RTEMS
6.3
Toggle main menu visibility
bsps
arm
csb337
include
at91rm9200_mem.h
1
8
9
10
* AT91RM9200 Memory Controller definitions
11
12
* Copyright (c) 2002 by Cogent Computer Systems
13
* Written by Mike Kelly <mike@cogcomp.com>
14
15
* The license and distribution terms for this file may be
16
* found in the file LICENSE in this distribution or at
17
* http://www.rtems.org/license/LICENSE.
18
19
#ifndef AT91RM9200_MEM_H
20
#define AT91RM9200_MEM_H
21
22
23
* External Bus Interface Unit
24
25
#define EBI_CSA 0x00
/* Chip Select Assignment Register */
26
#define EBI_CFGR 0x04
/* Configuration Register */
27
28
/* Bit Defines */
29
/* EBI_CSA - Chip Select Assignment Register */
30
#define EBI_CSA_CS4_CF BIT4
/* 1 = CS4-6 are assigned to Compact Flash, 0 = Chip Selects */
31
#define EBI_CSA_CS3_SMM BIT3
/* 1 = CS3 is assigned to SmartMedia, 0 = Chip Select */
32
#define EBI_CSA_CS1_SDRAM BIT1
/* 1 = CS1 is assigned to SDRAM, 0 = Chip Select */
33
#define EBI_CSA_CS0_BF BIT0
/* 1 = CS0 is assigned to Burst Flash, 0 = Chip Select */
34
35
/* EBI_CFGR - Configuration Register */
36
#define EBI_CFGR_DBPU BIT0
/* 1 = Disable D0-15 pullups */
37
38
39
* Static Memory Interface Unit
40
41
#define SMC_CSR0 0x00
/* Chip Select Register 0 */
42
#define SMC_CSR1 0x04
/* Chip Select Register 1 */
43
#define SMC_CSR2 0x08
/* Chip Select Register 2 */
44
#define SMC_CSR3 0x0C
/* Chip Select Register 3 */
45
#define SMC_CSR4 0x10
/* Chip Select Register 4 */
46
#define SMC_CSR5 0x14
/* Chip Select Register 5 */
47
#define SMC_CSR6 0x18
/* Chip Select Register 6 */
48
#define SMC_CSR7 0x1C
/* Chip Select Register 7 */
49
50
/* Bit Defines */
51
/* SMC_CSR0 -7 - Chip Selects 0 - 7 Register */
52
#define SMC_CSR_RWHOLD(_x_) ((_x_ & 0x3) << 28)
/* Hold CS after R/W strobes */
53
#define SMC_CSR_RWSETUP(_x_) ((_x_ & 0x3) << 24)
/* Setup CS before R/W strobes */
54
#define SMC_CSR_ACSS_0 (0 << 16)
/* Setup/Hold Address 0 clocks before/after CS */
55
#define SMC_CSR_ACSS_1 (1 << 16)
/* Setup/Hold Address 1 clock before/after CS */
56
#define SMC_CSR_ACSS_2 (2 << 16)
/* Setup/Hold Address 2 clocks before/after CS */
57
#define SMC_CSR_ACSS_3 (3 << 16)
/* Setup/Hold Address 3 clocks before/after CS */
58
#define SMC_CSR_DRP_NORMAL 0
/* 0 = normal read protocol */
59
#define SMC_CSR_DRP_EARLY BIT15
/* 1 = early read protocol */
60
#define SMC_CSR_DBW_16 (1 << 13)
/* CS DataBus Width = 16-Bits */
61
#define SMC_CSR_DBW_8 (2 << 13)
/* CS DataBus Width = 8 Bits */
62
#define SMC_CSR_BAT_16_1 0
/* Single 16-Bit device (when DBW is 16) */
63
#define SMC_CSR_BAT_16_2 BIT12
/* Dual 8-Bit devices (when DBW is 16) */
64
#define SMC_CSR_TDF(_x_) ((_x_ & 0xf) << 8)
/* Intercycle Data Float Time */
65
#define SMC_CSR_WSEN BIT7
/* 1 = wait states are enabled */
