RTEMS 6.3
Directories | |
| config | |
| console | |
| fb | |
| i2c | |
| include | |
| irq | |
| rtc | |
| spi | |
| start | |
Development Board: QVGA Base Board from Embedded Artists
http://www.embeddedartists.com/products/uclinux/oem_lpc2478.php
Drivers:
o Console o Clock o RTC o SSP (SPI mode) o Network o I2C
Howto setup QVGA Base Board?
o Unpack board.
o Connect board via USB to your PC.
o Verify that demo application runs.
o Disconnect board.
o Change jumpers to enable ISP.
o Connect board.
o Load U-Boot image 'u-boot_v1.1.6_lpc2468oem_v1_8_16bit.hex'
(available from the EA support page) into the flash (flash tool
FlashMagic is availabe from NXP).
o Change jumbers back to disable ISP.
o Use a terminal program to change the U-Boot settings via the console.
o U-Boot settings:
set ethaddr '00:1a:f1:X:X:X'
set serverip 'X.X.X.X'
set ipaddr 'X.X.X.X'
set rtems 'tftp a1000000 lpc2478.img;bootm'
set bootcmd 'echo Booting RTEMS ...;run rtems'
saveenv
Howto make a U-Boot image?
mkimage -A arm -O rtems -T kernel -C gzip \ -a a0000000 -e a0000040 -n "RTEMS Application" -d app.bin.gz app.img
Application Board: NCS (Nurse Control Station)
Board: NextGenNCS Processor: NXP LPC2478 or LPC2470 SDRAM: 8MByte, 16 bit wide Ext. Flash: 1MByte, 16 bit wide Console: UART, 115200 Baud Network: 100Base-T
Application Board: TLI800 TLI800 is a network node using four serial ports produced by Thorn Security Limited. It is used by Tyco Fire & Integrated Solutions for a fire control network.
