RTEMS 6.3
This group contains the GRPCI2 interfaces. More...
Topics | |
| AHB master to PCI memory address mapping register (AHBM2PCI) | |
| This group contains register bit definitions. | |
| AHB to PCI mapping for PCI IO (AHB2PCI) | |
| Control register (CTRL) | |
| DMA channel active register (DMACHAN) | |
| DMA control and status register (DMACTRL) | |
| DMA descriptor base address register (DMABASE) | |
| PCI BAR to AHB address mapping register (PCI2AHB) | |
| PCI master prefetch burst limit (BCIM) | |
| PCI trace AD mask register (TADM) | |
| PCI trace AD pattern register (TADP) | |
| PCI trace Control and Status register (TCTRC) | |
| PCI trace Ctrl signal mask register (TCM) | |
| PCI trace Ctrl signal pattern register (TCP) | |
| PCI trace PCI AD state register (TADS) | |
| PCI trace PCI Ctrl signal state register (TCS) | |
| PCI trace counter and mode register (TMODE) | |
| Status and Capability register (STATCAP) | |
Files | |
| file | bsps/include/grlib/grpci2-regs.h |
| This header file defines the GRPCI2 register block interface. | |
| struct | grpci2 |
| This structure defines the GRPCI2 register block memory map. More... | |
Typedefs | |
| typedef struct grpci2 | grpci2 |
| This structure defines the GRPCI2 register block memory map. | |
