RTEMS
6.3
Toggle main menu visibility
bsps
arm
altera-cyclone-v
include
bsp
socal
hps.h
1
6
7
8
9
* Copyright 2013 Altera Corporation. All Rights Reserved. *
10
11
* Redistribution and use in source and binary forms, with or without *
12
* modification, are permitted provided that the following conditions are met: *
13
14
* 1. Redistributions of source code must retain the above copyright notice, *
15
* this list of conditions and the following disclaimer. *
16
17
* 2. Redistributions in binary form must reproduce the above copyright notice, *
18
* this list of conditions and the following disclaimer in the documentation *
19
* and/or other materials provided with the distribution. *
20
21
* 3. The name of the author may not be used to endorse or promote products *
22
* derived from this software without specific prior written permission. *
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
25
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
26
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO *
27
* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, *
28
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
29
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
30
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, *
31
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR *
32
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF *
33
* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *
34
35
36
37
/* Altera - hps */
38
39
#ifndef __ALTERA_HPS_H__
40
#define __ALTERA_HPS_H__
41
42
#ifdef __cplusplus
43
extern
"C"
44
45
#endif
/* __cplusplus */
46
47
#define ALT_HPS_ADDR 0
48
49
* Address Space : ALT_HPS
50
51
52
53
* Component Instance : stm
54
55
* Instance stm of component ALT_STM.
56
57
58
59
/* The address of the ALT_STM_REG register for the ALT_STM instance. */
60
#define ALT_STM_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_STM_ADDR) + ALT_STM_REG_OFST))
61
/* The base address byte offset for the start of the ALT_STM component. */
62
#define ALT_STM_OFST 0xfc000000
63
/* The start address of the ALT_STM component. */
64
#define ALT_STM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_STM_OFST))
65
/* The lower bound address range of the ALT_STM component. */
66
#define ALT_STM_LB_ADDR ALT_STM_ADDR
67
/* The upper bound address range of the ALT_STM component. */
68
#define ALT_STM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_STM_ADDR) + 0x4) - 1))
69
70
71
72
* Component Instance : dap
73
74
* Instance dap of component ALT_DAP.
75
76
77
78
/* The address of the ALT_DAP_REG register for the ALT_DAP instance. */
79
#define ALT_DAP_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_DAP_ADDR) + ALT_DAP_REG_OFST))
80
/* The base address byte offset for the start of the ALT_DAP component. */
81
#define ALT_DAP_OFST 0xff000000
82
/* The start address of the ALT_DAP component. */
83
#define ALT_DAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_DAP_OFST))
84
/* The lower bound address range of the ALT_DAP component. */
85
#define ALT_DAP_LB_ADDR ALT_DAP_ADDR
86
/* The upper bound address range of the ALT_DAP component. */
87
#define ALT_DAP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_DAP_ADDR) + 0x4) - 1))
88
89
90
91
* Component Instance : lwfpgaslaves
92
93
* Instance lwfpgaslaves of component ALT_LWFPGASLVS.
94
95
96
97
/* The base address byte offset for the start of the ALT_LWFPGASLVS component. */
98
#define ALT_LWFPGASLVS_OFST 0xff200000
99
/* The start address of the ALT_LWFPGASLVS component. */
100
#define ALT_LWFPGASLVS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_LWFPGASLVS_OFST))
101
/* The lower bound address range of the ALT_LWFPGASLVS component. */
102
#define ALT_LWFPGASLVS_LB_ADDR ALT_LWFPGASLVS_ADDR
103
/* The upper bound address range of the ALT_LWFPGASLVS component. */
104
#define ALT_LWFPGASLVS_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWFPGASLVS_ADDR) + 0x200000) - 1))
105
106
107
108
* Component Instance : lwhps2fpgaregs
109
110
* Instance lwhps2fpgaregs of component ALT_LWH2F.
111
112
113
114
115
* Register Group Instance : idgrp
116
117
* Instance idgrp of register group ALT_LWH2F_ID.
118
119
120
121
/* The address of the ALT_LWH2F_ID_PERIPH_ID_4 register for the ALT_LWH2F_ID instance. */
122
#define ALT_LWH2F_ID_PERIPH_ID_4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_PERIPH_ID_4_OFST))
123
/* The address of the ALT_LWH2F_ID_PERIPH_ID_0 register for the ALT_LWH2F_ID instance. */
124
#define ALT_LWH2F_ID_PERIPH_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_PERIPH_ID_0_OFST))
125
/* The address of the ALT_LWH2F_ID_PERIPH_ID_1 register for the ALT_LWH2F_ID instance. */
126
#define ALT_LWH2F_ID_PERIPH_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_PERIPH_ID_1_OFST))
127
/* The address of the ALT_LWH2F_ID_PERIPH_ID_2 register for the ALT_LWH2F_ID instance. */
128
#define ALT_LWH2F_ID_PERIPH_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_PERIPH_ID_2_OFST))
129
/* The address of the ALT_LWH2F_ID_PERIPH_ID_3 register for the ALT_LWH2F_ID instance. */
130
#define ALT_LWH2F_ID_PERIPH_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_PERIPH_ID_3_OFST))
131
/* The address of the ALT_LWH2F_ID_COMP_ID_0 register for the ALT_LWH2F_ID instance. */
132
#define ALT_LWH2F_ID_COMP_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_COMP_ID_0_OFST))
133
/* The address of the ALT_LWH2F_ID_COMP_ID_1 register for the ALT_LWH2F_ID instance. */
134
#define ALT_LWH2F_ID_COMP_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_COMP_ID_1_OFST))
135
/* The address of the ALT_LWH2F_ID_COMP_ID_2 register for the ALT_LWH2F_ID instance. */
136
#define ALT_LWH2F_ID_COMP_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_COMP_ID_2_OFST))
137
/* The address of the ALT_LWH2F_ID_COMP_ID_3 register for the ALT_LWH2F_ID instance. */
138
#define ALT_LWH2F_ID_COMP_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + ALT_LWH2F_ID_COMP_ID_3_OFST))
139
/* The base address byte offset for the start of the ALT_LWH2F_ID component. */
140
#define ALT_LWH2F_ID_OFST 0x1000
141
/* The start address of the ALT_LWH2F_ID component. */
142
#define ALT_LWH2F_ID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ADDR) + ALT_LWH2F_ID_OFST))
143
/* The lower bound address range of the ALT_LWH2F_ID component. */
144
#define ALT_LWH2F_ID_LB_ADDR ALT_LWH2F_ID_ADDR
145
/* The upper bound address range of the ALT_LWH2F_ID component. */
146
#define ALT_LWH2F_ID_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_ID_ADDR) + 0x1000) - 1))
147
148
149
150
* Register Group Instance : mastergrp
151
152
* Instance mastergrp of register group ALT_LWH2F_MST.
153
154
155
156
157
* Register Group Instance : mastergrp_fpga2hpsregs
158
159
* Instance mastergrp_fpga2hpsregs of register group ALT_LWH2F_MST_F2H.
160
161
162
163
/* The address of the ALT_LWH2F_FN_MOD_BM_ISS register for the ALT_LWH2F_MST_MST_F2H instance. */
164
#define ALT_LWH2F_MST_MST_F2H_FN_MOD_BM_ISS_ADDR ALT_LWH2F_FN_MOD_BM_ISS_ADDR(ALT_LWH2F_MST_MST_F2H_ADDR)
165
/* The address of the ALT_LWH2F_AHB_CNTL register for the ALT_LWH2F_MST_MST_F2H instance. */
166
#define ALT_LWH2F_MST_MST_F2H_AHB_CNTL_ADDR ALT_LWH2F_AHB_CNTL_ADDR(ALT_LWH2F_MST_MST_F2H_ADDR)
167
/* The base address byte offset for the start of the ALT_LWH2F_MST_MST_F2H component. */
168
#define ALT_LWH2F_MST_MST_F2H_OFST 0x0
169
/* The start address of the ALT_LWH2F_MST_MST_F2H component. */
170
#define ALT_LWH2F_MST_MST_F2H_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_MST_ADDR) + ALT_LWH2F_MST_MST_F2H_OFST))
171
/* The lower bound address range of the ALT_LWH2F_MST_MST_F2H component. */
172
#define ALT_LWH2F_MST_MST_F2H_LB_ADDR ALT_LWH2F_MST_MST_F2H_ADDR
173
/* The upper bound address range of the ALT_LWH2F_MST_MST_F2H component. */
174
#define ALT_LWH2F_MST_MST_F2H_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_MST_MST_F2H_ADDR) + 0x48) - 1))
175
176
177
178
* Register Group Instance : mastergrp_hps2fpgaregs
179
180
* Instance mastergrp_hps2fpgaregs of register group ALT_LWH2F_MST_H2F.
181
182
183
184
/* The address of the ALT_LWH2F_FN_MOD_BM_ISS register for the ALT_LWH2F_MST_MST_H2F instance. */
185
#define ALT_LWH2F_MST_MST_H2F_FN_MOD_BM_ISS_ADDR ALT_LWH2F_FN_MOD_BM_ISS_ADDR(ALT_LWH2F_MST_MST_H2F_ADDR)
186
/* The address of the ALT_LWH2F_AHB_CNTL register for the ALT_LWH2F_MST_MST_H2F instance. */
187
#define ALT_LWH2F_MST_MST_H2F_AHB_CNTL_ADDR ALT_LWH2F_AHB_CNTL_ADDR(ALT_LWH2F_MST_MST_H2F_ADDR)
188
/* The base address byte offset for the start of the ALT_LWH2F_MST_MST_H2F component. */
189
#define ALT_LWH2F_MST_MST_H2F_OFST 0x1000
190
/* The start address of the ALT_LWH2F_MST_MST_H2F component. */
191
#define ALT_LWH2F_MST_MST_H2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_MST_ADDR) + ALT_LWH2F_MST_MST_H2F_OFST))
192
/* The lower bound address range of the ALT_LWH2F_MST_MST_H2F component. */
193
#define ALT_LWH2F_MST_MST_H2F_LB_ADDR ALT_LWH2F_MST_MST_H2F_ADDR
194
/* The upper bound address range of the ALT_LWH2F_MST_MST_H2F component. */
195
#define ALT_LWH2F_MST_MST_H2F_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_MST_MST_H2F_ADDR) + 0x48) - 1))
196
197
198
199
* Register Group Instance : mastergrp_b32
200
201
* Instance mastergrp_b32 of register group ALT_LWH2F_MST_B32.
202
203
204
205
/* The address of the ALT_LWH2F_FN_MOD_BM_ISS register for the ALT_LWH2F_MST_MST_B32 instance. */
206
#define ALT_LWH2F_MST_MST_B32_FN_MOD_BM_ISS_ADDR ALT_LWH2F_FN_MOD_BM_ISS_ADDR(ALT_LWH2F_MST_MST_B32_ADDR)
207
/* The address of the ALT_LWH2F_WR_TIDEMARK register for the ALT_LWH2F_MST_MST_B32 instance. */
208
#define ALT_LWH2F_MST_MST_B32_WR_TIDEMARK_ADDR ALT_LWH2F_WR_TIDEMARK_ADDR(ALT_LWH2F_MST_MST_B32_ADDR)
209
/* The address of the ALT_LWH2F_FN_MOD register for the ALT_LWH2F_MST_MST_B32 instance. */
210
#define ALT_LWH2F_MST_MST_B32_FN_MOD_ADDR ALT_LWH2F_FN_MOD_ADDR(ALT_LWH2F_MST_MST_B32_ADDR)
211
/* The base address byte offset for the start of the ALT_LWH2F_MST_MST_B32 component. */
212
#define ALT_LWH2F_MST_MST_B32_OFST 0x3000
213
/* The start address of the ALT_LWH2F_MST_MST_B32 component. */
214
#define ALT_LWH2F_MST_MST_B32_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_MST_ADDR) + ALT_LWH2F_MST_MST_B32_OFST))
215
/* The lower bound address range of the ALT_LWH2F_MST_MST_B32 component. */
216
#define ALT_LWH2F_MST_MST_B32_LB_ADDR ALT_LWH2F_MST_MST_B32_ADDR
217
/* The upper bound address range of the ALT_LWH2F_MST_MST_B32 component. */
218
#define ALT_LWH2F_MST_MST_B32_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_MST_MST_B32_ADDR) + 0x10c) - 1))
219
220
221
/* The base address byte offset for the start of the ALT_LWH2F_MST component. */
222
#define ALT_LWH2F_MST_OFST 0x2000
223
/* The start address of the ALT_LWH2F_MST component. */
224
#define ALT_LWH2F_MST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ADDR) + ALT_LWH2F_MST_OFST))
225
/* The lower bound address range of the ALT_LWH2F_MST component. */
226
#define ALT_LWH2F_MST_LB_ADDR ALT_LWH2F_MST_ADDR
227
/* The upper bound address range of the ALT_LWH2F_MST component. */
228
#define ALT_LWH2F_MST_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_MST_ADDR) + 0x310c) - 1))
229
230
231
232
* Register Group Instance : slavegrp
233
234
* Instance slavegrp of register group ALT_LWH2F_SLV.
235
236
237
238
239
* Register Group Instance : slavegrp_b32
240
241
* Instance slavegrp_b32 of register group ALT_LWH2F_SLV_B32.
242
243
244
245
/* The address of the ALT_LWH2F_FN_MOD register for the ALT_LWH2F_SLV_SLV_B32 instance. */
246
#define ALT_LWH2F_SLV_SLV_B32_FN_MOD_ADDR ALT_LWH2F_FN_MOD_ADDR(ALT_LWH2F_SLV_SLV_B32_ADDR)
247
/* The base address byte offset for the start of the ALT_LWH2F_SLV_SLV_B32 component. */
248
#define ALT_LWH2F_SLV_SLV_B32_OFST 0x3000
249
/* The start address of the ALT_LWH2F_SLV_SLV_B32 component. */
250
#define ALT_LWH2F_SLV_SLV_B32_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_SLV_ADDR) + ALT_LWH2F_SLV_SLV_B32_OFST))
251
/* The lower bound address range of the ALT_LWH2F_SLV_SLV_B32 component. */
252
#define ALT_LWH2F_SLV_SLV_B32_LB_ADDR ALT_LWH2F_SLV_SLV_B32_ADDR
253
/* The upper bound address range of the ALT_LWH2F_SLV_SLV_B32 component. */
254
#define ALT_LWH2F_SLV_SLV_B32_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_SLV_SLV_B32_ADDR) + 0x10c) - 1))
255
256
257
/* The base address byte offset for the start of the ALT_LWH2F_SLV component. */
258
#define ALT_LWH2F_SLV_OFST 0x42000
259
/* The start address of the ALT_LWH2F_SLV component. */
260
#define ALT_LWH2F_SLV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_LWH2F_ADDR) + ALT_LWH2F_SLV_OFST))
261
/* The lower bound address range of the ALT_LWH2F_SLV component. */
262
#define ALT_LWH2F_SLV_LB_ADDR ALT_LWH2F_SLV_ADDR
263
/* The upper bound address range of the ALT_LWH2F_SLV component. */
264
#define ALT_LWH2F_SLV_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_SLV_ADDR) + 0x310c) - 1))
265
266
267
/* The base address byte offset for the start of the ALT_LWH2F component. */
268
#define ALT_LWH2F_OFST 0xff400000
269
/* The start address of the ALT_LWH2F component. */
270
#define ALT_LWH2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_LWH2F_OFST))
271
/* The lower bound address range of the ALT_LWH2F component. */
272
#define ALT_LWH2F_LB_ADDR ALT_LWH2F_ADDR
273
/* The upper bound address range of the ALT_LWH2F component. */
274
#define ALT_LWH2F_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_LWH2F_ADDR) + 0x80000) - 1))
275
276
277
278
* Component Instance : hps2fpgaregs
279
280
* Instance hps2fpgaregs of component ALT_H2F.
281
282
283
284
285
286
287
* Instance idgrp of register group ALT_H2F_IDGRP.
288
289
290
291
/* The address of the ALT_H2F_ID_PERIPH_ID_4 register for the ALT_H2F_IDGRP instance. */
292
#define ALT_H2F_ID_PERIPH_ID_4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_PERIPH_ID_4_OFST))
293
/* The address of the ALT_H2F_ID_PERIPH_ID_0 register for the ALT_H2F_IDGRP instance. */
294
#define ALT_H2F_ID_PERIPH_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_PERIPH_ID_0_OFST))
295
/* The address of the ALT_H2F_ID_PERIPH_ID_1 register for the ALT_H2F_IDGRP instance. */
296
#define ALT_H2F_ID_PERIPH_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_PERIPH_ID_1_OFST))
297
/* The address of the ALT_H2F_ID_PERIPH_ID_2 register for the ALT_H2F_IDGRP instance. */
298
#define ALT_H2F_ID_PERIPH_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_PERIPH_ID_2_OFST))
299
/* The address of the ALT_H2F_ID_PERIPH_ID_3 register for the ALT_H2F_IDGRP instance. */
300
#define ALT_H2F_ID_PERIPH_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_PERIPH_ID_3_OFST))
301
/* The address of the ALT_H2F_ID_COMP_ID_0 register for the ALT_H2F_IDGRP instance. */
302
#define ALT_H2F_ID_COMP_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_COMP_ID_0_OFST))
303
/* The address of the ALT_H2F_ID_COMP_ID_1 register for the ALT_H2F_IDGRP instance. */
304
#define ALT_H2F_ID_COMP_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_COMP_ID_1_OFST))
305
/* The address of the ALT_H2F_ID_COMP_ID_2 register for the ALT_H2F_IDGRP instance. */
306
#define ALT_H2F_ID_COMP_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_COMP_ID_2_OFST))
307
/* The address of the ALT_H2F_ID_COMP_ID_3 register for the ALT_H2F_IDGRP instance. */
308
#define ALT_H2F_ID_COMP_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + ALT_H2F_ID_COMP_ID_3_OFST))
309
/* The base address byte offset for the start of the ALT_H2F_IDGRP component. */
310
#define ALT_H2F_IDGRP_OFST 0x1000
311
/* The start address of the ALT_H2F_IDGRP component. */
312
#define ALT_H2F_IDGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_ADDR) + ALT_H2F_IDGRP_OFST))
313
/* The lower bound address range of the ALT_H2F_IDGRP component. */
314
#define ALT_H2F_IDGRP_LB_ADDR ALT_H2F_IDGRP_ADDR
315
/* The upper bound address range of the ALT_H2F_IDGRP component. */
316
#define ALT_H2F_IDGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_H2F_IDGRP_ADDR) + 0x1000) - 1))
317
318
319
320
321
322
* Instance mastergrp of register group ALT_H2F_MSTGRP.
323
324
325
326
327
328
329
* Instance mastergrp_b32 of register group ALT_H2F_MST_B32.
330
331
332
333
/* The address of the ALT_H2F_FN_MOD2 register for the ALT_H2F_MST_MST_B32 instance. */
334
#define ALT_H2F_MST_MST_B32_FN_MOD2_ADDR ALT_H2F_FN_MOD2_ADDR(ALT_H2F_MST_MST_B32_ADDR)
335
/* The address of the ALT_H2F_FN_MOD register for the ALT_H2F_MST_MST_B32 instance. */
336
#define ALT_H2F_MST_MST_B32_FN_MOD_ADDR ALT_H2F_FN_MOD_ADDR(ALT_H2F_MST_MST_B32_ADDR)
337
/* The base address byte offset for the start of the ALT_H2F_MST_MST_B32 component. */
338
#define ALT_H2F_MST_MST_B32_OFST 0x0
339
/* The start address of the ALT_H2F_MST_MST_B32 component. */
340
#define ALT_H2F_MST_MST_B32_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_MSTGRP_ADDR) + ALT_H2F_MST_MST_B32_OFST))
341
/* The lower bound address range of the ALT_H2F_MST_MST_B32 component. */
342
#define ALT_H2F_MST_MST_B32_LB_ADDR ALT_H2F_MST_MST_B32_ADDR
343
/* The upper bound address range of the ALT_H2F_MST_MST_B32 component. */
344
#define ALT_H2F_MST_MST_B32_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_H2F_MST_MST_B32_ADDR) + 0x10c) - 1))
345
346
347
348
* Register Group Instance : mastergrp_b128
349
350
* Instance mastergrp_b128 of register group ALT_H2F_MST_B128.
351
352
353
354
/* The address of the ALT_H2F_FN_MOD2 register for the ALT_H2F_MST_MST_B128 instance. */
355
#define ALT_H2F_MST_MST_B128_FN_MOD2_ADDR ALT_H2F_FN_MOD2_ADDR(ALT_H2F_MST_MST_B128_ADDR)
356
/* The address of the ALT_H2F_FN_MOD register for the ALT_H2F_MST_MST_B128 instance. */
357
#define ALT_H2F_MST_MST_B128_FN_MOD_ADDR ALT_H2F_FN_MOD_ADDR(ALT_H2F_MST_MST_B128_ADDR)
358
/* The base address byte offset for the start of the ALT_H2F_MST_MST_B128 component. */
359
#define ALT_H2F_MST_MST_B128_OFST 0x2000
360
/* The start address of the ALT_H2F_MST_MST_B128 component. */
361
#define ALT_H2F_MST_MST_B128_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_MSTGRP_ADDR) + ALT_H2F_MST_MST_B128_OFST))
362
/* The lower bound address range of the ALT_H2F_MST_MST_B128 component. */
363
#define ALT_H2F_MST_MST_B128_LB_ADDR ALT_H2F_MST_MST_B128_ADDR
364
/* The upper bound address range of the ALT_H2F_MST_MST_B128 component. */
365
#define ALT_H2F_MST_MST_B128_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_H2F_MST_MST_B128_ADDR) + 0x10c) - 1))
366
367
368
/* The base address byte offset for the start of the ALT_H2F_MSTGRP component. */
369
#define ALT_H2F_MSTGRP_OFST 0x2000
370
/* The start address of the ALT_H2F_MSTGRP component. */
371
#define ALT_H2F_MSTGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_H2F_ADDR) + ALT_H2F_MSTGRP_OFST))
372
/* The lower bound address range of the ALT_H2F_MSTGRP component. */
373
#define ALT_H2F_MSTGRP_LB_ADDR ALT_H2F_MSTGRP_ADDR
374
/* The upper bound address range of the ALT_H2F_MSTGRP component. */
375
#define ALT_H2F_MSTGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_H2F_MSTGRP_ADDR) + 0x210c) - 1))
376
377
378
/* The base address byte offset for the start of the ALT_H2F component. */
379
#define ALT_H2F_OFST 0xff500000
380
/* The start address of the ALT_H2F component. */
381
#define ALT_H2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_H2F_OFST))
382
/* The lower bound address range of the ALT_H2F component. */
383
#define ALT_H2F_LB_ADDR ALT_H2F_ADDR
384
/* The upper bound address range of the ALT_H2F component. */
385
#define ALT_H2F_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_H2F_ADDR) + 0x8000) - 1))
386
387
388
389
* Component Instance : fpga2hpsregs
390
391
* Instance fpga2hpsregs of component ALT_F2H.
392
393
394
395
396
397
398
* Instance idgrp of register group ALT_F2H_IDGRP.
399
400
401
402
/* The address of the ALT_F2H_ID_PERIPH_ID_4 register for the ALT_F2H_IDGRP instance. */
403
#define ALT_F2H_ID_PERIPH_ID_4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_PERIPH_ID_4_OFST))
404
/* The address of the ALT_F2H_ID_PERIPH_ID_0 register for the ALT_F2H_IDGRP instance. */
405
#define ALT_F2H_ID_PERIPH_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_PERIPH_ID_0_OFST))
406
/* The address of the ALT_F2H_ID_PERIPH_ID_1 register for the ALT_F2H_IDGRP instance. */
407
#define ALT_F2H_ID_PERIPH_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_PERIPH_ID_1_OFST))
408
/* The address of the ALT_F2H_ID_PERIPH_ID_2 register for the ALT_F2H_IDGRP instance. */
409
#define ALT_F2H_ID_PERIPH_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_PERIPH_ID_2_OFST))
410
/* The address of the ALT_F2H_ID_PERIPH_ID_3 register for the ALT_F2H_IDGRP instance. */
411
#define ALT_F2H_ID_PERIPH_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_PERIPH_ID_3_OFST))
412
/* The address of the ALT_F2H_ID_COMP_ID_0 register for the ALT_F2H_IDGRP instance. */
413
#define ALT_F2H_ID_COMP_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_COMP_ID_0_OFST))
414
/* The address of the ALT_F2H_ID_COMP_ID_1 register for the ALT_F2H_IDGRP instance. */
415
#define ALT_F2H_ID_COMP_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_COMP_ID_1_OFST))
416
/* The address of the ALT_F2H_ID_COMP_ID_2 register for the ALT_F2H_IDGRP instance. */
417
#define ALT_F2H_ID_COMP_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_COMP_ID_2_OFST))
418
/* The address of the ALT_F2H_ID_COMP_ID_3 register for the ALT_F2H_IDGRP instance. */
419
#define ALT_F2H_ID_COMP_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + ALT_F2H_ID_COMP_ID_3_OFST))
420
/* The base address byte offset for the start of the ALT_F2H_IDGRP component. */
421
#define ALT_F2H_IDGRP_OFST 0x1000
422
/* The start address of the ALT_F2H_IDGRP component. */
423
#define ALT_F2H_IDGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_ADDR) + ALT_F2H_IDGRP_OFST))
424
/* The lower bound address range of the ALT_F2H_IDGRP component. */
425
#define ALT_F2H_IDGRP_LB_ADDR ALT_F2H_IDGRP_ADDR
426
/* The upper bound address range of the ALT_F2H_IDGRP component. */
427
#define ALT_F2H_IDGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_F2H_IDGRP_ADDR) + 0x1000) - 1))
428
429
430
431
432
433
* Instance slavegrp of register group ALT_F2H_SLVGRP.
434
435
436
437
438
439
440
* Instance slavegrp_b32 of register group ALT_F2H_SLV_B32.
441
442
443
444
/* The address of the ALT_F2H_FN_MOD2 register for the ALT_F2H_SLV_SLV_B32 instance. */
445
#define ALT_F2H_SLV_SLV_B32_FN_MOD2_ADDR ALT_F2H_FN_MOD2_ADDR(ALT_F2H_SLV_SLV_B32_ADDR)
446
/* The address of the ALT_F2H_FN_MOD register for the ALT_F2H_SLV_SLV_B32 instance. */
447
#define ALT_F2H_SLV_SLV_B32_FN_MOD_ADDR ALT_F2H_FN_MOD_ADDR(ALT_F2H_SLV_SLV_B32_ADDR)
448
/* The base address byte offset for the start of the ALT_F2H_SLV_SLV_B32 component. */
449
#define ALT_F2H_SLV_SLV_B32_OFST 0x0
450
/* The start address of the ALT_F2H_SLV_SLV_B32 component. */
451
#define ALT_F2H_SLV_SLV_B32_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_SLVGRP_ADDR) + ALT_F2H_SLV_SLV_B32_OFST))
452
/* The lower bound address range of the ALT_F2H_SLV_SLV_B32 component. */
453
#define ALT_F2H_SLV_SLV_B32_LB_ADDR ALT_F2H_SLV_SLV_B32_ADDR
454
/* The upper bound address range of the ALT_F2H_SLV_SLV_B32 component. */
455
#define ALT_F2H_SLV_SLV_B32_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_F2H_SLV_SLV_B32_ADDR) + 0x10c) - 1))
456
457
458
459
* Register Group Instance : slavegrp_b128
460
461
* Instance slavegrp_b128 of register group ALT_F2H_SLV_B128.
462
463
464
465
/* The address of the ALT_F2H_FN_MOD2 register for the ALT_F2H_SLV_SLV_B128 instance. */
466
#define ALT_F2H_SLV_SLV_B128_FN_MOD2_ADDR ALT_F2H_FN_MOD2_ADDR(ALT_F2H_SLV_SLV_B128_ADDR)
467
/* The address of the ALT_F2H_FN_MOD register for the ALT_F2H_SLV_SLV_B128 instance. */
468
#define ALT_F2H_SLV_SLV_B128_FN_MOD_ADDR ALT_F2H_FN_MOD_ADDR(ALT_F2H_SLV_SLV_B128_ADDR)
469
/* The base address byte offset for the start of the ALT_F2H_SLV_SLV_B128 component. */
470
#define ALT_F2H_SLV_SLV_B128_OFST 0x2000
471
/* The start address of the ALT_F2H_SLV_SLV_B128 component. */
472
#define ALT_F2H_SLV_SLV_B128_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_SLVGRP_ADDR) + ALT_F2H_SLV_SLV_B128_OFST))
473
/* The lower bound address range of the ALT_F2H_SLV_SLV_B128 component. */
474
#define ALT_F2H_SLV_SLV_B128_LB_ADDR ALT_F2H_SLV_SLV_B128_ADDR
475
/* The upper bound address range of the ALT_F2H_SLV_SLV_B128 component. */
476
#define ALT_F2H_SLV_SLV_B128_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_F2H_SLV_SLV_B128_ADDR) + 0x10c) - 1))
477
478
479
/* The base address byte offset for the start of the ALT_F2H_SLVGRP component. */
480
#define ALT_F2H_SLVGRP_OFST 0x42000
481
/* The start address of the ALT_F2H_SLVGRP component. */
482
#define ALT_F2H_SLVGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_F2H_ADDR) + ALT_F2H_SLVGRP_OFST))
483
/* The lower bound address range of the ALT_F2H_SLVGRP component. */
484
#define ALT_F2H_SLVGRP_LB_ADDR ALT_F2H_SLVGRP_ADDR
485
/* The upper bound address range of the ALT_F2H_SLVGRP component. */
486
#define ALT_F2H_SLVGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_F2H_SLVGRP_ADDR) + 0x210c) - 1))
487
488
489
/* The base address byte offset for the start of the ALT_F2H component. */
490
#define ALT_F2H_OFST 0xff600000
491
/* The start address of the ALT_F2H component. */
492
#define ALT_F2H_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_F2H_OFST))
493
/* The lower bound address range of the ALT_F2H component. */
494
#define ALT_F2H_LB_ADDR ALT_F2H_ADDR
495
/* The upper bound address range of the ALT_F2H component. */
496
#define ALT_F2H_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_F2H_ADDR) + 0x80000) - 1))
497
498
499
500
* Component Instance : emac0
501
502
* Instance emac0 of component ALT_EMAC.
503
504
505
506
507
* Register Group Instance : gmacgrp
508
509
* Instance gmacgrp of register group ALT_EMAC_GMAC.
510
511
512
513
/* The address of the ALT_EMAC_GMAC_MAC_CFG register for the ALT_EMAC0_GMACGRP instance. */
514
#define ALT_EMAC0_GMAC_MAC_CFG_ADDR ALT_EMAC_GMAC_MAC_CFG_ADDR(ALT_EMAC0_GMACGRP_ADDR)
515
/* The address of the ALT_EMAC_GMAC_MAC_FRM_FLT register for the ALT_EMAC0_GMACGRP instance. */
516
#define ALT_EMAC0_GMAC_MAC_FRM_FLT_ADDR ALT_EMAC_GMAC_MAC_FRM_FLT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
517
/* The address of the ALT_EMAC_GMAC_GMII_ADDR register for the ALT_EMAC0_GMACGRP instance. */
518
#define ALT_EMAC0_GMAC_GMII_ADDR_ADDR ALT_EMAC_GMAC_GMII_ADDR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
519
/* The address of the ALT_EMAC_GMAC_GMII_DATA register for the ALT_EMAC0_GMACGRP instance. */
520
#define ALT_EMAC0_GMAC_GMII_DATA_ADDR ALT_EMAC_GMAC_GMII_DATA_ADDR(ALT_EMAC0_GMACGRP_ADDR)
521
/* The address of the ALT_EMAC_GMAC_FLOW_CTL register for the ALT_EMAC0_GMACGRP instance. */
522
#define ALT_EMAC0_GMAC_FLOW_CTL_ADDR ALT_EMAC_GMAC_FLOW_CTL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
523
/* The address of the ALT_EMAC_GMAC_VLAN_TAG register for the ALT_EMAC0_GMACGRP instance. */
524
#define ALT_EMAC0_GMAC_VLAN_TAG_ADDR ALT_EMAC_GMAC_VLAN_TAG_ADDR(ALT_EMAC0_GMACGRP_ADDR)
525
/* The address of the ALT_EMAC_GMAC_VER register for the ALT_EMAC0_GMACGRP instance. */
526
#define ALT_EMAC0_GMAC_VER_ADDR ALT_EMAC_GMAC_VER_ADDR(ALT_EMAC0_GMACGRP_ADDR)
527
/* The address of the ALT_EMAC_GMAC_DBG register for the ALT_EMAC0_GMACGRP instance. */
528
#define ALT_EMAC0_GMAC_DBG_ADDR ALT_EMAC_GMAC_DBG_ADDR(ALT_EMAC0_GMACGRP_ADDR)
529
/* The address of the ALT_EMAC_GMAC_LPI_CTL_STAT register for the ALT_EMAC0_GMACGRP instance. */
530
#define ALT_EMAC0_GMAC_LPI_CTL_STAT_ADDR ALT_EMAC_GMAC_LPI_CTL_STAT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
531
/* The address of the ALT_EMAC_GMAC_LPI_TMRS_CTL register for the ALT_EMAC0_GMACGRP instance. */
532
#define ALT_EMAC0_GMAC_LPI_TMRS_CTL_ADDR ALT_EMAC_GMAC_LPI_TMRS_CTL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
533
/* The address of the ALT_EMAC_GMAC_INT_STAT register for the ALT_EMAC0_GMACGRP instance. */
534
#define ALT_EMAC0_GMAC_INT_STAT_ADDR ALT_EMAC_GMAC_INT_STAT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
535
/* The address of the ALT_EMAC_GMAC_INT_MSK register for the ALT_EMAC0_GMACGRP instance. */
536
#define ALT_EMAC0_GMAC_INT_MSK_ADDR ALT_EMAC_GMAC_INT_MSK_ADDR(ALT_EMAC0_GMACGRP_ADDR)
537
/* The address of the ALT_EMAC_GMAC_MAC_ADDR0_HIGH register for the ALT_EMAC0_GMACGRP instance. */
538
#define ALT_EMAC0_GMAC_MAC_ADDR0_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR0_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
539
/* The address of the ALT_EMAC_GMAC_MAC_ADDR0_LOW register for the ALT_EMAC0_GMACGRP instance. */
540
#define ALT_EMAC0_GMAC_MAC_ADDR0_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR0_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
541
/* The address of the ALT_EMAC_GMAC_MAC_ADDR1_HIGH register for the ALT_EMAC0_GMACGRP instance. */
542
#define ALT_EMAC0_GMAC_MAC_ADDR1_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR1_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
543
/* The address of the ALT_EMAC_GMAC_MAC_ADDR1_LOW register for the ALT_EMAC0_GMACGRP instance. */
544
#define ALT_EMAC0_GMAC_MAC_ADDR1_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR1_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
545
/* The address of the ALT_EMAC_GMAC_MAC_ADDR2_HIGH register for the ALT_EMAC0_GMACGRP instance. */
546
#define ALT_EMAC0_GMAC_MAC_ADDR2_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR2_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
547
/* The address of the ALT_EMAC_GMAC_MAC_ADDR2_LOW register for the ALT_EMAC0_GMACGRP instance. */
548
#define ALT_EMAC0_GMAC_MAC_ADDR2_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR2_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
549
/* The address of the ALT_EMAC_GMAC_MAC_ADDR3_HIGH register for the ALT_EMAC0_GMACGRP instance. */
550
#define ALT_EMAC0_GMAC_MAC_ADDR3_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR3_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
551
/* The address of the ALT_EMAC_GMAC_MAC_ADDR3_LOW register for the ALT_EMAC0_GMACGRP instance. */
552
#define ALT_EMAC0_GMAC_MAC_ADDR3_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR3_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
553
/* The address of the ALT_EMAC_GMAC_MAC_ADDR4_HIGH register for the ALT_EMAC0_GMACGRP instance. */
554
#define ALT_EMAC0_GMAC_MAC_ADDR4_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR4_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
555
/* The address of the ALT_EMAC_GMAC_MAC_ADDR4_LOW register for the ALT_EMAC0_GMACGRP instance. */
556
#define ALT_EMAC0_GMAC_MAC_ADDR4_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR4_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
557
/* The address of the ALT_EMAC_GMAC_MAC_ADDR5_HIGH register for the ALT_EMAC0_GMACGRP instance. */
558
#define ALT_EMAC0_GMAC_MAC_ADDR5_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR5_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
559
/* The address of the ALT_EMAC_GMAC_MAC_ADDR5_LOW register for the ALT_EMAC0_GMACGRP instance. */
560
#define ALT_EMAC0_GMAC_MAC_ADDR5_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR5_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
561
/* The address of the ALT_EMAC_GMAC_MAC_ADDR6_HIGH register for the ALT_EMAC0_GMACGRP instance. */
562
#define ALT_EMAC0_GMAC_MAC_ADDR6_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR6_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
563
/* The address of the ALT_EMAC_GMAC_MAC_ADDR6_LOW register for the ALT_EMAC0_GMACGRP instance. */
564
#define ALT_EMAC0_GMAC_MAC_ADDR6_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR6_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
565
/* The address of the ALT_EMAC_GMAC_MAC_ADDR7_HIGH register for the ALT_EMAC0_GMACGRP instance. */
566
#define ALT_EMAC0_GMAC_MAC_ADDR7_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR7_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
567
/* The address of the ALT_EMAC_GMAC_MAC_ADDR7_LOW register for the ALT_EMAC0_GMACGRP instance. */
568
#define ALT_EMAC0_GMAC_MAC_ADDR7_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR7_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
569
/* The address of the ALT_EMAC_GMAC_MAC_ADDR8_HIGH register for the ALT_EMAC0_GMACGRP instance. */
570
#define ALT_EMAC0_GMAC_MAC_ADDR8_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR8_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
571
/* The address of the ALT_EMAC_GMAC_MAC_ADDR8_LOW register for the ALT_EMAC0_GMACGRP instance. */
572
#define ALT_EMAC0_GMAC_MAC_ADDR8_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR8_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
573
/* The address of the ALT_EMAC_GMAC_MAC_ADDR9_HIGH register for the ALT_EMAC0_GMACGRP instance. */
574
#define ALT_EMAC0_GMAC_MAC_ADDR9_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR9_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
575
/* The address of the ALT_EMAC_GMAC_MAC_ADDR9_LOW register for the ALT_EMAC0_GMACGRP instance. */
576
#define ALT_EMAC0_GMAC_MAC_ADDR9_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR9_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
577
/* The address of the ALT_EMAC_GMAC_MAC_ADDR10_HIGH register for the ALT_EMAC0_GMACGRP instance. */
578
#define ALT_EMAC0_GMAC_MAC_ADDR10_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR10_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
579
/* The address of the ALT_EMAC_GMAC_MAC_ADDR10_LOW register for the ALT_EMAC0_GMACGRP instance. */
580
#define ALT_EMAC0_GMAC_MAC_ADDR10_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR10_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
581
/* The address of the ALT_EMAC_GMAC_MAC_ADDR11_HIGH register for the ALT_EMAC0_GMACGRP instance. */
582
#define ALT_EMAC0_GMAC_MAC_ADDR11_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR11_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
583
/* The address of the ALT_EMAC_GMAC_MAC_ADDR11_LOW register for the ALT_EMAC0_GMACGRP instance. */
584
#define ALT_EMAC0_GMAC_MAC_ADDR11_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR11_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
585
/* The address of the ALT_EMAC_GMAC_MAC_ADDR12_HIGH register for the ALT_EMAC0_GMACGRP instance. */
586
#define ALT_EMAC0_GMAC_MAC_ADDR12_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR12_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
587
/* The address of the ALT_EMAC_GMAC_MAC_ADDR12_LOW register for the ALT_EMAC0_GMACGRP instance. */
588
#define ALT_EMAC0_GMAC_MAC_ADDR12_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR12_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
589
/* The address of the ALT_EMAC_GMAC_MAC_ADDR13_HIGH register for the ALT_EMAC0_GMACGRP instance. */
590
#define ALT_EMAC0_GMAC_MAC_ADDR13_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR13_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
591
/* The address of the ALT_EMAC_GMAC_MAC_ADDR13_LOW register for the ALT_EMAC0_GMACGRP instance. */
592
#define ALT_EMAC0_GMAC_MAC_ADDR13_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR13_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
593
/* The address of the ALT_EMAC_GMAC_MAC_ADDR14_HIGH register for the ALT_EMAC0_GMACGRP instance. */
594
#define ALT_EMAC0_GMAC_MAC_ADDR14_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR14_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
595
/* The address of the ALT_EMAC_GMAC_MAC_ADDR14_LOW register for the ALT_EMAC0_GMACGRP instance. */
596
#define ALT_EMAC0_GMAC_MAC_ADDR14_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR14_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
597
/* The address of the ALT_EMAC_GMAC_MAC_ADDR15_HIGH register for the ALT_EMAC0_GMACGRP instance. */
598
#define ALT_EMAC0_GMAC_MAC_ADDR15_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR15_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
599
/* The address of the ALT_EMAC_GMAC_MAC_ADDR15_LOW register for the ALT_EMAC0_GMACGRP instance. */
600
#define ALT_EMAC0_GMAC_MAC_ADDR15_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR15_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
601
/* The address of the ALT_EMAC_GMAC_MII_CTL_STAT register for the ALT_EMAC0_GMACGRP instance. */
602
#define ALT_EMAC0_GMAC_SGMII_RGMII_SMII_CTL_STAT_ADDR ALT_EMAC_GMAC_MII_CTL_STAT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
603
/* The address of the ALT_EMAC_GMAC_MMC_CTL register for the ALT_EMAC0_GMACGRP instance. */
604
#define ALT_EMAC0_GMAC_MMC_CTL_ADDR ALT_EMAC_GMAC_MMC_CTL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
605
/* The address of the ALT_EMAC_GMAC_MMC_RX_INT register for the ALT_EMAC0_GMACGRP instance. */
606
#define ALT_EMAC0_GMAC_MMC_RX_INT_ADDR ALT_EMAC_GMAC_MMC_RX_INT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
607
/* The address of the ALT_EMAC_GMAC_MMC_TX_INT register for the ALT_EMAC0_GMACGRP instance. */
608
#define ALT_EMAC0_GMAC_MMC_TX_INT_ADDR ALT_EMAC_GMAC_MMC_TX_INT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
609
/* The address of the ALT_EMAC_GMAC_MMC_RX_INT_MSK register for the ALT_EMAC0_GMACGRP instance. */
610
#define ALT_EMAC0_GMAC_MMC_RX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_RX_INT_MSK_ADDR(ALT_EMAC0_GMACGRP_ADDR)
611
/* The address of the ALT_EMAC_GMAC_MMC_TX_INT_MSK register for the ALT_EMAC0_GMACGRP instance. */
612
#define ALT_EMAC0_GMAC_MMC_TX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_TX_INT_MSK_ADDR(ALT_EMAC0_GMACGRP_ADDR)
613
/* The address of the ALT_EMAC_GMAC_TXOCTETCOUNT_GB register for the ALT_EMAC0_GMACGRP instance. */
614
#define ALT_EMAC0_GMAC_TXOCTETCOUNT_GB_ADDR ALT_EMAC_GMAC_TXOCTETCOUNT_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
615
/* The address of the ALT_EMAC_GMAC_TXFRMCOUNT_GB register for the ALT_EMAC0_GMACGRP instance. */
616
#define ALT_EMAC0_GMAC_TXFRMCOUNT_GB_ADDR ALT_EMAC_GMAC_TXFRMCOUNT_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
617
/* The address of the ALT_EMAC_GMAC_TXBCASTFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
618
#define ALT_EMAC0_GMAC_TXBCASTFRMS_G_ADDR ALT_EMAC_GMAC_TXBCASTFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
619
/* The address of the ALT_EMAC_GMAC_TXMCASTFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
620
#define ALT_EMAC0_GMAC_TXMCASTFRMS_G_ADDR ALT_EMAC_GMAC_TXMCASTFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
621
/* The address of the ALT_EMAC_GMAC_TX64OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
622
#define ALT_EMAC0_GMAC_TX64OCTETS_GB_ADDR ALT_EMAC_GMAC_TX64OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
623
/* The address of the ALT_EMAC_GMAC_TX65TO127OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
624
#define ALT_EMAC0_GMAC_TX65TO127OCTETS_GB_ADDR ALT_EMAC_GMAC_TX65TO127OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
625
/* The address of the ALT_EMAC_GMAC_TX128TO255OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
626
#define ALT_EMAC0_GMAC_TX128TO255OCTETS_GB_ADDR ALT_EMAC_GMAC_TX128TO255OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
627
/* The address of the ALT_EMAC_GMAC_TX256TO511OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
628
#define ALT_EMAC0_GMAC_TX256TO511OCTETS_GB_ADDR ALT_EMAC_GMAC_TX256TO511OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
629
/* The address of the ALT_EMAC_GMAC_TX512TO1023OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
630
#define ALT_EMAC0_GMAC_TX512TO1023OCTETS_GB_ADDR ALT_EMAC_GMAC_TX512TO1023OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
631
/* The address of the ALT_EMAC_GMAC_TX1024TOMAXOCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
632
#define ALT_EMAC0_GMAC_TX1024TOMAXOCTETS_GB_ADDR ALT_EMAC_GMAC_TX1024TOMAXOCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
633
/* The address of the ALT_EMAC_GMAC_TXUNICASTFRMS_GB register for the ALT_EMAC0_GMACGRP instance. */
634
#define ALT_EMAC0_GMAC_TXUNICASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXUNICASTFRMS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
635
/* The address of the ALT_EMAC_GMAC_TXMCASTFRMS_GB register for the ALT_EMAC0_GMACGRP instance. */
636
#define ALT_EMAC0_GMAC_TXMCASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXMCASTFRMS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
637
/* The address of the ALT_EMAC_GMAC_TXBCASTFRMS_GB register for the ALT_EMAC0_GMACGRP instance. */
638
#define ALT_EMAC0_GMAC_TXBCASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXBCASTFRMS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
639
/* The address of the ALT_EMAC_GMAC_TXUNDERFLOWERROR register for the ALT_EMAC0_GMACGRP instance. */
640
#define ALT_EMAC0_GMAC_TXUNDERFLOWERROR_ADDR ALT_EMAC_GMAC_TXUNDERFLOWERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
641
/* The address of the ALT_EMAC_GMAC_TXSINGLECOL_G register for the ALT_EMAC0_GMACGRP instance. */
642
#define ALT_EMAC0_GMAC_TXSINGLECOL_G_ADDR ALT_EMAC_GMAC_TXSINGLECOL_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
643
/* The address of the ALT_EMAC_GMAC_TXMULTICOL_G register for the ALT_EMAC0_GMACGRP instance. */
644
#define ALT_EMAC0_GMAC_TXMULTICOL_G_ADDR ALT_EMAC_GMAC_TXMULTICOL_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
645
/* The address of the ALT_EMAC_GMAC_TXDEFERRED register for the ALT_EMAC0_GMACGRP instance. */
646
#define ALT_EMAC0_GMAC_TXDEFERRED_ADDR ALT_EMAC_GMAC_TXDEFERRED_ADDR(ALT_EMAC0_GMACGRP_ADDR)
647
/* The address of the ALT_EMAC_GMAC_TXLATECOL register for the ALT_EMAC0_GMACGRP instance. */
648
#define ALT_EMAC0_GMAC_TXLATECOL_ADDR ALT_EMAC_GMAC_TXLATECOL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
649
/* The address of the ALT_EMAC_GMAC_TXEXESSCOL register for the ALT_EMAC0_GMACGRP instance. */
650
#define ALT_EMAC0_GMAC_TXEXESSCOL_ADDR ALT_EMAC_GMAC_TXEXESSCOL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
651
/* The address of the ALT_EMAC_GMAC_TXCARRIERERR register for the ALT_EMAC0_GMACGRP instance. */
652
#define ALT_EMAC0_GMAC_TXCARRIERERR_ADDR ALT_EMAC_GMAC_TXCARRIERERR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
653
/* The address of the ALT_EMAC_GMAC_TXOCTETCNT register for the ALT_EMAC0_GMACGRP instance. */
654
#define ALT_EMAC0_GMAC_TXOCTETCNT_ADDR ALT_EMAC_GMAC_TXOCTETCNT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
655
/* The address of the ALT_EMAC_GMAC_TXFRMCOUNT_G register for the ALT_EMAC0_GMACGRP instance. */
656
#define ALT_EMAC0_GMAC_TXFRMCOUNT_G_ADDR ALT_EMAC_GMAC_TXFRMCOUNT_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
657
/* The address of the ALT_EMAC_GMAC_TXEXCESSDEF register for the ALT_EMAC0_GMACGRP instance. */
658
#define ALT_EMAC0_GMAC_TXEXCESSDEF_ADDR ALT_EMAC_GMAC_TXEXCESSDEF_ADDR(ALT_EMAC0_GMACGRP_ADDR)
659
/* The address of the ALT_EMAC_GMAC_TXPAUSEFRMS register for the ALT_EMAC0_GMACGRP instance. */
660
#define ALT_EMAC0_GMAC_TXPAUSEFRMS_ADDR ALT_EMAC_GMAC_TXPAUSEFRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
661
/* The address of the ALT_EMAC_GMAC_TXVLANFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
662
#define ALT_EMAC0_GMAC_TXVLANFRMS_G_ADDR ALT_EMAC_GMAC_TXVLANFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
663
/* The address of the ALT_EMAC_GMAC_TXOVERSIZE_G register for the ALT_EMAC0_GMACGRP instance. */
664
#define ALT_EMAC0_GMAC_TXOVERSIZE_G_ADDR ALT_EMAC_GMAC_TXOVERSIZE_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
665
/* The address of the ALT_EMAC_GMAC_RXFRMCOUNT_GB register for the ALT_EMAC0_GMACGRP instance. */
666
#define ALT_EMAC0_GMAC_RXFRMCOUNT_GB_ADDR ALT_EMAC_GMAC_RXFRMCOUNT_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
667
/* The address of the ALT_EMAC_GMAC_RXOCTETCOUNT_GB register for the ALT_EMAC0_GMACGRP instance. */
668
#define ALT_EMAC0_GMAC_RXOCTETCOUNT_GB_ADDR ALT_EMAC_GMAC_RXOCTETCOUNT_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
669
/* The address of the ALT_EMAC_GMAC_RXOCTETCOUNT_G register for the ALT_EMAC0_GMACGRP instance. */
670
#define ALT_EMAC0_GMAC_RXOCTETCOUNT_G_ADDR ALT_EMAC_GMAC_RXOCTETCOUNT_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
671
/* The address of the ALT_EMAC_GMAC_RXBCASTFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
672
#define ALT_EMAC0_GMAC_RXBCASTFRMS_G_ADDR ALT_EMAC_GMAC_RXBCASTFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
673
/* The address of the ALT_EMAC_GMAC_RXMCASTFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
674
#define ALT_EMAC0_GMAC_RXMCASTFRMS_G_ADDR ALT_EMAC_GMAC_RXMCASTFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
675
/* The address of the ALT_EMAC_GMAC_RXCRCERROR register for the ALT_EMAC0_GMACGRP instance. */
676
#define ALT_EMAC0_GMAC_RXCRCERROR_ADDR ALT_EMAC_GMAC_RXCRCERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
677
/* The address of the ALT_EMAC_GMAC_RXALIGNMENTERROR register for the ALT_EMAC0_GMACGRP instance. */
678
#define ALT_EMAC0_GMAC_RXALIGNMENTERROR_ADDR ALT_EMAC_GMAC_RXALIGNMENTERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
679
/* The address of the ALT_EMAC_GMAC_RXRUNTERROR register for the ALT_EMAC0_GMACGRP instance. */
680
#define ALT_EMAC0_GMAC_RXRUNTERROR_ADDR ALT_EMAC_GMAC_RXRUNTERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
681
/* The address of the ALT_EMAC_GMAC_RXJABBERERROR register for the ALT_EMAC0_GMACGRP instance. */
682
#define ALT_EMAC0_GMAC_RXJABBERERROR_ADDR ALT_EMAC_GMAC_RXJABBERERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
683
/* The address of the ALT_EMAC_GMAC_RXUNDERSIZE_G register for the ALT_EMAC0_GMACGRP instance. */
684
#define ALT_EMAC0_GMAC_RXUNDERSIZE_G_ADDR ALT_EMAC_GMAC_RXUNDERSIZE_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
685
/* The address of the ALT_EMAC_GMAC_RXOVERSIZE_G register for the ALT_EMAC0_GMACGRP instance. */
686
#define ALT_EMAC0_GMAC_RXOVERSIZE_G_ADDR ALT_EMAC_GMAC_RXOVERSIZE_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
687
/* The address of the ALT_EMAC_GMAC_RX64OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
688
#define ALT_EMAC0_GMAC_RX64OCTETS_GB_ADDR ALT_EMAC_GMAC_RX64OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
689
/* The address of the ALT_EMAC_GMAC_RX65TO127OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
690
#define ALT_EMAC0_GMAC_RX65TO127OCTETS_GB_ADDR ALT_EMAC_GMAC_RX65TO127OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
691
/* The address of the ALT_EMAC_GMAC_RX128TO255OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
692
#define ALT_EMAC0_GMAC_RX128TO255OCTETS_GB_ADDR ALT_EMAC_GMAC_RX128TO255OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
693
/* The address of the ALT_EMAC_GMAC_RX256TO511OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
694
#define ALT_EMAC0_GMAC_RX256TO511OCTETS_GB_ADDR ALT_EMAC_GMAC_RX256TO511OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
695
/* The address of the ALT_EMAC_GMAC_RX512TO1023OCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
696
#define ALT_EMAC0_GMAC_RX512TO1023OCTETS_GB_ADDR ALT_EMAC_GMAC_RX512TO1023OCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
697
/* The address of the ALT_EMAC_GMAC_RX1024TOMAXOCTETS_GB register for the ALT_EMAC0_GMACGRP instance. */
698
#define ALT_EMAC0_GMAC_RX1024TOMAXOCTETS_GB_ADDR ALT_EMAC_GMAC_RX1024TOMAXOCTETS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
699
/* The address of the ALT_EMAC_GMAC_RXUNICASTFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
700
#define ALT_EMAC0_GMAC_RXUNICASTFRMS_G_ADDR ALT_EMAC_GMAC_RXUNICASTFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
701
/* The address of the ALT_EMAC_GMAC_RXLENERROR register for the ALT_EMAC0_GMACGRP instance. */
702
#define ALT_EMAC0_GMAC_RXLENERROR_ADDR ALT_EMAC_GMAC_RXLENERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
703
/* The address of the ALT_EMAC_GMAC_RXOUTOFRANGETYPE register for the ALT_EMAC0_GMACGRP instance. */
704
#define ALT_EMAC0_GMAC_RXOUTOFRANGETYPE_ADDR ALT_EMAC_GMAC_RXOUTOFRANGETYPE_ADDR(ALT_EMAC0_GMACGRP_ADDR)
705
/* The address of the ALT_EMAC_GMAC_RXPAUSEFRMS register for the ALT_EMAC0_GMACGRP instance. */
706
#define ALT_EMAC0_GMAC_RXPAUSEFRMS_ADDR ALT_EMAC_GMAC_RXPAUSEFRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
707
/* The address of the ALT_EMAC_GMAC_RXFIFOOVF register for the ALT_EMAC0_GMACGRP instance. */
708
#define ALT_EMAC0_GMAC_RXFIFOOVF_ADDR ALT_EMAC_GMAC_RXFIFOOVF_ADDR(ALT_EMAC0_GMACGRP_ADDR)
709
/* The address of the ALT_EMAC_GMAC_RXVLANFRMS_GB register for the ALT_EMAC0_GMACGRP instance. */
710
#define ALT_EMAC0_GMAC_RXVLANFRMS_GB_ADDR ALT_EMAC_GMAC_RXVLANFRMS_GB_ADDR(ALT_EMAC0_GMACGRP_ADDR)
711
/* The address of the ALT_EMAC_GMAC_RXWDERROR register for the ALT_EMAC0_GMACGRP instance. */
712
#define ALT_EMAC0_GMAC_RXWDERROR_ADDR ALT_EMAC_GMAC_RXWDERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
713
/* The address of the ALT_EMAC_GMAC_RXRCVERROR register for the ALT_EMAC0_GMACGRP instance. */
714
#define ALT_EMAC0_GMAC_RXRCVERROR_ADDR ALT_EMAC_GMAC_RXRCVERROR_ADDR(ALT_EMAC0_GMACGRP_ADDR)
715
/* The address of the ALT_EMAC_GMAC_RXCTLFRMS_G register for the ALT_EMAC0_GMACGRP instance. */
716
#define ALT_EMAC0_GMAC_RXCTLFRMS_G_ADDR ALT_EMAC_GMAC_RXCTLFRMS_G_ADDR(ALT_EMAC0_GMACGRP_ADDR)
717
/* The address of the ALT_EMAC_GMAC_MMC_IPC_RX_INT_MSK register for the ALT_EMAC0_GMACGRP instance. */
718
#define ALT_EMAC0_GMAC_MMC_IPC_RX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_IPC_RX_INT_MSK_ADDR(ALT_EMAC0_GMACGRP_ADDR)
719
/* The address of the ALT_EMAC_GMAC_MMC_IPC_RX_INT register for the ALT_EMAC0_GMACGRP instance. */
720
#define ALT_EMAC0_GMAC_MMC_IPC_RX_INT_ADDR ALT_EMAC_GMAC_MMC_IPC_RX_INT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
721
/* The address of the ALT_EMAC_GMAC_RXIPV4_GD_FRMS register for the ALT_EMAC0_GMACGRP instance. */
722
#define ALT_EMAC0_GMAC_RXIPV4_GD_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_GD_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
723
/* The address of the ALT_EMAC_GMAC_RXIPV4_HDRERR_FRMS register for the ALT_EMAC0_GMACGRP instance. */
724
#define ALT_EMAC0_GMAC_RXIPV4_HDRERR_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_HDRERR_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
725
/* The address of the ALT_EMAC_GMAC_RXIPV4_NOPAY_FRMS register for the ALT_EMAC0_GMACGRP instance. */
726
#define ALT_EMAC0_GMAC_RXIPV4_NOPAY_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_NOPAY_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
727
/* The address of the ALT_EMAC_GMAC_RXIPV4_FRAG_FRMS register for the ALT_EMAC0_GMACGRP instance. */
728
#define ALT_EMAC0_GMAC_RXIPV4_FRAG_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_FRAG_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
729
/* The address of the ALT_EMAC_GMAC_RXIPV4_UDSBL_FRMS register for the ALT_EMAC0_GMACGRP instance. */
730
#define ALT_EMAC0_GMAC_RXIPV4_UDSBL_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_UDSBL_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
731
/* The address of the ALT_EMAC_GMAC_RXIPV6_GD_FRMS register for the ALT_EMAC0_GMACGRP instance. */
732
#define ALT_EMAC0_GMAC_RXIPV6_GD_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_GD_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
733
/* The address of the ALT_EMAC_GMAC_RXIPV6_HDRERR_FRMS register for the ALT_EMAC0_GMACGRP instance. */
734
#define ALT_EMAC0_GMAC_RXIPV6_HDRERR_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_HDRERR_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
735
/* The address of the ALT_EMAC_GMAC_RXIPV6_NOPAY_FRMS register for the ALT_EMAC0_GMACGRP instance. */
736
#define ALT_EMAC0_GMAC_RXIPV6_NOPAY_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_NOPAY_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
737
/* The address of the ALT_EMAC_GMAC_RXUDP_GD_FRMS register for the ALT_EMAC0_GMACGRP instance. */
738
#define ALT_EMAC0_GMAC_RXUDP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXUDP_GD_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
739
/* The address of the ALT_EMAC_GMAC_RXUDP_ERR_FRMS register for the ALT_EMAC0_GMACGRP instance. */
740
#define ALT_EMAC0_GMAC_RXUDP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXUDP_ERR_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
741
/* The address of the ALT_EMAC_GMAC_RXTCP_GD_FRMS register for the ALT_EMAC0_GMACGRP instance. */
742
#define ALT_EMAC0_GMAC_RXTCP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXTCP_GD_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
743
/* The address of the ALT_EMAC_GMAC_RXTCP_ERR_FRMS register for the ALT_EMAC0_GMACGRP instance. */
744
#define ALT_EMAC0_GMAC_RXTCP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXTCP_ERR_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
745
/* The address of the ALT_EMAC_GMAC_RXICMP_GD_FRMS register for the ALT_EMAC0_GMACGRP instance. */
746
#define ALT_EMAC0_GMAC_RXICMP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXICMP_GD_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
747
/* The address of the ALT_EMAC_GMAC_RXICMP_ERR_FRMS register for the ALT_EMAC0_GMACGRP instance. */
748
#define ALT_EMAC0_GMAC_RXICMP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXICMP_ERR_FRMS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
749
/* The address of the ALT_EMAC_GMAC_RXIPV4_GD_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
750
#define ALT_EMAC0_GMAC_RXIPV4_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_GD_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
751
/* The address of the ALT_EMAC_GMAC_RXIPV4_HDRERR_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
752
#define ALT_EMAC0_GMAC_RXIPV4_HDRERR_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_HDRERR_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
753
/* The address of the ALT_EMAC_GMAC_RXIPV4_NOPAY_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
754
#define ALT_EMAC0_GMAC_RXIPV4_NOPAY_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_NOPAY_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
755
/* The address of the ALT_EMAC_GMAC_RXIPV4_FRAG_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
756
#define ALT_EMAC0_GMAC_RXIPV4_FRAG_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_FRAG_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
757
/* The address of the ALT_EMAC_GMAC_RXIPV4_UDSBL_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
758
#define ALT_EMAC0_GMAC_RXIPV4_UDSBL_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_UDSBL_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
759
/* The address of the ALT_EMAC_GMAC_RXIPV6_GD_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
760
#define ALT_EMAC0_GMAC_RXIPV6_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_GD_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
761
/* The address of the ALT_EMAC_GMAC_RXIPV6_HDRERR_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
762
#define ALT_EMAC0_GMAC_RXIPV6_HDRERR_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_HDRERR_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
763
/* The address of the ALT_EMAC_GMAC_RXIPV6_NOPAY_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
764
#define ALT_EMAC0_GMAC_RXIPV6_NOPAY_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_NOPAY_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
765
/* The address of the ALT_EMAC_GMAC_RXUDP_GD_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
766
#define ALT_EMAC0_GMAC_RXUDP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXUDP_GD_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
767
/* The address of the ALT_EMAC_GMAC_RXUDP_ERR_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
768
#define ALT_EMAC0_GMAC_RXUDP_ERR_OCTETS_ADDR ALT_EMAC_GMAC_RXUDP_ERR_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
769
/* The address of the ALT_EMAC_GMAC_RXTCP_GD_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
770
#define ALT_EMAC0_GMAC_RXTCP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXTCP_GD_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
771
/* The address of the ALT_EMAC_GMAC_RXTCPERROCTETS register for the ALT_EMAC0_GMACGRP instance. */
772
#define ALT_EMAC0_GMAC_RXTCPERROCTETS_ADDR ALT_EMAC_GMAC_RXTCPERROCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
773
/* The address of the ALT_EMAC_GMAC_RXICMP_GD_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
774
#define ALT_EMAC0_GMAC_RXICMP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXICMP_GD_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
775
/* The address of the ALT_EMAC_GMAC_RXICMP_ERR_OCTETS register for the ALT_EMAC0_GMACGRP instance. */
776
#define ALT_EMAC0_GMAC_RXICMP_ERR_OCTETS_ADDR ALT_EMAC_GMAC_RXICMP_ERR_OCTETS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
777
/* The address of the ALT_EMAC_GMAC_L3_L4_CTL0 register for the ALT_EMAC0_GMACGRP instance. */
778
#define ALT_EMAC0_GMAC_L3_L4_CTL0_ADDR ALT_EMAC_GMAC_L3_L4_CTL0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
779
/* The address of the ALT_EMAC_GMAC_LYR4_ADDR0 register for the ALT_EMAC0_GMACGRP instance. */
780
#define ALT_EMAC0_GMAC_LYR4_ADDR0_ADDR ALT_EMAC_GMAC_LYR4_ADDR0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
781
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG0 register for the ALT_EMAC0_GMACGRP instance. */
782
#define ALT_EMAC0_GMAC_LYR3_ADDR0_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
783
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG0 register for the ALT_EMAC0_GMACGRP instance. */
784
#define ALT_EMAC0_GMAC_LYR3_ADDR1_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
785
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG0 register for the ALT_EMAC0_GMACGRP instance. */
786
#define ALT_EMAC0_GMAC_LYR3_ADDR2_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
787
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG0 register for the ALT_EMAC0_GMACGRP instance. */
788
#define ALT_EMAC0_GMAC_LYR3_ADDR3_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
789
/* The address of the ALT_EMAC_GMAC_L3_L4_CTL1 register for the ALT_EMAC0_GMACGRP instance. */
790
#define ALT_EMAC0_GMAC_L3_L4_CTL1_ADDR ALT_EMAC_GMAC_L3_L4_CTL1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
791
/* The address of the ALT_EMAC_GMAC_LYR4_ADDR1 register for the ALT_EMAC0_GMACGRP instance. */
792
#define ALT_EMAC0_GMAC_LYR4_ADDR1_ADDR ALT_EMAC_GMAC_LYR4_ADDR1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
793
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG1 register for the ALT_EMAC0_GMACGRP instance. */
794
#define ALT_EMAC0_GMAC_LYR3_ADDR0_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
795
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG1 register for the ALT_EMAC0_GMACGRP instance. */
796
#define ALT_EMAC0_GMAC_LYR3_ADDR1_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
797
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG1 register for the ALT_EMAC0_GMACGRP instance. */
798
#define ALT_EMAC0_GMAC_LYR3_ADDR2_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
799
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG1 register for the ALT_EMAC0_GMACGRP instance. */
800
#define ALT_EMAC0_GMAC_LYR3_ADDR3_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
801
/* The address of the ALT_EMAC_GMAC_L3_L4_CTL2 register for the ALT_EMAC0_GMACGRP instance. */
802
#define ALT_EMAC0_GMAC_L3_L4_CTL2_ADDR ALT_EMAC_GMAC_L3_L4_CTL2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
803
/* The address of the ALT_EMAC_GMAC_LYR4_ADDR2 register for the ALT_EMAC0_GMACGRP instance. */
804
#define ALT_EMAC0_GMAC_LYR4_ADDR2_ADDR ALT_EMAC_GMAC_LYR4_ADDR2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
805
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG2 register for the ALT_EMAC0_GMACGRP instance. */
806
#define ALT_EMAC0_GMAC_LYR3_ADDR0_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
807
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG2 register for the ALT_EMAC0_GMACGRP instance. */
808
#define ALT_EMAC0_GMAC_LYR3_ADDR1_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
809
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG2 register for the ALT_EMAC0_GMACGRP instance. */
810
#define ALT_EMAC0_GMAC_LYR3_ADDR2_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
811
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG2 register for the ALT_EMAC0_GMACGRP instance. */
812
#define ALT_EMAC0_GMAC_LYR3_ADDR3_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
813
/* The address of the ALT_EMAC_GMAC_L3_L4_CTL3 register for the ALT_EMAC0_GMACGRP instance. */
814
#define ALT_EMAC0_GMAC_L3_L4_CTL3_ADDR ALT_EMAC_GMAC_L3_L4_CTL3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
815
/* The address of the ALT_EMAC_GMAC_LYR4_ADDR3 register for the ALT_EMAC0_GMACGRP instance. */
816
#define ALT_EMAC0_GMAC_LYR4_ADDR3_ADDR ALT_EMAC_GMAC_LYR4_ADDR3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
817
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG3 register for the ALT_EMAC0_GMACGRP instance. */
818
#define ALT_EMAC0_GMAC_LYR3_ADDR0_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
819
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG3 register for the ALT_EMAC0_GMACGRP instance. */
820
#define ALT_EMAC0_GMAC_LYR3_ADDR1_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
821
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG3 register for the ALT_EMAC0_GMACGRP instance. */
822
#define ALT_EMAC0_GMAC_LYR3_ADDR2_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
823
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG3 register for the ALT_EMAC0_GMACGRP instance. */
824
#define ALT_EMAC0_GMAC_LYR3_ADDR3_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
825
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG0 register for the ALT_EMAC0_GMACGRP instance. */
826
#define ALT_EMAC0_GMAC_HASH_TABLE_REG0_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG0_ADDR(ALT_EMAC0_GMACGRP_ADDR)
827
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG1 register for the ALT_EMAC0_GMACGRP instance. */
828
#define ALT_EMAC0_GMAC_HASH_TABLE_REG1_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG1_ADDR(ALT_EMAC0_GMACGRP_ADDR)
829
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG2 register for the ALT_EMAC0_GMACGRP instance. */
830
#define ALT_EMAC0_GMAC_HASH_TABLE_REG2_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG2_ADDR(ALT_EMAC0_GMACGRP_ADDR)
831
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG3 register for the ALT_EMAC0_GMACGRP instance. */
832
#define ALT_EMAC0_GMAC_HASH_TABLE_REG3_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG3_ADDR(ALT_EMAC0_GMACGRP_ADDR)
833
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG4 register for the ALT_EMAC0_GMACGRP instance. */
834
#define ALT_EMAC0_GMAC_HASH_TABLE_REG4_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG4_ADDR(ALT_EMAC0_GMACGRP_ADDR)
835
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG5 register for the ALT_EMAC0_GMACGRP instance. */
836
#define ALT_EMAC0_GMAC_HASH_TABLE_REG5_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG5_ADDR(ALT_EMAC0_GMACGRP_ADDR)
837
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG6 register for the ALT_EMAC0_GMACGRP instance. */
838
#define ALT_EMAC0_GMAC_HASH_TABLE_REG6_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG6_ADDR(ALT_EMAC0_GMACGRP_ADDR)
839
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG7 register for the ALT_EMAC0_GMACGRP instance. */
840
#define ALT_EMAC0_GMAC_HASH_TABLE_REG7_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG7_ADDR(ALT_EMAC0_GMACGRP_ADDR)
841
/* The address of the ALT_EMAC_GMAC_VLAN_INCL_REG register for the ALT_EMAC0_GMACGRP instance. */
842
#define ALT_EMAC0_GMAC_VLAN_INCL_REG_ADDR ALT_EMAC_GMAC_VLAN_INCL_REG_ADDR(ALT_EMAC0_GMACGRP_ADDR)
843
/* The address of the ALT_EMAC_GMAC_VLAN_HASH_TABLE_REG register for the ALT_EMAC0_GMACGRP instance. */
844
#define ALT_EMAC0_GMAC_VLAN_HASH_TABLE_REG_ADDR ALT_EMAC_GMAC_VLAN_HASH_TABLE_REG_ADDR(ALT_EMAC0_GMACGRP_ADDR)
845
/* The address of the ALT_EMAC_GMAC_TS_CTL register for the ALT_EMAC0_GMACGRP instance. */
846
#define ALT_EMAC0_GMAC_TS_CTL_ADDR ALT_EMAC_GMAC_TS_CTL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
847
/* The address of the ALT_EMAC_GMAC_SUB_SEC_INCREMENT register for the ALT_EMAC0_GMACGRP instance. */
848
#define ALT_EMAC0_GMAC_SUB_SEC_INCREMENT_ADDR ALT_EMAC_GMAC_SUB_SEC_INCREMENT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
849
/* The address of the ALT_EMAC_GMAC_SYS_TIME_SECS register for the ALT_EMAC0_GMACGRP instance. */
850
#define ALT_EMAC0_GMAC_SYS_TIME_SECS_ADDR ALT_EMAC_GMAC_SYS_TIME_SECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
851
/* The address of the ALT_EMAC_GMAC_SYS_TIME_NANOSECS register for the ALT_EMAC0_GMACGRP instance. */
852
#define ALT_EMAC0_GMAC_SYS_TIME_NANOSECS_ADDR ALT_EMAC_GMAC_SYS_TIME_NANOSECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
853
/* The address of the ALT_EMAC_GMAC_SYS_TIME_SECS_UPDATE register for the ALT_EMAC0_GMACGRP instance. */
854
