RTEMS
6.3
Toggle main menu visibility
bsps
arm
lpc24xx
include
bsp
system-clocks.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2008, 2009 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_LPC24XX_SYSTEM_CLOCKS_H
37
#define LIBBSP_ARM_LPC24XX_SYSTEM_CLOCKS_H
38
39
bsp/lpc24xx.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
54
60
void
lpc24xx_timer_initialize
void
61
67
static
inline
unsigned
lpc24xx_timer(
void
68
69
return
T1TC;
70
71
81
void
lpc24xx_micro_seconds_delay
unsigned
us);
82
88
unsigned
lpc24xx_pllclk
void
89
95
unsigned
lpc24xx_cclk
void
96
98
99
#ifdef __cplusplus
100
101
#endif
/* __cplusplus */
102
103
#endif
/* LIBBSP_ARM_LPC24XX_SYSTEM_CLOCKS_H */
lpc24xx_cclk
unsigned lpc24xx_cclk(void)
Returns the CPU clock frequency in [Hz].
Definition
system-clocks.c:159
lpc24xx_pllclk
unsigned lpc24xx_pllclk(void)
Returns the PLL output clock frequency in [Hz].
Definition
system-clocks.c:109
void lpc24xx_timer_initialize(void)
Initializes the standard timer.
Definition
system-clocks.c:55
void lpc24xx_micro_seconds_delay(unsigned us)
Delay for us micro seconds.
Definition
system-clocks.c:89
lpc24xx.h
Register definitions.
