RTEMS 6.3
EMC Support. More...
Files | |
| file | bsps/arm/include/bsp/lpc-emc.h |
| EMC support API. | |
| struct | lpc_emc_dynamic |
| struct | lpc_emc_static |
| struct | lpc_emc |
| struct | lpc32xx_emc_dynamic_chip_config |
| struct | lpc32xx_emc_dynamic_config |
| #define | EMC_DYN_CHIP_COUNT 4 |
| #define | EMC_STATIC_CHIP_COUNT 4 |
| void | lpc32xx_emc_init (const lpc32xx_emc_dynamic_config *dyn_cfg) |
EMC Control Register (EMCControl) | |
| #define | EMC_CTRL_E BSP_BIT32(0) |
| #define | EMC_CTRL_M BSP_BIT32(0) |
| #define | EMC_CTRL_L BSP_BIT32(2) |
EMC Dynamic Memory Read Configuration Register (EMCDynamicReadConfig) | |
| #define | EMC_DYN_READ_CONFIG_SDR_STRAT(val) |
| #define | EMC_DYN_READ_CONFIG_SDR_POL_POS BSP_BIT32(4) |
| #define | EMC_DYN_READ_CONFIG_DDR_STRAT(val) |
| #define | EMC_DYN_READ_CONFIG_DDR_POL_POS BSP_BIT32(12) |
EMC Dynamic Memory Configuration N Register (EMCDynamicConfigN) | |
| #define | EMC_DYN_CFG_MD_LPC24XX(val) |
| #define | EMC_DYN_CFG_MD_LPC32XX(val) |
| #define | EMC_DYN_CFG_AM(val) |
| #define | EMC_DYN_CFG_B BSP_BIT32(19) |
| #define | EMC_DYN_CFG_P BSP_BIT32(20) |
EMC Dynamic Memory RAS and CAS Delay N Register (EMCDynamicRasCasN) | |
| #define | EMC_DYN_RASCAS_RAS(val) |
| #define | EMC_DYN_RASCAS_CAS(val, half) |
SDRAM Clock Control Register (SDRAMCLK_CTRL) | |
| #define | SDRAMCLK_CLOCKS_DIS BSP_BIT32(0) |
| #define | SDRAMCLK_DDR_MODE BSP_BIT32(1) |
| #define | SDRAMCLK_DDR_DQSIN_DELAY(val) |
| #define | SDRAMCLK_RTC_TICK_EN BSP_BIT32(7) |
| #define | SDRAMCLK_SW_DDR_CAL BSP_BIT32(8) |
| #define | SDRAMCLK_CAL_DELAY BSP_BIT32(9) |
| #define | SDRAMCLK_SENSITIVITY_FACTOR(val) |
| #define | SDRAMCLK_DCA_STATUS BSP_BIT32(13) |
| #define | SDRAMCLK_COMMAND_DELAY(val) |
| #define | SDRAMCLK_SW_DDR_RESET BSP_BIT32(19) |
| #define | SDRAMCLK_PIN_1_FAST BSP_BIT32(20) |
| #define | SDRAMCLK_PIN_2_FAST BSP_BIT32(21) |
| #define | SDRAMCLK_PIN_3_FAST BSP_BIT32(22) |
EMC AHB Control Register (EMCAHBControl) | |
| #define | EMC_AHB_PORT_BUFF_EN BSP_BIT32(0) |
EMC AHB Timeout Register (EMCAHBTimeOut) | |
| #define | EMC_AHB_TIMEOUT(val) |
SDRAM Mode and Extended Mode Registers | |
| #define | SDRAM_ADDR_ROW_16MB(val) |
| #define | SDRAM_ADDR_ROW_32MB(val) |
| #define | SDRAM_ADDR_ROW_64MB(val) |
| #define | SDRAM_ADDR_BANK_16MB(ba1, ba0) |
| #define | SDRAM_ADDR_BANK_32MB(ba1, ba0) |
| #define | SDRAM_ADDR_BANK_64MB(ba1, ba0) |
| #define | SDRAM_MODE_16MB(mode) |
| #define | SDRAM_MODE_32MB(mode) |
| #define | SDRAM_MODE_64MB(mode) |
| #define | SDRAM_EXTMODE_16MB(mode) |
| #define | SDRAM_EXTMODE_32MB(mode) |
| #define | SDRAM_EXTMODE_64MB(mode) |
| #define | SDRAM_MODE_BURST_LENGTH(val) |
| #define | SDRAM_MODE_BURST_INTERLEAVE BSP_BIT32(3) |
| #define | SDRAM_MODE_CAS(val) |
| #define | SDRAM_MODE_TEST_MODE(val) |
| #define | SDRAM_MODE_WRITE_BURST_SINGLE_BIT BSP_BIT32(9) |
| #define | SDRAM_EXTMODE_PASR(val) |
| #define | SDRAM_EXTMODE_DRIVER_STRENGTH(val) |
EMC Support.
| #define EMC_AHB_TIMEOUT | ( | val | ) |
| #define EMC_DYN_CFG_AM | ( | val | ) |
| #define EMC_DYN_CFG_MD_LPC24XX | ( | val | ) |
| #define EMC_DYN_CFG_MD_LPC32XX | ( | val | ) |
| #define EMC_DYN_RASCAS_CAS | ( | val, | |
| half ) |
| #define EMC_DYN_RASCAS_RAS | ( | val | ) |
| #define EMC_DYN_READ_CONFIG_DDR_STRAT | ( | val | ) |
| #define EMC_DYN_READ_CONFIG_SDR_STRAT | ( | val | ) |
| #define SDRAM_ADDR_BANK_16MB | ( | ba1, | |
| ba0 ) |
| #define SDRAM_ADDR_BANK_32MB | ( | ba1, | |
| ba0 ) |
| #define SDRAM_ADDR_BANK_64MB | ( | ba1, | |
| ba0 ) |
| #define SDRAM_ADDR_ROW_16MB | ( | val | ) |
| #define SDRAM_ADDR_ROW_32MB | ( | val | ) |
| #define SDRAM_ADDR_ROW_64MB | ( | val | ) |
| #define SDRAM_EXTMODE_16MB | ( | mode | ) |
| #define SDRAM_EXTMODE_32MB | ( | mode | ) |
| #define SDRAM_EXTMODE_64MB | ( | mode | ) |
| #define SDRAM_EXTMODE_DRIVER_STRENGTH | ( | val | ) |
| #define SDRAM_EXTMODE_PASR | ( | val | ) |
| #define SDRAM_MODE_16MB | ( | mode | ) |
| #define SDRAM_MODE_32MB | ( | mode | ) |
| #define SDRAM_MODE_64MB | ( | mode | ) |
| #define SDRAM_MODE_BURST_LENGTH | ( | val | ) |
| #define SDRAM_MODE_CAS | ( | val | ) |
| #define SDRAM_MODE_TEST_MODE | ( | val | ) |
| #define SDRAMCLK_COMMAND_DELAY | ( | val | ) |
| #define SDRAMCLK_DDR_DQSIN_DELAY | ( | val | ) |
| #define SDRAMCLK_SENSITIVITY_FACTOR | ( | val | ) |
