RTEMS 6.3
lpc-clock-config.h
2
10
11/*
12 * Copyright (c) 2009 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC24XX_LPC_CLOCK_CONFIG_H
37#define LIBBSP_ARM_LPC24XX_LPC_CLOCK_CONFIG_H
38
39#include <bsp.h>
40#include <bsp/irq.h>
41#include <bsp/lpc24xx.h>
42#include <bsp/io.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif /* __cplusplus */
47
48#define LPC_CLOCK_INTERRUPT LPC24XX_IRQ_TIMER_0
49
50#define LPC_CLOCK_TIMER_BASE TMR0_BASE_ADDR
51
52#define LPC_CLOCK_TIMECOUNTER_BASE TMR1_BASE_ADDR
53
54#define LPC_CLOCK_REFERENCE LPC24XX_PCLK
55
56#define LPC_CLOCK_MODULE_ENABLE() \
57 lpc24xx_module_enable(LPC24XX_MODULE_TIMER_0, LPC24XX_MODULE_PCLK_DEFAULT)
58
59#ifdef __cplusplus
60}
61#endif /* __cplusplus */
62
63#endif /* LIBBSP_ARM_LPC24XX_LPC_CLOCK_CONFIG_H */
Register definitions.
