RTEMS 6.3
Register definitions. More...
| struct | lpc24xx_ssp |
| struct | lpc24xx_dma_descriptor |
| struct | lpc24xx_dma_channel |
| struct | lpc24xx_i2c |
| struct | lpc24xx_fio |
| #define | PINSEL_BASE_ADDR 0x4002C000 |
| #define | GPIO_BASE_ADDR 0x40028000 |
| #define | IOPIN0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x00)) |
| #define | IOSET0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x04)) |
| #define | IODIR0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x08)) |
| #define | IOCLR0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x0C)) |
| #define | IOPIN1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x10)) |
| #define | IOSET1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x14)) |
| #define | IODIR1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x18)) |
| #define | IOCLR1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x1C)) |
| #define | IO0_INT_EN_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x90)) |
| #define | IO0_INT_EN_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x94)) |
| #define | IO0_INT_STAT_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x84)) |
| #define | IO0_INT_STAT_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x88)) |
| #define | IO0_INT_CLR (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x8C)) |
| #define | IO2_INT_EN_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xB0)) |
| #define | IO2_INT_EN_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xB4)) |
| #define | IO2_INT_STAT_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xA4)) |
| #define | IO2_INT_STAT_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xA8)) |
| #define | IO2_INT_CLR (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xAC)) |
| #define | IO_INT_STAT (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x80)) |
| #define | FIO_BASE_ADDR 0x20098000 |
| #define | FIO0DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x00)) |
| #define | FIO0MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x10)) |
| #define | FIO0PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x14)) |
| #define | FIO0SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x18)) |
| #define | FIO0CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x1C)) |
| #define | FIO1DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x20)) |
| #define | FIO1MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x30)) |
| #define | FIO1PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x34)) |
| #define | FIO1SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x38)) |
| #define | FIO1CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x3C)) |
| #define | FIO2DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x40)) |
| #define | FIO2MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x50)) |
| #define | FIO2PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x54)) |
| #define | FIO2SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x58)) |
| #define | FIO2CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x5C)) |
| #define | FIO3DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x60)) |
| #define | FIO3MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x70)) |
| #define | FIO3PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x74)) |
| #define | FIO3SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x78)) |
| #define | FIO3CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x7C)) |
| #define | FIO4DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x80)) |
| #define | FIO4MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x90)) |
| #define | FIO4PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x94)) |
| #define | FIO4SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x98)) |
| #define | FIO4CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x9C)) |
| #define | FIO0DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x00)) |
| #define | FIO1DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x20)) |
| #define | FIO2DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x40)) |
| #define | FIO3DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x60)) |
| #define | FIO4DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x80)) |
| #define | FIO0DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x01)) |
| #define | FIO1DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x21)) |
| #define | FIO2DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x41)) |
| #define | FIO3DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x61)) |
| #define | FIO4DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x81)) |
| #define | FIO0DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x02)) |
| #define | FIO1DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x22)) |
| #define | FIO2DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x42)) |
| #define | FIO3DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x62)) |
| #define | FIO4DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x82)) |
| #define | FIO0DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x03)) |
| #define | FIO1DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x23)) |
| #define | FIO2DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x43)) |
| #define | FIO3DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x63)) |
| #define | FIO4DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x83)) |
| #define | FIO0DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x00)) |
| #define | FIO1DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x20)) |
| #define | FIO2DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x40)) |
| #define | FIO3DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x60)) |
| #define | FIO4DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x80)) |
| #define | FIO0DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x02)) |
| #define | FIO1DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x22)) |
| #define | FIO2DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x42)) |
| #define | FIO3DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x62)) |
| #define | FIO4DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x82)) |
| #define | FIO0MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x10)) |
| #define | FIO1MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x30)) |
| #define | FIO2MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x50)) |
| #define | FIO3MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x70)) |
| #define | FIO4MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x90)) |
| #define | FIO0MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x11)) |
| #define | FIO1MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x21)) |
| #define | FIO2MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x51)) |
| #define | FIO3MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x71)) |
| #define | FIO4MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x91)) |
| #define | FIO0MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x12)) |
| #define | FIO1MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x32)) |
| #define | FIO2MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x52)) |
| #define | FIO3MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x72)) |
| #define | FIO4MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x92)) |
| #define | FIO0MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x13)) |
| #define | FIO1MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x33)) |
| #define | FIO2MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x53)) |
| #define | FIO3MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x73)) |
| #define | FIO4MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x93)) |
| #define | FIO0MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x10)) |
| #define | FIO1MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x30)) |
| #define | FIO2MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x50)) |
| #define | FIO3MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x70)) |
| #define | FIO4MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x90)) |
| #define | FIO0MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x12)) |
| #define | FIO1MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x32)) |
| #define | FIO2MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x52)) |
| #define | FIO3MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x72)) |
| #define | FIO4MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x92)) |
| #define | FIO0PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x14)) |
| #define | FIO1PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x34)) |
| #define | FIO2PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x54)) |
| #define | FIO3PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x74)) |
| #define | FIO4PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x94)) |
| #define | FIO0PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x15)) |
| #define | FIO1PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x25)) |
| #define | FIO2PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x55)) |
| #define | FIO3PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x75)) |
| #define | FIO4PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x95)) |
| #define | FIO0PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x16)) |
| #define | FIO1PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x36)) |
| #define | FIO2PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x56)) |
| #define | FIO3PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x76)) |
| #define | FIO4PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x96)) |
| #define | FIO0PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x17)) |
