RTEMS
6.3
Toggle main menu visibility
bsps
aarch64
xilinx-zynqmp
include
bsp
ecc_priv.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2024 On-Line Applications Research Corporation (OAR)
13
* Written by Kinsey Moore <kinsey.moore@oarcorp.com>
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef LIBBSP_AARCH64_XILINX_ZYNQMP_BSP_ECC_PRIV_H
38
#define LIBBSP_AARCH64_XILINX_ZYNQMP_BSP_ECC_PRIV_H
39
45
46
#include <bspopts.h>
47
48
#ifndef ASM
49
50
rtems.h
51
52
#ifdef __cplusplus
53
extern
"C"
54
#endif
/* __cplusplus */
55
56
bsp/ecc.h
57
63
void
zynqmp_ecc_init
void
64
71
void
zynqmp_ecc_init_bsp
void
72
76
rtems_status_code
zynqmp_configure_cache_ecc
void
77
81
rtems_status_code
zynqmp_configure_ocm_ecc
void
82
86
rtems_status_code
zynqmp_configure_ddr_ecc
void
87
94
void
zynqmp_invoke_ecc_handler
ECC_Event_Type
event,
void
*data );
95
96
#ifdef __cplusplus
97
98
#endif
/* __cplusplus */
99
100
#endif
/* ASM */
101
103
104
#endif
/* LIBBSP_AARCH64_XILINX_ZYNQMP_BSP_ECC_PRIV_H */
ecc.h
This header file provides internal APIs for managing ECC events.
rtems_status_code
rtems_status_code
Definition
status.h:85
zynqmp_ecc_init_bsp
void zynqmp_ecc_init_bsp(void)
Initialize BSP-specific ECC reporting.
Definition
bspstartecc_cfc400x.c:40
zynqmp_ecc_init
void zynqmp_ecc_init(void)
Initialize ECC reporting support.
Definition
bspstartecc_hw.c:84
ECC_Event_Type
ECC_Event_Type
Enumeration describing the possible types of ECC events.
Definition
ecc.h:57
rtems_status_code zynqmp_configure_ocm_ecc(void)
Configure On-Chip Memory (OCM) ECC reporting.
Definition
ocm.c:255
rtems_status_code zynqmp_configure_cache_ecc(void)
Configure Cache ECC reporting.
Definition
cache.c:115
rtems_status_code zynqmp_configure_ddr_ecc(void)
Configure DDR Memory ECC reporting.
Definition
ddr.c:607
void zynqmp_invoke_ecc_handler(ECC_Event_Type event, void *data)
Invoke the ECC error handler.
Definition
bspstartecc_hw.c:49
rtems.h