#define ALT_EMAC0_GMAC_SYS_TIME_SECS_UPDATE_ADDR ALT_EMAC_GMAC_SYS_TIME_SECS_UPDATE_ADDR(ALT_EMAC0_GMACGRP_ADDR)
855
/* The address of the ALT_EMAC_GMAC_SYS_TIME_NANOSECS_UPDATE register for the ALT_EMAC0_GMACGRP instance. */
856
#define ALT_EMAC0_GMAC_SYS_TIME_NANOSECS_UPDATE_ADDR ALT_EMAC_GMAC_SYS_TIME_NANOSECS_UPDATE_ADDR(ALT_EMAC0_GMACGRP_ADDR)
857
/* The address of the ALT_EMAC_GMAC_TS_ADDEND register for the ALT_EMAC0_GMACGRP instance. */
858
#define ALT_EMAC0_GMAC_TS_ADDEND_ADDR ALT_EMAC_GMAC_TS_ADDEND_ADDR(ALT_EMAC0_GMACGRP_ADDR)
859
/* The address of the ALT_EMAC_GMAC_TGT_TIME_SECS register for the ALT_EMAC0_GMACGRP instance. */
860
#define ALT_EMAC0_GMAC_TGT_TIME_SECS_ADDR ALT_EMAC_GMAC_TGT_TIME_SECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
861
/* The address of the ALT_EMAC_GMAC_TGT_TIME_NANOSECS register for the ALT_EMAC0_GMACGRP instance. */
862
#define ALT_EMAC0_GMAC_TGT_TIME_NANOSECS_ADDR ALT_EMAC_GMAC_TGT_TIME_NANOSECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
863
/* The address of the ALT_EMAC_GMAC_SYS_TIME_HIGHER_WORD_SECS register for the ALT_EMAC0_GMACGRP instance. */
864
#define ALT_EMAC0_GMAC_SYS_TIME_HIGHER_WORD_SECS_ADDR ALT_EMAC_GMAC_SYS_TIME_HIGHER_WORD_SECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
865
/* The address of the ALT_EMAC_GMAC_TS_STAT register for the ALT_EMAC0_GMACGRP instance. */
866
#define ALT_EMAC0_GMAC_TS_STAT_ADDR ALT_EMAC_GMAC_TS_STAT_ADDR(ALT_EMAC0_GMACGRP_ADDR)
867
/* The address of the ALT_EMAC_GMAC_PPS_CTL register for the ALT_EMAC0_GMACGRP instance. */
868
#define ALT_EMAC0_GMAC_PPS_CTL_ADDR ALT_EMAC_GMAC_PPS_CTL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
869
/* The address of the ALT_EMAC_GMAC_AUX_TS_NANOSECS register for the ALT_EMAC0_GMACGRP instance. */
870
#define ALT_EMAC0_GMAC_AUX_TS_NANOSECS_ADDR ALT_EMAC_GMAC_AUX_TS_NANOSECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
871
/* The address of the ALT_EMAC_GMAC_AUX_TS_SECS register for the ALT_EMAC0_GMACGRP instance. */
872
#define ALT_EMAC0_GMAC_AUX_TS_SECS_ADDR ALT_EMAC_GMAC_AUX_TS_SECS_ADDR(ALT_EMAC0_GMACGRP_ADDR)
873
/* The address of the ALT_EMAC_GMAC_PPS0_INTERVAL register for the ALT_EMAC0_GMACGRP instance. */
874
#define ALT_EMAC0_GMAC_PPS0_INTERVAL_ADDR ALT_EMAC_GMAC_PPS0_INTERVAL_ADDR(ALT_EMAC0_GMACGRP_ADDR)
875
/* The address of the ALT_EMAC_GMAC_PPS0_WIDTH register for the ALT_EMAC0_GMACGRP instance. */
876
#define ALT_EMAC0_GMAC_PPS0_WIDTH_ADDR ALT_EMAC_GMAC_PPS0_WIDTH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
877
/* The address of the ALT_EMAC_GMAC_MAC_ADDR16_HIGH register for the ALT_EMAC0_GMACGRP instance. */
878
#define ALT_EMAC0_GMAC_MAC_ADDR16_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR16_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
879
/* The address of the ALT_EMAC_GMAC_MAC_ADDR16_LOW register for the ALT_EMAC0_GMACGRP instance. */
880
#define ALT_EMAC0_GMAC_MAC_ADDR16_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR16_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
881
/* The address of the ALT_EMAC_GMAC_MAC_ADDR17_HIGH register for the ALT_EMAC0_GMACGRP instance. */
882
#define ALT_EMAC0_GMAC_MAC_ADDR17_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR17_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
883
/* The address of the ALT_EMAC_GMAC_MAC_ADDR17_LOW register for the ALT_EMAC0_GMACGRP instance. */
884
#define ALT_EMAC0_GMAC_MAC_ADDR17_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR17_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
885
/* The address of the ALT_EMAC_GMAC_MAC_ADDR18_HIGH register for the ALT_EMAC0_GMACGRP instance. */
886
#define ALT_EMAC0_GMAC_MAC_ADDR18_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR18_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
887
/* The address of the ALT_EMAC_GMAC_MAC_ADDR18_LOW register for the ALT_EMAC0_GMACGRP instance. */
888
#define ALT_EMAC0_GMAC_MAC_ADDR18_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR18_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
889
/* The address of the ALT_EMAC_GMAC_MAC_ADDR19_HIGH register for the ALT_EMAC0_GMACGRP instance. */
890
#define ALT_EMAC0_GMAC_MAC_ADDR19_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR19_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
891
/* The address of the ALT_EMAC_GMAC_MAC_ADDR19_LOW register for the ALT_EMAC0_GMACGRP instance. */
892
#define ALT_EMAC0_GMAC_MAC_ADDR19_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR19_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
893
/* The address of the ALT_EMAC_GMAC_MAC_ADDR20_HIGH register for the ALT_EMAC0_GMACGRP instance. */
894
#define ALT_EMAC0_GMAC_MAC_ADDR20_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR20_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
895
/* The address of the ALT_EMAC_GMAC_MAC_ADDR20_LOW register for the ALT_EMAC0_GMACGRP instance. */
896
#define ALT_EMAC0_GMAC_MAC_ADDR20_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR20_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
897
/* The address of the ALT_EMAC_GMAC_MAC_ADDR21_HIGH register for the ALT_EMAC0_GMACGRP instance. */
898
#define ALT_EMAC0_GMAC_MAC_ADDR21_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR21_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
899
/* The address of the ALT_EMAC_GMAC_MAC_ADDR21_LOW register for the ALT_EMAC0_GMACGRP instance. */
900
#define ALT_EMAC0_GMAC_MAC_ADDR21_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR21_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
901
/* The address of the ALT_EMAC_GMAC_MAC_ADDR22_HIGH register for the ALT_EMAC0_GMACGRP instance. */
902
#define ALT_EMAC0_GMAC_MAC_ADDR22_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR22_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
903
/* The address of the ALT_EMAC_GMAC_MAC_ADDR22_LOW register for the ALT_EMAC0_GMACGRP instance. */
904
#define ALT_EMAC0_GMAC_MAC_ADDR22_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR22_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
905
/* The address of the ALT_EMAC_GMAC_MAC_ADDR23_HIGH register for the ALT_EMAC0_GMACGRP instance. */
906
#define ALT_EMAC0_GMAC_MAC_ADDR23_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR23_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
907
/* The address of the ALT_EMAC_GMAC_MAC_ADDR23_LOW register for the ALT_EMAC0_GMACGRP instance. */
908
#define ALT_EMAC0_GMAC_MAC_ADDR23_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR23_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
909
/* The address of the ALT_EMAC_GMAC_MAC_ADDR24_HIGH register for the ALT_EMAC0_GMACGRP instance. */
910
#define ALT_EMAC0_GMAC_MAC_ADDR24_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR24_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
911
/* The address of the ALT_EMAC_GMAC_MAC_ADDR24_LOW register for the ALT_EMAC0_GMACGRP instance. */
912
#define ALT_EMAC0_GMAC_MAC_ADDR24_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR24_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
913
/* The address of the ALT_EMAC_GMAC_MAC_ADDR25_HIGH register for the ALT_EMAC0_GMACGRP instance. */
914
#define ALT_EMAC0_GMAC_MAC_ADDR25_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR25_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
915
/* The address of the ALT_EMAC_GMAC_MAC_ADDR25_LOW register for the ALT_EMAC0_GMACGRP instance. */
916
#define ALT_EMAC0_GMAC_MAC_ADDR25_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR25_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
917
/* The address of the ALT_EMAC_GMAC_MAC_ADDR26_HIGH register for the ALT_EMAC0_GMACGRP instance. */
918
#define ALT_EMAC0_GMAC_MAC_ADDR26_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR26_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
919
/* The address of the ALT_EMAC_GMAC_MAC_ADDR26_LOW register for the ALT_EMAC0_GMACGRP instance. */
920
#define ALT_EMAC0_GMAC_MAC_ADDR26_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR26_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
921
/* The address of the ALT_EMAC_GMAC_MAC_ADDR27_HIGH register for the ALT_EMAC0_GMACGRP instance. */
922
#define ALT_EMAC0_GMAC_MAC_ADDR27_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR27_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
923
/* The address of the ALT_EMAC_GMAC_MAC_ADDR27_LOW register for the ALT_EMAC0_GMACGRP instance. */
924
#define ALT_EMAC0_GMAC_MAC_ADDR27_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR27_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
925
/* The address of the ALT_EMAC_GMAC_MAC_ADDR28_HIGH register for the ALT_EMAC0_GMACGRP instance. */
926
#define ALT_EMAC0_GMAC_MAC_ADDR28_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR28_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
927
/* The address of the ALT_EMAC_GMAC_MAC_ADDR28_LOW register for the ALT_EMAC0_GMACGRP instance. */
928
#define ALT_EMAC0_GMAC_MAC_ADDR28_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR28_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
929
/* The address of the ALT_EMAC_GMAC_MAC_ADDR29_HIGH register for the ALT_EMAC0_GMACGRP instance. */
930
#define ALT_EMAC0_GMAC_MAC_ADDR29_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR29_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
931
/* The address of the ALT_EMAC_GMAC_MAC_ADDR29_LOW register for the ALT_EMAC0_GMACGRP instance. */
932
#define ALT_EMAC0_GMAC_MAC_ADDR29_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR29_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
933
/* The address of the ALT_EMAC_GMAC_MAC_ADDR30_HIGH register for the ALT_EMAC0_GMACGRP instance. */
934
#define ALT_EMAC0_GMAC_MAC_ADDR30_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR30_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
935
/* The address of the ALT_EMAC_GMAC_MAC_ADDR30_LOW register for the ALT_EMAC0_GMACGRP instance. */
936
#define ALT_EMAC0_GMAC_MAC_ADDR30_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR30_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
937
/* The address of the ALT_EMAC_GMAC_MAC_ADDR31_HIGH register for the ALT_EMAC0_GMACGRP instance. */
938
#define ALT_EMAC0_GMAC_MAC_ADDR31_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR31_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
939
/* The address of the ALT_EMAC_GMAC_MAC_ADDR31_LOW register for the ALT_EMAC0_GMACGRP instance. */
940
#define ALT_EMAC0_GMAC_MAC_ADDR31_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR31_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
941
/* The address of the ALT_EMAC_GMAC_MAC_ADDR32_HIGH register for the ALT_EMAC0_GMACGRP instance. */
942
#define ALT_EMAC0_GMAC_MAC_ADDR32_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR32_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
943
/* The address of the ALT_EMAC_GMAC_MAC_ADDR32_LOW register for the ALT_EMAC0_GMACGRP instance. */
944
#define ALT_EMAC0_GMAC_MAC_ADDR32_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR32_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
945
/* The address of the ALT_EMAC_GMAC_MAC_ADDR33_HIGH register for the ALT_EMAC0_GMACGRP instance. */
946
#define ALT_EMAC0_GMAC_MAC_ADDR33_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR33_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
947
/* The address of the ALT_EMAC_GMAC_MAC_ADDR33_LOW register for the ALT_EMAC0_GMACGRP instance. */
948
#define ALT_EMAC0_GMAC_MAC_ADDR33_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR33_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
949
/* The address of the ALT_EMAC_GMAC_MAC_ADDR34_HIGH register for the ALT_EMAC0_GMACGRP instance. */
950
#define ALT_EMAC0_GMAC_MAC_ADDR34_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR34_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
951
/* The address of the ALT_EMAC_GMAC_MAC_ADDR34_LOW register for the ALT_EMAC0_GMACGRP instance. */
952
#define ALT_EMAC0_GMAC_MAC_ADDR34_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR34_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
953
/* The address of the ALT_EMAC_GMAC_MAC_ADDR35_HIGH register for the ALT_EMAC0_GMACGRP instance. */
954
#define ALT_EMAC0_GMAC_MAC_ADDR35_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR35_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
955
/* The address of the ALT_EMAC_GMAC_MAC_ADDR35_LOW register for the ALT_EMAC0_GMACGRP instance. */
956
#define ALT_EMAC0_GMAC_MAC_ADDR35_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR35_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
957
/* The address of the ALT_EMAC_GMAC_MAC_ADDR36_HIGH register for the ALT_EMAC0_GMACGRP instance. */
958
#define ALT_EMAC0_GMAC_MAC_ADDR36_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR36_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
959
/* The address of the ALT_EMAC_GMAC_MAC_ADDR36_LOW register for the ALT_EMAC0_GMACGRP instance. */
960
#define ALT_EMAC0_GMAC_MAC_ADDR36_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR36_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
961
/* The address of the ALT_EMAC_GMAC_MAC_ADDR37_HIGH register for the ALT_EMAC0_GMACGRP instance. */
962
#define ALT_EMAC0_GMAC_MAC_ADDR37_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR37_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
963
/* The address of the ALT_EMAC_GMAC_MAC_ADDR37_LOW register for the ALT_EMAC0_GMACGRP instance. */
964
#define ALT_EMAC0_GMAC_MAC_ADDR37_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR37_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
965
/* The address of the ALT_EMAC_GMAC_MAC_ADDR38_HIGH register for the ALT_EMAC0_GMACGRP instance. */
966
#define ALT_EMAC0_GMAC_MAC_ADDR38_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR38_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
967
/* The address of the ALT_EMAC_GMAC_MAC_ADDR38_LOW register for the ALT_EMAC0_GMACGRP instance. */
968
#define ALT_EMAC0_GMAC_MAC_ADDR38_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR38_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
969
/* The address of the ALT_EMAC_GMAC_MAC_ADDR39_HIGH register for the ALT_EMAC0_GMACGRP instance. */
970
#define ALT_EMAC0_GMAC_MAC_ADDR39_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR39_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
971
/* The address of the ALT_EMAC_GMAC_MAC_ADDR39_LOW register for the ALT_EMAC0_GMACGRP instance. */
972
#define ALT_EMAC0_GMAC_MAC_ADDR39_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR39_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
973
/* The address of the ALT_EMAC_GMAC_MAC_ADDR40_HIGH register for the ALT_EMAC0_GMACGRP instance. */
974
#define ALT_EMAC0_GMAC_MAC_ADDR40_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR40_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
975
/* The address of the ALT_EMAC_GMAC_MAC_ADDR40_LOW register for the ALT_EMAC0_GMACGRP instance. */
976
#define ALT_EMAC0_GMAC_MAC_ADDR40_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR40_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
977
/* The address of the ALT_EMAC_GMAC_MAC_ADDR41_HIGH register for the ALT_EMAC0_GMACGRP instance. */
978
#define ALT_EMAC0_GMAC_MAC_ADDR41_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR41_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
979
/* The address of the ALT_EMAC_GMAC_MAC_ADDR41_LOW register for the ALT_EMAC0_GMACGRP instance. */
980
#define ALT_EMAC0_GMAC_MAC_ADDR41_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR41_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
981
/* The address of the ALT_EMAC_GMAC_MAC_ADDR42_HIGH register for the ALT_EMAC0_GMACGRP instance. */
982
#define ALT_EMAC0_GMAC_MAC_ADDR42_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR42_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
983
/* The address of the ALT_EMAC_GMAC_MAC_ADDR42_LOW register for the ALT_EMAC0_GMACGRP instance. */
984
#define ALT_EMAC0_GMAC_MAC_ADDR42_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR42_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
985
/* The address of the ALT_EMAC_GMAC_MAC_ADDR43_HIGH register for the ALT_EMAC0_GMACGRP instance. */
986
#define ALT_EMAC0_GMAC_MAC_ADDR43_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR43_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
987
/* The address of the ALT_EMAC_GMAC_MAC_ADDR43_LOW register for the ALT_EMAC0_GMACGRP instance. */
988
#define ALT_EMAC0_GMAC_MAC_ADDR43_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR43_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
989
/* The address of the ALT_EMAC_GMAC_MAC_ADDR44_HIGH register for the ALT_EMAC0_GMACGRP instance. */
990
#define ALT_EMAC0_GMAC_MAC_ADDR44_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR44_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
991
/* The address of the ALT_EMAC_GMAC_MAC_ADDR44_LOW register for the ALT_EMAC0_GMACGRP instance. */
992
#define ALT_EMAC0_GMAC_MAC_ADDR44_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR44_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
993
/* The address of the ALT_EMAC_GMAC_MAC_ADDR45_HIGH register for the ALT_EMAC0_GMACGRP instance. */
994
#define ALT_EMAC0_GMAC_MAC_ADDR45_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR45_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
995
/* The address of the ALT_EMAC_GMAC_MAC_ADDR45_LOW register for the ALT_EMAC0_GMACGRP instance. */
996
#define ALT_EMAC0_GMAC_MAC_ADDR45_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR45_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
997
/* The address of the ALT_EMAC_GMAC_MAC_ADDR46_HIGH register for the ALT_EMAC0_GMACGRP instance. */
998
#define ALT_EMAC0_GMAC_MAC_ADDR46_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR46_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
999
/* The address of the ALT_EMAC_GMAC_MAC_ADDR46_LOW register for the ALT_EMAC0_GMACGRP instance. */
1000
#define ALT_EMAC0_GMAC_MAC_ADDR46_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR46_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1001
/* The address of the ALT_EMAC_GMAC_MAC_ADDR47_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1002
#define ALT_EMAC0_GMAC_MAC_ADDR47_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR47_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1003
/* The address of the ALT_EMAC_GMAC_MAC_ADDR47_LOW register for the ALT_EMAC0_GMACGRP instance. */
1004
#define ALT_EMAC0_GMAC_MAC_ADDR47_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR47_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1005
/* The address of the ALT_EMAC_GMAC_MAC_ADDR48_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1006
#define ALT_EMAC0_GMAC_MAC_ADDR48_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR48_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1007
/* The address of the ALT_EMAC_GMAC_MAC_ADDR48_LOW register for the ALT_EMAC0_GMACGRP instance. */
1008
#define ALT_EMAC0_GMAC_MAC_ADDR48_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR48_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1009
/* The address of the ALT_EMAC_GMAC_MAC_ADDR49_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1010
#define ALT_EMAC0_GMAC_MAC_ADDR49_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR49_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1011
/* The address of the ALT_EMAC_GMAC_MAC_ADDR49_LOW register for the ALT_EMAC0_GMACGRP instance. */
1012
#define ALT_EMAC0_GMAC_MAC_ADDR49_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR49_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1013
/* The address of the ALT_EMAC_GMAC_MAC_ADDR50_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1014
#define ALT_EMAC0_GMAC_MAC_ADDR50_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR50_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1015
/* The address of the ALT_EMAC_GMAC_MAC_ADDR50_LOW register for the ALT_EMAC0_GMACGRP instance. */
1016
#define ALT_EMAC0_GMAC_MAC_ADDR50_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR50_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1017
/* The address of the ALT_EMAC_GMAC_MAC_ADDR51_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1018
#define ALT_EMAC0_GMAC_MAC_ADDR51_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR51_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1019
/* The address of the ALT_EMAC_GMAC_MAC_ADDR51_LOW register for the ALT_EMAC0_GMACGRP instance. */
1020
#define ALT_EMAC0_GMAC_MAC_ADDR51_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR51_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1021
/* The address of the ALT_EMAC_GMAC_MAC_ADDR52_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1022
#define ALT_EMAC0_GMAC_MAC_ADDR52_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR52_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1023
/* The address of the ALT_EMAC_GMAC_MAC_ADDR52_LOW register for the ALT_EMAC0_GMACGRP instance. */
1024
#define ALT_EMAC0_GMAC_MAC_ADDR52_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR52_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1025
/* The address of the ALT_EMAC_GMAC_MAC_ADDR53_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1026
#define ALT_EMAC0_GMAC_MAC_ADDR53_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR53_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1027
/* The address of the ALT_EMAC_GMAC_MAC_ADDR53_LOW register for the ALT_EMAC0_GMACGRP instance. */
1028
#define ALT_EMAC0_GMAC_MAC_ADDR53_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR53_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1029
/* The address of the ALT_EMAC_GMAC_MAC_ADDR54_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1030
#define ALT_EMAC0_GMAC_MAC_ADDR54_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR54_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1031
/* The address of the ALT_EMAC_GMAC_MAC_ADDR54_LOW register for the ALT_EMAC0_GMACGRP instance. */
1032
#define ALT_EMAC0_GMAC_MAC_ADDR54_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR54_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1033
/* The address of the ALT_EMAC_GMAC_MAC_ADDR55_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1034
#define ALT_EMAC0_GMAC_MAC_ADDR55_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR55_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1035
/* The address of the ALT_EMAC_GMAC_MAC_ADDR55_LOW register for the ALT_EMAC0_GMACGRP instance. */
1036
#define ALT_EMAC0_GMAC_MAC_ADDR55_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR55_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1037
/* The address of the ALT_EMAC_GMAC_MAC_ADDR56_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1038
#define ALT_EMAC0_GMAC_MAC_ADDR56_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR56_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1039
/* The address of the ALT_EMAC_GMAC_MAC_ADDR56_LOW register for the ALT_EMAC0_GMACGRP instance. */
1040
#define ALT_EMAC0_GMAC_MAC_ADDR56_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR56_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1041
/* The address of the ALT_EMAC_GMAC_MAC_ADDR57_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1042
#define ALT_EMAC0_GMAC_MAC_ADDR57_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR57_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1043
/* The address of the ALT_EMAC_GMAC_MAC_ADDR57_LOW register for the ALT_EMAC0_GMACGRP instance. */
1044
#define ALT_EMAC0_GMAC_MAC_ADDR57_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR57_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1045
/* The address of the ALT_EMAC_GMAC_MAC_ADDR58_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1046
#define ALT_EMAC0_GMAC_MAC_ADDR58_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR58_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1047
/* The address of the ALT_EMAC_GMAC_MAC_ADDR58_LOW register for the ALT_EMAC0_GMACGRP instance. */
1048
#define ALT_EMAC0_GMAC_MAC_ADDR58_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR58_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1049
/* The address of the ALT_EMAC_GMAC_MAC_ADDR59_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1050
#define ALT_EMAC0_GMAC_MAC_ADDR59_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR59_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1051
/* The address of the ALT_EMAC_GMAC_MAC_ADDR59_LOW register for the ALT_EMAC0_GMACGRP instance. */
1052
#define ALT_EMAC0_GMAC_MAC_ADDR59_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR59_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1053
/* The address of the ALT_EMAC_GMAC_MAC_ADDR60_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1054
#define ALT_EMAC0_GMAC_MAC_ADDR60_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR60_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1055
/* The address of the ALT_EMAC_GMAC_MAC_ADDR60_LOW register for the ALT_EMAC0_GMACGRP instance. */
1056
#define ALT_EMAC0_GMAC_MAC_ADDR60_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR60_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1057
/* The address of the ALT_EMAC_GMAC_MAC_ADDR61_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1058
#define ALT_EMAC0_GMAC_MAC_ADDR61_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR61_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1059
/* The address of the ALT_EMAC_GMAC_MAC_ADDR61_LOW register for the ALT_EMAC0_GMACGRP instance. */
1060
#define ALT_EMAC0_GMAC_MAC_ADDR61_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR61_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1061
/* The address of the ALT_EMAC_GMAC_MAC_ADDR62_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1062
#define ALT_EMAC0_GMAC_MAC_ADDR62_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR62_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1063
/* The address of the ALT_EMAC_GMAC_MAC_ADDR62_LOW register for the ALT_EMAC0_GMACGRP instance. */
1064
#define ALT_EMAC0_GMAC_MAC_ADDR62_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR62_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1065
/* The address of the ALT_EMAC_GMAC_MAC_ADDR63_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1066
#define ALT_EMAC0_GMAC_MAC_ADDR63_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR63_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1067
/* The address of the ALT_EMAC_GMAC_MAC_ADDR63_LOW register for the ALT_EMAC0_GMACGRP instance. */
1068
#define ALT_EMAC0_GMAC_MAC_ADDR63_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR63_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1069
/* The address of the ALT_EMAC_GMAC_MAC_ADDR64_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1070
#define ALT_EMAC0_GMAC_MAC_ADDR64_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR64_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1071
/* The address of the ALT_EMAC_GMAC_MAC_ADDR64_LOW register for the ALT_EMAC0_GMACGRP instance. */
1072
#define ALT_EMAC0_GMAC_MAC_ADDR64_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR64_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1073
/* The address of the ALT_EMAC_GMAC_MAC_ADDR65_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1074
#define ALT_EMAC0_GMAC_MAC_ADDR65_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR65_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1075
/* The address of the ALT_EMAC_GMAC_MAC_ADDR65_LOW register for the ALT_EMAC0_GMACGRP instance. */
1076
#define ALT_EMAC0_GMAC_MAC_ADDR65_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR65_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1077
/* The address of the ALT_EMAC_GMAC_MAC_ADDR66_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1078
#define ALT_EMAC0_GMAC_MAC_ADDR66_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR66_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1079
/* The address of the ALT_EMAC_GMAC_MAC_ADDR66_LOW register for the ALT_EMAC0_GMACGRP instance. */
1080
#define ALT_EMAC0_GMAC_MAC_ADDR66_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR66_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1081
/* The address of the ALT_EMAC_GMAC_MAC_ADDR67_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1082
#define ALT_EMAC0_GMAC_MAC_ADDR67_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR67_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1083
/* The address of the ALT_EMAC_GMAC_MAC_ADDR67_LOW register for the ALT_EMAC0_GMACGRP instance. */
1084
#define ALT_EMAC0_GMAC_MAC_ADDR67_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR67_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1085
/* The address of the ALT_EMAC_GMAC_MAC_ADDR68_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1086
#define ALT_EMAC0_GMAC_MAC_ADDR68_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR68_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1087
/* The address of the ALT_EMAC_GMAC_MAC_ADDR68_LOW register for the ALT_EMAC0_GMACGRP instance. */
1088
#define ALT_EMAC0_GMAC_MAC_ADDR68_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR68_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1089
/* The address of the ALT_EMAC_GMAC_MAC_ADDR69_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1090
#define ALT_EMAC0_GMAC_MAC_ADDR69_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR69_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1091
/* The address of the ALT_EMAC_GMAC_MAC_ADDR69_LOW register for the ALT_EMAC0_GMACGRP instance. */
1092
#define ALT_EMAC0_GMAC_MAC_ADDR69_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR69_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1093
/* The address of the ALT_EMAC_GMAC_MAC_ADDR70_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1094
#define ALT_EMAC0_GMAC_MAC_ADDR70_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR70_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1095
/* The address of the ALT_EMAC_GMAC_MAC_ADDR70_LOW register for the ALT_EMAC0_GMACGRP instance. */
1096
#define ALT_EMAC0_GMAC_MAC_ADDR70_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR70_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1097
/* The address of the ALT_EMAC_GMAC_MAC_ADDR71_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1098
#define ALT_EMAC0_GMAC_MAC_ADDR71_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR71_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1099
/* The address of the ALT_EMAC_GMAC_MAC_ADDR71_LOW register for the ALT_EMAC0_GMACGRP instance. */
1100
#define ALT_EMAC0_GMAC_MAC_ADDR71_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR71_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1101
/* The address of the ALT_EMAC_GMAC_MAC_ADDR72_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1102
#define ALT_EMAC0_GMAC_MAC_ADDR72_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR72_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1103
/* The address of the ALT_EMAC_GMAC_MAC_ADDR72_LOW register for the ALT_EMAC0_GMACGRP instance. */
1104
#define ALT_EMAC0_GMAC_MAC_ADDR72_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR72_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1105
/* The address of the ALT_EMAC_GMAC_MAC_ADDR73_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1106
#define ALT_EMAC0_GMAC_MAC_ADDR73_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR73_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1107
/* The address of the ALT_EMAC_GMAC_MAC_ADDR73_LOW register for the ALT_EMAC0_GMACGRP instance. */
1108
#define ALT_EMAC0_GMAC_MAC_ADDR73_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR73_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1109
/* The address of the ALT_EMAC_GMAC_MAC_ADDR74_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1110
#define ALT_EMAC0_GMAC_MAC_ADDR74_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR74_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1111
/* The address of the ALT_EMAC_GMAC_MAC_ADDR74_LOW register for the ALT_EMAC0_GMACGRP instance. */
1112
#define ALT_EMAC0_GMAC_MAC_ADDR74_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR74_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1113
/* The address of the ALT_EMAC_GMAC_MAC_ADDR75_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1114
#define ALT_EMAC0_GMAC_MAC_ADDR75_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR75_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1115
/* The address of the ALT_EMAC_GMAC_MAC_ADDR75_LOW register for the ALT_EMAC0_GMACGRP instance. */
1116
#define ALT_EMAC0_GMAC_MAC_ADDR75_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR75_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1117
/* The address of the ALT_EMAC_GMAC_MAC_ADDR76_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1118
#define ALT_EMAC0_GMAC_MAC_ADDR76_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR76_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1119
/* The address of the ALT_EMAC_GMAC_MAC_ADDR76_LOW register for the ALT_EMAC0_GMACGRP instance. */
1120
#define ALT_EMAC0_GMAC_MAC_ADDR76_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR76_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1121
/* The address of the ALT_EMAC_GMAC_MAC_ADDR77_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1122
#define ALT_EMAC0_GMAC_MAC_ADDR77_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR77_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1123
/* The address of the ALT_EMAC_GMAC_MAC_ADDR77_LOW register for the ALT_EMAC0_GMACGRP instance. */
1124
#define ALT_EMAC0_GMAC_MAC_ADDR77_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR77_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1125
/* The address of the ALT_EMAC_GMAC_MAC_ADDR78_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1126
#define ALT_EMAC0_GMAC_MAC_ADDR78_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR78_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1127
/* The address of the ALT_EMAC_GMAC_MAC_ADDR78_LOW register for the ALT_EMAC0_GMACGRP instance. */
1128
#define ALT_EMAC0_GMAC_MAC_ADDR78_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR78_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1129
/* The address of the ALT_EMAC_GMAC_MAC_ADDR79_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1130
#define ALT_EMAC0_GMAC_MAC_ADDR79_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR79_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1131
/* The address of the ALT_EMAC_GMAC_MAC_ADDR79_LOW register for the ALT_EMAC0_GMACGRP instance. */
1132
#define ALT_EMAC0_GMAC_MAC_ADDR79_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR79_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1133
/* The address of the ALT_EMAC_GMAC_MAC_ADDR80_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1134
#define ALT_EMAC0_GMAC_MAC_ADDR80_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR80_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1135
/* The address of the ALT_EMAC_GMAC_MAC_ADDR80_LOW register for the ALT_EMAC0_GMACGRP instance. */
1136
#define ALT_EMAC0_GMAC_MAC_ADDR80_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR80_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1137
/* The address of the ALT_EMAC_GMAC_MAC_ADDR81_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1138
#define ALT_EMAC0_GMAC_MAC_ADDR81_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR81_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1139
/* The address of the ALT_EMAC_GMAC_MAC_ADDR81_LOW register for the ALT_EMAC0_GMACGRP instance. */
1140
#define ALT_EMAC0_GMAC_MAC_ADDR81_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR81_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1141
/* The address of the ALT_EMAC_GMAC_MAC_ADDR82_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1142
#define ALT_EMAC0_GMAC_MAC_ADDR82_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR82_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1143
/* The address of the ALT_EMAC_GMAC_MAC_ADDR82_LOW register for the ALT_EMAC0_GMACGRP instance. */
1144
#define ALT_EMAC0_GMAC_MAC_ADDR82_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR82_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1145
/* The address of the ALT_EMAC_GMAC_MAC_ADDR83_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1146
#define ALT_EMAC0_GMAC_MAC_ADDR83_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR83_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1147
/* The address of the ALT_EMAC_GMAC_MAC_ADDR83_LOW register for the ALT_EMAC0_GMACGRP instance. */
1148
#define ALT_EMAC0_GMAC_MAC_ADDR83_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR83_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1149
/* The address of the ALT_EMAC_GMAC_MAC_ADDR84_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1150
#define ALT_EMAC0_GMAC_MAC_ADDR84_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR84_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1151
/* The address of the ALT_EMAC_GMAC_MAC_ADDR84_LOW register for the ALT_EMAC0_GMACGRP instance. */
1152
#define ALT_EMAC0_GMAC_MAC_ADDR84_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR84_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1153
/* The address of the ALT_EMAC_GMAC_MAC_ADDR85_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1154
#define ALT_EMAC0_GMAC_MAC_ADDR85_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR85_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1155
/* The address of the ALT_EMAC_GMAC_MAC_ADDR85_LOW register for the ALT_EMAC0_GMACGRP instance. */
1156
#define ALT_EMAC0_GMAC_MAC_ADDR85_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR85_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1157
/* The address of the ALT_EMAC_GMAC_MAC_ADDR86_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1158
#define ALT_EMAC0_GMAC_MAC_ADDR86_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR86_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1159
/* The address of the ALT_EMAC_GMAC_MAC_ADDR86_LOW register for the ALT_EMAC0_GMACGRP instance. */
1160
#define ALT_EMAC0_GMAC_MAC_ADDR86_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR86_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1161
/* The address of the ALT_EMAC_GMAC_MAC_ADDR87_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1162
#define ALT_EMAC0_GMAC_MAC_ADDR87_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR87_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1163
/* The address of the ALT_EMAC_GMAC_MAC_ADDR87_LOW register for the ALT_EMAC0_GMACGRP instance. */
1164
#define ALT_EMAC0_GMAC_MAC_ADDR87_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR87_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1165
/* The address of the ALT_EMAC_GMAC_MAC_ADDR88_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1166
#define ALT_EMAC0_GMAC_MAC_ADDR88_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR88_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1167
/* The address of the ALT_EMAC_GMAC_MAC_ADDR88_LOW register for the ALT_EMAC0_GMACGRP instance. */
1168
#define ALT_EMAC0_GMAC_MAC_ADDR88_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR88_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1169
/* The address of the ALT_EMAC_GMAC_MAC_ADDR89_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1170
#define ALT_EMAC0_GMAC_MAC_ADDR89_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR89_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1171
/* The address of the ALT_EMAC_GMAC_MAC_ADDR89_LOW register for the ALT_EMAC0_GMACGRP instance. */
1172
#define ALT_EMAC0_GMAC_MAC_ADDR89_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR89_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1173
/* The address of the ALT_EMAC_GMAC_MAC_ADDR90_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1174
#define ALT_EMAC0_GMAC_MAC_ADDR90_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR90_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1175
/* The address of the ALT_EMAC_GMAC_MAC_ADDR90_LOW register for the ALT_EMAC0_GMACGRP instance. */
1176
#define ALT_EMAC0_GMAC_MAC_ADDR90_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR90_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1177
/* The address of the ALT_EMAC_GMAC_MAC_ADDR91_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1178
#define ALT_EMAC0_GMAC_MAC_ADDR91_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR91_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1179
/* The address of the ALT_EMAC_GMAC_MAC_ADDR91_LOW register for the ALT_EMAC0_GMACGRP instance. */
1180
#define ALT_EMAC0_GMAC_MAC_ADDR91_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR91_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1181
/* The address of the ALT_EMAC_GMAC_MAC_ADDR92_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1182
#define ALT_EMAC0_GMAC_MAC_ADDR92_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR92_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1183
/* The address of the ALT_EMAC_GMAC_MAC_ADDR92_LOW register for the ALT_EMAC0_GMACGRP instance. */
1184
#define ALT_EMAC0_GMAC_MAC_ADDR92_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR92_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1185
/* The address of the ALT_EMAC_GMAC_MAC_ADDR93_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1186
#define ALT_EMAC0_GMAC_MAC_ADDR93_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR93_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1187
/* The address of the ALT_EMAC_GMAC_MAC_ADDR93_LOW register for the ALT_EMAC0_GMACGRP instance. */
1188
#define ALT_EMAC0_GMAC_MAC_ADDR93_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR93_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1189
/* The address of the ALT_EMAC_GMAC_MAC_ADDR94_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1190
#define ALT_EMAC0_GMAC_MAC_ADDR94_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR94_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1191
/* The address of the ALT_EMAC_GMAC_MAC_ADDR94_LOW register for the ALT_EMAC0_GMACGRP instance. */
1192
#define ALT_EMAC0_GMAC_MAC_ADDR94_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR94_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1193
/* The address of the ALT_EMAC_GMAC_MAC_ADDR95_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1194
#define ALT_EMAC0_GMAC_MAC_ADDR95_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR95_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1195
/* The address of the ALT_EMAC_GMAC_MAC_ADDR95_LOW register for the ALT_EMAC0_GMACGRP instance. */
1196
#define ALT_EMAC0_GMAC_MAC_ADDR95_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR95_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1197
/* The address of the ALT_EMAC_GMAC_MAC_ADDR96_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1198
#define ALT_EMAC0_GMAC_MAC_ADDR96_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR96_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1199
/* The address of the ALT_EMAC_GMAC_MAC_ADDR96_LOW register for the ALT_EMAC0_GMACGRP instance. */
1200
#define ALT_EMAC0_GMAC_MAC_ADDR96_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR96_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1201
/* The address of the ALT_EMAC_GMAC_MAC_ADDR97_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1202
#define ALT_EMAC0_GMAC_MAC_ADDR97_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR97_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1203
/* The address of the ALT_EMAC_GMAC_MAC_ADDR97_LOW register for the ALT_EMAC0_GMACGRP instance. */
1204
#define ALT_EMAC0_GMAC_MAC_ADDR97_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR97_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1205
/* The address of the ALT_EMAC_GMAC_MAC_ADDR98_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1206
#define ALT_EMAC0_GMAC_MAC_ADDR98_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR98_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1207
/* The address of the ALT_EMAC_GMAC_MAC_ADDR98_LOW register for the ALT_EMAC0_GMACGRP instance. */
1208
#define ALT_EMAC0_GMAC_MAC_ADDR98_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR98_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1209
/* The address of the ALT_EMAC_GMAC_MAC_ADDR99_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1210
#define ALT_EMAC0_GMAC_MAC_ADDR99_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR99_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1211
/* The address of the ALT_EMAC_GMAC_MAC_ADDR99_LOW register for the ALT_EMAC0_GMACGRP instance. */
1212
#define ALT_EMAC0_GMAC_MAC_ADDR99_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR99_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1213
/* The address of the ALT_EMAC_GMAC_MAC_ADDR100_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1214
#define ALT_EMAC0_GMAC_MAC_ADDR100_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR100_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1215
/* The address of the ALT_EMAC_GMAC_MAC_ADDR100_LOW register for the ALT_EMAC0_GMACGRP instance. */
1216
#define ALT_EMAC0_GMAC_MAC_ADDR100_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR100_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1217
/* The address of the ALT_EMAC_GMAC_MAC_ADDR101_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1218
#define ALT_EMAC0_GMAC_MAC_ADDR101_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR101_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1219
/* The address of the ALT_EMAC_GMAC_MAC_ADDR101_LOW register for the ALT_EMAC0_GMACGRP instance. */
1220
#define ALT_EMAC0_GMAC_MAC_ADDR101_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR101_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1221
/* The address of the ALT_EMAC_GMAC_MAC_ADDR102_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1222
#define ALT_EMAC0_GMAC_MAC_ADDR102_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR102_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1223
/* The address of the ALT_EMAC_GMAC_MAC_ADDR102_LOW register for the ALT_EMAC0_GMACGRP instance. */
1224
#define ALT_EMAC0_GMAC_MAC_ADDR102_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR102_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1225
/* The address of the ALT_EMAC_GMAC_MAC_ADDR103_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1226
#define ALT_EMAC0_GMAC_MAC_ADDR103_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR103_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1227
/* The address of the ALT_EMAC_GMAC_MAC_ADDR103_LOW register for the ALT_EMAC0_GMACGRP instance. */
1228
#define ALT_EMAC0_GMAC_MAC_ADDR103_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR103_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1229
/* The address of the ALT_EMAC_GMAC_MAC_ADDR104_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1230
#define ALT_EMAC0_GMAC_MAC_ADDR104_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR104_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1231
/* The address of the ALT_EMAC_GMAC_MAC_ADDR104_LOW register for the ALT_EMAC0_GMACGRP instance. */
1232
#define ALT_EMAC0_GMAC_MAC_ADDR104_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR104_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1233
/* The address of the ALT_EMAC_GMAC_MAC_ADDR105_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1234
#define ALT_EMAC0_GMAC_MAC_ADDR105_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR105_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1235
/* The address of the ALT_EMAC_GMAC_MAC_ADDR105_LOW register for the ALT_EMAC0_GMACGRP instance. */
1236
#define ALT_EMAC0_GMAC_MAC_ADDR105_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR105_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1237
/* The address of the ALT_EMAC_GMAC_MAC_ADDR106_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1238
#define ALT_EMAC0_GMAC_MAC_ADDR106_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR106_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1239
/* The address of the ALT_EMAC_GMAC_MAC_ADDR106_LOW register for the ALT_EMAC0_GMACGRP instance. */
1240
#define ALT_EMAC0_GMAC_MAC_ADDR106_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR106_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1241
/* The address of the ALT_EMAC_GMAC_MAC_ADDR107_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1242
#define ALT_EMAC0_GMAC_MAC_ADDR107_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR107_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1243
/* The address of the ALT_EMAC_GMAC_MAC_ADDR107_LOW register for the ALT_EMAC0_GMACGRP instance. */
1244
#define ALT_EMAC0_GMAC_MAC_ADDR107_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR107_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1245
/* The address of the ALT_EMAC_GMAC_MAC_ADDR108_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1246
#define ALT_EMAC0_GMAC_MAC_ADDR108_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR108_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1247
/* The address of the ALT_EMAC_GMAC_MAC_ADDR108_LOW register for the ALT_EMAC0_GMACGRP instance. */
1248
#define ALT_EMAC0_GMAC_MAC_ADDR108_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR108_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1249
/* The address of the ALT_EMAC_GMAC_MAC_ADDR109_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1250
#define ALT_EMAC0_GMAC_MAC_ADDR109_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR109_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1251
/* The address of the ALT_EMAC_GMAC_MAC_ADDR109_LOW register for the ALT_EMAC0_GMACGRP instance. */
1252
#define ALT_EMAC0_GMAC_MAC_ADDR109_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR109_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1253
/* The address of the ALT_EMAC_GMAC_MAC_ADDR110_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1254
#define ALT_EMAC0_GMAC_MAC_ADDR110_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR110_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1255
/* The address of the ALT_EMAC_GMAC_MAC_ADDR110_LOW register for the ALT_EMAC0_GMACGRP instance. */
1256
#define ALT_EMAC0_GMAC_MAC_ADDR110_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR110_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1257
/* The address of the ALT_EMAC_GMAC_MAC_ADDR111_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1258
#define ALT_EMAC0_GMAC_MAC_ADDR111_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR111_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1259
/* The address of the ALT_EMAC_GMAC_MAC_ADDR111_LOW register for the ALT_EMAC0_GMACGRP instance. */
1260
#define ALT_EMAC0_GMAC_MAC_ADDR111_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR111_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1261
/* The address of the ALT_EMAC_GMAC_MAC_ADDR112_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1262
#define ALT_EMAC0_GMAC_MAC_ADDR112_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR112_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1263
/* The address of the ALT_EMAC_GMAC_MAC_ADDR112_LOW register for the ALT_EMAC0_GMACGRP instance. */
1264
#define ALT_EMAC0_GMAC_MAC_ADDR112_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR112_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1265
/* The address of the ALT_EMAC_GMAC_MAC_ADDR113_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1266
#define ALT_EMAC0_GMAC_MAC_ADDR113_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR113_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1267
/* The address of the ALT_EMAC_GMAC_MAC_ADDR113_LOW register for the ALT_EMAC0_GMACGRP instance. */
1268
#define ALT_EMAC0_GMAC_MAC_ADDR113_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR113_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1269
/* The address of the ALT_EMAC_GMAC_MAC_ADDR114_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1270
#define ALT_EMAC0_GMAC_MAC_ADDR114_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR114_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1271
/* The address of the ALT_EMAC_GMAC_MAC_ADDR114_LOW register for the ALT_EMAC0_GMACGRP instance. */
1272
#define ALT_EMAC0_GMAC_MAC_ADDR114_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR114_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1273
/* The address of the ALT_EMAC_GMAC_MAC_ADDR115_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1274
#define ALT_EMAC0_GMAC_MAC_ADDR115_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR115_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1275
/* The address of the ALT_EMAC_GMAC_MAC_ADDR115_LOW register for the ALT_EMAC0_GMACGRP instance. */
1276
#define ALT_EMAC0_GMAC_MAC_ADDR115_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR115_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1277
/* The address of the ALT_EMAC_GMAC_MAC_ADDR116_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1278
#define ALT_EMAC0_GMAC_MAC_ADDR116_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR116_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1279
/* The address of the ALT_EMAC_GMAC_MAC_ADDR116_LOW register for the ALT_EMAC0_GMACGRP instance. */
1280
#define ALT_EMAC0_GMAC_MAC_ADDR116_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR116_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1281
/* The address of the ALT_EMAC_GMAC_MAC_ADDR117_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1282
#define ALT_EMAC0_GMAC_MAC_ADDR117_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR117_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1283
/* The address of the ALT_EMAC_GMAC_MAC_ADDR117_LOW register for the ALT_EMAC0_GMACGRP instance. */
1284
#define ALT_EMAC0_GMAC_MAC_ADDR117_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR117_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1285
/* The address of the ALT_EMAC_GMAC_MAC_ADDR118_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1286
#define ALT_EMAC0_GMAC_MAC_ADDR118_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR118_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1287
/* The address of the ALT_EMAC_GMAC_MAC_ADDR118_LOW register for the ALT_EMAC0_GMACGRP instance. */
1288
#define ALT_EMAC0_GMAC_MAC_ADDR118_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR118_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1289
/* The address of the ALT_EMAC_GMAC_MAC_ADDR119_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1290
#define ALT_EMAC0_GMAC_MAC_ADDR119_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR119_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1291
/* The address of the ALT_EMAC_GMAC_MAC_ADDR119_LOW register for the ALT_EMAC0_GMACGRP instance. */
1292
#define ALT_EMAC0_GMAC_MAC_ADDR119_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR119_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1293
/* The address of the ALT_EMAC_GMAC_MAC_ADDR120_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1294
#define ALT_EMAC0_GMAC_MAC_ADDR120_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR120_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1295
/* The address of the ALT_EMAC_GMAC_MAC_ADDR120_LOW register for the ALT_EMAC0_GMACGRP instance. */
1296
#define ALT_EMAC0_GMAC_MAC_ADDR120_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR120_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1297
/* The address of the ALT_EMAC_GMAC_MAC_ADDR121_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1298
#define ALT_EMAC0_GMAC_MAC_ADDR121_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR121_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1299
/* The address of the ALT_EMAC_GMAC_MAC_ADDR121_LOW register for the ALT_EMAC0_GMACGRP instance. */
1300
#define ALT_EMAC0_GMAC_MAC_ADDR121_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR121_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1301
/* The address of the ALT_EMAC_GMAC_MAC_ADDR122_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1302
#define ALT_EMAC0_GMAC_MAC_ADDR122_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR122_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1303
/* The address of the ALT_EMAC_GMAC_MAC_ADDR122_LOW register for the ALT_EMAC0_GMACGRP instance. */
1304
#define ALT_EMAC0_GMAC_MAC_ADDR122_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR122_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1305
/* The address of the ALT_EMAC_GMAC_MAC_ADDR123_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1306
#define ALT_EMAC0_GMAC_MAC_ADDR123_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR123_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1307
/* The address of the ALT_EMAC_GMAC_MAC_ADDR123_LOW register for the ALT_EMAC0_GMACGRP instance. */
1308
#define ALT_EMAC0_GMAC_MAC_ADDR123_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR123_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1309
/* The address of the ALT_EMAC_GMAC_MAC_ADDR124_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1310
#define ALT_EMAC0_GMAC_MAC_ADDR124_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR124_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1311
/* The address of the ALT_EMAC_GMAC_MAC_ADDR124_LOW register for the ALT_EMAC0_GMACGRP instance. */
1312
#define ALT_EMAC0_GMAC_MAC_ADDR124_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR124_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1313
/* The address of the ALT_EMAC_GMAC_MAC_ADDR125_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1314
#define ALT_EMAC0_GMAC_MAC_ADDR125_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR125_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1315
/* The address of the ALT_EMAC_GMAC_MAC_ADDR125_LOW register for the ALT_EMAC0_GMACGRP instance. */
1316
#define ALT_EMAC0_GMAC_MAC_ADDR125_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR125_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1317
/* The address of the ALT_EMAC_GMAC_MAC_ADDR126_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1318
#define ALT_EMAC0_GMAC_MAC_ADDR126_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR126_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1319
/* The address of the ALT_EMAC_GMAC_MAC_ADDR126_LOW register for the ALT_EMAC0_GMACGRP instance. */
1320
#define ALT_EMAC0_GMAC_MAC_ADDR126_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR126_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1321
/* The address of the ALT_EMAC_GMAC_MAC_ADDR127_HIGH register for the ALT_EMAC0_GMACGRP instance. */
1322
#define ALT_EMAC0_GMAC_MAC_ADDR127_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR127_HIGH_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1323
/* The address of the ALT_EMAC_GMAC_MAC_ADDR127_LOW register for the ALT_EMAC0_GMACGRP instance. */
1324
#define ALT_EMAC0_GMAC_MAC_ADDR127_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR127_LOW_ADDR(ALT_EMAC0_GMACGRP_ADDR)
1325
/* The base address byte offset for the start of the ALT_EMAC0_GMACGRP component. */
1326
#define ALT_EMAC0_GMACGRP_OFST 0x0
1327
/* The start address of the ALT_EMAC0_GMACGRP component. */
1328
#define ALT_EMAC0_GMACGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_EMAC0_ADDR) + ALT_EMAC0_GMACGRP_OFST))
1329
/* The lower bound address range of the ALT_EMAC0_GMACGRP component. */
1330
#define ALT_EMAC0_GMACGRP_LB_ADDR ALT_EMAC0_GMACGRP_ADDR
1331
/* The upper bound address range of the ALT_EMAC0_GMACGRP component. */
1332
#define ALT_EMAC0_GMACGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC0_GMACGRP_ADDR) + 0xb80) - 1))
1333
1334
1335
1336
* Register Group Instance : dmagrp
1337
1338
* Instance dmagrp of register group ALT_EMAC_DMA.
1339
1340
1341
1342
/* The address of the ALT_EMAC_DMA_BUS_MOD register for the ALT_EMAC0_DMAGRP instance. */
1343
#define ALT_EMAC0_DMA_BUS_MOD_ADDR ALT_EMAC_DMA_BUS_MOD_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1344
/* The address of the ALT_EMAC_DMA_TX_POLL_DEMAND register for the ALT_EMAC0_DMAGRP instance. */
1345
#define ALT_EMAC0_DMA_TX_POLL_DEMAND_ADDR ALT_EMAC_DMA_TX_POLL_DEMAND_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1346
/* The address of the ALT_EMAC_DMA_RX_POLL_DEMAND register for the ALT_EMAC0_DMAGRP instance. */
1347
#define ALT_EMAC0_DMA_RX_POLL_DEMAND_ADDR ALT_EMAC_DMA_RX_POLL_DEMAND_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1348
/* The address of the ALT_EMAC_DMA_RX_DESC_LIST_ADDR register for the ALT_EMAC0_DMAGRP instance. */
1349
#define ALT_EMAC0_DMA_RX_DESC_LIST_ADDR_ADDR ALT_EMAC_DMA_RX_DESC_LIST_ADDR_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1350
/* The address of the ALT_EMAC_DMA_TX_DESC_LIST_ADDR register for the ALT_EMAC0_DMAGRP instance. */
1351
#define ALT_EMAC0_DMA_TX_DESC_LIST_ADDR_ADDR ALT_EMAC_DMA_TX_DESC_LIST_ADDR_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1352
/* The address of the ALT_EMAC_DMA_STAT register for the ALT_EMAC0_DMAGRP instance. */
1353
#define ALT_EMAC0_DMA_STAT_ADDR ALT_EMAC_DMA_STAT_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1354
/* The address of the ALT_EMAC_DMA_OP_MOD register for the ALT_EMAC0_DMAGRP instance. */
1355
#define ALT_EMAC0_DMA_OP_MOD_ADDR ALT_EMAC_DMA_OP_MOD_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1356
/* The address of the ALT_EMAC_DMA_INT_EN register for the ALT_EMAC0_DMAGRP instance. */
1357
#define ALT_EMAC0_DMA_INT_EN_ADDR ALT_EMAC_DMA_INT_EN_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1358
/* The address of the ALT_EMAC_DMA_MFRM_BUF_OVF_CNTR register for the ALT_EMAC0_DMAGRP instance. */
1359
#define ALT_EMAC0_DMA_MISSED_FRM_AND_BUF_OVF_CNTR_ADDR ALT_EMAC_DMA_MFRM_BUF_OVF_CNTR_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1360
/* The address of the ALT_EMAC_DMA_RX_INT_WDT register for the ALT_EMAC0_DMAGRP instance. */
1361
#define ALT_EMAC0_DMA_RX_INT_WDT_ADDR ALT_EMAC_DMA_RX_INT_WDT_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1362
/* The address of the ALT_EMAC_DMA_AXI_BUS_MOD register for the ALT_EMAC0_DMAGRP instance. */
1363
#define ALT_EMAC0_DMA_AXI_BUS_MOD_ADDR ALT_EMAC_DMA_AXI_BUS_MOD_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1364
/* The address of the ALT_EMAC_DMA_AHB_OR_AXI_STAT register for the ALT_EMAC0_DMAGRP instance. */
1365
#define ALT_EMAC0_DMA_AHB_OR_AXI_STAT_ADDR ALT_EMAC_DMA_AHB_OR_AXI_STAT_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1366
/* The address of the ALT_EMAC_DMA_CUR_HOST_TX_DESC register for the ALT_EMAC0_DMAGRP instance. */
1367
#define ALT_EMAC0_DMA_CUR_HOST_TX_DESC_ADDR ALT_EMAC_DMA_CUR_HOST_TX_DESC_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1368
/* The address of the ALT_EMAC_DMA_CUR_HOST_RX_DESC register for the ALT_EMAC0_DMAGRP instance. */
1369
#define ALT_EMAC0_DMA_CUR_HOST_RX_DESC_ADDR ALT_EMAC_DMA_CUR_HOST_RX_DESC_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1370
/* The address of the ALT_EMAC_DMA_CUR_HOST_TX_BUF_ADDR register for the ALT_EMAC0_DMAGRP instance. */
1371
#define ALT_EMAC0_DMA_CUR_HOST_TX_BUF_ADDR_ADDR ALT_EMAC_DMA_CUR_HOST_TX_BUF_ADDR_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1372
/* The address of the ALT_EMAC_DMA_CUR_HOST_RX_BUF_ADDR register for the ALT_EMAC0_DMAGRP instance. */
1373
#define ALT_EMAC0_DMA_CUR_HOST_RX_BUF_ADDR_ADDR ALT_EMAC_DMA_CUR_HOST_RX_BUF_ADDR_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1374
/* The address of the ALT_EMAC_DMA_HW_FEATURE register for the ALT_EMAC0_DMAGRP instance. */
1375
#define ALT_EMAC0_DMA_HW_FEATURE_ADDR ALT_EMAC_DMA_HW_FEATURE_ADDR(ALT_EMAC0_DMAGRP_ADDR)
1376
/* The base address byte offset for the start of the ALT_EMAC0_DMAGRP component. */
1377
#define ALT_EMAC0_DMAGRP_OFST 0x1000
1378
/* The start address of the ALT_EMAC0_DMAGRP component. */
1379
#define ALT_EMAC0_DMAGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_EMAC0_ADDR) + ALT_EMAC0_DMAGRP_OFST))
1380
/* The lower bound address range of the ALT_EMAC0_DMAGRP component. */
1381
#define ALT_EMAC0_DMAGRP_LB_ADDR ALT_EMAC0_DMAGRP_ADDR
1382
/* The upper bound address range of the ALT_EMAC0_DMAGRP component. */
1383
#define ALT_EMAC0_DMAGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC0_DMAGRP_ADDR) + 0x5c) - 1))
1384
1385
1386
/* The base address byte offset for the start of the ALT_EMAC0 component. */
1387
#define ALT_EMAC0_OFST 0xff700000
1388
/* The start address of the ALT_EMAC0 component. */
1389
#define ALT_EMAC0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_EMAC0_OFST))
1390
/* The lower bound address range of the ALT_EMAC0 component. */
1391
#define ALT_EMAC0_LB_ADDR ALT_EMAC0_ADDR
1392
/* The upper bound address range of the ALT_EMAC0 component. */
1393
#define ALT_EMAC0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC0_ADDR) + 0x2000) - 1))
1394
1395
1396
1397
* Component Instance : emac1
1398
1399
* Instance emac1 of component ALT_EMAC.
1400
1401
1402
1403
1404
* Register Group Instance : gmacgrp
1405
1406
* Instance gmacgrp of register group ALT_EMAC_GMAC.