| #define | FIO1PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x37)) |
| #define | FIO2PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x57)) |
| #define | FIO3PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x77)) |
| #define | FIO4PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x97)) |
| #define | FIO0PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x14)) |
| #define | FIO1PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x34)) |
| #define | FIO2PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x54)) |
| #define | FIO3PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x74)) |
| #define | FIO4PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x94)) |
| #define | FIO0PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x16)) |
| #define | FIO1PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x36)) |
| #define | FIO2PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x56)) |
| #define | FIO3PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x76)) |
| #define | FIO4PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x96)) |
| #define | FIO0SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x18)) |
| #define | FIO1SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x38)) |
| #define | FIO2SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x58)) |
| #define | FIO3SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x78)) |
| #define | FIO4SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x98)) |
| #define | FIO0SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x19)) |
| #define | FIO1SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x29)) |
| #define | FIO2SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x59)) |
| #define | FIO3SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x79)) |
| #define | FIO4SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x99)) |
| #define | FIO0SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1A)) |
| #define | FIO1SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3A)) |
| #define | FIO2SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5A)) |
| #define | FIO3SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7A)) |
| #define | FIO4SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9A)) |
| #define | FIO0SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1B)) |
| #define | FIO1SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3B)) |
| #define | FIO2SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5B)) |
| #define | FIO3SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7B)) |
| #define | FIO4SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9B)) |
| #define | FIO0SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x18)) |
| #define | FIO1SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x38)) |
| #define | FIO2SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x58)) |
| #define | FIO3SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x78)) |
| #define | FIO4SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x98)) |
| #define | FIO0SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x1A)) |
| #define | FIO1SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x3A)) |
| #define | FIO2SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x5A)) |
| #define | FIO3SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x7A)) |
| #define | FIO4SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x9A)) |
| #define | FIO0CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1C)) |
| #define | FIO1CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3C)) |
| #define | FIO2CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5C)) |
| #define | FIO3CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7C)) |
| #define | FIO4CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9C)) |
| #define | FIO0CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1D)) |
| #define | FIO1CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x2D)) |
| #define | FIO2CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5D)) |
| #define | FIO3CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7D)) |
| #define | FIO4CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9D)) |
| #define | FIO0CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1E)) |
| #define | FIO1CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3E)) |
| #define | FIO2CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5E)) |
| #define | FIO3CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7E)) |
| #define | FIO4CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9E)) |
| #define | FIO0CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1F)) |
| #define | FIO1CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3F)) |
| #define | FIO2CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5F)) |
| #define | FIO3CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7F)) |
| #define | FIO4CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9F)) |
| #define | FIO0CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x1C)) |
| #define | FIO1CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x3C)) |
| #define | FIO2CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x5C)) |
| #define | FIO3CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x7C)) |
| #define | FIO4CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x9C)) |
| #define | FIO0CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x1E)) |
| #define | FIO1CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x3E)) |
| #define | FIO2CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x5E)) |
| #define | FIO3CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x7E)) |
| #define | FIO4CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x9E)) |
| #define | EMC_BASE_ADDR 0x2009c000 |
| #define | EMC_CTRL (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x000)) |
| #define | EMC_STAT (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x004)) |
| #define | EMC_CONFIG (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x008)) |
| #define | EMC_DYN_CTRL (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x020)) |
| #define | EMC_DYN_RFSH (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x024)) |
| #define | EMC_DYN_RD_CFG (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x028)) |
| #define | EMC_DYN_RP (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x030)) |
| #define | EMC_DYN_RAS (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x034)) |
| #define | EMC_DYN_SREX (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x038)) |
| #define | EMC_DYN_APR (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x03C)) |
| #define | EMC_DYN_DAL (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x040)) |
| #define | EMC_DYN_WR (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x044)) |
| #define | EMC_DYN_RC (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x048)) |
| #define | EMC_DYN_RFC (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x04C)) |
| #define | EMC_DYN_XSR (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x050)) |
| #define | EMC_DYN_RRD (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x054)) |
| #define | EMC_DYN_MRD (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x058)) |
| #define | EMC_DYN_CFG0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x100)) |
| #define | EMC_DYN_RASCAS0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x104)) |
| #define | EMC_DYN_CFG1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x140)) |
| #define | EMC_DYN_RASCAS1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x144)) |
| #define | EMC_DYN_CFG2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x160)) |
| #define | EMC_DYN_RASCAS2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x164)) |
| #define | EMC_DYN_CFG3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x180)) |
| #define | EMC_DYN_RASCAS3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x184)) |
| #define | EMC_STA_BASE_0 ((uint32_t *) (EMC_BASE_ADDR + 0x200)) |
| #define | EMC_STA_CFG0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x200)) |
| #define | EMC_STA_WAITWEN0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x204)) |
| #define | EMC_STA_WAITOEN0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x208)) |
| #define | EMC_STA_WAITRD0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x20C)) |
| #define | EMC_STA_WAITPAGE0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x210)) |
| #define | EMC_STA_WAITWR0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x214)) |
| #define | EMC_STA_WAITTURN0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x218)) |
| #define | EMC_STA_BASE_1 ((uint32_t *) (EMC_BASE_ADDR + 0x220)) |
| #define | EMC_STA_CFG1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x220)) |
| #define | EMC_STA_WAITWEN1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x224)) |
| #define | EMC_STA_WAITOEN1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x228)) |
| #define | EMC_STA_WAITRD1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x22C)) |
| #define | EMC_STA_WAITPAGE1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x230)) |
| #define | EMC_STA_WAITWR1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x234)) |
| #define | EMC_STA_WAITTURN1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x238)) |
| #define | EMC_STA_BASE_2 ((uint32_t *) (EMC_BASE_ADDR + 0x240)) |
| #define | EMC_STA_CFG2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x240)) |
| #define | EMC_STA_WAITWEN2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x244)) |
| #define | EMC_STA_WAITOEN2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x248)) |
| #define | EMC_STA_WAITRD2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x24C)) |
