RTEMS
6.3
Toggle main menu visibility
bsps
arm
tms570
include
bsp
ti_herc
reg_n2het.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
/* The header file is generated by make_header.py from N2HET.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_NHET
50
#define LIBBSP_ARM_TMS570_NHET
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t GCR;
/*Global Configuration Register*/
56
uint32_t PFR;
/*Prescale Factor Register*/
57
uint32_t ADDR;
/*NHET Current Address Register*/
58
uint32_t OFF1;
/*Offset Index Priority Level 1 Register*/
59
uint32_t OFF2;
/*Offset Index Priority Level 2 Register*/
60
uint32_t INTENAS;
/*Interrupt Enable Set Register*/
61
uint32_t INTENAC;
/*Interrupt Enable Clear Register*/
62
uint32_t EXC1;
/*Exception Control Register 1*/
63
uint32_t EXC2;
/*Exception Control Register 2*/
64
uint32_t PRY;
/*Interrupt Priority Register*/
65
uint32_t FLG;
/*Interrupt Flag Register*/
66
uint32_t AND;
/*AND Share Control Register*/
67
uint8_t reserved1 [4];
68
uint32_t HRSH;
/*HR Share Control Register*/
69
uint32_t XOR;
/*HR XOR-Share Control Register*/
70
uint32_t REQENS;
/*Request Enable Set Register*/
71
uint32_t REQENC;
/*Request Enable Clear Register*/
72
uint32_t REQDS;
/*Request Destination Select Register*/
73
uint8_t reserved2 [4];
74
uint32_t DIR;
/*NHET Direction Register*/
75
uint32_t DIN;
/*NHET Data Input Register*/
76
uint32_t DOUT;
/*NHET Data Output Register*/
77
uint32_t DSET;
/*NHET Data Set Register*/
78
uint32_t DCLR;
/*NHET Data Clear Register*/
79
uint32_t PDR;
/*NHET Open Drain Register*/
80
uint32_t PULDIS;
/*NHET Pull Disable Register*/
81
uint32_t PSL;
/*NHET Pull Select Register*/
82
uint8_t reserved3 [8];
83
uint32_t PCR;
/*Parity Control Register*/
84
uint32_t PAR;
/*Parity Address Register*/
85
uint32_t PPR;
/*Parity Pin Register*/
86
uint32_t SFPRLD;
/*Suppression Filter Preload Register*/
87
uint32_t SFENA;
/*Suppression Filter Enable Register*/
88
uint8_t reserved4 [4];
89
uint32_t LBPSEL;
/*Loop Back Pair Select Register*/
90
uint32_t LBPDIR;
/*Loop Back Pair Direction Register*/
91
uint32_t PINDIS;
/*NHET Pin Disable Register*/
92
tms570_nhet_t
93
94
95
/*----------------------TMS570_NHET_GCR----------------------*/
96
/* field: HET_PIN_ENA - Enables the output buffers of the pin structures depending on the value of nDIS and DIR. */
97
#define TMS570_NHET_GCR_HET_PIN_ENA BSP_BIT32(24)
98
99
/* field: MP - Master Priority */
100
#define TMS570_NHET_GCR_MP(val) BSP_FLD32(val,21, 22)
101
#define TMS570_NHET_GCR_MP_GET(reg) BSP_FLD32GET(reg,21, 22)
102
#define TMS570_NHET_GCR_MP_SET(reg,val) BSP_FLD32SET(reg, val,21, 22)
103
104
/* field: PPF - Protect Program Fields */
105
#define TMS570_NHET_GCR_PPF BSP_BIT32(18)
106
107
/* field: IS - Ignore Suspend */
108
#define TMS570_NHET_GCR_IS BSP_BIT32(17)
109
110
/* field: CMS - Clk_master/slave */
111
#define TMS570_NHET_GCR_CMS BSP_BIT32(16)
112
113
114
/*----------------------TMS570_NHET_PFR----------------------*/
115
/* field: LRPFC - oop Resolution Pre-scale Factor Code */
116
#define TMS570_NHET_PFR_LRPFC(val) BSP_FLD32(val,8, 10)
117
#define TMS570_NHET_PFR_LRPFC_GET(reg) BSP_FLD32GET(reg,8, 10)
118
#define TMS570_NHET_PFR_LRPFC_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
119
120
/* field: HRPFC - High Resolution Pre-scale Factor Code */
121
#define TMS570_NHET_PFR_HRPFC(val) BSP_FLD32(val,0, 5)
122
#define TMS570_NHET_PFR_HRPFC_GET(reg) BSP_FLD32GET(reg,0, 5)
123
#define TMS570_NHET_PFR_HRPFC_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
