RTEMS
6.3
Toggle main menu visibility
bsps
arm
csb337
include
at91rm9200_dbgu.h
1
8
9
10
* Atmel AT91RM9200_DBGU Register definitions
11
12
* Copyright (c) 2003 by Cogent Computer Systems
13
* Written by Mike Kelly <mike@cogcomp.com>
14
15
* The license and distribution terms for this file may be
16
* found in the file LICENSE in this distribution or at
17
* http://www.rtems.org/license/LICENSE.
18
19
#ifndef __AT91RM9200_DBGU_H__
20
#define __AT91RM9200_DBGU_H__
21
22
#include "
bits.h
23
24
/* Register Offsets */
25
#define DBGU_CR 0x00
/* Control Register */
26
#define DBGU_MR 0x04
/* Mode Register */
27
#define DBGU_IER 0x08
/* Interrupt Enable Register */
28
#define DBGU_IDR 0x0C
/* Interrupt Disable Register */
29
#define DBGU_IMR 0x10
/* Interrupt Mask Register */
30
#define DBGU_SR 0x14
/* Channel Status Register */
31
#define DBGU_RHR 0x18
/* Receiver Holding Register */
32
#define DBGU_THR 0x1C
/* Transmitter Holding Register */
33
#define DBGU_BRGR 0x20
/* Baud Rate Generator Register */
34
#define DBGU_C1R 0x40
/* Chip ID1 Register */
35
#define DBGU_C2R 0x44
/* Chip ID2 Register */
36
#define DBGU_FNTR 0x48
/* Force NTRST Register */
37
38
/* Bit Defines */
39
/* Control Register, DBGU_CR, Offset 0x00 */
40
#define DBGU_CR_RSTRX BIT2
/* 1 = Reset and disable receiver */
41
#define DBGU_CR_RSTTX BIT3
/* 1 = Reset and disable transmitter */
42
#define DBGU_CR_RXEN BIT4
/* 1 = Receiver enable */
43
#define DBGU_CR_RXDIS BIT5
/* 1 = Receiver disable */
44
#define DBGU_CR_TXEN BIT6
/* 1 = Transmitter enable */
45
#define DBGU_CR_TXDIS BIT7
/* 1 = Transmitter disable */
46
#define DBGU_CR_RSTSTA BIT8
/* 1 = Reset PARE, FRAME and OVRE in DBGU_SR. */
47
48
/* Mode Register. DBGU_MR. Offset 0x04 */
49
#define DBGU_MR_PAR_EVEN (0x0 << 9)
/* Even Parity */
50
#define DBGU_MR_PAR_ODD (0x1 << 9)
/* Odd Parity */
51
#define DBGU_MR_PAR_SPACE (0x2 << 9)
/* Parity forced to 0 (Space) */
52
#define DBGU_MR_PAR_MARK (0x3 << 9)
/* Parity forced to 1 (Mark) */
53
#define DBGU_MR_PAR_NONE (0x4 << 9)
/* No Parity */
54
#define DBGU_MR_PAR_MDROP (0x6 << 9)
/* Multi-drop mode */
55
#define DBGU_MR_CHMODE_NORM (0x0 << 14)
/* Normal Mode */
56
#define DBGU_MR_CHMODE_AUTO (0x1 << 14)
/* Auto Echo: RXD drives TXD */
57
#define DBGU_MR_CHMODE_LOC (0x2 << 14)
/* Local Loopback: TXD drives RXD */
58
#define DBGU_MR_CHMODE_REM (0x3 << 14)
/* Remote Loopback: RXD pin connected to TXD pin. */
59
60
/* Interrupt Enable Register, DBGU_IER, Offset 0x08 */
61
/* Interrupt Disable Register, DBGU_IDR, Offset 0x0C */
62
/* Interrupt Mask Register, DBGU_IMR, Offset 0x10 */
63
/* Channel Status Register, DBGU_SR, Offset 0x14 */
64
#define DBGU_INT_RXRDY BIT0
/* RXRDY Interrupt */
65
#define DBGU_INT_TXRDY BIT1
/* TXRDY Interrupt */
66
#define DBGU_INT_ENDRX BIT3
/* End of Receive Transfer Interrupt */
67
#define DBGU_INT_ENDTX BIT4
/* End of Transmit Interrupt */
68
#define DBGU_INT_OVRE BIT5
/* Overrun Interrupt */
69
#define DBGU_INT_FRAME BIT6
/* Framing Error Interrupt */
70
#define DBGU_INT_PARE BIT7
/* Parity Error Interrupt */
71
#define DBGU_INT_TXEMPTY BIT9
/* TXEMPTY Interrupt */
72
#define DBGU_INT_TXBUFE BIT11
/* TXBUFE Interrupt */
73
#define DBGU_INT_RXBUFF BIT12
/* RXBUFF Interrupt */
74
#define DBGU_INT_COMM_TX BIT30
/* COMM_TX Interrupt */
75
#define DBGU_INT_COMM_RX BIT31
/* COMM_RX Interrupt */
76
#define DBGU_INT_ALL 0xC0001AFB
/* all assigned bits */
77
78
/* FORCE_NTRST Register, DBGU_FNTR, Offset 0x48 */
79
#define DBGU_FNTR_NTRST BIT0
/* 1 = Force NTRST low in JTAG */
80
81
typedef
struct
82
volatile
uint32_t cr;
83
volatile
uint32_t mr;
84
volatile
uint32_t ier;
85
volatile
uint32_t idr;
86
volatile
uint32_t imr;
87
volatile
uint32_t sr;
88
volatile
uint32_t rhr;
89
volatile
uint32_t thr;
90
volatile
uint32_t brgr;
91
volatile
uint32_t _res0[7];
92
volatile
uint32_t cidr;
93
volatile
uint32_t exid;
94
volatile
uint32_t fnr;
95
at91rm9200_dbgu_regs_t
96
97
#endif
/* __AT91RM9200_DBGU_H__ */
bits.h
Contains Defined Bits.
Definition
at91rm9200_dbgu.h:81
