RTEMS 6.3
console Directory Reference
conscfg.c
console_select.c
 pc386 console select
exar17d15x.c
 Driver for Exar XR17D15x Multiport UARTs.
fb_vesa_rm.c
 FB driver for graphic hardware compatible with VESA Bios Extension Real mode interface utilized Tested on real HW.
gdb_select.c
 pc386 gdb select
i386kbd.h
 I386 keyboard definitions.
ps2_mouse.h
 Keyboard and mouse definitions.
rtd316.c
 Driver for RTD316 ISA SCC Board.
The i386 GDB stub has been updated to use the libchip drivers for the NS16550. Make sure you have detect the device and you have added a console entry. On the PC the legacy and PCI boards are supported.
This GDB stub glue code is specific to the UART protocol defined in libbchip.
The pc386 BSP has boot command line options to manage GDB support.
a) Find the minor number of the console device:
#include <console_private.h>
strlen("/dev/com1") - 1, &minor) == NULL)
error("driver not found\n");
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition io.h:115
console_tbl * console_find_console_entry(const char *match, size_t length, rtems_device_minor_number *match_minor)
Definition legacy-console.c:62
Note, this call is part of the private console API and may change.
b) To start GDB stub, run this:
#include <bsp.h>
/* Init GDB glue */
i386_stub_glue_init(minor);
/* Init GDB stub itself */
set_debug_traps();
* Init GDB break in capability,
* has to be called after
* set_debug_traps
i386_stub_glue_init_breakin();
/* Put breakpoint in */
breakpoint();
c) To run use GDB:
$ i386-rtems4.12-gdb hello.exe
GNU gdb (GDB) 7.11
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-freebsd10.1 --target=i386-rtems4.12".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from hello.exe...done.
(gdb) target remote /dev/cuaU5
Remote debugging using /dev/cuaU5
0x00103fda in breakpoint () at i386-stub.c:1004
1004 BREAKPOINT ();
(gdb) b Init
Breakpoint 1 at 0x1001e0: file init.c, line 29.
(gdb) c
Continuing.
Breakpoint 1, Init (ignored=1269800) at init.c:29
29 {
(gdb)
Pressing ^C works and if running the board should halt when GDB connects.
e) Use ser2net to provide reomve access over a network to a board. Install the ser2net package and add a configuration for the port GDB connects to. For example:
0005:raw:0:/dev/cuaU5:115200
Start ser2net running then connect GDB using:
(gdb) target remote myhost:30005