124
125
126
/*----------------------TMS570_NHET_ADDR----------------------*/
127
/* field: HETADDR - N2HET Current Address */
128
#define TMS570_NHET_ADDR_HETADDR(val) BSP_FLD32(val,0, 8)
129
#define TMS570_NHET_ADDR_HETADDR_GET(reg) BSP_FLD32GET(reg,0, 8)
130
#define TMS570_NHET_ADDR_HETADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
131
132
133
/*----------------------TMS570_NHET_OFF1----------------------*/
134
/* field: OFFSET1 - HETOFF1[5:0] indexes the currently pending high-priority interrupt. */
135
#define TMS570_NHET_OFF1_OFFSET1(val) BSP_FLD32(val,0, 5)
136
#define TMS570_NHET_OFF1_OFFSET1_GET(reg) BSP_FLD32GET(reg,0, 5)
137
#define TMS570_NHET_OFF1_OFFSET1_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
138
139
140
/*----------------------TMS570_NHET_OFF2----------------------*/
141
/* field: OFFSET2 - HETOFF2[5:0] indexes the currently pending low-priority interrupt. */
142
#define TMS570_NHET_OFF2_OFFSET2(val) BSP_FLD32(val,0, 5)
143
#define TMS570_NHET_OFF2_OFFSET2_GET(reg) BSP_FLD32GET(reg,0, 5)
144
#define TMS570_NHET_OFF2_OFFSET2_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
145
146
147
/*--------------------TMS570_NHET_INTENAS--------------------*/
148
/* field: HETINTENAS - Interrupt Enable Set bits. HETINTENAS is readable and writable in any operation mode. */
149
/* Whole 32 bits */
150
151
/*--------------------TMS570_NHET_INTENAC--------------------*/
152
/* field: HETINTENAC - Interrupt Enable Clear bits. HETINTENAC is readable and writable in any operation mode. */
153
/* Whole 32 bits */
154
155
/*----------------------TMS570_NHET_EXC1----------------------*/
156
/* field: APCNT_OVRFL_ENA - APCNT Overflow Enable */
157
#define TMS570_NHET_EXC1_APCNT_OVRFL_ENA BSP_BIT32(24)
158
159
/* field: APCNT_UNRFL_ENA - APCNT Underflow Enable */
160
#define TMS570_NHET_EXC1_APCNT_UNRFL_ENA BSP_BIT32(16)
161
162
/* field: PRGM_OVRFL_ENA - Program Overflow Enable */
163
#define TMS570_NHET_EXC1_PRGM_OVRFL_ENA BSP_BIT32(8)
164
165
/* field: APCNT_OVRFL_PRY - APCNT Overflow Exception Interrupt Priority */
166
#define TMS570_NHET_EXC1_APCNT_OVRFL_PRY BSP_BIT32(2)
167
168
/* field: APCNT_UNRFL_PRY - APCNT Underflow Exception Interrupt Priority */
169
#define TMS570_NHET_EXC1_APCNT_UNRFL_PRY BSP_BIT32(1)
170
171
/* field: PRGM_OVRFL_PRY - ProgramOverflow Exception Interrupt Priority */
172
#define TMS570_NHET_EXC1_PRGM_OVRFL_PRY BSP_BIT32(0)
173
174
175
/*----------------------TMS570_NHET_EXC2----------------------*/
176
/* field: DEBUG_STATUS_FLAG - Debug Status Flag. */
177
#define TMS570_NHET_EXC2_DEBUG_STATUS_FLAG BSP_BIT32(8)
178
179
/* field: APCNT_OVRFL_FLAG - APCNT Overflow Flag */
180
#define TMS570_NHET_EXC2_APCNT_OVRFL_FLAG BSP_BIT32(2)
181
182
/* field: APCNT_UNDFL_FLAG - APCNT Underflow Flag */
183
#define TMS570_NHET_EXC2_APCNT_UNDFL_FLAG BSP_BIT32(1)
184
185
/* field: PRGM_OVERFL_FLAG - Program Overflow Flag */
186
#define TMS570_NHET_EXC2_PRGM_OVERFL_FLAG BSP_BIT32(0)
187
188
189
/*----------------------TMS570_NHET_PRY----------------------*/
190
/* field: HETPRY - HET Interrupt Priority Level bits */
191
/* Whole 32 bits */
192
193
/*----------------------TMS570_NHET_FLG----------------------*/
194
/* field: HETFLAG - Interrupt Flag Register Bits */
195
/* Whole 32 bits */
196
197
/*----------------------TMS570_NHET_AND----------------------*/
198
/* field: AND_SHARE - AND Share Enable */
199
#define TMS570_NHET_AND_AND_SHARE(val) BSP_FLD32(val,0, 15)
200
#define TMS570_NHET_AND_AND_SHARE_GET(reg) BSP_FLD32GET(reg,0, 15)
