RTEMS
6.3
Toggle main menu visibility
bsps
arm
csb337
include
at91rm9200_emac.h
1
8
9
10
* Atmel AT91RM9200 EMAC Register definitions
11
12
* Copyright (c) 2003 by Cogent Computer Systems
13
* Written by Mike Kelly <mike@cogcomp.com>
14
15
* The license and distribution terms for this file may be
16
* found in the file LICENSE in this distribution or at
17
* http://www.rtems.org/license/LICENSE.
18
19
#ifndef __AT91RM9200_EMAC_H__
20
#define __AT91RM9200_EMAC_H__
21
22
bits.h
23
24
/*Register offsets */
25
#define EMAC_CTL 0x00
/* Network Control Register */
26
#define EMAC_CFG 0x04
/* Network Configuration Register */
27
#define EMAC_SR 0x08
/* Network Status Register */
28
#define EMAC_TAR 0x0C
/* Transmit Address Register */
29
#define EMAC_TCR 0x10
/* Transmit Control Register */
30
#define EMAC_TSR 0x14
/* Transmit Status Register */
31
#define EMAC_RBQP 0x18
/* Receive Buffer Queue Pointer */
32
#define EMAC_RSR 0x20
/* Receive Status Register */
33
#define EMAC_ISR 0x24
/* Interrupt Enable Register */
34
#define EMAC_IER 0x28
35
#define EMAC_IDR 0x2C
/* Interrupt Disable Register */
36
#define EMAC_IMR 0x30
/* Interrupt Mask Register */
37
#define EMAC_MAN 0x34
/* PHY Maintenance Register */
38
#define EMAC_FRA 0x40
/* Frames Transmitted OK Register */
39
#define EMAC_SCOL 0x44
/* Single Collision Frame Register */
40
#define EMAC_MCOL 0x48
/* Multiple Collision Frame Register */
41
#define EMAC_OK 0x4C
/* Frames Received OK Register */
42
#define EMAC_SEQE 0x50
/* Frame Check Sequence Error Register */
43
#define EMAC_ALE 0x54
/* Alignment Error Register */
44
#define EMAC_DTE 0x58
/* Deferred Transmission Frame Register */
45
#define EMAC_LCOL 0x5C
/* Late Collision Register */
46
#define EMAC_ECOL 0x60
/* Excessive Collision Register */
47
#define EMAC_CSE 0x64
/* Carrier Sense Error Register */
48
#define EMAC_TUE 0x68
/* Transmit Underrun Error Register */
49
#define EMAC_CDE 0x6C
/* Code Error Register */
50
#define EMAC_ELR 0x70
/* Excessive Length Error Register */
51
#define EMAC_RJB 0x74
/* Receive Jabber Register */
52
#define EMAC_USF 0x78
/* Undersize Frame Register */
53
#define EMAC_SQEE 0x7C
/* SQE Test Error Register */
54
#define EMAC_DRFC 0x80
/* Discarded RX Frame Register */
55
#define EMAC_HSH 0x90
/* Hash Address High[63:32] */
56
#define EMAC_HSL 0x94
/* Hash Address Low[31:0] */
57
#define EMAC_SA1L 0x98
/* Specific Addr 1 Low, First 4 bytes */
58
#define EMAC_SA1H 0x9C
/* Specific Addr 1 High, Last 2 bytes */
59
#define EMAC_SA2L 0xA0
/* Specific Addr 2 Low, First 4 bytes */
60
#define EMAC_SA2H 0xA4
/* Specific Addr 2 High, Last 2 bytes */
61
#define EMAC_SA3L 0xA8
/* Specific Addr 3 Low, First 4 bytes */
62
#define EMAC_SA3H 0xAC
/* Specific Addr 3 High, Last 2 bytes */
