RTEMS 6.3
This header file provides the interfaces of the Cortex-A9 MPCore Support. More...
#include <bsp/utility.h>Go to the source code of this file.
| struct | a9mpcore_scu |
| struct | a9mpcore_gic |
| struct | a9mpcore_gt |
| struct | a9mpcore_pt |
| struct | a9mpcore_pw |
| struct | a9mpcore_idist |
| struct | a9mpcore |
| #define | A9MPCORE_SCU_CTRL_SCU_EN BSP_BIT32(0) |
| #define | A9MPCORE_SCU_CTRL_ADDR_FLT_EN BSP_BIT32(1) |
| #define | A9MPCORE_SCU_CTRL_RAM_PAR_EN BSP_BIT32(2) |
| #define | A9MPCORE_SCU_CTRL_SCU_SPEC_LINE_FILL_EN BSP_BIT32(3) |
| #define | A9MPCORE_SCU_CTRL_FORCE_PORT_0_EN BSP_BIT32(4) |
| #define | A9MPCORE_SCU_CTRL_SCU_STANDBY_EN BSP_BIT32(5) |
| #define | A9MPCORE_SCU_CTRL_IC_STANDBY_EN BSP_BIT32(6) |
| #define | A9MPCORE_SCU_CFG_CPU_COUNT(val) |
| #define | A9MPCORE_SCU_CFG_CPU_COUNT_GET(reg) |
| #define | A9MPCORE_SCU_CFG_CPU_COUNT_SET(reg, val) |
| #define | A9MPCORE_SCU_CFG_SMP_MODE(val) |
| #define | A9MPCORE_SCU_CFG_SMP_MODE_GET(reg) |
| #define | A9MPCORE_SCU_CFG_SMP_MODE_SET(reg, val) |
| #define | A9MPCORE_SCU_CFG_TAG_RAM_SIZE(val) |
| #define | A9MPCORE_SCU_CFG_TAG_RAM_SIZE_GET(reg) |
| #define | A9MPCORE_SCU_CFG_TAG_RAM_SIZE_SET(reg, val) |
| #define | A9MPCORE_SCU_INVSS_CPU0(ways) |
| #define | A9MPCORE_SCU_INVSS_CPU0_GET(reg) |
| #define | A9MPCORE_SCU_INVSS_CPU0_SET(reg, val) |
| #define | A9MPCORE_SCU_INVSS_CPU1(ways) |
| #define | A9MPCORE_SCU_INVSS_CPU1_GET(reg) |
| #define | A9MPCORE_SCU_INVSS_CPU1_SET(reg, val) |
| #define | A9MPCORE_SCU_INVSS_CPU2(ways) |
| #define | A9MPCORE_SCU_INVSS_CPU2_GET(reg) |
| #define | A9MPCORE_SCU_INVSS_CPU2_SET(reg, val) |
| #define | A9MPCORE_SCU_INVSS_CPU3(ways) |
| #define | A9MPCORE_SCU_INVSS_CPU3_GET(reg) |
| #define | A9MPCORE_SCU_INVSS_CPU3_SET(reg, val) |
| #define | A9MPCORE_SCU_DIAGN_CTRL_MIGRATORY_BIT_DISABLE BSP_BIT32(0) |
| #define | A9MPCORE_GT_CTRL_PRESCALER(val) |
| #define | A9MPCORE_GT_CTRL_PRESCALER_GET(reg) |
| #define | A9MPCORE_GT_CTRL_PRESCALER_SET(reg, val) |
| #define | A9MPCORE_GT_CTRL_AUTOINC_EN BSP_BIT32(3) |
| #define | A9MPCORE_GT_CTRL_IRQ_EN BSP_BIT32(2) |
| #define | A9MPCORE_GT_CTRL_COMP_EN BSP_BIT32(1) |
| #define | A9MPCORE_GT_CTRL_TMR_EN BSP_BIT32(0) |
| #define | A9MPCORE_GT_IRQST_EFLG BSP_BIT32(0) |
| #define | A9MPCORE_PT_CTRL_PRESCALER(val) |
| #define | A9MPCORE_PT_CTRL_PRESCALER_GET(reg) |
| #define | A9MPCORE_PT_CTRL_PRESCALER_SET(reg, val) |
| #define | A9MPCORE_PT_CTRL_IRQ_EN BSP_BIT32(2) |
| #define | A9MPCORE_PT_CTRL_AUTO_RLD BSP_BIT32(1) |
| #define | A9MPCORE_PT_CTRL_TMR_EN BSP_BIT32(0) |
| #define | A9MPCORE_PT_IRQST_EFLG BSP_BIT32(0) |
| #define A9MPCORE_GT_CTRL_PRESCALER | ( | val | ) |
| #define A9MPCORE_GT_CTRL_PRESCALER_GET | ( | reg | ) |
| #define A9MPCORE_GT_CTRL_PRESCALER_SET | ( | reg, | |
| val ) |
| #define A9MPCORE_PT_CTRL_PRESCALER | ( | val | ) |
| #define A9MPCORE_PT_CTRL_PRESCALER_GET | ( | reg | ) |
| #define A9MPCORE_PT_CTRL_PRESCALER_SET | ( | reg, | |
| val ) |
| #define A9MPCORE_SCU_CFG_CPU_COUNT | ( | val | ) |
| #define A9MPCORE_SCU_CFG_CPU_COUNT_GET | ( | reg | ) |
| #define A9MPCORE_SCU_CFG_CPU_COUNT_SET | ( | reg, | |
| val ) |
| #define A9MPCORE_SCU_CFG_SMP_MODE | ( | val | ) |
| #define A9MPCORE_SCU_CFG_SMP_MODE_GET | ( | reg | ) |
| #define A9MPCORE_SCU_CFG_SMP_MODE_SET | ( | reg, | |
| val ) |
| #define A9MPCORE_SCU_CFG_TAG_RAM_SIZE | ( | val | ) |
| #define A9MPCORE_SCU_CFG_TAG_RAM_SIZE_GET | ( | reg | ) |
| #define A9MPCORE_SCU_CFG_TAG_RAM_SIZE_SET | ( | reg, | |
| val ) |
| #define A9MPCORE_SCU_INVSS_CPU0 | ( | ways | ) |
| #define A9MPCORE_SCU_INVSS_CPU0_SET | ( | reg, | |
| val ) |
| #define A9MPCORE_SCU_INVSS_CPU1 | ( | ways | ) |
| #define A9MPCORE_SCU_INVSS_CPU1_SET | ( | reg, | |
| val ) |
| #define A9MPCORE_SCU_INVSS_CPU2 | ( | ways | ) |
| #define A9MPCORE_SCU_INVSS_CPU2_SET | ( | reg, | |
| val ) |
| #define A9MPCORE_SCU_INVSS_CPU3 | ( | ways | ) |
| #define A9MPCORE_SCU_INVSS_CPU3_SET | ( | reg, | |
| val ) |
