RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
include
bsp
openpic.h
1
2
* openpic.h -- OpenPIC definitions
3
4
* Copyright (C) 1997 Geert Uytterhoeven
5
6
* This file is based on the following documentation:
7
8
* The Open Programmable Interrupt Controller (PIC)
9
* Register Interface Specification Revision 1.2
10
11
* Issue Date: October 1995
12
13
* Issued jointly by Advanced Micro Devices and Cyrix Corporation
14
15
* AMD is a registered trademark of Advanced Micro Devices, Inc.
16
* Copyright (C) 1995, Advanced Micro Devices, Inc. and Cyrix, Inc.
17
* All Rights Reserved.
18
19
* To receive a copy of this documentation, send an email to openpic@amd.com.
20
21
* This file is subject to the terms and conditions of the GNU General Public
22
* License. See the file COPYING in the main directory of this archive
23
* for more details.
24
25
* Modified to compile in RTEMS development environment
26
* by Eric Valette
27
28
* Copyright (C) 1999 Eric Valette. valette@crf.canon.fr
29
30
* The license and distribution terms for this file may be
31
* found in the file LICENSE in this distribution or at
32
* http://www.rtems.org/license/LICENSE.
33
34
35
#ifndef _RTEMS_OPENPIC_H
36
#define _RTEMS_OPENPIC_H
37
38
39
* OpenPIC supports up to 2048 interrupt sources and up to 32 processors
40
41
#define OPENPIC_MAX_SOURCES 2048
42
#define OPENPIC_MAX_PROCESSORS 32
43
44
#define OPENPIC_NUM_TIMERS 4
45
#define OPENPIC_NUM_IPI 4
46
#define OPENPIC_NUM_PRI 16
47
#define OPENPIC_NUM_VECTORS 256
48
49
50
* Vector numbers
51
52
53
#define OPENPIC_VEC_SOURCE 0x10
/* and up */
54
#define OPENPIC_VEC_TIMER 0x40
/* and up */
55
#define OPENPIC_VEC_IPI 0x50
/* and up */
56
#define OPENPIC_VEC_SPURIOUS 99
57
58
59
* OpenPIC Registers are 32 bits and aligned on 128 bit boundaries
60
61
62
typedef
struct
_OpenPIC_Reg
63
unsigned
int
Reg;
/* Little endian! */
64
char
Pad[0xc];
65
} OpenPIC_Reg;
66
67
68
* Per Processor Registers
69
70
71
typedef
struct
_OpenPIC_Processor
72
73
* Private Shadow Registers (for SLiC backwards compatibility)
74
75
unsigned
int
IPI0_Dispatch_Shadow;
/* Write Only */
76
char
Pad1[0x4];
77
unsigned
int
IPI0_Vector_Priority_Shadow;
/* Read/Write */
78
char
Pad2[0x34];
79
80
* Interprocessor Interrupt Command Ports
81
82
OpenPIC_Reg _IPI_Dispatch[OPENPIC_NUM_IPI];
/* Write Only */
83
84
* Current Task Priority Register
85
86
OpenPIC_Reg _Current_Task_Priority;
/* Read/Write */
87
char
Pad3[0x10];
88
89
* Interrupt Acknowledge Register
90
91
OpenPIC_Reg _Interrupt_Acknowledge;
/* Read Only */
92
93
* End of Interrupt (EOI) Register
94
95
OpenPIC_Reg _EOI;
/* Read/Write */
96
char
Pad5[0xf40];
97
} OpenPIC_Processor;
98
99
100
* Timer Registers
101
102
103
typedef
struct
_OpenPIC_Timer
104
OpenPIC_Reg _Current_Count;
/* Read Only */
105
OpenPIC_Reg _Base_Count;
/* Read/Write */
106
OpenPIC_Reg _Vector_Priority;
/* Read/Write */
107
OpenPIC_Reg _Destination;
/* Read/Write */
108
} OpenPIC_Timer;
109
110
111
* Global Registers
112
113
114
typedef
struct
_OpenPIC_Global
115
116
* Feature Reporting Registers
117
118
OpenPIC_Reg _Feature_Reporting0;
/* Read Only */
119
OpenPIC_Reg _Feature_Reporting1;
/* Future Expansion */
120
121
* Global Configuration Registers
122
123
OpenPIC_Reg _Global_Configuration0;
/* Read/Write */
124
OpenPIC_Reg _Global_Configuration1;
125
126
* Vendor Specific Registers
127
128
OpenPIC_Reg _Vendor_Specific[4];
129
130
* Vendor Identification Register
131
132
OpenPIC_Reg _Vendor_Identification;
/* Read Only */
133
134
* Processor Initialization Register
135
136
OpenPIC_Reg _Processor_Initialization;
/* Read/Write */
137
138
* IPI Vector/Priority Registers
139
140
OpenPIC_Reg _IPI_Vector_Priority[OPENPIC_NUM_IPI];
/* Read/Write */
141
142
* Spurious Vector Register
143
144
OpenPIC_Reg _Spurious_Vector;
/* Read/Write */
145
146
* Global Timer Registers
147
148
OpenPIC_Reg _Timer_Frequency;