1407
1408
1409
1410
/* The address of the ALT_EMAC_GMAC_MAC_CFG register for the ALT_EMAC1_GMACGRP instance. */
1411
#define ALT_EMAC1_GMAC_MAC_CFG_ADDR ALT_EMAC_GMAC_MAC_CFG_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1412
/* The address of the ALT_EMAC_GMAC_MAC_FRM_FLT register for the ALT_EMAC1_GMACGRP instance. */
1413
#define ALT_EMAC1_GMAC_MAC_FRM_FLT_ADDR ALT_EMAC_GMAC_MAC_FRM_FLT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1414
/* The address of the ALT_EMAC_GMAC_GMII_ADDR register for the ALT_EMAC1_GMACGRP instance. */
1415
#define ALT_EMAC1_GMAC_GMII_ADDR_ADDR ALT_EMAC_GMAC_GMII_ADDR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1416
/* The address of the ALT_EMAC_GMAC_GMII_DATA register for the ALT_EMAC1_GMACGRP instance. */
1417
#define ALT_EMAC1_GMAC_GMII_DATA_ADDR ALT_EMAC_GMAC_GMII_DATA_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1418
/* The address of the ALT_EMAC_GMAC_FLOW_CTL register for the ALT_EMAC1_GMACGRP instance. */
1419
#define ALT_EMAC1_GMAC_FLOW_CTL_ADDR ALT_EMAC_GMAC_FLOW_CTL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1420
/* The address of the ALT_EMAC_GMAC_VLAN_TAG register for the ALT_EMAC1_GMACGRP instance. */
1421
#define ALT_EMAC1_GMAC_VLAN_TAG_ADDR ALT_EMAC_GMAC_VLAN_TAG_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1422
/* The address of the ALT_EMAC_GMAC_VER register for the ALT_EMAC1_GMACGRP instance. */
1423
#define ALT_EMAC1_GMAC_VER_ADDR ALT_EMAC_GMAC_VER_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1424
/* The address of the ALT_EMAC_GMAC_DBG register for the ALT_EMAC1_GMACGRP instance. */
1425
#define ALT_EMAC1_GMAC_DBG_ADDR ALT_EMAC_GMAC_DBG_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1426
/* The address of the ALT_EMAC_GMAC_LPI_CTL_STAT register for the ALT_EMAC1_GMACGRP instance. */
1427
#define ALT_EMAC1_GMAC_LPI_CTL_STAT_ADDR ALT_EMAC_GMAC_LPI_CTL_STAT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1428
/* The address of the ALT_EMAC_GMAC_LPI_TMRS_CTL register for the ALT_EMAC1_GMACGRP instance. */
1429
#define ALT_EMAC1_GMAC_LPI_TMRS_CTL_ADDR ALT_EMAC_GMAC_LPI_TMRS_CTL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1430
/* The address of the ALT_EMAC_GMAC_INT_STAT register for the ALT_EMAC1_GMACGRP instance. */
1431
#define ALT_EMAC1_GMAC_INT_STAT_ADDR ALT_EMAC_GMAC_INT_STAT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1432
/* The address of the ALT_EMAC_GMAC_INT_MSK register for the ALT_EMAC1_GMACGRP instance. */
1433
#define ALT_EMAC1_GMAC_INT_MSK_ADDR ALT_EMAC_GMAC_INT_MSK_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1434
/* The address of the ALT_EMAC_GMAC_MAC_ADDR0_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1435
#define ALT_EMAC1_GMAC_MAC_ADDR0_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR0_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1436
/* The address of the ALT_EMAC_GMAC_MAC_ADDR0_LOW register for the ALT_EMAC1_GMACGRP instance. */
1437
#define ALT_EMAC1_GMAC_MAC_ADDR0_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR0_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1438
/* The address of the ALT_EMAC_GMAC_MAC_ADDR1_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1439
#define ALT_EMAC1_GMAC_MAC_ADDR1_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR1_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1440
/* The address of the ALT_EMAC_GMAC_MAC_ADDR1_LOW register for the ALT_EMAC1_GMACGRP instance. */
1441
#define ALT_EMAC1_GMAC_MAC_ADDR1_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR1_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1442
/* The address of the ALT_EMAC_GMAC_MAC_ADDR2_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1443
#define ALT_EMAC1_GMAC_MAC_ADDR2_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR2_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1444
/* The address of the ALT_EMAC_GMAC_MAC_ADDR2_LOW register for the ALT_EMAC1_GMACGRP instance. */
1445
#define ALT_EMAC1_GMAC_MAC_ADDR2_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR2_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1446
/* The address of the ALT_EMAC_GMAC_MAC_ADDR3_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1447
#define ALT_EMAC1_GMAC_MAC_ADDR3_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR3_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1448
/* The address of the ALT_EMAC_GMAC_MAC_ADDR3_LOW register for the ALT_EMAC1_GMACGRP instance. */
1449
#define ALT_EMAC1_GMAC_MAC_ADDR3_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR3_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1450
/* The address of the ALT_EMAC_GMAC_MAC_ADDR4_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1451
#define ALT_EMAC1_GMAC_MAC_ADDR4_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR4_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1452
/* The address of the ALT_EMAC_GMAC_MAC_ADDR4_LOW register for the ALT_EMAC1_GMACGRP instance. */
1453
#define ALT_EMAC1_GMAC_MAC_ADDR4_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR4_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1454
/* The address of the ALT_EMAC_GMAC_MAC_ADDR5_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1455
#define ALT_EMAC1_GMAC_MAC_ADDR5_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR5_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1456
/* The address of the ALT_EMAC_GMAC_MAC_ADDR5_LOW register for the ALT_EMAC1_GMACGRP instance. */
1457
#define ALT_EMAC1_GMAC_MAC_ADDR5_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR5_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1458
/* The address of the ALT_EMAC_GMAC_MAC_ADDR6_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1459
#define ALT_EMAC1_GMAC_MAC_ADDR6_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR6_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1460
/* The address of the ALT_EMAC_GMAC_MAC_ADDR6_LOW register for the ALT_EMAC1_GMACGRP instance. */
1461
#define ALT_EMAC1_GMAC_MAC_ADDR6_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR6_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1462
/* The address of the ALT_EMAC_GMAC_MAC_ADDR7_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1463
#define ALT_EMAC1_GMAC_MAC_ADDR7_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR7_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1464
/* The address of the ALT_EMAC_GMAC_MAC_ADDR7_LOW register for the ALT_EMAC1_GMACGRP instance. */
1465
#define ALT_EMAC1_GMAC_MAC_ADDR7_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR7_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1466
/* The address of the ALT_EMAC_GMAC_MAC_ADDR8_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1467
#define ALT_EMAC1_GMAC_MAC_ADDR8_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR8_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1468
/* The address of the ALT_EMAC_GMAC_MAC_ADDR8_LOW register for the ALT_EMAC1_GMACGRP instance. */
1469
#define ALT_EMAC1_GMAC_MAC_ADDR8_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR8_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1470
/* The address of the ALT_EMAC_GMAC_MAC_ADDR9_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1471
#define ALT_EMAC1_GMAC_MAC_ADDR9_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR9_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1472
/* The address of the ALT_EMAC_GMAC_MAC_ADDR9_LOW register for the ALT_EMAC1_GMACGRP instance. */
1473
#define ALT_EMAC1_GMAC_MAC_ADDR9_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR9_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1474
/* The address of the ALT_EMAC_GMAC_MAC_ADDR10_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1475
#define ALT_EMAC1_GMAC_MAC_ADDR10_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR10_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1476
/* The address of the ALT_EMAC_GMAC_MAC_ADDR10_LOW register for the ALT_EMAC1_GMACGRP instance. */
1477
#define ALT_EMAC1_GMAC_MAC_ADDR10_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR10_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1478
/* The address of the ALT_EMAC_GMAC_MAC_ADDR11_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1479
#define ALT_EMAC1_GMAC_MAC_ADDR11_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR11_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1480
/* The address of the ALT_EMAC_GMAC_MAC_ADDR11_LOW register for the ALT_EMAC1_GMACGRP instance. */
1481
#define ALT_EMAC1_GMAC_MAC_ADDR11_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR11_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1482
/* The address of the ALT_EMAC_GMAC_MAC_ADDR12_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1483
#define ALT_EMAC1_GMAC_MAC_ADDR12_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR12_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1484
/* The address of the ALT_EMAC_GMAC_MAC_ADDR12_LOW register for the ALT_EMAC1_GMACGRP instance. */
1485
#define ALT_EMAC1_GMAC_MAC_ADDR12_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR12_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1486
/* The address of the ALT_EMAC_GMAC_MAC_ADDR13_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1487
#define ALT_EMAC1_GMAC_MAC_ADDR13_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR13_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1488
/* The address of the ALT_EMAC_GMAC_MAC_ADDR13_LOW register for the ALT_EMAC1_GMACGRP instance. */
1489
#define ALT_EMAC1_GMAC_MAC_ADDR13_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR13_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1490
/* The address of the ALT_EMAC_GMAC_MAC_ADDR14_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1491
#define ALT_EMAC1_GMAC_MAC_ADDR14_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR14_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1492
/* The address of the ALT_EMAC_GMAC_MAC_ADDR14_LOW register for the ALT_EMAC1_GMACGRP instance. */
1493
#define ALT_EMAC1_GMAC_MAC_ADDR14_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR14_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1494
/* The address of the ALT_EMAC_GMAC_MAC_ADDR15_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1495
#define ALT_EMAC1_GMAC_MAC_ADDR15_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR15_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1496
/* The address of the ALT_EMAC_GMAC_MAC_ADDR15_LOW register for the ALT_EMAC1_GMACGRP instance. */
1497
#define ALT_EMAC1_GMAC_MAC_ADDR15_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR15_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1498
/* The address of the ALT_EMAC_GMAC_MII_CTL_STAT register for the ALT_EMAC1_GMACGRP instance. */
1499
#define ALT_EMAC1_GMAC_SGMII_RGMII_SMII_CTL_STAT_ADDR ALT_EMAC_GMAC_MII_CTL_STAT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1500
/* The address of the ALT_EMAC_GMAC_MMC_CTL register for the ALT_EMAC1_GMACGRP instance. */
1501
#define ALT_EMAC1_GMAC_MMC_CTL_ADDR ALT_EMAC_GMAC_MMC_CTL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1502
/* The address of the ALT_EMAC_GMAC_MMC_RX_INT register for the ALT_EMAC1_GMACGRP instance. */
1503
#define ALT_EMAC1_GMAC_MMC_RX_INT_ADDR ALT_EMAC_GMAC_MMC_RX_INT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1504
/* The address of the ALT_EMAC_GMAC_MMC_TX_INT register for the ALT_EMAC1_GMACGRP instance. */
1505
#define ALT_EMAC1_GMAC_MMC_TX_INT_ADDR ALT_EMAC_GMAC_MMC_TX_INT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1506
/* The address of the ALT_EMAC_GMAC_MMC_RX_INT_MSK register for the ALT_EMAC1_GMACGRP instance. */
1507
#define ALT_EMAC1_GMAC_MMC_RX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_RX_INT_MSK_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1508
/* The address of the ALT_EMAC_GMAC_MMC_TX_INT_MSK register for the ALT_EMAC1_GMACGRP instance. */
1509
#define ALT_EMAC1_GMAC_MMC_TX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_TX_INT_MSK_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1510
/* The address of the ALT_EMAC_GMAC_TXOCTETCOUNT_GB register for the ALT_EMAC1_GMACGRP instance. */
1511
#define ALT_EMAC1_GMAC_TXOCTETCOUNT_GB_ADDR ALT_EMAC_GMAC_TXOCTETCOUNT_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1512
/* The address of the ALT_EMAC_GMAC_TXFRMCOUNT_GB register for the ALT_EMAC1_GMACGRP instance. */
1513
#define ALT_EMAC1_GMAC_TXFRMCOUNT_GB_ADDR ALT_EMAC_GMAC_TXFRMCOUNT_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1514
/* The address of the ALT_EMAC_GMAC_TXBCASTFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1515
#define ALT_EMAC1_GMAC_TXBCASTFRMS_G_ADDR ALT_EMAC_GMAC_TXBCASTFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1516
/* The address of the ALT_EMAC_GMAC_TXMCASTFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1517
#define ALT_EMAC1_GMAC_TXMCASTFRMS_G_ADDR ALT_EMAC_GMAC_TXMCASTFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1518
/* The address of the ALT_EMAC_GMAC_TX64OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1519
#define ALT_EMAC1_GMAC_TX64OCTETS_GB_ADDR ALT_EMAC_GMAC_TX64OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1520
/* The address of the ALT_EMAC_GMAC_TX65TO127OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1521
#define ALT_EMAC1_GMAC_TX65TO127OCTETS_GB_ADDR ALT_EMAC_GMAC_TX65TO127OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1522
/* The address of the ALT_EMAC_GMAC_TX128TO255OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1523
#define ALT_EMAC1_GMAC_TX128TO255OCTETS_GB_ADDR ALT_EMAC_GMAC_TX128TO255OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1524
/* The address of the ALT_EMAC_GMAC_TX256TO511OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1525
#define ALT_EMAC1_GMAC_TX256TO511OCTETS_GB_ADDR ALT_EMAC_GMAC_TX256TO511OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1526
/* The address of the ALT_EMAC_GMAC_TX512TO1023OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1527
#define ALT_EMAC1_GMAC_TX512TO1023OCTETS_GB_ADDR ALT_EMAC_GMAC_TX512TO1023OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1528
/* The address of the ALT_EMAC_GMAC_TX1024TOMAXOCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1529
#define ALT_EMAC1_GMAC_TX1024TOMAXOCTETS_GB_ADDR ALT_EMAC_GMAC_TX1024TOMAXOCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1530
/* The address of the ALT_EMAC_GMAC_TXUNICASTFRMS_GB register for the ALT_EMAC1_GMACGRP instance. */
1531
#define ALT_EMAC1_GMAC_TXUNICASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXUNICASTFRMS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1532
/* The address of the ALT_EMAC_GMAC_TXMCASTFRMS_GB register for the ALT_EMAC1_GMACGRP instance. */
1533
#define ALT_EMAC1_GMAC_TXMCASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXMCASTFRMS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1534
/* The address of the ALT_EMAC_GMAC_TXBCASTFRMS_GB register for the ALT_EMAC1_GMACGRP instance. */
1535
#define ALT_EMAC1_GMAC_TXBCASTFRMS_GB_ADDR ALT_EMAC_GMAC_TXBCASTFRMS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1536
/* The address of the ALT_EMAC_GMAC_TXUNDERFLOWERROR register for the ALT_EMAC1_GMACGRP instance. */
1537
#define ALT_EMAC1_GMAC_TXUNDERFLOWERROR_ADDR ALT_EMAC_GMAC_TXUNDERFLOWERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1538
/* The address of the ALT_EMAC_GMAC_TXSINGLECOL_G register for the ALT_EMAC1_GMACGRP instance. */
1539
#define ALT_EMAC1_GMAC_TXSINGLECOL_G_ADDR ALT_EMAC_GMAC_TXSINGLECOL_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1540
/* The address of the ALT_EMAC_GMAC_TXMULTICOL_G register for the ALT_EMAC1_GMACGRP instance. */
1541
#define ALT_EMAC1_GMAC_TXMULTICOL_G_ADDR ALT_EMAC_GMAC_TXMULTICOL_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1542
/* The address of the ALT_EMAC_GMAC_TXDEFERRED register for the ALT_EMAC1_GMACGRP instance. */
1543
#define ALT_EMAC1_GMAC_TXDEFERRED_ADDR ALT_EMAC_GMAC_TXDEFERRED_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1544
/* The address of the ALT_EMAC_GMAC_TXLATECOL register for the ALT_EMAC1_GMACGRP instance. */
1545
#define ALT_EMAC1_GMAC_TXLATECOL_ADDR ALT_EMAC_GMAC_TXLATECOL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1546
/* The address of the ALT_EMAC_GMAC_TXEXESSCOL register for the ALT_EMAC1_GMACGRP instance. */
1547
#define ALT_EMAC1_GMAC_TXEXESSCOL_ADDR ALT_EMAC_GMAC_TXEXESSCOL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1548
/* The address of the ALT_EMAC_GMAC_TXCARRIERERR register for the ALT_EMAC1_GMACGRP instance. */
1549
#define ALT_EMAC1_GMAC_TXCARRIERERR_ADDR ALT_EMAC_GMAC_TXCARRIERERR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1550
/* The address of the ALT_EMAC_GMAC_TXOCTETCNT register for the ALT_EMAC1_GMACGRP instance. */
1551
#define ALT_EMAC1_GMAC_TXOCTETCNT_ADDR ALT_EMAC_GMAC_TXOCTETCNT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1552
/* The address of the ALT_EMAC_GMAC_TXFRMCOUNT_G register for the ALT_EMAC1_GMACGRP instance. */
1553
#define ALT_EMAC1_GMAC_TXFRMCOUNT_G_ADDR ALT_EMAC_GMAC_TXFRMCOUNT_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1554
/* The address of the ALT_EMAC_GMAC_TXEXCESSDEF register for the ALT_EMAC1_GMACGRP instance. */
1555
#define ALT_EMAC1_GMAC_TXEXCESSDEF_ADDR ALT_EMAC_GMAC_TXEXCESSDEF_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1556
/* The address of the ALT_EMAC_GMAC_TXPAUSEFRMS register for the ALT_EMAC1_GMACGRP instance. */
1557
#define ALT_EMAC1_GMAC_TXPAUSEFRMS_ADDR ALT_EMAC_GMAC_TXPAUSEFRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1558
/* The address of the ALT_EMAC_GMAC_TXVLANFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1559
#define ALT_EMAC1_GMAC_TXVLANFRMS_G_ADDR ALT_EMAC_GMAC_TXVLANFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1560
/* The address of the ALT_EMAC_GMAC_TXOVERSIZE_G register for the ALT_EMAC1_GMACGRP instance. */
1561
#define ALT_EMAC1_GMAC_TXOVERSIZE_G_ADDR ALT_EMAC_GMAC_TXOVERSIZE_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1562
/* The address of the ALT_EMAC_GMAC_RXFRMCOUNT_GB register for the ALT_EMAC1_GMACGRP instance. */
1563
#define ALT_EMAC1_GMAC_RXFRMCOUNT_GB_ADDR ALT_EMAC_GMAC_RXFRMCOUNT_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1564
/* The address of the ALT_EMAC_GMAC_RXOCTETCOUNT_GB register for the ALT_EMAC1_GMACGRP instance. */
1565
#define ALT_EMAC1_GMAC_RXOCTETCOUNT_GB_ADDR ALT_EMAC_GMAC_RXOCTETCOUNT_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1566
/* The address of the ALT_EMAC_GMAC_RXOCTETCOUNT_G register for the ALT_EMAC1_GMACGRP instance. */
1567
#define ALT_EMAC1_GMAC_RXOCTETCOUNT_G_ADDR ALT_EMAC_GMAC_RXOCTETCOUNT_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1568
/* The address of the ALT_EMAC_GMAC_RXBCASTFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1569
#define ALT_EMAC1_GMAC_RXBCASTFRMS_G_ADDR ALT_EMAC_GMAC_RXBCASTFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1570
/* The address of the ALT_EMAC_GMAC_RXMCASTFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1571
#define ALT_EMAC1_GMAC_RXMCASTFRMS_G_ADDR ALT_EMAC_GMAC_RXMCASTFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1572
/* The address of the ALT_EMAC_GMAC_RXCRCERROR register for the ALT_EMAC1_GMACGRP instance. */
1573
#define ALT_EMAC1_GMAC_RXCRCERROR_ADDR ALT_EMAC_GMAC_RXCRCERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1574
/* The address of the ALT_EMAC_GMAC_RXALIGNMENTERROR register for the ALT_EMAC1_GMACGRP instance. */
1575
#define ALT_EMAC1_GMAC_RXALIGNMENTERROR_ADDR ALT_EMAC_GMAC_RXALIGNMENTERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1576
/* The address of the ALT_EMAC_GMAC_RXRUNTERROR register for the ALT_EMAC1_GMACGRP instance. */
1577
#define ALT_EMAC1_GMAC_RXRUNTERROR_ADDR ALT_EMAC_GMAC_RXRUNTERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1578
/* The address of the ALT_EMAC_GMAC_RXJABBERERROR register for the ALT_EMAC1_GMACGRP instance. */
1579
#define ALT_EMAC1_GMAC_RXJABBERERROR_ADDR ALT_EMAC_GMAC_RXJABBERERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1580
/* The address of the ALT_EMAC_GMAC_RXUNDERSIZE_G register for the ALT_EMAC1_GMACGRP instance. */
1581
#define ALT_EMAC1_GMAC_RXUNDERSIZE_G_ADDR ALT_EMAC_GMAC_RXUNDERSIZE_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1582
/* The address of the ALT_EMAC_GMAC_RXOVERSIZE_G register for the ALT_EMAC1_GMACGRP instance. */
1583
#define ALT_EMAC1_GMAC_RXOVERSIZE_G_ADDR ALT_EMAC_GMAC_RXOVERSIZE_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1584
/* The address of the ALT_EMAC_GMAC_RX64OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1585
#define ALT_EMAC1_GMAC_RX64OCTETS_GB_ADDR ALT_EMAC_GMAC_RX64OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1586
/* The address of the ALT_EMAC_GMAC_RX65TO127OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1587
#define ALT_EMAC1_GMAC_RX65TO127OCTETS_GB_ADDR ALT_EMAC_GMAC_RX65TO127OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1588
/* The address of the ALT_EMAC_GMAC_RX128TO255OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1589
#define ALT_EMAC1_GMAC_RX128TO255OCTETS_GB_ADDR ALT_EMAC_GMAC_RX128TO255OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1590
/* The address of the ALT_EMAC_GMAC_RX256TO511OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1591
#define ALT_EMAC1_GMAC_RX256TO511OCTETS_GB_ADDR ALT_EMAC_GMAC_RX256TO511OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1592
/* The address of the ALT_EMAC_GMAC_RX512TO1023OCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1593
#define ALT_EMAC1_GMAC_RX512TO1023OCTETS_GB_ADDR ALT_EMAC_GMAC_RX512TO1023OCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1594
/* The address of the ALT_EMAC_GMAC_RX1024TOMAXOCTETS_GB register for the ALT_EMAC1_GMACGRP instance. */
1595
#define ALT_EMAC1_GMAC_RX1024TOMAXOCTETS_GB_ADDR ALT_EMAC_GMAC_RX1024TOMAXOCTETS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1596
/* The address of the ALT_EMAC_GMAC_RXUNICASTFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1597
#define ALT_EMAC1_GMAC_RXUNICASTFRMS_G_ADDR ALT_EMAC_GMAC_RXUNICASTFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1598
/* The address of the ALT_EMAC_GMAC_RXLENERROR register for the ALT_EMAC1_GMACGRP instance. */
1599
#define ALT_EMAC1_GMAC_RXLENERROR_ADDR ALT_EMAC_GMAC_RXLENERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1600
/* The address of the ALT_EMAC_GMAC_RXOUTOFRANGETYPE register for the ALT_EMAC1_GMACGRP instance. */
1601
#define ALT_EMAC1_GMAC_RXOUTOFRANGETYPE_ADDR ALT_EMAC_GMAC_RXOUTOFRANGETYPE_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1602
/* The address of the ALT_EMAC_GMAC_RXPAUSEFRMS register for the ALT_EMAC1_GMACGRP instance. */
1603
#define ALT_EMAC1_GMAC_RXPAUSEFRMS_ADDR ALT_EMAC_GMAC_RXPAUSEFRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1604
/* The address of the ALT_EMAC_GMAC_RXFIFOOVF register for the ALT_EMAC1_GMACGRP instance. */
1605
#define ALT_EMAC1_GMAC_RXFIFOOVF_ADDR ALT_EMAC_GMAC_RXFIFOOVF_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1606
/* The address of the ALT_EMAC_GMAC_RXVLANFRMS_GB register for the ALT_EMAC1_GMACGRP instance. */
1607
#define ALT_EMAC1_GMAC_RXVLANFRMS_GB_ADDR ALT_EMAC_GMAC_RXVLANFRMS_GB_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1608
/* The address of the ALT_EMAC_GMAC_RXWDERROR register for the ALT_EMAC1_GMACGRP instance. */
1609
#define ALT_EMAC1_GMAC_RXWDERROR_ADDR ALT_EMAC_GMAC_RXWDERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1610
/* The address of the ALT_EMAC_GMAC_RXRCVERROR register for the ALT_EMAC1_GMACGRP instance. */
1611
#define ALT_EMAC1_GMAC_RXRCVERROR_ADDR ALT_EMAC_GMAC_RXRCVERROR_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1612
/* The address of the ALT_EMAC_GMAC_RXCTLFRMS_G register for the ALT_EMAC1_GMACGRP instance. */
1613
#define ALT_EMAC1_GMAC_RXCTLFRMS_G_ADDR ALT_EMAC_GMAC_RXCTLFRMS_G_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1614
/* The address of the ALT_EMAC_GMAC_MMC_IPC_RX_INT_MSK register for the ALT_EMAC1_GMACGRP instance. */
1615
#define ALT_EMAC1_GMAC_MMC_IPC_RX_INT_MSK_ADDR ALT_EMAC_GMAC_MMC_IPC_RX_INT_MSK_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1616
/* The address of the ALT_EMAC_GMAC_MMC_IPC_RX_INT register for the ALT_EMAC1_GMACGRP instance. */
1617
#define ALT_EMAC1_GMAC_MMC_IPC_RX_INT_ADDR ALT_EMAC_GMAC_MMC_IPC_RX_INT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1618
/* The address of the ALT_EMAC_GMAC_RXIPV4_GD_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1619
#define ALT_EMAC1_GMAC_RXIPV4_GD_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_GD_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1620
/* The address of the ALT_EMAC_GMAC_RXIPV4_HDRERR_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1621
#define ALT_EMAC1_GMAC_RXIPV4_HDRERR_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_HDRERR_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1622
/* The address of the ALT_EMAC_GMAC_RXIPV4_NOPAY_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1623
#define ALT_EMAC1_GMAC_RXIPV4_NOPAY_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_NOPAY_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1624
/* The address of the ALT_EMAC_GMAC_RXIPV4_FRAG_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1625
#define ALT_EMAC1_GMAC_RXIPV4_FRAG_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_FRAG_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1626
/* The address of the ALT_EMAC_GMAC_RXIPV4_UDSBL_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1627
#define ALT_EMAC1_GMAC_RXIPV4_UDSBL_FRMS_ADDR ALT_EMAC_GMAC_RXIPV4_UDSBL_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1628
/* The address of the ALT_EMAC_GMAC_RXIPV6_GD_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1629
#define ALT_EMAC1_GMAC_RXIPV6_GD_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_GD_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1630
/* The address of the ALT_EMAC_GMAC_RXIPV6_HDRERR_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1631
#define ALT_EMAC1_GMAC_RXIPV6_HDRERR_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_HDRERR_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1632
/* The address of the ALT_EMAC_GMAC_RXIPV6_NOPAY_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1633
#define ALT_EMAC1_GMAC_RXIPV6_NOPAY_FRMS_ADDR ALT_EMAC_GMAC_RXIPV6_NOPAY_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1634
/* The address of the ALT_EMAC_GMAC_RXUDP_GD_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1635
#define ALT_EMAC1_GMAC_RXUDP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXUDP_GD_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1636
/* The address of the ALT_EMAC_GMAC_RXUDP_ERR_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1637
#define ALT_EMAC1_GMAC_RXUDP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXUDP_ERR_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1638
/* The address of the ALT_EMAC_GMAC_RXTCP_GD_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1639
#define ALT_EMAC1_GMAC_RXTCP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXTCP_GD_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1640
/* The address of the ALT_EMAC_GMAC_RXTCP_ERR_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1641
#define ALT_EMAC1_GMAC_RXTCP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXTCP_ERR_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1642
/* The address of the ALT_EMAC_GMAC_RXICMP_GD_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1643
#define ALT_EMAC1_GMAC_RXICMP_GD_FRMS_ADDR ALT_EMAC_GMAC_RXICMP_GD_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1644
/* The address of the ALT_EMAC_GMAC_RXICMP_ERR_FRMS register for the ALT_EMAC1_GMACGRP instance. */
1645
#define ALT_EMAC1_GMAC_RXICMP_ERR_FRMS_ADDR ALT_EMAC_GMAC_RXICMP_ERR_FRMS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1646
/* The address of the ALT_EMAC_GMAC_RXIPV4_GD_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1647
#define ALT_EMAC1_GMAC_RXIPV4_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_GD_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1648
/* The address of the ALT_EMAC_GMAC_RXIPV4_HDRERR_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1649
#define ALT_EMAC1_GMAC_RXIPV4_HDRERR_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_HDRERR_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1650
/* The address of the ALT_EMAC_GMAC_RXIPV4_NOPAY_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1651
#define ALT_EMAC1_GMAC_RXIPV4_NOPAY_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_NOPAY_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1652
/* The address of the ALT_EMAC_GMAC_RXIPV4_FRAG_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1653
#define ALT_EMAC1_GMAC_RXIPV4_FRAG_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_FRAG_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1654
/* The address of the ALT_EMAC_GMAC_RXIPV4_UDSBL_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1655
#define ALT_EMAC1_GMAC_RXIPV4_UDSBL_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV4_UDSBL_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1656
/* The address of the ALT_EMAC_GMAC_RXIPV6_GD_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1657
#define ALT_EMAC1_GMAC_RXIPV6_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_GD_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1658
/* The address of the ALT_EMAC_GMAC_RXIPV6_HDRERR_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1659
#define ALT_EMAC1_GMAC_RXIPV6_HDRERR_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_HDRERR_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1660
/* The address of the ALT_EMAC_GMAC_RXIPV6_NOPAY_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1661
#define ALT_EMAC1_GMAC_RXIPV6_NOPAY_OCTETS_ADDR ALT_EMAC_GMAC_RXIPV6_NOPAY_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1662
/* The address of the ALT_EMAC_GMAC_RXUDP_GD_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1663
#define ALT_EMAC1_GMAC_RXUDP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXUDP_GD_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1664
/* The address of the ALT_EMAC_GMAC_RXUDP_ERR_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1665
#define ALT_EMAC1_GMAC_RXUDP_ERR_OCTETS_ADDR ALT_EMAC_GMAC_RXUDP_ERR_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1666
/* The address of the ALT_EMAC_GMAC_RXTCP_GD_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1667
#define ALT_EMAC1_GMAC_RXTCP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXTCP_GD_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1668
/* The address of the ALT_EMAC_GMAC_RXTCPERROCTETS register for the ALT_EMAC1_GMACGRP instance. */
1669
#define ALT_EMAC1_GMAC_RXTCPERROCTETS_ADDR ALT_EMAC_GMAC_RXTCPERROCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1670
/* The address of the ALT_EMAC_GMAC_RXICMP_GD_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1671
#define ALT_EMAC1_GMAC_RXICMP_GD_OCTETS_ADDR ALT_EMAC_GMAC_RXICMP_GD_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1672
/* The address of the ALT_EMAC_GMAC_RXICMP_ERR_OCTETS register for the ALT_EMAC1_GMACGRP instance. */
1673
#define ALT_EMAC1_GMAC_RXICMP_ERR_OCTETS_ADDR ALT_EMAC_GMAC_RXICMP_ERR_OCTETS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1674
/* The address of the ALT_EMAC_GMAC_L3_L4_CTL0 register for the ALT_EMAC1_GMACGRP instance. */
1675
#define ALT_EMAC1_GMAC_L3_L4_CTL0_ADDR ALT_EMAC_GMAC_L3_L4_CTL0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1676
/* The address of the ALT_EMAC_GMAC_LYR4_ADDR0 register for the ALT_EMAC1_GMACGRP instance. */
1677
#define ALT_EMAC1_GMAC_LYR4_ADDR0_ADDR ALT_EMAC_GMAC_LYR4_ADDR0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1678
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG0 register for the ALT_EMAC1_GMACGRP instance. */
1679
#define ALT_EMAC1_GMAC_LYR3_ADDR0_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1680
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG0 register for the ALT_EMAC1_GMACGRP instance. */
1681
#define ALT_EMAC1_GMAC_LYR3_ADDR1_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1682
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG0 register for the ALT_EMAC1_GMACGRP instance. */
1683
#define ALT_EMAC1_GMAC_LYR3_ADDR2_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1684
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG0 register for the ALT_EMAC1_GMACGRP instance. */
1685
#define ALT_EMAC1_GMAC_LYR3_ADDR3_REG0_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1686
/* The address of the ALT_EMAC_GMAC_L3_L4_CTL1 register for the ALT_EMAC1_GMACGRP instance. */
1687
#define ALT_EMAC1_GMAC_L3_L4_CTL1_ADDR ALT_EMAC_GMAC_L3_L4_CTL1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1688
/* The address of the ALT_EMAC_GMAC_LYR4_ADDR1 register for the ALT_EMAC1_GMACGRP instance. */
1689
#define ALT_EMAC1_GMAC_LYR4_ADDR1_ADDR ALT_EMAC_GMAC_LYR4_ADDR1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1690
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG1 register for the ALT_EMAC1_GMACGRP instance. */
1691
#define ALT_EMAC1_GMAC_LYR3_ADDR0_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1692
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG1 register for the ALT_EMAC1_GMACGRP instance. */
1693
#define ALT_EMAC1_GMAC_LYR3_ADDR1_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1694
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG1 register for the ALT_EMAC1_GMACGRP instance. */
1695
#define ALT_EMAC1_GMAC_LYR3_ADDR2_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1696
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG1 register for the ALT_EMAC1_GMACGRP instance. */
1697
#define ALT_EMAC1_GMAC_LYR3_ADDR3_REG1_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1698
/* The address of the ALT_EMAC_GMAC_L3_L4_CTL2 register for the ALT_EMAC1_GMACGRP instance. */
1699
#define ALT_EMAC1_GMAC_L3_L4_CTL2_ADDR ALT_EMAC_GMAC_L3_L4_CTL2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1700
/* The address of the ALT_EMAC_GMAC_LYR4_ADDR2 register for the ALT_EMAC1_GMACGRP instance. */
1701
#define ALT_EMAC1_GMAC_LYR4_ADDR2_ADDR ALT_EMAC_GMAC_LYR4_ADDR2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1702
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG2 register for the ALT_EMAC1_GMACGRP instance. */
1703
#define ALT_EMAC1_GMAC_LYR3_ADDR0_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1704
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG2 register for the ALT_EMAC1_GMACGRP instance. */
1705
#define ALT_EMAC1_GMAC_LYR3_ADDR1_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1706
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG2 register for the ALT_EMAC1_GMACGRP instance. */
1707
#define ALT_EMAC1_GMAC_LYR3_ADDR2_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1708
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG2 register for the ALT_EMAC1_GMACGRP instance. */
1709
#define ALT_EMAC1_GMAC_LYR3_ADDR3_REG2_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1710
/* The address of the ALT_EMAC_GMAC_L3_L4_CTL3 register for the ALT_EMAC1_GMACGRP instance. */
1711
#define ALT_EMAC1_GMAC_L3_L4_CTL3_ADDR ALT_EMAC_GMAC_L3_L4_CTL3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1712
/* The address of the ALT_EMAC_GMAC_LYR4_ADDR3 register for the ALT_EMAC1_GMACGRP instance. */
1713
#define ALT_EMAC1_GMAC_LYR4_ADDR3_ADDR ALT_EMAC_GMAC_LYR4_ADDR3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1714
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR0_REG3 register for the ALT_EMAC1_GMACGRP instance. */
1715
#define ALT_EMAC1_GMAC_LYR3_ADDR0_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR0_REG3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1716
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR1_REG3 register for the ALT_EMAC1_GMACGRP instance. */
1717
#define ALT_EMAC1_GMAC_LYR3_ADDR1_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR1_REG3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1718
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR2_REG3 register for the ALT_EMAC1_GMACGRP instance. */
1719
#define ALT_EMAC1_GMAC_LYR3_ADDR2_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR2_REG3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1720
/* The address of the ALT_EMAC_GMAC_LYR3_ADDR3_REG3 register for the ALT_EMAC1_GMACGRP instance. */
1721
#define ALT_EMAC1_GMAC_LYR3_ADDR3_REG3_ADDR ALT_EMAC_GMAC_LYR3_ADDR3_REG3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1722
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG0 register for the ALT_EMAC1_GMACGRP instance. */
1723
#define ALT_EMAC1_GMAC_HASH_TABLE_REG0_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG0_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1724
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG1 register for the ALT_EMAC1_GMACGRP instance. */
1725
#define ALT_EMAC1_GMAC_HASH_TABLE_REG1_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG1_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1726
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG2 register for the ALT_EMAC1_GMACGRP instance. */
1727
#define ALT_EMAC1_GMAC_HASH_TABLE_REG2_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG2_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1728
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG3 register for the ALT_EMAC1_GMACGRP instance. */
1729
#define ALT_EMAC1_GMAC_HASH_TABLE_REG3_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG3_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1730
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG4 register for the ALT_EMAC1_GMACGRP instance. */
1731
#define ALT_EMAC1_GMAC_HASH_TABLE_REG4_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG4_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1732
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG5 register for the ALT_EMAC1_GMACGRP instance. */
1733
#define ALT_EMAC1_GMAC_HASH_TABLE_REG5_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG5_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1734
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG6 register for the ALT_EMAC1_GMACGRP instance. */
1735
#define ALT_EMAC1_GMAC_HASH_TABLE_REG6_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG6_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1736
/* The address of the ALT_EMAC_GMAC_HASH_TABLE_REG7 register for the ALT_EMAC1_GMACGRP instance. */
1737
#define ALT_EMAC1_GMAC_HASH_TABLE_REG7_ADDR ALT_EMAC_GMAC_HASH_TABLE_REG7_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1738
/* The address of the ALT_EMAC_GMAC_VLAN_INCL_REG register for the ALT_EMAC1_GMACGRP instance. */
1739
#define ALT_EMAC1_GMAC_VLAN_INCL_REG_ADDR ALT_EMAC_GMAC_VLAN_INCL_REG_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1740
/* The address of the ALT_EMAC_GMAC_VLAN_HASH_TABLE_REG register for the ALT_EMAC1_GMACGRP instance. */
1741
#define ALT_EMAC1_GMAC_VLAN_HASH_TABLE_REG_ADDR ALT_EMAC_GMAC_VLAN_HASH_TABLE_REG_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1742
/* The address of the ALT_EMAC_GMAC_TS_CTL register for the ALT_EMAC1_GMACGRP instance. */
1743
#define ALT_EMAC1_GMAC_TS_CTL_ADDR ALT_EMAC_GMAC_TS_CTL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1744
/* The address of the ALT_EMAC_GMAC_SUB_SEC_INCREMENT register for the ALT_EMAC1_GMACGRP instance. */
1745
#define ALT_EMAC1_GMAC_SUB_SEC_INCREMENT_ADDR ALT_EMAC_GMAC_SUB_SEC_INCREMENT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1746
/* The address of the ALT_EMAC_GMAC_SYS_TIME_SECS register for the ALT_EMAC1_GMACGRP instance. */
1747
#define ALT_EMAC1_GMAC_SYS_TIME_SECS_ADDR ALT_EMAC_GMAC_SYS_TIME_SECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1748
/* The address of the ALT_EMAC_GMAC_SYS_TIME_NANOSECS register for the ALT_EMAC1_GMACGRP instance. */
1749
#define ALT_EMAC1_GMAC_SYS_TIME_NANOSECS_ADDR ALT_EMAC_GMAC_SYS_TIME_NANOSECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1750
/* The address of the ALT_EMAC_GMAC_SYS_TIME_SECS_UPDATE register for the ALT_EMAC1_GMACGRP instance. */
1751
#define ALT_EMAC1_GMAC_SYS_TIME_SECS_UPDATE_ADDR ALT_EMAC_GMAC_SYS_TIME_SECS_UPDATE_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1752
/* The address of the ALT_EMAC_GMAC_SYS_TIME_NANOSECS_UPDATE register for the ALT_EMAC1_GMACGRP instance. */
1753
#define ALT_EMAC1_GMAC_SYS_TIME_NANOSECS_UPDATE_ADDR ALT_EMAC_GMAC_SYS_TIME_NANOSECS_UPDATE_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1754
/* The address of the ALT_EMAC_GMAC_TS_ADDEND register for the ALT_EMAC1_GMACGRP instance. */
1755
#define ALT_EMAC1_GMAC_TS_ADDEND_ADDR ALT_EMAC_GMAC_TS_ADDEND_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1756
/* The address of the ALT_EMAC_GMAC_TGT_TIME_SECS register for the ALT_EMAC1_GMACGRP instance. */
1757
#define ALT_EMAC1_GMAC_TGT_TIME_SECS_ADDR ALT_EMAC_GMAC_TGT_TIME_SECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1758
/* The address of the ALT_EMAC_GMAC_TGT_TIME_NANOSECS register for the ALT_EMAC1_GMACGRP instance. */
1759
#define ALT_EMAC1_GMAC_TGT_TIME_NANOSECS_ADDR ALT_EMAC_GMAC_TGT_TIME_NANOSECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1760
/* The address of the ALT_EMAC_GMAC_SYS_TIME_HIGHER_WORD_SECS register for the ALT_EMAC1_GMACGRP instance. */
1761
#define ALT_EMAC1_GMAC_SYS_TIME_HIGHER_WORD_SECS_ADDR ALT_EMAC_GMAC_SYS_TIME_HIGHER_WORD_SECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1762
/* The address of the ALT_EMAC_GMAC_TS_STAT register for the ALT_EMAC1_GMACGRP instance. */
1763
#define ALT_EMAC1_GMAC_TS_STAT_ADDR ALT_EMAC_GMAC_TS_STAT_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1764
/* The address of the ALT_EMAC_GMAC_PPS_CTL register for the ALT_EMAC1_GMACGRP instance. */
1765
#define ALT_EMAC1_GMAC_PPS_CTL_ADDR ALT_EMAC_GMAC_PPS_CTL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1766
/* The address of the ALT_EMAC_GMAC_AUX_TS_NANOSECS register for the ALT_EMAC1_GMACGRP instance. */
1767
#define ALT_EMAC1_GMAC_AUX_TS_NANOSECS_ADDR ALT_EMAC_GMAC_AUX_TS_NANOSECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1768
/* The address of the ALT_EMAC_GMAC_AUX_TS_SECS register for the ALT_EMAC1_GMACGRP instance. */
1769
#define ALT_EMAC1_GMAC_AUX_TS_SECS_ADDR ALT_EMAC_GMAC_AUX_TS_SECS_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1770
/* The address of the ALT_EMAC_GMAC_PPS0_INTERVAL register for the ALT_EMAC1_GMACGRP instance. */
1771
#define ALT_EMAC1_GMAC_PPS0_INTERVAL_ADDR ALT_EMAC_GMAC_PPS0_INTERVAL_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1772
/* The address of the ALT_EMAC_GMAC_PPS0_WIDTH register for the ALT_EMAC1_GMACGRP instance. */
1773
#define ALT_EMAC1_GMAC_PPS0_WIDTH_ADDR ALT_EMAC_GMAC_PPS0_WIDTH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1774
/* The address of the ALT_EMAC_GMAC_MAC_ADDR16_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1775
#define ALT_EMAC1_GMAC_MAC_ADDR16_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR16_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1776
/* The address of the ALT_EMAC_GMAC_MAC_ADDR16_LOW register for the ALT_EMAC1_GMACGRP instance. */
1777
#define ALT_EMAC1_GMAC_MAC_ADDR16_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR16_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1778
/* The address of the ALT_EMAC_GMAC_MAC_ADDR17_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1779
#define ALT_EMAC1_GMAC_MAC_ADDR17_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR17_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1780
/* The address of the ALT_EMAC_GMAC_MAC_ADDR17_LOW register for the ALT_EMAC1_GMACGRP instance. */
1781
#define ALT_EMAC1_GMAC_MAC_ADDR17_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR17_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1782
/* The address of the ALT_EMAC_GMAC_MAC_ADDR18_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1783
#define ALT_EMAC1_GMAC_MAC_ADDR18_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR18_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1784
/* The address of the ALT_EMAC_GMAC_MAC_ADDR18_LOW register for the ALT_EMAC1_GMACGRP instance. */
1785
#define ALT_EMAC1_GMAC_MAC_ADDR18_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR18_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1786
/* The address of the ALT_EMAC_GMAC_MAC_ADDR19_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1787
#define ALT_EMAC1_GMAC_MAC_ADDR19_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR19_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1788
/* The address of the ALT_EMAC_GMAC_MAC_ADDR19_LOW register for the ALT_EMAC1_GMACGRP instance. */
1789
#define ALT_EMAC1_GMAC_MAC_ADDR19_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR19_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1790
/* The address of the ALT_EMAC_GMAC_MAC_ADDR20_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1791
#define ALT_EMAC1_GMAC_MAC_ADDR20_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR20_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1792
/* The address of the ALT_EMAC_GMAC_MAC_ADDR20_LOW register for the ALT_EMAC1_GMACGRP instance. */
1793
#define ALT_EMAC1_GMAC_MAC_ADDR20_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR20_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1794
/* The address of the ALT_EMAC_GMAC_MAC_ADDR21_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1795
#define ALT_EMAC1_GMAC_MAC_ADDR21_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR21_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1796
/* The address of the ALT_EMAC_GMAC_MAC_ADDR21_LOW register for the ALT_EMAC1_GMACGRP instance. */
1797
#define ALT_EMAC1_GMAC_MAC_ADDR21_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR21_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1798
/* The address of the ALT_EMAC_GMAC_MAC_ADDR22_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1799
#define ALT_EMAC1_GMAC_MAC_ADDR22_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR22_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1800
/* The address of the ALT_EMAC_GMAC_MAC_ADDR22_LOW register for the ALT_EMAC1_GMACGRP instance. */
1801
#define ALT_EMAC1_GMAC_MAC_ADDR22_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR22_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1802
/* The address of the ALT_EMAC_GMAC_MAC_ADDR23_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1803
#define ALT_EMAC1_GMAC_MAC_ADDR23_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR23_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1804
/* The address of the ALT_EMAC_GMAC_MAC_ADDR23_LOW register for the ALT_EMAC1_GMACGRP instance. */
1805
#define ALT_EMAC1_GMAC_MAC_ADDR23_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR23_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1806
/* The address of the ALT_EMAC_GMAC_MAC_ADDR24_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1807
#define ALT_EMAC1_GMAC_MAC_ADDR24_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR24_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1808
/* The address of the ALT_EMAC_GMAC_MAC_ADDR24_LOW register for the ALT_EMAC1_GMACGRP instance. */
1809
#define ALT_EMAC1_GMAC_MAC_ADDR24_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR24_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1810
/* The address of the ALT_EMAC_GMAC_MAC_ADDR25_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1811
#define ALT_EMAC1_GMAC_MAC_ADDR25_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR25_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1812
/* The address of the ALT_EMAC_GMAC_MAC_ADDR25_LOW register for the ALT_EMAC1_GMACGRP instance. */
1813
#define ALT_EMAC1_GMAC_MAC_ADDR25_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR25_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1814
/* The address of the ALT_EMAC_GMAC_MAC_ADDR26_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1815
#define ALT_EMAC1_GMAC_MAC_ADDR26_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR26_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1816
/* The address of the ALT_EMAC_GMAC_MAC_ADDR26_LOW register for the ALT_EMAC1_GMACGRP instance. */
1817
#define ALT_EMAC1_GMAC_MAC_ADDR26_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR26_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1818
/* The address of the ALT_EMAC_GMAC_MAC_ADDR27_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1819
#define ALT_EMAC1_GMAC_MAC_ADDR27_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR27_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1820
/* The address of the ALT_EMAC_GMAC_MAC_ADDR27_LOW register for the ALT_EMAC1_GMACGRP instance. */
1821
#define ALT_EMAC1_GMAC_MAC_ADDR27_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR27_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1822
/* The address of the ALT_EMAC_GMAC_MAC_ADDR28_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1823
#define ALT_EMAC1_GMAC_MAC_ADDR28_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR28_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1824
/* The address of the ALT_EMAC_GMAC_MAC_ADDR28_LOW register for the ALT_EMAC1_GMACGRP instance. */
1825
#define ALT_EMAC1_GMAC_MAC_ADDR28_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR28_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1826
/* The address of the ALT_EMAC_GMAC_MAC_ADDR29_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1827
#define ALT_EMAC1_GMAC_MAC_ADDR29_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR29_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1828
/* The address of the ALT_EMAC_GMAC_MAC_ADDR29_LOW register for the ALT_EMAC1_GMACGRP instance. */
1829
#define ALT_EMAC1_GMAC_MAC_ADDR29_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR29_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1830
/* The address of the ALT_EMAC_GMAC_MAC_ADDR30_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1831
#define ALT_EMAC1_GMAC_MAC_ADDR30_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR30_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1832
/* The address of the ALT_EMAC_GMAC_MAC_ADDR30_LOW register for the ALT_EMAC1_GMACGRP instance. */
1833
#define ALT_EMAC1_GMAC_MAC_ADDR30_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR30_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1834
/* The address of the ALT_EMAC_GMAC_MAC_ADDR31_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1835
#define ALT_EMAC1_GMAC_MAC_ADDR31_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR31_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1836
/* The address of the ALT_EMAC_GMAC_MAC_ADDR31_LOW register for the ALT_EMAC1_GMACGRP instance. */
1837
#define ALT_EMAC1_GMAC_MAC_ADDR31_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR31_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1838
/* The address of the ALT_EMAC_GMAC_MAC_ADDR32_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1839
#define ALT_EMAC1_GMAC_MAC_ADDR32_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR32_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1840
/* The address of the ALT_EMAC_GMAC_MAC_ADDR32_LOW register for the ALT_EMAC1_GMACGRP instance. */
1841
#define ALT_EMAC1_GMAC_MAC_ADDR32_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR32_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1842
/* The address of the ALT_EMAC_GMAC_MAC_ADDR33_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1843
#define ALT_EMAC1_GMAC_MAC_ADDR33_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR33_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1844
/* The address of the ALT_EMAC_GMAC_MAC_ADDR33_LOW register for the ALT_EMAC1_GMACGRP instance. */
1845
#define ALT_EMAC1_GMAC_MAC_ADDR33_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR33_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1846
/* The address of the ALT_EMAC_GMAC_MAC_ADDR34_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1847
#define ALT_EMAC1_GMAC_MAC_ADDR34_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR34_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1848
/* The address of the ALT_EMAC_GMAC_MAC_ADDR34_LOW register for the ALT_EMAC1_GMACGRP instance. */
1849
#define ALT_EMAC1_GMAC_MAC_ADDR34_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR34_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1850
/* The address of the ALT_EMAC_GMAC_MAC_ADDR35_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1851
#define ALT_EMAC1_GMAC_MAC_ADDR35_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR35_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1852
/* The address of the ALT_EMAC_GMAC_MAC_ADDR35_LOW register for the ALT_EMAC1_GMACGRP instance. */
1853
#define ALT_EMAC1_GMAC_MAC_ADDR35_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR35_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1854
/* The address of the ALT_EMAC_GMAC_MAC_ADDR36_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1855
#define ALT_EMAC1_GMAC_MAC_ADDR36_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR36_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1856
/* The address of the ALT_EMAC_GMAC_MAC_ADDR36_LOW register for the ALT_EMAC1_GMACGRP instance. */
1857
#define ALT_EMAC1_GMAC_MAC_ADDR36_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR36_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1858
/* The address of the ALT_EMAC_GMAC_MAC_ADDR37_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1859
#define ALT_EMAC1_GMAC_MAC_ADDR37_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR37_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1860
/* The address of the ALT_EMAC_GMAC_MAC_ADDR37_LOW register for the ALT_EMAC1_GMACGRP instance. */
1861
#define ALT_EMAC1_GMAC_MAC_ADDR37_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR37_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1862
/* The address of the ALT_EMAC_GMAC_MAC_ADDR38_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1863
#define ALT_EMAC1_GMAC_MAC_ADDR38_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR38_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1864
/* The address of the ALT_EMAC_GMAC_MAC_ADDR38_LOW register for the ALT_EMAC1_GMACGRP instance. */
1865
#define ALT_EMAC1_GMAC_MAC_ADDR38_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR38_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1866
/* The address of the ALT_EMAC_GMAC_MAC_ADDR39_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1867
#define ALT_EMAC1_GMAC_MAC_ADDR39_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR39_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1868
/* The address of the ALT_EMAC_GMAC_MAC_ADDR39_LOW register for the ALT_EMAC1_GMACGRP instance. */
1869
#define ALT_EMAC1_GMAC_MAC_ADDR39_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR39_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1870
/* The address of the ALT_EMAC_GMAC_MAC_ADDR40_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1871
#define ALT_EMAC1_GMAC_MAC_ADDR40_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR40_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1872
/* The address of the ALT_EMAC_GMAC_MAC_ADDR40_LOW register for the ALT_EMAC1_GMACGRP instance. */
1873
#define ALT_EMAC1_GMAC_MAC_ADDR40_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR40_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1874
/* The address of the ALT_EMAC_GMAC_MAC_ADDR41_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1875
#define ALT_EMAC1_GMAC_MAC_ADDR41_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR41_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1876
/* The address of the ALT_EMAC_GMAC_MAC_ADDR41_LOW register for the ALT_EMAC1_GMACGRP instance. */
1877
#define ALT_EMAC1_GMAC_MAC_ADDR41_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR41_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1878
/* The address of the ALT_EMAC_GMAC_MAC_ADDR42_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1879
#define ALT_EMAC1_GMAC_MAC_ADDR42_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR42_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1880
/* The address of the ALT_EMAC_GMAC_MAC_ADDR42_LOW register for the ALT_EMAC1_GMACGRP instance. */
1881
#define ALT_EMAC1_GMAC_MAC_ADDR42_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR42_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1882
/* The address of the ALT_EMAC_GMAC_MAC_ADDR43_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1883
#define ALT_EMAC1_GMAC_MAC_ADDR43_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR43_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1884
/* The address of the ALT_EMAC_GMAC_MAC_ADDR43_LOW register for the ALT_EMAC1_GMACGRP instance. */
1885
#define ALT_EMAC1_GMAC_MAC_ADDR43_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR43_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1886
/* The address of the ALT_EMAC_GMAC_MAC_ADDR44_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1887
#define ALT_EMAC1_GMAC_MAC_ADDR44_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR44_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1888
/* The address of the ALT_EMAC_GMAC_MAC_ADDR44_LOW register for the ALT_EMAC1_GMACGRP instance. */
1889
#define ALT_EMAC1_GMAC_MAC_ADDR44_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR44_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1890
/* The address of the ALT_EMAC_GMAC_MAC_ADDR45_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1891
#define ALT_EMAC1_GMAC_MAC_ADDR45_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR45_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1892
/* The address of the ALT_EMAC_GMAC_MAC_ADDR45_LOW register for the ALT_EMAC1_GMACGRP instance. */
1893
#define ALT_EMAC1_GMAC_MAC_ADDR45_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR45_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1894
/* The address of the ALT_EMAC_GMAC_MAC_ADDR46_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1895
#define ALT_EMAC1_GMAC_MAC_ADDR46_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR46_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1896
/* The address of the ALT_EMAC_GMAC_MAC_ADDR46_LOW register for the ALT_EMAC1_GMACGRP instance. */
1897
#define ALT_EMAC1_GMAC_MAC_ADDR46_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR46_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1898
/* The address of the ALT_EMAC_GMAC_MAC_ADDR47_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1899
#define ALT_EMAC1_GMAC_MAC_ADDR47_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR47_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1900
/* The address of the ALT_EMAC_GMAC_MAC_ADDR47_LOW register for the ALT_EMAC1_GMACGRP instance. */
1901
#define ALT_EMAC1_GMAC_MAC_ADDR47_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR47_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1902
/* The address of the ALT_EMAC_GMAC_MAC_ADDR48_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1903
#define ALT_EMAC1_GMAC_MAC_ADDR48_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR48_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1904
/* The address of the ALT_EMAC_GMAC_MAC_ADDR48_LOW register for the ALT_EMAC1_GMACGRP instance. */
1905
#define ALT_EMAC1_GMAC_MAC_ADDR48_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR48_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1906
/* The address of the ALT_EMAC_GMAC_MAC_ADDR49_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1907
#define ALT_EMAC1_GMAC_MAC_ADDR49_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR49_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1908
/* The address of the ALT_EMAC_GMAC_MAC_ADDR49_LOW register for the ALT_EMAC1_GMACGRP instance. */
1909
#define ALT_EMAC1_GMAC_MAC_ADDR49_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR49_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1910
/* The address of the ALT_EMAC_GMAC_MAC_ADDR50_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1911
#define ALT_EMAC1_GMAC_MAC_ADDR50_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR50_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1912
/* The address of the ALT_EMAC_GMAC_MAC_ADDR50_LOW register for the ALT_EMAC1_GMACGRP instance. */
1913
#define ALT_EMAC1_GMAC_MAC_ADDR50_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR50_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1914
/* The address of the ALT_EMAC_GMAC_MAC_ADDR51_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1915
#define ALT_EMAC1_GMAC_MAC_ADDR51_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR51_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1916
/* The address of the ALT_EMAC_GMAC_MAC_ADDR51_LOW register for the ALT_EMAC1_GMACGRP instance. */
1917
#define ALT_EMAC1_GMAC_MAC_ADDR51_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR51_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1918
/* The address of the ALT_EMAC_GMAC_MAC_ADDR52_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1919
#define ALT_EMAC1_GMAC_MAC_ADDR52_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR52_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1920
/* The address of the ALT_EMAC_GMAC_MAC_ADDR52_LOW register for the ALT_EMAC1_GMACGRP instance. */
1921
#define ALT_EMAC1_GMAC_MAC_ADDR52_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR52_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1922
/* The address of the ALT_EMAC_GMAC_MAC_ADDR53_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1923
#define ALT_EMAC1_GMAC_MAC_ADDR53_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR53_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1924
/* The address of the ALT_EMAC_GMAC_MAC_ADDR53_LOW register for the ALT_EMAC1_GMACGRP instance. */
1925
#define ALT_EMAC1_GMAC_MAC_ADDR53_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR53_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1926
/* The address of the ALT_EMAC_GMAC_MAC_ADDR54_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1927
#define ALT_EMAC1_GMAC_MAC_ADDR54_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR54_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1928
/* The address of the ALT_EMAC_GMAC_MAC_ADDR54_LOW register for the ALT_EMAC1_GMACGRP instance. */
1929
#define ALT_EMAC1_GMAC_MAC_ADDR54_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR54_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1930
/* The address of the ALT_EMAC_GMAC_MAC_ADDR55_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1931
#define ALT_EMAC1_GMAC_MAC_ADDR55_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR55_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1932
/* The address of the ALT_EMAC_GMAC_MAC_ADDR55_LOW register for the ALT_EMAC1_GMACGRP instance. */
1933
#define ALT_EMAC1_GMAC_MAC_ADDR55_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR55_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1934
/* The address of the ALT_EMAC_GMAC_MAC_ADDR56_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1935
#define ALT_EMAC1_GMAC_MAC_ADDR56_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR56_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1936
/* The address of the ALT_EMAC_GMAC_MAC_ADDR56_LOW register for the ALT_EMAC1_GMACGRP instance. */
1937
#define ALT_EMAC1_GMAC_MAC_ADDR56_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR56_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1938
/* The address of the ALT_EMAC_GMAC_MAC_ADDR57_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1939
#define ALT_EMAC1_GMAC_MAC_ADDR57_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR57_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1940
/* The address of the ALT_EMAC_GMAC_MAC_ADDR57_LOW register for the ALT_EMAC1_GMACGRP instance. */
1941
#define ALT_EMAC1_GMAC_MAC_ADDR57_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR57_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1942
/* The address of the ALT_EMAC_GMAC_MAC_ADDR58_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1943
#define ALT_EMAC1_GMAC_MAC_ADDR58_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR58_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1944
/* The address of the ALT_EMAC_GMAC_MAC_ADDR58_LOW register for the ALT_EMAC1_GMACGRP instance. */
1945
#define ALT_EMAC1_GMAC_MAC_ADDR58_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR58_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1946
/* The address of the ALT_EMAC_GMAC_MAC_ADDR59_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1947
#define ALT_EMAC1_GMAC_MAC_ADDR59_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR59_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1948
/* The address of the ALT_EMAC_GMAC_MAC_ADDR59_LOW register for the ALT_EMAC1_GMACGRP instance. */
1949
#define ALT_EMAC1_GMAC_MAC_ADDR59_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR59_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1950
/* The address of the ALT_EMAC_GMAC_MAC_ADDR60_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1951
#define ALT_EMAC1_GMAC_MAC_ADDR60_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR60_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1952
/* The address of the ALT_EMAC_GMAC_MAC_ADDR60_LOW register for the ALT_EMAC1_GMACGRP instance. */
1953
#define ALT_EMAC1_GMAC_MAC_ADDR60_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR60_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1954
/* The address of the ALT_EMAC_GMAC_MAC_ADDR61_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1955
#define ALT_EMAC1_GMAC_MAC_ADDR61_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR61_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1956
/* The address of the ALT_EMAC_GMAC_MAC_ADDR61_LOW register for the ALT_EMAC1_GMACGRP instance. */
1957
#define ALT_EMAC1_GMAC_MAC_ADDR61_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR61_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1958
/* The address of the ALT_EMAC_GMAC_MAC_ADDR62_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1959
#define ALT_EMAC1_GMAC_MAC_ADDR62_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR62_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1960
/* The address of the ALT_EMAC_GMAC_MAC_ADDR62_LOW register for the ALT_EMAC1_GMACGRP instance. */
1961
#define ALT_EMAC1_GMAC_MAC_ADDR62_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR62_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1962
/* The address of the ALT_EMAC_GMAC_MAC_ADDR63_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1963
#define ALT_EMAC1_GMAC_MAC_ADDR63_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR63_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1964
/* The address of the ALT_EMAC_GMAC_MAC_ADDR63_LOW register for the ALT_EMAC1_GMACGRP instance. */
1965
#define ALT_EMAC1_GMAC_MAC_ADDR63_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR63_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1966
/* The address of the ALT_EMAC_GMAC_MAC_ADDR64_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1967
#define ALT_EMAC1_GMAC_MAC_ADDR64_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR64_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1968
/* The address of the ALT_EMAC_GMAC_MAC_ADDR64_LOW register for the ALT_EMAC1_GMACGRP instance. */
1969
#define ALT_EMAC1_GMAC_MAC_ADDR64_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR64_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1970
/* The address of the ALT_EMAC_GMAC_MAC_ADDR65_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1971
#define ALT_EMAC1_GMAC_MAC_ADDR65_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR65_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1972
/* The address of the ALT_EMAC_GMAC_MAC_ADDR65_LOW register for the ALT_EMAC1_GMACGRP instance. */
1973
#define ALT_EMAC1_GMAC_MAC_ADDR65_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR65_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1974
/* The address of the ALT_EMAC_GMAC_MAC_ADDR66_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1975
#define ALT_EMAC1_GMAC_MAC_ADDR66_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR66_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1976
/* The address of the ALT_EMAC_GMAC_MAC_ADDR66_LOW register for the ALT_EMAC1_GMACGRP instance. */
1977
