RTEMS 6.3
#define SD_CONTEXT_NONE   ((uint32_t)0x00000000U)
#define SD_CONTEXT_READ_SINGLE_BLOCK   ((uint32_t)0x00000001U)
#define SD_CONTEXT_READ_MULTIPLE_BLOCK   ((uint32_t)0x00000002U)
#define SD_CONTEXT_WRITE_SINGLE_BLOCK   ((uint32_t)0x00000010U)
#define SD_CONTEXT_WRITE_MULTIPLE_BLOCK   ((uint32_t)0x00000020U)
#define SD_CONTEXT_IT   ((uint32_t)0x00000008U)
#define SD_CONTEXT_DMA   ((uint32_t)0x00000080U)
◆ SD_CONTEXT_DMA
Process in DMA mode
◆ SD_CONTEXT_IT
Process in Interrupt mode
◆ SD_CONTEXT_NONE
None
◆ SD_CONTEXT_READ_MULTIPLE_BLOCK
Read multiple blocks operation
◆ SD_CONTEXT_READ_SINGLE_BLOCK
Read single block operation
◆ SD_CONTEXT_WRITE_MULTIPLE_BLOCK
Write multiple blocks operation
◆ SD_CONTEXT_WRITE_SINGLE_BLOCK
Write single block operation