/* Read/Write */
149
OpenPIC_Timer Timer[OPENPIC_NUM_TIMERS];
150
char
Pad1[0xee00];
151
} OpenPIC_Global;
152
153
154
* Interrupt Source Registers
155
156
157
typedef
struct
_OpenPIC_Source
158
/* Read/Write */
159
/* Read/Write */
160
} OpenPIC_Source;
161
162
163
* OpenPIC Register Map
164
165
166
struct
OpenPIC
167
char
Pad1[0x1000];
168
169
* Global Registers
170
171
OpenPIC_Global Global;
172
173
* Interrupt Source Configuration Registers
174
175
OpenPIC_Source Source[OPENPIC_MAX_SOURCES];
176
177
178
179
OpenPIC_Processor Processor[OPENPIC_MAX_PROCESSORS];
180
181
182
extern
volatile
struct
OpenPIC
OpenPIC
183
184
185
186
187
188
#define OPENPIC_CURRENT_TASK_PRIORITY_MASK 0x0000000f
189
190
191
* Who Am I Register
192
193
194
#define OPENPIC_WHO_AM_I_ID_MASK 0x0000001f
195
196
197
* Feature Reporting Register 0
198
199
200
#define OPENPIC_FEATURE_LAST_SOURCE_MASK 0x07ff0000
201
#define OPENPIC_FEATURE_LAST_SOURCE_SHIFT 16
202
#define OPENPIC_FEATURE_LAST_PROCESSOR_MASK 0x00001f00
203
#define OPENPIC_FEATURE_LAST_PROCESSOR_SHIFT 8
204
#define OPENPIC_FEATURE_VERSION_MASK 0x000000ff
205
206
207
* Global Configuration Register 0
208
209
210
#define OPENPIC_CONFIG_RESET 0x80000000
211
#define OPENPIC_CONFIG_8259_PASSTHROUGH_DISABLE 0x20000000
212
#define OPENPIC_CONFIG_BASE_MASK 0x000fffff
213
214
215
216
217
218
#define OPENPIC_VENDOR_ID_STEPPING_MASK 0x00ff0000
219
#define OPENPIC_VENDOR_ID_STEPPING_SHIFT 16
220
#define OPENPIC_VENDOR_ID_DEVICE_ID_MASK 0x0000ff00
221
#define OPENPIC_VENDOR_ID_DEVICE_ID_SHIFT 8
222
#define OPENPIC_VENDOR_ID_VENDOR_ID_MASK 0x000000ff
223
224
225
* Vector/Priority Registers
226
227
228
#define OPENPIC_MASK 0x80000000
229
#define OPENPIC_ACTIVITY 0x40000000
/* Read Only */
230
#define OPENPIC_PRIORITY_MASK 0x000f0000
231
#define OPENPIC_PRIORITY_SHIFT 16
232
#define OPENPIC_VECTOR_MASK 0x000000ff
233
234
235
236
237
238
#define OPENPIC_SENSE_POLARITY 0x00800000
/* Undoc'd */
239
#define OPENPIC_SENSE_LEVEL 0x00400000
240
241
242
* Timer Registers
243
244
245
#define OPENPIC_COUNT_MASK 0x7fffffff
246
#define OPENPIC_TIMER_TOGGLE 0x80000000
247
#define OPENPIC_TIMER_COUNT_INHIBIT 0x80000000
248
249
250
* Aliases to make life simpler
251
252
253
/* Per Processor Registers */
254
#define IPI_Dispatch(i) _IPI_Dispatch[i].Reg
255
#define Current_Task_Priority _Current_Task_Priority.Reg
256
#define Interrupt_Acknowledge _Interrupt_Acknowledge.Reg
257
#define EOI _EOI.Reg
258
259
/* Global Registers */
260
#define Feature_Reporting0 _Feature_Reporting0.Reg
261
#define Feature_Reporting1 _Feature_Reporting1.Reg
262
#define Global_Configuration0 _Global_Configuration0.Reg
263
#define Global_Configuration1 _Global_Configuration1.Reg
264
#define Vendor_Specific(i) _Vendor_Specific[i].Reg
265
#define Vendor_Identification _Vendor_Identification.Reg
266
#define Processor_Initialization _Processor_Initialization.Reg
267
#define IPI_Vector_Priority(i) _IPI_Vector_Priority[i].Reg
268
#define Spurious_Vector _Spurious_Vector.Reg
269
#define Timer_Frequency _Timer_Frequency.Reg
270
271
/* Timer Registers */
272
#define Current_Count _Current_Count.Reg
273
#define Base_Count _Base_Count.Reg
274
#define Vector_Priority _Vector_Priority.Reg
275
#define Destination _Destination.Reg
276
277
/* Interrupt Source Registers */
278
279
280
281
282
* Vendor and Device IDs
283
284
285
#define OPENPIC_VENDOR_ID_APPLE 0x14
286
#define OPENPIC_DEVICE_ID_APPLE_HYDRA 0x46
287
288
289
* OpenPIC Operations
290
291
292
293
* Handle EPIC differences. Unfortunately, I don't know of an easy
294
* way to tell an EPIC from a normal PIC at run-time. Therefore,
295
* the BSP must enable a few quirks if it knows that an EPIC is being
296
* used:
297
* - If the BSP uses the serial interrupt mode / 'multiplexer' then
298
* EOI must be delayed by at least 16 SRAM_CLK cycles to avoid
299
* spurious interrupts.
