RTEMS 6.3
mvme3100 Directory Reference
Directories
flash
i2c
include
irq
pci
rtc
start
Valuable information was obtained from the following drivers
linux: (BCM54xx) Maciej W. Rozycki, Amy Fong.
This BSP also builds on top of the work of others who have contributed to similar RTEMS (powerpc) BSPs, most notably Eric Valette, Eric Norum and others.
This BSP was produced by the Stanford Linear Accelerator Center, Stanford University under contract with the US Department of Energy.
LICENSE
See ./LICENSE file.
Note that not all files that are part of this BSP were written by myself. Consult individual file headers for copyright and authorship information.
HARDWARE SUPPORT
(some of the headers mentioned below contain more detailed information)
NOTE: The BSP supports the mvme3100 board.
WARNING: It is extremely important that a MOTLoad "waitProbe", "netShut" sequence be executed before booting RTEMS. Otherwise, network interface interrupt handlers installed by MOTLoad may cause memory corruption
CONSOLE: 2 serial devices, UART driver from 'shared' - no surprises ("/dev/ttyS0", [="/dev/console"], "/dev/ttyS1"). (Only /dev/ttyS0 is accessible from the front panel.)
CLOCK: Decrementer, same as other PPC BSPs. (FIXME: a openpic timer could be used.) The bookE decrementer is slightly different from the classic PPC decrementer but the differences are hidden from the user.
PIC (interrupt controller) (bsp/irq.h): OpenPIC integrated with the MPC8540. (see also: bsp/openpic.h).
PCI (bsp/pci.h): In addition to rtems' PCI API, a call is available to scan all devices executing a user callback on each device. BSP_pciConfigDump() is a convenience wrapper dumping essential information (IDs, BAs, IRQ pin/line) to the console or a file.
MEMORY MAP: MotLoad; all addresses (MEM + I/O) read from PCI config. space are CPU addresses. For sake of portability, drivers should still use the _IO_BASE, PCI_MEM_BASE, PCI_DRAM_OFFSET constants.
NVRAM: No NVRAM.
FLASH (bsp/flashPgm.h): Routines to write flash. Highest level wrapper writes a file to flash. NOTE: Writing to flash is disabled by default; call BSP_flashWriteEnable().
I2C (bsp.h, rtems/libi2c.h, libchip/i2c-xxx.h): temp. sensor, eeprom and real-time clock (RTC) are available as device files (bsp.h); lower-level interface is provided by libi2c.h.
Available i2c devices are:
      /dev/i2c0.vpd-eeprom
      /dev/i2c0.usr-eeprom
      /dev/i2c0.usr1-eeprom
      /dev/i2c0.ds1621
      /dev/i2c0.ds1621-raw
      /dev/i2c0.ds1375-raw
You can e.g., read the board temperature: fd = open("/dev/i2c0.ds1621",O_RDONLY) read(fd,&temp,1) close(fd); printf("Board Temp. is %idegC\n",(int)temp);
VME: (bsp/VME.h, bsp/vme_am_defs.h, bsp/VMEDMA.h). always use VME.h API, if possible; do not use chip driver (vmeTsi148.h) directly unless you know what you are doing (i.e., if you need specific features provided by the particular chip)
VMEConfig.h should not be used by applications as it makes them dependent on BSP internals. VMEConfig.h is intended to be used by BSP designers only.
VME interrupt priorities: the VME bridge(s) do not implement priorities in hardware. However, on the 3100 multiple physical interrupt lines/wires connect the VME bridge to the PIC. Hence, it is possible to assign the different wires different priorities at the PIC (see bsp/openpic.h) and to route VME interrupts to different wires according to their priority. You need to call driver specific routines for this (vmeXXXIntRoute()), however (for driver-specific API consult bsp/vmeTsi148.h).
For VME DMA always use the bsp/VMEDMA.h API. DO NOT use chip-specific features. Applications written using the bsp/VMEDMA.h API are portable between the UniverseII and the Tsi148.
HARDWARE TIMERS: (bsp/openpic.h). Programmable general-purpose timers. Routines are provided to setup, start and stop GPTs. The setup routine allows for specifying single-shot or periodic mode and dispatches a user ISR when the GPT expires.
NETWORK: (bsp/if_tsec_pub.h). In addition to the standard bsdnet 'attach' function the driver offers a low-level API that can be used to implement alternate communication links which are totally decoupled from BSDNET.
Consult 'KNOWN_PROBLEMS'.
VPD: (bsp/vpd.h). The board's VPD (vital-product-data such as S/N, MAC addresses and so forth) can be retrieved.
BOOTING: BSP has a relocator-header. Clear MSR and jump to the first instruction in the binary. R3 and R4, if non-null, point to the start/end of an optional command line string that is copied into BSP_commandline_string. The BSP is compatible with 'netboot'.
Have fun.
– Till Straumann strau.nosp@m.man@.nosp@m.slac..nosp@m.stan.nosp@m.ford..nosp@m.edu, 2007.
Known Problems
I have observed what seem to be strange initialization problems with the ethernet driver:
I usually configure RTEMS networking by BOOTP (the problem has nothing to do with BOOTP but I just want to describe my environment). Sometimes (it can actually happen quite frequently, like 1 out of 4 attempts but since yesterday when I decided to hunt this down more systematically the problem seems to have gone - typical!) networking fails to initialize properly:
BOOTP requests are sent (to the MAC), TX interrupts occur and the TX MIB counters increment - i.e., everything seems normal but no data can be seen on the wire. Also, even though we are on a quite busy network, the receiver doesn't see anything, i.e., 0 RX interrupts, RX MIB counters for broadcast packets remain steady at zero etc. In brief, everyting seems normal at the MAC and higher layers but no connection to the wire seems to be established.
Some further tests reveal (system under test is in the 'bad' state): 1 communication with the BCM5461 PHY is normal. Registers can be read/written and everything seems normal. In particular, the link status is reported OK: disconnect the cable and MII - BMSR bit 1<<2 is clear, reconnect the cable and BMSR[2] is set. Restart autoneg, the link goes and comes back after a short while. 2 setting the loopback bit in the TSEC's MACCFG1 register correctly feeds packets back into the RX, RX MIB counters now increment and indicate data flow. There are RX interrupts and all indicates (I haven't actually looked at RX packet data) that the RX would work normally. After switching MACCFG1[LOOP_BACK] off no RX traffic can be seen anymore. 3 resetting the PHY (BMCR = 0x8000) and/or restarting autoneg (BMCR = 0x1200) seems to perform the desired action (registers take on expected values) but still no luck with communication all the way through to the wire.
Especially point 2 seems to indicate that the problem is likely to be between the wire and the MAC somewhere but re-setting the PHY doesn't change things. Analysis is much complicated by the fact that there is no documentation on the BCM5461 chip available.
Noteworthy is also that if the system initializes OK then it continues to work normally; if initialization fails then only resetting the board and restarting helps.
I wanted to test if it makes a difference if MotLoad used the chip prior to RTEMS being booted (in case MotLoad did some magic step during initialization) but before I could really test this the problem went away.
Big Mystery...
12/12/2007, T.S.