| #define | EMC_STA_WAITPAGE2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x250)) |
| #define | EMC_STA_WAITWR2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x254)) |
| #define | EMC_STA_WAITTURN2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x258)) |
| #define | EMC_STA_BASE_3 ((uint32_t *) (EMC_BASE_ADDR + 0x260)) |
| #define | EMC_STA_CFG3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x260)) |
| #define | EMC_STA_WAITWEN3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x264)) |
| #define | EMC_STA_WAITOEN3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x268)) |
| #define | EMC_STA_WAITRD3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x26C)) |
| #define | EMC_STA_WAITPAGE3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x270)) |
| #define | EMC_STA_WAITWR3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x274)) |
| #define | EMC_STA_WAITTURN3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x278)) |
| #define | EMC_STA_EXT_WAIT (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x880)) |
| #define | TMR0_BASE_ADDR 0x40004000 |
| #define | T0IR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x00)) |
| #define | T0TCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x04)) |
| #define | T0TC (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x08)) |
| #define | T0PR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x0C)) |
| #define | T0PC (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x10)) |
| #define | T0MCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x14)) |
| #define | T0MR0 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x18)) |
| #define | T0MR1 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x1C)) |
| #define | T0MR2 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x20)) |
| #define | T0MR3 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x24)) |
| #define | T0CCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x28)) |
| #define | T0CR0 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x2C)) |
| #define | T0CR1 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x30)) |
| #define | T0CR2 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x34)) |
| #define | T0CR3 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x38)) |
| #define | T0EMR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x3C)) |
| #define | T0CTCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x70)) |
| #define | TMR1_BASE_ADDR 0x40008000 |
| #define | T1IR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x00)) |
| #define | T1TCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x04)) |
| #define | T1TC (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x08)) |
| #define | T1PR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x0C)) |
| #define | T1PC (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x10)) |
| #define | T1MCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x14)) |
| #define | T1MR0 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x18)) |
| #define | T1MR1 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x1C)) |
| #define | T1MR2 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x20)) |
| #define | T1MR3 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x24)) |
| #define | T1CCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x28)) |
| #define | T1CR0 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x2C)) |
| #define | T1CR1 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x30)) |
| #define | T1CR2 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x34)) |
| #define | T1CR3 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x38)) |
| #define | T1EMR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x3C)) |
| #define | T1CTCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x70)) |
| #define | TMR2_BASE_ADDR 0x40090000 |
| #define | T2IR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x00)) |
| #define | T2TCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x04)) |
| #define | T2TC (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x08)) |
| #define | T2PR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x0C)) |
| #define | T2PC (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x10)) |
| #define | T2MCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x14)) |
| #define | T2MR0 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x18)) |
| #define | T2MR1 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x1C)) |
| #define | T2MR2 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x20)) |
| #define | T2MR3 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x24)) |
| #define | T2CCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x28)) |
| #define | T2CR0 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x2C)) |
| #define | T2CR1 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x30)) |
| #define | T2CR2 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x34)) |
| #define | T2CR3 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x38)) |
| #define | T2EMR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x3C)) |
| #define | T2CTCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x70)) |
| #define | TMR3_BASE_ADDR 0x40094000 |
| #define | T3IR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x00)) |
| #define | T3TCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x04)) |
| #define | T3TC (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x08)) |
| #define | T3PR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x0C)) |
| #define | T3PC (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x10)) |
| #define | T3MCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x14)) |
| #define | T3MR0 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x18)) |
| #define | T3MR1 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x1C)) |
| #define | T3MR2 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x20)) |
| #define | T3MR3 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x24)) |
| #define | T3CCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x28)) |
| #define | T3CR0 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x2C)) |
| #define | T3CR1 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x30)) |
| #define | T3CR2 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x34)) |
| #define | T3CR3 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x38)) |
| #define | T3EMR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x3C)) |
| #define | T3CTCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x70)) |
| #define | PWM0_BASE_ADDR 0x40014000 |
| #define | PWM0IR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x00)) |
| #define | PWM0TCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x04)) |
| #define | PWM0TC (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x08)) |
| #define | PWM0PR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x0C)) |
| #define | PWM0PC (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x10)) |
| #define | PWM0MCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x14)) |
| #define | PWM0MR0 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x18)) |
| #define | PWM0MR1 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x1C)) |
| #define | PWM0MR2 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x20)) |
| #define | PWM0MR3 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x24)) |
| #define | PWM0CCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x28)) |
| #define | PWM0CR0 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x2C)) |
| #define | PWM0CR1 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x30)) |
| #define | PWM0CR2 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x34)) |
| #define | PWM0CR3 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x38)) |
| #define | PWM0EMR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x3C)) |
| #define | PWM0MR4 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x40)) |
| #define | PWM0MR5 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x44)) |
| #define | PWM0MR6 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x48)) |
| #define | PWM0PCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x4C)) |
| #define | PWM0LER (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x50)) |
| #define | PWM0CTCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x70)) |
| #define | PWM1_BASE_ADDR 0x40018000 |
| #define | PWM1IR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x00)) |
| #define | PWM1TCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x04)) |
| #define | PWM1TC (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x08)) |
| #define | PWM1PR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x0C)) |
| #define | PWM1PC (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x10)) |
| #define | PWM1MCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x14)) |
| #define | PWM1MR0 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x18)) |
| #define | PWM1MR1 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x1C)) |
| #define | PWM1MR2 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x20)) |
| #define | PWM1MR3 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x24)) |
| #define | PWM1CCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x28)) |
| #define | PWM1CR0 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x2C)) |
| #define | PWM1CR1 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x30)) |
| #define | PWM1CR2 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x34)) |
| #define | PWM1CR3 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x38)) |
| #define | PWM1EMR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x3C)) |
| #define | PWM1MR4 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x40)) |
