RTEMS 6.3
pio_it.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
60
61#ifndef _PIO_IT_
62#define _PIO_IT_
63
64/*
65 * Headers
66 */
67
68#include "pio.h"
69#include <rtems.h>
70
71#ifdef __cplusplus
72extern "C" {
73#endif
74
75/*
76 * Global functions
77 */
78
79extern void PIO_InitializeInterrupts(uint32_t dwPriority);
80
81extern void PIO_ConfigureIt(const Pin *pPin,
82 void (*handler)(const Pin *, void *arg), void *arg);
83
84extern rtems_status_code PIO_RemoveIt(const Pin *pPin,
85 void (*handler)(const Pin *, void *arg), void *arg);
86
93static inline void PIO_EnableIt(const Pin *pPin)
94{
95 pPin->pio->PIO_ISR;
96 pPin->pio->PIO_IER = pPin->mask;
97}
98
104static inline void PIO_DisableIt(const Pin *pPin)
105{
106 pPin->pio->PIO_IDR = pPin->mask;
107}
108
114static inline bool PIO_ItIsActive(const Pin *pPin)
115{
116 return ((pPin->pio->PIO_IMR & pPin->mask) != 0);
117}
118
119extern void PIO_IT_InterruptHandler(void);
120
121extern void PioInterruptHandler(uint32_t id, Pio *pPio);
122
123extern void PIO_CaptureHandler(void);
124
125#ifdef __cplusplus
126}
127#endif
128
129#endif /* #ifndef _PIO_IT_ */
130
rtems_status_code
Definition status.h:85
The PIO_CaptureHandler must be called by the PIO Capture Interrupt Service Routine with the correspon...
Definition pio_capture.c:113
Pio hardware registers.
Definition component_pio.h:41
__I uint32_t PIO_ISR
(Pio Offset: 0x004C) Interrupt Status Register
Definition component_pio.h:61
__O uint32_t PIO_IER
(Pio Offset: 0x0040) Interrupt Enable Register
Definition component_pio.h:58
__I uint32_t PIO_IMR
(Pio Offset: 0x0048) Interrupt Mask Register
Definition component_pio.h:60
__O uint32_t PIO_IDR
(Pio Offset: 0x0044) Interrupt Disable Register
Definition component_pio.h:59
