RTEMS 6.3
csb337 Directory Reference
Directories
btimer
clock
console
include
irq
start
umon
This is the BSP for Cogent Computer System's CSB337 and updated for CSB637, single board computers using the Atmel AT91RM9200 CPU. The differences in the board are very slight but important:
CSB337 CSB637
16Mb RAM 64Mb RAM
Please check README.kit637_v6 for more explanation about the Cogent's Development Kit that uses the CSB637 single board computer.
kit637_v6
Fernando Nicodemos fgnic.nosp@m.odem.nosp@m.os@te.nosp@m.rra..nosp@m.com.b.nosp@m.r from NCB - Sistemas Embarcados Ltda. (Brazil)
This is the BSP for Cogent Computer System's KIT637_V6. It implements an updated version of the CSB337 board with a number of optional peripherals.
This KIT is implemented by CSB637 single board computer using the Atmel AT91RM9200 CPU and the CSB937 target main board. It uses an Optrex LCD (T-51750AA, 640x480) and Touchscreen (not supported in this BSP). The IDE and USB (host and device) interfaces are also not supported. The SD and Compact Flash cards drivers are still under development.
The differences in the CSB637 single board computer are very slight but important:
CSB337 CSB637
Clock speed 184MHz 184MHz
External memory 16MB SDRAM 64MB SDRAM
Flash memory 8MB Strata 8/16MB Strata (8MB used by default)
Video buffer 1MB 8MB
Video driver S1D13706 S1D13506
PHY Layer LXT971ALC BCM5221
?? Some GPIO or interrupts moved around.
