| ALT_STATUS_CODE | alt_dma_init (const ALT_DMA_CFG_t *dma_cfg) |
| ALT_STATUS_CODE | alt_dma_uninit (void) |
| ALT_STATUS_CODE | alt_dma_channel_alloc (ALT_DMA_CHANNEL_t channel) |
| ALT_STATUS_CODE | alt_dma_channel_alloc_any (ALT_DMA_CHANNEL_t *allocated) |
| ALT_STATUS_CODE | alt_dma_channel_free (ALT_DMA_CHANNEL_t channel) |
| ALT_STATUS_CODE | alt_dma_channel_exec (ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *pgm) |
| ALT_STATUS_CODE | alt_dma_channel_kill (ALT_DMA_CHANNEL_t channel) |
| ALT_STATUS_CODE | alt_dma_channel_reg_get (ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_REG_t reg, uint32_t *val) |
| ALT_STATUS_CODE | alt_dma_send_event (ALT_DMA_EVENT_t evt_num) |
| ALT_STATUS_CODE | alt_dma_manager_state_get (ALT_DMA_MANAGER_STATE_t *state) |
| ALT_STATUS_CODE | alt_dma_channel_state_get (ALT_DMA_CHANNEL_t channel, ALT_DMA_CHANNEL_STATE_t *state) |
| ALT_STATUS_CODE | alt_dma_manager_fault_status_get (ALT_DMA_MANAGER_FAULT_t *fault) |
| ALT_STATUS_CODE | alt_dma_channel_fault_status_get (ALT_DMA_CHANNEL_t channel, ALT_DMA_CHANNEL_FAULT_t *fault) |
| ALT_STATUS_CODE | alt_dma_event_int_select (ALT_DMA_EVENT_t evt_num, ALT_DMA_EVENT_SELECT_t opt) |
| ALT_STATUS_CODE | alt_dma_event_int_status_get_raw (ALT_DMA_EVENT_t evt_num) |
| ALT_STATUS_CODE | alt_dma_int_status_get (ALT_DMA_EVENT_t irq_num) |
| ALT_STATUS_CODE | alt_dma_int_clear (ALT_DMA_EVENT_t irq_num) |
| ALT_STATUS_CODE | alt_dma_memory_to_memory (ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, void *dst, const void *src, size_t size, bool send_evt, ALT_DMA_EVENT_t evt) |
| ALT_STATUS_CODE | alt_dma_zero_to_memory (ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, void *buf, size_t size, bool send_evt, ALT_DMA_EVENT_t evt) |
| ALT_STATUS_CODE | alt_dma_memory_to_register (ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, void *dst_reg, const void *src_buf, size_t count, uint32_t register_width_bits, bool send_evt, ALT_DMA_EVENT_t evt) |
| ALT_STATUS_CODE | alt_dma_register_to_memory (ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, void *dst_buf, const void *src_reg, size_t count, uint32_t register_width_bits, bool send_evt, ALT_DMA_EVENT_t evt) |
| ALT_STATUS_CODE | alt_dma_memory_to_periph (ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, ALT_DMA_PERIPH_t dstp, const void *src, size_t size, void *periph_info, bool send_evt, ALT_DMA_EVENT_t evt) |
| ALT_STATUS_CODE | alt_dma_periph_to_memory (ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, void *dst, ALT_DMA_PERIPH_t srcp, size_t size, void *periph_info, bool send_evt, ALT_DMA_EVENT_t evt) |
ALT_STATUS_CODE | alt_dma_ecc_start (void *block, size_t size) |
