RTEMS 6.3
bsp.h File Reference
Global BSP definitions. More...
#include <bspopts.h>
#include <libcpu/powerpc-utility.h>
#include <bsp/hwreg_vals.h>
#include <bsp/vectors.h>
#include <bsp/irq.h>
#include <bsp/default-initial-extension.h>
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_ARRAY_CNT(arr)
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   BSP_tsec_attach
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "tsec1"
#define RTEMS_BSP_NETWORK_DRIVER_NAME2   "tsec2"
#define BSP_Convert_decrementer(_value)
 LINKER_SYMBOL (bsp_ram_start)
 LINKER_SYMBOL (bsp_ram_end)
 LINKER_SYMBOL (bsp_ram_size)
 LINKER_SYMBOL (bsp_rom_start)
 LINKER_SYMBOL (bsp_rom_end)
 LINKER_SYMBOL (bsp_rom_size)
 LINKER_SYMBOL (bsp_section_text_start)
 LINKER_SYMBOL (bsp_section_text_end)
 LINKER_SYMBOL (bsp_section_text_size)
 LINKER_SYMBOL (bsp_section_data_start)
 LINKER_SYMBOL (bsp_section_data_end)
 LINKER_SYMBOL (bsp_section_data_size)
 LINKER_SYMBOL (bsp_section_bss_start)
 LINKER_SYMBOL (bsp_section_bss_end)
 LINKER_SYMBOL (bsp_section_bss_size)
 LINKER_SYMBOL (bsp_work_area_start)
 LINKER_SYMBOL (IMMRBAR)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task.
rtems_status_code bsp_register_i2c (void)
rtems_status_code bsp_register_spi (void)
int BSP_tsec_attach (struct rtems_bsdnet_ifconfig *config, int attaching)
void mpc83xx_zero_4 (void *dest, size_t n)
void cpu_init (void)
void bsp_restart (void *addr)
unsigned int BSP_bus_frequency
uint32_t bsp_clicks_per_usec
