RTEMS 6.3
irq-generic.c File Reference
This source file contains the generic interrupt controller support implementation. More...
#include <bsp/irq-generic.h>
#include <rtems/malloc.h>
RTEMS_WEAK rtems_interrupt_entry ** bsp_interrupt_get_dispatch_table_slot (rtems_vector_number index)
 Gets a reference to the interrupt handler table slot associated with the index.
rtems_status_code bsp_interrupt_check_and_lock (rtems_vector_number vector, rtems_interrupt_handler routine)
 Checks the vector and routine. When the checks were successful, the interrupt support lock will be obtained.
rtems_interrupt_entry * bsp_interrupt_entry_find (rtems_vector_number vector, rtems_interrupt_handler routine, void *arg, rtems_interrupt_entry ***previous_next)
void bsp_interrupt_initialize (void)
 Initialize Interrupt Manager implementation.
rtems_status_code rtems_interrupt_entry_install (rtems_vector_number vector, rtems_option options, rtems_interrupt_entry *entry)
 Installs the interrupt entry at the interrupt vector.
rtems_interrupt_entry * bsp_interrupt_dispatch_table [BSP_INTERRUPT_DISPATCH_TABLE_SIZE]
 Each member of this table references the first installed entry at the corresponding interrupt vector or is NULL.
uint8_t bsp_interrupt_handler_unique_table [(BSP_INTERRUPT_DISPATCH_TABLE_SIZE+7+1)/8]
 This table contains a bit map which indicates if an entry is unique or shared.
◆ bsp_interrupt_check_and_lock()
rtems_status_code bsp_interrupt_check_and_lock ( rtems_vector_number vector,
rtems_interrupt_handler handler )
Parameters
vectoris the interrupt vector number to check.
routineis the routine to check.
Return values
RTEMS_SUCCESSFULThe requested operation was successful.
RTEMS_INCORRECT_STATEThe interrupt support was not initialized.
RTEMS_CALLED_FROM_ISRThe function was called from within interrupt context.
RTEMS_INVALID_ADDRESSThe routine parameter was NULL.
RTEMS_INVALID_IDThere was no interrupt vector associated with the number specified by vector.
◆ bsp_interrupt_get_dispatch_table_slot()
RTEMS_WEAK rtems_interrupt_entry ** bsp_interrupt_get_dispatch_table_slot ( rtems_vector_number index)
Returns
Returns a reference to the interrupt handler table slot associated with the index.
Variable Documentation
◆ bsp_interrupt_handler_unique_table
uint8_t bsp_interrupt_handler_unique_table[(BSP_INTERRUPT_DISPATCH_TABLE_SIZE+7+1)/8]
If the bit associated with a vector is set, then the entry is unique, otherwise it may be shared. If the bit with index #BSP_INTERRUPT_DISPATCH_TABLE_SIZE is set, then the interrupt support is initialized, otherwise it is not initialized.