#define ALT_EMAC1_GMAC_MAC_ADDR66_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR66_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1978
/* The address of the ALT_EMAC_GMAC_MAC_ADDR67_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1979
#define ALT_EMAC1_GMAC_MAC_ADDR67_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR67_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1980
/* The address of the ALT_EMAC_GMAC_MAC_ADDR67_LOW register for the ALT_EMAC1_GMACGRP instance. */
1981
#define ALT_EMAC1_GMAC_MAC_ADDR67_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR67_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1982
/* The address of the ALT_EMAC_GMAC_MAC_ADDR68_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1983
#define ALT_EMAC1_GMAC_MAC_ADDR68_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR68_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1984
/* The address of the ALT_EMAC_GMAC_MAC_ADDR68_LOW register for the ALT_EMAC1_GMACGRP instance. */
1985
#define ALT_EMAC1_GMAC_MAC_ADDR68_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR68_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1986
/* The address of the ALT_EMAC_GMAC_MAC_ADDR69_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1987
#define ALT_EMAC1_GMAC_MAC_ADDR69_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR69_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1988
/* The address of the ALT_EMAC_GMAC_MAC_ADDR69_LOW register for the ALT_EMAC1_GMACGRP instance. */
1989
#define ALT_EMAC1_GMAC_MAC_ADDR69_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR69_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1990
/* The address of the ALT_EMAC_GMAC_MAC_ADDR70_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1991
#define ALT_EMAC1_GMAC_MAC_ADDR70_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR70_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1992
/* The address of the ALT_EMAC_GMAC_MAC_ADDR70_LOW register for the ALT_EMAC1_GMACGRP instance. */
1993
#define ALT_EMAC1_GMAC_MAC_ADDR70_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR70_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1994
/* The address of the ALT_EMAC_GMAC_MAC_ADDR71_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1995
#define ALT_EMAC1_GMAC_MAC_ADDR71_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR71_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1996
/* The address of the ALT_EMAC_GMAC_MAC_ADDR71_LOW register for the ALT_EMAC1_GMACGRP instance. */
1997
#define ALT_EMAC1_GMAC_MAC_ADDR71_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR71_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
1998
/* The address of the ALT_EMAC_GMAC_MAC_ADDR72_HIGH register for the ALT_EMAC1_GMACGRP instance. */
1999
#define ALT_EMAC1_GMAC_MAC_ADDR72_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR72_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2000
/* The address of the ALT_EMAC_GMAC_MAC_ADDR72_LOW register for the ALT_EMAC1_GMACGRP instance. */
2001
#define ALT_EMAC1_GMAC_MAC_ADDR72_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR72_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2002
/* The address of the ALT_EMAC_GMAC_MAC_ADDR73_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2003
#define ALT_EMAC1_GMAC_MAC_ADDR73_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR73_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2004
/* The address of the ALT_EMAC_GMAC_MAC_ADDR73_LOW register for the ALT_EMAC1_GMACGRP instance. */
2005
#define ALT_EMAC1_GMAC_MAC_ADDR73_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR73_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2006
/* The address of the ALT_EMAC_GMAC_MAC_ADDR74_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2007
#define ALT_EMAC1_GMAC_MAC_ADDR74_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR74_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2008
/* The address of the ALT_EMAC_GMAC_MAC_ADDR74_LOW register for the ALT_EMAC1_GMACGRP instance. */
2009
#define ALT_EMAC1_GMAC_MAC_ADDR74_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR74_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2010
/* The address of the ALT_EMAC_GMAC_MAC_ADDR75_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2011
#define ALT_EMAC1_GMAC_MAC_ADDR75_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR75_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2012
/* The address of the ALT_EMAC_GMAC_MAC_ADDR75_LOW register for the ALT_EMAC1_GMACGRP instance. */
2013
#define ALT_EMAC1_GMAC_MAC_ADDR75_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR75_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2014
/* The address of the ALT_EMAC_GMAC_MAC_ADDR76_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2015
#define ALT_EMAC1_GMAC_MAC_ADDR76_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR76_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2016
/* The address of the ALT_EMAC_GMAC_MAC_ADDR76_LOW register for the ALT_EMAC1_GMACGRP instance. */
2017
#define ALT_EMAC1_GMAC_MAC_ADDR76_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR76_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2018
/* The address of the ALT_EMAC_GMAC_MAC_ADDR77_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2019
#define ALT_EMAC1_GMAC_MAC_ADDR77_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR77_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2020
/* The address of the ALT_EMAC_GMAC_MAC_ADDR77_LOW register for the ALT_EMAC1_GMACGRP instance. */
2021
#define ALT_EMAC1_GMAC_MAC_ADDR77_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR77_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2022
/* The address of the ALT_EMAC_GMAC_MAC_ADDR78_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2023
#define ALT_EMAC1_GMAC_MAC_ADDR78_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR78_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2024
/* The address of the ALT_EMAC_GMAC_MAC_ADDR78_LOW register for the ALT_EMAC1_GMACGRP instance. */
2025
#define ALT_EMAC1_GMAC_MAC_ADDR78_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR78_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2026
/* The address of the ALT_EMAC_GMAC_MAC_ADDR79_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2027
#define ALT_EMAC1_GMAC_MAC_ADDR79_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR79_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2028
/* The address of the ALT_EMAC_GMAC_MAC_ADDR79_LOW register for the ALT_EMAC1_GMACGRP instance. */
2029
#define ALT_EMAC1_GMAC_MAC_ADDR79_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR79_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2030
/* The address of the ALT_EMAC_GMAC_MAC_ADDR80_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2031
#define ALT_EMAC1_GMAC_MAC_ADDR80_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR80_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2032
/* The address of the ALT_EMAC_GMAC_MAC_ADDR80_LOW register for the ALT_EMAC1_GMACGRP instance. */
2033
#define ALT_EMAC1_GMAC_MAC_ADDR80_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR80_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2034
/* The address of the ALT_EMAC_GMAC_MAC_ADDR81_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2035
#define ALT_EMAC1_GMAC_MAC_ADDR81_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR81_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2036
/* The address of the ALT_EMAC_GMAC_MAC_ADDR81_LOW register for the ALT_EMAC1_GMACGRP instance. */
2037
#define ALT_EMAC1_GMAC_MAC_ADDR81_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR81_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2038
/* The address of the ALT_EMAC_GMAC_MAC_ADDR82_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2039
#define ALT_EMAC1_GMAC_MAC_ADDR82_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR82_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2040
/* The address of the ALT_EMAC_GMAC_MAC_ADDR82_LOW register for the ALT_EMAC1_GMACGRP instance. */
2041
#define ALT_EMAC1_GMAC_MAC_ADDR82_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR82_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2042
/* The address of the ALT_EMAC_GMAC_MAC_ADDR83_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2043
#define ALT_EMAC1_GMAC_MAC_ADDR83_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR83_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2044
/* The address of the ALT_EMAC_GMAC_MAC_ADDR83_LOW register for the ALT_EMAC1_GMACGRP instance. */
2045
#define ALT_EMAC1_GMAC_MAC_ADDR83_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR83_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2046
/* The address of the ALT_EMAC_GMAC_MAC_ADDR84_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2047
#define ALT_EMAC1_GMAC_MAC_ADDR84_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR84_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2048
/* The address of the ALT_EMAC_GMAC_MAC_ADDR84_LOW register for the ALT_EMAC1_GMACGRP instance. */
2049
#define ALT_EMAC1_GMAC_MAC_ADDR84_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR84_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2050
/* The address of the ALT_EMAC_GMAC_MAC_ADDR85_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2051
#define ALT_EMAC1_GMAC_MAC_ADDR85_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR85_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2052
/* The address of the ALT_EMAC_GMAC_MAC_ADDR85_LOW register for the ALT_EMAC1_GMACGRP instance. */
2053
#define ALT_EMAC1_GMAC_MAC_ADDR85_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR85_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2054
/* The address of the ALT_EMAC_GMAC_MAC_ADDR86_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2055
#define ALT_EMAC1_GMAC_MAC_ADDR86_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR86_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2056
/* The address of the ALT_EMAC_GMAC_MAC_ADDR86_LOW register for the ALT_EMAC1_GMACGRP instance. */
2057
#define ALT_EMAC1_GMAC_MAC_ADDR86_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR86_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2058
/* The address of the ALT_EMAC_GMAC_MAC_ADDR87_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2059
#define ALT_EMAC1_GMAC_MAC_ADDR87_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR87_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2060
/* The address of the ALT_EMAC_GMAC_MAC_ADDR87_LOW register for the ALT_EMAC1_GMACGRP instance. */
2061
#define ALT_EMAC1_GMAC_MAC_ADDR87_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR87_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2062
/* The address of the ALT_EMAC_GMAC_MAC_ADDR88_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2063
#define ALT_EMAC1_GMAC_MAC_ADDR88_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR88_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2064
/* The address of the ALT_EMAC_GMAC_MAC_ADDR88_LOW register for the ALT_EMAC1_GMACGRP instance. */
2065
#define ALT_EMAC1_GMAC_MAC_ADDR88_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR88_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2066
/* The address of the ALT_EMAC_GMAC_MAC_ADDR89_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2067
#define ALT_EMAC1_GMAC_MAC_ADDR89_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR89_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2068
/* The address of the ALT_EMAC_GMAC_MAC_ADDR89_LOW register for the ALT_EMAC1_GMACGRP instance. */
2069
#define ALT_EMAC1_GMAC_MAC_ADDR89_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR89_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2070
/* The address of the ALT_EMAC_GMAC_MAC_ADDR90_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2071
#define ALT_EMAC1_GMAC_MAC_ADDR90_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR90_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2072
/* The address of the ALT_EMAC_GMAC_MAC_ADDR90_LOW register for the ALT_EMAC1_GMACGRP instance. */
2073
#define ALT_EMAC1_GMAC_MAC_ADDR90_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR90_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2074
/* The address of the ALT_EMAC_GMAC_MAC_ADDR91_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2075
#define ALT_EMAC1_GMAC_MAC_ADDR91_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR91_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2076
/* The address of the ALT_EMAC_GMAC_MAC_ADDR91_LOW register for the ALT_EMAC1_GMACGRP instance. */
2077
#define ALT_EMAC1_GMAC_MAC_ADDR91_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR91_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2078
/* The address of the ALT_EMAC_GMAC_MAC_ADDR92_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2079
#define ALT_EMAC1_GMAC_MAC_ADDR92_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR92_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2080
/* The address of the ALT_EMAC_GMAC_MAC_ADDR92_LOW register for the ALT_EMAC1_GMACGRP instance. */
2081
#define ALT_EMAC1_GMAC_MAC_ADDR92_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR92_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2082
/* The address of the ALT_EMAC_GMAC_MAC_ADDR93_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2083
#define ALT_EMAC1_GMAC_MAC_ADDR93_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR93_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2084
/* The address of the ALT_EMAC_GMAC_MAC_ADDR93_LOW register for the ALT_EMAC1_GMACGRP instance. */
2085
#define ALT_EMAC1_GMAC_MAC_ADDR93_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR93_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2086
/* The address of the ALT_EMAC_GMAC_MAC_ADDR94_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2087
#define ALT_EMAC1_GMAC_MAC_ADDR94_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR94_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2088
/* The address of the ALT_EMAC_GMAC_MAC_ADDR94_LOW register for the ALT_EMAC1_GMACGRP instance. */
2089
#define ALT_EMAC1_GMAC_MAC_ADDR94_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR94_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2090
/* The address of the ALT_EMAC_GMAC_MAC_ADDR95_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2091
#define ALT_EMAC1_GMAC_MAC_ADDR95_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR95_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2092
/* The address of the ALT_EMAC_GMAC_MAC_ADDR95_LOW register for the ALT_EMAC1_GMACGRP instance. */
2093
#define ALT_EMAC1_GMAC_MAC_ADDR95_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR95_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2094
/* The address of the ALT_EMAC_GMAC_MAC_ADDR96_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2095
#define ALT_EMAC1_GMAC_MAC_ADDR96_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR96_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2096
/* The address of the ALT_EMAC_GMAC_MAC_ADDR96_LOW register for the ALT_EMAC1_GMACGRP instance. */
2097
#define ALT_EMAC1_GMAC_MAC_ADDR96_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR96_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2098
/* The address of the ALT_EMAC_GMAC_MAC_ADDR97_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2099
#define ALT_EMAC1_GMAC_MAC_ADDR97_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR97_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2100
/* The address of the ALT_EMAC_GMAC_MAC_ADDR97_LOW register for the ALT_EMAC1_GMACGRP instance. */
2101
#define ALT_EMAC1_GMAC_MAC_ADDR97_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR97_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2102
/* The address of the ALT_EMAC_GMAC_MAC_ADDR98_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2103
#define ALT_EMAC1_GMAC_MAC_ADDR98_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR98_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2104
/* The address of the ALT_EMAC_GMAC_MAC_ADDR98_LOW register for the ALT_EMAC1_GMACGRP instance. */
2105
#define ALT_EMAC1_GMAC_MAC_ADDR98_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR98_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2106
/* The address of the ALT_EMAC_GMAC_MAC_ADDR99_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2107
#define ALT_EMAC1_GMAC_MAC_ADDR99_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR99_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2108
/* The address of the ALT_EMAC_GMAC_MAC_ADDR99_LOW register for the ALT_EMAC1_GMACGRP instance. */
2109
#define ALT_EMAC1_GMAC_MAC_ADDR99_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR99_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2110
/* The address of the ALT_EMAC_GMAC_MAC_ADDR100_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2111
#define ALT_EMAC1_GMAC_MAC_ADDR100_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR100_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2112
/* The address of the ALT_EMAC_GMAC_MAC_ADDR100_LOW register for the ALT_EMAC1_GMACGRP instance. */
2113
#define ALT_EMAC1_GMAC_MAC_ADDR100_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR100_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2114
/* The address of the ALT_EMAC_GMAC_MAC_ADDR101_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2115
#define ALT_EMAC1_GMAC_MAC_ADDR101_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR101_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2116
/* The address of the ALT_EMAC_GMAC_MAC_ADDR101_LOW register for the ALT_EMAC1_GMACGRP instance. */
2117
#define ALT_EMAC1_GMAC_MAC_ADDR101_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR101_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2118
/* The address of the ALT_EMAC_GMAC_MAC_ADDR102_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2119
#define ALT_EMAC1_GMAC_MAC_ADDR102_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR102_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2120
/* The address of the ALT_EMAC_GMAC_MAC_ADDR102_LOW register for the ALT_EMAC1_GMACGRP instance. */
2121
#define ALT_EMAC1_GMAC_MAC_ADDR102_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR102_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2122
/* The address of the ALT_EMAC_GMAC_MAC_ADDR103_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2123
#define ALT_EMAC1_GMAC_MAC_ADDR103_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR103_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2124
/* The address of the ALT_EMAC_GMAC_MAC_ADDR103_LOW register for the ALT_EMAC1_GMACGRP instance. */
2125
#define ALT_EMAC1_GMAC_MAC_ADDR103_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR103_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2126
/* The address of the ALT_EMAC_GMAC_MAC_ADDR104_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2127
#define ALT_EMAC1_GMAC_MAC_ADDR104_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR104_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2128
/* The address of the ALT_EMAC_GMAC_MAC_ADDR104_LOW register for the ALT_EMAC1_GMACGRP instance. */
2129
#define ALT_EMAC1_GMAC_MAC_ADDR104_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR104_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2130
/* The address of the ALT_EMAC_GMAC_MAC_ADDR105_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2131
#define ALT_EMAC1_GMAC_MAC_ADDR105_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR105_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2132
/* The address of the ALT_EMAC_GMAC_MAC_ADDR105_LOW register for the ALT_EMAC1_GMACGRP instance. */
2133
#define ALT_EMAC1_GMAC_MAC_ADDR105_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR105_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2134
/* The address of the ALT_EMAC_GMAC_MAC_ADDR106_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2135
#define ALT_EMAC1_GMAC_MAC_ADDR106_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR106_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2136
/* The address of the ALT_EMAC_GMAC_MAC_ADDR106_LOW register for the ALT_EMAC1_GMACGRP instance. */
2137
#define ALT_EMAC1_GMAC_MAC_ADDR106_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR106_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2138
/* The address of the ALT_EMAC_GMAC_MAC_ADDR107_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2139
#define ALT_EMAC1_GMAC_MAC_ADDR107_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR107_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2140
/* The address of the ALT_EMAC_GMAC_MAC_ADDR107_LOW register for the ALT_EMAC1_GMACGRP instance. */
2141
#define ALT_EMAC1_GMAC_MAC_ADDR107_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR107_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2142
/* The address of the ALT_EMAC_GMAC_MAC_ADDR108_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2143
#define ALT_EMAC1_GMAC_MAC_ADDR108_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR108_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2144
/* The address of the ALT_EMAC_GMAC_MAC_ADDR108_LOW register for the ALT_EMAC1_GMACGRP instance. */
2145
#define ALT_EMAC1_GMAC_MAC_ADDR108_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR108_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2146
/* The address of the ALT_EMAC_GMAC_MAC_ADDR109_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2147
#define ALT_EMAC1_GMAC_MAC_ADDR109_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR109_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2148
/* The address of the ALT_EMAC_GMAC_MAC_ADDR109_LOW register for the ALT_EMAC1_GMACGRP instance. */
2149
#define ALT_EMAC1_GMAC_MAC_ADDR109_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR109_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2150
/* The address of the ALT_EMAC_GMAC_MAC_ADDR110_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2151
#define ALT_EMAC1_GMAC_MAC_ADDR110_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR110_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2152
/* The address of the ALT_EMAC_GMAC_MAC_ADDR110_LOW register for the ALT_EMAC1_GMACGRP instance. */
2153
#define ALT_EMAC1_GMAC_MAC_ADDR110_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR110_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2154
/* The address of the ALT_EMAC_GMAC_MAC_ADDR111_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2155
#define ALT_EMAC1_GMAC_MAC_ADDR111_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR111_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2156
/* The address of the ALT_EMAC_GMAC_MAC_ADDR111_LOW register for the ALT_EMAC1_GMACGRP instance. */
2157
#define ALT_EMAC1_GMAC_MAC_ADDR111_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR111_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2158
/* The address of the ALT_EMAC_GMAC_MAC_ADDR112_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2159
#define ALT_EMAC1_GMAC_MAC_ADDR112_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR112_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2160
/* The address of the ALT_EMAC_GMAC_MAC_ADDR112_LOW register for the ALT_EMAC1_GMACGRP instance. */
2161
#define ALT_EMAC1_GMAC_MAC_ADDR112_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR112_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2162
/* The address of the ALT_EMAC_GMAC_MAC_ADDR113_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2163
#define ALT_EMAC1_GMAC_MAC_ADDR113_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR113_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2164
/* The address of the ALT_EMAC_GMAC_MAC_ADDR113_LOW register for the ALT_EMAC1_GMACGRP instance. */
2165
#define ALT_EMAC1_GMAC_MAC_ADDR113_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR113_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2166
/* The address of the ALT_EMAC_GMAC_MAC_ADDR114_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2167
#define ALT_EMAC1_GMAC_MAC_ADDR114_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR114_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2168
/* The address of the ALT_EMAC_GMAC_MAC_ADDR114_LOW register for the ALT_EMAC1_GMACGRP instance. */
2169
#define ALT_EMAC1_GMAC_MAC_ADDR114_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR114_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2170
/* The address of the ALT_EMAC_GMAC_MAC_ADDR115_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2171
#define ALT_EMAC1_GMAC_MAC_ADDR115_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR115_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2172
/* The address of the ALT_EMAC_GMAC_MAC_ADDR115_LOW register for the ALT_EMAC1_GMACGRP instance. */
2173
#define ALT_EMAC1_GMAC_MAC_ADDR115_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR115_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2174
/* The address of the ALT_EMAC_GMAC_MAC_ADDR116_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2175
#define ALT_EMAC1_GMAC_MAC_ADDR116_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR116_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2176
/* The address of the ALT_EMAC_GMAC_MAC_ADDR116_LOW register for the ALT_EMAC1_GMACGRP instance. */
2177
#define ALT_EMAC1_GMAC_MAC_ADDR116_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR116_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2178
/* The address of the ALT_EMAC_GMAC_MAC_ADDR117_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2179
#define ALT_EMAC1_GMAC_MAC_ADDR117_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR117_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2180
/* The address of the ALT_EMAC_GMAC_MAC_ADDR117_LOW register for the ALT_EMAC1_GMACGRP instance. */
2181
#define ALT_EMAC1_GMAC_MAC_ADDR117_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR117_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2182
/* The address of the ALT_EMAC_GMAC_MAC_ADDR118_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2183
#define ALT_EMAC1_GMAC_MAC_ADDR118_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR118_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2184
/* The address of the ALT_EMAC_GMAC_MAC_ADDR118_LOW register for the ALT_EMAC1_GMACGRP instance. */
2185
#define ALT_EMAC1_GMAC_MAC_ADDR118_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR118_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2186
/* The address of the ALT_EMAC_GMAC_MAC_ADDR119_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2187
#define ALT_EMAC1_GMAC_MAC_ADDR119_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR119_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2188
/* The address of the ALT_EMAC_GMAC_MAC_ADDR119_LOW register for the ALT_EMAC1_GMACGRP instance. */
2189
#define ALT_EMAC1_GMAC_MAC_ADDR119_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR119_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2190
/* The address of the ALT_EMAC_GMAC_MAC_ADDR120_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2191
#define ALT_EMAC1_GMAC_MAC_ADDR120_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR120_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2192
/* The address of the ALT_EMAC_GMAC_MAC_ADDR120_LOW register for the ALT_EMAC1_GMACGRP instance. */
2193
#define ALT_EMAC1_GMAC_MAC_ADDR120_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR120_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2194
/* The address of the ALT_EMAC_GMAC_MAC_ADDR121_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2195
#define ALT_EMAC1_GMAC_MAC_ADDR121_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR121_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2196
/* The address of the ALT_EMAC_GMAC_MAC_ADDR121_LOW register for the ALT_EMAC1_GMACGRP instance. */
2197
#define ALT_EMAC1_GMAC_MAC_ADDR121_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR121_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2198
/* The address of the ALT_EMAC_GMAC_MAC_ADDR122_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2199
#define ALT_EMAC1_GMAC_MAC_ADDR122_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR122_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2200
/* The address of the ALT_EMAC_GMAC_MAC_ADDR122_LOW register for the ALT_EMAC1_GMACGRP instance. */
2201
#define ALT_EMAC1_GMAC_MAC_ADDR122_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR122_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2202
/* The address of the ALT_EMAC_GMAC_MAC_ADDR123_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2203
#define ALT_EMAC1_GMAC_MAC_ADDR123_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR123_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2204
/* The address of the ALT_EMAC_GMAC_MAC_ADDR123_LOW register for the ALT_EMAC1_GMACGRP instance. */
2205
#define ALT_EMAC1_GMAC_MAC_ADDR123_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR123_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2206
/* The address of the ALT_EMAC_GMAC_MAC_ADDR124_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2207
#define ALT_EMAC1_GMAC_MAC_ADDR124_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR124_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2208
/* The address of the ALT_EMAC_GMAC_MAC_ADDR124_LOW register for the ALT_EMAC1_GMACGRP instance. */
2209
#define ALT_EMAC1_GMAC_MAC_ADDR124_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR124_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2210
/* The address of the ALT_EMAC_GMAC_MAC_ADDR125_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2211
#define ALT_EMAC1_GMAC_MAC_ADDR125_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR125_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2212
/* The address of the ALT_EMAC_GMAC_MAC_ADDR125_LOW register for the ALT_EMAC1_GMACGRP instance. */
2213
#define ALT_EMAC1_GMAC_MAC_ADDR125_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR125_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2214
/* The address of the ALT_EMAC_GMAC_MAC_ADDR126_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2215
#define ALT_EMAC1_GMAC_MAC_ADDR126_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR126_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2216
/* The address of the ALT_EMAC_GMAC_MAC_ADDR126_LOW register for the ALT_EMAC1_GMACGRP instance. */
2217
#define ALT_EMAC1_GMAC_MAC_ADDR126_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR126_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2218
/* The address of the ALT_EMAC_GMAC_MAC_ADDR127_HIGH register for the ALT_EMAC1_GMACGRP instance. */
2219
#define ALT_EMAC1_GMAC_MAC_ADDR127_HIGH_ADDR ALT_EMAC_GMAC_MAC_ADDR127_HIGH_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2220
/* The address of the ALT_EMAC_GMAC_MAC_ADDR127_LOW register for the ALT_EMAC1_GMACGRP instance. */
2221
#define ALT_EMAC1_GMAC_MAC_ADDR127_LOW_ADDR ALT_EMAC_GMAC_MAC_ADDR127_LOW_ADDR(ALT_EMAC1_GMACGRP_ADDR)
2222
/* The base address byte offset for the start of the ALT_EMAC1_GMACGRP component. */
2223
#define ALT_EMAC1_GMACGRP_OFST 0x0
2224
/* The start address of the ALT_EMAC1_GMACGRP component. */
2225
#define ALT_EMAC1_GMACGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_EMAC1_ADDR) + ALT_EMAC1_GMACGRP_OFST))
2226
/* The lower bound address range of the ALT_EMAC1_GMACGRP component. */
2227
#define ALT_EMAC1_GMACGRP_LB_ADDR ALT_EMAC1_GMACGRP_ADDR
2228
/* The upper bound address range of the ALT_EMAC1_GMACGRP component. */
2229
#define ALT_EMAC1_GMACGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC1_GMACGRP_ADDR) + 0xb80) - 1))
2230
2231
2232
2233
* Register Group Instance : dmagrp
2234
2235
* Instance dmagrp of register group ALT_EMAC_DMA.
2236
2237
2238
2239
/* The address of the ALT_EMAC_DMA_BUS_MOD register for the ALT_EMAC1_DMAGRP instance. */
2240
#define ALT_EMAC1_DMA_BUS_MOD_ADDR ALT_EMAC_DMA_BUS_MOD_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2241
/* The address of the ALT_EMAC_DMA_TX_POLL_DEMAND register for the ALT_EMAC1_DMAGRP instance. */
2242
#define ALT_EMAC1_DMA_TX_POLL_DEMAND_ADDR ALT_EMAC_DMA_TX_POLL_DEMAND_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2243
/* The address of the ALT_EMAC_DMA_RX_POLL_DEMAND register for the ALT_EMAC1_DMAGRP instance. */
2244
#define ALT_EMAC1_DMA_RX_POLL_DEMAND_ADDR ALT_EMAC_DMA_RX_POLL_DEMAND_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2245
/* The address of the ALT_EMAC_DMA_RX_DESC_LIST_ADDR register for the ALT_EMAC1_DMAGRP instance. */
2246
#define ALT_EMAC1_DMA_RX_DESC_LIST_ADDR_ADDR ALT_EMAC_DMA_RX_DESC_LIST_ADDR_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2247
/* The address of the ALT_EMAC_DMA_TX_DESC_LIST_ADDR register for the ALT_EMAC1_DMAGRP instance. */
2248
#define ALT_EMAC1_DMA_TX_DESC_LIST_ADDR_ADDR ALT_EMAC_DMA_TX_DESC_LIST_ADDR_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2249
/* The address of the ALT_EMAC_DMA_STAT register for the ALT_EMAC1_DMAGRP instance. */
2250
#define ALT_EMAC1_DMA_STAT_ADDR ALT_EMAC_DMA_STAT_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2251
/* The address of the ALT_EMAC_DMA_OP_MOD register for the ALT_EMAC1_DMAGRP instance. */
2252
#define ALT_EMAC1_DMA_OP_MOD_ADDR ALT_EMAC_DMA_OP_MOD_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2253
/* The address of the ALT_EMAC_DMA_INT_EN register for the ALT_EMAC1_DMAGRP instance. */
2254
#define ALT_EMAC1_DMA_INT_EN_ADDR ALT_EMAC_DMA_INT_EN_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2255
/* The address of the ALT_EMAC_DMA_MFRM_BUF_OVF_CNTR register for the ALT_EMAC1_DMAGRP instance. */
2256
#define ALT_EMAC1_DMA_MISSED_FRM_AND_BUF_OVF_CNTR_ADDR ALT_EMAC_DMA_MFRM_BUF_OVF_CNTR_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2257
/* The address of the ALT_EMAC_DMA_RX_INT_WDT register for the ALT_EMAC1_DMAGRP instance. */
2258
#define ALT_EMAC1_DMA_RX_INT_WDT_ADDR ALT_EMAC_DMA_RX_INT_WDT_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2259
/* The address of the ALT_EMAC_DMA_AXI_BUS_MOD register for the ALT_EMAC1_DMAGRP instance. */
2260
#define ALT_EMAC1_DMA_AXI_BUS_MOD_ADDR ALT_EMAC_DMA_AXI_BUS_MOD_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2261
/* The address of the ALT_EMAC_DMA_AHB_OR_AXI_STAT register for the ALT_EMAC1_DMAGRP instance. */
2262
#define ALT_EMAC1_DMA_AHB_OR_AXI_STAT_ADDR ALT_EMAC_DMA_AHB_OR_AXI_STAT_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2263
/* The address of the ALT_EMAC_DMA_CUR_HOST_TX_DESC register for the ALT_EMAC1_DMAGRP instance. */
2264
#define ALT_EMAC1_DMA_CUR_HOST_TX_DESC_ADDR ALT_EMAC_DMA_CUR_HOST_TX_DESC_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2265
/* The address of the ALT_EMAC_DMA_CUR_HOST_RX_DESC register for the ALT_EMAC1_DMAGRP instance. */
2266
#define ALT_EMAC1_DMA_CUR_HOST_RX_DESC_ADDR ALT_EMAC_DMA_CUR_HOST_RX_DESC_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2267
/* The address of the ALT_EMAC_DMA_CUR_HOST_TX_BUF_ADDR register for the ALT_EMAC1_DMAGRP instance. */
2268
#define ALT_EMAC1_DMA_CUR_HOST_TX_BUF_ADDR_ADDR ALT_EMAC_DMA_CUR_HOST_TX_BUF_ADDR_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2269
/* The address of the ALT_EMAC_DMA_CUR_HOST_RX_BUF_ADDR register for the ALT_EMAC1_DMAGRP instance. */
2270
#define ALT_EMAC1_DMA_CUR_HOST_RX_BUF_ADDR_ADDR ALT_EMAC_DMA_CUR_HOST_RX_BUF_ADDR_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2271
/* The address of the ALT_EMAC_DMA_HW_FEATURE register for the ALT_EMAC1_DMAGRP instance. */
2272
#define ALT_EMAC1_DMA_HW_FEATURE_ADDR ALT_EMAC_DMA_HW_FEATURE_ADDR(ALT_EMAC1_DMAGRP_ADDR)
2273
/* The base address byte offset for the start of the ALT_EMAC1_DMAGRP component. */
2274
#define ALT_EMAC1_DMAGRP_OFST 0x1000
2275
/* The start address of the ALT_EMAC1_DMAGRP component. */
2276
#define ALT_EMAC1_DMAGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_EMAC1_ADDR) + ALT_EMAC1_DMAGRP_OFST))
2277
/* The lower bound address range of the ALT_EMAC1_DMAGRP component. */
2278
#define ALT_EMAC1_DMAGRP_LB_ADDR ALT_EMAC1_DMAGRP_ADDR
2279
/* The upper bound address range of the ALT_EMAC1_DMAGRP component. */
2280
#define ALT_EMAC1_DMAGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC1_DMAGRP_ADDR) + 0x5c) - 1))
2281
2282
2283
/* The base address byte offset for the start of the ALT_EMAC1 component. */
2284
#define ALT_EMAC1_OFST 0xff702000
2285
/* The start address of the ALT_EMAC1 component. */
2286
#define ALT_EMAC1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_EMAC1_OFST))
2287
/* The lower bound address range of the ALT_EMAC1 component. */
2288
#define ALT_EMAC1_LB_ADDR ALT_EMAC1_ADDR
2289
/* The upper bound address range of the ALT_EMAC1 component. */
2290
#define ALT_EMAC1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_EMAC1_ADDR) + 0x2000) - 1))
2291
2292
2293
2294
* Component Instance : sdmmc
2295
2296
* Instance sdmmc of component ALT_SDMMC.
2297
2298
2299
2300
/* The address of the ALT_SDMMC_CTL register for the ALT_SDMMC instance. */
2301
#define ALT_SDMMC_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CTL_OFST))
2302
/* The address of the ALT_SDMMC_PWREN register for the ALT_SDMMC instance. */
2303
#define ALT_SDMMC_PWREN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_PWREN_OFST))
2304
/* The address of the ALT_SDMMC_CLKDIV register for the ALT_SDMMC instance. */
2305
#define ALT_SDMMC_CLKDIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CLKDIV_OFST))
2306
/* The address of the ALT_SDMMC_CLKSRC register for the ALT_SDMMC instance. */
2307
#define ALT_SDMMC_CLKSRC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CLKSRC_OFST))
2308
/* The address of the ALT_SDMMC_CLKENA register for the ALT_SDMMC instance. */
2309
#define ALT_SDMMC_CLKENA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CLKENA_OFST))
2310
/* The address of the ALT_SDMMC_TMOUT register for the ALT_SDMMC instance. */
2311
#define ALT_SDMMC_TMOUT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_TMOUT_OFST))
2312
/* The address of the ALT_SDMMC_CTYPE register for the ALT_SDMMC instance. */
2313
#define ALT_SDMMC_CTYPE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CTYPE_OFST))
2314
/* The address of the ALT_SDMMC_BLKSIZ register for the ALT_SDMMC instance. */
2315
#define ALT_SDMMC_BLKSIZ_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_BLKSIZ_OFST))
2316
/* The address of the ALT_SDMMC_BYTCNT register for the ALT_SDMMC instance. */
2317
#define ALT_SDMMC_BYTCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_BYTCNT_OFST))
2318
/* The address of the ALT_SDMMC_INTMSK register for the ALT_SDMMC instance. */
2319
#define ALT_SDMMC_INTMSK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_INTMSK_OFST))
2320
/* The address of the ALT_SDMMC_CMDARG register for the ALT_SDMMC instance. */
2321
#define ALT_SDMMC_CMDARG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CMDARG_OFST))
2322
/* The address of the ALT_SDMMC_CMD register for the ALT_SDMMC instance. */
2323
#define ALT_SDMMC_CMD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CMD_OFST))
2324
/* The address of the ALT_SDMMC_RESP0 register for the ALT_SDMMC instance. */
2325
#define ALT_SDMMC_RESP0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RESP0_OFST))
2326
/* The address of the ALT_SDMMC_RESP1 register for the ALT_SDMMC instance. */
2327
#define ALT_SDMMC_RESP1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RESP1_OFST))
2328
/* The address of the ALT_SDMMC_RESP2 register for the ALT_SDMMC instance. */
2329
#define ALT_SDMMC_RESP2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RESP2_OFST))
2330
/* The address of the ALT_SDMMC_RESP3 register for the ALT_SDMMC instance. */
2331
#define ALT_SDMMC_RESP3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RESP3_OFST))
2332
/* The address of the ALT_SDMMC_MINTSTS register for the ALT_SDMMC instance. */
2333
#define ALT_SDMMC_MINTSTS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_MINTSTS_OFST))
2334
/* The address of the ALT_SDMMC_RINTSTS register for the ALT_SDMMC instance. */
2335
#define ALT_SDMMC_RINTSTS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RINTSTS_OFST))
2336
/* The address of the ALT_SDMMC_STAT register for the ALT_SDMMC instance. */
2337
#define ALT_SDMMC_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_STAT_OFST))
2338
/* The address of the ALT_SDMMC_FIFOTH register for the ALT_SDMMC instance. */
2339
#define ALT_SDMMC_FIFOTH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_FIFOTH_OFST))
2340
/* The address of the ALT_SDMMC_CDETECT register for the ALT_SDMMC instance. */
2341
#define ALT_SDMMC_CDETECT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CDETECT_OFST))
2342
/* The address of the ALT_SDMMC_WRTPRT register for the ALT_SDMMC instance. */
2343
#define ALT_SDMMC_WRTPRT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_WRTPRT_OFST))
2344
/* The address of the ALT_SDMMC_TCBCNT register for the ALT_SDMMC instance. */
2345
#define ALT_SDMMC_TCBCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_TCBCNT_OFST))
2346
/* The address of the ALT_SDMMC_TBBCNT register for the ALT_SDMMC instance. */
2347
#define ALT_SDMMC_TBBCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_TBBCNT_OFST))
2348
/* The address of the ALT_SDMMC_DEBNCE register for the ALT_SDMMC instance. */
2349
#define ALT_SDMMC_DEBNCE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_DEBNCE_OFST))
2350
/* The address of the ALT_SDMMC_USRID register for the ALT_SDMMC instance. */
2351
#define ALT_SDMMC_USRID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_USRID_OFST))
2352
/* The address of the ALT_SDMMC_VERID register for the ALT_SDMMC instance. */
2353
#define ALT_SDMMC_VERID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_VERID_OFST))
2354
/* The address of the ALT_SDMMC_HCON register for the ALT_SDMMC instance. */
2355
#define ALT_SDMMC_HCON_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_HCON_OFST))
2356
/* The address of the ALT_SDMMC_UHS_REG register for the ALT_SDMMC instance. */
2357
#define ALT_SDMMC_UHS_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_UHS_REG_OFST))
2358
/* The address of the ALT_SDMMC_RST_N register for the ALT_SDMMC instance. */
2359
#define ALT_SDMMC_RST_N_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_RST_N_OFST))
2360
/* The address of the ALT_SDMMC_BMOD register for the ALT_SDMMC instance. */
2361
#define ALT_SDMMC_BMOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_BMOD_OFST))
2362
/* The address of the ALT_SDMMC_PLDMND register for the ALT_SDMMC instance. */
2363
#define ALT_SDMMC_PLDMND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_PLDMND_OFST))
2364
/* The address of the ALT_SDMMC_DBADDR register for the ALT_SDMMC instance. */
2365
#define ALT_SDMMC_DBADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_DBADDR_OFST))
2366
/* The address of the ALT_SDMMC_IDSTS register for the ALT_SDMMC instance. */
2367
#define ALT_SDMMC_IDSTS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_IDSTS_OFST))
2368
/* The address of the ALT_SDMMC_IDINTEN register for the ALT_SDMMC instance. */
2369
#define ALT_SDMMC_IDINTEN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_IDINTEN_OFST))
2370
/* The address of the ALT_SDMMC_DSCADDR register for the ALT_SDMMC instance. */
2371
#define ALT_SDMMC_DSCADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_DSCADDR_OFST))
2372
/* The address of the ALT_SDMMC_BUFADDR register for the ALT_SDMMC instance. */
2373
#define ALT_SDMMC_BUFADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_BUFADDR_OFST))
2374
/* The address of the ALT_SDMMC_CARDTHRCTL register for the ALT_SDMMC instance. */
2375
#define ALT_SDMMC_CARDTHRCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_CARDTHRCTL_OFST))
2376
/* The address of the ALT_SDMMC_BACK_END_POWER_R register for the ALT_SDMMC instance. */
2377
#define ALT_SDMMC_BACK_END_POWER_R_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_BACK_END_POWER_R_OFST))
2378
/* The address of the ALT_SDMMC_DATA register for the ALT_SDMMC instance. */
2379
#define ALT_SDMMC_DATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDMMC_ADDR) + ALT_SDMMC_DATA_OFST))
2380
/* The base address byte offset for the start of the ALT_SDMMC component. */
2381
#define ALT_SDMMC_OFST 0xff704000
2382
/* The start address of the ALT_SDMMC component. */
2383
#define ALT_SDMMC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SDMMC_OFST))
2384
/* The lower bound address range of the ALT_SDMMC component. */
2385
#define ALT_SDMMC_LB_ADDR ALT_SDMMC_ADDR
2386
/* The upper bound address range of the ALT_SDMMC component. */
2387
#define ALT_SDMMC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SDMMC_ADDR) + 0x400) - 1))
2388
2389
2390
2391
* Component Instance : qspiregs
2392
2393
* Instance qspiregs of component ALT_QSPI.
2394
2395
2396
2397
/* The address of the ALT_QSPI_CFG register for the ALT_QSPI instance. */
2398
#define ALT_QSPI_CFG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_CFG_OFST))
2399
/* The address of the ALT_QSPI_DEVRD register for the ALT_QSPI instance. */
2400
#define ALT_QSPI_DEVRD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_DEVRD_OFST))
2401
/* The address of the ALT_QSPI_DEVWR register for the ALT_QSPI instance. */
2402
#define ALT_QSPI_DEVWR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_DEVWR_OFST))
2403
/* The address of the ALT_QSPI_DELAY register for the ALT_QSPI instance. */
2404
#define ALT_QSPI_DELAY_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_DELAY_OFST))
2405
/* The address of the ALT_QSPI_RDDATACAP register for the ALT_QSPI instance. */
2406
#define ALT_QSPI_RDDATACAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_RDDATACAP_OFST))
2407
/* The address of the ALT_QSPI_DEVSZ register for the ALT_QSPI instance. */
2408
#define ALT_QSPI_DEVSZ_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_DEVSZ_OFST))
2409
/* The address of the ALT_QSPI_SRAMPART register for the ALT_QSPI instance. */
2410
#define ALT_QSPI_SRAMPART_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_SRAMPART_OFST))
2411
/* The address of the ALT_QSPI_INDADDRTRIG register for the ALT_QSPI instance. */
2412
#define ALT_QSPI_INDADDRTRIG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDADDRTRIG_OFST))
2413
/* The address of the ALT_QSPI_DMAPER register for the ALT_QSPI instance. */
2414
#define ALT_QSPI_DMAPER_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_DMAPER_OFST))
2415
/* The address of the ALT_QSPI_REMAPADDR register for the ALT_QSPI instance. */
2416
#define ALT_QSPI_REMAPADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_REMAPADDR_OFST))
2417
/* The address of the ALT_QSPI_MODBIT register for the ALT_QSPI instance. */
2418
#define ALT_QSPI_MODBIT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_MODBIT_OFST))
2419
/* The address of the ALT_QSPI_SRAMFILL register for the ALT_QSPI instance. */
2420
#define ALT_QSPI_SRAMFILL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_SRAMFILL_OFST))
2421
/* The address of the ALT_QSPI_TXTHRESH register for the ALT_QSPI instance. */
2422
#define ALT_QSPI_TXTHRESH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_TXTHRESH_OFST))
2423
/* The address of the ALT_QSPI_RXTHRESH register for the ALT_QSPI instance. */
2424
#define ALT_QSPI_RXTHRESH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_RXTHRESH_OFST))
2425
/* The address of the ALT_QSPI_IRQSTAT register for the ALT_QSPI instance. */
2426
#define ALT_QSPI_IRQSTAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_IRQSTAT_OFST))
2427
/* The address of the ALT_QSPI_IRQMSK register for the ALT_QSPI instance. */
2428
#define ALT_QSPI_IRQMSK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_IRQMSK_OFST))
2429
/* The address of the ALT_QSPI_LOWWRPROT register for the ALT_QSPI instance. */
2430
#define ALT_QSPI_LOWWRPROT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_LOWWRPROT_OFST))
2431
/* The address of the ALT_QSPI_UPPWRPROT register for the ALT_QSPI instance. */
2432
#define ALT_QSPI_UPPWRPROT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_UPPWRPROT_OFST))
2433
/* The address of the ALT_QSPI_WRPROT register for the ALT_QSPI instance. */
2434
#define ALT_QSPI_WRPROT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_WRPROT_OFST))
2435
/* The address of the ALT_QSPI_INDRD register for the ALT_QSPI instance. */
2436
#define ALT_QSPI_INDRD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDRD_OFST))
2437
/* The address of the ALT_QSPI_INDRDWATER register for the ALT_QSPI instance. */
2438
#define ALT_QSPI_INDRDWATER_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDRDWATER_OFST))
2439
/* The address of the ALT_QSPI_INDRDSTADDR register for the ALT_QSPI instance. */
2440
#define ALT_QSPI_INDRDSTADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDRDSTADDR_OFST))
2441
/* The address of the ALT_QSPI_INDRDCNT register for the ALT_QSPI instance. */
2442
#define ALT_QSPI_INDRDCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDRDCNT_OFST))
2443
/* The address of the ALT_QSPI_INDWR register for the ALT_QSPI instance. */
2444
#define ALT_QSPI_INDWR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDWR_OFST))
2445
/* The address of the ALT_QSPI_INDWRWATER register for the ALT_QSPI instance. */
2446
#define ALT_QSPI_INDWRWATER_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDWRWATER_OFST))
2447
/* The address of the ALT_QSPI_INDWRSTADDR register for the ALT_QSPI instance. */
2448
#define ALT_QSPI_INDWRSTADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDWRSTADDR_OFST))
2449
/* The address of the ALT_QSPI_INDWRCNT register for the ALT_QSPI instance. */
2450
#define ALT_QSPI_INDWRCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_INDWRCNT_OFST))
2451
/* The address of the ALT_QSPI_FLSHCMD register for the ALT_QSPI instance. */
2452
#define ALT_QSPI_FLSHCMD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMD_OFST))
2453
/* The address of the ALT_QSPI_FLSHCMDADDR register for the ALT_QSPI instance. */
2454
#define ALT_QSPI_FLSHCMDADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMDADDR_OFST))
2455
/* The address of the ALT_QSPI_FLSHCMDRDDATALO register for the ALT_QSPI instance. */
2456
#define ALT_QSPI_FLSHCMDRDDATALO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMDRDDATALO_OFST))
2457
/* The address of the ALT_QSPI_FLSHCMDRDDATAUP register for the ALT_QSPI instance. */
2458
#define ALT_QSPI_FLSHCMDRDDATAUP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMDRDDATAUP_OFST))
2459
/* The address of the ALT_QSPI_FLSHCMDWRDATALO register for the ALT_QSPI instance. */
2460
#define ALT_QSPI_FLSHCMDWRDATALO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMDWRDATALO_OFST))
2461
/* The address of the ALT_QSPI_FLSHCMDWRDATAUP register for the ALT_QSPI instance. */
2462
#define ALT_QSPI_FLSHCMDWRDATAUP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_FLSHCMDWRDATAUP_OFST))
2463
/* The address of the ALT_QSPI_MODULEID register for the ALT_QSPI instance. */
2464
#define ALT_QSPI_MODULEID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_QSPI_ADDR) + ALT_QSPI_MODULEID_OFST))
2465
/* The base address byte offset for the start of the ALT_QSPI component. */
2466
#define ALT_QSPI_OFST 0xff705000
2467
/* The start address of the ALT_QSPI component. */
2468
#define ALT_QSPI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_QSPI_OFST))
2469
/* The lower bound address range of the ALT_QSPI component. */
2470
#define ALT_QSPI_LB_ADDR ALT_QSPI_ADDR
2471
/* The upper bound address range of the ALT_QSPI component. */
2472
#define ALT_QSPI_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_QSPI_ADDR) + 0x100) - 1))
2473
2474
2475
2476
* Component Instance : fpgamgrregs
2477
2478
* Instance fpgamgrregs of component ALT_FPGAMGR.
2479
2480
2481
2482
/* The address of the ALT_FPGAMGR_STAT register for the ALT_FPGAMGR instance. */
2483
#define ALT_FPGAMGR_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_STAT_OFST))
2484
/* The address of the ALT_FPGAMGR_CTL register for the ALT_FPGAMGR instance. */
2485
#define ALT_FPGAMGR_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_CTL_OFST))
2486
/* The address of the ALT_FPGAMGR_DCLKCNT register for the ALT_FPGAMGR instance. */
2487
#define ALT_FPGAMGR_DCLKCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_DCLKCNT_OFST))
2488
/* The address of the ALT_FPGAMGR_DCLKSTAT register for the ALT_FPGAMGR instance. */
2489
#define ALT_FPGAMGR_DCLKSTAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_DCLKSTAT_OFST))
2490
/* The address of the ALT_FPGAMGR_GPO register for the ALT_FPGAMGR instance. */
2491
#define ALT_FPGAMGR_GPO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_GPO_OFST))
2492
/* The address of the ALT_FPGAMGR_GPI register for the ALT_FPGAMGR instance. */
2493
#define ALT_FPGAMGR_GPI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_GPI_OFST))
2494
/* The address of the ALT_FPGAMGR_MISCI register for the ALT_FPGAMGR instance. */
2495
#define ALT_FPGAMGR_MISCI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_MISCI_OFST))
2496
2497
* Register Group Instance : mon
2498
2499
* Instance mon of register group ALT_MON.
2500
2501
2502
2503
/* The address of the ALT_MON_GPIO_INTEN register for the ALT_FPGAMGR_MON instance. */
2504
#define ALT_FPGAMGR_MON_GPIO_INTEN_ADDR ALT_MON_GPIO_INTEN_ADDR(ALT_FPGAMGR_MON_ADDR)
2505
/* The address of the ALT_MON_GPIO_INTMSK register for the ALT_FPGAMGR_MON instance. */
2506
#define ALT_FPGAMGR_MON_GPIO_INTMSK_ADDR ALT_MON_GPIO_INTMSK_ADDR(ALT_FPGAMGR_MON_ADDR)
2507
/* The address of the ALT_MON_GPIO_INTTYPE_LEVEL register for the ALT_FPGAMGR_MON instance. */
2508
#define ALT_FPGAMGR_MON_GPIO_INTTYPE_LEVEL_ADDR ALT_MON_GPIO_INTTYPE_LEVEL_ADDR(ALT_FPGAMGR_MON_ADDR)
2509
/* The address of the ALT_MON_GPIO_INT_POL register for the ALT_FPGAMGR_MON instance. */
2510
#define ALT_FPGAMGR_MON_GPIO_INT_POL_ADDR ALT_MON_GPIO_INT_POL_ADDR(ALT_FPGAMGR_MON_ADDR)
2511
/* The address of the ALT_MON_GPIO_INTSTAT register for the ALT_FPGAMGR_MON instance. */
2512
#define ALT_FPGAMGR_MON_GPIO_INTSTAT_ADDR ALT_MON_GPIO_INTSTAT_ADDR(ALT_FPGAMGR_MON_ADDR)
2513
/* The address of the ALT_MON_GPIO_RAW_INTSTAT register for the ALT_FPGAMGR_MON instance. */
2514
#define ALT_FPGAMGR_MON_GPIO_RAW_INTSTAT_ADDR ALT_MON_GPIO_RAW_INTSTAT_ADDR(ALT_FPGAMGR_MON_ADDR)
2515
/* The address of the ALT_MON_GPIO_PORTA_EOI register for the ALT_FPGAMGR_MON instance. */
2516
#define ALT_FPGAMGR_MON_GPIO_PORTA_EOI_ADDR ALT_MON_GPIO_PORTA_EOI_ADDR(ALT_FPGAMGR_MON_ADDR)
2517
/* The address of the ALT_MON_GPIO_EXT_PORTA register for the ALT_FPGAMGR_MON instance. */
2518
#define ALT_FPGAMGR_MON_GPIO_EXT_PORTA_ADDR ALT_MON_GPIO_EXT_PORTA_ADDR(ALT_FPGAMGR_MON_ADDR)
2519
/* The address of the ALT_MON_GPIO_LS_SYNC register for the ALT_FPGAMGR_MON instance. */
2520
#define ALT_FPGAMGR_MON_GPIO_LS_SYNC_ADDR ALT_MON_GPIO_LS_SYNC_ADDR(ALT_FPGAMGR_MON_ADDR)
2521
/* The address of the ALT_MON_GPIO_VER_ID_CODE register for the ALT_FPGAMGR_MON instance. */
2522
#define ALT_FPGAMGR_MON_GPIO_VER_ID_CODE_ADDR ALT_MON_GPIO_VER_ID_CODE_ADDR(ALT_FPGAMGR_MON_ADDR)
2523
/* The address of the ALT_MON_GPIO_CFG_REG2 register for the ALT_FPGAMGR_MON instance. */
2524
#define ALT_FPGAMGR_MON_GPIO_CFG_REG2_ADDR ALT_MON_GPIO_CFG_REG2_ADDR(ALT_FPGAMGR_MON_ADDR)
2525
/* The address of the ALT_MON_GPIO_CFG_REG1 register for the ALT_FPGAMGR_MON instance. */
2526
#define ALT_FPGAMGR_MON_GPIO_CFG_REG1_ADDR ALT_MON_GPIO_CFG_REG1_ADDR(ALT_FPGAMGR_MON_ADDR)
2527
/* The base address byte offset for the start of the ALT_FPGAMGR_MON component. */
2528
#define ALT_FPGAMGR_MON_OFST 0x800
2529
/* The start address of the ALT_FPGAMGR_MON component. */
2530
#define ALT_FPGAMGR_MON_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGR_ADDR) + ALT_FPGAMGR_MON_OFST))
2531
/* The lower bound address range of the ALT_FPGAMGR_MON component. */
2532
#define ALT_FPGAMGR_MON_LB_ADDR ALT_FPGAMGR_MON_ADDR
2533
/* The upper bound address range of the ALT_FPGAMGR_MON component. */
2534
#define ALT_FPGAMGR_MON_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_FPGAMGR_MON_ADDR) + 0x80) - 1))
2535
2536
2537
/* The base address byte offset for the start of the ALT_FPGAMGR component. */
2538
#define ALT_FPGAMGR_OFST 0xff706000
2539
/* The start address of the ALT_FPGAMGR component. */
2540
#define ALT_FPGAMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_FPGAMGR_OFST))
2541
/* The lower bound address range of the ALT_FPGAMGR component. */
2542
#define ALT_FPGAMGR_LB_ADDR ALT_FPGAMGR_ADDR
2543
/* The upper bound address range of the ALT_FPGAMGR component. */
2544
#define ALT_FPGAMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_FPGAMGR_ADDR) + 0x1000) - 1))
2545
2546
2547
2548
* Component Instance : acpidmap
2549
2550
* Instance acpidmap of component ALT_ACPIDMAP.
2551
2552
2553
2554
/* The address of the ALT_ACPIDMAP_VID2RD register for the ALT_ACPIDMAP instance. */
2555
#define ALT_ACPIDMAP_VID2RD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID2RD_OFST))
2556
/* The address of the ALT_ACPIDMAP_VID2WR register for the ALT_ACPIDMAP instance. */
2557
#define ALT_ACPIDMAP_VID2WR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID2WR_OFST))
2558
/* The address of the ALT_ACPIDMAP_VID3RD register for the ALT_ACPIDMAP instance. */
2559
#define ALT_ACPIDMAP_VID3RD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID3RD_OFST))
2560
/* The address of the ALT_ACPIDMAP_VID3WR register for the ALT_ACPIDMAP instance. */
2561
#define ALT_ACPIDMAP_VID3WR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID3WR_OFST))
2562
/* The address of the ALT_ACPIDMAP_VID4RD register for the ALT_ACPIDMAP instance. */
2563
#define ALT_ACPIDMAP_VID4RD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID4RD_OFST))
2564
/* The address of the ALT_ACPIDMAP_VID4WR register for the ALT_ACPIDMAP instance. */
2565
#define ALT_ACPIDMAP_VID4WR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID4WR_OFST))
2566
/* The address of the ALT_ACPIDMAP_VID5RD register for the ALT_ACPIDMAP instance. */
2567
#define ALT_ACPIDMAP_VID5RD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID5RD_OFST))
2568
/* The address of the ALT_ACPIDMAP_VID5WR register for the ALT_ACPIDMAP instance. */
2569
#define ALT_ACPIDMAP_VID5WR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID5WR_OFST))
2570
/* The address of the ALT_ACPIDMAP_VID6RD register for the ALT_ACPIDMAP instance. */
2571
#define ALT_ACPIDMAP_VID6RD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID6RD_OFST))
2572
/* The address of the ALT_ACPIDMAP_VID6WR register for the ALT_ACPIDMAP instance. */
2573
#define ALT_ACPIDMAP_VID6WR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID6WR_OFST))
2574
/* The address of the ALT_ACPIDMAP_DYNRD register for the ALT_ACPIDMAP instance. */
2575
#define ALT_ACPIDMAP_DYNRD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_DYNRD_OFST))
2576
/* The address of the ALT_ACPIDMAP_DYNWR register for the ALT_ACPIDMAP instance. */
2577
#define ALT_ACPIDMAP_DYNWR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_DYNWR_OFST))
2578
/* The address of the ALT_ACPIDMAP_VID2RD_S register for the ALT_ACPIDMAP instance. */
2579
#define ALT_ACPIDMAP_VID2RD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID2RD_S_OFST))
2580
/* The address of the ALT_ACPIDMAP_VID2WR_S register for the ALT_ACPIDMAP instance. */
2581
#define ALT_ACPIDMAP_VID2WR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID2WR_S_OFST))
2582
/* The address of the ALT_ACPIDMAP_VID3RD_S register for the ALT_ACPIDMAP instance. */
2583
#define ALT_ACPIDMAP_VID3RD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID3RD_S_OFST))
2584
/* The address of the ALT_ACPIDMAP_VID3WR_S register for the ALT_ACPIDMAP instance. */
2585
#define ALT_ACPIDMAP_VID3WR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID3WR_S_OFST))
2586
/* The address of the ALT_ACPIDMAP_VID4RD_S register for the ALT_ACPIDMAP instance. */
2587
#define ALT_ACPIDMAP_VID4RD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID4RD_S_OFST))
2588
/* The address of the ALT_ACPIDMAP_VID4WR_S register for the ALT_ACPIDMAP instance. */
2589
#define ALT_ACPIDMAP_VID4WR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID4WR_S_OFST))
2590
/* The address of the ALT_ACPIDMAP_VID5RD_S register for the ALT_ACPIDMAP instance. */
2591
#define ALT_ACPIDMAP_VID5RD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID5RD_S_OFST))
2592
/* The address of the ALT_ACPIDMAP_VID5WR_S register for the ALT_ACPIDMAP instance. */
2593
#define ALT_ACPIDMAP_VID5WR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID5WR_S_OFST))
2594
/* The address of the ALT_ACPIDMAP_VID6RD_S register for the ALT_ACPIDMAP instance. */
2595
#define ALT_ACPIDMAP_VID6RD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID6RD_S_OFST))
2596
/* The address of the ALT_ACPIDMAP_VID6WR_S register for the ALT_ACPIDMAP instance. */
2597
#define ALT_ACPIDMAP_VID6WR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_VID6WR_S_OFST))
2598
/* The address of the ALT_ACPIDMAP_DYNRD_S register for the ALT_ACPIDMAP instance. */
2599
#define ALT_ACPIDMAP_DYNRD_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_DYNRD_S_OFST))
2600
/* The address of the ALT_ACPIDMAP_DYNWR_S register for the ALT_ACPIDMAP instance. */
2601
#define ALT_ACPIDMAP_DYNWR_S_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + ALT_ACPIDMAP_DYNWR_S_OFST))
2602
/* The base address byte offset for the start of the ALT_ACPIDMAP component. */
2603
#define ALT_ACPIDMAP_OFST 0xff707000
2604
/* The start address of the ALT_ACPIDMAP component. */
2605
#define ALT_ACPIDMAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_ACPIDMAP_OFST))
2606
/* The lower bound address range of the ALT_ACPIDMAP component. */
2607
#define ALT_ACPIDMAP_LB_ADDR ALT_ACPIDMAP_ADDR
2608
/* The upper bound address range of the ALT_ACPIDMAP component. */
2609
#define ALT_ACPIDMAP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_ACPIDMAP_ADDR) + 0x1000) - 1))
2610
2611
2612
2613
* Component Instance : gpio0
2614
2615
* Instance gpio0 of component ALT_GPIO.
2616
2617
2618
2619
/* The address of the ALT_GPIO_SWPORTA_DR register for the ALT_GPIO0 instance. */
2620
#define ALT_GPIO0_SWPORTA_DR_ADDR ALT_GPIO_SWPORTA_DR_ADDR(ALT_GPIO0_ADDR)
2621
/* The address of the ALT_GPIO_SWPORTA_DDR register for the ALT_GPIO0 instance. */
2622
#define ALT_GPIO0_SWPORTA_DDR_ADDR ALT_GPIO_SWPORTA_DDR_ADDR(ALT_GPIO0_ADDR)
2623
/* The address of the ALT_GPIO_INTEN register for the ALT_GPIO0 instance. */
2624
#define ALT_GPIO0_INTEN_ADDR ALT_GPIO_INTEN_ADDR(ALT_GPIO0_ADDR)
2625
/* The address of the ALT_GPIO_INTMSK register for the ALT_GPIO0 instance. */
2626
#define ALT_GPIO0_INTMSK_ADDR ALT_GPIO_INTMSK_ADDR(ALT_GPIO0_ADDR)
2627
/* The address of the ALT_GPIO_INTTYPE_LEVEL register for the ALT_GPIO0 instance. */
2628
#define ALT_GPIO0_INTTYPE_LEVEL_ADDR ALT_GPIO_INTTYPE_LEVEL_ADDR(ALT_GPIO0_ADDR)
2629
/* The address of the ALT_GPIO_INT_POL register for the ALT_GPIO0 instance. */
2630
#define ALT_GPIO0_INT_POL_ADDR ALT_GPIO_INT_POL_ADDR(ALT_GPIO0_ADDR)
2631
/* The address of the ALT_GPIO_INTSTAT register for the ALT_GPIO0 instance. */
2632
#define ALT_GPIO0_INTSTAT_ADDR ALT_GPIO_INTSTAT_ADDR(ALT_GPIO0_ADDR)
2633
/* The address of the ALT_GPIO_RAW_INTSTAT register for the ALT_GPIO0 instance. */
2634
#define ALT_GPIO0_RAW_INTSTAT_ADDR ALT_GPIO_RAW_INTSTAT_ADDR(ALT_GPIO0_ADDR)
2635
/* The address of the ALT_GPIO_DEBOUNCE register for the ALT_GPIO0 instance. */
2636
#define ALT_GPIO0_DEBOUNCE_ADDR ALT_GPIO_DEBOUNCE_ADDR(ALT_GPIO0_ADDR)
2637
/* The address of the ALT_GPIO_PORTA_EOI register for the ALT_GPIO0 instance. */
2638
#define ALT_GPIO0_PORTA_EOI_ADDR ALT_GPIO_PORTA_EOI_ADDR(ALT_GPIO0_ADDR)
2639
/* The address of the ALT_GPIO_EXT_PORTA register for the ALT_GPIO0 instance. */
2640
#define ALT_GPIO0_EXT_PORTA_ADDR ALT_GPIO_EXT_PORTA_ADDR(ALT_GPIO0_ADDR)
2641
/* The address of the ALT_GPIO_LS_SYNC register for the ALT_GPIO0 instance. */
2642
#define ALT_GPIO0_LS_SYNC_ADDR ALT_GPIO_LS_SYNC_ADDR(ALT_GPIO0_ADDR)
2643
/* The address of the ALT_GPIO_ID_CODE register for the ALT_GPIO0 instance. */
2644
#define ALT_GPIO0_ID_CODE_ADDR ALT_GPIO_ID_CODE_ADDR(ALT_GPIO0_ADDR)
2645
/* The address of the ALT_GPIO_VER_ID_CODE register for the ALT_GPIO0 instance. */
2646
#define ALT_GPIO0_VER_ID_CODE_ADDR ALT_GPIO_VER_ID_CODE_ADDR(ALT_GPIO0_ADDR)
2647
/* The address of the ALT_GPIO_CFG_REG2 register for the ALT_GPIO0 instance. */
2648
#define ALT_GPIO0_CFG_REG2_ADDR ALT_GPIO_CFG_REG2_ADDR(ALT_GPIO0_ADDR)
2649
/* The address of the ALT_GPIO_CFG_REG1 register for the ALT_GPIO0 instance. */
2650
#define ALT_GPIO0_CFG_REG1_ADDR ALT_GPIO_CFG_REG1_ADDR(ALT_GPIO0_ADDR)
2651
/* The base address byte offset for the start of the ALT_GPIO0 component. */
2652
#define ALT_GPIO0_OFST 0xff708000
2653
/* The start address of the ALT_GPIO0 component. */
2654
#define ALT_GPIO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_GPIO0_OFST))
2655
/* The lower bound address range of the ALT_GPIO0 component. */
2656
#define ALT_GPIO0_LB_ADDR ALT_GPIO0_ADDR
2657
/* The upper bound address range of the ALT_GPIO0 component. */
2658
#define ALT_GPIO0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_GPIO0_ADDR) + 0x80) - 1))
2659
2660
2661
2662
* Component Instance : gpio1
2663
2664
* Instance gpio1 of component ALT_GPIO.
2665
2666
2667
2668
/* The address of the ALT_GPIO_SWPORTA_DR register for the ALT_GPIO1 instance. */
2669
#define ALT_GPIO1_SWPORTA_DR_ADDR ALT_GPIO_SWPORTA_DR_ADDR(ALT_GPIO1_ADDR)
2670
/* The address of the ALT_GPIO_SWPORTA_DDR register for the ALT_GPIO1 instance. */
2671
#define ALT_GPIO1_SWPORTA_DDR_ADDR ALT_GPIO_SWPORTA_DDR_ADDR(ALT_GPIO1_ADDR)
2672
/* The address of the ALT_GPIO_INTEN register for the ALT_GPIO1 instance. */
2673
#define ALT_GPIO1_INTEN_ADDR ALT_GPIO_INTEN_ADDR(ALT_GPIO1_ADDR)
2674
/* The address of the ALT_GPIO_INTMSK register for the ALT_GPIO1 instance. */
2675
#define ALT_GPIO1_INTMSK_ADDR ALT_GPIO_INTMSK_ADDR(ALT_GPIO1_ADDR)
2676
/* The address of the ALT_GPIO_INTTYPE_LEVEL register for the ALT_GPIO1 instance. */
2677
#define ALT_GPIO1_INTTYPE_LEVEL_ADDR ALT_GPIO_INTTYPE_LEVEL_ADDR(ALT_GPIO1_ADDR)
2678
/* The address of the ALT_GPIO_INT_POL register for the ALT_GPIO1 instance. */
2679
#define ALT_GPIO1_INT_POL_ADDR ALT_GPIO_INT_POL_ADDR(ALT_GPIO1_ADDR)
2680
/* The address of the ALT_GPIO_INTSTAT register for the ALT_GPIO1 instance. */
2681
#define ALT_GPIO1_INTSTAT_ADDR ALT_GPIO_INTSTAT_ADDR(ALT_GPIO1_ADDR)
2682
/* The address of the ALT_GPIO_RAW_INTSTAT register for the ALT_GPIO1 instance. */
2683
#define ALT_GPIO1_RAW_INTSTAT_ADDR ALT_GPIO_RAW_INTSTAT_ADDR(ALT_GPIO1_ADDR)
2684
/* The address of the ALT_GPIO_DEBOUNCE register for the ALT_GPIO1 instance. */
2685
#define ALT_GPIO1_DEBOUNCE_ADDR ALT_GPIO_DEBOUNCE_ADDR(ALT_GPIO1_ADDR)
2686
/* The address of the ALT_GPIO_PORTA_EOI register for the ALT_GPIO1 instance. */
2687
#define ALT_GPIO1_PORTA_EOI_ADDR ALT_GPIO_PORTA_EOI_ADDR(ALT_GPIO1_ADDR)
2688
/* The address of the ALT_GPIO_EXT_PORTA register for the ALT_GPIO1 instance. */
2689
#define ALT_GPIO1_EXT_PORTA_ADDR ALT_GPIO_EXT_PORTA_ADDR(ALT_GPIO1_ADDR)
2690
/* The address of the ALT_GPIO_LS_SYNC register for the ALT_GPIO1 instance. */
2691
#define ALT_GPIO1_LS_SYNC_ADDR ALT_GPIO_LS_SYNC_ADDR(ALT_GPIO1_ADDR)
2692
/* The address of the ALT_GPIO_ID_CODE register for the ALT_GPIO1 instance. */
2693
#define ALT_GPIO1_ID_CODE_ADDR ALT_GPIO_ID_CODE_ADDR(ALT_GPIO1_ADDR)
2694
/* The address of the ALT_GPIO_VER_ID_CODE register for the ALT_GPIO1 instance. */
2695
#define ALT_GPIO1_VER_ID_CODE_ADDR ALT_GPIO_VER_ID_CODE_ADDR(ALT_GPIO1_ADDR)
2696
/* The address of the ALT_GPIO_CFG_REG2 register for the ALT_GPIO1 instance. */
2697
#define ALT_GPIO1_CFG_REG2_ADDR ALT_GPIO_CFG_REG2_ADDR(ALT_GPIO1_ADDR)
2698
/* The address of the ALT_GPIO_CFG_REG1 register for the ALT_GPIO1 instance. */
2699
#define ALT_GPIO1_CFG_REG1_ADDR ALT_GPIO_CFG_REG1_ADDR(ALT_GPIO1_ADDR)
2700
/* The base address byte offset for the start of the ALT_GPIO1 component. */
2701
#define ALT_GPIO1_OFST 0xff709000
2702
/* The start address of the ALT_GPIO1 component. */
2703
#define ALT_GPIO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_GPIO1_OFST))
2704
/* The lower bound address range of the ALT_GPIO1 component. */
2705
#define ALT_GPIO1_LB_ADDR ALT_GPIO1_ADDR
2706
/* The upper bound address range of the ALT_GPIO1 component. */
2707
#define ALT_GPIO1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_GPIO1_ADDR) + 0x80) - 1))
2708
2709
2710
2711
* Component Instance : gpio2
2712
2713
* Instance gpio2 of component ALT_GPIO.