300
* It is the BSP's responsibility to set up an appropriate delay
301
* (in timebase-clock cycles) at init time using
302
* 'openpic_set_eoi_delay()'. This is ONLY necessary when using
303
* an EPIC in serial mode.
304
* - The EPIC sources start at an offset of 16 in the register
305
* map, i.e., on an EPIC you'd say Sources[ x + 16 ] where
306
* on a PIC you would say Sources[ x ].
307
* Again, the BSP can set an offset that is used by the
308
* calls dealing with 'Interrupt Sources'
309
* openpic_enable_irq()
310
* openpic_disable_irq()
311
* openpic_initirq()
312
* openpic_mapirq()
313
* openpic_set_sense()
314
* openpic_get_source_priority()
315
* openpic_set_source_priority()
316
* the desired source offset parameter is passed to openpic_init().
317
318
* The routine 'openpic_set_eoi_delay()' returns the previous/old
319
* value of the delay parameter.
320
321
extern
unsigned
unsigned
tb_cycles);
322
323
324
/* Global Operations */
325
326
/* num_sources: number of sources to use; if zero this value
327
* is read from the device, if nonzero the value read from
328
* the device is overridden.
329
* 'polarities' and 'senses' are arrays defining the desired
330
* polarities (active hi [nonzero]/lo [zero]) and
331
* senses (level [nonzero]/edge [zero]).
332
* Either of the two array pointers may be NULL resulting
333
* in the driver choosing default values of: 'active low'
334
* and 'level sensitive', respectively.
335
* NOTE: if you do pass arrays then their size must either
336
* match the number of sources read from the device or
337
* that value must be overridden by specifying
338
* a non-zero 'num_sources' parameter.
339
340
* Nonzero 'epic_freq' activates the EOI delay if the EPIC is
341
* configured in serial mode (driver assumes firmware performs initial
342
* EPIC setup). The BSP must pass the clock frequency of the EPIC
343
* serial interface here.
344
345
extern
void
openpic_init(
int
main_pic,
unsigned
char
*polarities,
unsigned
char
*senses,
int
num_sources,
int
source_offset,
unsigned
long
epic_freq);
346
347
extern
void
openpic_reset(
void
348
extern
void
openpic_enable_8259_pass_through(
void
349
extern
void
openpic_disable_8259_pass_through(
void
350
extern
unsigned
int
openpic_irq(
unsigned
int
cpu);
351
extern
void
openpic_eoi(
unsigned
int
cpu);
352
extern
unsigned
int
openpic_get_priority(
unsigned
int
cpu);
353
extern
void
openpic_set_priority(
unsigned
int
cpu,
unsigned
int
pri);
354
extern
unsigned
int
openpic_get_spurious(
void
355
extern
void
openpic_set_spurious(
unsigned
int
vector);
356
extern
void
openpic_init_processor(
unsigned
int
cpumask);
357
358
/* Interprocessor Interrupts */
359
extern
void
openpic_initipi(
unsigned
int
ipi,
unsigned
int
pri,
unsigned
int
vector);
360
extern
void
openpic_cause_IPI(
unsigned
int
cpu,
unsigned
int
ipi,
unsigned
int
cpumask);
361
362
/* Timer Interrupts */
363
extern
void
openpic_inittimer(
unsigned
int
timer,
unsigned
int
pri,
unsigned
int
vector);
364
extern
void
openpic_settimer(
unsigned
int
timer,
unsigned
int
base_count,
int
irq_enable);
365
extern
unsigned
int
openpic_gettimer(
unsigned
int
timer);
366
extern
void
openpic_maptimer(
unsigned
int
timer,
unsigned
int
cpumask);
367
368
/* Interrupt Sources */
369
extern
void
openpic_enable_irq(
unsigned
int
irq);
370
extern
int
unsigned
int
irq);
371
extern
void
openpic_initirq(
unsigned
int
irq,
unsigned
int
pri,
unsigned
int
vector,
int
polarity,
372
int
is_level);
373
extern
void
openpic_mapirq(
unsigned
int
irq,
unsigned
int
cpumask);
374
extern
void
openpic_set_sense(
unsigned
int
irq,
int
sense);
375
extern
unsigned
int
unsigned
int
irq);
376
extern
void
unsigned
int
irq,
unsigned
int
pri);
377
378
#endif
/* RTEMS_OPENPIC_H */
OpenPIC
Definition
openpic.h:166
_OpenPIC_Global
Definition
openpic.h:114
_OpenPIC_Processor
Definition
openpic.h:71
_OpenPIC_Reg
Definition
openpic.h:62
_OpenPIC_Source
Definition
openpic.h:157
_OpenPIC_Timer
Definition
openpic.h:103