201
#define TMS570_NHET_AND_AND_SHARE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
202
203
204
/*----------------------TMS570_NHET_HRSH----------------------*/
205
/* field: HR_SHARE - HR Share Bits */
206
#define TMS570_NHET_HRSH_HR_SHARE(val) BSP_FLD32(val,0, 15)
207
#define TMS570_NHET_HRSH_HR_SHARE_GET(reg) BSP_FLD32GET(reg,0, 15)
208
#define TMS570_NHET_HRSH_HR_SHARE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
209
210
211
/*----------------------TMS570_NHET_XOR----------------------*/
212
/* field: XOR_SHARE - XOR Share Enable */
213
#define TMS570_NHET_XOR_XOR_SHARE(val) BSP_FLD32(val,0, 15)
214
#define TMS570_NHET_XOR_XOR_SHARE_GET(reg) BSP_FLD32GET(reg,0, 15)
215
#define TMS570_NHET_XOR_XOR_SHARE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
216
217
218
/*---------------------TMS570_NHET_REQENS---------------------*/
219
/* field: REQ_ENA_n - Request Enable Bits */
220
#define TMS570_NHET_REQENS_REQ_ENA_n(val) BSP_FLD32(val,0, 7)
221
#define TMS570_NHET_REQENS_REQ_ENA_n_GET(reg) BSP_FLD32GET(reg,0, 7)
222
#define TMS570_NHET_REQENS_REQ_ENA_n_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
223
224
225
/*---------------------TMS570_NHET_REQENC---------------------*/
226
/* field: REQ_DIS_n - Request Disable Bits */
227
#define TMS570_NHET_REQENC_REQ_DIS_n(val) BSP_FLD32(val,0, 7)
228
#define TMS570_NHET_REQENC_REQ_DIS_n_GET(reg) BSP_FLD32GET(reg,0, 7)
229
#define TMS570_NHET_REQENC_REQ_DIS_n_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
230
231
232
/*---------------------TMS570_NHET_REQDS---------------------*/
233
/* field: TDBS_n - HTU, DMA or Both Select Bits */
234
#define TMS570_NHET_REQDS_TDBS_n(val) BSP_FLD32(val,16, 23)
235
#define TMS570_NHET_REQDS_TDBS_n_GET(reg) BSP_FLD32GET(reg,16, 23)
236
#define TMS570_NHET_REQDS_TDBS_n_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
237
238
/* field: TDS_n - HTU or DMA Select Bits */
239
#define TMS570_NHET_REQDS_TDS_n(val) BSP_FLD32(val,0, 7)
240
#define TMS570_NHET_REQDS_TDS_n_GET(reg) BSP_FLD32GET(reg,0, 7)
241
#define TMS570_NHET_REQDS_TDS_n_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
242
243
244
/*----------------------TMS570_NHET_DIR----------------------*/
245
/* field: HETDIR_n - Data direction of NHET pins */
246
/* Whole 32 bits */
247
248
/*----------------------TMS570_NHET_DIN----------------------*/
249
/* field: HETDIN_n - Data input. This bit displays the logic state of the pin. */
250
/* Whole 32 bits */
251
252
/*----------------------TMS570_NHET_DOUT----------------------*/
253
/* field: HETDOUT_n - Data out write. Writes to this bit will only take effect when the pin is configured as an output. */
254
/* Whole 32 bits */
255
256
/*----------------------TMS570_NHET_DSET----------------------*/
257
/* field: HETDSET_n - This register allows bits of HETDOUT to be set while avoiding the pitfalls of a readmodify- write */
258
/* Whole 32 bits */
259
260
/*----------------------TMS570_NHET_DCLR----------------------*/
261
/* field: HETDCLR_n - This register allows bits of HETDOUT to be cleared while avoiding the pitfalls of a read-modifywrite */
262
/* Whole 32 bits */
263
264
/*----------------------TMS570_NHET_PDR----------------------*/
265
/* field: HETPDR_n - Open drain control for HET[n] pins */
266
/* Whole 32 bits */
267
268
/*---------------------TMS570_NHET_PULDIS---------------------*/
269
/* field: HETPULDIS_n - Pull disable for N2HET pins */
270
/* Whole 32 bits */
271
272
