#define | DDRC_ADDRMAP_4BIT_SPECIAL 15 |
#define | DDRC_ADDRMAP_5BIT_SPECIAL 31 |
#define | DDRC_MSTR_OFFSET 0x0 |
| #define | DDRC_MSTR_BURST_RDWR(val) |
| #define | DDRC_MSTR_BURST_RDWR_GET(reg) |
| #define | DDRC_MSTR_BURST_RDWR_SET(reg, val) |
#define | DDRC_MSTR_BURST_RDWR_4 0x2 |
#define | DDRC_MSTR_BURST_RDWR_8 0x4 |
#define | DDRC_MSTR_BURST_RDWR_16 0x8 |
| #define | DDRC_MSTR_DATA_BUS_WIDTH(val) |
| #define | DDRC_MSTR_DATA_BUS_WIDTH_GET(reg) |
| #define | DDRC_MSTR_DATA_BUS_WIDTH_SET(reg, val) |
#define | DDRC_MSTR_DATA_BUS_WIDTH_FULL 0x0 |
#define | DDRC_MSTR_DATA_BUS_WIDTH_HALF 0x1 |
#define | DDRC_MSTR_DATA_BUS_WIDTH_QUARTER 0x2 |
#define | DDRC_MSTR_LPDDR4 BSP_BIT32(5) |
#define | DDRC_MSTR_DDR4 BSP_BIT32(4) |
#define | DDRC_MSTR_LPDDR3 BSP_BIT32(3) |
#define | DDRC_MSTR_DDR3 BSP_BIT32(0) |
#define | DDRC_ADDRMAP0_OFFSET 0x200 |
#define | DDRC_ADDRMAP0_RANK_B0_BASE 6 |
| #define | DDRC_ADDRMAP0_RANK_B0_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP0_RANK_B0_TARGET rank |
#define | DDRC_ADDRMAP0_RANK_B0_SPECIAL DDRC_ADDRMAP_5BIT_SPECIAL |
| #define | DDRC_ADDRMAP0_RANK_B0(val) |
| #define | DDRC_ADDRMAP0_RANK_B0_GET(reg) |
| #define | DDRC_ADDRMAP0_RANK_B0_SET(reg, val) |
#define | DDRC_ADDRMAP1_OFFSET 0x204 |
#define | DDRC_ADDRMAP1_BANK_B2_BASE 4 |
| #define | DDRC_ADDRMAP1_BANK_B2_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP1_BANK_B2_TARGET bank |
#define | DDRC_ADDRMAP1_BANK_B2_SPECIAL DDRC_ADDRMAP_5BIT_SPECIAL |
| #define | DDRC_ADDRMAP1_BANK_B2(val) |
| #define | DDRC_ADDRMAP1_BANK_B2_GET(reg) |
| #define | DDRC_ADDRMAP1_BANK_B2_SET(reg, val) |
#define | DDRC_ADDRMAP1_BANK_B1_BASE 3 |
| #define | DDRC_ADDRMAP1_BANK_B1_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP1_BANK_B1_TARGET bank |
#define | DDRC_ADDRMAP1_BANK_B1_SPECIAL DDRC_ADDRMAP_5BIT_SPECIAL |
| #define | DDRC_ADDRMAP1_BANK_B1(val) |
| #define | DDRC_ADDRMAP1_BANK_B1_GET(reg) |
| #define | DDRC_ADDRMAP1_BANK_B1_SET(reg, val) |
#define | DDRC_ADDRMAP1_BANK_B0_BASE 2 |
| #define | DDRC_ADDRMAP1_BANK_B0_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP1_BANK_B0_TARGET bank |
#define | DDRC_ADDRMAP1_BANK_B0_SPECIAL DDRC_ADDRMAP_5BIT_SPECIAL |
| #define | DDRC_ADDRMAP1_BANK_B0(val) |
| #define | DDRC_ADDRMAP1_BANK_B0_GET(reg) |
| #define | DDRC_ADDRMAP1_BANK_B0_SET(reg, val) |
#define | DDRC_ADDRMAP2_OFFSET 0x208 |
#define | DDRC_ADDRMAP2_COL_B5_BASE 5 |
| #define | DDRC_ADDRMAP2_COL_B5_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP2_COL_B5_TARGET column |
#define | DDRC_ADDRMAP2_COL_B5_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP2_COL_B5(val) |
| #define | DDRC_ADDRMAP2_COL_B5_GET(reg) |
| #define | DDRC_ADDRMAP2_COL_B5_SET(reg, val) |
#define | DDRC_ADDRMAP2_COL_B4_BASE 4 |
| #define | DDRC_ADDRMAP2_COL_B4_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP2_COL_B4_TARGET column |
#define | DDRC_ADDRMAP2_COL_B4_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP2_COL_B4(val) |
| #define | DDRC_ADDRMAP2_COL_B4_GET(reg) |
| #define | DDRC_ADDRMAP2_COL_B4_SET(reg, val) |
#define | DDRC_ADDRMAP2_COL_B3_BASE 3 |