2714
2715
2716
2717
/* The address of the ALT_GPIO_SWPORTA_DR register for the ALT_GPIO2 instance. */
2718
#define ALT_GPIO2_SWPORTA_DR_ADDR ALT_GPIO_SWPORTA_DR_ADDR(ALT_GPIO2_ADDR)
2719
/* The address of the ALT_GPIO_SWPORTA_DDR register for the ALT_GPIO2 instance. */
2720
#define ALT_GPIO2_SWPORTA_DDR_ADDR ALT_GPIO_SWPORTA_DDR_ADDR(ALT_GPIO2_ADDR)
2721
/* The address of the ALT_GPIO_INTEN register for the ALT_GPIO2 instance. */
2722
#define ALT_GPIO2_INTEN_ADDR ALT_GPIO_INTEN_ADDR(ALT_GPIO2_ADDR)
2723
/* The address of the ALT_GPIO_INTMSK register for the ALT_GPIO2 instance. */
2724
#define ALT_GPIO2_INTMSK_ADDR ALT_GPIO_INTMSK_ADDR(ALT_GPIO2_ADDR)
2725
/* The address of the ALT_GPIO_INTTYPE_LEVEL register for the ALT_GPIO2 instance. */
2726
#define ALT_GPIO2_INTTYPE_LEVEL_ADDR ALT_GPIO_INTTYPE_LEVEL_ADDR(ALT_GPIO2_ADDR)
2727
/* The address of the ALT_GPIO_INT_POL register for the ALT_GPIO2 instance. */
2728
#define ALT_GPIO2_INT_POL_ADDR ALT_GPIO_INT_POL_ADDR(ALT_GPIO2_ADDR)
2729
/* The address of the ALT_GPIO_INTSTAT register for the ALT_GPIO2 instance. */
2730
#define ALT_GPIO2_INTSTAT_ADDR ALT_GPIO_INTSTAT_ADDR(ALT_GPIO2_ADDR)
2731
/* The address of the ALT_GPIO_RAW_INTSTAT register for the ALT_GPIO2 instance. */
2732
#define ALT_GPIO2_RAW_INTSTAT_ADDR ALT_GPIO_RAW_INTSTAT_ADDR(ALT_GPIO2_ADDR)
2733
/* The address of the ALT_GPIO_DEBOUNCE register for the ALT_GPIO2 instance. */
2734
#define ALT_GPIO2_DEBOUNCE_ADDR ALT_GPIO_DEBOUNCE_ADDR(ALT_GPIO2_ADDR)
2735
/* The address of the ALT_GPIO_PORTA_EOI register for the ALT_GPIO2 instance. */
2736
#define ALT_GPIO2_PORTA_EOI_ADDR ALT_GPIO_PORTA_EOI_ADDR(ALT_GPIO2_ADDR)
2737
/* The address of the ALT_GPIO_EXT_PORTA register for the ALT_GPIO2 instance. */
2738
#define ALT_GPIO2_EXT_PORTA_ADDR ALT_GPIO_EXT_PORTA_ADDR(ALT_GPIO2_ADDR)
2739
/* The address of the ALT_GPIO_LS_SYNC register for the ALT_GPIO2 instance. */
2740
#define ALT_GPIO2_LS_SYNC_ADDR ALT_GPIO_LS_SYNC_ADDR(ALT_GPIO2_ADDR)
2741
/* The address of the ALT_GPIO_ID_CODE register for the ALT_GPIO2 instance. */
2742
#define ALT_GPIO2_ID_CODE_ADDR ALT_GPIO_ID_CODE_ADDR(ALT_GPIO2_ADDR)
2743
/* The address of the ALT_GPIO_VER_ID_CODE register for the ALT_GPIO2 instance. */
2744
#define ALT_GPIO2_VER_ID_CODE_ADDR ALT_GPIO_VER_ID_CODE_ADDR(ALT_GPIO2_ADDR)
2745
/* The address of the ALT_GPIO_CFG_REG2 register for the ALT_GPIO2 instance. */
2746
#define ALT_GPIO2_CFG_REG2_ADDR ALT_GPIO_CFG_REG2_ADDR(ALT_GPIO2_ADDR)
2747
/* The address of the ALT_GPIO_CFG_REG1 register for the ALT_GPIO2 instance. */
2748
#define ALT_GPIO2_CFG_REG1_ADDR ALT_GPIO_CFG_REG1_ADDR(ALT_GPIO2_ADDR)
2749
/* The base address byte offset for the start of the ALT_GPIO2 component. */
2750
#define ALT_GPIO2_OFST 0xff70a000
2751
/* The start address of the ALT_GPIO2 component. */
2752
#define ALT_GPIO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_GPIO2_OFST))
2753
/* The lower bound address range of the ALT_GPIO2 component. */
2754
#define ALT_GPIO2_LB_ADDR ALT_GPIO2_ADDR
2755
/* The upper bound address range of the ALT_GPIO2 component. */
2756
#define ALT_GPIO2_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_GPIO2_ADDR) + 0x80) - 1))
2757
2758
2759
2760
* Component Instance : l3regs
2761
2762
* Instance l3regs of component ALT_L3.
2763
2764
2765
2766
/* The address of the ALT_L3_REMAP register for the ALT_L3 instance. */
2767
#define ALT_L3_REMAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_ADDR) + ALT_L3_REMAP_OFST))
2768
2769
* Register Group Instance : secgrp
2770
2771
* Instance secgrp of register group ALT_L3_SECGRP.
2772
2773
2774
2775
/* The address of the ALT_L3_SEC_L4MAIN register for the ALT_L3_SECGRP instance. */
2776
#define ALT_L3_SEC_L4MAIN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_L4MAIN_OFST))
2777
/* The address of the ALT_L3_SEC_L4SP register for the ALT_L3_SECGRP instance. */
2778
#define ALT_L3_SEC_L4SP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_L4SP_OFST))
2779
/* The address of the ALT_L3_SEC_L4MP register for the ALT_L3_SECGRP instance. */
2780
#define ALT_L3_SEC_L4MP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_L4MP_OFST))
2781
/* The address of the ALT_L3_SEC_L4OSC1 register for the ALT_L3_SECGRP instance. */
2782
#define ALT_L3_SEC_L4OSC1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_L4OSC1_OFST))
2783
/* The address of the ALT_L3_SEC_L4SPIM register for the ALT_L3_SECGRP instance. */
2784
#define ALT_L3_SEC_L4SPIM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_L4SPIM_OFST))
2785
/* The address of the ALT_L3_SEC_STM register for the ALT_L3_SECGRP instance. */
2786
#define ALT_L3_SEC_STM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_STM_OFST))
2787
/* The address of the ALT_L3_SEC_LWH2F register for the ALT_L3_SECGRP instance. */
2788
#define ALT_L3_SEC_LWH2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_LWH2F_OFST))
2789
/* The address of the ALT_L3_SEC_USB1 register for the ALT_L3_SECGRP instance. */
2790
#define ALT_L3_SEC_USB1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_USB1_OFST))
2791
/* The address of the ALT_L3_SEC_NANDDATA register for the ALT_L3_SECGRP instance. */
2792
#define ALT_L3_SEC_NANDDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_NANDDATA_OFST))
2793
/* The address of the ALT_L3_SEC_USB0 register for the ALT_L3_SECGRP instance. */
2794
#define ALT_L3_SEC_USB0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_USB0_OFST))
2795
/* The address of the ALT_L3_SEC_NAND register for the ALT_L3_SECGRP instance. */
2796
#define ALT_L3_SEC_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_NAND_OFST))
2797
/* The address of the ALT_L3_SEC_QSPIDATA register for the ALT_L3_SECGRP instance. */
2798
#define ALT_L3_SEC_QSPIDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_QSPIDATA_OFST))
2799
/* The address of the ALT_L3_SEC_FPGAMGRDATA register for the ALT_L3_SECGRP instance. */
2800
#define ALT_L3_SEC_FPGAMGRDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_FPGAMGRDATA_OFST))
2801
/* The address of the ALT_L3_SEC_H2F register for the ALT_L3_SECGRP instance. */
2802
#define ALT_L3_SEC_H2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_H2F_OFST))
2803
/* The address of the ALT_L3_SEC_ACP register for the ALT_L3_SECGRP instance. */
2804
#define ALT_L3_SEC_ACP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_ACP_OFST))
2805
/* The address of the ALT_L3_SEC_ROM register for the ALT_L3_SECGRP instance. */
2806
#define ALT_L3_SEC_ROM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_ROM_OFST))
2807
/* The address of the ALT_L3_SEC_OCRAM register for the ALT_L3_SECGRP instance. */
2808
#define ALT_L3_SEC_OCRAM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_OCRAM_OFST))
2809
/* The address of the ALT_L3_SEC_SDRDATA register for the ALT_L3_SECGRP instance. */
2810
#define ALT_L3_SEC_SDRDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + ALT_L3_SEC_SDRDATA_OFST))
2811
/* The base address byte offset for the start of the ALT_L3_SECGRP component. */
2812
#define ALT_L3_SECGRP_OFST 0x8
2813
/* The start address of the ALT_L3_SECGRP component. */
2814
#define ALT_L3_SECGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_ADDR) + ALT_L3_SECGRP_OFST))
2815
/* The lower bound address range of the ALT_L3_SECGRP component. */
2816
#define ALT_L3_SECGRP_LB_ADDR ALT_L3_SECGRP_ADDR
2817
/* The upper bound address range of the ALT_L3_SECGRP component. */
2818
#define ALT_L3_SECGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SECGRP_ADDR) + 0x9c) - 1))
2819
2820
2821
2822
* Register Group Instance : idgrp
2823
2824
* Instance idgrp of register group ALT_L3_IDGRP.
2825
2826
2827
2828
/* The address of the ALT_L3_ID_PERIPH_ID_4 register for the ALT_L3_IDGRP instance. */
2829
#define ALT_L3_ID_PERIPH_ID_4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_PERIPH_ID_4_OFST))
2830
/* The address of the ALT_L3_ID_PERIPH_ID_0 register for the ALT_L3_IDGRP instance. */
2831
#define ALT_L3_ID_PERIPH_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_PERIPH_ID_0_OFST))
2832
/* The address of the ALT_L3_ID_PERIPH_ID_1 register for the ALT_L3_IDGRP instance. */
2833
#define ALT_L3_ID_PERIPH_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_PERIPH_ID_1_OFST))
2834
/* The address of the ALT_L3_ID_PERIPH_ID_2 register for the ALT_L3_IDGRP instance. */
2835
#define ALT_L3_ID_PERIPH_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_PERIPH_ID_2_OFST))
2836
/* The address of the ALT_L3_ID_PERIPH_ID_3 register for the ALT_L3_IDGRP instance. */
2837
#define ALT_L3_ID_PERIPH_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_PERIPH_ID_3_OFST))
2838
/* The address of the ALT_L3_ID_COMP_ID_0 register for the ALT_L3_IDGRP instance. */
2839
#define ALT_L3_ID_COMP_ID_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_COMP_ID_0_OFST))
2840
/* The address of the ALT_L3_ID_COMP_ID_1 register for the ALT_L3_IDGRP instance. */
2841
#define ALT_L3_ID_COMP_ID_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_COMP_ID_1_OFST))
2842
/* The address of the ALT_L3_ID_COMP_ID_2 register for the ALT_L3_IDGRP instance. */
2843
#define ALT_L3_ID_COMP_ID_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_COMP_ID_2_OFST))
2844
/* The address of the ALT_L3_ID_COMP_ID_3 register for the ALT_L3_IDGRP instance. */
2845
#define ALT_L3_ID_COMP_ID_3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + ALT_L3_ID_COMP_ID_3_OFST))
2846
/* The base address byte offset for the start of the ALT_L3_IDGRP component. */
2847
#define ALT_L3_IDGRP_OFST 0x1000
2848
/* The start address of the ALT_L3_IDGRP component. */
2849
#define ALT_L3_IDGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_ADDR) + ALT_L3_IDGRP_OFST))
2850
/* The lower bound address range of the ALT_L3_IDGRP component. */
2851
#define ALT_L3_IDGRP_LB_ADDR ALT_L3_IDGRP_ADDR
2852
/* The upper bound address range of the ALT_L3_IDGRP component. */
2853
#define ALT_L3_IDGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_IDGRP_ADDR) + 0x1000) - 1))
2854
2855
2856
2857
* Register Group Instance : mastergrp
2858
2859
* Instance mastergrp of register group ALT_L3_MSTGRP.
2860
2861
2862
2863
2864
* Register Group Instance : mastergrp_l4main
2865
2866
* Instance mastergrp_l4main of register group ALT_L3_MST_L4MAIN.
2867
2868
2869
2870
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_L4MAIN instance. */
2871
#define ALT_L3_MST_MST_L4MAIN_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_L4MAIN_ADDR)
2872
/* The base address byte offset for the start of the ALT_L3_MST_MST_L4MAIN component. */
2873
#define ALT_L3_MST_MST_L4MAIN_OFST 0x0
2874
/* The start address of the ALT_L3_MST_MST_L4MAIN component. */
2875
#define ALT_L3_MST_MST_L4MAIN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_L4MAIN_OFST))
2876
/* The lower bound address range of the ALT_L3_MST_MST_L4MAIN component. */
2877
#define ALT_L3_MST_MST_L4MAIN_LB_ADDR ALT_L3_MST_MST_L4MAIN_ADDR
2878
/* The upper bound address range of the ALT_L3_MST_MST_L4MAIN component. */
2879
#define ALT_L3_MST_MST_L4MAIN_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_L4MAIN_ADDR) + 0xc) - 1))
2880
2881
2882
2883
* Register Group Instance : mastergrp_l4sp
2884
2885
* Instance mastergrp_l4sp of register group ALT_L3_MST_L4SP.
2886
2887
2888
2889
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_L4SP instance. */
2890
#define ALT_L3_MST_MST_L4SP_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_L4SP_ADDR)
2891
/* The base address byte offset for the start of the ALT_L3_MST_MST_L4SP component. */
2892
#define ALT_L3_MST_MST_L4SP_OFST 0x1000
2893
/* The start address of the ALT_L3_MST_MST_L4SP component. */
2894
#define ALT_L3_MST_MST_L4SP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_L4SP_OFST))
2895
/* The lower bound address range of the ALT_L3_MST_MST_L4SP component. */
2896
#define ALT_L3_MST_MST_L4SP_LB_ADDR ALT_L3_MST_MST_L4SP_ADDR
2897
/* The upper bound address range of the ALT_L3_MST_MST_L4SP component. */
2898
#define ALT_L3_MST_MST_L4SP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_L4SP_ADDR) + 0xc) - 1))
2899
2900
2901
2902
* Register Group Instance : mastergrp_l4mp
2903
2904
* Instance mastergrp_l4mp of register group ALT_L3_MST_L4MP.
2905
2906
2907
2908
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_L4MP instance. */
2909
#define ALT_L3_MST_MST_L4MP_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_L4MP_ADDR)
2910
/* The base address byte offset for the start of the ALT_L3_MST_MST_L4MP component. */
2911
#define ALT_L3_MST_MST_L4MP_OFST 0x2000
2912
/* The start address of the ALT_L3_MST_MST_L4MP component. */
2913
#define ALT_L3_MST_MST_L4MP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_L4MP_OFST))
2914
/* The lower bound address range of the ALT_L3_MST_MST_L4MP component. */
2915
#define ALT_L3_MST_MST_L4MP_LB_ADDR ALT_L3_MST_MST_L4MP_ADDR
2916
/* The upper bound address range of the ALT_L3_MST_MST_L4MP component. */
2917
#define ALT_L3_MST_MST_L4MP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_L4MP_ADDR) + 0xc) - 1))
2918
2919
2920
2921
* Register Group Instance : mastergrp_l4osc1
2922
2923
* Instance mastergrp_l4osc1 of register group ALT_L3_MST_L4OSC1.
2924
2925
2926
2927
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_L4OSC1 instance. */
2928
#define ALT_L3_MST_MST_L4OSC1_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_L4OSC1_ADDR)
2929
/* The base address byte offset for the start of the ALT_L3_MST_MST_L4OSC1 component. */
2930
#define ALT_L3_MST_MST_L4OSC1_OFST 0x3000
2931
/* The start address of the ALT_L3_MST_MST_L4OSC1 component. */
2932
#define ALT_L3_MST_MST_L4OSC1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_L4OSC1_OFST))
2933
/* The lower bound address range of the ALT_L3_MST_MST_L4OSC1 component. */
2934
#define ALT_L3_MST_MST_L4OSC1_LB_ADDR ALT_L3_MST_MST_L4OSC1_ADDR
2935
/* The upper bound address range of the ALT_L3_MST_MST_L4OSC1 component. */
2936
#define ALT_L3_MST_MST_L4OSC1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_L4OSC1_ADDR) + 0xc) - 1))
2937
2938
2939
2940
* Register Group Instance : mastergrp_l4spim
2941
2942
* Instance mastergrp_l4spim of register group ALT_L3_MST_L4SPIM.
2943
2944
2945
2946
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_L4SPIM instance. */
2947
#define ALT_L3_MST_MST_L4SPIM_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_L4SPIM_ADDR)
2948
/* The base address byte offset for the start of the ALT_L3_MST_MST_L4SPIM component. */
2949
#define ALT_L3_MST_MST_L4SPIM_OFST 0x4000
2950
/* The start address of the ALT_L3_MST_MST_L4SPIM component. */
2951
#define ALT_L3_MST_MST_L4SPIM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_L4SPIM_OFST))
2952
/* The lower bound address range of the ALT_L3_MST_MST_L4SPIM component. */
2953
#define ALT_L3_MST_MST_L4SPIM_LB_ADDR ALT_L3_MST_MST_L4SPIM_ADDR
2954
/* The upper bound address range of the ALT_L3_MST_MST_L4SPIM component. */
2955
#define ALT_L3_MST_MST_L4SPIM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_L4SPIM_ADDR) + 0xc) - 1))
2956
2957
2958
2959
* Register Group Instance : mastergrp_stm
2960
2961
* Instance mastergrp_stm of register group ALT_L3_MST_STM.
2962
2963
2964
2965
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_STM instance. */
2966
#define ALT_L3_MST_MST_STM_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_STM_ADDR)
2967
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_STM instance. */
2968
#define ALT_L3_MST_MST_STM_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_STM_ADDR)
2969
/* The base address byte offset for the start of the ALT_L3_MST_MST_STM component. */
2970
#define ALT_L3_MST_MST_STM_OFST 0x5000
2971
/* The start address of the ALT_L3_MST_MST_STM component. */
2972
#define ALT_L3_MST_MST_STM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_STM_OFST))
2973
/* The lower bound address range of the ALT_L3_MST_MST_STM component. */
2974
#define ALT_L3_MST_MST_STM_LB_ADDR ALT_L3_MST_MST_STM_ADDR
2975
/* The upper bound address range of the ALT_L3_MST_MST_STM component. */
2976
#define ALT_L3_MST_MST_STM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_STM_ADDR) + 0x10c) - 1))
2977
2978
2979
2980
* Register Group Instance : mastergrp_lwhps2fpga
2981
2982
* Instance mastergrp_lwhps2fpga of register group ALT_L3_MST_LWH2F.
2983
2984
2985
2986
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_LWH2F instance. */
2987
#define ALT_L3_MST_MST_LWH2F_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_LWH2F_ADDR)
2988
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_LWH2F instance. */
2989
#define ALT_L3_MST_MST_LWH2F_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_LWH2F_ADDR)
2990
/* The base address byte offset for the start of the ALT_L3_MST_MST_LWH2F component. */
2991
#define ALT_L3_MST_MST_LWH2F_OFST 0x6000
2992
/* The start address of the ALT_L3_MST_MST_LWH2F component. */
2993
#define ALT_L3_MST_MST_LWH2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_LWH2F_OFST))
2994
/* The lower bound address range of the ALT_L3_MST_MST_LWH2F component. */
2995
#define ALT_L3_MST_MST_LWH2F_LB_ADDR ALT_L3_MST_MST_LWH2F_ADDR
2996
/* The upper bound address range of the ALT_L3_MST_MST_LWH2F component. */
2997
#define ALT_L3_MST_MST_LWH2F_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_LWH2F_ADDR) + 0x10c) - 1))
2998
2999
3000
3001
* Register Group Instance : mastergrp_usb1
3002
3003
* Instance mastergrp_usb1 of register group ALT_L3_MST_USB1.
3004
3005
3006
3007
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_USB1 instance. */
3008
#define ALT_L3_MST_MST_USB1_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_USB1_ADDR)
3009
/* The address of the ALT_L3_AHB_CNTL register for the ALT_L3_MST_MST_USB1 instance. */
3010
#define ALT_L3_MST_MST_USB1_AHB_CNTL_ADDR ALT_L3_AHB_CNTL_ADDR(ALT_L3_MST_MST_USB1_ADDR)
3011
/* The base address byte offset for the start of the ALT_L3_MST_MST_USB1 component. */
3012
#define ALT_L3_MST_MST_USB1_OFST 0x8000
3013
/* The start address of the ALT_L3_MST_MST_USB1 component. */
3014
#define ALT_L3_MST_MST_USB1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_USB1_OFST))
3015
/* The lower bound address range of the ALT_L3_MST_MST_USB1 component. */
3016
#define ALT_L3_MST_MST_USB1_LB_ADDR ALT_L3_MST_MST_USB1_ADDR
3017
/* The upper bound address range of the ALT_L3_MST_MST_USB1 component. */
3018
#define ALT_L3_MST_MST_USB1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_USB1_ADDR) + 0x48) - 1))
3019
3020
3021
3022
* Register Group Instance : mastergrp_nanddata
3023
3024
* Instance mastergrp_nanddata of register group ALT_L3_MST_NANDDATA.
3025
3026
3027
3028
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_NANDDATA instance. */
3029
#define ALT_L3_MST_MST_NANDDATA_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_NANDDATA_ADDR)
3030
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_NANDDATA instance. */
3031
#define ALT_L3_MST_MST_NANDDATA_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_NANDDATA_ADDR)
3032
/* The base address byte offset for the start of the ALT_L3_MST_MST_NANDDATA component. */
3033
#define ALT_L3_MST_MST_NANDDATA_OFST 0x9000
3034
/* The start address of the ALT_L3_MST_MST_NANDDATA component. */
3035
#define ALT_L3_MST_MST_NANDDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_NANDDATA_OFST))
3036
/* The lower bound address range of the ALT_L3_MST_MST_NANDDATA component. */
3037
#define ALT_L3_MST_MST_NANDDATA_LB_ADDR ALT_L3_MST_MST_NANDDATA_ADDR
3038
/* The upper bound address range of the ALT_L3_MST_MST_NANDDATA component. */
3039
#define ALT_L3_MST_MST_NANDDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_NANDDATA_ADDR) + 0x10c) - 1))
3040
3041
3042
3043
* Register Group Instance : mastergrp_usb0
3044
3045
* Instance mastergrp_usb0 of register group ALT_L3_MST_USB0.
3046
3047
3048
3049
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_USB0 instance. */
3050
#define ALT_L3_MST_MST_USB0_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_USB0_ADDR)
3051
/* The address of the ALT_L3_AHB_CNTL register for the ALT_L3_MST_MST_USB0 instance. */
3052
#define ALT_L3_MST_MST_USB0_AHB_CNTL_ADDR ALT_L3_AHB_CNTL_ADDR(ALT_L3_MST_MST_USB0_ADDR)
3053
/* The base address byte offset for the start of the ALT_L3_MST_MST_USB0 component. */
3054
#define ALT_L3_MST_MST_USB0_OFST 0x1e000
3055
/* The start address of the ALT_L3_MST_MST_USB0 component. */
3056
#define ALT_L3_MST_MST_USB0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_USB0_OFST))
3057
/* The lower bound address range of the ALT_L3_MST_MST_USB0 component. */
3058
#define ALT_L3_MST_MST_USB0_LB_ADDR ALT_L3_MST_MST_USB0_ADDR
3059
/* The upper bound address range of the ALT_L3_MST_MST_USB0 component. */
3060
#define ALT_L3_MST_MST_USB0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_USB0_ADDR) + 0x48) - 1))
3061
3062
3063
3064
* Register Group Instance : mastergrp_nandregs
3065
3066
* Instance mastergrp_nandregs of register group ALT_L3_MST_NAND.
3067
3068
3069
3070
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_NAND instance. */
3071
#define ALT_L3_MST_MST_NAND_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_NAND_ADDR)
3072
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_NAND instance. */
3073
#define ALT_L3_MST_MST_NAND_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_NAND_ADDR)
3074
/* The base address byte offset for the start of the ALT_L3_MST_MST_NAND component. */
3075
#define ALT_L3_MST_MST_NAND_OFST 0x1f000
3076
/* The start address of the ALT_L3_MST_MST_NAND component. */
3077
#define ALT_L3_MST_MST_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_NAND_OFST))
3078
/* The lower bound address range of the ALT_L3_MST_MST_NAND component. */
3079
#define ALT_L3_MST_MST_NAND_LB_ADDR ALT_L3_MST_MST_NAND_ADDR
3080
/* The upper bound address range of the ALT_L3_MST_MST_NAND component. */
3081
#define ALT_L3_MST_MST_NAND_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_NAND_ADDR) + 0x10c) - 1))
3082
3083
3084
3085
* Register Group Instance : mastergrp_qspidata
3086
3087
* Instance mastergrp_qspidata of register group ALT_L3_MST_QSPIDATA.
3088
3089
3090
3091
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_QSPIDATA instance. */
3092
#define ALT_L3_MST_MST_QSPIDATA_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_QSPIDATA_ADDR)
3093
/* The address of the ALT_L3_AHB_CNTL register for the ALT_L3_MST_MST_QSPIDATA instance. */
3094
#define ALT_L3_MST_MST_QSPIDATA_AHB_CNTL_ADDR ALT_L3_AHB_CNTL_ADDR(ALT_L3_MST_MST_QSPIDATA_ADDR)
3095
/* The base address byte offset for the start of the ALT_L3_MST_MST_QSPIDATA component. */
3096
#define ALT_L3_MST_MST_QSPIDATA_OFST 0x20000
3097
/* The start address of the ALT_L3_MST_MST_QSPIDATA component. */
3098
#define ALT_L3_MST_MST_QSPIDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_QSPIDATA_OFST))
3099
/* The lower bound address range of the ALT_L3_MST_MST_QSPIDATA component. */
3100
#define ALT_L3_MST_MST_QSPIDATA_LB_ADDR ALT_L3_MST_MST_QSPIDATA_ADDR
3101
/* The upper bound address range of the ALT_L3_MST_MST_QSPIDATA component. */
3102
#define ALT_L3_MST_MST_QSPIDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_QSPIDATA_ADDR) + 0x48) - 1))
3103
3104
3105
3106
* Register Group Instance : mastergrp_fpgamgrdata
3107
3108
* Instance mastergrp_fpgamgrdata of register group ALT_L3_MST_FPGAMGRDATA.
3109
3110
3111
3112
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_FPGAMGRDATA instance. */
3113
#define ALT_L3_MST_MST_FPGAMGRDATA_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_FPGAMGRDATA_ADDR)
3114
/* The address of the ALT_L3_WR_TIDEMARK register for the ALT_L3_MST_MST_FPGAMGRDATA instance. */
3115
#define ALT_L3_MST_MST_FPGAMGRDATA_WR_TIDEMARK_ADDR ALT_L3_WR_TIDEMARK_ADDR(ALT_L3_MST_MST_FPGAMGRDATA_ADDR)
3116
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_FPGAMGRDATA instance. */
3117
#define ALT_L3_MST_MST_FPGAMGRDATA_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_FPGAMGRDATA_ADDR)
3118
/* The base address byte offset for the start of the ALT_L3_MST_MST_FPGAMGRDATA component. */
3119
#define ALT_L3_MST_MST_FPGAMGRDATA_OFST 0x21000
3120
/* The start address of the ALT_L3_MST_MST_FPGAMGRDATA component. */
3121
#define ALT_L3_MST_MST_FPGAMGRDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_FPGAMGRDATA_OFST))
3122
/* The lower bound address range of the ALT_L3_MST_MST_FPGAMGRDATA component. */
3123
#define ALT_L3_MST_MST_FPGAMGRDATA_LB_ADDR ALT_L3_MST_MST_FPGAMGRDATA_ADDR
3124
/* The upper bound address range of the ALT_L3_MST_MST_FPGAMGRDATA component. */
3125
#define ALT_L3_MST_MST_FPGAMGRDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_FPGAMGRDATA_ADDR) + 0x10c) - 1))
3126
3127
3128
3129
* Register Group Instance : mastergrp_hps2fpga
3130
3131
* Instance mastergrp_hps2fpga of register group ALT_L3_MST_H2F.
3132
3133
3134
3135
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_H2F instance. */
3136
#define ALT_L3_MST_MST_H2F_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_H2F_ADDR)
3137
/* The address of the ALT_L3_WR_TIDEMARK register for the ALT_L3_MST_MST_H2F instance. */
3138
#define ALT_L3_MST_MST_H2F_WR_TIDEMARK_ADDR ALT_L3_WR_TIDEMARK_ADDR(ALT_L3_MST_MST_H2F_ADDR)
3139
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_H2F instance. */
3140
#define ALT_L3_MST_MST_H2F_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_H2F_ADDR)
3141
/* The base address byte offset for the start of the ALT_L3_MST_MST_H2F component. */
3142
#define ALT_L3_MST_MST_H2F_OFST 0x22000
3143
/* The start address of the ALT_L3_MST_MST_H2F component. */
3144
#define ALT_L3_MST_MST_H2F_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_H2F_OFST))
3145
/* The lower bound address range of the ALT_L3_MST_MST_H2F component. */
3146
#define ALT_L3_MST_MST_H2F_LB_ADDR ALT_L3_MST_MST_H2F_ADDR
3147
/* The upper bound address range of the ALT_L3_MST_MST_H2F component. */
3148
#define ALT_L3_MST_MST_H2F_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_H2F_ADDR) + 0x10c) - 1))
3149
3150
3151
3152
* Register Group Instance : mastergrp_acp
3153
3154
* Instance mastergrp_acp of register group ALT_L3_MST_ACP.
3155
3156
3157
3158
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_ACP instance. */
3159
#define ALT_L3_MST_MST_ACP_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_ACP_ADDR)
3160
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_ACP instance. */
3161
#define ALT_L3_MST_MST_ACP_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_ACP_ADDR)
3162
/* The base address byte offset for the start of the ALT_L3_MST_MST_ACP component. */
3163
#define ALT_L3_MST_MST_ACP_OFST 0x23000
3164
/* The start address of the ALT_L3_MST_MST_ACP component. */
3165
#define ALT_L3_MST_MST_ACP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_ACP_OFST))
3166
/* The lower bound address range of the ALT_L3_MST_MST_ACP component. */
3167
#define ALT_L3_MST_MST_ACP_LB_ADDR ALT_L3_MST_MST_ACP_ADDR
3168
/* The upper bound address range of the ALT_L3_MST_MST_ACP component. */
3169
#define ALT_L3_MST_MST_ACP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_ACP_ADDR) + 0x10c) - 1))
3170
3171
3172
3173
* Register Group Instance : mastergrp_rom
3174
3175
* Instance mastergrp_rom of register group ALT_L3_MST_ROM.
3176
3177
3178
3179
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_ROM instance. */
3180
#define ALT_L3_MST_MST_ROM_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_ROM_ADDR)
3181
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_ROM instance. */
3182
#define ALT_L3_MST_MST_ROM_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_ROM_ADDR)
3183
/* The base address byte offset for the start of the ALT_L3_MST_MST_ROM component. */
3184
#define ALT_L3_MST_MST_ROM_OFST 0x24000
3185
/* The start address of the ALT_L3_MST_MST_ROM component. */
3186
#define ALT_L3_MST_MST_ROM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_ROM_OFST))
3187
/* The lower bound address range of the ALT_L3_MST_MST_ROM component. */
3188
#define ALT_L3_MST_MST_ROM_LB_ADDR ALT_L3_MST_MST_ROM_ADDR
3189
/* The upper bound address range of the ALT_L3_MST_MST_ROM component. */
3190
#define ALT_L3_MST_MST_ROM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_ROM_ADDR) + 0x10c) - 1))
3191
3192
3193
3194
* Register Group Instance : mastergrp_ocram
3195
3196
* Instance mastergrp_ocram of register group ALT_L3_MST_OCRAM.
3197
3198
3199
3200
/* The address of the ALT_L3_FN_MOD_BM_ISS register for the ALT_L3_MST_MST_OCRAM instance. */
3201
#define ALT_L3_MST_MST_OCRAM_FN_MOD_BM_ISS_ADDR ALT_L3_FN_MOD_BM_ISS_ADDR(ALT_L3_MST_MST_OCRAM_ADDR)
3202
/* The address of the ALT_L3_WR_TIDEMARK register for the ALT_L3_MST_MST_OCRAM instance. */
3203
#define ALT_L3_MST_MST_OCRAM_WR_TIDEMARK_ADDR ALT_L3_WR_TIDEMARK_ADDR(ALT_L3_MST_MST_OCRAM_ADDR)
3204
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_MST_MST_OCRAM instance. */
3205
#define ALT_L3_MST_MST_OCRAM_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_MST_MST_OCRAM_ADDR)
3206
/* The base address byte offset for the start of the ALT_L3_MST_MST_OCRAM component. */
3207
#define ALT_L3_MST_MST_OCRAM_OFST 0x25000
3208
/* The start address of the ALT_L3_MST_MST_OCRAM component. */
3209
#define ALT_L3_MST_MST_OCRAM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + ALT_L3_MST_MST_OCRAM_OFST))
3210
/* The lower bound address range of the ALT_L3_MST_MST_OCRAM component. */
3211
#define ALT_L3_MST_MST_OCRAM_LB_ADDR ALT_L3_MST_MST_OCRAM_ADDR
3212
/* The upper bound address range of the ALT_L3_MST_MST_OCRAM component. */
3213
#define ALT_L3_MST_MST_OCRAM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MST_MST_OCRAM_ADDR) + 0x10c) - 1))
3214
3215
3216
/* The base address byte offset for the start of the ALT_L3_MSTGRP component. */
3217
#define ALT_L3_MSTGRP_OFST 0x2000
3218
/* The start address of the ALT_L3_MSTGRP component. */
3219
#define ALT_L3_MSTGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_ADDR) + ALT_L3_MSTGRP_OFST))
3220
/* The lower bound address range of the ALT_L3_MSTGRP component. */
3221
#define ALT_L3_MSTGRP_LB_ADDR ALT_L3_MSTGRP_ADDR
3222
/* The upper bound address range of the ALT_L3_MSTGRP component. */
3223
#define ALT_L3_MSTGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_MSTGRP_ADDR) + 0x2510c) - 1))
3224
3225
3226
3227
* Register Group Instance : slavegrp
3228
3229
* Instance slavegrp of register group ALT_L3_SLVGRP.
3230
3231
3232
3233
3234
* Register Group Instance : slavegrp_dap
3235
3236
* Instance slavegrp_dap of register group ALT_L3_SLV_DAP.
3237
3238
3239
3240
/* The address of the ALT_L3_FN_MOD2 register for the ALT_L3_SLV_SLV_DAP instance. */
3241
#define ALT_L3_SLV_SLV_DAP_FN_MOD2_ADDR ALT_L3_FN_MOD2_ADDR(ALT_L3_SLV_SLV_DAP_ADDR)
3242
/* The address of the ALT_L3_FN_MOD_AHB register for the ALT_L3_SLV_SLV_DAP instance. */
3243
#define ALT_L3_SLV_SLV_DAP_FN_MOD_AHB_ADDR ALT_L3_FN_MOD_AHB_ADDR(ALT_L3_SLV_SLV_DAP_ADDR)
3244
/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_DAP instance. */
3245
#define ALT_L3_SLV_SLV_DAP_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_DAP_ADDR)
3246
/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_DAP instance. */
3247
#define ALT_L3_SLV_SLV_DAP_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_DAP_ADDR)
3248
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_DAP instance. */
3249
#define ALT_L3_SLV_SLV_DAP_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_DAP_ADDR)
3250
/* The base address byte offset for the start of the ALT_L3_SLV_SLV_DAP component. */
3251
#define ALT_L3_SLV_SLV_DAP_OFST 0x0
3252
/* The start address of the ALT_L3_SLV_SLV_DAP component. */
3253
#define ALT_L3_SLV_SLV_DAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_DAP_OFST))
3254
/* The lower bound address range of the ALT_L3_SLV_SLV_DAP component. */
3255
#define ALT_L3_SLV_SLV_DAP_LB_ADDR ALT_L3_SLV_SLV_DAP_ADDR
3256
/* The upper bound address range of the ALT_L3_SLV_SLV_DAP component. */
3257
#define ALT_L3_SLV_SLV_DAP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_DAP_ADDR) + 0x10c) - 1))
3258
3259
3260
3261
* Register Group Instance : slavegrp_mpu
3262
3263
* Instance slavegrp_mpu of register group ALT_L3_SLV_MPU.
3264
3265
3266
3267
/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_MPU instance. */
3268
#define ALT_L3_SLV_SLV_MPU_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_MPU_ADDR)
3269
/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_MPU instance. */
3270
#define ALT_L3_SLV_SLV_MPU_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_MPU_ADDR)
3271
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_MPU instance. */
3272
#define ALT_L3_SLV_SLV_MPU_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_MPU_ADDR)
3273
/* The base address byte offset for the start of the ALT_L3_SLV_SLV_MPU component. */
3274
#define ALT_L3_SLV_SLV_MPU_OFST 0x1000
3275
/* The start address of the ALT_L3_SLV_SLV_MPU component. */
3276
#define ALT_L3_SLV_SLV_MPU_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_MPU_OFST))
3277
/* The lower bound address range of the ALT_L3_SLV_SLV_MPU component. */
3278
#define ALT_L3_SLV_SLV_MPU_LB_ADDR ALT_L3_SLV_SLV_MPU_ADDR
3279
/* The upper bound address range of the ALT_L3_SLV_SLV_MPU component. */
3280
#define ALT_L3_SLV_SLV_MPU_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_MPU_ADDR) + 0x10c) - 1))
3281
3282
3283
3284
* Register Group Instance : slavegrp_sdmmc
3285
3286
* Instance slavegrp_sdmmc of register group ALT_L3_SLV_SDMMC.
3287
3288
3289
3290
/* The address of the ALT_L3_FN_MOD_AHB register for the ALT_L3_SLV_SLV_SDMMC instance. */
3291
#define ALT_L3_SLV_SLV_SDMMC_FN_MOD_AHB_ADDR ALT_L3_FN_MOD_AHB_ADDR(ALT_L3_SLV_SLV_SDMMC_ADDR)
3292
/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_SDMMC instance. */
3293
#define ALT_L3_SLV_SLV_SDMMC_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_SDMMC_ADDR)
3294
/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_SDMMC instance. */
3295
#define ALT_L3_SLV_SLV_SDMMC_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_SDMMC_ADDR)
3296
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_SDMMC instance. */
3297
#define ALT_L3_SLV_SLV_SDMMC_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_SDMMC_ADDR)
3298
/* The base address byte offset for the start of the ALT_L3_SLV_SLV_SDMMC component. */
3299
#define ALT_L3_SLV_SLV_SDMMC_OFST 0x2000
3300
/* The start address of the ALT_L3_SLV_SLV_SDMMC component. */
3301
#define ALT_L3_SLV_SLV_SDMMC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_SDMMC_OFST))
3302
/* The lower bound address range of the ALT_L3_SLV_SLV_SDMMC component. */
3303
#define ALT_L3_SLV_SLV_SDMMC_LB_ADDR ALT_L3_SLV_SLV_SDMMC_ADDR
3304
/* The upper bound address range of the ALT_L3_SLV_SLV_SDMMC component. */
3305
#define ALT_L3_SLV_SLV_SDMMC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_SDMMC_ADDR) + 0x10c) - 1))
3306
3307
3308
3309
* Register Group Instance : slavegrp_dma
3310
3311
* Instance slavegrp_dma of register group ALT_L3_SLV_DMA.
3312
3313
3314
3315
/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_DMA instance. */
3316
#define ALT_L3_SLV_SLV_DMA_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_DMA_ADDR)
3317
/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_DMA instance. */
3318
#define ALT_L3_SLV_SLV_DMA_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_DMA_ADDR)
3319
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_DMA instance. */
3320
#define ALT_L3_SLV_SLV_DMA_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_DMA_ADDR)
3321
/* The base address byte offset for the start of the ALT_L3_SLV_SLV_DMA component. */
3322
#define ALT_L3_SLV_SLV_DMA_OFST 0x3000
3323
/* The start address of the ALT_L3_SLV_SLV_DMA component. */
3324
#define ALT_L3_SLV_SLV_DMA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_DMA_OFST))
3325
/* The lower bound address range of the ALT_L3_SLV_SLV_DMA component. */
3326
#define ALT_L3_SLV_SLV_DMA_LB_ADDR ALT_L3_SLV_SLV_DMA_ADDR
3327
/* The upper bound address range of the ALT_L3_SLV_SLV_DMA component. */
3328
#define ALT_L3_SLV_SLV_DMA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_DMA_ADDR) + 0x10c) - 1))
3329
3330
3331
3332
* Register Group Instance : slavegrp_fpga2hps
3333
3334
* Instance slavegrp_fpga2hps of register group ALT_L3_SLV_F2H.
3335
3336
3337
3338
/* The address of the ALT_L3_WR_TIDEMARK register for the ALT_L3_SLV_SLV_F2H instance. */
3339
#define ALT_L3_SLV_SLV_FPGA2WR_TIDEMARK_ADDR ALT_L3_WR_TIDEMARK_ADDR(ALT_L3_SLV_SLV_F2H_ADDR)
3340
/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_F2H instance. */
3341
#define ALT_L3_SLV_SLV_FPGA2RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_F2H_ADDR)
3342
/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_F2H instance. */
3343
#define ALT_L3_SLV_SLV_FPGA2WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_F2H_ADDR)
3344
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_F2H instance. */
3345
#define ALT_L3_SLV_SLV_FPGA2FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_F2H_ADDR)
3346
/* The base address byte offset for the start of the ALT_L3_SLV_SLV_F2H component. */
3347
#define ALT_L3_SLV_SLV_F2H_OFST 0x4000
3348
/* The start address of the ALT_L3_SLV_SLV_F2H component. */
3349
#define ALT_L3_SLV_SLV_F2H_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_F2H_OFST))
3350
/* The lower bound address range of the ALT_L3_SLV_SLV_F2H component. */
3351
#define ALT_L3_SLV_SLV_F2H_LB_ADDR ALT_L3_SLV_SLV_F2H_ADDR
3352
/* The upper bound address range of the ALT_L3_SLV_SLV_F2H component. */
3353
#define ALT_L3_SLV_SLV_F2H_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_F2H_ADDR) + 0x10c) - 1))
3354
3355
3356
3357
* Register Group Instance : slavegrp_etr
3358
3359
* Instance slavegrp_etr of register group ALT_L3_SLV_ETR.
3360
3361
3362
3363
/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_ETR instance. */
3364
#define ALT_L3_SLV_SLV_ETR_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_ETR_ADDR)
3365
/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_ETR instance. */
3366
#define ALT_L3_SLV_SLV_ETR_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_ETR_ADDR)
3367
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_ETR instance. */
3368
#define ALT_L3_SLV_SLV_ETR_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_ETR_ADDR)
3369
/* The base address byte offset for the start of the ALT_L3_SLV_SLV_ETR component. */
3370
#define ALT_L3_SLV_SLV_ETR_OFST 0x5000
3371
/* The start address of the ALT_L3_SLV_SLV_ETR component. */
3372
#define ALT_L3_SLV_SLV_ETR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_ETR_OFST))
3373
/* The lower bound address range of the ALT_L3_SLV_SLV_ETR component. */
3374
#define ALT_L3_SLV_SLV_ETR_LB_ADDR ALT_L3_SLV_SLV_ETR_ADDR
3375
/* The upper bound address range of the ALT_L3_SLV_SLV_ETR component. */
3376
#define ALT_L3_SLV_SLV_ETR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_ETR_ADDR) + 0x10c) - 1))
3377
3378
3379
3380
* Register Group Instance : slavegrp_emac0
3381
3382
* Instance slavegrp_emac0 of register group ALT_L3_SLV_EMAC0.
3383
3384
3385
3386
/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_EMAC0 instance. */
3387
#define ALT_L3_SLV_SLV_EMAC0_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_EMAC0_ADDR)
3388
/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_EMAC0 instance. */
3389
#define ALT_L3_SLV_SLV_EMAC0_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_EMAC0_ADDR)
3390
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_EMAC0 instance. */
3391
#define ALT_L3_SLV_SLV_EMAC0_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_EMAC0_ADDR)
3392
/* The base address byte offset for the start of the ALT_L3_SLV_SLV_EMAC0 component. */
3393
#define ALT_L3_SLV_SLV_EMAC0_OFST 0x6000
3394
/* The start address of the ALT_L3_SLV_SLV_EMAC0 component. */
3395
#define ALT_L3_SLV_SLV_EMAC0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_EMAC0_OFST))
3396
/* The lower bound address range of the ALT_L3_SLV_SLV_EMAC0 component. */
3397
#define ALT_L3_SLV_SLV_EMAC0_LB_ADDR ALT_L3_SLV_SLV_EMAC0_ADDR
3398
/* The upper bound address range of the ALT_L3_SLV_SLV_EMAC0 component. */
3399
#define ALT_L3_SLV_SLV_EMAC0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_EMAC0_ADDR) + 0x10c) - 1))
3400
3401
3402
3403
* Register Group Instance : slavegrp_emac1
3404
3405
* Instance slavegrp_emac1 of register group ALT_L3_SLV_EMAC1.
3406
3407
3408
3409
/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_EMAC1 instance. */
3410
#define ALT_L3_SLV_SLV_EMAC1_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_EMAC1_ADDR)
3411
/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_EMAC1 instance. */
3412
#define ALT_L3_SLV_SLV_EMAC1_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_EMAC1_ADDR)
3413
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_EMAC1 instance. */
3414
#define ALT_L3_SLV_SLV_EMAC1_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_EMAC1_ADDR)
3415
/* The base address byte offset for the start of the ALT_L3_SLV_SLV_EMAC1 component. */
3416
#define ALT_L3_SLV_SLV_EMAC1_OFST 0x7000
3417
/* The start address of the ALT_L3_SLV_SLV_EMAC1 component. */
3418
#define ALT_L3_SLV_SLV_EMAC1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_EMAC1_OFST))
3419
/* The lower bound address range of the ALT_L3_SLV_SLV_EMAC1 component. */
3420
#define ALT_L3_SLV_SLV_EMAC1_LB_ADDR ALT_L3_SLV_SLV_EMAC1_ADDR
3421
/* The upper bound address range of the ALT_L3_SLV_SLV_EMAC1 component. */
3422
#define ALT_L3_SLV_SLV_EMAC1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_EMAC1_ADDR) + 0x10c) - 1))
3423
3424
3425
3426
* Register Group Instance : slavegrp_usb0
3427
3428
* Instance slavegrp_usb0 of register group ALT_L3_SLV_USB0.
3429
3430
3431
3432
/* The address of the ALT_L3_FN_MOD_AHB register for the ALT_L3_SLV_SLV_USB0 instance. */
3433
#define ALT_L3_SLV_SLV_USB0_FN_MOD_AHB_ADDR ALT_L3_FN_MOD_AHB_ADDR(ALT_L3_SLV_SLV_USB0_ADDR)
3434
/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_USB0 instance. */
3435
#define ALT_L3_SLV_SLV_USB0_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_USB0_ADDR)
3436
/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_USB0 instance. */
3437
#define ALT_L3_SLV_SLV_USB0_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_USB0_ADDR)
3438
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_USB0 instance. */
3439
#define ALT_L3_SLV_SLV_USB0_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_USB0_ADDR)
3440
/* The base address byte offset for the start of the ALT_L3_SLV_SLV_USB0 component. */
3441
#define ALT_L3_SLV_SLV_USB0_OFST 0x8000
3442
/* The start address of the ALT_L3_SLV_SLV_USB0 component. */
3443
#define ALT_L3_SLV_SLV_USB0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_USB0_OFST))
3444
/* The lower bound address range of the ALT_L3_SLV_SLV_USB0 component. */
3445
#define ALT_L3_SLV_SLV_USB0_LB_ADDR ALT_L3_SLV_SLV_USB0_ADDR
3446
/* The upper bound address range of the ALT_L3_SLV_SLV_USB0 component. */
3447
#define ALT_L3_SLV_SLV_USB0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_USB0_ADDR) + 0x10c) - 1))
3448
3449
3450
3451
* Register Group Instance : slavegrp_nand
3452
3453
* Instance slavegrp_nand of register group ALT_L3_SLV_NAND.
3454
3455
3456
3457
/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_NAND instance. */
3458
#define ALT_L3_SLV_SLV_NAND_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_NAND_ADDR)
3459
/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_NAND instance. */
3460
#define ALT_L3_SLV_SLV_NAND_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_NAND_ADDR)
3461
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_NAND instance. */
3462
#define ALT_L3_SLV_SLV_NAND_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_NAND_ADDR)
3463
/* The base address byte offset for the start of the ALT_L3_SLV_SLV_NAND component. */
3464
#define ALT_L3_SLV_SLV_NAND_OFST 0x9000
3465
/* The start address of the ALT_L3_SLV_SLV_NAND component. */
3466
#define ALT_L3_SLV_SLV_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_NAND_OFST))
3467
/* The lower bound address range of the ALT_L3_SLV_SLV_NAND component. */
3468
#define ALT_L3_SLV_SLV_NAND_LB_ADDR ALT_L3_SLV_SLV_NAND_ADDR
3469
/* The upper bound address range of the ALT_L3_SLV_SLV_NAND component. */
3470
#define ALT_L3_SLV_SLV_NAND_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_NAND_ADDR) + 0x10c) - 1))
3471
3472
3473
3474
* Register Group Instance : slavegrp_usb1
3475
3476
* Instance slavegrp_usb1 of register group ALT_L3_SLV_USB1.
3477
3478
3479
3480
/* The address of the ALT_L3_FN_MOD_AHB register for the ALT_L3_SLV_SLV_USB1 instance. */
3481
#define ALT_L3_SLV_SLV_USB1_FN_MOD_AHB_ADDR ALT_L3_FN_MOD_AHB_ADDR(ALT_L3_SLV_SLV_USB1_ADDR)
3482
/* The address of the ALT_L3_RD_QOS register for the ALT_L3_SLV_SLV_USB1 instance. */
3483
#define ALT_L3_SLV_SLV_USB1_RD_QOS_ADDR ALT_L3_RD_QOS_ADDR(ALT_L3_SLV_SLV_USB1_ADDR)
3484
/* The address of the ALT_L3_WR_QOS register for the ALT_L3_SLV_SLV_USB1 instance. */
3485
#define ALT_L3_SLV_SLV_USB1_WR_QOS_ADDR ALT_L3_WR_QOS_ADDR(ALT_L3_SLV_SLV_USB1_ADDR)
3486
/* The address of the ALT_L3_FN_MOD register for the ALT_L3_SLV_SLV_USB1 instance. */
3487
#define ALT_L3_SLV_SLV_USB1_FN_MOD_ADDR ALT_L3_FN_MOD_ADDR(ALT_L3_SLV_SLV_USB1_ADDR)
3488
/* The base address byte offset for the start of the ALT_L3_SLV_SLV_USB1 component. */
3489
#define ALT_L3_SLV_SLV_USB1_OFST 0xa000
3490
/* The start address of the ALT_L3_SLV_SLV_USB1 component. */
3491
#define ALT_L3_SLV_SLV_USB1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + ALT_L3_SLV_SLV_USB1_OFST))
3492
/* The lower bound address range of the ALT_L3_SLV_SLV_USB1 component. */
3493
#define ALT_L3_SLV_SLV_USB1_LB_ADDR ALT_L3_SLV_SLV_USB1_ADDR
3494
/* The upper bound address range of the ALT_L3_SLV_SLV_USB1 component. */
3495
#define ALT_L3_SLV_SLV_USB1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLV_SLV_USB1_ADDR) + 0x10c) - 1))
3496
3497
3498
/* The base address byte offset for the start of the ALT_L3_SLVGRP component. */
3499
#define ALT_L3_SLVGRP_OFST 0x42000
3500
/* The start address of the ALT_L3_SLVGRP component. */
3501
#define ALT_L3_SLVGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_L3_ADDR) + ALT_L3_SLVGRP_OFST))
3502
/* The lower bound address range of the ALT_L3_SLVGRP component. */
3503
#define ALT_L3_SLVGRP_LB_ADDR ALT_L3_SLVGRP_ADDR
3504
/* The upper bound address range of the ALT_L3_SLVGRP component. */
3505
#define ALT_L3_SLVGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_SLVGRP_ADDR) + 0xa10c) - 1))
3506
3507
3508
/* The base address byte offset for the start of the ALT_L3 component. */
3509
#define ALT_L3_OFST 0xff800000
3510
/* The start address of the ALT_L3 component. */
3511
#define ALT_L3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_L3_OFST))
3512
/* The lower bound address range of the ALT_L3 component. */
3513
#define ALT_L3_LB_ADDR ALT_L3_ADDR
3514
/* The upper bound address range of the ALT_L3 component. */
3515
#define ALT_L3_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L3_ADDR) + 0x80000) - 1))
3516
3517
3518
3519
* Component Instance : nanddata
3520
3521
* Instance nanddata of component ALT_NANDDATA.
3522
3523
3524
3525
/* The base address byte offset for the start of the ALT_NANDDATA component. */
3526
#define ALT_NANDDATA_OFST 0xff900000
3527
/* The start address of the ALT_NANDDATA component. */
3528
#define ALT_NANDDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_NANDDATA_OFST))
3529
/* The lower bound address range of the ALT_NANDDATA component. */
3530
#define ALT_NANDDATA_LB_ADDR ALT_NANDDATA_ADDR
3531
/* The upper bound address range of the ALT_NANDDATA component. */
3532
#define ALT_NANDDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NANDDATA_ADDR) + 0x100000) - 1))
3533
3534
3535
3536
* Component Instance : qspidata
3537
3538
* Instance qspidata of component ALT_QSPIDATA.
3539
3540
3541
3542
/* The base address byte offset for the start of the ALT_QSPIDATA component. */
3543
#define ALT_QSPIDATA_OFST 0xffa00000
3544
/* The start address of the ALT_QSPIDATA component. */
3545
#define ALT_QSPIDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_QSPIDATA_OFST))
3546
/* The lower bound address range of the ALT_QSPIDATA component. */
3547
#define ALT_QSPIDATA_LB_ADDR ALT_QSPIDATA_ADDR
3548
/* The upper bound address range of the ALT_QSPIDATA component. */
3549
#define ALT_QSPIDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_QSPIDATA_ADDR) + 0x100000) - 1))
3550
3551
3552
3553
* Component Instance : usb0
3554
3555
* Instance usb0 of component ALT_USB.
3556
3557
3558
3559
3560
* Register Group Instance : globgrp
3561
3562
* Instance globgrp of register group ALT_USB_GLOB.
3563
3564
3565
3566
/* The address of the ALT_USB_GLOB_GOTGCTL register for the ALT_USB0_GLOBGRP instance. */
3567
#define ALT_USB0_GLOB_GOTGCTL_ADDR ALT_USB_GLOB_GOTGCTL_ADDR(ALT_USB0_GLOBGRP_ADDR)
3568
/* The address of the ALT_USB_GLOB_GOTGINT register for the ALT_USB0_GLOBGRP instance. */
3569
#define ALT_USB0_GLOB_GOTGINT_ADDR ALT_USB_GLOB_GOTGINT_ADDR(ALT_USB0_GLOBGRP_ADDR)
3570
/* The address of the ALT_USB_GLOB_GAHBCFG register for the ALT_USB0_GLOBGRP instance. */
3571
#define ALT_USB0_GLOB_GAHBCFG_ADDR ALT_USB_GLOB_GAHBCFG_ADDR(ALT_USB0_GLOBGRP_ADDR)
3572
/* The address of the ALT_USB_GLOB_GUSBCFG register for the ALT_USB0_GLOBGRP instance. */
3573
#define ALT_USB0_GLOB_GUSBCFG_ADDR ALT_USB_GLOB_GUSBCFG_ADDR(ALT_USB0_GLOBGRP_ADDR)
3574
/* The address of the ALT_USB_GLOB_GRSTCTL register for the ALT_USB0_GLOBGRP instance. */
3575
#define ALT_USB0_GLOB_GRSTCTL_ADDR ALT_USB_GLOB_GRSTCTL_ADDR(ALT_USB0_GLOBGRP_ADDR)
3576
/* The address of the ALT_USB_GLOB_GINTSTS register for the ALT_USB0_GLOBGRP instance. */
3577
#define ALT_USB0_GLOB_GINTSTS_ADDR ALT_USB_GLOB_GINTSTS_ADDR(ALT_USB0_GLOBGRP_ADDR)
3578
/* The address of the ALT_USB_GLOB_GINTMSK register for the ALT_USB0_GLOBGRP instance. */
3579
#define ALT_USB0_GLOB_GINTMSK_ADDR ALT_USB_GLOB_GINTMSK_ADDR(ALT_USB0_GLOBGRP_ADDR)
3580
/* The address of the ALT_USB_GLOB_GRXSTSR register for the ALT_USB0_GLOBGRP instance. */
3581
#define ALT_USB0_GLOB_GRXSTSR_ADDR ALT_USB_GLOB_GRXSTSR_ADDR(ALT_USB0_GLOBGRP_ADDR)
3582
/* The address of the ALT_USB_GLOB_GRXSTSP register for the ALT_USB0_GLOBGRP instance. */
3583
#define ALT_USB0_GLOB_GRXSTSP_ADDR ALT_USB_GLOB_GRXSTSP_ADDR(ALT_USB0_GLOBGRP_ADDR)
3584
/* The address of the ALT_USB_GLOB_GRXFSIZ register for the ALT_USB0_GLOBGRP instance. */
3585
#define ALT_USB0_GLOB_GRXFSIZ_ADDR ALT_USB_GLOB_GRXFSIZ_ADDR(ALT_USB0_GLOBGRP_ADDR)
3586
/* The address of the ALT_USB_GLOB_GNPTXFSIZ register for the ALT_USB0_GLOBGRP instance. */
3587
#define ALT_USB0_GLOB_GNPTXFSIZ_ADDR ALT_USB_GLOB_GNPTXFSIZ_ADDR(ALT_USB0_GLOBGRP_ADDR)
3588
/* The address of the ALT_USB_GLOB_GNPTXSTS register for the ALT_USB0_GLOBGRP instance. */
3589
#define ALT_USB0_GLOB_GNPTXSTS_ADDR ALT_USB_GLOB_GNPTXSTS_ADDR(ALT_USB0_GLOBGRP_ADDR)
3590
/* The address of the ALT_USB_GLOB_GPVNDCTL register for the ALT_USB0_GLOBGRP instance. */
3591
#define ALT_USB0_GLOB_GPVNDCTL_ADDR ALT_USB_GLOB_GPVNDCTL_ADDR(ALT_USB0_GLOBGRP_ADDR)
3592
/* The address of the ALT_USB_GLOB_GGPIO register for the ALT_USB0_GLOBGRP instance. */
3593
#define ALT_USB0_GLOB_GGPIO_ADDR ALT_USB_GLOB_GGPIO_ADDR(ALT_USB0_GLOBGRP_ADDR)
3594
/* The address of the ALT_USB_GLOB_GUID register for the ALT_USB0_GLOBGRP instance. */
3595
#define ALT_USB0_GLOB_GUID_ADDR ALT_USB_GLOB_GUID_ADDR(ALT_USB0_GLOBGRP_ADDR)
3596
/* The address of the ALT_USB_GLOB_GSNPSID register for the ALT_USB0_GLOBGRP instance. */
3597
#define ALT_USB0_GLOB_GSNPSID_ADDR ALT_USB_GLOB_GSNPSID_ADDR(ALT_USB0_GLOBGRP_ADDR)
3598
/* The address of the ALT_USB_GLOB_GHWCFG1 register for the ALT_USB0_GLOBGRP instance. */
3599
#define ALT_USB0_GLOB_GHWCFG1_ADDR ALT_USB_GLOB_GHWCFG1_ADDR(ALT_USB0_GLOBGRP_ADDR)
3600
/* The address of the ALT_USB_GLOB_GHWCFG2 register for the ALT_USB0_GLOBGRP instance. */
3601
#define ALT_USB0_GLOB_GHWCFG2_ADDR ALT_USB_GLOB_GHWCFG2_ADDR(ALT_USB0_GLOBGRP_ADDR)
3602
/* The address of the ALT_USB_GLOB_GHWCFG3 register for the ALT_USB0_GLOBGRP instance. */
3603
#define ALT_USB0_GLOB_GHWCFG3_ADDR ALT_USB_GLOB_GHWCFG3_ADDR(ALT_USB0_GLOBGRP_ADDR)
3604
/* The address of the ALT_USB_GLOB_GHWCFG4 register for the ALT_USB0_GLOBGRP instance. */
3605
#define ALT_USB0_GLOB_GHWCFG4_ADDR ALT_USB_GLOB_GHWCFG4_ADDR(ALT_USB0_GLOBGRP_ADDR)
3606
/* The address of the ALT_USB_GLOB_GDFIFOCFG register for the ALT_USB0_GLOBGRP instance. */
3607
#define ALT_USB0_GLOB_GDFIFOCFG_ADDR ALT_USB_GLOB_GDFIFOCFG_ADDR(ALT_USB0_GLOBGRP_ADDR)
3608
/* The address of the ALT_USB_GLOB_HPTXFSIZ register for the ALT_USB0_GLOBGRP instance. */
3609
#define ALT_USB0_GLOB_HPTXFSIZ_ADDR ALT_USB_GLOB_HPTXFSIZ_ADDR(ALT_USB0_GLOBGRP_ADDR)
3610
/* The address of the ALT_USB_GLOB_DIEPTXF1 register for the ALT_USB0_GLOBGRP instance. */
3611
#define ALT_USB0_GLOB_DIEPTXF1_ADDR ALT_USB_GLOB_DIEPTXF1_ADDR(ALT_USB0_GLOBGRP_ADDR)
3612
/* The address of the ALT_USB_GLOB_DIEPTXF2 register for the ALT_USB0_GLOBGRP instance. */
3613
#define ALT_USB0_GLOB_DIEPTXF2_ADDR ALT_USB_GLOB_DIEPTXF2_ADDR(ALT_USB0_GLOBGRP_ADDR)
3614
/* The address of the ALT_USB_GLOB_DIEPTXF3 register for the ALT_USB0_GLOBGRP instance. */
3615
#define ALT_USB0_GLOB_DIEPTXF3_ADDR ALT_USB_GLOB_DIEPTXF3_ADDR(ALT_USB0_GLOBGRP_ADDR)
3616
/* The address of the ALT_USB_GLOB_DIEPTXF4 register for the ALT_USB0_GLOBGRP instance. */
3617
#define ALT_USB0_GLOB_DIEPTXF4_ADDR ALT_USB_GLOB_DIEPTXF4_ADDR(ALT_USB0_GLOBGRP_ADDR)
3618
/* The address of the ALT_USB_GLOB_DIEPTXF5 register for the ALT_USB0_GLOBGRP instance. */
3619
#define ALT_USB0_GLOB_DIEPTXF5_ADDR ALT_USB_GLOB_DIEPTXF5_ADDR(ALT_USB0_GLOBGRP_ADDR)
3620
/* The address of the ALT_USB_GLOB_DIEPTXF6 register for the ALT_USB0_GLOBGRP instance. */
3621
#define ALT_USB0_GLOB_DIEPTXF6_ADDR ALT_USB_GLOB_DIEPTXF6_ADDR(ALT_USB0_GLOBGRP_ADDR)
3622
/* The address of the ALT_USB_GLOB_DIEPTXF7 register for the ALT_USB0_GLOBGRP instance. */
3623
#define ALT_USB0_GLOB_DIEPTXF7_ADDR ALT_USB_GLOB_DIEPTXF7_ADDR(ALT_USB0_GLOBGRP_ADDR)
3624
/* The address of the ALT_USB_GLOB_DIEPTXF8 register for the ALT_USB0_GLOBGRP instance. */
3625
#define ALT_USB0_GLOB_DIEPTXF8_ADDR ALT_USB_GLOB_DIEPTXF8_ADDR(ALT_USB0_GLOBGRP_ADDR)
3626
/* The address of the ALT_USB_GLOB_DIEPTXF9 register for the ALT_USB0_GLOBGRP instance. */
3627
#define ALT_USB0_GLOB_DIEPTXF9_ADDR ALT_USB_GLOB_DIEPTXF9_ADDR(ALT_USB0_GLOBGRP_ADDR)
3628
/* The address of the ALT_USB_GLOB_DIEPTXF10 register for the ALT_USB0_GLOBGRP instance. */
3629
#define ALT_USB0_GLOB_DIEPTXF10_ADDR ALT_USB_GLOB_DIEPTXF10_ADDR(ALT_USB0_GLOBGRP_ADDR)
3630
/* The address of the ALT_USB_GLOB_DIEPTXF11 register for the ALT_USB0_GLOBGRP instance. */
3631
#define ALT_USB0_GLOB_DIEPTXF11_ADDR ALT_USB_GLOB_DIEPTXF11_ADDR(ALT_USB0_GLOBGRP_ADDR)
3632
/* The address of the ALT_USB_GLOB_DIEPTXF12 register for the ALT_USB0_GLOBGRP instance. */
3633
#define ALT_USB0_GLOB_DIEPTXF12_ADDR ALT_USB_GLOB_DIEPTXF12_ADDR(ALT_USB0_GLOBGRP_ADDR)
3634
/* The address of the ALT_USB_GLOB_DIEPTXF13 register for the ALT_USB0_GLOBGRP instance. */
3635
#define ALT_USB0_GLOB_DIEPTXF13_ADDR ALT_USB_GLOB_DIEPTXF13_ADDR(ALT_USB0_GLOBGRP_ADDR)
3636
/* The address of the ALT_USB_GLOB_DIEPTXF14 register for the ALT_USB0_GLOBGRP instance. */
3637
#define ALT_USB0_GLOB_DIEPTXF14_ADDR ALT_USB_GLOB_DIEPTXF14_ADDR(ALT_USB0_GLOBGRP_ADDR)
3638
/* The address of the ALT_USB_GLOB_DIEPTXF15 register for the ALT_USB0_GLOBGRP instance. */
3639
#define ALT_USB0_GLOB_DIEPTXF15_ADDR ALT_USB_GLOB_DIEPTXF15_ADDR(ALT_USB0_GLOBGRP_ADDR)
3640
/* The base address byte offset for the start of the ALT_USB0_GLOBGRP component. */
3641
#define ALT_USB0_GLOBGRP_OFST 0x0
3642
/* The start address of the ALT_USB0_GLOBGRP component. */
3643
#define ALT_USB0_GLOBGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB0_ADDR) + ALT_USB0_GLOBGRP_OFST))
3644
/* The lower bound address range of the ALT_USB0_GLOBGRP component. */
3645
#define ALT_USB0_GLOBGRP_LB_ADDR ALT_USB0_GLOBGRP_ADDR
3646
/* The upper bound address range of the ALT_USB0_GLOBGRP component. */
3647
#define ALT_USB0_GLOBGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB0_GLOBGRP_ADDR) + 0x140) - 1))
3648
3649
3650
3651
* Register Group Instance : hostgrp
3652
3653
* Instance hostgrp of register group ALT_USB_HOST.
