RTEMS 6.3
Status and Capability register (STATCAP)
This group contains register bit definitions. More...
#define GRPCI2_STATCAP_HOST   0x80000000U
#define GRPCI2_STATCAP_MST   0x40000000U
#define GRPCI2_STATCAP_TAR   0x20000000U
#define GRPCI2_STATCAP_DMA   0x10000000U
#define GRPCI2_STATCAP_DI   0x8000000U
#define GRPCI2_STATCAP_HI   0x4000000U
#define GRPCI2_STATCAP_IRQ_MODE_SHIFT   24
#define GRPCI2_STATCAP_IRQ_MODE_MASK   0x3000000U
#define GRPCI2_STATCAP_IRQ_MODE_GET(_reg)
#define GRPCI2_STATCAP_IRQ_MODE_SET(_reg, _val)
#define GRPCI2_STATCAP_IRQ_MODE(_val)
#define GRPCI2_STATCAP_TRACE   0x800000U
#define GRPCI2_STATCAP_CFGDO   0x100000U
#define GRPCI2_STATCAP_CFGER   0x80000U
#define GRPCI2_STATCAP_CORE_INT_STATUS_SHIFT   12
#define GRPCI2_STATCAP_CORE_INT_STATUS_MASK   0x7f000U
#define GRPCI2_STATCAP_CORE_INT_STATUS_GET(_reg)
#define GRPCI2_STATCAP_CORE_INT_STATUS_SET(_reg, _val)
#define GRPCI2_STATCAP_CORE_INT_STATUS(_val)
#define GRPCI2_STATCAP_HOST_INT_STATUS_SHIFT   8
#define GRPCI2_STATCAP_HOST_INT_STATUS_MASK   0xf00U
#define GRPCI2_STATCAP_HOST_INT_STATUS_GET(_reg)
#define GRPCI2_STATCAP_HOST_INT_STATUS_SET(_reg, _val)
#define GRPCI2_STATCAP_HOST_INT_STATUS(_val)
#define GRPCI2_STATCAP_FDEPTH_SHIFT   2
#define GRPCI2_STATCAP_FDEPTH_MASK   0x1cU
#define GRPCI2_STATCAP_FDEPTH_GET(_reg)
#define GRPCI2_STATCAP_FDEPTH_SET(_reg, _val)
#define GRPCI2_STATCAP_FDEPTH(_val)
#define GRPCI2_STATCAP_FNUM_SHIFT   0
#define GRPCI2_STATCAP_FNUM_MASK   0x3U
#define GRPCI2_STATCAP_FNUM_GET(_reg)
#define GRPCI2_STATCAP_FNUM_SET(_reg, _val)
#define GRPCI2_STATCAP_FNUM(_val)
◆ GRPCI2_STATCAP_CORE_INT_STATUS
#define GRPCI2_STATCAP_CORE_INT_STATUS ( _val)
Value:
( ( ( _val ) << GRPCI2_STATCAP_CORE_INT_STATUS_SHIFT ) & \
GRPCI2_STATCAP_CORE_INT_STATUS_MASK )
◆ GRPCI2_STATCAP_CORE_INT_STATUS_GET
#define GRPCI2_STATCAP_CORE_INT_STATUS_GET ( _reg)
Value:
( ( ( _reg ) & GRPCI2_STATCAP_CORE_INT_STATUS_MASK ) >> \
◆ GRPCI2_STATCAP_CORE_INT_STATUS_SET
#define GRPCI2_STATCAP_CORE_INT_STATUS_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GRPCI2_STATCAP_CORE_INT_STATUS_MASK ) | \
GRPCI2_STATCAP_CORE_INT_STATUS_MASK ) )
◆ GRPCI2_STATCAP_FDEPTH
#define GRPCI2_STATCAP_FDEPTH ( _val)
Value:
( ( ( _val ) << GRPCI2_STATCAP_FDEPTH_SHIFT ) & \
GRPCI2_STATCAP_FDEPTH_MASK )
◆ GRPCI2_STATCAP_FDEPTH_GET
#define GRPCI2_STATCAP_FDEPTH_GET ( _reg)
Value:
( ( ( _reg ) & GRPCI2_STATCAP_FDEPTH_MASK ) >> \
◆ GRPCI2_STATCAP_FDEPTH_SET
#define GRPCI2_STATCAP_FDEPTH_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GRPCI2_STATCAP_FDEPTH_MASK ) | \
GRPCI2_STATCAP_FDEPTH_MASK ) )
◆ GRPCI2_STATCAP_FNUM
#define GRPCI2_STATCAP_FNUM ( _val)
Value:
( ( ( _val ) << GRPCI2_STATCAP_FNUM_SHIFT ) & \
GRPCI2_STATCAP_FNUM_MASK )
◆ GRPCI2_STATCAP_FNUM_GET
#define GRPCI2_STATCAP_FNUM_GET ( _reg)
Value:
( ( ( _reg ) & GRPCI2_STATCAP_FNUM_MASK ) >> \
◆ GRPCI2_STATCAP_FNUM_SET
#define GRPCI2_STATCAP_FNUM_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GRPCI2_STATCAP_FNUM_MASK ) | \
GRPCI2_STATCAP_FNUM_MASK ) )
◆ GRPCI2_STATCAP_HOST_INT_STATUS
#define GRPCI2_STATCAP_HOST_INT_STATUS ( _val)
Value:
( ( ( _val ) << GRPCI2_STATCAP_HOST_INT_STATUS_SHIFT ) & \
GRPCI2_STATCAP_HOST_INT_STATUS_MASK )
◆ GRPCI2_STATCAP_HOST_INT_STATUS_GET
#define GRPCI2_STATCAP_HOST_INT_STATUS_GET ( _reg)
Value:
( ( ( _reg ) & GRPCI2_STATCAP_HOST_INT_STATUS_MASK ) >> \
◆ GRPCI2_STATCAP_HOST_INT_STATUS_SET
#define GRPCI2_STATCAP_HOST_INT_STATUS_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GRPCI2_STATCAP_HOST_INT_STATUS_MASK ) | \
GRPCI2_STATCAP_HOST_INT_STATUS_MASK ) )
◆ GRPCI2_STATCAP_IRQ_MODE
#define GRPCI2_STATCAP_IRQ_MODE ( _val)
Value:
( ( ( _val ) << GRPCI2_STATCAP_IRQ_MODE_SHIFT ) & \
GRPCI2_STATCAP_IRQ_MODE_MASK )
◆ GRPCI2_STATCAP_IRQ_MODE_GET
#define GRPCI2_STATCAP_IRQ_MODE_GET ( _reg)
Value:
( ( ( _reg ) & GRPCI2_STATCAP_IRQ_MODE_MASK ) >> \
◆ GRPCI2_STATCAP_IRQ_MODE_SET
#define GRPCI2_STATCAP_IRQ_MODE_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GRPCI2_STATCAP_IRQ_MODE_MASK ) | \
GRPCI2_STATCAP_IRQ_MODE_MASK ) )