| #define | DDRC_ADDRMAP2_COL_B3_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP2_COL_B3_TARGET column |
#define | DDRC_ADDRMAP2_COL_B3_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP2_COL_B3(val) |
| #define | DDRC_ADDRMAP2_COL_B3_GET(reg) |
| #define | DDRC_ADDRMAP2_COL_B3_SET(reg, val) |
#define | DDRC_ADDRMAP2_COL_B2_BASE 2 |
| #define | DDRC_ADDRMAP2_COL_B2_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP2_COL_B2_TARGET column |
#define | DDRC_ADDRMAP2_COL_B2_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP2_COL_B2(val) |
| #define | DDRC_ADDRMAP2_COL_B2_GET(reg) |
| #define | DDRC_ADDRMAP2_COL_B2_SET(reg, val) |
#define | DDRC_ADDRMAP3_OFFSET 0x20c |
#define | DDRC_ADDRMAP3_COL_B9_BASE 9 |
| #define | DDRC_ADDRMAP3_COL_B9_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP3_COL_B9_TARGET column |
#define | DDRC_ADDRMAP3_COL_B9_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP3_COL_B9(val) |
| #define | DDRC_ADDRMAP3_COL_B9_GET(reg) |
| #define | DDRC_ADDRMAP3_COL_B9_SET(reg, val) |
#define | DDRC_ADDRMAP3_COL_B8_BASE 8 |
| #define | DDRC_ADDRMAP3_COL_B8_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP3_COL_B8_TARGET column |
#define | DDRC_ADDRMAP3_COL_B8_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP3_COL_B8(val) |
| #define | DDRC_ADDRMAP3_COL_B8_GET(reg) |
| #define | DDRC_ADDRMAP3_COL_B8_SET(reg, val) |
#define | DDRC_ADDRMAP3_COL_B7_BASE 7 |
| #define | DDRC_ADDRMAP3_COL_B7_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP3_COL_B7_TARGET column |
#define | DDRC_ADDRMAP3_COL_B7_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP3_COL_B7(val) |
| #define | DDRC_ADDRMAP3_COL_B7_GET(reg) |
| #define | DDRC_ADDRMAP3_COL_B7_SET(reg, val) |
#define | DDRC_ADDRMAP3_COL_B6_BASE 6 |
| #define | DDRC_ADDRMAP3_COL_B6_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP3_COL_B6_TARGET column |
#define | DDRC_ADDRMAP3_COL_B6_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP3_COL_B6(val) |
| #define | DDRC_ADDRMAP3_COL_B6_GET(reg) |
| #define | DDRC_ADDRMAP3_COL_B6_SET(reg, val) |
#define | DDRC_ADDRMAP4_OFFSET 0x210 |
#define | DDRC_ADDRMAP4_COL_B11_BASE 11 |
| #define | DDRC_ADDRMAP4_COL_B11_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP4_COL_B11_TARGET column |
#define | DDRC_ADDRMAP4_COL_B11_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP4_COL_B11(val) |
| #define | DDRC_ADDRMAP4_COL_B11_GET(reg) |
| #define | DDRC_ADDRMAP4_COL_B11_SET(reg, val) |
#define | DDRC_ADDRMAP4_COL_B10_BASE 10 |
| #define | DDRC_ADDRMAP4_COL_B10_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP4_COL_B10_TARGET column |
#define | DDRC_ADDRMAP4_COL_B10_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP4_COL_B10(val) |
| #define | DDRC_ADDRMAP4_COL_B10_GET(reg) |
| #define | DDRC_ADDRMAP4_COL_B10_SET(reg, val) |
#define | DDRC_ADDRMAP5_OFFSET 0x214 |
#define | DDRC_ADDRMAP5_ROW_B11_BASE 17 |
| #define | DDRC_ADDRMAP5_ROW_B11_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP5_ROW_B11_TARGET row |
#define | DDRC_ADDRMAP5_ROW_B11_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP5_ROW_B11(val) |