66
#define SMC_CSR_NWS(_x_) ((_x_ & 0x7f) << 0)
/* Wait States + 1 */
67
68
69
/* SDRAM Memory Interface Unit */
70
71
#define SDRC_MR 0x00
/* Mode Register */
72
#define SDRC_TR 0x04
/* Refresh Timer Register */
73
#define SDRC_CR 0x08
74
#define SDRC_SRR 0x0C
/* Self Refresh Register */
75
#define SDRC_LPR 0x10
/* Low Power Register */
76
#define SDRC_IER 0x14
/* Interrupt Enable Register */
77
#define SDRC_IDR 0x18
/* Interrupt Disable Register */
78
#define SDRC_IMR 0x1C
/* Interrupt Mask Register */
79
#define SDRC_ISR 0x20
/* Interrupt Status Register */
80
81
/* Bit Defines */
82
/* SDRC_MR - Mode Register */
83
#define SDRC_MR_DBW_16 BIT4
/* 1 = SDRAM is 16-bits wide, 0 = 32-bits */
84
#define SDRC_MR_NORM (0 << 0)
/* Normal Mode - All accesses to SDRAM are decoded normally */
85
#define SDRC_MR_NOP (1 << 0)
/* NOP Command is sent to SDRAM */
86
#define SDRC_MR_PRE (2 << 0)
/* Precharge All Command is sent to SDRAM */
87
#define SDRC_MR_MRS (3 << 0)
/* Mode Register Set Command is sent to SDRAM */
88
#define SDRC_MR_REF (4 << 0)
/* Refresh Command is sent to SDRAM */
89
90
/* SDRC_TR - Refresh Timer Register */
91
#define SDRC_TR_COUNT(_x_) ((_x_ & 0xfff) << 0)
92
93
/* SDRC_CR - Configuration Register */
94
#define SDRC_CR_TXSR(_x_) ((_x_ & 0xf) << 27)
/* CKE to ACT Time */
95
#define SDRC_CR_TRAS(_x_) ((_x_ & 0xf) << 23)
/* ACT to PRE Time */
96
#define SDRC_CR_TRCD(_x_) ((_x_ & 0xf) << 19)
/* RAS to CAS Time */
97
#define SDRC_CR_TRP(_x_) ((_x_ & 0xf) << 15)
/* PRE to ACT Time */
98
#define SDRC_CR_TRC(_x_) ((_x_ & 0xf) << 11)
/* REF to ACT Time */
99
#define SDRC_CR_TWR(_x_) ((_x_ & 0xf) << 7)
/* Write Recovery Time */
100
#define SDRC_CR_CAS_2 (2 << 5)
/* Cas Delay = 2, this is the only supported value */
101
#define SDRC_CR_NB_2 0
/* 2 Banks per device */
102
#define SDRC_CR_NB_4 BIT4
/* 4 Banks per device */
103
#define SDRC_CR_NR_11 (0 << 2)
/* Number of rows = 11 */
104
#define SDRC_CR_NR_12 (1 << 2)
/* Number of rows = 12 */
105
#define SDRC_CR_NR_13 (2 << 2)
/* Number of rows = 13 */
106
#define SDRC_CR_NC_8 (0 << 0)
/* Number of columns = 8 */
107
#define SDRC_CR_NC_9 (1 << 0)
/* Number of columns = 9 */
108
#define SDRC_CR_NC_10 (2 << 0)
/* Number of columns = 10 */
109
#define SDRC_CR_NC_11 (3 << 0)
/* Number of columns = 11 */
110
111
/* SDRC_SRR - Self Refresh Register */
112
#define SDRC_SRR_SRCB BIT0
/* 1 = Enter Self Refresh */
113
114
/* SDRC_LPR - Low Power Register */
115
#define SDRC_LPR_LPCB BIT0
/* 1 = De-assert CKE between accesses */
116
117
/* SDRC_IER - Interrupt Enable Register */
118
/* SDRC_IDR - Interrupt Disable Register */
119
/* SDRC_ISR - Interrupt Mask Register */
120
/* SDRC_IMR - Interrupt Mask Register */
121
#define SDRC_INT_RES BIT0
/* Refresh Error Status */
122
123
#endif