/*----------------------TMS570_NHET_PSL----------------------*/
273
/* field: HETPSL_n - Pull select for NHET pins */
274
/* Whole 32 bits */
275
276
/*----------------------TMS570_NHET_PCR----------------------*/
277
/* field: TEST - Test Bit. */
278
#define TMS570_NHET_PCR_TEST BSP_BIT32(8)
279
280
/* field: PARITY_ENA - Enable/disable parity checking. */
281
#define TMS570_NHET_PCR_PARITY_ENA(val) BSP_FLD32(val,0, 3)
282
#define TMS570_NHET_PCR_PARITY_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
283
#define TMS570_NHET_PCR_PARITY_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
284
285
286
/*----------------------TMS570_NHET_PAR----------------------*/
287
/* field: PAOFF - Parity Error Address Offset. */
288
#define TMS570_NHET_PAR_PAOFF(val) BSP_FLD32(val,2, 12)
289
#define TMS570_NHET_PAR_PAOFF_GET(reg) BSP_FLD32GET(reg,2, 12)
290
#define TMS570_NHET_PAR_PAOFF_SET(reg,val) BSP_FLD32SET(reg, val,2, 12)
291
292
293
/*----------------------TMS570_NHET_PPR----------------------*/
294
/* field: HETPPR_n - NHET Parity Pin Select Bits - Allows HET[n] pins to be configured to drive to a known state when */
295
/* Whole 32 bits */
296
297
/*---------------------TMS570_NHET_SFPRLD---------------------*/
298
/* field: CCDIV - Counter Clock Divider */
299
#define TMS570_NHET_SFPRLD_CCDIV(val) BSP_FLD32(val,16, 17)
300
#define TMS570_NHET_SFPRLD_CCDIV_GET(reg) BSP_FLD32GET(reg,16, 17)
301
#define TMS570_NHET_SFPRLD_CCDIV_SET(reg,val) BSP_FLD32SET(reg, val,16, 17)
302
303
/* field: CPRLD - Counter Preload Value */
304
#define TMS570_NHET_SFPRLD_CPRLD(val) BSP_FLD32(val,0, 9)
305
#define TMS570_NHET_SFPRLD_CPRLD_GET(reg) BSP_FLD32GET(reg,0, 9)
306
#define TMS570_NHET_SFPRLD_CPRLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
307
308
309
/*---------------------TMS570_NHET_SFENA---------------------*/
310
/* field: HETSFENA_n - Suppression Filter Enable Bits */
311
/* Whole 32 bits */
312
313
/*---------------------TMS570_NHET_LBPSEL---------------------*/
314
/* field: LBPTYPE - Loop Back Pair Type Select Bits */
315
#define TMS570_NHET_LBPSEL_LBPTYPE(val) BSP_FLD32(val,16, 31)
316
#define TMS570_NHET_LBPSEL_LBPTYPE_GET(reg) BSP_FLD32GET(reg,16, 31)
317
#define TMS570_NHET_LBPSEL_LBPTYPE_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
318
319
/* field: LBPSEL - Loop Back Pair Select Bits */
320
#define TMS570_NHET_LBPSEL_LBPSEL(val) BSP_FLD32(val,0, 15)
321
#define TMS570_NHET_LBPSEL_LBPSEL_GET(reg) BSP_FLD32GET(reg,0, 15)
322
#define TMS570_NHET_LBPSEL_LBPSEL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
323
324
325
/*---------------------TMS570_NHET_LBPDIR---------------------*/
326
/* field: LBPTSTENA - Loopback Test Enable Key */
327
#define TMS570_NHET_LBPDIR_LBPTSTENA(val) BSP_FLD32(val,16, 19)
328
#define TMS570_NHET_LBPDIR_LBPTSTENA_GET(reg) BSP_FLD32GET(reg,16, 19)
329
#define TMS570_NHET_LBPDIR_LBPTSTENA_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
330
331
/* field: LBPDIR - Loop Back Pair Direction Bits */
332
#define TMS570_NHET_LBPDIR_LBPDIR(val) BSP_FLD32(val,0, 15)
333
#define TMS570_NHET_LBPDIR_LBPDIR_GET(reg) BSP_FLD32GET(reg,0, 15)
334
#define TMS570_NHET_LBPDIR_LBPDIR_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
335
336
337
/*---------------------TMS570_NHET_PINDIS---------------------*/
338
/* field: HETPINDIS_n - N2HET Pin Disable Bits */
339
/* Whole 32 bits */
340
341
342
#endif
/* LIBBSP_ARM_TMS570_NHET */
utility.h
This header file provides utility macros for BSPs.
tms570_nhet_t
Definition
reg_n2het.h:54