| #define | PWM1MR5 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x44)) |
| #define | PWM1MR6 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x48)) |
| #define | PWM1PCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x4C)) |
| #define | PWM1LER (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x50)) |
| #define | PWM1CTCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x70)) |
| #define | UART0_BASE_ADDR 0x4000C000 |
| #define | U0RBR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x00)) |
| #define | U0THR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x00)) |
| #define | U0DLL (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x00)) |
| #define | U0DLM (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x04)) |
| #define | U0IER (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x04)) |
| #define | U0IIR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x08)) |
| #define | U0FCR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x08)) |
| #define | U0LCR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x0C)) |
| #define | U0LSR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x14)) |
| #define | U0SCR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x1C)) |
| #define | U0ACR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x20)) |
| #define | U0ICR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x24)) |
| #define | U0FDR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x28)) |
| #define | U0TER (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x30)) |
| #define | UART1_BASE_ADDR 0x40010000 |
| #define | U1RBR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x00)) |
| #define | U1THR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x00)) |
| #define | U1DLL (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x00)) |
| #define | U1DLM (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x04)) |
| #define | U1IER (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x04)) |
| #define | U1IIR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x08)) |
| #define | U1FCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x08)) |
| #define | U1LCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x0C)) |
| #define | U1MCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x10)) |
| #define | U1LSR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x14)) |
| #define | U1MSR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x18)) |
| #define | U1SCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x1C)) |
| #define | U1ACR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x20)) |
| #define | U1FDR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x28)) |
| #define | U1TER (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x30)) |
| #define | UART2_BASE_ADDR 0x40098000 |
| #define | U2RBR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x00)) |
| #define | U2THR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x00)) |
| #define | U2DLL (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x00)) |
| #define | U2DLM (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x04)) |
| #define | U2IER (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x04)) |
| #define | U2IIR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x08)) |
| #define | U2FCR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x08)) |
| #define | U2LCR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x0C)) |
| #define | U2LSR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x14)) |
| #define | U2SCR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x1C)) |
| #define | U2ACR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x20)) |
| #define | U2ICR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x24)) |
| #define | U2FDR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x28)) |
| #define | U2TER (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x30)) |
| #define | UART3_BASE_ADDR 0x4009C000 |
| #define | U3RBR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x00)) |
| #define | U3THR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x00)) |
| #define | U3DLL (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x00)) |
| #define | U3DLM (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x04)) |
| #define | U3IER (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x04)) |
| #define | U3IIR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x08)) |
| #define | U3FCR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x08)) |
| #define | U3LCR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x0C)) |
| #define | U3LSR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x14)) |
| #define | U3SCR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x1C)) |
| #define | U3ACR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x20)) |
| #define | U3ICR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x24)) |
| #define | U3FDR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x28)) |
| #define | U3TER (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x30)) |
| #define | I2C0_BASE_ADDR 0x4001C000 |
| #define | I20CONSET (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x00)) |
| #define | I20STAT (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x04)) |
| #define | I20DAT (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x08)) |
| #define | I20ADR (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x0C)) |
| #define | I20SCLH (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x10)) |
| #define | I20SCLL (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x14)) |
| #define | I20CONCLR (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x18)) |
| #define | I2C1_BASE_ADDR 0x4005C000 |
| #define | I21CONSET (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x00)) |
| #define | I21STAT (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x04)) |
| #define | I21DAT (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x08)) |
| #define | I21ADR (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x0C)) |
| #define | I21SCLH (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x10)) |
| #define | I21SCLL (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x14)) |
| #define | I21CONCLR (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x18)) |
| #define | I2C2_BASE_ADDR 0x400a0000 |
| #define | I22CONSET (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x00)) |
| #define | I22STAT (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x04)) |
| #define | I22DAT (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x08)) |
| #define | I22ADR (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x0C)) |
| #define | I22SCLH (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x10)) |
| #define | I22SCLL (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x14)) |
| #define | I22CONCLR (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x18)) |
| #define | SPI0_BASE_ADDR 0xE0020000 |
| #define | S0SPCR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x00)) |
| #define | S0SPSR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x04)) |
| #define | S0SPDR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x08)) |
| #define | S0SPCCR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x0C)) |
| #define | S0SPINT (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x1C)) |
| #define | SSP0_BASE_ADDR 0x40088000 |
| #define | SSP0CR0 (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x00)) |
| #define | SSP0CR1 (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x04)) |
| #define | SSP0DR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x08)) |
| #define | SSP0SR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x0C)) |
| #define | SSP0CPSR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x10)) |
| #define | SSP0IMSC (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x14)) |
| #define | SSP0RIS (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x18)) |
| #define | SSP0MIS (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x1C)) |
| #define | SSP0ICR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x20)) |
| #define | SSP0DMACR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x24)) |
| #define | SSP1_BASE_ADDR 0x40030000 |
| #define | SSP1CR0 (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x00)) |
| #define | SSP1CR1 (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x04)) |
| #define | SSP1DR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x08)) |
| #define | SSP1SR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x0C)) |
| #define | SSP1CPSR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x10)) |
| #define | SSP1IMSC (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x14)) |
| #define | SSP1RIS (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x18)) |
| #define | SSP1MIS (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x1C)) |
| #define | SSP1ICR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x20)) |
| #define | SSP1DMACR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x24)) |
| #define | RTC_BASE_ADDR 0x40024000 |
| #define | RTC_ILR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x00)) |
| #define | RTC_CTC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x04)) |
| #define | RTC_CCR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x08)) |
| #define | RTC_CIIR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x0C)) |
| #define | RTC_AMR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x10)) |
| #define | RTC_CTIME0 (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x14)) |
| #define | RTC_CTIME1 (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x18)) |
| #define | RTC_CTIME2 (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x1C)) |
| #define | RTC_SEC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x20)) |