| #define | DDRC_ADDRMAP5_ROW_B11_GET(reg) |
| #define | DDRC_ADDRMAP5_ROW_B11_SET(reg, val) |
| #define | DDRC_ADDRMAP5_ROW_B2_10(val) |
| #define | DDRC_ADDRMAP5_ROW_B2_10_GET(reg) |
| #define | DDRC_ADDRMAP5_ROW_B2_10_SET(reg, val) |
#define | DDRC_ADDRMAP5_ROW_B1_BASE 7 |
| #define | DDRC_ADDRMAP5_ROW_B1_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP5_ROW_B1_TARGET row |
#define | DDRC_ADDRMAP5_ROW_B1_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP5_ROW_B1(val) |
| #define | DDRC_ADDRMAP5_ROW_B1_GET(reg) |
| #define | DDRC_ADDRMAP5_ROW_B1_SET(reg, val) |
#define | DDRC_ADDRMAP5_ROW_B0_BASE 6 |
| #define | DDRC_ADDRMAP5_ROW_B0_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP5_ROW_B0_TARGET row |
#define | DDRC_ADDRMAP5_ROW_B0_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP5_ROW_B0(val) |
| #define | DDRC_ADDRMAP5_ROW_B0_GET(reg) |
| #define | DDRC_ADDRMAP5_ROW_B0_SET(reg, val) |
#define | DDRC_ADDRMAP6_OFFSET 0x218 |
#define | DDRC_ADDRMAP6_LPDDR3_6_12 BSP_BIT(bw, lp3)32(31) |
#define | DDRC_ADDRMAP6_ROW_B15_BASE 21 |
| #define | DDRC_ADDRMAP6_ROW_B15_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP6_ROW_B15_TARGET row |
#define | DDRC_ADDRMAP6_ROW_B15_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP6_ROW_B15(val) |
| #define | DDRC_ADDRMAP6_ROW_B15_GET(reg) |
| #define | DDRC_ADDRMAP6_ROW_B15_SET(reg, val) |
#define | DDRC_ADDRMAP6_ROW_B14_BASE 20 |
| #define | DDRC_ADDRMAP6_ROW_B14_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP6_ROW_B14_TARGET row |
#define | DDRC_ADDRMAP6_ROW_B14_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP6_ROW_B14(val) |
| #define | DDRC_ADDRMAP6_ROW_B14_GET(reg) |
| #define | DDRC_ADDRMAP6_ROW_B14_SET(reg, val) |
#define | DDRC_ADDRMAP6_ROW_B13_BASE 19 |
| #define | DDRC_ADDRMAP6_ROW_B13_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP6_ROW_B13_TARGET row |
#define | DDRC_ADDRMAP6_ROW_B13_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP6_ROW_B13(val) |
| #define | DDRC_ADDRMAP6_ROW_B13_GET(reg) |
| #define | DDRC_ADDRMAP6_ROW_B13_SET(reg, val) |
#define | DDRC_ADDRMAP6_ROW_B12_BASE 18 |
| #define | DDRC_ADDRMAP6_ROW_B12_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP6_ROW_B12_TARGET row |
#define | DDRC_ADDRMAP6_ROW_B12_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP6_ROW_B12(val) |
| #define | DDRC_ADDRMAP6_ROW_B12_GET(reg) |
| #define | DDRC_ADDRMAP6_ROW_B12_SET(reg, val) |
#define | DDRC_ADDRMAP7_OFFSET 0x21c |
#define | DDRC_ADDRMAP7_ROW_B17_BASE 23 |
| #define | DDRC_ADDRMAP7_ROW_B17_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP7_ROW_B17_TARGET row |
#define | DDRC_ADDRMAP7_ROW_B17_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP7_ROW_B17(val) |
| #define | DDRC_ADDRMAP7_ROW_B17_GET(reg) |
| #define | DDRC_ADDRMAP7_ROW_B17_SET(reg, val) |
#define | DDRC_ADDRMAP7_ROW_B16_BASE 22 |
| #define | DDRC_ADDRMAP7_ROW_B16_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP7_ROW_B16_TARGET row |
#define | DDRC_ADDRMAP7_ROW_B16_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP7_ROW_B16(val) |
| #define | DDRC_ADDRMAP7_ROW_B16_GET(reg) |