63
#define EMAC_SA4L 0xB0
/* Specific Addr 4 Low, First 4 bytes */
64
#define EMAC_SA4H 0xB4
/* Specific Addr 4 High, Last 2 bytesr */
65
66
/* Control Register, EMAC_CTL, Offset 0x0 */
67
#define EMAC_CTL_LB BIT0
/* 1 = Set Loopback output signal */
68
#define EMAC_CTL_LBL BIT1
/* 1 = Loopback local. */
69
#define EMAC_CTL_RE BIT2
/* 1 = Receive enable. */
70
#define EMAC_CTL_TE BIT3
/* 1 = Transmit enable. */
71
#define EMAC_CTL_MPE BIT4
/* 1 = Management port enable. */
72
#define EMAC_CTL_CSR BIT5
/* Write 1 to clear stats registers. */
73
#define EMAC_CTL_ISR BIT6
/* Write to increment stats registers */
74
#define EMAC_CTL_WES BIT7
/* 1 = Enable writing to stats regs */
75
#define EMAC_CTL_BP BIT8
/* 1 = Force collision on all RX frames */
76
77
/* Configuration Register, EMAC_CFG, Offset 0x4 */
78
#define EMAC_CFG_SPD BIT0
/* 1 = 10/100 Speed (not functional?) */
79
#define EMAC_CFG_FD BIT1
/* 1 = Full duplex. */
80
#define EMAC_CFG_BR BIT2
/* write 0 */
81
#define EMAC_CFG_CAF BIT4
/* 1 = accept all frames */
82
#define EMAC_CFG_NBC BIT5
/* 1 = disable reception of bcast frms */
83
#define EMAC_CFG_MTI BIT6
/* 1 = Multicast hash enable */
84
#define EMAC_CFG_UNI BIT7
/* 1 = Unicast hash enable. */
85
#define EMAC_CFG_BIG BIT8
/* 1 = enable reception 1522 byte frms */
86
#define EMAC_CFG_EAE BIT9
/* write 0 */
87
#define EMAC_CFG_CLK_8 (0 << 10)
/* MII Clock = HCLK divided by 8 */
88
#define EMAC_CFG_CLK_16 (1 << 10)
/* MII Clock = HCLK divided by 16 */
89
#define EMAC_CFG_CLK_32 (2 << 10)
/* MII Clock = HCLK divided by 32 */
90
#define EMAC_CFG_CLK_64 (3 << 10)
/* MII Clock = HCLK divided by 64 */
91
#define EMAC_CFG_CLK_MASK (3 << 10)
/* MII Clock mask */
92
#define EMAC_CFG_RTY BIT12
/* Retry Test Mode - Must be 0 */
93
#define EMAC_CFG_RMII BIT13
/* Reduced MII Mode Enable */
94
95
/* Status Register, EMAC_SR, Offset 0x8 */
96
#define EMAC_LINK BIT0
/* Link pin */
97
#define EMAC_MDIO BIT1
/* Real Time state of MDIO pin */
98
#define EMAC_IDLE BIT2
/* 0 = PHY Logic is idle */
99
100
/* Transmit Control Register, EMAC_TCR, Offset 0x10 */
101
#define EMAC_TCR_LEN(_x_) ((_x_ & 0x7FF) << 0)
/* Tx frame len minus CRC */
102
#define EMAC_TCR_NCRC BIT15
/* Do'nt append CRC on Tx */
103
104
/* Transmit Status Register, EMAC_TSR, Offset 0x14 */
105
#define EMAC_TSR_OVR BIT0
/* 1 = Transmit buffer overrun */
106
#define EMAC_TSR_COL BIT1
/* 1 = Collision occured */
107
#define EMAC_TSR_RLE BIT2
/* 1 = Retry lmimt exceeded */
108
#define EMAC_TSR_TXIDLE BIT3
/* 1 = Transmitter is idle */
109
#define EMAC_TSR_BNQ BIT4
/* 1 = Transmit buffer not queued */
110
#define EMAC_TSR_COMP BIT5
/* 1 = Transmit complete */
111
#define EMAC_TSR_UND BIT6
/* 1 = Transmit underrun */
112
113