| #define | RTC_MIN (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x24)) |
| #define | RTC_HOUR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x28)) |
| #define | RTC_DOM (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x2C)) |
| #define | RTC_DOW (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x30)) |
| #define | RTC_DOY (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x34)) |
| #define | RTC_MONTH (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x38)) |
| #define | RTC_YEAR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x3C)) |
| #define | RTC_CISS (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x40)) |
| #define | RTC_ALSEC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x60)) |
| #define | RTC_ALMIN (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x64)) |
| #define | RTC_ALHOUR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x68)) |
| #define | RTC_ALDOM (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x6C)) |
| #define | RTC_ALDOW (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x70)) |
| #define | RTC_ALDOY (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x74)) |
| #define | RTC_ALMON (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x78)) |
| #define | RTC_ALYEAR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x7C)) |
| #define | RTC_PREINT (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x80)) |
| #define | RTC_PREFRAC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x84)) |
| #define | AD0_BASE_ADDR 0x40034000 |
| #define | AD0CR (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x00)) |
| #define | AD0GDR (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x04)) |
| #define | AD0INTEN (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x0C)) |
| #define | AD0_DATA_START ((volatile uint32_t *) (AD0_BASE_ADDR + 0x10)) |
| #define | AD0DR0 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x10)) |
| #define | AD0DR1 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x14)) |
| #define | AD0DR2 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x18)) |
| #define | AD0DR3 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x1C)) |
| #define | AD0DR4 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x20)) |
| #define | AD0DR5 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x24)) |
| #define | AD0DR6 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x28)) |
| #define | AD0DR7 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x2C)) |
| #define | AD0STAT (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x30)) |
| #define | DAC_BASE_ADDR 0x4008C000 |
| #define | DACR (*(volatile uint32_t *) (DAC_BASE_ADDR + 0x00)) |
| #define | WDG_BASE_ADDR 0x40000000 |
| #define | WDMOD (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x00)) |
| #define | WDTC (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x04)) |
| #define | WDFEED (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x08)) |
| #define | WDTV (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x0C)) |
| #define | WDCLKSEL (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x10)) |
| #define | CAN_ACCEPT_BASE_ADDR 0x4003C000 |
| #define | CAN_AFMR (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x00)) |
| #define | CAN_SFF_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x04)) |
| #define | CAN_SFF_GRP_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x08)) |
| #define | CAN_EFF_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x0C)) |
| #define | CAN_EFF_GRP_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x10)) |
| #define | CAN_EOT (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x14)) |
| #define | CAN_LUT_ERR_ADR (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x18)) |
| #define | CAN_LUT_ERR (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x1C)) |
| #define | CAN_CENTRAL_BASE_ADDR 0x40040000 |
| #define | CAN_TX_SR (*(volatile uint32_t *) (CAN_CENTRAL_BASE_ADDR + 0x00)) |
| #define | CAN_RX_SR (*(volatile uint32_t *) (CAN_CENTRAL_BASE_ADDR + 0x04)) |
| #define | CAN_MSR (*(volatile uint32_t *) (CAN_CENTRAL_BASE_ADDR + 0x08)) |
| #define | CAN1_BASE_ADDR 0x40044000 |
| #define | CAN1MOD (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x00)) |
| #define | CAN1CMR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x04)) |
| #define | CAN1GSR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x08)) |
| #define | CAN1ICR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x0C)) |
| #define | CAN1IER (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x10)) |
| #define | CAN1BTR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x14)) |
| #define | CAN1EWL (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x18)) |
| #define | CAN1SR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x1C)) |
| #define | CAN1RFS (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x20)) |
| #define | CAN1RID (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x24)) |
| #define | CAN1RDA (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x28)) |
| #define | CAN1RDB (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x2C)) |
| #define | CAN1TFI1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x30)) |
| #define | CAN1TID1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x34)) |
| #define | CAN1TDA1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x38)) |
| #define | CAN1TDB1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x3C)) |
| #define | CAN1TFI2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x40)) |
| #define | CAN1TID2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x44)) |
| #define | CAN1TDA2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x48)) |
| #define | CAN1TDB2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x4C)) |
| #define | CAN1TFI3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x50)) |
| #define | CAN1TID3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x54)) |
| #define | CAN1TDA3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x58)) |
| #define | CAN1TDB3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x5C)) |
| #define | CAN2_BASE_ADDR 0x40048000 |
| #define | CAN2MOD (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x00)) |
| #define | CAN2CMR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x04)) |
| #define | CAN2GSR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x08)) |
| #define | CAN2ICR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x0C)) |
| #define | CAN2IER (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x10)) |
| #define | CAN2BTR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x14)) |
| #define | CAN2EWL (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x18)) |
| #define | CAN2SR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x1C)) |
| #define | CAN2RFS (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x20)) |
| #define | CAN2RID (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x24)) |
| #define | CAN2RDA (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x28)) |
| #define | CAN2RDB (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x2C)) |
| #define | CAN2TFI1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x30)) |
| #define | CAN2TID1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x34)) |
| #define | CAN2TDA1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x38)) |
| #define | CAN2TDB1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x3C)) |
| #define | CAN2TFI2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x40)) |
| #define | CAN2TID2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x44)) |
| #define | CAN2TDA2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x48)) |
| #define | CAN2TDB2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x4C)) |
| #define | CAN2TFI3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x50)) |
| #define | CAN2TID3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x54)) |
| #define | CAN2TDA3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x58)) |
| #define | CAN2TDB3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x5C)) |
| #define | MCI_BASE_ADDR 0x400c0000 |
| #define | MCI_POWER (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x00)) |
| #define | MCI_CLOCK (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x04)) |
| #define | MCI_ARGUMENT (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x08)) |
| #define | MCI_COMMAND (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x0C)) |
| #define | MCI_RESP_CMD (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x10)) |
| #define | MCI_RESP0 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x14)) |
| #define | MCI_RESP1 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x18)) |
| #define | MCI_RESP2 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x1C)) |
| #define | MCI_RESP3 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x20)) |
| #define | MCI_DATA_TMR (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x24)) |
| #define | MCI_DATA_LEN (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x28)) |
| #define | MCI_DATA_CTRL (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x2C)) |
| #define | MCI_DATA_CNT (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x30)) |
| #define | MCI_STATUS (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x34)) |
| #define | MCI_CLEAR (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x38)) |
| #define | MCI_MASK0 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x3C)) |
| #define | MCI_MASK1 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x40)) |
| #define | MCI_FIFO_CNT (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x48)) |
| #define | MCI_FIFO (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x80)) |