| #define | DDRC_ADDRMAP7_ROW_B16_SET(reg, val) |
#define | DDRC_ADDRMAP8_OFFSET 0x220 |
#define | DDRC_ADDRMAP8_BG_B1_BASE 3 |
| #define | DDRC_ADDRMAP8_BG_B1_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP8_BG_B1_TARGET bank_group |
#define | DDRC_ADDRMAP8_BG_B1_SPECIAL DDRC_ADDRMAP_5BIT_SPECIAL |
| #define | DDRC_ADDRMAP8_BG_B1(val) |
| #define | DDRC_ADDRMAP8_BG_B1_GET(reg) |
| #define | DDRC_ADDRMAP8_BG_B1_SET(reg, val) |
#define | DDRC_ADDRMAP8_BG_B0_BASE 2 |
| #define | DDRC_ADDRMAP8_BG_B0_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP8_BG_B0_TARGET bank_group |
#define | DDRC_ADDRMAP8_BG_B0_SPECIAL DDRC_ADDRMAP_5BIT_SPECIAL |
| #define | DDRC_ADDRMAP8_BG_B0(val) |
| #define | DDRC_ADDRMAP8_BG_B0_GET(reg) |
| #define | DDRC_ADDRMAP8_BG_B0_SET(reg, val) |
#define | DDRC_ADDRMAP9_OFFSET 0x224 |
#define | DDRC_ADDRMAP9_ROW_B5_BASE 11 |
| #define | DDRC_ADDRMAP9_ROW_B5_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP9_ROW_B5_TARGET row |
#define | DDRC_ADDRMAP9_ROW_B5_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP9_ROW_B5(val) |
| #define | DDRC_ADDRMAP9_ROW_B5_GET(reg) |
| #define | DDRC_ADDRMAP9_ROW_B5_SET(reg, val) |
#define | DDRC_ADDRMAP9_ROW_B4_BASE 10 |
| #define | DDRC_ADDRMAP9_ROW_B4_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP9_ROW_B4_TARGET row |
#define | DDRC_ADDRMAP9_ROW_B4_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP9_ROW_B4(val) |
| #define | DDRC_ADDRMAP9_ROW_B4_GET(reg) |
| #define | DDRC_ADDRMAP9_ROW_B4_SET(reg, val) |
#define | DDRC_ADDRMAP9_ROW_B3_BASE 9 |
| #define | DDRC_ADDRMAP9_ROW_B3_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP9_ROW_B3_TARGET row |
#define | DDRC_ADDRMAP9_ROW_B3_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP9_ROW_B3(val) |
| #define | DDRC_ADDRMAP9_ROW_B3_GET(reg) |
| #define | DDRC_ADDRMAP9_ROW_B3_SET(reg, val) |
#define | DDRC_ADDRMAP9_ROW_B2_BASE 8 |
| #define | DDRC_ADDRMAP9_ROW_B2_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP9_ROW_B2_TARGET row |
#define | DDRC_ADDRMAP9_ROW_B2_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP9_ROW_B2(val) |
| #define | DDRC_ADDRMAP9_ROW_B2_GET(reg) |
| #define | DDRC_ADDRMAP9_ROW_B2_SET(reg, val) |
#define | DDRC_ADDRMAP10_OFFSET 0x228 |
#define | DDRC_ADDRMAP10_ROW_B9_BASE 15 |
| #define | DDRC_ADDRMAP10_ROW_B9_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP10_ROW_B9_TARGET row |
#define | DDRC_ADDRMAP10_ROW_B9_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP10_ROW_B9(val) |
| #define | DDRC_ADDRMAP10_ROW_B9_GET(reg) |
| #define | DDRC_ADDRMAP10_ROW_B9_SET(reg, val) |
#define | DDRC_ADDRMAP10_ROW_B8_BASE 14 |
| #define | DDRC_ADDRMAP10_ROW_B8_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP10_ROW_B8_TARGET row |
#define | DDRC_ADDRMAP10_ROW_B8_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP10_ROW_B8(val) |
| #define | DDRC_ADDRMAP10_ROW_B8_GET(reg) |
| #define | DDRC_ADDRMAP10_ROW_B8_SET(reg, val) |
#define | DDRC_ADDRMAP10_ROW_B7_BASE 13 |
| #define | DDRC_ADDRMAP10_ROW_B7_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP10_ROW_B7_TARGET row |
