RTEMS
6.3
Toggle main menu visibility
bsps
arm
lpc24xx
include
bsp
dma.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2008, 2009 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_LPC24XX_DMA_H
37
#define LIBBSP_ARM_LPC24XX_DMA_H
38
39
rtems.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
54
58
void
lpc24xx_dma_initialize
void
59
67
rtems_status_code
lpc24xx_dma_channel_obtain
unsigned
channel);
68
77
void
lpc24xx_dma_channel_release
unsigned
channel);
78
87
void
lpc24xx_dma_channel_disable
unsigned
channel,
bool
force);
88
89
rtems_status_code
lpc24xx_dma_copy_initialize(
void
90
91
rtems_status_code
lpc24xx_dma_copy_release(
void
92
93
rtems_status_code
lpc24xx_dma_copy(
94
unsigned
channel,
95
void
*dest,
96
const
void
*src,
97
size_t
n,
98
size_t
width
99
100
101
rtems_status_code
lpc24xx_dma_copy_wait(
unsigned
channel);
102
104
105
#ifdef __cplusplus
106
107
#endif
/* __cplusplus */
108
109
#endif
/* LIBBSP_ARM_LPC24XX_DMA_H */
rtems_status_code
rtems_status_code
Definition
status.h:85
rtems_status_code lpc24xx_dma_channel_obtain(unsigned channel)
Tries to obtain the DMA channel channel.
Definition
dma.c:72
void lpc24xx_dma_initialize(void)
Initializes the general purpose DMA.
Definition
dma.c:47
void lpc24xx_dma_channel_disable(unsigned channel, bool force)
Disables the DMA channel channel.
Definition
dma.c:96
void lpc24xx_dma_channel_release(unsigned channel)
Releases the DMA channel channel.
Definition
dma.c:89
rtems.h