| #define | I2S_BASE_ADDR 0x400a8000 |
| #define | I2S_DAO (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x00)) |
| #define | I2S_DAI (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x04)) |
| #define | I2S_TX_FIFO (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x08)) |
| #define | I2S_RX_FIFO (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x0C)) |
| #define | I2S_STATE (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x10)) |
| #define | I2S_DMA1 (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x14)) |
| #define | I2S_DMA2 (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x18)) |
| #define | I2S_IRQ (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x1C)) |
| #define | I2S_TXRATE (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x20)) |
| #define | I2S_RXRATE (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x24)) |
| #define | DMA_BASE_ADDR 0x20080000 |
| #define | GPDMA_INT_STAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x000)) |
| #define | GPDMA_INT_TCSTAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x004)) |
| #define | GPDMA_INT_TCCLR (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x008)) |
| #define | GPDMA_INT_ERR_STAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x00C)) |
| #define | GPDMA_INT_ERR_CLR (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x010)) |
| #define | GPDMA_RAW_INT_TCSTAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x014)) |
| #define | GPDMA_RAW_INT_ERR_STAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x018)) |
| #define | GPDMA_ENABLED_CHNS (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x01C)) |
| #define | GPDMA_SOFT_BREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x020)) |
| #define | GPDMA_SOFT_SREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x024)) |
| #define | GPDMA_SOFT_LBREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x028)) |
| #define | GPDMA_SOFT_LSREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x02C)) |
| #define | GPDMA_CONFIG (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x030)) |
| #define | GPDMA_SYNC (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x034)) |
| #define | GPDMA_CH0_BASE_ADDR (DMA_BASE_ADDR + 0x100) |
| #define | GPDMA_CH0_SRC (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x100)) |
| #define | GPDMA_CH0_DEST (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x104)) |
| #define | GPDMA_CH0_LLI (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x108)) |
| #define | GPDMA_CH0_CTRL (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x10C)) |
| #define | GPDMA_CH0_CFG (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x110)) |
| #define | GPDMA_CH1_BASE_ADDR (DMA_BASE_ADDR + 0x120) |
| #define | GPDMA_CH1_SRC (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x120)) |
| #define | GPDMA_CH1_DEST (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x124)) |
| #define | GPDMA_CH1_LLI (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x128)) |
| #define | GPDMA_CH1_CTRL (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x12C)) |
| #define | GPDMA_CH1_CFG (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x130)) |
| #define | USB_INT_BASE_ADDR 0x400fc1c0 |
| #define | USB_BASE_ADDR 0x2008c200 |
| #define | USB_INT_STAT (*(volatile uint32_t *) (USB_INT_BASE_ADDR + 0x00)) |
| #define | DEV_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x00)) |
| #define | DEV_INT_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x04)) |
| #define | DEV_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0x08)) |
| #define | DEV_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0x0C)) |
| #define | DEV_INT_PRIO (*(volatile uint32_t *) (USB_BASE_ADDR + 0x2C)) |
| #define | EP_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x30)) |
| #define | EP_INT_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x34)) |
| #define | EP_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0x38)) |
| #define | EP_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0x3C)) |
| #define | EP_INT_PRIO (*(volatile uint32_t *) (USB_BASE_ADDR + 0x40)) |
| #define | REALIZE_EP (*(volatile uint32_t *) (USB_BASE_ADDR + 0x44)) |
| #define | EP_INDEX (*(volatile uint32_t *) (USB_BASE_ADDR + 0x48)) |
| #define | MAXPACKET_SIZE (*(volatile uint32_t *) (USB_BASE_ADDR + 0x4C)) |
| #define | CMD_CODE (*(volatile uint32_t *) (USB_BASE_ADDR + 0x10)) |
| #define | CMD_DATA (*(volatile uint32_t *) (USB_BASE_ADDR + 0x14)) |
| #define | RX_DATA (*(volatile uint32_t *) (USB_BASE_ADDR + 0x18)) |
| #define | TX_DATA (*(volatile uint32_t *) (USB_BASE_ADDR + 0x1C)) |
| #define | RX_PLENGTH (*(volatile uint32_t *) (USB_BASE_ADDR + 0x20)) |
| #define | TX_PLENGTH (*(volatile uint32_t *) (USB_BASE_ADDR + 0x24)) |
| #define | USB_CTRL (*(volatile uint32_t *) (USB_BASE_ADDR + 0x28)) |
| #define | DMA_REQ_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x50)) |
| #define | DMA_REQ_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0x54)) |
| #define | DMA_REQ_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0x58)) |
| #define | UDCA_HEAD (*(volatile uint32_t *) (USB_BASE_ADDR + 0x80)) |
| #define | EP_DMA_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x84)) |
| #define | EP_DMA_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x88)) |
| #define | EP_DMA_DIS (*(volatile uint32_t *) (USB_BASE_ADDR + 0x8C)) |
| #define | DMA_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x90)) |
| #define | DMA_INT_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x94)) |
| #define | EOT_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0xA0)) |
| #define | EOT_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0xA4)) |
| #define | EOT_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0xA8)) |
| #define | NDD_REQ_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0xAC)) |
| #define | NDD_REQ_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0xB0)) |
| #define | NDD_REQ_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0xB4)) |
| #define | SYS_ERR_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0xB8)) |
| #define | SYS_ERR_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0xBC)) |
| #define | SYS_ERR_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0xC0)) |
| #define | USBHC_BASE_ADDR 0x2008c000 |
| #define | HC_REVISION (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x00)) |
| #define | HC_CONTROL (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x04)) |
| #define | HC_CMD_STAT (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x08)) |
| #define | HC_INT_STAT (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x0C)) |
| #define | HC_INT_EN (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x10)) |
| #define | HC_INT_DIS (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x14)) |
| #define | HC_HCCA (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x18)) |
| #define | HC_PERIOD_CUR_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x1C)) |
| #define | HC_CTRL_HEAD_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x20)) |
| #define | HC_CTRL_CUR_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x24)) |
| #define | HC_BULK_HEAD_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x28)) |
| #define | HC_BULK_CUR_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x2C)) |
| #define | HC_DONE_HEAD (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x30)) |
| #define | HC_FM_INTERVAL (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x34)) |
| #define | HC_FM_REMAINING (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x38)) |
| #define | HC_FM_NUMBER (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x3C)) |
| #define | HC_PERIOD_START (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x40)) |
| #define | HC_LS_THRHLD (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x44)) |
| #define | HC_RH_DESCA (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x48)) |
| #define | HC_RH_DESCB (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x4C)) |
| #define | HC_RH_STAT (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x50)) |
| #define | HC_RH_PORT_STAT1 (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x54)) |
| #define | HC_RH_PORT_STAT2 (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x58)) |
| #define | USBOTG_BASE_ADDR 0x2008c100 |
| #define | OTG_INT_STAT (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x00)) |
| #define | OTG_INT_EN (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x04)) |
| #define | OTG_INT_SET (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x08)) |
| #define | OTG_INT_CLR (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x0C)) |
| #define | OTG_STAT_CTRL (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x10)) |
| #define | OTG_TIMER (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x14)) |
| #define | USBOTG_I2C_BASE_ADDR 0x2008c300 |
| #define | OTG_I2C_RX (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x00)) |
| #define | OTG_I2C_TX (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x00)) |
| #define | OTG_I2C_STS (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x04)) |
| #define | OTG_I2C_CTL (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x08)) |
| #define | OTG_I2C_CLKHI (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x0C)) |
| #define | OTG_I2C_CLKLO (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x10)) |
| #define | USBOTG_CLK_BASE_ADDR 0x2008cff0 |
| #define | OTG_CLK_CTRL (*(volatile uint32_t *) (USBOTG_CLK_BASE_ADDR + 0x04)) |
| #define | OTG_CLK_STAT (*(volatile uint32_t *) (USBOTG_CLK_BASE_ADDR + 0x08)) |
| #define | MAC_BASE_ADDR 0x20084000 |
| #define | MAC_MAC1 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x000)) |
