RTEMS
6.3
Toggle main menu visibility
bsps
arm
include
bsp
arm-a9mpcore-regs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (c) 2013 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_SHARED_ARM_A9MPCORE_REGS_H
37
#define LIBBSP_ARM_SHARED_ARM_A9MPCORE_REGS_H
38
39
bsp/utility.h
40
50
51
typedef
struct
52
uint32_t ctrl;
53
#define A9MPCORE_SCU_CTRL_SCU_EN BSP_BIT32(0)
54
#define A9MPCORE_SCU_CTRL_ADDR_FLT_EN BSP_BIT32(1)
55
#define A9MPCORE_SCU_CTRL_RAM_PAR_EN BSP_BIT32(2)
56
#define A9MPCORE_SCU_CTRL_SCU_SPEC_LINE_FILL_EN BSP_BIT32(3)
57
#define A9MPCORE_SCU_CTRL_FORCE_PORT_0_EN BSP_BIT32(4)
58
#define A9MPCORE_SCU_CTRL_SCU_STANDBY_EN BSP_BIT32(5)
59
#define A9MPCORE_SCU_CTRL_IC_STANDBY_EN BSP_BIT32(6)
60
uint32_t cfg;
61
#define A9MPCORE_SCU_CFG_CPU_COUNT(val) BSP_FLD32(val, 0, 1)
62
#define A9MPCORE_SCU_CFG_CPU_COUNT_GET(reg) BSP_FLD32GET(reg, 0, 1)
63
#define A9MPCORE_SCU_CFG_CPU_COUNT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 1)
64
#define A9MPCORE_SCU_CFG_SMP_MODE(val) BSP_FLD32(val, 4, 7)
65
#define A9MPCORE_SCU_CFG_SMP_MODE_GET(reg) BSP_FLD32GET(reg, 4, 7)
66
#define A9MPCORE_SCU_CFG_SMP_MODE_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
67
#define A9MPCORE_SCU_CFG_TAG_RAM_SIZE(val) BSP_FLD32(val, 8, 15)
68
#define A9MPCORE_SCU_CFG_TAG_RAM_SIZE_GET(reg) BSP_FLD32GET(reg, 8, 15)
69
#define A9MPCORE_SCU_CFG_TAG_RAM_SIZE_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
70
uint32_t pwrst;
71
uint32_t invss;
72
#define A9MPCORE_SCU_INVSS_CPU0(ways) BSP_FLD32(val, 0, 3)
73
#define A9MPCORE_SCU_INVSS_CPU0_GET(reg)
/* Write only register */
74
#define A9MPCORE_SCU_INVSS_CPU0_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
75
#define A9MPCORE_SCU_INVSS_CPU1(ways) BSP_FLD32(val, 4, 7)
76
#define A9MPCORE_SCU_INVSS_CPU1_GET(reg)
77
#define A9MPCORE_SCU_INVSS_CPU1_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
78
#define A9MPCORE_SCU_INVSS_CPU2(ways) BSP_FLD32(val, 8, 11)
79
#define A9MPCORE_SCU_INVSS_CPU2_GET(reg)
80
#define A9MPCORE_SCU_INVSS_CPU2_SET(reg, val) BSP_FLD32SET(reg, val, 8, 11)
81
#define A9MPCORE_SCU_INVSS_CPU3(ways) BSP_FLD32(val, 12, 15)
82
#define A9MPCORE_SCU_INVSS_CPU3_GET(reg)
83
#define A9MPCORE_SCU_INVSS_CPU3_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
84
uint32_t reserved_09[8];
85
uint32_t diagn_ctrl;
86
#define A9MPCORE_SCU_DIAGN_CTRL_MIGRATORY_BIT_DISABLE BSP_BIT32(0)
87
uint32_t reserved_10[3];
88
uint32_t fltstart;
89
uint32_t fltend;
90
uint32_t reserved_48[2];
91
uint32_t sac;
92
uint32_t snsac;
93
a9mpcore_scu
94
95
typedef
struct
96
a9mpcore_gic
97
98
typedef
struct
99
uint32_t cntrlower;
100
uint32_t cntrupper;
101
#define A9MPCORE_GT_CTRL_PRESCALER(val) BSP_FLD32(val, 8, 15)
102
#define A9MPCORE_GT_CTRL_PRESCALER_GET(reg) BSP_FLD32GET(reg, 8, 15)
103
#define A9MPCORE_GT_CTRL_PRESCALER_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
104
#define A9MPCORE_GT_CTRL_AUTOINC_EN BSP_BIT32(3)
105
#define A9MPCORE_GT_CTRL_IRQ_EN BSP_BIT32(2)
106
#define A9MPCORE_GT_CTRL_COMP_EN BSP_BIT32(1)
107
#define A9MPCORE_GT_CTRL_TMR_EN BSP_BIT32(0)
108
uint32_t ctrl;
109
#define A9MPCORE_GT_IRQST_EFLG BSP_BIT32(0)
110
uint32_t irqst;
111
uint32_t cmpvallower;
112
uint32_t cmpvalupper;
113
uint32_t autoinc;
114
a9mpcore_gt
115
116
typedef
struct
117
uint32_t load;
118
uint32_t cntr;
119
uint32_t ctrl;
120
#define A9MPCORE_PT_CTRL_PRESCALER(val) BSP_FLD32(val, 8, 15)
121
#define A9MPCORE_PT_CTRL_PRESCALER_GET(reg) BSP_FLD32GET(reg, 8, 15)
122
#define A9MPCORE_PT_CTRL_PRESCALER_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
123
#define A9MPCORE_PT_CTRL_IRQ_EN BSP_BIT32(2)
124
#define A9MPCORE_PT_CTRL_AUTO_RLD BSP_BIT32(1)
125
#define A9MPCORE_PT_CTRL_TMR_EN BSP_BIT32(0)
126
uint32_t irqst;
127
#define A9MPCORE_PT_IRQST_EFLG BSP_BIT32(0)
128
a9mpcore_pt
129
130
typedef
struct
131
uint32_t load;
132
uint32_t cntr;
133
uint32_t ctrl;
134
uint32_t irqst;
135
uint32_t rstst;
136
uint32_t dis;
137
a9mpcore_pw
138
139
typedef
struct
140
a9mpcore_idist
141
142
typedef
struct
143
a9mpcore_scu
scu;
144
uint32_t reserved_58[42];
145
a9mpcore_gic
gic;
146
uint32_t reserved_100[64];
147
a9mpcore_gt
gt;
148
uint32_t reserved_21c[249];
149
a9mpcore_pt
pt;
150
uint32_t reserved_610[4];
151
a9mpcore_pw
pw;
152
uint32_t reserved_638[626];
153
a9mpcore_idist
idist;
154
a9mpcore
155
157
158
#endif
/* LIBBSP_ARM_SHARED_ARM_A9MPCORE_REGS_H */
utility.h
This header file provides utility macros for BSPs.
a9mpcore_gic
Definition
arm-a9mpcore-regs.h:95
a9mpcore_gt
Definition
arm-a9mpcore-regs.h:98
a9mpcore_idist
Definition
arm-a9mpcore-regs.h:139
a9mpcore_pt
Definition
arm-a9mpcore-regs.h:116
a9mpcore_pw
Definition
arm-a9mpcore-regs.h:130
a9mpcore_scu
Definition
arm-a9mpcore-regs.h:51
a9mpcore
Definition
arm-a9mpcore-regs.h:142