/* Receive Status Register, EMAC_RSR, Offset 0x20 */
114
#define EMAC_RSR_BNA BIT0
/* 1 = Buffer not available */
115
#define EMAC_RSR_REC BIT1
/* 1 = Frame received */
116
#define EMAC_RSR_OVR BIT2
/* 1 = Receive overrun */
117
118
119
* Interrupt Status Register, EMAC_ISR, Offsen 0x24
120
* Interrupt Enable Register, EMAC_IER, Offset 0x28
121
* Interrupt Disable Register, EMAC_IDR, Offset 0x2c
122
* Interrupt Mask Register, EMAC_IMR, Offset 0x30
123
124
#define EMAC_INT_DONE BIT0
/* Phy management done */
125
#define EMAC_INT_RCOM BIT1
/* Receive complete */
126
#define EMAC_INT_RBNA BIT2
/* Receive buffer not available */
127
#define EMAC_INT_TOVR BIT3
/* Transmit buffer overrun */
128
#define EMAC_INT_TUND BIT4
/* Transmit buffer underrun */
129
#define EMAC_INT_RTRY BIT5
/* Transmit Retry limt */
130
#define EMAC_INT_TBRE BIT6
/* Transmit buffer register empty */
131
#define EMAC_INT_TCOM BIT7
/* Transmit complete */
132
#define EMAC_INT_TIDLE BIT8
/* Transmit idle */
133
#define EMAC_INT_LINK BIT9
/* Link pin changed value */
134
#define EMAC_INT_ROVR BIT10
/* Receive overrun */
135
#define EMAC_INT_ABT BIT11
/* Abort on DMA transfer */
136
137
/* PHY Maintenance Register, EMAC_MAN, Offset 0x34 */
138
#define EMAC_MAN_DATA(_x_) ((_x_ & 0xFFFF) << 0)
/* PHY data register */
139
#define EMAC_MAN_CODE (0x2 << 16)
/* IEEE Code */
140
#define EMAC_MAN_REGA(_x_) ((_x_ & 0x1F) << 18)
/* PHY register address */
141
#define EMAC_MAN_PHYA(_x_) ((_x_ & 0x1F) << 23)
/* PHY address */
142
#define EMAC_MAN_WRITE (0x1 << 28)
/* Transfer is a write */
143
#define EMAC_MAN_READ (0x2 << 28)
/* Transfer is a read */
144
#define EMAC_MAN_HIGH BIT30
/* Must be set */
145
#define EMAC_MAN_LOW BIT31
146
147
148
* Bit assignments for Receive Buffer Descriptor
149
* Address - Word 0
150
151
#define RXBUF_ADD_BASE_MASK 0xfffffffc
/* Base addr of the rx buf */
152
#define RXBUF_ADD_WRAP BIT1
/* set indicates last buf */
153
#define RXBUF_ADD_OWNED BIT0
/* 1 = SW owns the pointer */
154
155
/* Status - Word 1 */
156
#define RXBUF_STAT_BCAST BIT31
/* Global bcast addr detected */
157
#define RXBUF_STAT_MULTI BIT30
/* Multicast hash match */
158
#define RXBUF_STAT_UNI BIT29
/* Unicast hash match */
159
#define RXBUF_STAT_EXT BIT28
/* External address (optional) */
160
#define RXBUF_STAT_UNK BIT27
/* Unknown source address */
161
#define RXBUF_STAT_LOC1 BIT26
/* Local address 1 match */
162
#define RXBUF_STAT_LOC2 BIT25
/* Local address 2 match */
163
#define RXBUF_STAT_LOC3 BIT24
/* Local address 3 match */
164
#define RXBUF_STAT_LOC4 BIT23
/* Local address 4 match */
165
#define RXBUF_STAT_LEN_MASK 0x7ff
/* Len of frame including FCS */
166
167
#endif
/* __AT91RM9200_EMAC_H__ */
168
bits.h
Contains Defined Bits.
