Keyboard and mouse definitions.
More...
#define | KBD_REPORT_UNKN |
#define | KBD_REPORT_TIMEOUTS |
#define | KBD_INIT_TIMEOUT 1000 |
#define | KBC_TIMEOUT 250 |
#define | KBD_TIMEOUT 1000 |
#define | KBD_STATUS_REG 0x64 |
#define | KBD_CNTL_REG 0x64 |
#define | KBD_DATA_REG 0x60 |
#define | KBD_CCMD_READ_MODE 0x20 |
#define | KBD_CCMD_WRITE_MODE 0x60 |
#define | KBD_CCMD_GET_VERSION 0xA1 |
#define | KBD_CCMD_MOUSE_DISABLE 0xA7 |
#define | KBD_CCMD_MOUSE_ENABLE 0xA8 |
#define | KBD_CCMD_TEST_MOUSE 0xA9 |
#define | KBD_CCMD_SELF_TEST 0xAA |
#define | KBD_CCMD_KBD_TEST 0xAB |
#define | KBD_CCMD_KBD_DISABLE 0xAD |
#define | KBD_CCMD_KBD_ENABLE 0xAE |
#define | KBD_CCMD_WRITE_AUX_OBUF 0xD3 |
#define | KBD_CCMD_WRITE_MOUSE 0xD4 |
#define | KBD_CMD_SET_LEDS 0xED |
#define | KBD_CMD_SET_RATE 0xF3 |
#define | KBD_CMD_ENABLE 0xF4 |
#define | KBD_CMD_DISABLE 0xF5 |
#define | KBD_CMD_RESET 0xFF |
#define | KBD_REPLY_POR 0xAA |
#define | KBD_REPLY_ACK 0xFA |
#define | KBD_REPLY_RESEND 0xFE |
#define | KBD_STAT_OBF 0x01 |
#define | KBD_STAT_IBF 0x02 |
#define | KBD_STAT_SELFTEST 0x04 |
#define | KBD_STAT_CMD 0x08 |
#define | KBD_STAT_UNLOCKED 0x10 |
#define | KBD_STAT_MOUSE_OBF 0x20 |
#define | KBD_STAT_GTO 0x40 |
#define | KBD_STAT_PERR 0x80 |
#define | AUX_STAT_OBF (KBD_STAT_OBF | KBD_STAT_MOUSE_OBF) |
#define | KBD_MODE_KBD_INT 0x01 |
#define | KBD_MODE_MOUSE_INT 0x02 |
#define | KBD_MODE_SYS 0x04 |
#define | KBD_MODE_NO_KEYLOCK 0x08 |
#define | KBD_MODE_DISABLE_KBD 0x10 |
#define | KBD_MODE_DISABLE_MOUSE 0x20 |
#define | KBD_MODE_KCC 0x40 |
#define | KBD_MODE_RFU 0x80 |
#define | AUX_SET_RES 0xE8 |
#define | AUX_SET_SCALE11 0xE6 |
#define | AUX_SET_SCALE21 0xE7 |
#define | AUX_GET_SCALE 0xE9 |
#define | AUX_SET_STREAM 0xEA |
#define | AUX_SET_SAMPLE 0xF3 |
#define | AUX_ENABLE_DEV 0xF4 |
#define | AUX_DISABLE_DEV 0xF5 |
#define | AUX_RESET 0xFF |
#define | AUX_ACK 0xFA |
#define | AUX_BUF_SIZE 512 |
| #define | kbd_read_input() |
| #define | kbd_read_status() |
| #define | kbd_write_output(val) |
| #define | kbd_write_command(val) |
#define | AUX_IRQ 12 |
unsigned char | pckbd_read_mask |
unsigned char | aux_device_present |
◆ kbd_read_input
| #define kbd_read_input |
◆ kbd_read_status
| #define kbd_read_status |
◆ kbd_write_command
| #define kbd_write_command |
| val | ) |
◆ kbd_write_output
| #define kbd_write_output |
| val | ) |