#define | DDRC_ADDRMAP10_ROW_B7_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP10_ROW_B7(val) |
| #define | DDRC_ADDRMAP10_ROW_B7_GET(reg) |
| #define | DDRC_ADDRMAP10_ROW_B7_SET(reg, val) |
#define | DDRC_ADDRMAP10_ROW_B6_BASE 12 |
| #define | DDRC_ADDRMAP10_ROW_B6_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP10_ROW_B6_TARGET row |
#define | DDRC_ADDRMAP10_ROW_B6_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP10_ROW_B6(val) |
| #define | DDRC_ADDRMAP10_ROW_B6_GET(reg) |
| #define | DDRC_ADDRMAP10_ROW_B6_SET(reg, val) |
#define | DDRC_ADDRMAP11_OFFSET 0x22c |
#define | DDRC_ADDRMAP11_ROW_B10_BASE 16 |
| #define | DDRC_ADDRMAP11_ROW_B10_TARGET_BIT(bw, lp3) |
#define | DDRC_ADDRMAP11_ROW_B10_TARGET row |
#define | DDRC_ADDRMAP11_ROW_B10_SPECIAL DDRC_ADDRMAP_4BIT_SPECIAL |
| #define | DDRC_ADDRMAP11_ROW_B10(val) |
| #define | DDRC_ADDRMAP11_ROW_B10_GET(reg) |
| #define | DDRC_ADDRMAP11_ROW_B10_SET(reg, val) |
#define | DDRC_ECCPOISONADDR0_OFFSET 0xB8 |
#define | DDRC_ECCPOISONADDR0_RANK BSP_BIT32(24) |
| #define | DDRC_ECCPOISONADDR0_COL(val) |
| #define | DDRC_ECCPOISONADDR0_COL_GET(reg) |
| #define | DDRC_ECCPOISONADDR0_COL_SET(reg, val) |
#define | DDRC_ECCPOISONADDR1_OFFSET 0xBC |
| #define | DDRC_ECCPOISONADDR1_BG(val) |
| #define | DDRC_ECCPOISONADDR1_BG_GET(reg) |
| #define | DDRC_ECCPOISONADDR1_BG_SET(reg, val) |
| #define | DDRC_ECCPOISONADDR1_BANK(val) |
| #define | DDRC_ECCPOISONADDR1_BANK_GET(reg) |
| #define | DDRC_ECCPOISONADDR1_BANK_SET(reg, val) |
| #define | DDRC_ECCPOISONADDR1_ROW(val) |
| #define | DDRC_ECCPOISONADDR1_ROW_GET(reg) |
| #define | DDRC_ECCPOISONADDR1_ROW_SET(reg, val) |
| #define | DDRC_READ(offset) |
| #define | DDRC_MAP_BIT(value, source, target) |
| #define | DDRC_CHECK_AND_UNMAP(bus_width, lpddr3, BIT_ID, info, addrmap) |
#define | DDR_QIS_OFFSET 0x200 |
#define | DDR_QIE_OFFSET 0x208 |
#define | DDR_QID_OFFSET 0x20c |
#define | DDR_QI_UNCRERR BSP_BIT32(2) |
#define | DDR_QI_CORERR BSP_BIT32(1) |
#define | DDRC_ECCSTAT_OFFSET 0x78 |
| #define | DDRC_ECCSTAT_UNCR_ERR(val) |
| #define | DDRC_ECCSTAT_UNCR_ERR_GET(reg) |
| #define | DDRC_ECCSTAT_UNCR_ERR_SET(reg, val) |
| #define | DDRC_ECCSTAT_CORR_ERR(val) |
| #define | DDRC_ECCSTAT_CORR_ERR_GET(reg) |
| #define | DDRC_ECCSTAT_CORR_ERR_SET(reg, val) |
| #define | DDRC_ECCSTAT_CORR_BIT(val) |
| #define | DDRC_ECCSTAT_CORR_BIT_GET(reg) |
| #define | DDRC_ECCSTAT_CORR_BIT_SET(reg, val) |
#define | DDRC_ECCCADDR0_OFFSET 0x84 |
#define | DDRC_ECCUADDR0_OFFSET 0xA4 |
#define | DDRC_ECCXADDR0_RANK BSP_BIT32(24) |
| #define | DDRC_ECCXADDR0_ROW(val) |
| #define | DDRC_ECCXADDR0_ROW_GET(reg) |
| #define | DDRC_ECCXADDR0_ROW_SET(reg, val) |
#define | DDRC_ECCCADDR1_OFFSET 0x88 |
#define | DDRC_ECCUADDR1_OFFSET 0xA8 |
| #define | DDRC_ECCXADDR1_BG(val) |
| #define | DDRC_ECCXADDR1_BG_GET(reg) |
| #define | DDRC_ECCXADDR1_BG_SET(reg, val) |
| #define | DDRC_ECCXADDR1_BANK(val) |
| #define | DDRC_ECCXADDR1_BANK_GET(reg) |
| #define | DDRC_ECCXADDR1_BANK_SET(reg, val) |
| #define | DDRC_ECCXADDR1_COL(val) |
| #define | DDRC_ECCXADDR1_COL_GET(reg) |
| #define | DDRC_ECCXADDR1_COL_SET(reg, val) |