3654
3655
3656
3657
/* The address of the ALT_USB_HOST_HCFG register for the ALT_USB0_HOSTGRP instance. */
3658
#define ALT_USB0_HOST_HCFG_ADDR ALT_USB_HOST_HCFG_ADDR(ALT_USB0_HOSTGRP_ADDR)
3659
/* The address of the ALT_USB_HOST_HFIR register for the ALT_USB0_HOSTGRP instance. */
3660
#define ALT_USB0_HOST_HFIR_ADDR ALT_USB_HOST_HFIR_ADDR(ALT_USB0_HOSTGRP_ADDR)
3661
/* The address of the ALT_USB_HOST_HFNUM register for the ALT_USB0_HOSTGRP instance. */
3662
#define ALT_USB0_HOST_HFNUM_ADDR ALT_USB_HOST_HFNUM_ADDR(ALT_USB0_HOSTGRP_ADDR)
3663
/* The address of the ALT_USB_HOST_HPTXSTS register for the ALT_USB0_HOSTGRP instance. */
3664
#define ALT_USB0_HOST_HPTXSTS_ADDR ALT_USB_HOST_HPTXSTS_ADDR(ALT_USB0_HOSTGRP_ADDR)
3665
/* The address of the ALT_USB_HOST_HAINT register for the ALT_USB0_HOSTGRP instance. */
3666
#define ALT_USB0_HOST_HAINT_ADDR ALT_USB_HOST_HAINT_ADDR(ALT_USB0_HOSTGRP_ADDR)
3667
/* The address of the ALT_USB_HOST_HAINTMSK register for the ALT_USB0_HOSTGRP instance. */
3668
#define ALT_USB0_HOST_HAINTMSK_ADDR ALT_USB_HOST_HAINTMSK_ADDR(ALT_USB0_HOSTGRP_ADDR)
3669
/* The address of the ALT_USB_HOST_HFLBADDR register for the ALT_USB0_HOSTGRP instance. */
3670
#define ALT_USB0_HOST_HFLBADDR_ADDR ALT_USB_HOST_HFLBADDR_ADDR(ALT_USB0_HOSTGRP_ADDR)
3671
/* The address of the ALT_USB_HOST_HPRT register for the ALT_USB0_HOSTGRP instance. */
3672
#define ALT_USB0_HOST_HPRT_ADDR ALT_USB_HOST_HPRT_ADDR(ALT_USB0_HOSTGRP_ADDR)
3673
/* The address of the ALT_USB_HOST_HCCHAR0 register for the ALT_USB0_HOSTGRP instance. */
3674
#define ALT_USB0_HOST_HCCHAR0_ADDR ALT_USB_HOST_HCCHAR0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3675
/* The address of the ALT_USB_HOST_HCSPLT0 register for the ALT_USB0_HOSTGRP instance. */
3676
#define ALT_USB0_HOST_HCSPLT0_ADDR ALT_USB_HOST_HCSPLT0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3677
/* The address of the ALT_USB_HOST_HCINT0 register for the ALT_USB0_HOSTGRP instance. */
3678
#define ALT_USB0_HOST_HCINT0_ADDR ALT_USB_HOST_HCINT0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3679
/* The address of the ALT_USB_HOST_HCINTMSK0 register for the ALT_USB0_HOSTGRP instance. */
3680
#define ALT_USB0_HOST_HCINTMSK0_ADDR ALT_USB_HOST_HCINTMSK0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3681
/* The address of the ALT_USB_HOST_HCTSIZ0 register for the ALT_USB0_HOSTGRP instance. */
3682
#define ALT_USB0_HOST_HCTSIZ0_ADDR ALT_USB_HOST_HCTSIZ0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3683
/* The address of the ALT_USB_HOST_HCDMA0 register for the ALT_USB0_HOSTGRP instance. */
3684
#define ALT_USB0_HOST_HCDMA0_ADDR ALT_USB_HOST_HCDMA0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3685
/* The address of the ALT_USB_HOST_HCDMAB0 register for the ALT_USB0_HOSTGRP instance. */
3686
#define ALT_USB0_HOST_HCDMAB0_ADDR ALT_USB_HOST_HCDMAB0_ADDR(ALT_USB0_HOSTGRP_ADDR)
3687
/* The address of the ALT_USB_HOST_HCCHAR1 register for the ALT_USB0_HOSTGRP instance. */
3688
#define ALT_USB0_HOST_HCCHAR1_ADDR ALT_USB_HOST_HCCHAR1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3689
/* The address of the ALT_USB_HOST_HCSPLT1 register for the ALT_USB0_HOSTGRP instance. */
3690
#define ALT_USB0_HOST_HCSPLT1_ADDR ALT_USB_HOST_HCSPLT1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3691
/* The address of the ALT_USB_HOST_HCINT1 register for the ALT_USB0_HOSTGRP instance. */
3692
#define ALT_USB0_HOST_HCINT1_ADDR ALT_USB_HOST_HCINT1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3693
/* The address of the ALT_USB_HOST_HCINTMSK1 register for the ALT_USB0_HOSTGRP instance. */
3694
#define ALT_USB0_HOST_HCINTMSK1_ADDR ALT_USB_HOST_HCINTMSK1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3695
/* The address of the ALT_USB_HOST_HCTSIZ1 register for the ALT_USB0_HOSTGRP instance. */
3696
#define ALT_USB0_HOST_HCTSIZ1_ADDR ALT_USB_HOST_HCTSIZ1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3697
/* The address of the ALT_USB_HOST_HCDMA1 register for the ALT_USB0_HOSTGRP instance. */
3698
#define ALT_USB0_HOST_HCDMA1_ADDR ALT_USB_HOST_HCDMA1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3699
/* The address of the ALT_USB_HOST_HCDMAB1 register for the ALT_USB0_HOSTGRP instance. */
3700
#define ALT_USB0_HOST_HCDMAB1_ADDR ALT_USB_HOST_HCDMAB1_ADDR(ALT_USB0_HOSTGRP_ADDR)
3701
/* The address of the ALT_USB_HOST_HCCHAR2 register for the ALT_USB0_HOSTGRP instance. */
3702
#define ALT_USB0_HOST_HCCHAR2_ADDR ALT_USB_HOST_HCCHAR2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3703
/* The address of the ALT_USB_HOST_HCSPLT2 register for the ALT_USB0_HOSTGRP instance. */
3704
#define ALT_USB0_HOST_HCSPLT2_ADDR ALT_USB_HOST_HCSPLT2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3705
/* The address of the ALT_USB_HOST_HCINT2 register for the ALT_USB0_HOSTGRP instance. */
3706
#define ALT_USB0_HOST_HCINT2_ADDR ALT_USB_HOST_HCINT2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3707
/* The address of the ALT_USB_HOST_HCINTMSK2 register for the ALT_USB0_HOSTGRP instance. */
3708
#define ALT_USB0_HOST_HCINTMSK2_ADDR ALT_USB_HOST_HCINTMSK2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3709
/* The address of the ALT_USB_HOST_HCTSIZ2 register for the ALT_USB0_HOSTGRP instance. */
3710
#define ALT_USB0_HOST_HCTSIZ2_ADDR ALT_USB_HOST_HCTSIZ2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3711
/* The address of the ALT_USB_HOST_HCDMA2 register for the ALT_USB0_HOSTGRP instance. */
3712
#define ALT_USB0_HOST_HCDMA2_ADDR ALT_USB_HOST_HCDMA2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3713
/* The address of the ALT_USB_HOST_HCDMAB2 register for the ALT_USB0_HOSTGRP instance. */
3714
#define ALT_USB0_HOST_HCDMAB2_ADDR ALT_USB_HOST_HCDMAB2_ADDR(ALT_USB0_HOSTGRP_ADDR)
3715
/* The address of the ALT_USB_HOST_HCCHAR3 register for the ALT_USB0_HOSTGRP instance. */
3716
#define ALT_USB0_HOST_HCCHAR3_ADDR ALT_USB_HOST_HCCHAR3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3717
/* The address of the ALT_USB_HOST_HCSPLT3 register for the ALT_USB0_HOSTGRP instance. */
3718
#define ALT_USB0_HOST_HCSPLT3_ADDR ALT_USB_HOST_HCSPLT3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3719
/* The address of the ALT_USB_HOST_HCINT3 register for the ALT_USB0_HOSTGRP instance. */
3720
#define ALT_USB0_HOST_HCINT3_ADDR ALT_USB_HOST_HCINT3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3721
/* The address of the ALT_USB_HOST_HCINTMSK3 register for the ALT_USB0_HOSTGRP instance. */
3722
#define ALT_USB0_HOST_HCINTMSK3_ADDR ALT_USB_HOST_HCINTMSK3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3723
/* The address of the ALT_USB_HOST_HCTSIZ3 register for the ALT_USB0_HOSTGRP instance. */
3724
#define ALT_USB0_HOST_HCTSIZ3_ADDR ALT_USB_HOST_HCTSIZ3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3725
/* The address of the ALT_USB_HOST_HCDMA3 register for the ALT_USB0_HOSTGRP instance. */
3726
#define ALT_USB0_HOST_HCDMA3_ADDR ALT_USB_HOST_HCDMA3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3727
/* The address of the ALT_USB_HOST_HCDMAB3 register for the ALT_USB0_HOSTGRP instance. */
3728
#define ALT_USB0_HOST_HCDMAB3_ADDR ALT_USB_HOST_HCDMAB3_ADDR(ALT_USB0_HOSTGRP_ADDR)
3729
/* The address of the ALT_USB_HOST_HCCHAR4 register for the ALT_USB0_HOSTGRP instance. */
3730
#define ALT_USB0_HOST_HCCHAR4_ADDR ALT_USB_HOST_HCCHAR4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3731
/* The address of the ALT_USB_HOST_HCSPLT4 register for the ALT_USB0_HOSTGRP instance. */
3732
#define ALT_USB0_HOST_HCSPLT4_ADDR ALT_USB_HOST_HCSPLT4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3733
/* The address of the ALT_USB_HOST_HCINT4 register for the ALT_USB0_HOSTGRP instance. */
3734
#define ALT_USB0_HOST_HCINT4_ADDR ALT_USB_HOST_HCINT4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3735
/* The address of the ALT_USB_HOST_HCINTMSK4 register for the ALT_USB0_HOSTGRP instance. */
3736
#define ALT_USB0_HOST_HCINTMSK4_ADDR ALT_USB_HOST_HCINTMSK4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3737
/* The address of the ALT_USB_HOST_HCTSIZ4 register for the ALT_USB0_HOSTGRP instance. */
3738
#define ALT_USB0_HOST_HCTSIZ4_ADDR ALT_USB_HOST_HCTSIZ4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3739
/* The address of the ALT_USB_HOST_HCDMA4 register for the ALT_USB0_HOSTGRP instance. */
3740
#define ALT_USB0_HOST_HCDMA4_ADDR ALT_USB_HOST_HCDMA4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3741
/* The address of the ALT_USB_HOST_HCDMAB4 register for the ALT_USB0_HOSTGRP instance. */
3742
#define ALT_USB0_HOST_HCDMAB4_ADDR ALT_USB_HOST_HCDMAB4_ADDR(ALT_USB0_HOSTGRP_ADDR)
3743
/* The address of the ALT_USB_HOST_HCCHAR5 register for the ALT_USB0_HOSTGRP instance. */
3744
#define ALT_USB0_HOST_HCCHAR5_ADDR ALT_USB_HOST_HCCHAR5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3745
/* The address of the ALT_USB_HOST_HCSPLT5 register for the ALT_USB0_HOSTGRP instance. */
3746
#define ALT_USB0_HOST_HCSPLT5_ADDR ALT_USB_HOST_HCSPLT5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3747
/* The address of the ALT_USB_HOST_HCINT5 register for the ALT_USB0_HOSTGRP instance. */
3748
#define ALT_USB0_HOST_HCINT5_ADDR ALT_USB_HOST_HCINT5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3749
/* The address of the ALT_USB_HOST_HCINTMSK5 register for the ALT_USB0_HOSTGRP instance. */
3750
#define ALT_USB0_HOST_HCINTMSK5_ADDR ALT_USB_HOST_HCINTMSK5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3751
/* The address of the ALT_USB_HOST_HCTSIZ5 register for the ALT_USB0_HOSTGRP instance. */
3752
#define ALT_USB0_HOST_HCTSIZ5_ADDR ALT_USB_HOST_HCTSIZ5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3753
/* The address of the ALT_USB_HOST_HCDMA5 register for the ALT_USB0_HOSTGRP instance. */
3754
#define ALT_USB0_HOST_HCDMA5_ADDR ALT_USB_HOST_HCDMA5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3755
/* The address of the ALT_USB_HOST_HCDMAB5 register for the ALT_USB0_HOSTGRP instance. */
3756
#define ALT_USB0_HOST_HCDMAB5_ADDR ALT_USB_HOST_HCDMAB5_ADDR(ALT_USB0_HOSTGRP_ADDR)
3757
/* The address of the ALT_USB_HOST_HCCHAR6 register for the ALT_USB0_HOSTGRP instance. */
3758
#define ALT_USB0_HOST_HCCHAR6_ADDR ALT_USB_HOST_HCCHAR6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3759
/* The address of the ALT_USB_HOST_HCSPLT6 register for the ALT_USB0_HOSTGRP instance. */
3760
#define ALT_USB0_HOST_HCSPLT6_ADDR ALT_USB_HOST_HCSPLT6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3761
/* The address of the ALT_USB_HOST_HCINT6 register for the ALT_USB0_HOSTGRP instance. */
3762
#define ALT_USB0_HOST_HCINT6_ADDR ALT_USB_HOST_HCINT6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3763
/* The address of the ALT_USB_HOST_HCINTMSK6 register for the ALT_USB0_HOSTGRP instance. */
3764
#define ALT_USB0_HOST_HCINTMSK6_ADDR ALT_USB_HOST_HCINTMSK6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3765
/* The address of the ALT_USB_HOST_HCTSIZ6 register for the ALT_USB0_HOSTGRP instance. */
3766
#define ALT_USB0_HOST_HCTSIZ6_ADDR ALT_USB_HOST_HCTSIZ6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3767
/* The address of the ALT_USB_HOST_HCDMA6 register for the ALT_USB0_HOSTGRP instance. */
3768
#define ALT_USB0_HOST_HCDMA6_ADDR ALT_USB_HOST_HCDMA6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3769
/* The address of the ALT_USB_HOST_HCDMAB6 register for the ALT_USB0_HOSTGRP instance. */
3770
#define ALT_USB0_HOST_HCDMAB6_ADDR ALT_USB_HOST_HCDMAB6_ADDR(ALT_USB0_HOSTGRP_ADDR)
3771
/* The address of the ALT_USB_HOST_HCCHAR7 register for the ALT_USB0_HOSTGRP instance. */
3772
#define ALT_USB0_HOST_HCCHAR7_ADDR ALT_USB_HOST_HCCHAR7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3773
/* The address of the ALT_USB_HOST_HCSPLT7 register for the ALT_USB0_HOSTGRP instance. */
3774
#define ALT_USB0_HOST_HCSPLT7_ADDR ALT_USB_HOST_HCSPLT7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3775
/* The address of the ALT_USB_HOST_HCINT7 register for the ALT_USB0_HOSTGRP instance. */
3776
#define ALT_USB0_HOST_HCINT7_ADDR ALT_USB_HOST_HCINT7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3777
/* The address of the ALT_USB_HOST_HCINTMSK7 register for the ALT_USB0_HOSTGRP instance. */
3778
#define ALT_USB0_HOST_HCINTMSK7_ADDR ALT_USB_HOST_HCINTMSK7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3779
/* The address of the ALT_USB_HOST_HCTSIZ7 register for the ALT_USB0_HOSTGRP instance. */
3780
#define ALT_USB0_HOST_HCTSIZ7_ADDR ALT_USB_HOST_HCTSIZ7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3781
/* The address of the ALT_USB_HOST_HCDMA7 register for the ALT_USB0_HOSTGRP instance. */
3782
#define ALT_USB0_HOST_HCDMA7_ADDR ALT_USB_HOST_HCDMA7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3783
/* The address of the ALT_USB_HOST_HCDMAB7 register for the ALT_USB0_HOSTGRP instance. */
3784
#define ALT_USB0_HOST_HCDMAB7_ADDR ALT_USB_HOST_HCDMAB7_ADDR(ALT_USB0_HOSTGRP_ADDR)
3785
/* The address of the ALT_USB_HOST_HCCHAR8 register for the ALT_USB0_HOSTGRP instance. */
3786
#define ALT_USB0_HOST_HCCHAR8_ADDR ALT_USB_HOST_HCCHAR8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3787
/* The address of the ALT_USB_HOST_HCSPLT8 register for the ALT_USB0_HOSTGRP instance. */
3788
#define ALT_USB0_HOST_HCSPLT8_ADDR ALT_USB_HOST_HCSPLT8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3789
/* The address of the ALT_USB_HOST_HCINT8 register for the ALT_USB0_HOSTGRP instance. */
3790
#define ALT_USB0_HOST_HCINT8_ADDR ALT_USB_HOST_HCINT8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3791
/* The address of the ALT_USB_HOST_HCINTMSK8 register for the ALT_USB0_HOSTGRP instance. */
3792
#define ALT_USB0_HOST_HCINTMSK8_ADDR ALT_USB_HOST_HCINTMSK8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3793
/* The address of the ALT_USB_HOST_HCTSIZ8 register for the ALT_USB0_HOSTGRP instance. */
3794
#define ALT_USB0_HOST_HCTSIZ8_ADDR ALT_USB_HOST_HCTSIZ8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3795
/* The address of the ALT_USB_HOST_HCDMA8 register for the ALT_USB0_HOSTGRP instance. */
3796
#define ALT_USB0_HOST_HCDMA8_ADDR ALT_USB_HOST_HCDMA8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3797
/* The address of the ALT_USB_HOST_HCDMAB8 register for the ALT_USB0_HOSTGRP instance. */
3798
#define ALT_USB0_HOST_HCDMAB8_ADDR ALT_USB_HOST_HCDMAB8_ADDR(ALT_USB0_HOSTGRP_ADDR)
3799
/* The address of the ALT_USB_HOST_HCCHAR9 register for the ALT_USB0_HOSTGRP instance. */
3800
#define ALT_USB0_HOST_HCCHAR9_ADDR ALT_USB_HOST_HCCHAR9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3801
/* The address of the ALT_USB_HOST_HCSPLT9 register for the ALT_USB0_HOSTGRP instance. */
3802
#define ALT_USB0_HOST_HCSPLT9_ADDR ALT_USB_HOST_HCSPLT9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3803
/* The address of the ALT_USB_HOST_HCINT9 register for the ALT_USB0_HOSTGRP instance. */
3804
#define ALT_USB0_HOST_HCINT9_ADDR ALT_USB_HOST_HCINT9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3805
/* The address of the ALT_USB_HOST_HCINTMSK9 register for the ALT_USB0_HOSTGRP instance. */
3806
#define ALT_USB0_HOST_HCINTMSK9_ADDR ALT_USB_HOST_HCINTMSK9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3807
/* The address of the ALT_USB_HOST_HCTSIZ9 register for the ALT_USB0_HOSTGRP instance. */
3808
#define ALT_USB0_HOST_HCTSIZ9_ADDR ALT_USB_HOST_HCTSIZ9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3809
/* The address of the ALT_USB_HOST_HCDMA9 register for the ALT_USB0_HOSTGRP instance. */
3810
#define ALT_USB0_HOST_HCDMA9_ADDR ALT_USB_HOST_HCDMA9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3811
/* The address of the ALT_USB_HOST_HCDMAB9 register for the ALT_USB0_HOSTGRP instance. */
3812
#define ALT_USB0_HOST_HCDMAB9_ADDR ALT_USB_HOST_HCDMAB9_ADDR(ALT_USB0_HOSTGRP_ADDR)
3813
/* The address of the ALT_USB_HOST_HCCHAR10 register for the ALT_USB0_HOSTGRP instance. */
3814
#define ALT_USB0_HOST_HCCHAR10_ADDR ALT_USB_HOST_HCCHAR10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3815
/* The address of the ALT_USB_HOST_HCSPLT10 register for the ALT_USB0_HOSTGRP instance. */
3816
#define ALT_USB0_HOST_HCSPLT10_ADDR ALT_USB_HOST_HCSPLT10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3817
/* The address of the ALT_USB_HOST_HCINT10 register for the ALT_USB0_HOSTGRP instance. */
3818
#define ALT_USB0_HOST_HCINT10_ADDR ALT_USB_HOST_HCINT10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3819
/* The address of the ALT_USB_HOST_HCINTMSK10 register for the ALT_USB0_HOSTGRP instance. */
3820
#define ALT_USB0_HOST_HCINTMSK10_ADDR ALT_USB_HOST_HCINTMSK10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3821
/* The address of the ALT_USB_HOST_HCTSIZ10 register for the ALT_USB0_HOSTGRP instance. */
3822
#define ALT_USB0_HOST_HCTSIZ10_ADDR ALT_USB_HOST_HCTSIZ10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3823
/* The address of the ALT_USB_HOST_HCDMA10 register for the ALT_USB0_HOSTGRP instance. */
3824
#define ALT_USB0_HOST_HCDMA10_ADDR ALT_USB_HOST_HCDMA10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3825
/* The address of the ALT_USB_HOST_HCDMAB10 register for the ALT_USB0_HOSTGRP instance. */
3826
#define ALT_USB0_HOST_HCDMAB10_ADDR ALT_USB_HOST_HCDMAB10_ADDR(ALT_USB0_HOSTGRP_ADDR)
3827
/* The address of the ALT_USB_HOST_HCCHAR11 register for the ALT_USB0_HOSTGRP instance. */
3828
#define ALT_USB0_HOST_HCCHAR11_ADDR ALT_USB_HOST_HCCHAR11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3829
/* The address of the ALT_USB_HOST_HCSPLT11 register for the ALT_USB0_HOSTGRP instance. */
3830
#define ALT_USB0_HOST_HCSPLT11_ADDR ALT_USB_HOST_HCSPLT11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3831
/* The address of the ALT_USB_HOST_HCINT11 register for the ALT_USB0_HOSTGRP instance. */
3832
#define ALT_USB0_HOST_HCINT11_ADDR ALT_USB_HOST_HCINT11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3833
/* The address of the ALT_USB_HOST_HCINTMSK11 register for the ALT_USB0_HOSTGRP instance. */
3834
#define ALT_USB0_HOST_HCINTMSK11_ADDR ALT_USB_HOST_HCINTMSK11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3835
/* The address of the ALT_USB_HOST_HCTSIZ11 register for the ALT_USB0_HOSTGRP instance. */
3836
#define ALT_USB0_HOST_HCTSIZ11_ADDR ALT_USB_HOST_HCTSIZ11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3837
/* The address of the ALT_USB_HOST_HCDMA11 register for the ALT_USB0_HOSTGRP instance. */
3838
#define ALT_USB0_HOST_HCDMA11_ADDR ALT_USB_HOST_HCDMA11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3839
/* The address of the ALT_USB_HOST_HCDMAB11 register for the ALT_USB0_HOSTGRP instance. */
3840
#define ALT_USB0_HOST_HCDMAB11_ADDR ALT_USB_HOST_HCDMAB11_ADDR(ALT_USB0_HOSTGRP_ADDR)
3841
/* The address of the ALT_USB_HOST_HCCHAR12 register for the ALT_USB0_HOSTGRP instance. */
3842
#define ALT_USB0_HOST_HCCHAR12_ADDR ALT_USB_HOST_HCCHAR12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3843
/* The address of the ALT_USB_HOST_HCSPLT12 register for the ALT_USB0_HOSTGRP instance. */
3844
#define ALT_USB0_HOST_HCSPLT12_ADDR ALT_USB_HOST_HCSPLT12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3845
/* The address of the ALT_USB_HOST_HCINT12 register for the ALT_USB0_HOSTGRP instance. */
3846
#define ALT_USB0_HOST_HCINT12_ADDR ALT_USB_HOST_HCINT12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3847
/* The address of the ALT_USB_HOST_HCINTMSK12 register for the ALT_USB0_HOSTGRP instance. */
3848
#define ALT_USB0_HOST_HCINTMSK12_ADDR ALT_USB_HOST_HCINTMSK12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3849
/* The address of the ALT_USB_HOST_HCTSIZ12 register for the ALT_USB0_HOSTGRP instance. */
3850
#define ALT_USB0_HOST_HCTSIZ12_ADDR ALT_USB_HOST_HCTSIZ12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3851
/* The address of the ALT_USB_HOST_HCDMA12 register for the ALT_USB0_HOSTGRP instance. */
3852
#define ALT_USB0_HOST_HCDMA12_ADDR ALT_USB_HOST_HCDMA12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3853
/* The address of the ALT_USB_HOST_HCDMAB12 register for the ALT_USB0_HOSTGRP instance. */
3854
#define ALT_USB0_HOST_HCDMAB12_ADDR ALT_USB_HOST_HCDMAB12_ADDR(ALT_USB0_HOSTGRP_ADDR)
3855
/* The address of the ALT_USB_HOST_HCCHAR13 register for the ALT_USB0_HOSTGRP instance. */
3856
#define ALT_USB0_HOST_HCCHAR13_ADDR ALT_USB_HOST_HCCHAR13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3857
/* The address of the ALT_USB_HOST_HCSPLT13 register for the ALT_USB0_HOSTGRP instance. */
3858
#define ALT_USB0_HOST_HCSPLT13_ADDR ALT_USB_HOST_HCSPLT13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3859
/* The address of the ALT_USB_HOST_HCINT13 register for the ALT_USB0_HOSTGRP instance. */
3860
#define ALT_USB0_HOST_HCINT13_ADDR ALT_USB_HOST_HCINT13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3861
/* The address of the ALT_USB_HOST_HCINTMSK13 register for the ALT_USB0_HOSTGRP instance. */
3862
#define ALT_USB0_HOST_HCINTMSK13_ADDR ALT_USB_HOST_HCINTMSK13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3863
/* The address of the ALT_USB_HOST_HCTSIZ13 register for the ALT_USB0_HOSTGRP instance. */
3864
#define ALT_USB0_HOST_HCTSIZ13_ADDR ALT_USB_HOST_HCTSIZ13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3865
/* The address of the ALT_USB_HOST_HCDMA13 register for the ALT_USB0_HOSTGRP instance. */
3866
#define ALT_USB0_HOST_HCDMA13_ADDR ALT_USB_HOST_HCDMA13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3867
/* The address of the ALT_USB_HOST_HCDMAB13 register for the ALT_USB0_HOSTGRP instance. */
3868
#define ALT_USB0_HOST_HCDMAB13_ADDR ALT_USB_HOST_HCDMAB13_ADDR(ALT_USB0_HOSTGRP_ADDR)
3869
/* The address of the ALT_USB_HOST_HCCHAR14 register for the ALT_USB0_HOSTGRP instance. */
3870
#define ALT_USB0_HOST_HCCHAR14_ADDR ALT_USB_HOST_HCCHAR14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3871
/* The address of the ALT_USB_HOST_HCSPLT14 register for the ALT_USB0_HOSTGRP instance. */
3872
#define ALT_USB0_HOST_HCSPLT14_ADDR ALT_USB_HOST_HCSPLT14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3873
/* The address of the ALT_USB_HOST_HCINT14 register for the ALT_USB0_HOSTGRP instance. */
3874
#define ALT_USB0_HOST_HCINT14_ADDR ALT_USB_HOST_HCINT14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3875
/* The address of the ALT_USB_HOST_HCINTMSK14 register for the ALT_USB0_HOSTGRP instance. */
3876
#define ALT_USB0_HOST_HCINTMSK14_ADDR ALT_USB_HOST_HCINTMSK14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3877
/* The address of the ALT_USB_HOST_HCTSIZ14 register for the ALT_USB0_HOSTGRP instance. */
3878
#define ALT_USB0_HOST_HCTSIZ14_ADDR ALT_USB_HOST_HCTSIZ14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3879
/* The address of the ALT_USB_HOST_HCDMA14 register for the ALT_USB0_HOSTGRP instance. */
3880
#define ALT_USB0_HOST_HCDMA14_ADDR ALT_USB_HOST_HCDMA14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3881
/* The address of the ALT_USB_HOST_HCDMAB14 register for the ALT_USB0_HOSTGRP instance. */
3882
#define ALT_USB0_HOST_HCDMAB14_ADDR ALT_USB_HOST_HCDMAB14_ADDR(ALT_USB0_HOSTGRP_ADDR)
3883
/* The address of the ALT_USB_HOST_HCCHAR15 register for the ALT_USB0_HOSTGRP instance. */
3884
#define ALT_USB0_HOST_HCCHAR15_ADDR ALT_USB_HOST_HCCHAR15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3885
/* The address of the ALT_USB_HOST_HCSPLT15 register for the ALT_USB0_HOSTGRP instance. */
3886
#define ALT_USB0_HOST_HCSPLT15_ADDR ALT_USB_HOST_HCSPLT15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3887
/* The address of the ALT_USB_HOST_HCINT15 register for the ALT_USB0_HOSTGRP instance. */
3888
#define ALT_USB0_HOST_HCINT15_ADDR ALT_USB_HOST_HCINT15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3889
/* The address of the ALT_USB_HOST_HCINTMSK15 register for the ALT_USB0_HOSTGRP instance. */
3890
#define ALT_USB0_HOST_HCINTMSK15_ADDR ALT_USB_HOST_HCINTMSK15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3891
/* The address of the ALT_USB_HOST_HCTSIZ15 register for the ALT_USB0_HOSTGRP instance. */
3892
#define ALT_USB0_HOST_HCTSIZ15_ADDR ALT_USB_HOST_HCTSIZ15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3893
/* The address of the ALT_USB_HOST_HCDMA15 register for the ALT_USB0_HOSTGRP instance. */
3894
#define ALT_USB0_HOST_HCDMA15_ADDR ALT_USB_HOST_HCDMA15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3895
/* The address of the ALT_USB_HOST_HCDMAB15 register for the ALT_USB0_HOSTGRP instance. */
3896
#define ALT_USB0_HOST_HCDMAB15_ADDR ALT_USB_HOST_HCDMAB15_ADDR(ALT_USB0_HOSTGRP_ADDR)
3897
/* The base address byte offset for the start of the ALT_USB0_HOSTGRP component. */
3898
#define ALT_USB0_HOSTGRP_OFST 0x400
3899
/* The start address of the ALT_USB0_HOSTGRP component. */
3900
#define ALT_USB0_HOSTGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB0_ADDR) + ALT_USB0_HOSTGRP_OFST))
3901
/* The lower bound address range of the ALT_USB0_HOSTGRP component. */
3902
#define ALT_USB0_HOSTGRP_LB_ADDR ALT_USB0_HOSTGRP_ADDR
3903
/* The upper bound address range of the ALT_USB0_HOSTGRP component. */
3904
#define ALT_USB0_HOSTGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB0_HOSTGRP_ADDR) + 0x2fc) - 1))
3905
3906
3907
3908
* Register Group Instance : devgrp
3909
3910
* Instance devgrp of register group ALT_USB_DEV.
3911
3912
3913
3914
/* The address of the ALT_USB_DEV_DCFG register for the ALT_USB0_DEVGRP instance. */
3915
#define ALT_USB0_DEV_DCFG_ADDR ALT_USB_DEV_DCFG_ADDR(ALT_USB0_DEVGRP_ADDR)
3916
/* The address of the ALT_USB_DEV_DCTL register for the ALT_USB0_DEVGRP instance. */
3917
#define ALT_USB0_DEV_DCTL_ADDR ALT_USB_DEV_DCTL_ADDR(ALT_USB0_DEVGRP_ADDR)
3918
/* The address of the ALT_USB_DEV_DSTS register for the ALT_USB0_DEVGRP instance. */
3919
#define ALT_USB0_DEV_DSTS_ADDR ALT_USB_DEV_DSTS_ADDR(ALT_USB0_DEVGRP_ADDR)
3920
/* The address of the ALT_USB_DEV_DIEPMSK register for the ALT_USB0_DEVGRP instance. */
3921
#define ALT_USB0_DEV_DIEPMSK_ADDR ALT_USB_DEV_DIEPMSK_ADDR(ALT_USB0_DEVGRP_ADDR)
3922
/* The address of the ALT_USB_DEV_DOEPMSK register for the ALT_USB0_DEVGRP instance. */
3923
#define ALT_USB0_DEV_DOEPMSK_ADDR ALT_USB_DEV_DOEPMSK_ADDR(ALT_USB0_DEVGRP_ADDR)
3924
/* The address of the ALT_USB_DEV_DAINT register for the ALT_USB0_DEVGRP instance. */
3925
#define ALT_USB0_DEV_DAINT_ADDR ALT_USB_DEV_DAINT_ADDR(ALT_USB0_DEVGRP_ADDR)
3926
/* The address of the ALT_USB_DEV_DAINTMSK register for the ALT_USB0_DEVGRP instance. */
3927
#define ALT_USB0_DEV_DAINTMSK_ADDR ALT_USB_DEV_DAINTMSK_ADDR(ALT_USB0_DEVGRP_ADDR)
3928
/* The address of the ALT_USB_DEV_DVBUSDIS register for the ALT_USB0_DEVGRP instance. */
3929
#define ALT_USB0_DEV_DVBUSDIS_ADDR ALT_USB_DEV_DVBUSDIS_ADDR(ALT_USB0_DEVGRP_ADDR)
3930
/* The address of the ALT_USB_DEV_DVBUSPULSE register for the ALT_USB0_DEVGRP instance. */
3931
#define ALT_USB0_DEV_DVBUSPULSE_ADDR ALT_USB_DEV_DVBUSPULSE_ADDR(ALT_USB0_DEVGRP_ADDR)
3932
/* The address of the ALT_USB_DEV_DTHRCTL register for the ALT_USB0_DEVGRP instance. */
3933
#define ALT_USB0_DEV_DTHRCTL_ADDR ALT_USB_DEV_DTHRCTL_ADDR(ALT_USB0_DEVGRP_ADDR)
3934
/* The address of the ALT_USB_DEV_DIEPEMPMSK register for the ALT_USB0_DEVGRP instance. */
3935
#define ALT_USB0_DEV_DIEPEMPMSK_ADDR ALT_USB_DEV_DIEPEMPMSK_ADDR(ALT_USB0_DEVGRP_ADDR)
3936
/* The address of the ALT_USB_DEV_DIEPCTL0 register for the ALT_USB0_DEVGRP instance. */
3937
#define ALT_USB0_DEV_DIEPCTL0_ADDR ALT_USB_DEV_DIEPCTL0_ADDR(ALT_USB0_DEVGRP_ADDR)
3938
/* The address of the ALT_USB_DEV_DIEPINT0 register for the ALT_USB0_DEVGRP instance. */
3939
#define ALT_USB0_DEV_DIEPINT0_ADDR ALT_USB_DEV_DIEPINT0_ADDR(ALT_USB0_DEVGRP_ADDR)
3940
/* The address of the ALT_USB_DEV_DIEPTSIZ0 register for the ALT_USB0_DEVGRP instance. */
3941
#define ALT_USB0_DEV_DIEPTSIZ0_ADDR ALT_USB_DEV_DIEPTSIZ0_ADDR(ALT_USB0_DEVGRP_ADDR)
3942
/* The address of the ALT_USB_DEV_DIEPDMA0 register for the ALT_USB0_DEVGRP instance. */
3943
#define ALT_USB0_DEV_DIEPDMA0_ADDR ALT_USB_DEV_DIEPDMA0_ADDR(ALT_USB0_DEVGRP_ADDR)
3944
/* The address of the ALT_USB_DEV_DTXFSTS0 register for the ALT_USB0_DEVGRP instance. */
3945
#define ALT_USB0_DEV_DTXFSTS0_ADDR ALT_USB_DEV_DTXFSTS0_ADDR(ALT_USB0_DEVGRP_ADDR)
3946
/* The address of the ALT_USB_DEV_DIEPDMAB0 register for the ALT_USB0_DEVGRP instance. */
3947
#define ALT_USB0_DEV_DIEPDMAB0_ADDR ALT_USB_DEV_DIEPDMAB0_ADDR(ALT_USB0_DEVGRP_ADDR)
3948
/* The address of the ALT_USB_DEV_DIEPCTL1 register for the ALT_USB0_DEVGRP instance. */
3949
#define ALT_USB0_DEV_DIEPCTL1_ADDR ALT_USB_DEV_DIEPCTL1_ADDR(ALT_USB0_DEVGRP_ADDR)
3950
/* The address of the ALT_USB_DEV_DIEPINT1 register for the ALT_USB0_DEVGRP instance. */
3951
#define ALT_USB0_DEV_DIEPINT1_ADDR ALT_USB_DEV_DIEPINT1_ADDR(ALT_USB0_DEVGRP_ADDR)
3952
/* The address of the ALT_USB_DEV_DIEPTSIZ1 register for the ALT_USB0_DEVGRP instance. */
3953
#define ALT_USB0_DEV_DIEPTSIZ1_ADDR ALT_USB_DEV_DIEPTSIZ1_ADDR(ALT_USB0_DEVGRP_ADDR)
3954
/* The address of the ALT_USB_DEV_DIEPDMA1 register for the ALT_USB0_DEVGRP instance. */
3955
#define ALT_USB0_DEV_DIEPDMA1_ADDR ALT_USB_DEV_DIEPDMA1_ADDR(ALT_USB0_DEVGRP_ADDR)
3956
/* The address of the ALT_USB_DEV_DTXFSTS1 register for the ALT_USB0_DEVGRP instance. */
3957
#define ALT_USB0_DEV_DTXFSTS1_ADDR ALT_USB_DEV_DTXFSTS1_ADDR(ALT_USB0_DEVGRP_ADDR)
3958
/* The address of the ALT_USB_DEV_DIEPDMAB1 register for the ALT_USB0_DEVGRP instance. */
3959
#define ALT_USB0_DEV_DIEPDMAB1_ADDR ALT_USB_DEV_DIEPDMAB1_ADDR(ALT_USB0_DEVGRP_ADDR)
3960
/* The address of the ALT_USB_DEV_DIEPCTL2 register for the ALT_USB0_DEVGRP instance. */
3961
#define ALT_USB0_DEV_DIEPCTL2_ADDR ALT_USB_DEV_DIEPCTL2_ADDR(ALT_USB0_DEVGRP_ADDR)
3962
/* The address of the ALT_USB_DEV_DIEPINT2 register for the ALT_USB0_DEVGRP instance. */
3963
#define ALT_USB0_DEV_DIEPINT2_ADDR ALT_USB_DEV_DIEPINT2_ADDR(ALT_USB0_DEVGRP_ADDR)
3964
/* The address of the ALT_USB_DEV_DIEPTSIZ2 register for the ALT_USB0_DEVGRP instance. */
3965
#define ALT_USB0_DEV_DIEPTSIZ2_ADDR ALT_USB_DEV_DIEPTSIZ2_ADDR(ALT_USB0_DEVGRP_ADDR)
3966
/* The address of the ALT_USB_DEV_DIEPDMA2 register for the ALT_USB0_DEVGRP instance. */
3967
#define ALT_USB0_DEV_DIEPDMA2_ADDR ALT_USB_DEV_DIEPDMA2_ADDR(ALT_USB0_DEVGRP_ADDR)
3968
/* The address of the ALT_USB_DEV_DTXFSTS2 register for the ALT_USB0_DEVGRP instance. */
3969
#define ALT_USB0_DEV_DTXFSTS2_ADDR ALT_USB_DEV_DTXFSTS2_ADDR(ALT_USB0_DEVGRP_ADDR)
3970
/* The address of the ALT_USB_DEV_DIEPDMAB2 register for the ALT_USB0_DEVGRP instance. */
3971
#define ALT_USB0_DEV_DIEPDMAB2_ADDR ALT_USB_DEV_DIEPDMAB2_ADDR(ALT_USB0_DEVGRP_ADDR)
3972
/* The address of the ALT_USB_DEV_DIEPCTL3 register for the ALT_USB0_DEVGRP instance. */
3973
#define ALT_USB0_DEV_DIEPCTL3_ADDR ALT_USB_DEV_DIEPCTL3_ADDR(ALT_USB0_DEVGRP_ADDR)
3974
/* The address of the ALT_USB_DEV_DIEPINT3 register for the ALT_USB0_DEVGRP instance. */
3975
#define ALT_USB0_DEV_DIEPINT3_ADDR ALT_USB_DEV_DIEPINT3_ADDR(ALT_USB0_DEVGRP_ADDR)
3976
/* The address of the ALT_USB_DEV_DIEPTSIZ3 register for the ALT_USB0_DEVGRP instance. */
3977
#define ALT_USB0_DEV_DIEPTSIZ3_ADDR ALT_USB_DEV_DIEPTSIZ3_ADDR(ALT_USB0_DEVGRP_ADDR)
3978
/* The address of the ALT_USB_DEV_DIEPDMA3 register for the ALT_USB0_DEVGRP instance. */
3979
#define ALT_USB0_DEV_DIEPDMA3_ADDR ALT_USB_DEV_DIEPDMA3_ADDR(ALT_USB0_DEVGRP_ADDR)
3980
/* The address of the ALT_USB_DEV_DTXFSTS3 register for the ALT_USB0_DEVGRP instance. */
3981
#define ALT_USB0_DEV_DTXFSTS3_ADDR ALT_USB_DEV_DTXFSTS3_ADDR(ALT_USB0_DEVGRP_ADDR)
3982
/* The address of the ALT_USB_DEV_DIEPDMAB3 register for the ALT_USB0_DEVGRP instance. */
3983
#define ALT_USB0_DEV_DIEPDMAB3_ADDR ALT_USB_DEV_DIEPDMAB3_ADDR(ALT_USB0_DEVGRP_ADDR)
3984
/* The address of the ALT_USB_DEV_DIEPCTL4 register for the ALT_USB0_DEVGRP instance. */
3985
#define ALT_USB0_DEV_DIEPCTL4_ADDR ALT_USB_DEV_DIEPCTL4_ADDR(ALT_USB0_DEVGRP_ADDR)
3986
/* The address of the ALT_USB_DEV_DIEPINT4 register for the ALT_USB0_DEVGRP instance. */
3987
#define ALT_USB0_DEV_DIEPINT4_ADDR ALT_USB_DEV_DIEPINT4_ADDR(ALT_USB0_DEVGRP_ADDR)
3988
/* The address of the ALT_USB_DEV_DIEPTSIZ4 register for the ALT_USB0_DEVGRP instance. */
3989
#define ALT_USB0_DEV_DIEPTSIZ4_ADDR ALT_USB_DEV_DIEPTSIZ4_ADDR(ALT_USB0_DEVGRP_ADDR)
3990
/* The address of the ALT_USB_DEV_DIEPDMA4 register for the ALT_USB0_DEVGRP instance. */
3991
#define ALT_USB0_DEV_DIEPDMA4_ADDR ALT_USB_DEV_DIEPDMA4_ADDR(ALT_USB0_DEVGRP_ADDR)
3992
/* The address of the ALT_USB_DEV_DTXFSTS4 register for the ALT_USB0_DEVGRP instance. */
3993
#define ALT_USB0_DEV_DTXFSTS4_ADDR ALT_USB_DEV_DTXFSTS4_ADDR(ALT_USB0_DEVGRP_ADDR)
3994
/* The address of the ALT_USB_DEV_DIEPDMAB4 register for the ALT_USB0_DEVGRP instance. */
3995
#define ALT_USB0_DEV_DIEPDMAB4_ADDR ALT_USB_DEV_DIEPDMAB4_ADDR(ALT_USB0_DEVGRP_ADDR)
3996
/* The address of the ALT_USB_DEV_DIEPCTL5 register for the ALT_USB0_DEVGRP instance. */
3997
#define ALT_USB0_DEV_DIEPCTL5_ADDR ALT_USB_DEV_DIEPCTL5_ADDR(ALT_USB0_DEVGRP_ADDR)
3998
/* The address of the ALT_USB_DEV_DIEPINT5 register for the ALT_USB0_DEVGRP instance. */
3999
#define ALT_USB0_DEV_DIEPINT5_ADDR ALT_USB_DEV_DIEPINT5_ADDR(ALT_USB0_DEVGRP_ADDR)
4000
/* The address of the ALT_USB_DEV_DIEPTSIZ5 register for the ALT_USB0_DEVGRP instance. */
4001
#define ALT_USB0_DEV_DIEPTSIZ5_ADDR ALT_USB_DEV_DIEPTSIZ5_ADDR(ALT_USB0_DEVGRP_ADDR)
4002
/* The address of the ALT_USB_DEV_DIEPDMA5 register for the ALT_USB0_DEVGRP instance. */
4003
#define ALT_USB0_DEV_DIEPDMA5_ADDR ALT_USB_DEV_DIEPDMA5_ADDR(ALT_USB0_DEVGRP_ADDR)
4004
/* The address of the ALT_USB_DEV_DTXFSTS5 register for the ALT_USB0_DEVGRP instance. */
4005
#define ALT_USB0_DEV_DTXFSTS5_ADDR ALT_USB_DEV_DTXFSTS5_ADDR(ALT_USB0_DEVGRP_ADDR)
4006
/* The address of the ALT_USB_DEV_DIEPDMAB5 register for the ALT_USB0_DEVGRP instance. */
4007
#define ALT_USB0_DEV_DIEPDMAB5_ADDR ALT_USB_DEV_DIEPDMAB5_ADDR(ALT_USB0_DEVGRP_ADDR)
4008
/* The address of the ALT_USB_DEV_DIEPCTL6 register for the ALT_USB0_DEVGRP instance. */
4009
#define ALT_USB0_DEV_DIEPCTL6_ADDR ALT_USB_DEV_DIEPCTL6_ADDR(ALT_USB0_DEVGRP_ADDR)
4010
/* The address of the ALT_USB_DEV_DIEPINT6 register for the ALT_USB0_DEVGRP instance. */
4011
#define ALT_USB0_DEV_DIEPINT6_ADDR ALT_USB_DEV_DIEPINT6_ADDR(ALT_USB0_DEVGRP_ADDR)
4012
/* The address of the ALT_USB_DEV_DIEPTSIZ6 register for the ALT_USB0_DEVGRP instance. */
4013
#define ALT_USB0_DEV_DIEPTSIZ6_ADDR ALT_USB_DEV_DIEPTSIZ6_ADDR(ALT_USB0_DEVGRP_ADDR)
4014
/* The address of the ALT_USB_DEV_DIEPDMA6 register for the ALT_USB0_DEVGRP instance. */
4015
#define ALT_USB0_DEV_DIEPDMA6_ADDR ALT_USB_DEV_DIEPDMA6_ADDR(ALT_USB0_DEVGRP_ADDR)
4016
/* The address of the ALT_USB_DEV_DTXFSTS6 register for the ALT_USB0_DEVGRP instance. */
4017
#define ALT_USB0_DEV_DTXFSTS6_ADDR ALT_USB_DEV_DTXFSTS6_ADDR(ALT_USB0_DEVGRP_ADDR)
4018
/* The address of the ALT_USB_DEV_DIEPDMAB6 register for the ALT_USB0_DEVGRP instance. */
4019
#define ALT_USB0_DEV_DIEPDMAB6_ADDR ALT_USB_DEV_DIEPDMAB6_ADDR(ALT_USB0_DEVGRP_ADDR)
4020
/* The address of the ALT_USB_DEV_DIEPCTL7 register for the ALT_USB0_DEVGRP instance. */
4021
#define ALT_USB0_DEV_DIEPCTL7_ADDR ALT_USB_DEV_DIEPCTL7_ADDR(ALT_USB0_DEVGRP_ADDR)
4022
/* The address of the ALT_USB_DEV_DIEPINT7 register for the ALT_USB0_DEVGRP instance. */
4023
#define ALT_USB0_DEV_DIEPINT7_ADDR ALT_USB_DEV_DIEPINT7_ADDR(ALT_USB0_DEVGRP_ADDR)
4024
/* The address of the ALT_USB_DEV_DIEPTSIZ7 register for the ALT_USB0_DEVGRP instance. */
4025
#define ALT_USB0_DEV_DIEPTSIZ7_ADDR ALT_USB_DEV_DIEPTSIZ7_ADDR(ALT_USB0_DEVGRP_ADDR)
4026
/* The address of the ALT_USB_DEV_DIEPDMA7 register for the ALT_USB0_DEVGRP instance. */
4027
#define ALT_USB0_DEV_DIEPDMA7_ADDR ALT_USB_DEV_DIEPDMA7_ADDR(ALT_USB0_DEVGRP_ADDR)
4028
/* The address of the ALT_USB_DEV_DTXFSTS7 register for the ALT_USB0_DEVGRP instance. */
4029
#define ALT_USB0_DEV_DTXFSTS7_ADDR ALT_USB_DEV_DTXFSTS7_ADDR(ALT_USB0_DEVGRP_ADDR)
4030
/* The address of the ALT_USB_DEV_DIEPDMAB7 register for the ALT_USB0_DEVGRP instance. */
4031
#define ALT_USB0_DEV_DIEPDMAB7_ADDR ALT_USB_DEV_DIEPDMAB7_ADDR(ALT_USB0_DEVGRP_ADDR)
4032
/* The address of the ALT_USB_DEV_DIEPCTL8 register for the ALT_USB0_DEVGRP instance. */
4033
#define ALT_USB0_DEV_DIEPCTL8_ADDR ALT_USB_DEV_DIEPCTL8_ADDR(ALT_USB0_DEVGRP_ADDR)
4034
/* The address of the ALT_USB_DEV_DIEPINT8 register for the ALT_USB0_DEVGRP instance. */
4035
#define ALT_USB0_DEV_DIEPINT8_ADDR ALT_USB_DEV_DIEPINT8_ADDR(ALT_USB0_DEVGRP_ADDR)
4036
/* The address of the ALT_USB_DEV_DIEPTSIZ8 register for the ALT_USB0_DEVGRP instance. */
4037
#define ALT_USB0_DEV_DIEPTSIZ8_ADDR ALT_USB_DEV_DIEPTSIZ8_ADDR(ALT_USB0_DEVGRP_ADDR)
4038
/* The address of the ALT_USB_DEV_DIEPDMA8 register for the ALT_USB0_DEVGRP instance. */
4039
#define ALT_USB0_DEV_DIEPDMA8_ADDR ALT_USB_DEV_DIEPDMA8_ADDR(ALT_USB0_DEVGRP_ADDR)
4040
/* The address of the ALT_USB_DEV_DTXFSTS8 register for the ALT_USB0_DEVGRP instance. */
4041
#define ALT_USB0_DEV_DTXFSTS8_ADDR ALT_USB_DEV_DTXFSTS8_ADDR(ALT_USB0_DEVGRP_ADDR)
4042
/* The address of the ALT_USB_DEV_DIEPDMAB8 register for the ALT_USB0_DEVGRP instance. */
4043
#define ALT_USB0_DEV_DIEPDMAB8_ADDR ALT_USB_DEV_DIEPDMAB8_ADDR(ALT_USB0_DEVGRP_ADDR)
4044
/* The address of the ALT_USB_DEV_DIEPCTL9 register for the ALT_USB0_DEVGRP instance. */
4045
#define ALT_USB0_DEV_DIEPCTL9_ADDR ALT_USB_DEV_DIEPCTL9_ADDR(ALT_USB0_DEVGRP_ADDR)
4046
/* The address of the ALT_USB_DEV_DIEPINT9 register for the ALT_USB0_DEVGRP instance. */
4047
#define ALT_USB0_DEV_DIEPINT9_ADDR ALT_USB_DEV_DIEPINT9_ADDR(ALT_USB0_DEVGRP_ADDR)
4048
/* The address of the ALT_USB_DEV_DIEPTSIZ9 register for the ALT_USB0_DEVGRP instance. */
4049
#define ALT_USB0_DEV_DIEPTSIZ9_ADDR ALT_USB_DEV_DIEPTSIZ9_ADDR(ALT_USB0_DEVGRP_ADDR)
4050
/* The address of the ALT_USB_DEV_DIEPDMA9 register for the ALT_USB0_DEVGRP instance. */
4051
#define ALT_USB0_DEV_DIEPDMA9_ADDR ALT_USB_DEV_DIEPDMA9_ADDR(ALT_USB0_DEVGRP_ADDR)
4052
/* The address of the ALT_USB_DEV_DTXFSTS9 register for the ALT_USB0_DEVGRP instance. */
4053
#define ALT_USB0_DEV_DTXFSTS9_ADDR ALT_USB_DEV_DTXFSTS9_ADDR(ALT_USB0_DEVGRP_ADDR)
4054
/* The address of the ALT_USB_DEV_DIEPDMAB9 register for the ALT_USB0_DEVGRP instance. */
4055
#define ALT_USB0_DEV_DIEPDMAB9_ADDR ALT_USB_DEV_DIEPDMAB9_ADDR(ALT_USB0_DEVGRP_ADDR)
4056
/* The address of the ALT_USB_DEV_DIEPCTL10 register for the ALT_USB0_DEVGRP instance. */
4057
#define ALT_USB0_DEV_DIEPCTL10_ADDR ALT_USB_DEV_DIEPCTL10_ADDR(ALT_USB0_DEVGRP_ADDR)
4058
/* The address of the ALT_USB_DEV_DIEPINT10 register for the ALT_USB0_DEVGRP instance. */
4059
#define ALT_USB0_DEV_DIEPINT10_ADDR ALT_USB_DEV_DIEPINT10_ADDR(ALT_USB0_DEVGRP_ADDR)
4060
/* The address of the ALT_USB_DEV_DIEPTSIZ10 register for the ALT_USB0_DEVGRP instance. */
4061
#define ALT_USB0_DEV_DIEPTSIZ10_ADDR ALT_USB_DEV_DIEPTSIZ10_ADDR(ALT_USB0_DEVGRP_ADDR)
4062
/* The address of the ALT_USB_DEV_DIEPDMA10 register for the ALT_USB0_DEVGRP instance. */
4063
#define ALT_USB0_DEV_DIEPDMA10_ADDR ALT_USB_DEV_DIEPDMA10_ADDR(ALT_USB0_DEVGRP_ADDR)
4064
/* The address of the ALT_USB_DEV_DTXFSTS10 register for the ALT_USB0_DEVGRP instance. */
4065
#define ALT_USB0_DEV_DTXFSTS10_ADDR ALT_USB_DEV_DTXFSTS10_ADDR(ALT_USB0_DEVGRP_ADDR)
4066
/* The address of the ALT_USB_DEV_DIEPDMAB10 register for the ALT_USB0_DEVGRP instance. */
4067
#define ALT_USB0_DEV_DIEPDMAB10_ADDR ALT_USB_DEV_DIEPDMAB10_ADDR(ALT_USB0_DEVGRP_ADDR)
4068
/* The address of the ALT_USB_DEV_DIEPCTL11 register for the ALT_USB0_DEVGRP instance. */
4069
#define ALT_USB0_DEV_DIEPCTL11_ADDR ALT_USB_DEV_DIEPCTL11_ADDR(ALT_USB0_DEVGRP_ADDR)
4070
/* The address of the ALT_USB_DEV_DIEPINT11 register for the ALT_USB0_DEVGRP instance. */
4071
#define ALT_USB0_DEV_DIEPINT11_ADDR ALT_USB_DEV_DIEPINT11_ADDR(ALT_USB0_DEVGRP_ADDR)
4072
/* The address of the ALT_USB_DEV_DIEPTSIZ11 register for the ALT_USB0_DEVGRP instance. */
4073
#define ALT_USB0_DEV_DIEPTSIZ11_ADDR ALT_USB_DEV_DIEPTSIZ11_ADDR(ALT_USB0_DEVGRP_ADDR)
4074
/* The address of the ALT_USB_DEV_DIEPDMA11 register for the ALT_USB0_DEVGRP instance. */
4075
#define ALT_USB0_DEV_DIEPDMA11_ADDR ALT_USB_DEV_DIEPDMA11_ADDR(ALT_USB0_DEVGRP_ADDR)
4076
/* The address of the ALT_USB_DEV_DTXFSTS11 register for the ALT_USB0_DEVGRP instance. */
4077
#define ALT_USB0_DEV_DTXFSTS11_ADDR ALT_USB_DEV_DTXFSTS11_ADDR(ALT_USB0_DEVGRP_ADDR)
4078
/* The address of the ALT_USB_DEV_DIEPDMAB11 register for the ALT_USB0_DEVGRP instance. */
4079
#define ALT_USB0_DEV_DIEPDMAB11_ADDR ALT_USB_DEV_DIEPDMAB11_ADDR(ALT_USB0_DEVGRP_ADDR)
4080
/* The address of the ALT_USB_DEV_DIEPCTL12 register for the ALT_USB0_DEVGRP instance. */
4081
#define ALT_USB0_DEV_DIEPCTL12_ADDR ALT_USB_DEV_DIEPCTL12_ADDR(ALT_USB0_DEVGRP_ADDR)
4082
/* The address of the ALT_USB_DEV_DIEPINT12 register for the ALT_USB0_DEVGRP instance. */
4083
#define ALT_USB0_DEV_DIEPINT12_ADDR ALT_USB_DEV_DIEPINT12_ADDR(ALT_USB0_DEVGRP_ADDR)
4084
/* The address of the ALT_USB_DEV_DIEPTSIZ12 register for the ALT_USB0_DEVGRP instance. */
4085
#define ALT_USB0_DEV_DIEPTSIZ12_ADDR ALT_USB_DEV_DIEPTSIZ12_ADDR(ALT_USB0_DEVGRP_ADDR)
4086
/* The address of the ALT_USB_DEV_DIEPDMA12 register for the ALT_USB0_DEVGRP instance. */
4087
#define ALT_USB0_DEV_DIEPDMA12_ADDR ALT_USB_DEV_DIEPDMA12_ADDR(ALT_USB0_DEVGRP_ADDR)
4088
/* The address of the ALT_USB_DEV_DTXFSTS12 register for the ALT_USB0_DEVGRP instance. */
4089
#define ALT_USB0_DEV_DTXFSTS12_ADDR ALT_USB_DEV_DTXFSTS12_ADDR(ALT_USB0_DEVGRP_ADDR)
4090
/* The address of the ALT_USB_DEV_DIEPDMAB12 register for the ALT_USB0_DEVGRP instance. */
4091
#define ALT_USB0_DEV_DIEPDMAB12_ADDR ALT_USB_DEV_DIEPDMAB12_ADDR(ALT_USB0_DEVGRP_ADDR)
4092
/* The address of the ALT_USB_DEV_DIEPCTL13 register for the ALT_USB0_DEVGRP instance. */
4093
#define ALT_USB0_DEV_DIEPCTL13_ADDR ALT_USB_DEV_DIEPCTL13_ADDR(ALT_USB0_DEVGRP_ADDR)
4094
/* The address of the ALT_USB_DEV_DIEPINT13 register for the ALT_USB0_DEVGRP instance. */
4095
#define ALT_USB0_DEV_DIEPINT13_ADDR ALT_USB_DEV_DIEPINT13_ADDR(ALT_USB0_DEVGRP_ADDR)
4096
/* The address of the ALT_USB_DEV_DIEPTSIZ13 register for the ALT_USB0_DEVGRP instance. */
4097
#define ALT_USB0_DEV_DIEPTSIZ13_ADDR ALT_USB_DEV_DIEPTSIZ13_ADDR(ALT_USB0_DEVGRP_ADDR)
4098
/* The address of the ALT_USB_DEV_DIEPDMA13 register for the ALT_USB0_DEVGRP instance. */
4099
#define ALT_USB0_DEV_DIEPDMA13_ADDR ALT_USB_DEV_DIEPDMA13_ADDR(ALT_USB0_DEVGRP_ADDR)
4100
/* The address of the ALT_USB_DEV_DTXFSTS13 register for the ALT_USB0_DEVGRP instance. */
4101
#define ALT_USB0_DEV_DTXFSTS13_ADDR ALT_USB_DEV_DTXFSTS13_ADDR(ALT_USB0_DEVGRP_ADDR)
4102
/* The address of the ALT_USB_DEV_DIEPDMAB13 register for the ALT_USB0_DEVGRP instance. */
4103
#define ALT_USB0_DEV_DIEPDMAB13_ADDR ALT_USB_DEV_DIEPDMAB13_ADDR(ALT_USB0_DEVGRP_ADDR)
4104
/* The address of the ALT_USB_DEV_DIEPCTL14 register for the ALT_USB0_DEVGRP instance. */
4105
#define ALT_USB0_DEV_DIEPCTL14_ADDR ALT_USB_DEV_DIEPCTL14_ADDR(ALT_USB0_DEVGRP_ADDR)
4106
/* The address of the ALT_USB_DEV_DIEPINT14 register for the ALT_USB0_DEVGRP instance. */
4107
#define ALT_USB0_DEV_DIEPINT14_ADDR ALT_USB_DEV_DIEPINT14_ADDR(ALT_USB0_DEVGRP_ADDR)
4108
/* The address of the ALT_USB_DEV_DIEPTSIZ14 register for the ALT_USB0_DEVGRP instance. */
4109
#define ALT_USB0_DEV_DIEPTSIZ14_ADDR ALT_USB_DEV_DIEPTSIZ14_ADDR(ALT_USB0_DEVGRP_ADDR)
4110
/* The address of the ALT_USB_DEV_DIEPDMA14 register for the ALT_USB0_DEVGRP instance. */
4111
#define ALT_USB0_DEV_DIEPDMA14_ADDR ALT_USB_DEV_DIEPDMA14_ADDR(ALT_USB0_DEVGRP_ADDR)
4112
/* The address of the ALT_USB_DEV_DTXFSTS14 register for the ALT_USB0_DEVGRP instance. */
4113
#define ALT_USB0_DEV_DTXFSTS14_ADDR ALT_USB_DEV_DTXFSTS14_ADDR(ALT_USB0_DEVGRP_ADDR)
4114
/* The address of the ALT_USB_DEV_DIEPDMAB14 register for the ALT_USB0_DEVGRP instance. */
4115
#define ALT_USB0_DEV_DIEPDMAB14_ADDR ALT_USB_DEV_DIEPDMAB14_ADDR(ALT_USB0_DEVGRP_ADDR)
4116
/* The address of the ALT_USB_DEV_DIEPCTL15 register for the ALT_USB0_DEVGRP instance. */
4117
#define ALT_USB0_DEV_DIEPCTL15_ADDR ALT_USB_DEV_DIEPCTL15_ADDR(ALT_USB0_DEVGRP_ADDR)
4118
/* The address of the ALT_USB_DEV_DIEPINT15 register for the ALT_USB0_DEVGRP instance. */
4119
#define ALT_USB0_DEV_DIEPINT15_ADDR ALT_USB_DEV_DIEPINT15_ADDR(ALT_USB0_DEVGRP_ADDR)
4120
/* The address of the ALT_USB_DEV_DIEPTSIZ15 register for the ALT_USB0_DEVGRP instance. */
4121
#define ALT_USB0_DEV_DIEPTSIZ15_ADDR ALT_USB_DEV_DIEPTSIZ15_ADDR(ALT_USB0_DEVGRP_ADDR)
4122
/* The address of the ALT_USB_DEV_DIEPDMA15 register for the ALT_USB0_DEVGRP instance. */
4123
#define ALT_USB0_DEV_DIEPDMA15_ADDR ALT_USB_DEV_DIEPDMA15_ADDR(ALT_USB0_DEVGRP_ADDR)
4124
/* The address of the ALT_USB_DEV_DTXFSTS15 register for the ALT_USB0_DEVGRP instance. */
4125
#define ALT_USB0_DEV_DTXFSTS15_ADDR ALT_USB_DEV_DTXFSTS15_ADDR(ALT_USB0_DEVGRP_ADDR)
4126
/* The address of the ALT_USB_DEV_DIEPDMAB15 register for the ALT_USB0_DEVGRP instance. */
4127
#define ALT_USB0_DEV_DIEPDMAB15_ADDR ALT_USB_DEV_DIEPDMAB15_ADDR(ALT_USB0_DEVGRP_ADDR)
4128
/* The address of the ALT_USB_DEV_DOEPCTL0 register for the ALT_USB0_DEVGRP instance. */
4129
#define ALT_USB0_DEV_DOEPCTL0_ADDR ALT_USB_DEV_DOEPCTL0_ADDR(ALT_USB0_DEVGRP_ADDR)
4130
/* The address of the ALT_USB_DEV_DOEPINT0 register for the ALT_USB0_DEVGRP instance. */
4131
#define ALT_USB0_DEV_DOEPINT0_ADDR ALT_USB_DEV_DOEPINT0_ADDR(ALT_USB0_DEVGRP_ADDR)
4132
/* The address of the ALT_USB_DEV_DOEPTSIZ0 register for the ALT_USB0_DEVGRP instance. */
4133
#define ALT_USB0_DEV_DOEPTSIZ0_ADDR ALT_USB_DEV_DOEPTSIZ0_ADDR(ALT_USB0_DEVGRP_ADDR)
4134
/* The address of the ALT_USB_DEV_DOEPDMA0 register for the ALT_USB0_DEVGRP instance. */
4135
#define ALT_USB0_DEV_DOEPDMA0_ADDR ALT_USB_DEV_DOEPDMA0_ADDR(ALT_USB0_DEVGRP_ADDR)
4136
/* The address of the ALT_USB_DEV_DOEPDMAB0 register for the ALT_USB0_DEVGRP instance. */
4137
#define ALT_USB0_DEV_DOEPDMAB0_ADDR ALT_USB_DEV_DOEPDMAB0_ADDR(ALT_USB0_DEVGRP_ADDR)
4138
/* The address of the ALT_USB_DEV_DOEPCTL1 register for the ALT_USB0_DEVGRP instance. */
4139
#define ALT_USB0_DEV_DOEPCTL1_ADDR ALT_USB_DEV_DOEPCTL1_ADDR(ALT_USB0_DEVGRP_ADDR)
4140
/* The address of the ALT_USB_DEV_DOEPINT1 register for the ALT_USB0_DEVGRP instance. */
4141
#define ALT_USB0_DEV_DOEPINT1_ADDR ALT_USB_DEV_DOEPINT1_ADDR(ALT_USB0_DEVGRP_ADDR)
4142
/* The address of the ALT_USB_DEV_DOEPTSIZ1 register for the ALT_USB0_DEVGRP instance. */
4143
#define ALT_USB0_DEV_DOEPTSIZ1_ADDR ALT_USB_DEV_DOEPTSIZ1_ADDR(ALT_USB0_DEVGRP_ADDR)
4144
/* The address of the ALT_USB_DEV_DOEPDMA1 register for the ALT_USB0_DEVGRP instance. */
4145
#define ALT_USB0_DEV_DOEPDMA1_ADDR ALT_USB_DEV_DOEPDMA1_ADDR(ALT_USB0_DEVGRP_ADDR)
4146
/* The address of the ALT_USB_DEV_DOEPDMAB1 register for the ALT_USB0_DEVGRP instance. */
4147
#define ALT_USB0_DEV_DOEPDMAB1_ADDR ALT_USB_DEV_DOEPDMAB1_ADDR(ALT_USB0_DEVGRP_ADDR)
4148
/* The address of the ALT_USB_DEV_DOEPCTL2 register for the ALT_USB0_DEVGRP instance. */
4149
#define ALT_USB0_DEV_DOEPCTL2_ADDR ALT_USB_DEV_DOEPCTL2_ADDR(ALT_USB0_DEVGRP_ADDR)
4150
/* The address of the ALT_USB_DEV_DOEPINT2 register for the ALT_USB0_DEVGRP instance. */
4151
#define ALT_USB0_DEV_DOEPINT2_ADDR ALT_USB_DEV_DOEPINT2_ADDR(ALT_USB0_DEVGRP_ADDR)
4152
/* The address of the ALT_USB_DEV_DOEPTSIZ2 register for the ALT_USB0_DEVGRP instance. */
4153
#define ALT_USB0_DEV_DOEPTSIZ2_ADDR ALT_USB_DEV_DOEPTSIZ2_ADDR(ALT_USB0_DEVGRP_ADDR)
4154
/* The address of the ALT_USB_DEV_DOEPDMA2 register for the ALT_USB0_DEVGRP instance. */
4155
#define ALT_USB0_DEV_DOEPDMA2_ADDR ALT_USB_DEV_DOEPDMA2_ADDR(ALT_USB0_DEVGRP_ADDR)
