RTEMS 6.3
NXP LPC32XX Board Support Package. More...
Topics
 Boot Support
 Boot support.
 Clock Support
 Clock support.
 DMA Support
 DMA support.
 EMC Support
 EMC Support.
 Ethernet Support
 Ethernet support.
 HSU Support
 HSU Support.
 I2C Support
 I2C Support.
 I2S Support
 I2S support.
 Interrupt Support
 LCD Support
 LCD support.
 MMU Support
 MMU support.
 NAND MLC Controller
 NAND MLC Controller.
 Register Definitions
 Register definitions.
 Timer Support
 Timer support.
file  bsps/arm/lpc32xx/console/console-config.c
 Console configuration.
file  bsps/arm/lpc32xx/console/hsu.c
 High speed UART driver (14-clock).
file  bsps/arm/lpc32xx/include/bsp.h
 Global BSP definitions.
file  bsps/arm/lpc32xx/nand/nand-select.c
 NAND controller selection.
file  bsps/arm/lpc32xx/rtc/rtc-config.c
 RTC configuration.
file  bsps/arm/lpc32xx/start/bspidle.c
 bsp_idle_thread() implementation.
file  bsps/arm/lpc32xx/start/bspreset.c
 Reset code.
file  bsps/arm/lpc32xx/start/bspstart.c
 Startup code.
file  bsps/arm/lpc32xx/start/bspstarthooks.c
 Startup code.
file  bsps/arm/lpc32xx/start/restart.c
 Restart implementation.
file  bsps/arm/lpc32xx/start/system-clocks.c
 System clocks.
file  bsps/arm/lpc32xx/start/timer.c
 Benchmark timer support.
#define BSP_FEATURE_IRQ_EXTENSION
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   lpc_eth_attach_detach
 Standard network driver attach and detach function.
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "eth0"
 Standard network driver name.
#define LPC32XX_STANDARD_TIMER   (&lpc32xx.timer_1)
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
#define BSP_CONSOLE_UART_BASE   LPC32XX_BASE_UART_5
#define LPC32XX_DO_STOP_GPDMA
#define LPC32XX_DO_STOP_ETHERNET
#define LPC32XX_DO_STOP_USB
#define LPC32XX_DO_RESTART(addr)
enum  lpc32xx_nand_controller { LPC32XX_NAND_CONTROLLER_NONE , LPC32XX_NAND_CONTROLLER_MLC , LPC32XX_NAND_CONTROLLER_SLC }
int lpc_eth_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching)
 Network driver attach and detach function.
void * lpc32xx_idle (uintptr_t ignored)
 Optimized idle task.
bool lpc32xx_start_pll_setup (uint32_t hclkpll_ctrl, uint32_t hclkdiv_ctrl, bool force)
uint32_t lpc32xx_sysclk (void)
uint32_t lpc32xx_hclkpll_clk (void)
uint32_t lpc32xx_periph_clk (void)
uint32_t lpc32xx_hclk (void)
uint32_t lpc32xx_arm_clk (void)
uint32_t lpc32xx_ddram_clk (void)
void lpc32xx_select_nand_controller (lpc32xx_nand_controller nand_controller)
void bsp_restart (void *addr)
void * bsp_idle_thread (uintptr_t arg)
uint32_t lpc32xx_magic_zero_begin []
 Begin of magic zero area.
uint32_t lpc32xx_magic_zero_end []
 End of magic zero area.
uint32_t lpc32xx_magic_zero_size []
 Size of magic zero area.
◆ LPC32XX_DO_RESTART
#define LPC32XX_DO_RESTART ( addr)
Value:
do { \
ARM_SWITCH_REGISTERS; \
uint32_t ctrl = 0; \
rtems_interrupt_disable(level); \
(void) level; \
arm_cp15_data_cache_test_and_clean(); \
arm_cp15_instruction_cache_invalidate(); \
ctrl = arm_cp15_get_control(); \
ctrl &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M); \
arm_cp15_set_control(ctrl); \
__asm__ volatile ( \
ARM_SWITCH_TO_ARM \
"mov pc, %[addr]\n" \
ARM_SWITCH_BACK \
: ARM_SWITCH_OUTPUT \
: [addr] "r" (addr) \
} while (0)
ISR_Level rtems_interrupt_level
This integer type represents interrupt levels.
Definition intr.h:111
◆ LPC32XX_DO_STOP_ETHERNET
Value:
do { \
if ((LPC32XX_MAC_CLK_CTRL & 0x7) == 0x7) { \
lpc32xx.eth.command = 0x38; \
lpc32xx.eth.mac1 = 0xcf00; \
lpc32xx.eth.mac1 = 0; \
LPC32XX_MAC_CLK_CTRL = 0; \
} while (0)
◆ LPC32XX_DO_STOP_GPDMA
Value:
do { \
if ((LPC32XX_DMACLK_CTRL & 0x1) != 0) { \
if ((lpc32xx.dma.cfg & DMA_CFG_E) != 0) { \
int i = 0; \
for (i = 0; i < 8; ++i) { \
lpc32xx.dma.channels [i].cfg = 0; \
lpc32xx.dma.cfg &= ~DMA_CFG_E; \
LPC32XX_DMACLK_CTRL = 0; \
} while (0)
◆ LPC32XX_DO_STOP_USB
Value:
do { \
if ((LPC32XX_USB_CTRL & 0x010e8000) != 0) { \
LPC32XX_OTG_CLK_CTRL = 0; \
LPC32XX_USB_CTRL = 0x80000; \
} while (0)
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t arg)
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
◆ lpc32xx_idle()
void * lpc32xx_idle ( uintptr_t ignored)
#include <bsp.h>
#define CONFIGURE_IDLE_TASK_BODY lpc32xx_idle
Variable Documentation
◆ lpc32xx_magic_zero_begin
uint32_t lpc32xx_magic_zero_begin[]
extern
A read from this area returns zero. Writes have no effect.
◆ lpc32xx_magic_zero_end
uint32_t lpc32xx_magic_zero_end[]
extern
◆ lpc32xx_magic_zero_size
uint32_t lpc32xx_magic_zero_size[]
extern