| #define | MAC_MAC2 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x004)) |
| #define | MAC_IPGT (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x008)) |
| #define | MAC_IPGR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x00C)) |
| #define | MAC_CLRT (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x010)) |
| #define | MAC_MAXF (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x014)) |
| #define | MAC_SUPP (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x018)) |
| #define | MAC_TEST (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x01C)) |
| #define | MAC_MCFG (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x020)) |
| #define | MAC_MCMD (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x024)) |
| #define | MAC_MADR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x028)) |
| #define | MAC_MWTD (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x02C)) |
| #define | MAC_MRDD (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x030)) |
| #define | MAC_MIND (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x034)) |
| #define | MAC_SA0 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x040)) |
| #define | MAC_SA1 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x044)) |
| #define | MAC_SA2 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x048)) |
| #define | MAC_COMMAND (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x100)) |
| #define | MAC_STATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x104)) |
| #define | MAC_RXDESCRIPTOR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x108)) |
| #define | MAC_RXSTATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x10C)) |
| #define | MAC_RXDESCRIPTORNUM (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x110)) |
| #define | MAC_RXPRODUCEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x114)) |
| #define | MAC_RXCONSUMEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x118)) |
| #define | MAC_TXDESCRIPTOR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x11C)) |
| #define | MAC_TXSTATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x120)) |
| #define | MAC_TXDESCRIPTORNUM (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x124)) |
| #define | MAC_TXPRODUCEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x128)) |
| #define | MAC_TXCONSUMEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x12C)) |
| #define | MAC_TSV0 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x158)) |
| #define | MAC_TSV1 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x15C)) |
| #define | MAC_RSV (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x160)) |
| #define | MAC_FLOWCONTROLCNT (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x170)) |
| #define | MAC_FLOWCONTROLSTS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x174)) |
| #define | MAC_RXFILTERCTRL (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x200)) |
| #define | MAC_RXFILTERWOLSTS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x204)) |
| #define | MAC_RXFILTERWOLCLR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x208)) |
| #define | MAC_HASHFILTERL (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x210)) |
| #define | MAC_HASHFILTERH (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x214)) |
| #define | MAC_INTSTATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFE0)) |
| #define | MAC_INTENABLE (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFE4)) |
| #define | MAC_INTCLEAR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFE8)) |
| #define | MAC_INTSET (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFEC)) |
| #define | MAC_POWERDOWN (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFF4)) |
| #define | MAC_MODULEID (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFFC)) |
| #define | LCD_CFG (*(volatile uint32_t *) 0x400FC1B8) |
| #define | LCD_BASE_ADDR 0x20088000 |
| #define | LCD_TIMH (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x000)) |
| #define | LCD_TIMV (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x004)) |
| #define | LCD_POL (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x008)) |
| #define | LCD_LE (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x00C)) |
| #define | LCD_UPBASE (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x010)) |
| #define | LCD_LPBASE (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x014)) |
| #define | LCD_CTRL (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x018)) |
| #define | LCD_INTMSK (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x01C)) |
| #define | LCD_INTRAW (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x020)) |
| #define | LCD_INTSTAT (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x024)) |
| #define | LCD_INTCLR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x028)) |
| #define | LCD_UPCURR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x02C)) |
| #define | LCD_LPCURR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x030)) |
| #define | LCD_PAL_ADDR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x200)) |
| #define | CRSR_IMG (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x800)) |
| #define | CRSR_CTLR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC00)) |
| #define | CRSR_CFG (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC04)) |
| #define | CRSR_PAL0 (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC08)) |
| #define | CRSR_PAL1 (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC0C)) |
| #define | CRSR_XY (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC10)) |
| #define | CRSR_CLIP (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC14)) |
| #define | CRSR_INTMSK (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC20)) |
| #define | CRSR_INTCLR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC24)) |
| #define | CRSR_INTRAW (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC28)) |
| #define | CRSR_INTSTAT (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC2C)) |
| #define | GET_FIELD(val, mask, shift) |
| #define | SET_FIELD(val, field, mask, shift) |
| #define | CLKSRCSEL_CLKSRC_MASK 0x00000003U |
| #define | GET_CLKSRCSEL_CLKSRC(reg) |
| #define | SET_CLKSRCSEL_CLKSRC(reg, val) |
| #define | PLLCON_PLLE 0x00000001U |
| #define | PLLCON_PLLC 0x00000002U |
| #define | PLLCFG_MSEL_MASK 0x00007fffU |
| #define | GET_PLLCFG_MSEL(reg) |
| #define | SET_PLLCFG_MSEL(reg, val) |
| #define | PLLCFG_NSEL_MASK 0x00ff0000U |
| #define | GET_PLLCFG_NSEL(reg) |
| #define | SET_PLLCFG_NSEL(reg, val) |
| #define | PLLSTAT_MSEL_MASK 0x00007fffU |
| #define | GET_PLLSTAT_MSEL(reg) |
| #define | SET_PLLSTAT_MSEL(reg, val) |
| #define | PLLSTAT_NSEL_MASK 0x00ff0000U |
| #define | GET_PLLSTAT_NSEL(reg) |
| #define | SET_PLLSTAT_NSEL(reg, val) |
| #define | PLLSTAT_PLLE 0x01000000U |
| #define | PLLSTAT_PLLC 0x02000000U |
| #define | PLLSTAT_PLOCK 0x04000000U |
| #define | CCLKCFG_CCLKSEL_MASK 0x000000ffU |
| #define | GET_CCLKCFG_CCLKSEL(reg) |
| #define | SET_CCLKCFG_CCLKSEL(reg, val) |
| #define | MEMMAP_MAP_MASK 0x00000003U |
| #define | GET_MEMMAP_MAP(reg) |
| #define | SET_MEMMAP_MAP(reg, val) |
| #define | TIR_MR0 0x00000001U |
| #define | TIR_MR1 0x00000002U |
| #define | TIR_MR2 0x00000004U |
| #define | TIR_MR3 0x00000008U |
| #define | TIR_CR0 0x00000010U |
| #define | TIR_CR1 0x00000020U |
| #define | TIR_CR2 0x00000040U |
| #define | TIR_CR3 0x00000080U |
| #define | TCR_EN 0x00000001U |
| #define | TCR_RST 0x00000002U |
| #define | TMCR_MR0I 0x00000001U |
| #define | TMCR_MR0R 0x00000002U |
| #define | TMCR_MR0S 0x00000004U |
| #define | TMCR_MR1I 0x00000008U |
| #define | TMCR_MR1R 0x00000010U |
| #define | TMCR_MR1S 0x00000020U |
| #define | TMCR_MR2I 0x00000040U |
| #define | TMCR_MR2R 0x00000080U |
| #define | TMCR_MR2S 0x00000100U |
| #define | TMCR_MR3I 0x00000200U |
| #define | TMCR_MR3R 0x00000400U |
| #define | TMCR_MR3S 0x00000800U |
| #define | PCLKSEL0_PCLK_WDT_MASK 0x00000003U |
| #define | GET_PCLKSEL0_PCLK_WDT(reg) |
| #define | SET_PCLKSEL0_PCLK_WDT(reg, val) |
| #define | PCLKSEL0_PCLK_TIMER0_MASK 0x0000000cU |
| #define | GET_PCLKSEL0_PCLK_TIMER0(reg) |
| #define | SET_PCLKSEL0_PCLK_TIMER0(reg, val) |
| #define | PCLKSEL0_PCLK_TIMER1_MASK 0x00000030U |
| #define | GET_PCLKSEL0_PCLK_TIMER1(reg) |
| #define | SET_PCLKSEL0_PCLK_TIMER1(reg, val) |
| #define | PCLKSEL0_PCLK_UART0_MASK 0x000000c0U |
| #define | GET_PCLKSEL0_PCLK_UART0(reg) |
| #define | SET_PCLKSEL0_PCLK_UART0(reg, val) |
| #define | PCLKSEL0_PCLK_UART1_MASK 0x00000300U |
| #define | GET_PCLKSEL0_PCLK_UART1(reg) |
| #define | SET_PCLKSEL0_PCLK_UART1(reg, val) |
| #define | PCLKSEL0_PCLK_PWM0_MASK 0x00000c00U |
| #define | GET_PCLKSEL0_PCLK_PWM0(reg) |
| #define | SET_PCLKSEL0_PCLK_PWM0(reg, val) |
| #define | PCLKSEL0_PCLK_PWM1_MASK 0x00003000U |
| #define | GET_PCLKSEL0_PCLK_PWM1(reg) |
| #define | SET_PCLKSEL0_PCLK_PWM1(reg, val) |
| #define | PCLKSEL0_PCLK_I2C0_MASK 0x0000c000U |
| #define | GET_PCLKSEL0_PCLK_I2C0(reg) |
| #define | SET_PCLKSEL0_PCLK_I2C0(reg, val) |
| #define | PCLKSEL0_PCLK_SPI_MASK 0x00030000U |
| #define | GET_PCLKSEL0_PCLK_SPI(reg) |
| #define | SET_PCLKSEL0_PCLK_SPI(reg, val) |
| #define | PCLKSEL0_PCLK_RTC_MASK 0x000c0000U |
| #define | GET_PCLKSEL0_PCLK_RTC(reg) |
| #define | SET_PCLKSEL0_PCLK_RTC(reg, val) |
| #define | PCLKSEL0_PCLK_SSP1_MASK 0x00300000U |
| #define | GET_PCLKSEL0_PCLK_SSP1(reg) |
| #define | SET_PCLKSEL0_PCLK_SSP1(reg, val) |
| #define | PCLKSEL0_PCLK_DAC_MASK 0x00c00000U |
| #define | GET_PCLKSEL0_PCLK_DAC(reg) |
| #define | SET_PCLKSEL0_PCLK_DAC(reg, val) |
| #define | PCLKSEL0_PCLK_ADC_MASK 0x03000000U |
| #define | GET_PCLKSEL0_PCLK_ADC(reg) |
| #define | SET_PCLKSEL0_PCLK_ADC(reg, val) |
| #define | PCLKSEL0_PCLK_CAN1_MASK 0x0c000000U |
