RTEMS
6.3
Toggle main menu visibility
Ethernet Support
Board Support Packages
ARM
NXP LPC32XX
Ethernet support.
More...
file
bsps/arm/lpc32xx/include/bsp/lpc-ethernet-config.h
Ethernet driver configuration.
#define
LPC_ETH_CONFIG_INTERRUPT
LPC32XX_IRQ_ETHERNET
#define
LPC_ETH_CONFIG_REG_BASE
LPC32XX_BASE_ETHERNET
#define
LPC_ETH_CONFIG_RX_UNIT_COUNT_DEFAULT
16
#define
LPC_ETH_CONFIG_RX_UNIT_COUNT_MAX
INT_MAX
#define
LPC_ETH_CONFIG_TX_UNIT_COUNT_DEFAULT
128
#define
LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX
INT_MAX
#define
LPC_ETH_CONFIG_UNIT_MULTIPLE
8U
#define
LPC_ETH_CONFIG_USE_TRANSMIT_DMA
Ethernet support.