4156
/* The address of the ALT_USB_DEV_DOEPDMAB2 register for the ALT_USB0_DEVGRP instance. */
4157
#define ALT_USB0_DEV_DOEPDMAB2_ADDR ALT_USB_DEV_DOEPDMAB2_ADDR(ALT_USB0_DEVGRP_ADDR)
4158
/* The address of the ALT_USB_DEV_DOEPCTL3 register for the ALT_USB0_DEVGRP instance. */
4159
#define ALT_USB0_DEV_DOEPCTL3_ADDR ALT_USB_DEV_DOEPCTL3_ADDR(ALT_USB0_DEVGRP_ADDR)
4160
/* The address of the ALT_USB_DEV_DOEPINT3 register for the ALT_USB0_DEVGRP instance. */
4161
#define ALT_USB0_DEV_DOEPINT3_ADDR ALT_USB_DEV_DOEPINT3_ADDR(ALT_USB0_DEVGRP_ADDR)
4162
/* The address of the ALT_USB_DEV_DOEPTSIZ3 register for the ALT_USB0_DEVGRP instance. */
4163
#define ALT_USB0_DEV_DOEPTSIZ3_ADDR ALT_USB_DEV_DOEPTSIZ3_ADDR(ALT_USB0_DEVGRP_ADDR)
4164
/* The address of the ALT_USB_DEV_DOEPDMA3 register for the ALT_USB0_DEVGRP instance. */
4165
#define ALT_USB0_DEV_DOEPDMA3_ADDR ALT_USB_DEV_DOEPDMA3_ADDR(ALT_USB0_DEVGRP_ADDR)
4166
/* The address of the ALT_USB_DEV_DOEPDMAB3 register for the ALT_USB0_DEVGRP instance. */
4167
#define ALT_USB0_DEV_DOEPDMAB3_ADDR ALT_USB_DEV_DOEPDMAB3_ADDR(ALT_USB0_DEVGRP_ADDR)
4168
/* The address of the ALT_USB_DEV_DOEPCTL4 register for the ALT_USB0_DEVGRP instance. */
4169
#define ALT_USB0_DEV_DOEPCTL4_ADDR ALT_USB_DEV_DOEPCTL4_ADDR(ALT_USB0_DEVGRP_ADDR)
4170
/* The address of the ALT_USB_DEV_DOEPINT4 register for the ALT_USB0_DEVGRP instance. */
4171
#define ALT_USB0_DEV_DOEPINT4_ADDR ALT_USB_DEV_DOEPINT4_ADDR(ALT_USB0_DEVGRP_ADDR)
4172
/* The address of the ALT_USB_DEV_DOEPTSIZ4 register for the ALT_USB0_DEVGRP instance. */
4173
#define ALT_USB0_DEV_DOEPTSIZ4_ADDR ALT_USB_DEV_DOEPTSIZ4_ADDR(ALT_USB0_DEVGRP_ADDR)
4174
/* The address of the ALT_USB_DEV_DOEPDMA4 register for the ALT_USB0_DEVGRP instance. */
4175
#define ALT_USB0_DEV_DOEPDMA4_ADDR ALT_USB_DEV_DOEPDMA4_ADDR(ALT_USB0_DEVGRP_ADDR)
4176
/* The address of the ALT_USB_DEV_DOEPDMAB4 register for the ALT_USB0_DEVGRP instance. */
4177
#define ALT_USB0_DEV_DOEPDMAB4_ADDR ALT_USB_DEV_DOEPDMAB4_ADDR(ALT_USB0_DEVGRP_ADDR)
4178
/* The address of the ALT_USB_DEV_DOEPCTL5 register for the ALT_USB0_DEVGRP instance. */
4179
#define ALT_USB0_DEV_DOEPCTL5_ADDR ALT_USB_DEV_DOEPCTL5_ADDR(ALT_USB0_DEVGRP_ADDR)
4180
/* The address of the ALT_USB_DEV_DOEPINT5 register for the ALT_USB0_DEVGRP instance. */
4181
#define ALT_USB0_DEV_DOEPINT5_ADDR ALT_USB_DEV_DOEPINT5_ADDR(ALT_USB0_DEVGRP_ADDR)
4182
/* The address of the ALT_USB_DEV_DOEPTSIZ5 register for the ALT_USB0_DEVGRP instance. */
4183
#define ALT_USB0_DEV_DOEPTSIZ5_ADDR ALT_USB_DEV_DOEPTSIZ5_ADDR(ALT_USB0_DEVGRP_ADDR)
4184
/* The address of the ALT_USB_DEV_DOEPDMA5 register for the ALT_USB0_DEVGRP instance. */
4185
#define ALT_USB0_DEV_DOEPDMA5_ADDR ALT_USB_DEV_DOEPDMA5_ADDR(ALT_USB0_DEVGRP_ADDR)
4186
/* The address of the ALT_USB_DEV_DOEPDMAB5 register for the ALT_USB0_DEVGRP instance. */
4187
#define ALT_USB0_DEV_DOEPDMAB5_ADDR ALT_USB_DEV_DOEPDMAB5_ADDR(ALT_USB0_DEVGRP_ADDR)
4188
/* The address of the ALT_USB_DEV_DOEPCTL6 register for the ALT_USB0_DEVGRP instance. */
4189
#define ALT_USB0_DEV_DOEPCTL6_ADDR ALT_USB_DEV_DOEPCTL6_ADDR(ALT_USB0_DEVGRP_ADDR)
4190
/* The address of the ALT_USB_DEV_DOEPINT6 register for the ALT_USB0_DEVGRP instance. */
4191
#define ALT_USB0_DEV_DOEPINT6_ADDR ALT_USB_DEV_DOEPINT6_ADDR(ALT_USB0_DEVGRP_ADDR)
4192
/* The address of the ALT_USB_DEV_DOEPTSIZ6 register for the ALT_USB0_DEVGRP instance. */
4193
#define ALT_USB0_DEV_DOEPTSIZ6_ADDR ALT_USB_DEV_DOEPTSIZ6_ADDR(ALT_USB0_DEVGRP_ADDR)
4194
/* The address of the ALT_USB_DEV_DOEPDMA6 register for the ALT_USB0_DEVGRP instance. */
4195
#define ALT_USB0_DEV_DOEPDMA6_ADDR ALT_USB_DEV_DOEPDMA6_ADDR(ALT_USB0_DEVGRP_ADDR)
4196
/* The address of the ALT_USB_DEV_DOEPDMAB6 register for the ALT_USB0_DEVGRP instance. */
4197
#define ALT_USB0_DEV_DOEPDMAB6_ADDR ALT_USB_DEV_DOEPDMAB6_ADDR(ALT_USB0_DEVGRP_ADDR)
4198
/* The address of the ALT_USB_DEV_DOEPCTL7 register for the ALT_USB0_DEVGRP instance. */
4199
#define ALT_USB0_DEV_DOEPCTL7_ADDR ALT_USB_DEV_DOEPCTL7_ADDR(ALT_USB0_DEVGRP_ADDR)
4200
/* The address of the ALT_USB_DEV_DOEPINT7 register for the ALT_USB0_DEVGRP instance. */
4201
#define ALT_USB0_DEV_DOEPINT7_ADDR ALT_USB_DEV_DOEPINT7_ADDR(ALT_USB0_DEVGRP_ADDR)
4202
/* The address of the ALT_USB_DEV_DOEPTSIZ7 register for the ALT_USB0_DEVGRP instance. */
4203
#define ALT_USB0_DEV_DOEPTSIZ7_ADDR ALT_USB_DEV_DOEPTSIZ7_ADDR(ALT_USB0_DEVGRP_ADDR)
4204
/* The address of the ALT_USB_DEV_DOEPDMA7 register for the ALT_USB0_DEVGRP instance. */
4205
#define ALT_USB0_DEV_DOEPDMA7_ADDR ALT_USB_DEV_DOEPDMA7_ADDR(ALT_USB0_DEVGRP_ADDR)
4206
/* The address of the ALT_USB_DEV_DOEPDMAB7 register for the ALT_USB0_DEVGRP instance. */
4207
#define ALT_USB0_DEV_DOEPDMAB7_ADDR ALT_USB_DEV_DOEPDMAB7_ADDR(ALT_USB0_DEVGRP_ADDR)
4208
/* The address of the ALT_USB_DEV_DOEPCTL8 register for the ALT_USB0_DEVGRP instance. */
4209
#define ALT_USB0_DEV_DOEPCTL8_ADDR ALT_USB_DEV_DOEPCTL8_ADDR(ALT_USB0_DEVGRP_ADDR)
4210
/* The address of the ALT_USB_DEV_DOEPINT8 register for the ALT_USB0_DEVGRP instance. */
4211
#define ALT_USB0_DEV_DOEPINT8_ADDR ALT_USB_DEV_DOEPINT8_ADDR(ALT_USB0_DEVGRP_ADDR)
4212
/* The address of the ALT_USB_DEV_DOEPTSIZ8 register for the ALT_USB0_DEVGRP instance. */
4213
#define ALT_USB0_DEV_DOEPTSIZ8_ADDR ALT_USB_DEV_DOEPTSIZ8_ADDR(ALT_USB0_DEVGRP_ADDR)
4214
/* The address of the ALT_USB_DEV_DOEPDMA8 register for the ALT_USB0_DEVGRP instance. */
4215
#define ALT_USB0_DEV_DOEPDMA8_ADDR ALT_USB_DEV_DOEPDMA8_ADDR(ALT_USB0_DEVGRP_ADDR)
4216
/* The address of the ALT_USB_DEV_DOEPDMAB8 register for the ALT_USB0_DEVGRP instance. */
4217
#define ALT_USB0_DEV_DOEPDMAB8_ADDR ALT_USB_DEV_DOEPDMAB8_ADDR(ALT_USB0_DEVGRP_ADDR)
4218
/* The address of the ALT_USB_DEV_DOEPCTL9 register for the ALT_USB0_DEVGRP instance. */
4219
#define ALT_USB0_DEV_DOEPCTL9_ADDR ALT_USB_DEV_DOEPCTL9_ADDR(ALT_USB0_DEVGRP_ADDR)
4220
/* The address of the ALT_USB_DEV_DOEPINT9 register for the ALT_USB0_DEVGRP instance. */
4221
#define ALT_USB0_DEV_DOEPINT9_ADDR ALT_USB_DEV_DOEPINT9_ADDR(ALT_USB0_DEVGRP_ADDR)
4222
/* The address of the ALT_USB_DEV_DOEPTSIZ9 register for the ALT_USB0_DEVGRP instance. */
4223
#define ALT_USB0_DEV_DOEPTSIZ9_ADDR ALT_USB_DEV_DOEPTSIZ9_ADDR(ALT_USB0_DEVGRP_ADDR)
4224
/* The address of the ALT_USB_DEV_DOEPDMA9 register for the ALT_USB0_DEVGRP instance. */
4225
#define ALT_USB0_DEV_DOEPDMA9_ADDR ALT_USB_DEV_DOEPDMA9_ADDR(ALT_USB0_DEVGRP_ADDR)
4226
/* The address of the ALT_USB_DEV_DOEPDMAB9 register for the ALT_USB0_DEVGRP instance. */
4227
#define ALT_USB0_DEV_DOEPDMAB9_ADDR ALT_USB_DEV_DOEPDMAB9_ADDR(ALT_USB0_DEVGRP_ADDR)
4228
/* The address of the ALT_USB_DEV_DOEPCTL10 register for the ALT_USB0_DEVGRP instance. */
4229
#define ALT_USB0_DEV_DOEPCTL10_ADDR ALT_USB_DEV_DOEPCTL10_ADDR(ALT_USB0_DEVGRP_ADDR)
4230
/* The address of the ALT_USB_DEV_DOEPINT10 register for the ALT_USB0_DEVGRP instance. */
4231
#define ALT_USB0_DEV_DOEPINT10_ADDR ALT_USB_DEV_DOEPINT10_ADDR(ALT_USB0_DEVGRP_ADDR)
4232
/* The address of the ALT_USB_DEV_DOEPTSIZ10 register for the ALT_USB0_DEVGRP instance. */
4233
#define ALT_USB0_DEV_DOEPTSIZ10_ADDR ALT_USB_DEV_DOEPTSIZ10_ADDR(ALT_USB0_DEVGRP_ADDR)
4234
/* The address of the ALT_USB_DEV_DOEPDMA10 register for the ALT_USB0_DEVGRP instance. */
4235
#define ALT_USB0_DEV_DOEPDMA10_ADDR ALT_USB_DEV_DOEPDMA10_ADDR(ALT_USB0_DEVGRP_ADDR)
4236
/* The address of the ALT_USB_DEV_DOEPDMAB10 register for the ALT_USB0_DEVGRP instance. */
4237
#define ALT_USB0_DEV_DOEPDMAB10_ADDR ALT_USB_DEV_DOEPDMAB10_ADDR(ALT_USB0_DEVGRP_ADDR)
4238
/* The address of the ALT_USB_DEV_DOEPCTL11 register for the ALT_USB0_DEVGRP instance. */
4239
#define ALT_USB0_DEV_DOEPCTL11_ADDR ALT_USB_DEV_DOEPCTL11_ADDR(ALT_USB0_DEVGRP_ADDR)
4240
/* The address of the ALT_USB_DEV_DOEPINT11 register for the ALT_USB0_DEVGRP instance. */
4241
#define ALT_USB0_DEV_DOEPINT11_ADDR ALT_USB_DEV_DOEPINT11_ADDR(ALT_USB0_DEVGRP_ADDR)
4242
/* The address of the ALT_USB_DEV_DOEPTSIZ11 register for the ALT_USB0_DEVGRP instance. */
4243
#define ALT_USB0_DEV_DOEPTSIZ11_ADDR ALT_USB_DEV_DOEPTSIZ11_ADDR(ALT_USB0_DEVGRP_ADDR)
4244
/* The address of the ALT_USB_DEV_DOEPDMA11 register for the ALT_USB0_DEVGRP instance. */
4245
#define ALT_USB0_DEV_DOEPDMA11_ADDR ALT_USB_DEV_DOEPDMA11_ADDR(ALT_USB0_DEVGRP_ADDR)
4246
/* The address of the ALT_USB_DEV_DOEPDMAB11 register for the ALT_USB0_DEVGRP instance. */
4247
#define ALT_USB0_DEV_DOEPDMAB11_ADDR ALT_USB_DEV_DOEPDMAB11_ADDR(ALT_USB0_DEVGRP_ADDR)
4248
/* The address of the ALT_USB_DEV_DOEPCTL12 register for the ALT_USB0_DEVGRP instance. */
4249
#define ALT_USB0_DEV_DOEPCTL12_ADDR ALT_USB_DEV_DOEPCTL12_ADDR(ALT_USB0_DEVGRP_ADDR)
4250
/* The address of the ALT_USB_DEV_DOEPINT12 register for the ALT_USB0_DEVGRP instance. */
4251
#define ALT_USB0_DEV_DOEPINT12_ADDR ALT_USB_DEV_DOEPINT12_ADDR(ALT_USB0_DEVGRP_ADDR)
4252
/* The address of the ALT_USB_DEV_DOEPTSIZ12 register for the ALT_USB0_DEVGRP instance. */
4253
#define ALT_USB0_DEV_DOEPTSIZ12_ADDR ALT_USB_DEV_DOEPTSIZ12_ADDR(ALT_USB0_DEVGRP_ADDR)
4254
/* The address of the ALT_USB_DEV_DOEPDMA12 register for the ALT_USB0_DEVGRP instance. */
4255
#define ALT_USB0_DEV_DOEPDMA12_ADDR ALT_USB_DEV_DOEPDMA12_ADDR(ALT_USB0_DEVGRP_ADDR)
4256
/* The address of the ALT_USB_DEV_DOEPDMAB12 register for the ALT_USB0_DEVGRP instance. */
4257
#define ALT_USB0_DEV_DOEPDMAB12_ADDR ALT_USB_DEV_DOEPDMAB12_ADDR(ALT_USB0_DEVGRP_ADDR)
4258
/* The address of the ALT_USB_DEV_DOEPCTL13 register for the ALT_USB0_DEVGRP instance. */
4259
#define ALT_USB0_DEV_DOEPCTL13_ADDR ALT_USB_DEV_DOEPCTL13_ADDR(ALT_USB0_DEVGRP_ADDR)
4260
/* The address of the ALT_USB_DEV_DOEPINT13 register for the ALT_USB0_DEVGRP instance. */
4261
#define ALT_USB0_DEV_DOEPINT13_ADDR ALT_USB_DEV_DOEPINT13_ADDR(ALT_USB0_DEVGRP_ADDR)
4262
/* The address of the ALT_USB_DEV_DOEPTSIZ13 register for the ALT_USB0_DEVGRP instance. */
4263
#define ALT_USB0_DEV_DOEPTSIZ13_ADDR ALT_USB_DEV_DOEPTSIZ13_ADDR(ALT_USB0_DEVGRP_ADDR)
4264
/* The address of the ALT_USB_DEV_DOEPDMA13 register for the ALT_USB0_DEVGRP instance. */
4265
#define ALT_USB0_DEV_DOEPDMA13_ADDR ALT_USB_DEV_DOEPDMA13_ADDR(ALT_USB0_DEVGRP_ADDR)
4266
/* The address of the ALT_USB_DEV_DOEPDMAB13 register for the ALT_USB0_DEVGRP instance. */
4267
#define ALT_USB0_DEV_DOEPDMAB13_ADDR ALT_USB_DEV_DOEPDMAB13_ADDR(ALT_USB0_DEVGRP_ADDR)
4268
/* The address of the ALT_USB_DEV_DOEPCTL14 register for the ALT_USB0_DEVGRP instance. */
4269
#define ALT_USB0_DEV_DOEPCTL14_ADDR ALT_USB_DEV_DOEPCTL14_ADDR(ALT_USB0_DEVGRP_ADDR)
4270
/* The address of the ALT_USB_DEV_DOEPINT14 register for the ALT_USB0_DEVGRP instance. */
4271
#define ALT_USB0_DEV_DOEPINT14_ADDR ALT_USB_DEV_DOEPINT14_ADDR(ALT_USB0_DEVGRP_ADDR)
4272
/* The address of the ALT_USB_DEV_DOEPTSIZ14 register for the ALT_USB0_DEVGRP instance. */
4273
#define ALT_USB0_DEV_DOEPTSIZ14_ADDR ALT_USB_DEV_DOEPTSIZ14_ADDR(ALT_USB0_DEVGRP_ADDR)
4274
/* The address of the ALT_USB_DEV_DOEPDMA14 register for the ALT_USB0_DEVGRP instance. */
4275
#define ALT_USB0_DEV_DOEPDMA14_ADDR ALT_USB_DEV_DOEPDMA14_ADDR(ALT_USB0_DEVGRP_ADDR)
4276
/* The address of the ALT_USB_DEV_DOEPDMAB14 register for the ALT_USB0_DEVGRP instance. */
4277
#define ALT_USB0_DEV_DOEPDMAB14_ADDR ALT_USB_DEV_DOEPDMAB14_ADDR(ALT_USB0_DEVGRP_ADDR)
4278
/* The address of the ALT_USB_DEV_DOEPCTL15 register for the ALT_USB0_DEVGRP instance. */
4279
#define ALT_USB0_DEV_DOEPCTL15_ADDR ALT_USB_DEV_DOEPCTL15_ADDR(ALT_USB0_DEVGRP_ADDR)
4280
/* The address of the ALT_USB_DEV_DOEPINT15 register for the ALT_USB0_DEVGRP instance. */
4281
#define ALT_USB0_DEV_DOEPINT15_ADDR ALT_USB_DEV_DOEPINT15_ADDR(ALT_USB0_DEVGRP_ADDR)
4282
/* The address of the ALT_USB_DEV_DOEPTSIZ15 register for the ALT_USB0_DEVGRP instance. */
4283
#define ALT_USB0_DEV_DOEPTSIZ15_ADDR ALT_USB_DEV_DOEPTSIZ15_ADDR(ALT_USB0_DEVGRP_ADDR)
4284
/* The address of the ALT_USB_DEV_DOEPDMA15 register for the ALT_USB0_DEVGRP instance. */
4285
#define ALT_USB0_DEV_DOEPDMA15_ADDR ALT_USB_DEV_DOEPDMA15_ADDR(ALT_USB0_DEVGRP_ADDR)
4286
/* The address of the ALT_USB_DEV_DOEPDMAB15 register for the ALT_USB0_DEVGRP instance. */
4287
#define ALT_USB0_DEV_DOEPDMAB15_ADDR ALT_USB_DEV_DOEPDMAB15_ADDR(ALT_USB0_DEVGRP_ADDR)
4288
/* The base address byte offset for the start of the ALT_USB0_DEVGRP component. */
4289
#define ALT_USB0_DEVGRP_OFST 0x800
4290
/* The start address of the ALT_USB0_DEVGRP component. */
4291
#define ALT_USB0_DEVGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB0_ADDR) + ALT_USB0_DEVGRP_OFST))
4292
/* The lower bound address range of the ALT_USB0_DEVGRP component. */
4293
#define ALT_USB0_DEVGRP_LB_ADDR ALT_USB0_DEVGRP_ADDR
4294
/* The upper bound address range of the ALT_USB0_DEVGRP component. */
4295
#define ALT_USB0_DEVGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB0_DEVGRP_ADDR) + 0x500) - 1))
4296
4297
4298
4299
* Register Group Instance : pwrclkgrp
4300
4301
* Instance pwrclkgrp of register group ALT_USB_PWRCLK.
4302
4303
4304
4305
/* The address of the ALT_USB_PWRCLK_PCGCCTL register for the ALT_USB0_PWRCLKGRP instance. */
4306
#define ALT_USB0_PWRCLK_PCGCCTL_ADDR ALT_USB_PWRCLK_PCGCCTL_ADDR(ALT_USB0_PWRCLKGRP_ADDR)
4307
/* The base address byte offset for the start of the ALT_USB0_PWRCLKGRP component. */
4308
#define ALT_USB0_PWRCLKGRP_OFST 0xe00
4309
/* The start address of the ALT_USB0_PWRCLKGRP component. */
4310
#define ALT_USB0_PWRCLKGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB0_ADDR) + ALT_USB0_PWRCLKGRP_OFST))
4311
/* The lower bound address range of the ALT_USB0_PWRCLKGRP component. */
4312
#define ALT_USB0_PWRCLKGRP_LB_ADDR ALT_USB0_PWRCLKGRP_ADDR
4313
/* The upper bound address range of the ALT_USB0_PWRCLKGRP component. */
4314
#define ALT_USB0_PWRCLKGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB0_PWRCLKGRP_ADDR) + 0x4) - 1))
4315
4316
4317
/* The base address byte offset for the start of the ALT_USB0 component. */
4318
#define ALT_USB0_OFST 0xffb00000
4319
/* The start address of the ALT_USB0 component. */
4320
#define ALT_USB0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_USB0_OFST))
4321
/* The lower bound address range of the ALT_USB0 component. */
4322
#define ALT_USB0_LB_ADDR ALT_USB0_ADDR
4323
/* The upper bound address range of the ALT_USB0 component. */
4324
#define ALT_USB0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB0_ADDR) + 0x40000) - 1))
4325
4326
4327
4328
* Component Instance : usb1
4329
4330
* Instance usb1 of component ALT_USB.
4331
4332
4333
4334
4335
* Register Group Instance : globgrp
4336
4337
* Instance globgrp of register group ALT_USB_GLOB.
4338
4339
4340
4341
/* The address of the ALT_USB_GLOB_GOTGCTL register for the ALT_USB1_GLOBGRP instance. */
4342
#define ALT_USB1_GLOB_GOTGCTL_ADDR ALT_USB_GLOB_GOTGCTL_ADDR(ALT_USB1_GLOBGRP_ADDR)
4343
/* The address of the ALT_USB_GLOB_GOTGINT register for the ALT_USB1_GLOBGRP instance. */
4344
#define ALT_USB1_GLOB_GOTGINT_ADDR ALT_USB_GLOB_GOTGINT_ADDR(ALT_USB1_GLOBGRP_ADDR)
4345
/* The address of the ALT_USB_GLOB_GAHBCFG register for the ALT_USB1_GLOBGRP instance. */
4346
#define ALT_USB1_GLOB_GAHBCFG_ADDR ALT_USB_GLOB_GAHBCFG_ADDR(ALT_USB1_GLOBGRP_ADDR)
4347
/* The address of the ALT_USB_GLOB_GUSBCFG register for the ALT_USB1_GLOBGRP instance. */
4348
#define ALT_USB1_GLOB_GUSBCFG_ADDR ALT_USB_GLOB_GUSBCFG_ADDR(ALT_USB1_GLOBGRP_ADDR)
4349
/* The address of the ALT_USB_GLOB_GRSTCTL register for the ALT_USB1_GLOBGRP instance. */
4350
#define ALT_USB1_GLOB_GRSTCTL_ADDR ALT_USB_GLOB_GRSTCTL_ADDR(ALT_USB1_GLOBGRP_ADDR)
4351
/* The address of the ALT_USB_GLOB_GINTSTS register for the ALT_USB1_GLOBGRP instance. */
4352
#define ALT_USB1_GLOB_GINTSTS_ADDR ALT_USB_GLOB_GINTSTS_ADDR(ALT_USB1_GLOBGRP_ADDR)
4353
/* The address of the ALT_USB_GLOB_GINTMSK register for the ALT_USB1_GLOBGRP instance. */
4354
#define ALT_USB1_GLOB_GINTMSK_ADDR ALT_USB_GLOB_GINTMSK_ADDR(ALT_USB1_GLOBGRP_ADDR)
4355
/* The address of the ALT_USB_GLOB_GRXSTSR register for the ALT_USB1_GLOBGRP instance. */
4356
#define ALT_USB1_GLOB_GRXSTSR_ADDR ALT_USB_GLOB_GRXSTSR_ADDR(ALT_USB1_GLOBGRP_ADDR)
4357
/* The address of the ALT_USB_GLOB_GRXSTSP register for the ALT_USB1_GLOBGRP instance. */
4358
#define ALT_USB1_GLOB_GRXSTSP_ADDR ALT_USB_GLOB_GRXSTSP_ADDR(ALT_USB1_GLOBGRP_ADDR)
4359
/* The address of the ALT_USB_GLOB_GRXFSIZ register for the ALT_USB1_GLOBGRP instance. */
4360
#define ALT_USB1_GLOB_GRXFSIZ_ADDR ALT_USB_GLOB_GRXFSIZ_ADDR(ALT_USB1_GLOBGRP_ADDR)
4361
/* The address of the ALT_USB_GLOB_GNPTXFSIZ register for the ALT_USB1_GLOBGRP instance. */
4362
#define ALT_USB1_GLOB_GNPTXFSIZ_ADDR ALT_USB_GLOB_GNPTXFSIZ_ADDR(ALT_USB1_GLOBGRP_ADDR)
4363
/* The address of the ALT_USB_GLOB_GNPTXSTS register for the ALT_USB1_GLOBGRP instance. */
4364
#define ALT_USB1_GLOB_GNPTXSTS_ADDR ALT_USB_GLOB_GNPTXSTS_ADDR(ALT_USB1_GLOBGRP_ADDR)
4365
/* The address of the ALT_USB_GLOB_GPVNDCTL register for the ALT_USB1_GLOBGRP instance. */
4366
#define ALT_USB1_GLOB_GPVNDCTL_ADDR ALT_USB_GLOB_GPVNDCTL_ADDR(ALT_USB1_GLOBGRP_ADDR)
4367
/* The address of the ALT_USB_GLOB_GGPIO register for the ALT_USB1_GLOBGRP instance. */
4368
#define ALT_USB1_GLOB_GGPIO_ADDR ALT_USB_GLOB_GGPIO_ADDR(ALT_USB1_GLOBGRP_ADDR)
4369
/* The address of the ALT_USB_GLOB_GUID register for the ALT_USB1_GLOBGRP instance. */
4370
#define ALT_USB1_GLOB_GUID_ADDR ALT_USB_GLOB_GUID_ADDR(ALT_USB1_GLOBGRP_ADDR)
4371
/* The address of the ALT_USB_GLOB_GSNPSID register for the ALT_USB1_GLOBGRP instance. */
4372
#define ALT_USB1_GLOB_GSNPSID_ADDR ALT_USB_GLOB_GSNPSID_ADDR(ALT_USB1_GLOBGRP_ADDR)
4373
/* The address of the ALT_USB_GLOB_GHWCFG1 register for the ALT_USB1_GLOBGRP instance. */
4374
#define ALT_USB1_GLOB_GHWCFG1_ADDR ALT_USB_GLOB_GHWCFG1_ADDR(ALT_USB1_GLOBGRP_ADDR)
4375
/* The address of the ALT_USB_GLOB_GHWCFG2 register for the ALT_USB1_GLOBGRP instance. */
4376
#define ALT_USB1_GLOB_GHWCFG2_ADDR ALT_USB_GLOB_GHWCFG2_ADDR(ALT_USB1_GLOBGRP_ADDR)
4377
/* The address of the ALT_USB_GLOB_GHWCFG3 register for the ALT_USB1_GLOBGRP instance. */
4378
#define ALT_USB1_GLOB_GHWCFG3_ADDR ALT_USB_GLOB_GHWCFG3_ADDR(ALT_USB1_GLOBGRP_ADDR)
4379
/* The address of the ALT_USB_GLOB_GHWCFG4 register for the ALT_USB1_GLOBGRP instance. */
4380
#define ALT_USB1_GLOB_GHWCFG4_ADDR ALT_USB_GLOB_GHWCFG4_ADDR(ALT_USB1_GLOBGRP_ADDR)
4381
/* The address of the ALT_USB_GLOB_GDFIFOCFG register for the ALT_USB1_GLOBGRP instance. */
4382
#define ALT_USB1_GLOB_GDFIFOCFG_ADDR ALT_USB_GLOB_GDFIFOCFG_ADDR(ALT_USB1_GLOBGRP_ADDR)
4383
/* The address of the ALT_USB_GLOB_HPTXFSIZ register for the ALT_USB1_GLOBGRP instance. */
4384
#define ALT_USB1_GLOB_HPTXFSIZ_ADDR ALT_USB_GLOB_HPTXFSIZ_ADDR(ALT_USB1_GLOBGRP_ADDR)
4385
/* The address of the ALT_USB_GLOB_DIEPTXF1 register for the ALT_USB1_GLOBGRP instance. */
4386
#define ALT_USB1_GLOB_DIEPTXF1_ADDR ALT_USB_GLOB_DIEPTXF1_ADDR(ALT_USB1_GLOBGRP_ADDR)
4387
/* The address of the ALT_USB_GLOB_DIEPTXF2 register for the ALT_USB1_GLOBGRP instance. */
4388
#define ALT_USB1_GLOB_DIEPTXF2_ADDR ALT_USB_GLOB_DIEPTXF2_ADDR(ALT_USB1_GLOBGRP_ADDR)
4389
/* The address of the ALT_USB_GLOB_DIEPTXF3 register for the ALT_USB1_GLOBGRP instance. */
4390
#define ALT_USB1_GLOB_DIEPTXF3_ADDR ALT_USB_GLOB_DIEPTXF3_ADDR(ALT_USB1_GLOBGRP_ADDR)
4391
/* The address of the ALT_USB_GLOB_DIEPTXF4 register for the ALT_USB1_GLOBGRP instance. */
4392
#define ALT_USB1_GLOB_DIEPTXF4_ADDR ALT_USB_GLOB_DIEPTXF4_ADDR(ALT_USB1_GLOBGRP_ADDR)
4393
/* The address of the ALT_USB_GLOB_DIEPTXF5 register for the ALT_USB1_GLOBGRP instance. */
4394
#define ALT_USB1_GLOB_DIEPTXF5_ADDR ALT_USB_GLOB_DIEPTXF5_ADDR(ALT_USB1_GLOBGRP_ADDR)
4395
/* The address of the ALT_USB_GLOB_DIEPTXF6 register for the ALT_USB1_GLOBGRP instance. */
4396
#define ALT_USB1_GLOB_DIEPTXF6_ADDR ALT_USB_GLOB_DIEPTXF6_ADDR(ALT_USB1_GLOBGRP_ADDR)
4397
/* The address of the ALT_USB_GLOB_DIEPTXF7 register for the ALT_USB1_GLOBGRP instance. */
4398
#define ALT_USB1_GLOB_DIEPTXF7_ADDR ALT_USB_GLOB_DIEPTXF7_ADDR(ALT_USB1_GLOBGRP_ADDR)
4399
/* The address of the ALT_USB_GLOB_DIEPTXF8 register for the ALT_USB1_GLOBGRP instance. */
4400
#define ALT_USB1_GLOB_DIEPTXF8_ADDR ALT_USB_GLOB_DIEPTXF8_ADDR(ALT_USB1_GLOBGRP_ADDR)
4401
/* The address of the ALT_USB_GLOB_DIEPTXF9 register for the ALT_USB1_GLOBGRP instance. */
4402
#define ALT_USB1_GLOB_DIEPTXF9_ADDR ALT_USB_GLOB_DIEPTXF9_ADDR(ALT_USB1_GLOBGRP_ADDR)
4403
/* The address of the ALT_USB_GLOB_DIEPTXF10 register for the ALT_USB1_GLOBGRP instance. */
4404
#define ALT_USB1_GLOB_DIEPTXF10_ADDR ALT_USB_GLOB_DIEPTXF10_ADDR(ALT_USB1_GLOBGRP_ADDR)
4405
/* The address of the ALT_USB_GLOB_DIEPTXF11 register for the ALT_USB1_GLOBGRP instance. */
4406
#define ALT_USB1_GLOB_DIEPTXF11_ADDR ALT_USB_GLOB_DIEPTXF11_ADDR(ALT_USB1_GLOBGRP_ADDR)
4407
/* The address of the ALT_USB_GLOB_DIEPTXF12 register for the ALT_USB1_GLOBGRP instance. */
4408
#define ALT_USB1_GLOB_DIEPTXF12_ADDR ALT_USB_GLOB_DIEPTXF12_ADDR(ALT_USB1_GLOBGRP_ADDR)
4409
/* The address of the ALT_USB_GLOB_DIEPTXF13 register for the ALT_USB1_GLOBGRP instance. */
4410
#define ALT_USB1_GLOB_DIEPTXF13_ADDR ALT_USB_GLOB_DIEPTXF13_ADDR(ALT_USB1_GLOBGRP_ADDR)
4411
/* The address of the ALT_USB_GLOB_DIEPTXF14 register for the ALT_USB1_GLOBGRP instance. */
4412
#define ALT_USB1_GLOB_DIEPTXF14_ADDR ALT_USB_GLOB_DIEPTXF14_ADDR(ALT_USB1_GLOBGRP_ADDR)
4413
/* The address of the ALT_USB_GLOB_DIEPTXF15 register for the ALT_USB1_GLOBGRP instance. */
4414
#define ALT_USB1_GLOB_DIEPTXF15_ADDR ALT_USB_GLOB_DIEPTXF15_ADDR(ALT_USB1_GLOBGRP_ADDR)
4415
/* The base address byte offset for the start of the ALT_USB1_GLOBGRP component. */
4416
#define ALT_USB1_GLOBGRP_OFST 0x0
4417
/* The start address of the ALT_USB1_GLOBGRP component. */
4418
#define ALT_USB1_GLOBGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB1_ADDR) + ALT_USB1_GLOBGRP_OFST))
4419
/* The lower bound address range of the ALT_USB1_GLOBGRP component. */
4420
#define ALT_USB1_GLOBGRP_LB_ADDR ALT_USB1_GLOBGRP_ADDR
4421
/* The upper bound address range of the ALT_USB1_GLOBGRP component. */
4422
#define ALT_USB1_GLOBGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB1_GLOBGRP_ADDR) + 0x140) - 1))
4423
4424
4425
4426
* Register Group Instance : hostgrp
4427
4428
* Instance hostgrp of register group ALT_USB_HOST.
4429
4430
4431
4432
/* The address of the ALT_USB_HOST_HCFG register for the ALT_USB1_HOSTGRP instance. */
4433
#define ALT_USB1_HOST_HCFG_ADDR ALT_USB_HOST_HCFG_ADDR(ALT_USB1_HOSTGRP_ADDR)
4434
/* The address of the ALT_USB_HOST_HFIR register for the ALT_USB1_HOSTGRP instance. */
4435
#define ALT_USB1_HOST_HFIR_ADDR ALT_USB_HOST_HFIR_ADDR(ALT_USB1_HOSTGRP_ADDR)
4436
/* The address of the ALT_USB_HOST_HFNUM register for the ALT_USB1_HOSTGRP instance. */
4437
#define ALT_USB1_HOST_HFNUM_ADDR ALT_USB_HOST_HFNUM_ADDR(ALT_USB1_HOSTGRP_ADDR)
4438
/* The address of the ALT_USB_HOST_HPTXSTS register for the ALT_USB1_HOSTGRP instance. */
4439
#define ALT_USB1_HOST_HPTXSTS_ADDR ALT_USB_HOST_HPTXSTS_ADDR(ALT_USB1_HOSTGRP_ADDR)
4440
/* The address of the ALT_USB_HOST_HAINT register for the ALT_USB1_HOSTGRP instance. */
4441
#define ALT_USB1_HOST_HAINT_ADDR ALT_USB_HOST_HAINT_ADDR(ALT_USB1_HOSTGRP_ADDR)
4442
/* The address of the ALT_USB_HOST_HAINTMSK register for the ALT_USB1_HOSTGRP instance. */
4443
#define ALT_USB1_HOST_HAINTMSK_ADDR ALT_USB_HOST_HAINTMSK_ADDR(ALT_USB1_HOSTGRP_ADDR)
4444
/* The address of the ALT_USB_HOST_HFLBADDR register for the ALT_USB1_HOSTGRP instance. */
4445
#define ALT_USB1_HOST_HFLBADDR_ADDR ALT_USB_HOST_HFLBADDR_ADDR(ALT_USB1_HOSTGRP_ADDR)
4446
/* The address of the ALT_USB_HOST_HPRT register for the ALT_USB1_HOSTGRP instance. */
4447
#define ALT_USB1_HOST_HPRT_ADDR ALT_USB_HOST_HPRT_ADDR(ALT_USB1_HOSTGRP_ADDR)
4448
/* The address of the ALT_USB_HOST_HCCHAR0 register for the ALT_USB1_HOSTGRP instance. */
4449
#define ALT_USB1_HOST_HCCHAR0_ADDR ALT_USB_HOST_HCCHAR0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4450
/* The address of the ALT_USB_HOST_HCSPLT0 register for the ALT_USB1_HOSTGRP instance. */
4451
#define ALT_USB1_HOST_HCSPLT0_ADDR ALT_USB_HOST_HCSPLT0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4452
/* The address of the ALT_USB_HOST_HCINT0 register for the ALT_USB1_HOSTGRP instance. */
4453
#define ALT_USB1_HOST_HCINT0_ADDR ALT_USB_HOST_HCINT0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4454
/* The address of the ALT_USB_HOST_HCINTMSK0 register for the ALT_USB1_HOSTGRP instance. */
4455
#define ALT_USB1_HOST_HCINTMSK0_ADDR ALT_USB_HOST_HCINTMSK0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4456
/* The address of the ALT_USB_HOST_HCTSIZ0 register for the ALT_USB1_HOSTGRP instance. */
4457
#define ALT_USB1_HOST_HCTSIZ0_ADDR ALT_USB_HOST_HCTSIZ0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4458
/* The address of the ALT_USB_HOST_HCDMA0 register for the ALT_USB1_HOSTGRP instance. */
4459
#define ALT_USB1_HOST_HCDMA0_ADDR ALT_USB_HOST_HCDMA0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4460
/* The address of the ALT_USB_HOST_HCDMAB0 register for the ALT_USB1_HOSTGRP instance. */
4461
#define ALT_USB1_HOST_HCDMAB0_ADDR ALT_USB_HOST_HCDMAB0_ADDR(ALT_USB1_HOSTGRP_ADDR)
4462
/* The address of the ALT_USB_HOST_HCCHAR1 register for the ALT_USB1_HOSTGRP instance. */
4463
#define ALT_USB1_HOST_HCCHAR1_ADDR ALT_USB_HOST_HCCHAR1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4464
/* The address of the ALT_USB_HOST_HCSPLT1 register for the ALT_USB1_HOSTGRP instance. */
4465
#define ALT_USB1_HOST_HCSPLT1_ADDR ALT_USB_HOST_HCSPLT1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4466
/* The address of the ALT_USB_HOST_HCINT1 register for the ALT_USB1_HOSTGRP instance. */
4467
#define ALT_USB1_HOST_HCINT1_ADDR ALT_USB_HOST_HCINT1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4468
/* The address of the ALT_USB_HOST_HCINTMSK1 register for the ALT_USB1_HOSTGRP instance. */
4469
#define ALT_USB1_HOST_HCINTMSK1_ADDR ALT_USB_HOST_HCINTMSK1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4470
/* The address of the ALT_USB_HOST_HCTSIZ1 register for the ALT_USB1_HOSTGRP instance. */
4471
#define ALT_USB1_HOST_HCTSIZ1_ADDR ALT_USB_HOST_HCTSIZ1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4472
/* The address of the ALT_USB_HOST_HCDMA1 register for the ALT_USB1_HOSTGRP instance. */
4473
#define ALT_USB1_HOST_HCDMA1_ADDR ALT_USB_HOST_HCDMA1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4474
/* The address of the ALT_USB_HOST_HCDMAB1 register for the ALT_USB1_HOSTGRP instance. */
4475
#define ALT_USB1_HOST_HCDMAB1_ADDR ALT_USB_HOST_HCDMAB1_ADDR(ALT_USB1_HOSTGRP_ADDR)
4476
/* The address of the ALT_USB_HOST_HCCHAR2 register for the ALT_USB1_HOSTGRP instance. */
4477
#define ALT_USB1_HOST_HCCHAR2_ADDR ALT_USB_HOST_HCCHAR2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4478
/* The address of the ALT_USB_HOST_HCSPLT2 register for the ALT_USB1_HOSTGRP instance. */
4479
#define ALT_USB1_HOST_HCSPLT2_ADDR ALT_USB_HOST_HCSPLT2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4480
/* The address of the ALT_USB_HOST_HCINT2 register for the ALT_USB1_HOSTGRP instance. */
4481
#define ALT_USB1_HOST_HCINT2_ADDR ALT_USB_HOST_HCINT2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4482
/* The address of the ALT_USB_HOST_HCINTMSK2 register for the ALT_USB1_HOSTGRP instance. */
4483
#define ALT_USB1_HOST_HCINTMSK2_ADDR ALT_USB_HOST_HCINTMSK2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4484
/* The address of the ALT_USB_HOST_HCTSIZ2 register for the ALT_USB1_HOSTGRP instance. */
4485
#define ALT_USB1_HOST_HCTSIZ2_ADDR ALT_USB_HOST_HCTSIZ2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4486
/* The address of the ALT_USB_HOST_HCDMA2 register for the ALT_USB1_HOSTGRP instance. */
4487
#define ALT_USB1_HOST_HCDMA2_ADDR ALT_USB_HOST_HCDMA2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4488
/* The address of the ALT_USB_HOST_HCDMAB2 register for the ALT_USB1_HOSTGRP instance. */
4489
#define ALT_USB1_HOST_HCDMAB2_ADDR ALT_USB_HOST_HCDMAB2_ADDR(ALT_USB1_HOSTGRP_ADDR)
4490
/* The address of the ALT_USB_HOST_HCCHAR3 register for the ALT_USB1_HOSTGRP instance. */
4491
#define ALT_USB1_HOST_HCCHAR3_ADDR ALT_USB_HOST_HCCHAR3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4492
/* The address of the ALT_USB_HOST_HCSPLT3 register for the ALT_USB1_HOSTGRP instance. */
4493
#define ALT_USB1_HOST_HCSPLT3_ADDR ALT_USB_HOST_HCSPLT3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4494
/* The address of the ALT_USB_HOST_HCINT3 register for the ALT_USB1_HOSTGRP instance. */
4495
#define ALT_USB1_HOST_HCINT3_ADDR ALT_USB_HOST_HCINT3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4496
/* The address of the ALT_USB_HOST_HCINTMSK3 register for the ALT_USB1_HOSTGRP instance. */
4497
#define ALT_USB1_HOST_HCINTMSK3_ADDR ALT_USB_HOST_HCINTMSK3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4498
/* The address of the ALT_USB_HOST_HCTSIZ3 register for the ALT_USB1_HOSTGRP instance. */
4499
#define ALT_USB1_HOST_HCTSIZ3_ADDR ALT_USB_HOST_HCTSIZ3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4500
/* The address of the ALT_USB_HOST_HCDMA3 register for the ALT_USB1_HOSTGRP instance. */
4501
#define ALT_USB1_HOST_HCDMA3_ADDR ALT_USB_HOST_HCDMA3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4502
/* The address of the ALT_USB_HOST_HCDMAB3 register for the ALT_USB1_HOSTGRP instance. */
4503
#define ALT_USB1_HOST_HCDMAB3_ADDR ALT_USB_HOST_HCDMAB3_ADDR(ALT_USB1_HOSTGRP_ADDR)
4504
/* The address of the ALT_USB_HOST_HCCHAR4 register for the ALT_USB1_HOSTGRP instance. */
4505
#define ALT_USB1_HOST_HCCHAR4_ADDR ALT_USB_HOST_HCCHAR4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4506
/* The address of the ALT_USB_HOST_HCSPLT4 register for the ALT_USB1_HOSTGRP instance. */
4507
#define ALT_USB1_HOST_HCSPLT4_ADDR ALT_USB_HOST_HCSPLT4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4508
/* The address of the ALT_USB_HOST_HCINT4 register for the ALT_USB1_HOSTGRP instance. */
4509
#define ALT_USB1_HOST_HCINT4_ADDR ALT_USB_HOST_HCINT4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4510
/* The address of the ALT_USB_HOST_HCINTMSK4 register for the ALT_USB1_HOSTGRP instance. */
4511
#define ALT_USB1_HOST_HCINTMSK4_ADDR ALT_USB_HOST_HCINTMSK4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4512
/* The address of the ALT_USB_HOST_HCTSIZ4 register for the ALT_USB1_HOSTGRP instance. */
4513
#define ALT_USB1_HOST_HCTSIZ4_ADDR ALT_USB_HOST_HCTSIZ4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4514
/* The address of the ALT_USB_HOST_HCDMA4 register for the ALT_USB1_HOSTGRP instance. */
4515
#define ALT_USB1_HOST_HCDMA4_ADDR ALT_USB_HOST_HCDMA4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4516
/* The address of the ALT_USB_HOST_HCDMAB4 register for the ALT_USB1_HOSTGRP instance. */
4517
#define ALT_USB1_HOST_HCDMAB4_ADDR ALT_USB_HOST_HCDMAB4_ADDR(ALT_USB1_HOSTGRP_ADDR)
4518
/* The address of the ALT_USB_HOST_HCCHAR5 register for the ALT_USB1_HOSTGRP instance. */
4519
#define ALT_USB1_HOST_HCCHAR5_ADDR ALT_USB_HOST_HCCHAR5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4520
/* The address of the ALT_USB_HOST_HCSPLT5 register for the ALT_USB1_HOSTGRP instance. */
4521
#define ALT_USB1_HOST_HCSPLT5_ADDR ALT_USB_HOST_HCSPLT5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4522
/* The address of the ALT_USB_HOST_HCINT5 register for the ALT_USB1_HOSTGRP instance. */
4523
#define ALT_USB1_HOST_HCINT5_ADDR ALT_USB_HOST_HCINT5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4524
/* The address of the ALT_USB_HOST_HCINTMSK5 register for the ALT_USB1_HOSTGRP instance. */
4525
#define ALT_USB1_HOST_HCINTMSK5_ADDR ALT_USB_HOST_HCINTMSK5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4526
/* The address of the ALT_USB_HOST_HCTSIZ5 register for the ALT_USB1_HOSTGRP instance. */
4527
#define ALT_USB1_HOST_HCTSIZ5_ADDR ALT_USB_HOST_HCTSIZ5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4528
/* The address of the ALT_USB_HOST_HCDMA5 register for the ALT_USB1_HOSTGRP instance. */
4529
#define ALT_USB1_HOST_HCDMA5_ADDR ALT_USB_HOST_HCDMA5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4530
/* The address of the ALT_USB_HOST_HCDMAB5 register for the ALT_USB1_HOSTGRP instance. */
4531
#define ALT_USB1_HOST_HCDMAB5_ADDR ALT_USB_HOST_HCDMAB5_ADDR(ALT_USB1_HOSTGRP_ADDR)
4532
/* The address of the ALT_USB_HOST_HCCHAR6 register for the ALT_USB1_HOSTGRP instance. */
4533
#define ALT_USB1_HOST_HCCHAR6_ADDR ALT_USB_HOST_HCCHAR6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4534
/* The address of the ALT_USB_HOST_HCSPLT6 register for the ALT_USB1_HOSTGRP instance. */
4535
#define ALT_USB1_HOST_HCSPLT6_ADDR ALT_USB_HOST_HCSPLT6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4536
/* The address of the ALT_USB_HOST_HCINT6 register for the ALT_USB1_HOSTGRP instance. */
4537
#define ALT_USB1_HOST_HCINT6_ADDR ALT_USB_HOST_HCINT6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4538
/* The address of the ALT_USB_HOST_HCINTMSK6 register for the ALT_USB1_HOSTGRP instance. */
4539
#define ALT_USB1_HOST_HCINTMSK6_ADDR ALT_USB_HOST_HCINTMSK6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4540
/* The address of the ALT_USB_HOST_HCTSIZ6 register for the ALT_USB1_HOSTGRP instance. */
4541
#define ALT_USB1_HOST_HCTSIZ6_ADDR ALT_USB_HOST_HCTSIZ6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4542
/* The address of the ALT_USB_HOST_HCDMA6 register for the ALT_USB1_HOSTGRP instance. */
4543
#define ALT_USB1_HOST_HCDMA6_ADDR ALT_USB_HOST_HCDMA6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4544
/* The address of the ALT_USB_HOST_HCDMAB6 register for the ALT_USB1_HOSTGRP instance. */
4545
#define ALT_USB1_HOST_HCDMAB6_ADDR ALT_USB_HOST_HCDMAB6_ADDR(ALT_USB1_HOSTGRP_ADDR)
4546
/* The address of the ALT_USB_HOST_HCCHAR7 register for the ALT_USB1_HOSTGRP instance. */
4547
#define ALT_USB1_HOST_HCCHAR7_ADDR ALT_USB_HOST_HCCHAR7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4548
/* The address of the ALT_USB_HOST_HCSPLT7 register for the ALT_USB1_HOSTGRP instance. */
4549
#define ALT_USB1_HOST_HCSPLT7_ADDR ALT_USB_HOST_HCSPLT7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4550
/* The address of the ALT_USB_HOST_HCINT7 register for the ALT_USB1_HOSTGRP instance. */
4551
#define ALT_USB1_HOST_HCINT7_ADDR ALT_USB_HOST_HCINT7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4552
/* The address of the ALT_USB_HOST_HCINTMSK7 register for the ALT_USB1_HOSTGRP instance. */
4553
#define ALT_USB1_HOST_HCINTMSK7_ADDR ALT_USB_HOST_HCINTMSK7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4554
/* The address of the ALT_USB_HOST_HCTSIZ7 register for the ALT_USB1_HOSTGRP instance. */
4555
#define ALT_USB1_HOST_HCTSIZ7_ADDR ALT_USB_HOST_HCTSIZ7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4556
/* The address of the ALT_USB_HOST_HCDMA7 register for the ALT_USB1_HOSTGRP instance. */
4557
#define ALT_USB1_HOST_HCDMA7_ADDR ALT_USB_HOST_HCDMA7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4558
/* The address of the ALT_USB_HOST_HCDMAB7 register for the ALT_USB1_HOSTGRP instance. */
4559
#define ALT_USB1_HOST_HCDMAB7_ADDR ALT_USB_HOST_HCDMAB7_ADDR(ALT_USB1_HOSTGRP_ADDR)
4560
/* The address of the ALT_USB_HOST_HCCHAR8 register for the ALT_USB1_HOSTGRP instance. */
4561
#define ALT_USB1_HOST_HCCHAR8_ADDR ALT_USB_HOST_HCCHAR8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4562
/* The address of the ALT_USB_HOST_HCSPLT8 register for the ALT_USB1_HOSTGRP instance. */
4563
#define ALT_USB1_HOST_HCSPLT8_ADDR ALT_USB_HOST_HCSPLT8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4564
/* The address of the ALT_USB_HOST_HCINT8 register for the ALT_USB1_HOSTGRP instance. */
4565
#define ALT_USB1_HOST_HCINT8_ADDR ALT_USB_HOST_HCINT8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4566
/* The address of the ALT_USB_HOST_HCINTMSK8 register for the ALT_USB1_HOSTGRP instance. */
4567
#define ALT_USB1_HOST_HCINTMSK8_ADDR ALT_USB_HOST_HCINTMSK8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4568
/* The address of the ALT_USB_HOST_HCTSIZ8 register for the ALT_USB1_HOSTGRP instance. */
4569
#define ALT_USB1_HOST_HCTSIZ8_ADDR ALT_USB_HOST_HCTSIZ8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4570
/* The address of the ALT_USB_HOST_HCDMA8 register for the ALT_USB1_HOSTGRP instance. */
4571
#define ALT_USB1_HOST_HCDMA8_ADDR ALT_USB_HOST_HCDMA8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4572
/* The address of the ALT_USB_HOST_HCDMAB8 register for the ALT_USB1_HOSTGRP instance. */
4573
#define ALT_USB1_HOST_HCDMAB8_ADDR ALT_USB_HOST_HCDMAB8_ADDR(ALT_USB1_HOSTGRP_ADDR)
4574
/* The address of the ALT_USB_HOST_HCCHAR9 register for the ALT_USB1_HOSTGRP instance. */
4575
#define ALT_USB1_HOST_HCCHAR9_ADDR ALT_USB_HOST_HCCHAR9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4576
/* The address of the ALT_USB_HOST_HCSPLT9 register for the ALT_USB1_HOSTGRP instance. */
4577
#define ALT_USB1_HOST_HCSPLT9_ADDR ALT_USB_HOST_HCSPLT9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4578
/* The address of the ALT_USB_HOST_HCINT9 register for the ALT_USB1_HOSTGRP instance. */
4579
#define ALT_USB1_HOST_HCINT9_ADDR ALT_USB_HOST_HCINT9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4580
/* The address of the ALT_USB_HOST_HCINTMSK9 register for the ALT_USB1_HOSTGRP instance. */
4581
#define ALT_USB1_HOST_HCINTMSK9_ADDR ALT_USB_HOST_HCINTMSK9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4582
/* The address of the ALT_USB_HOST_HCTSIZ9 register for the ALT_USB1_HOSTGRP instance. */
4583
#define ALT_USB1_HOST_HCTSIZ9_ADDR ALT_USB_HOST_HCTSIZ9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4584
/* The address of the ALT_USB_HOST_HCDMA9 register for the ALT_USB1_HOSTGRP instance. */
4585
#define ALT_USB1_HOST_HCDMA9_ADDR ALT_USB_HOST_HCDMA9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4586
/* The address of the ALT_USB_HOST_HCDMAB9 register for the ALT_USB1_HOSTGRP instance. */
4587
#define ALT_USB1_HOST_HCDMAB9_ADDR ALT_USB_HOST_HCDMAB9_ADDR(ALT_USB1_HOSTGRP_ADDR)
4588
/* The address of the ALT_USB_HOST_HCCHAR10 register for the ALT_USB1_HOSTGRP instance. */
4589
#define ALT_USB1_HOST_HCCHAR10_ADDR ALT_USB_HOST_HCCHAR10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4590
/* The address of the ALT_USB_HOST_HCSPLT10 register for the ALT_USB1_HOSTGRP instance. */
4591
#define ALT_USB1_HOST_HCSPLT10_ADDR ALT_USB_HOST_HCSPLT10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4592
/* The address of the ALT_USB_HOST_HCINT10 register for the ALT_USB1_HOSTGRP instance. */
4593
#define ALT_USB1_HOST_HCINT10_ADDR ALT_USB_HOST_HCINT10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4594
/* The address of the ALT_USB_HOST_HCINTMSK10 register for the ALT_USB1_HOSTGRP instance. */
4595
#define ALT_USB1_HOST_HCINTMSK10_ADDR ALT_USB_HOST_HCINTMSK10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4596
/* The address of the ALT_USB_HOST_HCTSIZ10 register for the ALT_USB1_HOSTGRP instance. */
4597
#define ALT_USB1_HOST_HCTSIZ10_ADDR ALT_USB_HOST_HCTSIZ10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4598
/* The address of the ALT_USB_HOST_HCDMA10 register for the ALT_USB1_HOSTGRP instance. */
4599
#define ALT_USB1_HOST_HCDMA10_ADDR ALT_USB_HOST_HCDMA10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4600
/* The address of the ALT_USB_HOST_HCDMAB10 register for the ALT_USB1_HOSTGRP instance. */
4601
#define ALT_USB1_HOST_HCDMAB10_ADDR ALT_USB_HOST_HCDMAB10_ADDR(ALT_USB1_HOSTGRP_ADDR)
4602
/* The address of the ALT_USB_HOST_HCCHAR11 register for the ALT_USB1_HOSTGRP instance. */
4603
#define ALT_USB1_HOST_HCCHAR11_ADDR ALT_USB_HOST_HCCHAR11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4604
/* The address of the ALT_USB_HOST_HCSPLT11 register for the ALT_USB1_HOSTGRP instance. */
4605
#define ALT_USB1_HOST_HCSPLT11_ADDR ALT_USB_HOST_HCSPLT11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4606
/* The address of the ALT_USB_HOST_HCINT11 register for the ALT_USB1_HOSTGRP instance. */
4607
#define ALT_USB1_HOST_HCINT11_ADDR ALT_USB_HOST_HCINT11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4608
/* The address of the ALT_USB_HOST_HCINTMSK11 register for the ALT_USB1_HOSTGRP instance. */
4609
#define ALT_USB1_HOST_HCINTMSK11_ADDR ALT_USB_HOST_HCINTMSK11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4610
/* The address of the ALT_USB_HOST_HCTSIZ11 register for the ALT_USB1_HOSTGRP instance. */
4611
#define ALT_USB1_HOST_HCTSIZ11_ADDR ALT_USB_HOST_HCTSIZ11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4612
/* The address of the ALT_USB_HOST_HCDMA11 register for the ALT_USB1_HOSTGRP instance. */
4613
#define ALT_USB1_HOST_HCDMA11_ADDR ALT_USB_HOST_HCDMA11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4614
/* The address of the ALT_USB_HOST_HCDMAB11 register for the ALT_USB1_HOSTGRP instance. */
4615
#define ALT_USB1_HOST_HCDMAB11_ADDR ALT_USB_HOST_HCDMAB11_ADDR(ALT_USB1_HOSTGRP_ADDR)
4616
/* The address of the ALT_USB_HOST_HCCHAR12 register for the ALT_USB1_HOSTGRP instance. */
4617
#define ALT_USB1_HOST_HCCHAR12_ADDR ALT_USB_HOST_HCCHAR12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4618
/* The address of the ALT_USB_HOST_HCSPLT12 register for the ALT_USB1_HOSTGRP instance. */
4619
#define ALT_USB1_HOST_HCSPLT12_ADDR ALT_USB_HOST_HCSPLT12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4620
/* The address of the ALT_USB_HOST_HCINT12 register for the ALT_USB1_HOSTGRP instance. */
4621
#define ALT_USB1_HOST_HCINT12_ADDR ALT_USB_HOST_HCINT12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4622
/* The address of the ALT_USB_HOST_HCINTMSK12 register for the ALT_USB1_HOSTGRP instance. */
4623
#define ALT_USB1_HOST_HCINTMSK12_ADDR ALT_USB_HOST_HCINTMSK12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4624
/* The address of the ALT_USB_HOST_HCTSIZ12 register for the ALT_USB1_HOSTGRP instance. */
4625
#define ALT_USB1_HOST_HCTSIZ12_ADDR ALT_USB_HOST_HCTSIZ12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4626
/* The address of the ALT_USB_HOST_HCDMA12 register for the ALT_USB1_HOSTGRP instance. */
4627
#define ALT_USB1_HOST_HCDMA12_ADDR ALT_USB_HOST_HCDMA12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4628
/* The address of the ALT_USB_HOST_HCDMAB12 register for the ALT_USB1_HOSTGRP instance. */
4629
#define ALT_USB1_HOST_HCDMAB12_ADDR ALT_USB_HOST_HCDMAB12_ADDR(ALT_USB1_HOSTGRP_ADDR)
4630
/* The address of the ALT_USB_HOST_HCCHAR13 register for the ALT_USB1_HOSTGRP instance. */
4631
#define ALT_USB1_HOST_HCCHAR13_ADDR ALT_USB_HOST_HCCHAR13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4632
/* The address of the ALT_USB_HOST_HCSPLT13 register for the ALT_USB1_HOSTGRP instance. */
4633
#define ALT_USB1_HOST_HCSPLT13_ADDR ALT_USB_HOST_HCSPLT13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4634
/* The address of the ALT_USB_HOST_HCINT13 register for the ALT_USB1_HOSTGRP instance. */
4635
#define ALT_USB1_HOST_HCINT13_ADDR ALT_USB_HOST_HCINT13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4636
/* The address of the ALT_USB_HOST_HCINTMSK13 register for the ALT_USB1_HOSTGRP instance. */
4637
#define ALT_USB1_HOST_HCINTMSK13_ADDR ALT_USB_HOST_HCINTMSK13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4638
/* The address of the ALT_USB_HOST_HCTSIZ13 register for the ALT_USB1_HOSTGRP instance. */
4639
#define ALT_USB1_HOST_HCTSIZ13_ADDR ALT_USB_HOST_HCTSIZ13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4640
/* The address of the ALT_USB_HOST_HCDMA13 register for the ALT_USB1_HOSTGRP instance. */
4641
#define ALT_USB1_HOST_HCDMA13_ADDR ALT_USB_HOST_HCDMA13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4642
/* The address of the ALT_USB_HOST_HCDMAB13 register for the ALT_USB1_HOSTGRP instance. */
4643
#define ALT_USB1_HOST_HCDMAB13_ADDR ALT_USB_HOST_HCDMAB13_ADDR(ALT_USB1_HOSTGRP_ADDR)
4644
/* The address of the ALT_USB_HOST_HCCHAR14 register for the ALT_USB1_HOSTGRP instance. */
4645
#define ALT_USB1_HOST_HCCHAR14_ADDR ALT_USB_HOST_HCCHAR14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4646
/* The address of the ALT_USB_HOST_HCSPLT14 register for the ALT_USB1_HOSTGRP instance. */
4647
#define ALT_USB1_HOST_HCSPLT14_ADDR ALT_USB_HOST_HCSPLT14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4648
/* The address of the ALT_USB_HOST_HCINT14 register for the ALT_USB1_HOSTGRP instance. */
4649
#define ALT_USB1_HOST_HCINT14_ADDR ALT_USB_HOST_HCINT14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4650
/* The address of the ALT_USB_HOST_HCINTMSK14 register for the ALT_USB1_HOSTGRP instance. */
4651
#define ALT_USB1_HOST_HCINTMSK14_ADDR ALT_USB_HOST_HCINTMSK14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4652
/* The address of the ALT_USB_HOST_HCTSIZ14 register for the ALT_USB1_HOSTGRP instance. */
4653
#define ALT_USB1_HOST_HCTSIZ14_ADDR ALT_USB_HOST_HCTSIZ14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4654
/* The address of the ALT_USB_HOST_HCDMA14 register for the ALT_USB1_HOSTGRP instance. */
4655
#define ALT_USB1_HOST_HCDMA14_ADDR ALT_USB_HOST_HCDMA14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4656
/* The address of the ALT_USB_HOST_HCDMAB14 register for the ALT_USB1_HOSTGRP instance. */
4657
#define ALT_USB1_HOST_HCDMAB14_ADDR ALT_USB_HOST_HCDMAB14_ADDR(ALT_USB1_HOSTGRP_ADDR)
4658
/* The address of the ALT_USB_HOST_HCCHAR15 register for the ALT_USB1_HOSTGRP instance. */
4659
#define ALT_USB1_HOST_HCCHAR15_ADDR ALT_USB_HOST_HCCHAR15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4660
/* The address of the ALT_USB_HOST_HCSPLT15 register for the ALT_USB1_HOSTGRP instance. */
4661
#define ALT_USB1_HOST_HCSPLT15_ADDR ALT_USB_HOST_HCSPLT15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4662
/* The address of the ALT_USB_HOST_HCINT15 register for the ALT_USB1_HOSTGRP instance. */
4663
#define ALT_USB1_HOST_HCINT15_ADDR ALT_USB_HOST_HCINT15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4664
/* The address of the ALT_USB_HOST_HCINTMSK15 register for the ALT_USB1_HOSTGRP instance. */
4665
#define ALT_USB1_HOST_HCINTMSK15_ADDR ALT_USB_HOST_HCINTMSK15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4666
/* The address of the ALT_USB_HOST_HCTSIZ15 register for the ALT_USB1_HOSTGRP instance. */
4667
#define ALT_USB1_HOST_HCTSIZ15_ADDR ALT_USB_HOST_HCTSIZ15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4668
/* The address of the ALT_USB_HOST_HCDMA15 register for the ALT_USB1_HOSTGRP instance. */
4669
#define ALT_USB1_HOST_HCDMA15_ADDR ALT_USB_HOST_HCDMA15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4670
/* The address of the ALT_USB_HOST_HCDMAB15 register for the ALT_USB1_HOSTGRP instance. */
4671
#define ALT_USB1_HOST_HCDMAB15_ADDR ALT_USB_HOST_HCDMAB15_ADDR(ALT_USB1_HOSTGRP_ADDR)
4672
/* The base address byte offset for the start of the ALT_USB1_HOSTGRP component. */
4673
#define ALT_USB1_HOSTGRP_OFST 0x400
4674
/* The start address of the ALT_USB1_HOSTGRP component. */
4675
#define ALT_USB1_HOSTGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB1_ADDR) + ALT_USB1_HOSTGRP_OFST))
4676
/* The lower bound address range of the ALT_USB1_HOSTGRP component. */
4677
#define ALT_USB1_HOSTGRP_LB_ADDR ALT_USB1_HOSTGRP_ADDR
4678
/* The upper bound address range of the ALT_USB1_HOSTGRP component. */
4679
#define ALT_USB1_HOSTGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB1_HOSTGRP_ADDR) + 0x2fc) - 1))
4680
4681
4682
4683
* Register Group Instance : devgrp
4684
4685
* Instance devgrp of register group ALT_USB_DEV.
