#define | TMS570_NHET_GCR_HET_PIN_ENA BSP_BIT32(24) |
| #define | TMS570_NHET_GCR_MP(val) |
| #define | TMS570_NHET_GCR_MP_GET(reg) |
| #define | TMS570_NHET_GCR_MP_SET(reg, val) |
#define | TMS570_NHET_GCR_PPF BSP_BIT32(18) |
#define | TMS570_NHET_GCR_IS BSP_BIT32(17) |
#define | TMS570_NHET_GCR_CMS BSP_BIT32(16) |
| #define | TMS570_NHET_PFR_LRPFC(val) |
| #define | TMS570_NHET_PFR_LRPFC_GET(reg) |
| #define | TMS570_NHET_PFR_LRPFC_SET(reg, val) |
| #define | TMS570_NHET_PFR_HRPFC(val) |
| #define | TMS570_NHET_PFR_HRPFC_GET(reg) |
| #define | TMS570_NHET_PFR_HRPFC_SET(reg, val) |
| #define | TMS570_NHET_ADDR_HETADDR(val) |
| #define | TMS570_NHET_ADDR_HETADDR_GET(reg) |
| #define | TMS570_NHET_ADDR_HETADDR_SET(reg, val) |
| #define | TMS570_NHET_OFF1_OFFSET1(val) |
| #define | TMS570_NHET_OFF1_OFFSET1_GET(reg) |
| #define | TMS570_NHET_OFF1_OFFSET1_SET(reg, val) |
| #define | TMS570_NHET_OFF2_OFFSET2(val) |
| #define | TMS570_NHET_OFF2_OFFSET2_GET(reg) |
| #define | TMS570_NHET_OFF2_OFFSET2_SET(reg, val) |
#define | TMS570_NHET_EXC1_APCNT_OVRFL_ENA BSP_BIT32(24) |
#define | TMS570_NHET_EXC1_APCNT_UNRFL_ENA BSP_BIT32(16) |
#define | TMS570_NHET_EXC1_PRGM_OVRFL_ENA BSP_BIT32(8) |
#define | TMS570_NHET_EXC1_APCNT_OVRFL_PRY BSP_BIT32(2) |
#define | TMS570_NHET_EXC1_APCNT_UNRFL_PRY BSP_BIT32(1) |
#define | TMS570_NHET_EXC1_PRGM_OVRFL_PRY BSP_BIT32(0) |
#define | TMS570_NHET_EXC2_DEBUG_STATUS_FLAG BSP_BIT32(8) |
#define | TMS570_NHET_EXC2_APCNT_OVRFL_FLAG BSP_BIT32(2) |
#define | TMS570_NHET_EXC2_APCNT_UNDFL_FLAG BSP_BIT32(1) |
#define | TMS570_NHET_EXC2_PRGM_OVERFL_FLAG BSP_BIT32(0) |
| #define | TMS570_NHET_AND_AND_SHARE(val) |
| #define | TMS570_NHET_AND_AND_SHARE_GET(reg) |
| #define | TMS570_NHET_AND_AND_SHARE_SET(reg, val) |
| #define | TMS570_NHET_HRSH_HR_SHARE(val) |
| #define | TMS570_NHET_HRSH_HR_SHARE_GET(reg) |
| #define | TMS570_NHET_HRSH_HR_SHARE_SET(reg, val) |
| #define | TMS570_NHET_XOR_XOR_SHARE(val) |
| #define | TMS570_NHET_XOR_XOR_SHARE_GET(reg) |
| #define | TMS570_NHET_XOR_XOR_SHARE_SET(reg, val) |
| #define | TMS570_NHET_REQENS_REQ_ENA_n(val) |
| #define | TMS570_NHET_REQENS_REQ_ENA_n_GET(reg) |
| #define | TMS570_NHET_REQENS_REQ_ENA_n_SET(reg, val) |
| #define | TMS570_NHET_REQENC_REQ_DIS_n(val) |
| #define | TMS570_NHET_REQENC_REQ_DIS_n_GET(reg) |
| #define | TMS570_NHET_REQENC_REQ_DIS_n_SET(reg, val) |
| #define | TMS570_NHET_REQDS_TDBS_n(val) |
| #define | TMS570_NHET_REQDS_TDBS_n_GET(reg) |
| #define | TMS570_NHET_REQDS_TDBS_n_SET(reg, val) |
| #define | TMS570_NHET_REQDS_TDS_n(val) |
| #define | TMS570_NHET_REQDS_TDS_n_GET(reg) |
| #define | TMS570_NHET_REQDS_TDS_n_SET(reg, val) |
#define | TMS570_NHET_PCR_TEST BSP_BIT32(8) |
| #define | TMS570_NHET_PCR_PARITY_ENA(val) |
| #define | TMS570_NHET_PCR_PARITY_ENA_GET(reg) |
| #define | TMS570_NHET_PCR_PARITY_ENA_SET(reg, val) |
| #define | TMS570_NHET_PAR_PAOFF(val) |
| #define | TMS570_NHET_PAR_PAOFF_GET(reg) |
| #define | TMS570_NHET_PAR_PAOFF_SET(reg, val) |
| #define | TMS570_NHET_SFPRLD_CCDIV(val) |
| #define | TMS570_NHET_SFPRLD_CCDIV_GET(reg) |
| #define | TMS570_NHET_SFPRLD_CCDIV_SET(reg, val) |
| #define | TMS570_NHET_SFPRLD_CPRLD(val) |
| #define | TMS570_NHET_SFPRLD_CPRLD_GET(reg) |
| #define | TMS570_NHET_SFPRLD_CPRLD_SET(reg, val) |
| #define | TMS570_NHET_LBPSEL_LBPTYPE(val) |
| #define | TMS570_NHET_LBPSEL_LBPTYPE_GET(reg) |
| #define | TMS570_NHET_LBPSEL_LBPTYPE_SET(reg, val) |
| #define | TMS570_NHET_LBPSEL_LBPSEL(val) |
| #define | TMS570_NHET_LBPSEL_LBPSEL_GET(reg) |
| #define | TMS570_NHET_LBPSEL_LBPSEL_SET(reg, val) |
| #define | TMS570_NHET_LBPDIR_LBPTSTENA(val) |
| #define | TMS570_NHET_LBPDIR_LBPTSTENA_GET(reg) |
| #define | TMS570_NHET_LBPDIR_LBPTSTENA_SET(reg, val) |
| #define | TMS570_NHET_LBPDIR_LBPDIR(val) |
| #define | TMS570_NHET_LBPDIR_LBPDIR_GET(reg) |
| #define | TMS570_NHET_LBPDIR_LBPDIR_SET(reg, val) |
This header file provides N2HET interfaces.
