_ACKFAIL: Boot Acknowledgment received interrupt
- SDMMC_IT_ACKTIMEOUT: Boot Acknowledgment timeout interrupt
- SDMMC_IT_VSWEND: Voltage switch critical timing section completion interrupt
- SDMMC_IT_CKSTOP: SDMMC_CK stopped in Voltage switch procedure interrupt
- SDMMC_IT_IDMABTC: IDMA buffer transfer complete interrupt
- Return values
◆ __HAL_SD_DISABLE_IT
| #define __HAL_SD_DISABLE_IT |
| __HANDLE__, |
| __INTERRUPT__ ) |
Value:
#define __SDMMC_DISABLE_IT(__INSTANCE__, __INTERRUPT__)
Disable the SDMMC device interrupt.
Definition stm32h7xx_ll_sdmmc.h:798
Disable the SD device interrupt.
- Parameters
| __INTERRUPT__ | specifies the SDMMC interrupt sources to be disabled. This parameter can be one or a combination of the following values:
- SDMMC_IT_TXFIFOHE: Transmit FIFO Half Empty interrupt
- SDMMC_IT_RXFIFOHF: Receive FIFO Half Full interrupt
- SDMMC_IT_RXFIFOF: Receive FIFO full interrupt
- SDMMC_IT_TXFIFOE: Transmit FIFO empty interrupt
- Return values
◆ __HAL_SD_ENABLE_IT
| #define __HAL_SD_ENABLE_IT |
| __HANDLE__, |
| __INTERRUPT__ ) |
Value:
#define __SDMMC_ENABLE_IT(__INSTANCE__, __INTERRUPT__)
Enable the SDMMC device interrupt.
Definition stm32h7xx_ll_sdmmc.h:766
Enable the SD device interrupt.
- Parameters
| __INTERRUPT__ | specifies the SDMMC interrupt sources to be enabled. This parameter can be one or a combination of the following values:
- Return values
◆ __HAL_SD_GET_FLAG
| #define __HAL_SD_GET_FLAG |
| __HANDLE__, |
| __FLAG__ ) |
Value:
#define __SDMMC_GET_FLAG(__INSTANCE__, __FLAG__)
Checks whether the specified SDMMC flag is set or not.
Definition stm32h7xx_ll_sdmmc.h:836
Check whether the specified SD flag is set or not.
- Parameters
| __FLAG__ | specifies the flag to check. This parameter can be one of the following values:
- SDMMC_FLAG_DPSMACT: Data path state machine active
- SDMMC_FLAG_CPSMACT: Command path state machine active
- SDMMC_FLAG_TXFIFOHE: Transmit FIFO Half Empty
- SDMMC_FLAG_RXFIFOHF: Receive FIFO Half Full
- SDMMC_FLAG_TXFIFOF: Transmit FIFO full
- SDMMC_FLAG_RXFIFOF: Receive FIFO full
- SDMMC_FLAG_TXFIFOE: Transmit FIFO empty
- SDMMC_FLAG_RXFIFOE: Receive FIFO empty
- SDMMC_FLAG_BUSYD0: Inverted value of SDMMC_D0 line (Busy)
- Return values
| The | new state of SD FLAG (SET or RESET). |
◆ __HAL_SD_GET_IT
| #define __HAL_SD_GET_IT |
| __HANDLE__, |
| __INTERRUPT__ ) |
Value:
#define __SDMMC_GET_IT(__INSTANCE__, __INTERRUPT__)
Checks whether the specified SDMMC interrupt has occurred or not.
Definition stm32h7xx_ll_sdmmc.h:898
Check whether the specified SD interrupt has occurred or not.
- Parameters
| __INTERRUPT__ | specifies the SDMMC interrupt source to check. This parameter can be one of the following values:
- Return values
| The | new state of SD IT (SET or RESET). |
◆ __HAL_SD_RESET_HANDLE_STATE
| #define __HAL_SD_RESET_HANDLE_STATE |
| __HANDLE__ | ) |
Value:
@ HAL_SD_STATE_RESET
Definition stm32h7xx_hal_sd.h:55
Reset SD handle state.
- Parameters
- Return values
