RTEMS 6.3
This header file provides utility macros for BSPs. More...
#include <stdint.h>Go to the source code of this file.
| #define | BSP_BIT8(bit) |
| #define | BSP_MSK8(first_bit, last_bit) |
| #define | BSP_FLD8(val, first_bit, last_bit) |
| #define | BSP_FLD8GET(reg, first_bit, last_bit) |
| #define | BSP_FLD8SET(reg, val, first_bit, last_bit) |
| #define | BSP_BIT16(bit) |
| #define | BSP_MSK16(first_bit, last_bit) |
| #define | BSP_FLD16(val, first_bit, last_bit) |
| #define | BSP_FLD16GET(reg, first_bit, last_bit) |
| #define | BSP_FLD16SET(reg, val, first_bit, last_bit) |
| #define | BSP_BIT32(bit) |
| #define | BSP_MSK32(first_bit, last_bit) |
| #define | BSP_FLD32(val, first_bit, last_bit) |
| #define | BSP_FLD32GET(reg, first_bit, last_bit) |
| #define | BSP_FLD32SET(reg, val, first_bit, last_bit) |
| #define | BSP_BIT64(bit) |
| #define | BSP_MSK64(first_bit, last_bit) |
| #define | BSP_FLD64(val, first_bit, last_bit) |
| #define | BSP_FLD64GET(reg, first_bit, last_bit) |
| #define | BSP_FLD64SET(reg, val, first_bit, last_bit) |
| #define | BSP_BBIT8(bit) |
| #define | BSP_BMSK8(first_bit, last_bit) |
| #define | BSP_BFLD8(val, first_bit, last_bit) |
| #define | BSP_BFLD8GET(reg, first_bit, last_bit) |
| #define | BSP_BFLD8SET(reg, val, first_bit, last_bit) |
| #define | BSP_BBIT16(bit) |
| #define | BSP_BMSK16(first_bit, last_bit) |
| #define | BSP_BFLD16(val, first_bit, last_bit) |
| #define | BSP_BFLD16GET(reg, first_bit, last_bit) |
| #define | BSP_BFLD16SET(reg, val, first_bit, last_bit) |
| #define | BSP_BBIT32(bit) |
| #define | BSP_BMSK32(first_bit, last_bit) |
| #define | BSP_BFLD32(val, first_bit, last_bit) |
| #define | BSP_BFLD32GET(reg, first_bit, last_bit) |
| #define | BSP_BFLD32SET(reg, val, first_bit, last_bit) |
| #define | BSP_BBIT64(bit) |
| #define | BSP_BMSK64(first_bit, last_bit) |
| #define | BSP_BFLD64(val, first_bit, last_bit) |
| #define | BSP_BFLD64GET(reg, first_bit, last_bit) |
| #define | BSP_BFLD64SET(reg, val, first_bit, last_bit) |
| #define BSP_BBIT16 | ( | bit | ) |
| #define BSP_BBIT32 | ( | bit | ) |
| #define BSP_BBIT64 | ( | bit | ) |
| #define BSP_BBIT8 | ( | bit | ) |
| #define BSP_BFLD16 | ( | val, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_BFLD16GET | ( | reg, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_BFLD16SET | ( | reg, | |
| val, | |||
| first_bit, | |||
| last_bit ) |
| #define BSP_BFLD32 | ( | val, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_BFLD32GET | ( | reg, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_BFLD32SET | ( | reg, | |
| val, | |||
| first_bit, | |||
| last_bit ) |
| #define BSP_BFLD64 | ( | val, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_BFLD64GET | ( | reg, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_BFLD64SET | ( | reg, | |
| val, | |||
| first_bit, | |||
| last_bit ) |
| #define BSP_BFLD8 | ( | val, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_BFLD8GET | ( | reg, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_BFLD8SET | ( | reg, | |
| val, | |||
| first_bit, | |||
| last_bit ) |
| #define BSP_BIT16 | ( | bit | ) |
| #define BSP_BIT32 | ( | bit | ) |
| #define BSP_BIT64 | ( | bit | ) |
| #define BSP_BIT8 | ( | bit | ) |
| #define BSP_BMSK16 | ( | first_bit, | |
| last_bit ) |
| #define BSP_BMSK32 | ( | first_bit, | |
| last_bit ) |
| #define BSP_BMSK64 | ( | first_bit, | |
| last_bit ) |
| #define BSP_BMSK8 | ( | first_bit, | |
| last_bit ) |
| #define BSP_FLD16 | ( | val, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_FLD16GET | ( | reg, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_FLD16SET | ( | reg, | |
| val, | |||
| first_bit, | |||
| last_bit ) |
| #define BSP_FLD32 | ( | val, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_FLD32GET | ( | reg, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_FLD32SET | ( | reg, | |
| val, | |||
| first_bit, | |||
| last_bit ) |
| #define BSP_FLD64 | ( | val, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_FLD64GET | ( | reg, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_FLD64SET | ( | reg, | |
| val, | |||
| first_bit, | |||
| last_bit ) |
| #define BSP_FLD8 | ( | val, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_FLD8GET | ( | reg, | |
| first_bit, | |||
| last_bit ) |
| #define BSP_FLD8SET | ( | reg, | |
| val, | |||
| first_bit, | |||
| last_bit ) |
| #define BSP_MSK16 | ( | first_bit, | |
| last_bit ) |
| #define BSP_MSK32 | ( | first_bit, | |
| last_bit ) |
| #define BSP_MSK64 | ( | first_bit, | |
| last_bit ) |
| #define BSP_MSK8 | ( | first_bit, | |
| last_bit ) |
