void | PIO_InitializeInterrupts (uint32_t dwPriority) |
| void | PIO_ConfigureIt (const Pin *pPin, void(*handler)(const Pin *, void *arg), void *arg) |
| rtems_status_code | PIO_RemoveIt (const Pin *pPin, void(*handler)(const Pin *, void *arg), void *arg) |
void | PIO_IT_InterruptHandler (void) |
void | PioInterruptHandler (uint32_t id, Pio *pPio) |
void | PIO_CaptureHandler (void) |
| | The PIO_CaptureHandler must be called by the PIO Capture Interrupt Service Routine with the corresponding PIO Capture instance.
- Purpose
Configuration and handling of interrupts on PIO status changes. The API provided here have several advantages over the traditional PIO interrupt configuration approach:
- It is highly portable
- It automatically demultiplexes interrupts when multiples pins have been configured on a single PIO controller
- It allows a group of pins to share the same interrupt
However, it also has several minor drawbacks that may prevent from using it in particular applications:
- It enables the clocks of all PIO controllers
- PIO controllers all share the same interrupt handler, which does the demultiplexing and can be slower than direct configuration
- It reserves space for a fixed number of interrupts, which can be increased by modifying the appropriate constant in pio_it.c.
- Usage
- Initialize the PIO interrupt mechanism using PIO_InitializeInterrupts() with the desired priority (0 ... 7).
- Configure a status change interrupt on one or more pin(s) with PIO_ConfigureIt().
- Enable & disable interrupts on pins using PIO_EnableIt() and PIO_DisableIt().
