RTEMS
6.3
Toggle main menu visibility
score
cpu
i386
include
score
interrupts.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
14
* COPYRIGHT (c) 1998 valette@crf.canon.fr
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
46
47
#ifndef _RTEMS_SCORE_INTERRUPTS_H
48
#define _RTEMS_SCORE_INTERRUPTS_H
49
50
#ifndef ASM
51
52
struct
__rtems_raw_irq_connect_data__
53
54
typedef
void (*rtems_raw_irq_hdl) (void);
55
typedef
void (*rtems_raw_irq_enable) (
const
struct
56
typedef
void (*rtems_raw_irq_disable) (
const
struct
57
typedef
int (*rtems_raw_irq_is_enabled) (
const
struct
58
64
#if !defined(I386_DISABLE_INLINE_ISR_DISABLE_ENABLE)
65
#define i386_disable_interrupts( _level ) \
66
67
__asm__ volatile ( "pushf ; \
68
cli ; \
69
pop %0" \
70
: "=rm" ((_level)) \
71
72
73
74
#define i386_enable_interrupts( _level ) \
75
76
__asm__ volatile ( "push %0 ; \
77
popf" \
78
: : "rm" ((_level)) : "cc" \
79
80
81
82
#define i386_flash_interrupts( _level ) \
83
84
85
popf ; \
86
cli" \
87
88
89
90
91
#define i386_get_interrupt_level( _level ) \
92
do { \
93
uint32_t _eflags; \
94
95
96
pop %0" \
97
: "=rm" ((_eflags)) \
98
99
100
_level = (_eflags & EFLAGS_INTR_ENABLE) ? 0 : 1; \
101
} while (0)
102
#else
103
uint32_t i386_disable_interrupts(
void
104
void
i386_enable_interrupts(uint32_t level);
105
void
i386_flash_interrupts(uint32_t level);
106
void
i386_set_interrupt_level(uint32_t new_level);
107
uint32_t i386_get_interrupt_level(
void
108
#endif
/* PARAVIRT */
109
111
113
#endif
114
#endif
Definition
i386.h:380
