RTEMS 6.3
i386 Interrupt Management More...
Typedefs | |
| typedef void(*) | rtems_raw_irq_hdl(void) |
| typedef void(*) | rtems_raw_irq_enable(const struct __rtems_raw_irq_connect_data__ *) |
| typedef void(*) | rtems_raw_irq_disable(const struct __rtems_raw_irq_connect_data__ *) |
| typedef int(*) | rtems_raw_irq_is_enabled(const struct __rtems_raw_irq_connect_data__ *) |
Interrupt Level Macros | |
| #define | i386_disable_interrupts(_level) |
| #define | i386_enable_interrupts(_level) |
| #define | i386_flash_interrupts(_level) |
| #define | i386_get_interrupt_level(_level) |
| #define i386_disable_interrupts | ( | _level | ) |
| #define i386_enable_interrupts | ( | _level | ) |
| #define i386_flash_interrupts | ( | _level | ) |
| #define i386_get_interrupt_level | ( | _level | ) |
