RTEMS 6.3
interrupts.h File Reference
Intel I386 Interrupt Macros. More...
Interrupt Level Macros
#define i386_disable_interrupts(_level)
#define i386_enable_interrupts(_level)
#define i386_flash_interrupts(_level)
#define i386_get_interrupt_level(_level)
typedef void(*) rtems_raw_irq_hdl(void)
typedef void(*) rtems_raw_irq_enable(const struct __rtems_raw_irq_connect_data__ *)
typedef void(*) rtems_raw_irq_disable(const struct __rtems_raw_irq_connect_data__ *)
typedef int(*) rtems_raw_irq_is_enabled(const struct __rtems_raw_irq_connect_data__ *)
Formerly contained in and extracted from libcpu/i386/cpu.h
Applications must not include this file directly.
