RTEMS
6.3
Toggle main menu visibility
bsps
aarch64
raspberrypi
include
bsp
raspberrypi-spi.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2024 Ning Yang
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_AARCH64_RASPBERRYPI_4_SPI_H
37
#define LIBBSP_AARCH64_RASPBERRYPI_4_SPI_H
38
39
bsp/utility.h
40
#include <bsp/rpi-gpio.h>
41
42
typedef
struct
43
44
uint32_t spics;
45
#define RPI_SPICS_LEN_LONG BSP_BIT32(25)
46
#define RPI_SPICS_DMA_LEN BSP_BIT32(24)
47
#define RPI_SPICS_CSPOL2 BSP_BIT32(23)
48
#define RPI_SPICS_CSPOL1 BSP_BIT32(22)
49
#define RPI_SPICS_CSPOL0 BSP_BIT32(21)
50
#define RPI_SPICS_RXF BSP_BIT32(20)
51
#define RPI_SPICS_RXR BSP_BIT32(19)
52
#define RPI_SPICS_TXD BSP_BIT32(18)
53
#define RPI_SPICS_RXD BSP_BIT32(17)
54
#define RPI_SPICS_DONE BSP_BIT32(16)
55
#define RPI_SPICS_LEN BSP_BIT32(13)
56
#define RPI_SPICS_REN BSP_BIT32(12)
57
#define RPI_SPICS_ADCS BSP_BIT32(11)
58
#define RPI_SPICS_INTR BSP_BIT32(10)
59
#define RPI_SPICS_INTD BSP_BIT32(9)
60
#define RPI_SPICS_DMAEN BSP_BIT32(8)
61
#define RPI_SPICS_TA BSP_BIT32(7)
62
#define RPI_SPICS_CSPOL BSP_BIT32(6)
63
#define RPI_SPICS_CLEAR_TX BSP_BIT32(5)
64
#define RPI_SPICS_CLEAR_RX BSP_BIT32(4)
65
#define RPI_SPICS_CPOL BSP_BIT32(3)
66
#define RPI_SPICS_CPHA BSP_BIT32(2)
67
#define RPI_SPICS_CS(val) BSP_FLD32(val, 0, 1)
68
#define RPI_SPICS_CS_SET(reg,val) BSP_FLD32SET(reg, val, 0, 1)
69
uint32_t spififo;
70
#define RPI_SPIFIFO_DATA(val) BSP_FLD32(val, 0, 31)
71
#define RPI_SPIFIFO_DATA_GET(reg) BSP_FLD32GET(reg, 0, 31)
72
#define RPI_SPIFIFO_DATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
73
uint32_t spiclk;
74
#define RPI_SPICLK_CDIV(val) BSP_FLD32(val, 0, 15)
75
#define RPI_SPICLK_CDIV_GET(reg) BSP_FLD32GET(reg, 0, 15)
76
#define RPI_SPICLK_CDIV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
77
uint32_t spidlen;
78
#define RPI_SPIDLEN_LEN(val) BSP_FLD32(val, 0, 15)
79
#define RPI_SPIDLEN_LEN_GET(reg) BSP_FLD32GET(reg, 0, 15)
80
#define RPI_SPIDLEN_LEN_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
81
uint32_t spiltoh;
82
#define RPI_SPILTOH_TOH(val) BSP_FLD32(val, 0, 3)
83
#define RPI_SPILTOH_TOH_GET(reg) BSP_FLD32GET(reg, 0, 3)
84
#define RPI_SPILTOH_TOH_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
85
uint32_t spidc;
86
#define RPI_SPIDC_RPANIC(val) BSP_FLD32(val, 24, 31)
87
#define RPI_SPIDC_RPANIC_GET(reg) BSP_FLD32GET(reg, 24, 31)
88
#define RPI_SPIDC_RPANIC_SET(reg, val) BSP_FLD32SET(reg, val, 24, 31)
89
#define RPI_SPIDC_RDREQ(val) BSP_FLD32(val, 16, 23)
90
#define RPI_SPIDC_RDREQ_GET(reg) BSP_FLD32GET(reg, 16, 23)
91
#define RPI_SPIDC_RDREQ_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)
92
#define RPI_SPIDC_TPANIC(val) BSP_FLD32(val, 8, 15)
93
#define RPI_SPIDC_TPANIC_GET(reg) BSP_FLD32GET(reg, 8, 15)
94
#define RPI_SPIDC_TPANIC_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
95
#define RPI_SPIDC_TDREQ(val) BSP_FLD32(val, 0, 7)
96
#define RPI_SPIDC_TDREQ_GET(reg) BSP_FLD32GET(reg, 0, 7)
97
#define RPI_SPIDC_TDREQ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
98
raspberrypi_spi
99
100
typedef
enum
101
raspberrypi_SPI0,
102
raspberrypi_SPI3,
103
raspberrypi_SPI4,
104
raspberrypi_SPI5,
105
raspberrypi_SPI6
106
} raspberrypi_spi_device;
107
120
rtems_status_code
raspberrypi_spi_init
(raspberrypi_spi_device device);
121
122
#endif
/* LIBBSP_AARCH64_RASPBERRYPI_4_SPI_H */
rtems_status_code
rtems_status_code
Definition
status.h:85
utility.h
This header file provides utility macros for BSPs.
rtems_status_code raspberrypi_spi_init(raspberrypi_spi_device device)
Register a spi device.
Definition
raspberrypi-spi.c:506
raspberrypi_spi
Definition
raspberrypi-spi.h:43