| #define | GET_PCLKSEL0_PCLK_CAN1(reg) |
| #define | SET_PCLKSEL0_PCLK_CAN1(reg, val) |
| #define | PCLKSEL0_PCLK_CAN2_MASK 0x30000000U |
| #define | GET_PCLKSEL0_PCLK_CAN2(reg) |
| #define | SET_PCLKSEL0_PCLK_CAN2(reg, val) |
| #define | PCLKSEL1_PCLK_BAT_RAM_MASK 0x00000003U |
| #define | GET_PCLKSEL1_PCLK_BAT_RAM(reg) |
| #define | SET_PCLKSEL1_PCLK_BAT_RAM(reg, val) |
| #define | PCLKSEL1_PCLK_GPIO_MASK 0x0000000cU |
| #define | GET_PCLKSEL1_PCLK_GPIO(reg) |
| #define | SET_PCLKSEL1_PCLK_GPIO(reg, val) |
| #define | PCLKSEL1_PCLK_PCB_MASK 0x00000030U |
| #define | GET_PCLKSEL1_PCLK_PCB(reg) |
| #define | SET_PCLKSEL1_PCLK_PCB(reg, val) |
| #define | PCLKSEL1_PCLK_I2C1_MASK 0x000000c0U |
| #define | GET_PCLKSEL1_PCLK_I2C1(reg) |
| #define | SET_PCLKSEL1_PCLK_I2C1(reg, val) |
| #define | PCLKSEL1_PCLK_SSP0_MASK 0x00000c00U |
| #define | GET_PCLKSEL1_PCLK_SSP0(reg) |
| #define | SET_PCLKSEL1_PCLK_SSP0(reg, val) |
| #define | PCLKSEL1_PCLK_TIMER2_MASK 0x00003000U |
| #define | GET_PCLKSEL1_PCLK_TIMER2(reg) |
| #define | SET_PCLKSEL1_PCLK_TIMER2(reg, val) |
| #define | PCLKSEL1_PCLK_TIMER3_MASK 0x0000c000U |
| #define | GET_PCLKSEL1_PCLK_TIMER3(reg) |
| #define | SET_PCLKSEL1_PCLK_TIMER3(reg, val) |
| #define | PCLKSEL1_PCLK_UART2_MASK 0x00030000U |
| #define | GET_PCLKSEL1_PCLK_UART2(reg) |
| #define | SET_PCLKSEL1_PCLK_UART2(reg, val) |
| #define | PCLKSEL1_PCLK_UART3_MASK 0x000c0000U |
| #define | GET_PCLKSEL1_PCLK_UART3(reg) |
| #define | SET_PCLKSEL1_PCLK_UART3(reg, val) |
| #define | PCLKSEL1_PCLK_I2C2_MASK 0x00300000U |
| #define | GET_PCLKSEL1_PCLK_I2C2(reg) |
| #define | SET_PCLKSEL1_PCLK_I2C2(reg, val) |
| #define | PCLKSEL1_PCLK_I2S_MASK 0x00c00000U |
| #define | GET_PCLKSEL1_PCLK_I2S(reg) |
| #define | SET_PCLKSEL1_PCLK_I2S(reg, val) |
| #define | PCLKSEL1_PCLK_MCI_MASK 0x03000000U |
| #define | GET_PCLKSEL1_PCLK_MCI(reg) |
| #define | SET_PCLKSEL1_PCLK_MCI(reg, val) |
| #define | PCLKSEL1_PCLK_SYSCON_MASK 0x30000000U |
| #define | GET_PCLKSEL1_PCLK_SYSCON(reg) |
| #define | SET_PCLKSEL1_PCLK_SYSCON(reg, val) |
| #define | RTC_ILR_RTCCIF 0x00000001U |
| #define | RTC_ILR_RTCALF 0x00000002U |
| #define | RTC_ILR_RTSSF 0x00000004U |
| #define | RTC_CCR_CLKEN 0x00000001U |
| #define | RTC_CCR_CTCRST 0x00000002U |
| #define | RTC_CCR_CLKSRC 0x00000010U |
| #define | SSP_CR0_DSS_MASK 0x0000000fU |
| #define | GET_SSP_CR0_DSS(reg) |
| #define | SET_SSP_CR0_DSS(reg, val) |
| #define | SSP_CR0_FRF_MASK 0x00000030U |
| #define | GET_SSP_CR0_FRF(reg) |
| #define | SET_SSP_CR0_FRF(reg, val) |
| #define | SSP_CR0_CPOL 0x00000040U |
| #define | SSP_CR0_CPHA 0x00000080U |
| #define | SSP_CR0_SCR_MASK 0x0000ff00U |
| #define | GET_SSP_CR0_SCR(reg) |
| #define | SET_SSP_CR0_SCR(reg, val) |
| #define | SSP_CR1_LBM 0x00000001U |
| #define | SSP_CR1_SSE 0x00000002U |
| #define | SSP_CR1_MS 0x00000004U |
| #define | SSP_CR1_SOD 0x00000008U |
| #define | SSP_SR_TFE 0x00000001U |
| #define | SSP_SR_TNF 0x00000002U |
| #define | SSP_SR_RNE 0x00000004U |
| #define | SSP_SR_RFF 0x00000008U |
| #define | SSP_SR_BSY 0x00000010U |
| #define | SSP_IMSC_RORIM 0x00000001U |
| #define | SSP_IMSC_RTIM 0x00000002U |
| #define | SSP_IMSC_RXIM 0x00000004U |
| #define | SSP_IMSC_TXIM 0x00000008U |
| #define | SSP_RIS_RORRIS 0x00000001U |
| #define | SSP_RIS_RTRIS 0x00000002U |
| #define | SSP_RIS_RXRIS 0x00000004U |
| #define | SSP_RIS_TXRIS 0x00000008U |
| #define | SSP_MIS_RORRIS 0x00000001U |
| #define | SSP_MIS_RTRIS 0x00000002U |
| #define | SSP_MIS_RXRIS 0x00000004U |
| #define | SSP_MIS_TXRIS 0x00000008U |
| #define | SSP_ICR_RORRIS 0x00000001U |
| #define | SSP_ICR_RTRIS 0x00000002U |
| #define | SSP_ICR_RXRIS 0x00000004U |
| #define | SSP_ICR_TXRIS 0x00000008U |
| #define | SSP_DMACR_RXDMAE 0x00000001U |
| #define | SSP_DMACR_TXDMAE 0x00000002U |
| #define | GPDMA_CH_NUMBER 2 |
| #define | GPDMA_STATUS_CH_0 0x00000001U |
| #define | GPDMA_STATUS_CH_1 0x00000002U |
| #define | GPDMA_CH_BASE_ADDR(i) |
| #define | GPDMA_CONFIG_EN 0x00000001U |
| #define | GPDMA_CONFIG_MODE 0x00000002U |
| #define | GPDMA_ENABLED_CHNS_CH0 0x00000001U |
| #define | GPDMA_ENABLED_CHNS_CH1 0x00000002U |
| #define | GPDMA_CH_CTRL_TSZ_MASK 0x00000fffU |
| #define | GET_GPDMA_CH_CTRL_TSZ(reg) |
| #define | SET_GPDMA_CH_CTRL_TSZ(reg, val) |
| #define | GPDMA_CH_CTRL_TSZ_MAX 0x00000fffU |
| #define | GPDMA_CH_CTRL_SBSZ_MASK 0x00007000U |
| #define | GET_GPDMA_CH_CTRL_SBSZ(reg) |
| #define | SET_GPDMA_CH_CTRL_SBSZ(reg, val) |
| #define | GPDMA_CH_CTRL_DBSZ_MASK 0x00038000U |
| #define | GET_GPDMA_CH_CTRL_DBSZ(reg) |
| #define | SET_GPDMA_CH_CTRL_DBSZ(reg, val) |
| #define | GPDMA_CH_CTRL_BSZ_1 0x00000000U |
| #define | GPDMA_CH_CTRL_BSZ_4 0x00000001U |
| #define | GPDMA_CH_CTRL_BSZ_8 0x00000002U |
| #define | GPDMA_CH_CTRL_BSZ_16 0x00000003U |
| #define | GPDMA_CH_CTRL_BSZ_32 0x00000004U |
| #define | GPDMA_CH_CTRL_BSZ_64 0x00000005U |
| #define | GPDMA_CH_CTRL_BSZ_128 0x00000006U |
| #define | GPDMA_CH_CTRL_BSZ_256 0x00000007U |
| #define | GPDMA_CH_CTRL_SW_MASK 0x001c0000U |
| #define | GET_GPDMA_CH_CTRL_SW(reg) |
| #define | SET_GPDMA_CH_CTRL_SW(reg, val) |
| #define | GPDMA_CH_CTRL_DW_MASK 0x00e00000U |
| #define | GET_GPDMA_CH_CTRL_DW(reg) |
| #define | SET_GPDMA_CH_CTRL_DW(reg, val) |
| #define | GPDMA_CH_CTRL_W_8 0x00000000U |
| #define | GPDMA_CH_CTRL_W_16 0x00000001U |
| #define | GPDMA_CH_CTRL_W_32 0x00000002U |
| #define | GPDMA_CH_CTRL_SI 0x04000000U |
| #define | GPDMA_CH_CTRL_DI 0x08000000U |
| #define | GPDMA_CH_CTRL_PROT_MASK 0x70000000U |
| #define | GET_GPDMA_CH_CTRL_PROT(reg) |
| #define | SET_GPDMA_CH_CTRL_PROT(reg, val) |
| #define | GPDMA_CH_CTRL_ITC 0x80000000U |
| #define | GPDMA_CH_CFG_EN 0x00000001U |
| #define | GPDMA_CH_CFG_SRCPER_MASK 0x0000001eU |
| #define | GET_GPDMA_CH_CFG_SRCPER(reg) |
| #define | SET_GPDMA_CH_CFG_SRCPER(reg, val) |
| #define | GPDMA_CH_CFG_DESTPER_MASK 0x000003c0U |
| #define | GET_GPDMA_CH_CFG_DESTPER(reg) |
| #define | SET_GPDMA_CH_CFG_DESTPER(reg, val) |
| #define | GPDMA_CH_CFG_PER_SSP0_TX 0x00000000U |
| #define | GPDMA_CH_CFG_PER_SSP0_RX 0x00000001U |
| #define | GPDMA_CH_CFG_PER_SSP1_TX 0x00000002U |
| #define | GPDMA_CH_CFG_PER_SSP1_RX 0x00000003U |
| #define | GPDMA_CH_CFG_PER_SD_MMC 0x00000004U |
| #define | GPDMA_CH_CFG_PER_I2S_CH0 0x00000005U |
| #define | GPDMA_CH_CFG_PER_I2S_CH1 0x00000006U |
| #define | GPDMA_CH_CFG_FLOW_MASK 0x00003800U |
| #define | GET_GPDMA_CH_CFG_FLOW(reg) |
| #define | SET_GPDMA_CH_CFG_FLOW(reg, val) |
| #define | GPDMA_CH_CFG_FLOW_MEM_TO_MEM_DMA 0x00000000U |
| #define | GPDMA_CH_CFG_FLOW_MEM_TO_PER_DMA 0x00000001U |
| #define | GPDMA_CH_CFG_FLOW_PER_TO_MEM_DMA 0x00000002U |
| #define | GPDMA_CH_CFG_FLOW_PER_TO_PER_DMA 0x00000003U |
| #define | GPDMA_CH_CFG_FLOW_PER_TO_PER_DEST 0x00000004U |
| #define | GPDMA_CH_CFG_FLOW_MEM_TO_PER_PER 0x00000005U |
| #define | GPDMA_CH_CFG_FLOW_PER_TO_MEM_PER 0x00000006U |
| #define | GPDMA_CH_CFG_FLOW_PER_TO_PER_SRC 0x00000007U |
| #define | GPDMA_CH_CFG_IE 0x00004000U |
| #define | GPDMA_CH_CFG_ITC 0x00008000U |
| #define | GPDMA_CH_CFG_LOCK 0x00010000U |
| #define | GPDMA_CH_CFG_ACTIVE 0x00020000U |
| #define | GPDMA_CH_CFG_HALT 0x00040000U |
| #define | AHBCFG_SCHEDULER_UNIFORM 0x00000001U |
| #define | AHBCFG_BREAK_BURST_MASK 0x00000006U |
| #define | GET_AHBCFG_BREAK_BURST(reg) |
| #define | SET_AHBCFG_BREAK_BURST(reg, val) |
| #define | AHBCFG_QUANTUM_BUS_CYCLE 0x00000008U |
| #define | AHBCFG_QUANTUM_SIZE_MASK 0x000000f0U |
| #define | GET_AHBCFG_QUANTUM_SIZE(reg) |
| #define | SET_AHBCFG_QUANTUM_SIZE(reg, val) |
| #define | AHBCFG_DEFAULT_MASTER_MASK 0x00000700U |
| #define | GET_AHBCFG_DEFAULT_MASTER(reg) |
| #define | SET_AHBCFG_DEFAULT_MASTER(reg, val) |
| #define | AHBCFG_EP1_MASK 0x00007000U |
| #define | GET_AHBCFG_EP1(reg) |
| #define | SET_AHBCFG_EP1(reg, val) |
| #define | AHBCFG_EP2_MASK 0x00070000U |
| #define | GET_AHBCFG_EP2(reg) |
| #define | SET_AHBCFG_EP2(reg, val) |
| #define | AHBCFG_EP3_MASK 0x00700000U |
| #define | GET_AHBCFG_EP3(reg) |
| #define | SET_AHBCFG_EP3(reg, val) |
| #define | AHBCFG_EP4_MASK 0x07000000U |
| #define | GET_AHBCFG_EP4(reg) |
| #define | SET_AHBCFG_EP4(reg, val) |
| #define | AHBCFG_EP5_MASK 0x70000000U |
| #define | GET_AHBCFG_EP5(reg) |
| #define | SET_AHBCFG_EP5(reg, val) |
| #define | LPC24XX_I2C_AA (1U << 2U) |
| #define | LPC24XX_I2C_SI (1U << 3U) |
| #define | LPC24XX_I2C_STO (1U << 4U) |
| #define | LPC24XX_I2C_STA (1U << 5U) |
| #define | LPC24XX_I2C_EN (1U << 6U) |
| #define | IOCON_FUNC(val) |
| #define | IOCON_FUNC_GET(reg) |
| #define | IOCON_FUNC_SET(reg, val) |
| #define | IOCON_MODE(val) |
| #define | IOCON_MODE_GET(reg) |
| #define | IOCON_MODE_SET(reg, val) |
| #define | IOCON_HYS BSP_BIT32(5) |
| #define | IOCON_INV BSP_BIT32(6) |
| #define | IOCON_ADMODE BSP_BIT32(7) |
| #define | IOCON_FILTER BSP_BIT32(8) |
| #define | IOCON_HS BSP_BIT32(8) |
| #define | IOCON_SLEW BSP_BIT32(9) |
| #define | IOCON_HIDRIVE BSP_BIT32(9) |
| #define | IOCON_OD BSP_BIT32(10) |
| #define | IOCON_DACEN BSP_BIT32(16) |
| #define | LPC17XX_IOCON ((volatile uint32_t *) PINSEL_BASE_ADDR) |
| #define | LPC24XX_FIO ((volatile lpc24xx_fio *) FIO_BASE_ADDR) |
| #define | ADC_CR_SEL(val) |
| #define | ADC_CR_SEL_GET(val) |
| #define | ADC_CR_SEL_SET(reg, val) |
| #define | ADC_CR_CLKDIV(val) |
| #define | ADC_CR_CLKDIV_GET(reg) |
| #define | ADC_CR_CLKDIV_SET(reg, val) |
| #define | ADC_CR_BURST BSP_BIT32(16) |
| #define | ADC_CR_CLKS(val) |
| #define | ADC_CR_PDN BSP_BIT32(21) |
| #define | ADC_CR_START(val) |
| #define | ADC_CR_EDGE BSP_BIT32(27) |
| #define | ADC_DR_VALUE(reg) |
| #define | ADC_DR_OVERRUN BSP_BIT32(30) |
| #define | ADC_DR_DONE BSP_BIT32(31) |
| #define | DAC_STEPS 1024 |
| #define | DAC_VALUE(val) |
| #define | DAC_BIAS BSP_BIT32(16) |
Register definitions.