4686
4687
4688
4689
/* The address of the ALT_USB_DEV_DCFG register for the ALT_USB1_DEVGRP instance. */
4690
#define ALT_USB1_DEV_DCFG_ADDR ALT_USB_DEV_DCFG_ADDR(ALT_USB1_DEVGRP_ADDR)
4691
/* The address of the ALT_USB_DEV_DCTL register for the ALT_USB1_DEVGRP instance. */
4692
#define ALT_USB1_DEV_DCTL_ADDR ALT_USB_DEV_DCTL_ADDR(ALT_USB1_DEVGRP_ADDR)
4693
/* The address of the ALT_USB_DEV_DSTS register for the ALT_USB1_DEVGRP instance. */
4694
#define ALT_USB1_DEV_DSTS_ADDR ALT_USB_DEV_DSTS_ADDR(ALT_USB1_DEVGRP_ADDR)
4695
/* The address of the ALT_USB_DEV_DIEPMSK register for the ALT_USB1_DEVGRP instance. */
4696
#define ALT_USB1_DEV_DIEPMSK_ADDR ALT_USB_DEV_DIEPMSK_ADDR(ALT_USB1_DEVGRP_ADDR)
4697
/* The address of the ALT_USB_DEV_DOEPMSK register for the ALT_USB1_DEVGRP instance. */
4698
#define ALT_USB1_DEV_DOEPMSK_ADDR ALT_USB_DEV_DOEPMSK_ADDR(ALT_USB1_DEVGRP_ADDR)
4699
/* The address of the ALT_USB_DEV_DAINT register for the ALT_USB1_DEVGRP instance. */
4700
#define ALT_USB1_DEV_DAINT_ADDR ALT_USB_DEV_DAINT_ADDR(ALT_USB1_DEVGRP_ADDR)
4701
/* The address of the ALT_USB_DEV_DAINTMSK register for the ALT_USB1_DEVGRP instance. */
4702
#define ALT_USB1_DEV_DAINTMSK_ADDR ALT_USB_DEV_DAINTMSK_ADDR(ALT_USB1_DEVGRP_ADDR)
4703
/* The address of the ALT_USB_DEV_DVBUSDIS register for the ALT_USB1_DEVGRP instance. */
4704
#define ALT_USB1_DEV_DVBUSDIS_ADDR ALT_USB_DEV_DVBUSDIS_ADDR(ALT_USB1_DEVGRP_ADDR)
4705
/* The address of the ALT_USB_DEV_DVBUSPULSE register for the ALT_USB1_DEVGRP instance. */
4706
#define ALT_USB1_DEV_DVBUSPULSE_ADDR ALT_USB_DEV_DVBUSPULSE_ADDR(ALT_USB1_DEVGRP_ADDR)
4707
/* The address of the ALT_USB_DEV_DTHRCTL register for the ALT_USB1_DEVGRP instance. */
4708
#define ALT_USB1_DEV_DTHRCTL_ADDR ALT_USB_DEV_DTHRCTL_ADDR(ALT_USB1_DEVGRP_ADDR)
4709
/* The address of the ALT_USB_DEV_DIEPEMPMSK register for the ALT_USB1_DEVGRP instance. */
4710
#define ALT_USB1_DEV_DIEPEMPMSK_ADDR ALT_USB_DEV_DIEPEMPMSK_ADDR(ALT_USB1_DEVGRP_ADDR)
4711
/* The address of the ALT_USB_DEV_DIEPCTL0 register for the ALT_USB1_DEVGRP instance. */
4712
#define ALT_USB1_DEV_DIEPCTL0_ADDR ALT_USB_DEV_DIEPCTL0_ADDR(ALT_USB1_DEVGRP_ADDR)
4713
/* The address of the ALT_USB_DEV_DIEPINT0 register for the ALT_USB1_DEVGRP instance. */
4714
#define ALT_USB1_DEV_DIEPINT0_ADDR ALT_USB_DEV_DIEPINT0_ADDR(ALT_USB1_DEVGRP_ADDR)
4715
/* The address of the ALT_USB_DEV_DIEPTSIZ0 register for the ALT_USB1_DEVGRP instance. */
4716
#define ALT_USB1_DEV_DIEPTSIZ0_ADDR ALT_USB_DEV_DIEPTSIZ0_ADDR(ALT_USB1_DEVGRP_ADDR)
4717
/* The address of the ALT_USB_DEV_DIEPDMA0 register for the ALT_USB1_DEVGRP instance. */
4718
#define ALT_USB1_DEV_DIEPDMA0_ADDR ALT_USB_DEV_DIEPDMA0_ADDR(ALT_USB1_DEVGRP_ADDR)
4719
/* The address of the ALT_USB_DEV_DTXFSTS0 register for the ALT_USB1_DEVGRP instance. */
4720
#define ALT_USB1_DEV_DTXFSTS0_ADDR ALT_USB_DEV_DTXFSTS0_ADDR(ALT_USB1_DEVGRP_ADDR)
4721
/* The address of the ALT_USB_DEV_DIEPDMAB0 register for the ALT_USB1_DEVGRP instance. */
4722
#define ALT_USB1_DEV_DIEPDMAB0_ADDR ALT_USB_DEV_DIEPDMAB0_ADDR(ALT_USB1_DEVGRP_ADDR)
4723
/* The address of the ALT_USB_DEV_DIEPCTL1 register for the ALT_USB1_DEVGRP instance. */
4724
#define ALT_USB1_DEV_DIEPCTL1_ADDR ALT_USB_DEV_DIEPCTL1_ADDR(ALT_USB1_DEVGRP_ADDR)
4725
/* The address of the ALT_USB_DEV_DIEPINT1 register for the ALT_USB1_DEVGRP instance. */
4726
#define ALT_USB1_DEV_DIEPINT1_ADDR ALT_USB_DEV_DIEPINT1_ADDR(ALT_USB1_DEVGRP_ADDR)
4727
/* The address of the ALT_USB_DEV_DIEPTSIZ1 register for the ALT_USB1_DEVGRP instance. */
4728
#define ALT_USB1_DEV_DIEPTSIZ1_ADDR ALT_USB_DEV_DIEPTSIZ1_ADDR(ALT_USB1_DEVGRP_ADDR)
4729
/* The address of the ALT_USB_DEV_DIEPDMA1 register for the ALT_USB1_DEVGRP instance. */
4730
#define ALT_USB1_DEV_DIEPDMA1_ADDR ALT_USB_DEV_DIEPDMA1_ADDR(ALT_USB1_DEVGRP_ADDR)
4731
/* The address of the ALT_USB_DEV_DTXFSTS1 register for the ALT_USB1_DEVGRP instance. */
4732
#define ALT_USB1_DEV_DTXFSTS1_ADDR ALT_USB_DEV_DTXFSTS1_ADDR(ALT_USB1_DEVGRP_ADDR)
4733
/* The address of the ALT_USB_DEV_DIEPDMAB1 register for the ALT_USB1_DEVGRP instance. */
4734
#define ALT_USB1_DEV_DIEPDMAB1_ADDR ALT_USB_DEV_DIEPDMAB1_ADDR(ALT_USB1_DEVGRP_ADDR)
4735
/* The address of the ALT_USB_DEV_DIEPCTL2 register for the ALT_USB1_DEVGRP instance. */
4736
#define ALT_USB1_DEV_DIEPCTL2_ADDR ALT_USB_DEV_DIEPCTL2_ADDR(ALT_USB1_DEVGRP_ADDR)
4737
/* The address of the ALT_USB_DEV_DIEPINT2 register for the ALT_USB1_DEVGRP instance. */
4738
#define ALT_USB1_DEV_DIEPINT2_ADDR ALT_USB_DEV_DIEPINT2_ADDR(ALT_USB1_DEVGRP_ADDR)
4739
/* The address of the ALT_USB_DEV_DIEPTSIZ2 register for the ALT_USB1_DEVGRP instance. */
4740
#define ALT_USB1_DEV_DIEPTSIZ2_ADDR ALT_USB_DEV_DIEPTSIZ2_ADDR(ALT_USB1_DEVGRP_ADDR)
4741
/* The address of the ALT_USB_DEV_DIEPDMA2 register for the ALT_USB1_DEVGRP instance. */
4742
#define ALT_USB1_DEV_DIEPDMA2_ADDR ALT_USB_DEV_DIEPDMA2_ADDR(ALT_USB1_DEVGRP_ADDR)
4743
/* The address of the ALT_USB_DEV_DTXFSTS2 register for the ALT_USB1_DEVGRP instance. */
4744
#define ALT_USB1_DEV_DTXFSTS2_ADDR ALT_USB_DEV_DTXFSTS2_ADDR(ALT_USB1_DEVGRP_ADDR)
4745
/* The address of the ALT_USB_DEV_DIEPDMAB2 register for the ALT_USB1_DEVGRP instance. */
4746
#define ALT_USB1_DEV_DIEPDMAB2_ADDR ALT_USB_DEV_DIEPDMAB2_ADDR(ALT_USB1_DEVGRP_ADDR)
4747
/* The address of the ALT_USB_DEV_DIEPCTL3 register for the ALT_USB1_DEVGRP instance. */
4748
#define ALT_USB1_DEV_DIEPCTL3_ADDR ALT_USB_DEV_DIEPCTL3_ADDR(ALT_USB1_DEVGRP_ADDR)
4749
/* The address of the ALT_USB_DEV_DIEPINT3 register for the ALT_USB1_DEVGRP instance. */
4750
#define ALT_USB1_DEV_DIEPINT3_ADDR ALT_USB_DEV_DIEPINT3_ADDR(ALT_USB1_DEVGRP_ADDR)
4751
/* The address of the ALT_USB_DEV_DIEPTSIZ3 register for the ALT_USB1_DEVGRP instance. */
4752
#define ALT_USB1_DEV_DIEPTSIZ3_ADDR ALT_USB_DEV_DIEPTSIZ3_ADDR(ALT_USB1_DEVGRP_ADDR)
4753
/* The address of the ALT_USB_DEV_DIEPDMA3 register for the ALT_USB1_DEVGRP instance. */
4754
#define ALT_USB1_DEV_DIEPDMA3_ADDR ALT_USB_DEV_DIEPDMA3_ADDR(ALT_USB1_DEVGRP_ADDR)
4755
/* The address of the ALT_USB_DEV_DTXFSTS3 register for the ALT_USB1_DEVGRP instance. */
4756
#define ALT_USB1_DEV_DTXFSTS3_ADDR ALT_USB_DEV_DTXFSTS3_ADDR(ALT_USB1_DEVGRP_ADDR)
4757
/* The address of the ALT_USB_DEV_DIEPDMAB3 register for the ALT_USB1_DEVGRP instance. */
4758
#define ALT_USB1_DEV_DIEPDMAB3_ADDR ALT_USB_DEV_DIEPDMAB3_ADDR(ALT_USB1_DEVGRP_ADDR)
4759
/* The address of the ALT_USB_DEV_DIEPCTL4 register for the ALT_USB1_DEVGRP instance. */
4760
#define ALT_USB1_DEV_DIEPCTL4_ADDR ALT_USB_DEV_DIEPCTL4_ADDR(ALT_USB1_DEVGRP_ADDR)
4761
/* The address of the ALT_USB_DEV_DIEPINT4 register for the ALT_USB1_DEVGRP instance. */
4762
#define ALT_USB1_DEV_DIEPINT4_ADDR ALT_USB_DEV_DIEPINT4_ADDR(ALT_USB1_DEVGRP_ADDR)
4763
/* The address of the ALT_USB_DEV_DIEPTSIZ4 register for the ALT_USB1_DEVGRP instance. */
4764
#define ALT_USB1_DEV_DIEPTSIZ4_ADDR ALT_USB_DEV_DIEPTSIZ4_ADDR(ALT_USB1_DEVGRP_ADDR)
4765
/* The address of the ALT_USB_DEV_DIEPDMA4 register for the ALT_USB1_DEVGRP instance. */
4766
#define ALT_USB1_DEV_DIEPDMA4_ADDR ALT_USB_DEV_DIEPDMA4_ADDR(ALT_USB1_DEVGRP_ADDR)
4767
/* The address of the ALT_USB_DEV_DTXFSTS4 register for the ALT_USB1_DEVGRP instance. */
4768
#define ALT_USB1_DEV_DTXFSTS4_ADDR ALT_USB_DEV_DTXFSTS4_ADDR(ALT_USB1_DEVGRP_ADDR)
4769
/* The address of the ALT_USB_DEV_DIEPDMAB4 register for the ALT_USB1_DEVGRP instance. */
4770
#define ALT_USB1_DEV_DIEPDMAB4_ADDR ALT_USB_DEV_DIEPDMAB4_ADDR(ALT_USB1_DEVGRP_ADDR)
4771
/* The address of the ALT_USB_DEV_DIEPCTL5 register for the ALT_USB1_DEVGRP instance. */
4772
#define ALT_USB1_DEV_DIEPCTL5_ADDR ALT_USB_DEV_DIEPCTL5_ADDR(ALT_USB1_DEVGRP_ADDR)
4773
/* The address of the ALT_USB_DEV_DIEPINT5 register for the ALT_USB1_DEVGRP instance. */
4774
#define ALT_USB1_DEV_DIEPINT5_ADDR ALT_USB_DEV_DIEPINT5_ADDR(ALT_USB1_DEVGRP_ADDR)
4775
/* The address of the ALT_USB_DEV_DIEPTSIZ5 register for the ALT_USB1_DEVGRP instance. */
4776
#define ALT_USB1_DEV_DIEPTSIZ5_ADDR ALT_USB_DEV_DIEPTSIZ5_ADDR(ALT_USB1_DEVGRP_ADDR)
4777
/* The address of the ALT_USB_DEV_DIEPDMA5 register for the ALT_USB1_DEVGRP instance. */
4778
#define ALT_USB1_DEV_DIEPDMA5_ADDR ALT_USB_DEV_DIEPDMA5_ADDR(ALT_USB1_DEVGRP_ADDR)
4779
/* The address of the ALT_USB_DEV_DTXFSTS5 register for the ALT_USB1_DEVGRP instance. */
4780
#define ALT_USB1_DEV_DTXFSTS5_ADDR ALT_USB_DEV_DTXFSTS5_ADDR(ALT_USB1_DEVGRP_ADDR)
4781
/* The address of the ALT_USB_DEV_DIEPDMAB5 register for the ALT_USB1_DEVGRP instance. */
4782
#define ALT_USB1_DEV_DIEPDMAB5_ADDR ALT_USB_DEV_DIEPDMAB5_ADDR(ALT_USB1_DEVGRP_ADDR)
4783
/* The address of the ALT_USB_DEV_DIEPCTL6 register for the ALT_USB1_DEVGRP instance. */
4784
#define ALT_USB1_DEV_DIEPCTL6_ADDR ALT_USB_DEV_DIEPCTL6_ADDR(ALT_USB1_DEVGRP_ADDR)
4785
/* The address of the ALT_USB_DEV_DIEPINT6 register for the ALT_USB1_DEVGRP instance. */
4786
#define ALT_USB1_DEV_DIEPINT6_ADDR ALT_USB_DEV_DIEPINT6_ADDR(ALT_USB1_DEVGRP_ADDR)
4787
/* The address of the ALT_USB_DEV_DIEPTSIZ6 register for the ALT_USB1_DEVGRP instance. */
4788
#define ALT_USB1_DEV_DIEPTSIZ6_ADDR ALT_USB_DEV_DIEPTSIZ6_ADDR(ALT_USB1_DEVGRP_ADDR)
4789
/* The address of the ALT_USB_DEV_DIEPDMA6 register for the ALT_USB1_DEVGRP instance. */
4790
#define ALT_USB1_DEV_DIEPDMA6_ADDR ALT_USB_DEV_DIEPDMA6_ADDR(ALT_USB1_DEVGRP_ADDR)
4791
/* The address of the ALT_USB_DEV_DTXFSTS6 register for the ALT_USB1_DEVGRP instance. */
4792
#define ALT_USB1_DEV_DTXFSTS6_ADDR ALT_USB_DEV_DTXFSTS6_ADDR(ALT_USB1_DEVGRP_ADDR)
4793
/* The address of the ALT_USB_DEV_DIEPDMAB6 register for the ALT_USB1_DEVGRP instance. */
4794
#define ALT_USB1_DEV_DIEPDMAB6_ADDR ALT_USB_DEV_DIEPDMAB6_ADDR(ALT_USB1_DEVGRP_ADDR)
4795
/* The address of the ALT_USB_DEV_DIEPCTL7 register for the ALT_USB1_DEVGRP instance. */
4796
#define ALT_USB1_DEV_DIEPCTL7_ADDR ALT_USB_DEV_DIEPCTL7_ADDR(ALT_USB1_DEVGRP_ADDR)
4797
/* The address of the ALT_USB_DEV_DIEPINT7 register for the ALT_USB1_DEVGRP instance. */
4798
#define ALT_USB1_DEV_DIEPINT7_ADDR ALT_USB_DEV_DIEPINT7_ADDR(ALT_USB1_DEVGRP_ADDR)
4799
/* The address of the ALT_USB_DEV_DIEPTSIZ7 register for the ALT_USB1_DEVGRP instance. */
4800
#define ALT_USB1_DEV_DIEPTSIZ7_ADDR ALT_USB_DEV_DIEPTSIZ7_ADDR(ALT_USB1_DEVGRP_ADDR)
4801
/* The address of the ALT_USB_DEV_DIEPDMA7 register for the ALT_USB1_DEVGRP instance. */
4802
#define ALT_USB1_DEV_DIEPDMA7_ADDR ALT_USB_DEV_DIEPDMA7_ADDR(ALT_USB1_DEVGRP_ADDR)
4803
/* The address of the ALT_USB_DEV_DTXFSTS7 register for the ALT_USB1_DEVGRP instance. */
4804
#define ALT_USB1_DEV_DTXFSTS7_ADDR ALT_USB_DEV_DTXFSTS7_ADDR(ALT_USB1_DEVGRP_ADDR)
4805
/* The address of the ALT_USB_DEV_DIEPDMAB7 register for the ALT_USB1_DEVGRP instance. */
4806
#define ALT_USB1_DEV_DIEPDMAB7_ADDR ALT_USB_DEV_DIEPDMAB7_ADDR(ALT_USB1_DEVGRP_ADDR)
4807
/* The address of the ALT_USB_DEV_DIEPCTL8 register for the ALT_USB1_DEVGRP instance. */
4808
#define ALT_USB1_DEV_DIEPCTL8_ADDR ALT_USB_DEV_DIEPCTL8_ADDR(ALT_USB1_DEVGRP_ADDR)
4809
/* The address of the ALT_USB_DEV_DIEPINT8 register for the ALT_USB1_DEVGRP instance. */
4810
#define ALT_USB1_DEV_DIEPINT8_ADDR ALT_USB_DEV_DIEPINT8_ADDR(ALT_USB1_DEVGRP_ADDR)
4811
/* The address of the ALT_USB_DEV_DIEPTSIZ8 register for the ALT_USB1_DEVGRP instance. */
4812
#define ALT_USB1_DEV_DIEPTSIZ8_ADDR ALT_USB_DEV_DIEPTSIZ8_ADDR(ALT_USB1_DEVGRP_ADDR)
4813
/* The address of the ALT_USB_DEV_DIEPDMA8 register for the ALT_USB1_DEVGRP instance. */
4814
#define ALT_USB1_DEV_DIEPDMA8_ADDR ALT_USB_DEV_DIEPDMA8_ADDR(ALT_USB1_DEVGRP_ADDR)
4815
/* The address of the ALT_USB_DEV_DTXFSTS8 register for the ALT_USB1_DEVGRP instance. */
4816
#define ALT_USB1_DEV_DTXFSTS8_ADDR ALT_USB_DEV_DTXFSTS8_ADDR(ALT_USB1_DEVGRP_ADDR)
4817
/* The address of the ALT_USB_DEV_DIEPDMAB8 register for the ALT_USB1_DEVGRP instance. */
4818
#define ALT_USB1_DEV_DIEPDMAB8_ADDR ALT_USB_DEV_DIEPDMAB8_ADDR(ALT_USB1_DEVGRP_ADDR)
4819
/* The address of the ALT_USB_DEV_DIEPCTL9 register for the ALT_USB1_DEVGRP instance. */
4820
#define ALT_USB1_DEV_DIEPCTL9_ADDR ALT_USB_DEV_DIEPCTL9_ADDR(ALT_USB1_DEVGRP_ADDR)
4821
/* The address of the ALT_USB_DEV_DIEPINT9 register for the ALT_USB1_DEVGRP instance. */
4822
#define ALT_USB1_DEV_DIEPINT9_ADDR ALT_USB_DEV_DIEPINT9_ADDR(ALT_USB1_DEVGRP_ADDR)
4823
/* The address of the ALT_USB_DEV_DIEPTSIZ9 register for the ALT_USB1_DEVGRP instance. */
4824
#define ALT_USB1_DEV_DIEPTSIZ9_ADDR ALT_USB_DEV_DIEPTSIZ9_ADDR(ALT_USB1_DEVGRP_ADDR)
4825
/* The address of the ALT_USB_DEV_DIEPDMA9 register for the ALT_USB1_DEVGRP instance. */
4826
#define ALT_USB1_DEV_DIEPDMA9_ADDR ALT_USB_DEV_DIEPDMA9_ADDR(ALT_USB1_DEVGRP_ADDR)
4827
/* The address of the ALT_USB_DEV_DTXFSTS9 register for the ALT_USB1_DEVGRP instance. */
4828
#define ALT_USB1_DEV_DTXFSTS9_ADDR ALT_USB_DEV_DTXFSTS9_ADDR(ALT_USB1_DEVGRP_ADDR)
4829
/* The address of the ALT_USB_DEV_DIEPDMAB9 register for the ALT_USB1_DEVGRP instance. */
4830
#define ALT_USB1_DEV_DIEPDMAB9_ADDR ALT_USB_DEV_DIEPDMAB9_ADDR(ALT_USB1_DEVGRP_ADDR)
4831
/* The address of the ALT_USB_DEV_DIEPCTL10 register for the ALT_USB1_DEVGRP instance. */
4832
#define ALT_USB1_DEV_DIEPCTL10_ADDR ALT_USB_DEV_DIEPCTL10_ADDR(ALT_USB1_DEVGRP_ADDR)
4833
/* The address of the ALT_USB_DEV_DIEPINT10 register for the ALT_USB1_DEVGRP instance. */
4834
#define ALT_USB1_DEV_DIEPINT10_ADDR ALT_USB_DEV_DIEPINT10_ADDR(ALT_USB1_DEVGRP_ADDR)
4835
/* The address of the ALT_USB_DEV_DIEPTSIZ10 register for the ALT_USB1_DEVGRP instance. */
4836
#define ALT_USB1_DEV_DIEPTSIZ10_ADDR ALT_USB_DEV_DIEPTSIZ10_ADDR(ALT_USB1_DEVGRP_ADDR)
4837
/* The address of the ALT_USB_DEV_DIEPDMA10 register for the ALT_USB1_DEVGRP instance. */
4838
#define ALT_USB1_DEV_DIEPDMA10_ADDR ALT_USB_DEV_DIEPDMA10_ADDR(ALT_USB1_DEVGRP_ADDR)
4839
/* The address of the ALT_USB_DEV_DTXFSTS10 register for the ALT_USB1_DEVGRP instance. */
4840
#define ALT_USB1_DEV_DTXFSTS10_ADDR ALT_USB_DEV_DTXFSTS10_ADDR(ALT_USB1_DEVGRP_ADDR)
4841
/* The address of the ALT_USB_DEV_DIEPDMAB10 register for the ALT_USB1_DEVGRP instance. */
4842
#define ALT_USB1_DEV_DIEPDMAB10_ADDR ALT_USB_DEV_DIEPDMAB10_ADDR(ALT_USB1_DEVGRP_ADDR)
4843
/* The address of the ALT_USB_DEV_DIEPCTL11 register for the ALT_USB1_DEVGRP instance. */
4844
#define ALT_USB1_DEV_DIEPCTL11_ADDR ALT_USB_DEV_DIEPCTL11_ADDR(ALT_USB1_DEVGRP_ADDR)
4845
/* The address of the ALT_USB_DEV_DIEPINT11 register for the ALT_USB1_DEVGRP instance. */
4846
#define ALT_USB1_DEV_DIEPINT11_ADDR ALT_USB_DEV_DIEPINT11_ADDR(ALT_USB1_DEVGRP_ADDR)
4847
/* The address of the ALT_USB_DEV_DIEPTSIZ11 register for the ALT_USB1_DEVGRP instance. */
4848
#define ALT_USB1_DEV_DIEPTSIZ11_ADDR ALT_USB_DEV_DIEPTSIZ11_ADDR(ALT_USB1_DEVGRP_ADDR)
4849
/* The address of the ALT_USB_DEV_DIEPDMA11 register for the ALT_USB1_DEVGRP instance. */
4850
#define ALT_USB1_DEV_DIEPDMA11_ADDR ALT_USB_DEV_DIEPDMA11_ADDR(ALT_USB1_DEVGRP_ADDR)
4851
/* The address of the ALT_USB_DEV_DTXFSTS11 register for the ALT_USB1_DEVGRP instance. */
4852
#define ALT_USB1_DEV_DTXFSTS11_ADDR ALT_USB_DEV_DTXFSTS11_ADDR(ALT_USB1_DEVGRP_ADDR)
4853
/* The address of the ALT_USB_DEV_DIEPDMAB11 register for the ALT_USB1_DEVGRP instance. */
4854
#define ALT_USB1_DEV_DIEPDMAB11_ADDR ALT_USB_DEV_DIEPDMAB11_ADDR(ALT_USB1_DEVGRP_ADDR)
4855
/* The address of the ALT_USB_DEV_DIEPCTL12 register for the ALT_USB1_DEVGRP instance. */
4856
#define ALT_USB1_DEV_DIEPCTL12_ADDR ALT_USB_DEV_DIEPCTL12_ADDR(ALT_USB1_DEVGRP_ADDR)
4857
/* The address of the ALT_USB_DEV_DIEPINT12 register for the ALT_USB1_DEVGRP instance. */
4858
#define ALT_USB1_DEV_DIEPINT12_ADDR ALT_USB_DEV_DIEPINT12_ADDR(ALT_USB1_DEVGRP_ADDR)
4859
/* The address of the ALT_USB_DEV_DIEPTSIZ12 register for the ALT_USB1_DEVGRP instance. */
4860
#define ALT_USB1_DEV_DIEPTSIZ12_ADDR ALT_USB_DEV_DIEPTSIZ12_ADDR(ALT_USB1_DEVGRP_ADDR)
4861
/* The address of the ALT_USB_DEV_DIEPDMA12 register for the ALT_USB1_DEVGRP instance. */
4862
#define ALT_USB1_DEV_DIEPDMA12_ADDR ALT_USB_DEV_DIEPDMA12_ADDR(ALT_USB1_DEVGRP_ADDR)
4863
/* The address of the ALT_USB_DEV_DTXFSTS12 register for the ALT_USB1_DEVGRP instance. */
4864
#define ALT_USB1_DEV_DTXFSTS12_ADDR ALT_USB_DEV_DTXFSTS12_ADDR(ALT_USB1_DEVGRP_ADDR)
4865
/* The address of the ALT_USB_DEV_DIEPDMAB12 register for the ALT_USB1_DEVGRP instance. */
4866
#define ALT_USB1_DEV_DIEPDMAB12_ADDR ALT_USB_DEV_DIEPDMAB12_ADDR(ALT_USB1_DEVGRP_ADDR)
4867
/* The address of the ALT_USB_DEV_DIEPCTL13 register for the ALT_USB1_DEVGRP instance. */
4868
#define ALT_USB1_DEV_DIEPCTL13_ADDR ALT_USB_DEV_DIEPCTL13_ADDR(ALT_USB1_DEVGRP_ADDR)
4869
/* The address of the ALT_USB_DEV_DIEPINT13 register for the ALT_USB1_DEVGRP instance. */
4870
#define ALT_USB1_DEV_DIEPINT13_ADDR ALT_USB_DEV_DIEPINT13_ADDR(ALT_USB1_DEVGRP_ADDR)
4871
/* The address of the ALT_USB_DEV_DIEPTSIZ13 register for the ALT_USB1_DEVGRP instance. */
4872
#define ALT_USB1_DEV_DIEPTSIZ13_ADDR ALT_USB_DEV_DIEPTSIZ13_ADDR(ALT_USB1_DEVGRP_ADDR)
4873
/* The address of the ALT_USB_DEV_DIEPDMA13 register for the ALT_USB1_DEVGRP instance. */
4874
#define ALT_USB1_DEV_DIEPDMA13_ADDR ALT_USB_DEV_DIEPDMA13_ADDR(ALT_USB1_DEVGRP_ADDR)
4875
/* The address of the ALT_USB_DEV_DTXFSTS13 register for the ALT_USB1_DEVGRP instance. */
4876
#define ALT_USB1_DEV_DTXFSTS13_ADDR ALT_USB_DEV_DTXFSTS13_ADDR(ALT_USB1_DEVGRP_ADDR)
4877
/* The address of the ALT_USB_DEV_DIEPDMAB13 register for the ALT_USB1_DEVGRP instance. */
4878
#define ALT_USB1_DEV_DIEPDMAB13_ADDR ALT_USB_DEV_DIEPDMAB13_ADDR(ALT_USB1_DEVGRP_ADDR)
4879
/* The address of the ALT_USB_DEV_DIEPCTL14 register for the ALT_USB1_DEVGRP instance. */
4880
#define ALT_USB1_DEV_DIEPCTL14_ADDR ALT_USB_DEV_DIEPCTL14_ADDR(ALT_USB1_DEVGRP_ADDR)
4881
/* The address of the ALT_USB_DEV_DIEPINT14 register for the ALT_USB1_DEVGRP instance. */
4882
#define ALT_USB1_DEV_DIEPINT14_ADDR ALT_USB_DEV_DIEPINT14_ADDR(ALT_USB1_DEVGRP_ADDR)
4883
/* The address of the ALT_USB_DEV_DIEPTSIZ14 register for the ALT_USB1_DEVGRP instance. */
4884
#define ALT_USB1_DEV_DIEPTSIZ14_ADDR ALT_USB_DEV_DIEPTSIZ14_ADDR(ALT_USB1_DEVGRP_ADDR)
4885
/* The address of the ALT_USB_DEV_DIEPDMA14 register for the ALT_USB1_DEVGRP instance. */
4886
#define ALT_USB1_DEV_DIEPDMA14_ADDR ALT_USB_DEV_DIEPDMA14_ADDR(ALT_USB1_DEVGRP_ADDR)
4887
/* The address of the ALT_USB_DEV_DTXFSTS14 register for the ALT_USB1_DEVGRP instance. */
4888
#define ALT_USB1_DEV_DTXFSTS14_ADDR ALT_USB_DEV_DTXFSTS14_ADDR(ALT_USB1_DEVGRP_ADDR)
4889
/* The address of the ALT_USB_DEV_DIEPDMAB14 register for the ALT_USB1_DEVGRP instance. */
4890
#define ALT_USB1_DEV_DIEPDMAB14_ADDR ALT_USB_DEV_DIEPDMAB14_ADDR(ALT_USB1_DEVGRP_ADDR)
4891
/* The address of the ALT_USB_DEV_DIEPCTL15 register for the ALT_USB1_DEVGRP instance. */
4892
#define ALT_USB1_DEV_DIEPCTL15_ADDR ALT_USB_DEV_DIEPCTL15_ADDR(ALT_USB1_DEVGRP_ADDR)
4893
/* The address of the ALT_USB_DEV_DIEPINT15 register for the ALT_USB1_DEVGRP instance. */
4894
#define ALT_USB1_DEV_DIEPINT15_ADDR ALT_USB_DEV_DIEPINT15_ADDR(ALT_USB1_DEVGRP_ADDR)
4895
/* The address of the ALT_USB_DEV_DIEPTSIZ15 register for the ALT_USB1_DEVGRP instance. */
4896
#define ALT_USB1_DEV_DIEPTSIZ15_ADDR ALT_USB_DEV_DIEPTSIZ15_ADDR(ALT_USB1_DEVGRP_ADDR)
4897
/* The address of the ALT_USB_DEV_DIEPDMA15 register for the ALT_USB1_DEVGRP instance. */
4898
#define ALT_USB1_DEV_DIEPDMA15_ADDR ALT_USB_DEV_DIEPDMA15_ADDR(ALT_USB1_DEVGRP_ADDR)
4899
/* The address of the ALT_USB_DEV_DTXFSTS15 register for the ALT_USB1_DEVGRP instance. */
4900
#define ALT_USB1_DEV_DTXFSTS15_ADDR ALT_USB_DEV_DTXFSTS15_ADDR(ALT_USB1_DEVGRP_ADDR)
4901
/* The address of the ALT_USB_DEV_DIEPDMAB15 register for the ALT_USB1_DEVGRP instance. */
4902
#define ALT_USB1_DEV_DIEPDMAB15_ADDR ALT_USB_DEV_DIEPDMAB15_ADDR(ALT_USB1_DEVGRP_ADDR)
4903
/* The address of the ALT_USB_DEV_DOEPCTL0 register for the ALT_USB1_DEVGRP instance. */
4904
#define ALT_USB1_DEV_DOEPCTL0_ADDR ALT_USB_DEV_DOEPCTL0_ADDR(ALT_USB1_DEVGRP_ADDR)
4905
/* The address of the ALT_USB_DEV_DOEPINT0 register for the ALT_USB1_DEVGRP instance. */
4906
#define ALT_USB1_DEV_DOEPINT0_ADDR ALT_USB_DEV_DOEPINT0_ADDR(ALT_USB1_DEVGRP_ADDR)
4907
/* The address of the ALT_USB_DEV_DOEPTSIZ0 register for the ALT_USB1_DEVGRP instance. */
4908
#define ALT_USB1_DEV_DOEPTSIZ0_ADDR ALT_USB_DEV_DOEPTSIZ0_ADDR(ALT_USB1_DEVGRP_ADDR)
4909
/* The address of the ALT_USB_DEV_DOEPDMA0 register for the ALT_USB1_DEVGRP instance. */
4910
#define ALT_USB1_DEV_DOEPDMA0_ADDR ALT_USB_DEV_DOEPDMA0_ADDR(ALT_USB1_DEVGRP_ADDR)
4911
/* The address of the ALT_USB_DEV_DOEPDMAB0 register for the ALT_USB1_DEVGRP instance. */
4912
#define ALT_USB1_DEV_DOEPDMAB0_ADDR ALT_USB_DEV_DOEPDMAB0_ADDR(ALT_USB1_DEVGRP_ADDR)
4913
/* The address of the ALT_USB_DEV_DOEPCTL1 register for the ALT_USB1_DEVGRP instance. */
4914
#define ALT_USB1_DEV_DOEPCTL1_ADDR ALT_USB_DEV_DOEPCTL1_ADDR(ALT_USB1_DEVGRP_ADDR)
4915
/* The address of the ALT_USB_DEV_DOEPINT1 register for the ALT_USB1_DEVGRP instance. */
4916
#define ALT_USB1_DEV_DOEPINT1_ADDR ALT_USB_DEV_DOEPINT1_ADDR(ALT_USB1_DEVGRP_ADDR)
4917
/* The address of the ALT_USB_DEV_DOEPTSIZ1 register for the ALT_USB1_DEVGRP instance. */
4918
#define ALT_USB1_DEV_DOEPTSIZ1_ADDR ALT_USB_DEV_DOEPTSIZ1_ADDR(ALT_USB1_DEVGRP_ADDR)
4919
/* The address of the ALT_USB_DEV_DOEPDMA1 register for the ALT_USB1_DEVGRP instance. */
4920
#define ALT_USB1_DEV_DOEPDMA1_ADDR ALT_USB_DEV_DOEPDMA1_ADDR(ALT_USB1_DEVGRP_ADDR)
4921
/* The address of the ALT_USB_DEV_DOEPDMAB1 register for the ALT_USB1_DEVGRP instance. */
4922
#define ALT_USB1_DEV_DOEPDMAB1_ADDR ALT_USB_DEV_DOEPDMAB1_ADDR(ALT_USB1_DEVGRP_ADDR)
4923
/* The address of the ALT_USB_DEV_DOEPCTL2 register for the ALT_USB1_DEVGRP instance. */
4924
#define ALT_USB1_DEV_DOEPCTL2_ADDR ALT_USB_DEV_DOEPCTL2_ADDR(ALT_USB1_DEVGRP_ADDR)
4925
/* The address of the ALT_USB_DEV_DOEPINT2 register for the ALT_USB1_DEVGRP instance. */
4926
#define ALT_USB1_DEV_DOEPINT2_ADDR ALT_USB_DEV_DOEPINT2_ADDR(ALT_USB1_DEVGRP_ADDR)
4927
/* The address of the ALT_USB_DEV_DOEPTSIZ2 register for the ALT_USB1_DEVGRP instance. */
4928
#define ALT_USB1_DEV_DOEPTSIZ2_ADDR ALT_USB_DEV_DOEPTSIZ2_ADDR(ALT_USB1_DEVGRP_ADDR)
4929
/* The address of the ALT_USB_DEV_DOEPDMA2 register for the ALT_USB1_DEVGRP instance. */
4930
#define ALT_USB1_DEV_DOEPDMA2_ADDR ALT_USB_DEV_DOEPDMA2_ADDR(ALT_USB1_DEVGRP_ADDR)
4931
/* The address of the ALT_USB_DEV_DOEPDMAB2 register for the ALT_USB1_DEVGRP instance. */
4932
#define ALT_USB1_DEV_DOEPDMAB2_ADDR ALT_USB_DEV_DOEPDMAB2_ADDR(ALT_USB1_DEVGRP_ADDR)
4933
/* The address of the ALT_USB_DEV_DOEPCTL3 register for the ALT_USB1_DEVGRP instance. */
4934
#define ALT_USB1_DEV_DOEPCTL3_ADDR ALT_USB_DEV_DOEPCTL3_ADDR(ALT_USB1_DEVGRP_ADDR)
4935
/* The address of the ALT_USB_DEV_DOEPINT3 register for the ALT_USB1_DEVGRP instance. */
4936
#define ALT_USB1_DEV_DOEPINT3_ADDR ALT_USB_DEV_DOEPINT3_ADDR(ALT_USB1_DEVGRP_ADDR)
4937
/* The address of the ALT_USB_DEV_DOEPTSIZ3 register for the ALT_USB1_DEVGRP instance. */
4938
#define ALT_USB1_DEV_DOEPTSIZ3_ADDR ALT_USB_DEV_DOEPTSIZ3_ADDR(ALT_USB1_DEVGRP_ADDR)
4939
/* The address of the ALT_USB_DEV_DOEPDMA3 register for the ALT_USB1_DEVGRP instance. */
4940
#define ALT_USB1_DEV_DOEPDMA3_ADDR ALT_USB_DEV_DOEPDMA3_ADDR(ALT_USB1_DEVGRP_ADDR)
4941
/* The address of the ALT_USB_DEV_DOEPDMAB3 register for the ALT_USB1_DEVGRP instance. */
4942
#define ALT_USB1_DEV_DOEPDMAB3_ADDR ALT_USB_DEV_DOEPDMAB3_ADDR(ALT_USB1_DEVGRP_ADDR)
4943
/* The address of the ALT_USB_DEV_DOEPCTL4 register for the ALT_USB1_DEVGRP instance. */
4944
#define ALT_USB1_DEV_DOEPCTL4_ADDR ALT_USB_DEV_DOEPCTL4_ADDR(ALT_USB1_DEVGRP_ADDR)
4945
/* The address of the ALT_USB_DEV_DOEPINT4 register for the ALT_USB1_DEVGRP instance. */
4946
#define ALT_USB1_DEV_DOEPINT4_ADDR ALT_USB_DEV_DOEPINT4_ADDR(ALT_USB1_DEVGRP_ADDR)
4947
/* The address of the ALT_USB_DEV_DOEPTSIZ4 register for the ALT_USB1_DEVGRP instance. */
4948
#define ALT_USB1_DEV_DOEPTSIZ4_ADDR ALT_USB_DEV_DOEPTSIZ4_ADDR(ALT_USB1_DEVGRP_ADDR)
4949
/* The address of the ALT_USB_DEV_DOEPDMA4 register for the ALT_USB1_DEVGRP instance. */
4950
#define ALT_USB1_DEV_DOEPDMA4_ADDR ALT_USB_DEV_DOEPDMA4_ADDR(ALT_USB1_DEVGRP_ADDR)
4951
/* The address of the ALT_USB_DEV_DOEPDMAB4 register for the ALT_USB1_DEVGRP instance. */
4952
#define ALT_USB1_DEV_DOEPDMAB4_ADDR ALT_USB_DEV_DOEPDMAB4_ADDR(ALT_USB1_DEVGRP_ADDR)
4953
/* The address of the ALT_USB_DEV_DOEPCTL5 register for the ALT_USB1_DEVGRP instance. */
4954
#define ALT_USB1_DEV_DOEPCTL5_ADDR ALT_USB_DEV_DOEPCTL5_ADDR(ALT_USB1_DEVGRP_ADDR)
4955
/* The address of the ALT_USB_DEV_DOEPINT5 register for the ALT_USB1_DEVGRP instance. */
4956
#define ALT_USB1_DEV_DOEPINT5_ADDR ALT_USB_DEV_DOEPINT5_ADDR(ALT_USB1_DEVGRP_ADDR)
4957
/* The address of the ALT_USB_DEV_DOEPTSIZ5 register for the ALT_USB1_DEVGRP instance. */
4958
#define ALT_USB1_DEV_DOEPTSIZ5_ADDR ALT_USB_DEV_DOEPTSIZ5_ADDR(ALT_USB1_DEVGRP_ADDR)
4959
/* The address of the ALT_USB_DEV_DOEPDMA5 register for the ALT_USB1_DEVGRP instance. */
4960
#define ALT_USB1_DEV_DOEPDMA5_ADDR ALT_USB_DEV_DOEPDMA5_ADDR(ALT_USB1_DEVGRP_ADDR)
4961
/* The address of the ALT_USB_DEV_DOEPDMAB5 register for the ALT_USB1_DEVGRP instance. */
4962
#define ALT_USB1_DEV_DOEPDMAB5_ADDR ALT_USB_DEV_DOEPDMAB5_ADDR(ALT_USB1_DEVGRP_ADDR)
4963
/* The address of the ALT_USB_DEV_DOEPCTL6 register for the ALT_USB1_DEVGRP instance. */
4964
#define ALT_USB1_DEV_DOEPCTL6_ADDR ALT_USB_DEV_DOEPCTL6_ADDR(ALT_USB1_DEVGRP_ADDR)
4965
/* The address of the ALT_USB_DEV_DOEPINT6 register for the ALT_USB1_DEVGRP instance. */
4966
#define ALT_USB1_DEV_DOEPINT6_ADDR ALT_USB_DEV_DOEPINT6_ADDR(ALT_USB1_DEVGRP_ADDR)
4967
/* The address of the ALT_USB_DEV_DOEPTSIZ6 register for the ALT_USB1_DEVGRP instance. */
4968
#define ALT_USB1_DEV_DOEPTSIZ6_ADDR ALT_USB_DEV_DOEPTSIZ6_ADDR(ALT_USB1_DEVGRP_ADDR)
4969
/* The address of the ALT_USB_DEV_DOEPDMA6 register for the ALT_USB1_DEVGRP instance. */
4970
#define ALT_USB1_DEV_DOEPDMA6_ADDR ALT_USB_DEV_DOEPDMA6_ADDR(ALT_USB1_DEVGRP_ADDR)
4971
/* The address of the ALT_USB_DEV_DOEPDMAB6 register for the ALT_USB1_DEVGRP instance. */
4972
#define ALT_USB1_DEV_DOEPDMAB6_ADDR ALT_USB_DEV_DOEPDMAB6_ADDR(ALT_USB1_DEVGRP_ADDR)
4973
/* The address of the ALT_USB_DEV_DOEPCTL7 register for the ALT_USB1_DEVGRP instance. */
4974
#define ALT_USB1_DEV_DOEPCTL7_ADDR ALT_USB_DEV_DOEPCTL7_ADDR(ALT_USB1_DEVGRP_ADDR)
4975
/* The address of the ALT_USB_DEV_DOEPINT7 register for the ALT_USB1_DEVGRP instance. */
4976
#define ALT_USB1_DEV_DOEPINT7_ADDR ALT_USB_DEV_DOEPINT7_ADDR(ALT_USB1_DEVGRP_ADDR)
4977
/* The address of the ALT_USB_DEV_DOEPTSIZ7 register for the ALT_USB1_DEVGRP instance. */
4978
#define ALT_USB1_DEV_DOEPTSIZ7_ADDR ALT_USB_DEV_DOEPTSIZ7_ADDR(ALT_USB1_DEVGRP_ADDR)
4979
/* The address of the ALT_USB_DEV_DOEPDMA7 register for the ALT_USB1_DEVGRP instance. */
4980
#define ALT_USB1_DEV_DOEPDMA7_ADDR ALT_USB_DEV_DOEPDMA7_ADDR(ALT_USB1_DEVGRP_ADDR)
4981
/* The address of the ALT_USB_DEV_DOEPDMAB7 register for the ALT_USB1_DEVGRP instance. */
4982
#define ALT_USB1_DEV_DOEPDMAB7_ADDR ALT_USB_DEV_DOEPDMAB7_ADDR(ALT_USB1_DEVGRP_ADDR)
4983
/* The address of the ALT_USB_DEV_DOEPCTL8 register for the ALT_USB1_DEVGRP instance. */
4984
#define ALT_USB1_DEV_DOEPCTL8_ADDR ALT_USB_DEV_DOEPCTL8_ADDR(ALT_USB1_DEVGRP_ADDR)
4985
/* The address of the ALT_USB_DEV_DOEPINT8 register for the ALT_USB1_DEVGRP instance. */
4986
#define ALT_USB1_DEV_DOEPINT8_ADDR ALT_USB_DEV_DOEPINT8_ADDR(ALT_USB1_DEVGRP_ADDR)
4987
/* The address of the ALT_USB_DEV_DOEPTSIZ8 register for the ALT_USB1_DEVGRP instance. */
4988
#define ALT_USB1_DEV_DOEPTSIZ8_ADDR ALT_USB_DEV_DOEPTSIZ8_ADDR(ALT_USB1_DEVGRP_ADDR)
4989
/* The address of the ALT_USB_DEV_DOEPDMA8 register for the ALT_USB1_DEVGRP instance. */
4990
#define ALT_USB1_DEV_DOEPDMA8_ADDR ALT_USB_DEV_DOEPDMA8_ADDR(ALT_USB1_DEVGRP_ADDR)
4991
/* The address of the ALT_USB_DEV_DOEPDMAB8 register for the ALT_USB1_DEVGRP instance. */
4992
#define ALT_USB1_DEV_DOEPDMAB8_ADDR ALT_USB_DEV_DOEPDMAB8_ADDR(ALT_USB1_DEVGRP_ADDR)
4993
/* The address of the ALT_USB_DEV_DOEPCTL9 register for the ALT_USB1_DEVGRP instance. */
4994
#define ALT_USB1_DEV_DOEPCTL9_ADDR ALT_USB_DEV_DOEPCTL9_ADDR(ALT_USB1_DEVGRP_ADDR)
4995
/* The address of the ALT_USB_DEV_DOEPINT9 register for the ALT_USB1_DEVGRP instance. */
4996
#define ALT_USB1_DEV_DOEPINT9_ADDR ALT_USB_DEV_DOEPINT9_ADDR(ALT_USB1_DEVGRP_ADDR)
4997
/* The address of the ALT_USB_DEV_DOEPTSIZ9 register for the ALT_USB1_DEVGRP instance. */
4998
#define ALT_USB1_DEV_DOEPTSIZ9_ADDR ALT_USB_DEV_DOEPTSIZ9_ADDR(ALT_USB1_DEVGRP_ADDR)
4999
/* The address of the ALT_USB_DEV_DOEPDMA9 register for the ALT_USB1_DEVGRP instance. */
5000
#define ALT_USB1_DEV_DOEPDMA9_ADDR ALT_USB_DEV_DOEPDMA9_ADDR(ALT_USB1_DEVGRP_ADDR)
5001
/* The address of the ALT_USB_DEV_DOEPDMAB9 register for the ALT_USB1_DEVGRP instance. */
5002
#define ALT_USB1_DEV_DOEPDMAB9_ADDR ALT_USB_DEV_DOEPDMAB9_ADDR(ALT_USB1_DEVGRP_ADDR)
5003
/* The address of the ALT_USB_DEV_DOEPCTL10 register for the ALT_USB1_DEVGRP instance. */
5004
#define ALT_USB1_DEV_DOEPCTL10_ADDR ALT_USB_DEV_DOEPCTL10_ADDR(ALT_USB1_DEVGRP_ADDR)
5005
/* The address of the ALT_USB_DEV_DOEPINT10 register for the ALT_USB1_DEVGRP instance. */
5006
#define ALT_USB1_DEV_DOEPINT10_ADDR ALT_USB_DEV_DOEPINT10_ADDR(ALT_USB1_DEVGRP_ADDR)
5007
/* The address of the ALT_USB_DEV_DOEPTSIZ10 register for the ALT_USB1_DEVGRP instance. */
5008
#define ALT_USB1_DEV_DOEPTSIZ10_ADDR ALT_USB_DEV_DOEPTSIZ10_ADDR(ALT_USB1_DEVGRP_ADDR)
5009
/* The address of the ALT_USB_DEV_DOEPDMA10 register for the ALT_USB1_DEVGRP instance. */
5010
#define ALT_USB1_DEV_DOEPDMA10_ADDR ALT_USB_DEV_DOEPDMA10_ADDR(ALT_USB1_DEVGRP_ADDR)
5011
/* The address of the ALT_USB_DEV_DOEPDMAB10 register for the ALT_USB1_DEVGRP instance. */
5012
#define ALT_USB1_DEV_DOEPDMAB10_ADDR ALT_USB_DEV_DOEPDMAB10_ADDR(ALT_USB1_DEVGRP_ADDR)
5013
/* The address of the ALT_USB_DEV_DOEPCTL11 register for the ALT_USB1_DEVGRP instance. */
5014
#define ALT_USB1_DEV_DOEPCTL11_ADDR ALT_USB_DEV_DOEPCTL11_ADDR(ALT_USB1_DEVGRP_ADDR)
5015
/* The address of the ALT_USB_DEV_DOEPINT11 register for the ALT_USB1_DEVGRP instance. */
5016
#define ALT_USB1_DEV_DOEPINT11_ADDR ALT_USB_DEV_DOEPINT11_ADDR(ALT_USB1_DEVGRP_ADDR)
5017
/* The address of the ALT_USB_DEV_DOEPTSIZ11 register for the ALT_USB1_DEVGRP instance. */
5018
#define ALT_USB1_DEV_DOEPTSIZ11_ADDR ALT_USB_DEV_DOEPTSIZ11_ADDR(ALT_USB1_DEVGRP_ADDR)
5019
/* The address of the ALT_USB_DEV_DOEPDMA11 register for the ALT_USB1_DEVGRP instance. */
5020
#define ALT_USB1_DEV_DOEPDMA11_ADDR ALT_USB_DEV_DOEPDMA11_ADDR(ALT_USB1_DEVGRP_ADDR)
5021
/* The address of the ALT_USB_DEV_DOEPDMAB11 register for the ALT_USB1_DEVGRP instance. */
5022
#define ALT_USB1_DEV_DOEPDMAB11_ADDR ALT_USB_DEV_DOEPDMAB11_ADDR(ALT_USB1_DEVGRP_ADDR)
5023
/* The address of the ALT_USB_DEV_DOEPCTL12 register for the ALT_USB1_DEVGRP instance. */
5024
#define ALT_USB1_DEV_DOEPCTL12_ADDR ALT_USB_DEV_DOEPCTL12_ADDR(ALT_USB1_DEVGRP_ADDR)
5025
/* The address of the ALT_USB_DEV_DOEPINT12 register for the ALT_USB1_DEVGRP instance. */
5026
#define ALT_USB1_DEV_DOEPINT12_ADDR ALT_USB_DEV_DOEPINT12_ADDR(ALT_USB1_DEVGRP_ADDR)
5027
/* The address of the ALT_USB_DEV_DOEPTSIZ12 register for the ALT_USB1_DEVGRP instance. */
5028
#define ALT_USB1_DEV_DOEPTSIZ12_ADDR ALT_USB_DEV_DOEPTSIZ12_ADDR(ALT_USB1_DEVGRP_ADDR)
5029
/* The address of the ALT_USB_DEV_DOEPDMA12 register for the ALT_USB1_DEVGRP instance. */
5030
#define ALT_USB1_DEV_DOEPDMA12_ADDR ALT_USB_DEV_DOEPDMA12_ADDR(ALT_USB1_DEVGRP_ADDR)
5031
/* The address of the ALT_USB_DEV_DOEPDMAB12 register for the ALT_USB1_DEVGRP instance. */
5032
#define ALT_USB1_DEV_DOEPDMAB12_ADDR ALT_USB_DEV_DOEPDMAB12_ADDR(ALT_USB1_DEVGRP_ADDR)
5033
/* The address of the ALT_USB_DEV_DOEPCTL13 register for the ALT_USB1_DEVGRP instance. */
5034
#define ALT_USB1_DEV_DOEPCTL13_ADDR ALT_USB_DEV_DOEPCTL13_ADDR(ALT_USB1_DEVGRP_ADDR)
5035
/* The address of the ALT_USB_DEV_DOEPINT13 register for the ALT_USB1_DEVGRP instance. */
5036
#define ALT_USB1_DEV_DOEPINT13_ADDR ALT_USB_DEV_DOEPINT13_ADDR(ALT_USB1_DEVGRP_ADDR)
5037
/* The address of the ALT_USB_DEV_DOEPTSIZ13 register for the ALT_USB1_DEVGRP instance. */
5038
#define ALT_USB1_DEV_DOEPTSIZ13_ADDR ALT_USB_DEV_DOEPTSIZ13_ADDR(ALT_USB1_DEVGRP_ADDR)
5039
/* The address of the ALT_USB_DEV_DOEPDMA13 register for the ALT_USB1_DEVGRP instance. */
5040
#define ALT_USB1_DEV_DOEPDMA13_ADDR ALT_USB_DEV_DOEPDMA13_ADDR(ALT_USB1_DEVGRP_ADDR)
5041
/* The address of the ALT_USB_DEV_DOEPDMAB13 register for the ALT_USB1_DEVGRP instance. */
5042
#define ALT_USB1_DEV_DOEPDMAB13_ADDR ALT_USB_DEV_DOEPDMAB13_ADDR(ALT_USB1_DEVGRP_ADDR)
5043
/* The address of the ALT_USB_DEV_DOEPCTL14 register for the ALT_USB1_DEVGRP instance. */
5044
#define ALT_USB1_DEV_DOEPCTL14_ADDR ALT_USB_DEV_DOEPCTL14_ADDR(ALT_USB1_DEVGRP_ADDR)
5045
/* The address of the ALT_USB_DEV_DOEPINT14 register for the ALT_USB1_DEVGRP instance. */
5046
#define ALT_USB1_DEV_DOEPINT14_ADDR ALT_USB_DEV_DOEPINT14_ADDR(ALT_USB1_DEVGRP_ADDR)
5047
/* The address of the ALT_USB_DEV_DOEPTSIZ14 register for the ALT_USB1_DEVGRP instance. */
5048
#define ALT_USB1_DEV_DOEPTSIZ14_ADDR ALT_USB_DEV_DOEPTSIZ14_ADDR(ALT_USB1_DEVGRP_ADDR)
5049
/* The address of the ALT_USB_DEV_DOEPDMA14 register for the ALT_USB1_DEVGRP instance. */
5050
#define ALT_USB1_DEV_DOEPDMA14_ADDR ALT_USB_DEV_DOEPDMA14_ADDR(ALT_USB1_DEVGRP_ADDR)
5051
/* The address of the ALT_USB_DEV_DOEPDMAB14 register for the ALT_USB1_DEVGRP instance. */
5052
#define ALT_USB1_DEV_DOEPDMAB14_ADDR ALT_USB_DEV_DOEPDMAB14_ADDR(ALT_USB1_DEVGRP_ADDR)
5053
/* The address of the ALT_USB_DEV_DOEPCTL15 register for the ALT_USB1_DEVGRP instance. */
5054
#define ALT_USB1_DEV_DOEPCTL15_ADDR ALT_USB_DEV_DOEPCTL15_ADDR(ALT_USB1_DEVGRP_ADDR)
5055
/* The address of the ALT_USB_DEV_DOEPINT15 register for the ALT_USB1_DEVGRP instance. */
5056
#define ALT_USB1_DEV_DOEPINT15_ADDR ALT_USB_DEV_DOEPINT15_ADDR(ALT_USB1_DEVGRP_ADDR)
5057
/* The address of the ALT_USB_DEV_DOEPTSIZ15 register for the ALT_USB1_DEVGRP instance. */
5058
#define ALT_USB1_DEV_DOEPTSIZ15_ADDR ALT_USB_DEV_DOEPTSIZ15_ADDR(ALT_USB1_DEVGRP_ADDR)
5059
/* The address of the ALT_USB_DEV_DOEPDMA15 register for the ALT_USB1_DEVGRP instance. */
5060
#define ALT_USB1_DEV_DOEPDMA15_ADDR ALT_USB_DEV_DOEPDMA15_ADDR(ALT_USB1_DEVGRP_ADDR)
5061
/* The address of the ALT_USB_DEV_DOEPDMAB15 register for the ALT_USB1_DEVGRP instance. */
5062
#define ALT_USB1_DEV_DOEPDMAB15_ADDR ALT_USB_DEV_DOEPDMAB15_ADDR(ALT_USB1_DEVGRP_ADDR)
5063
/* The base address byte offset for the start of the ALT_USB1_DEVGRP component. */
5064
#define ALT_USB1_DEVGRP_OFST 0x800
5065
/* The start address of the ALT_USB1_DEVGRP component. */
5066
#define ALT_USB1_DEVGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB1_ADDR) + ALT_USB1_DEVGRP_OFST))
5067
/* The lower bound address range of the ALT_USB1_DEVGRP component. */
5068
#define ALT_USB1_DEVGRP_LB_ADDR ALT_USB1_DEVGRP_ADDR
5069
/* The upper bound address range of the ALT_USB1_DEVGRP component. */
5070
#define ALT_USB1_DEVGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB1_DEVGRP_ADDR) + 0x500) - 1))
5071
5072
5073
5074
* Register Group Instance : pwrclkgrp
5075
5076
* Instance pwrclkgrp of register group ALT_USB_PWRCLK.
5077
5078
5079
5080
/* The address of the ALT_USB_PWRCLK_PCGCCTL register for the ALT_USB1_PWRCLKGRP instance. */
5081
#define ALT_USB1_PWRCLK_PCGCCTL_ADDR ALT_USB_PWRCLK_PCGCCTL_ADDR(ALT_USB1_PWRCLKGRP_ADDR)
5082
/* The base address byte offset for the start of the ALT_USB1_PWRCLKGRP component. */
5083
#define ALT_USB1_PWRCLKGRP_OFST 0xe00
5084
/* The start address of the ALT_USB1_PWRCLKGRP component. */
5085
#define ALT_USB1_PWRCLKGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_USB1_ADDR) + ALT_USB1_PWRCLKGRP_OFST))
5086
/* The lower bound address range of the ALT_USB1_PWRCLKGRP component. */
5087
#define ALT_USB1_PWRCLKGRP_LB_ADDR ALT_USB1_PWRCLKGRP_ADDR
5088
/* The upper bound address range of the ALT_USB1_PWRCLKGRP component. */
5089
#define ALT_USB1_PWRCLKGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB1_PWRCLKGRP_ADDR) + 0x4) - 1))
5090
5091
5092
/* The base address byte offset for the start of the ALT_USB1 component. */
5093
#define ALT_USB1_OFST 0xffb40000
5094
/* The start address of the ALT_USB1 component. */
5095
#define ALT_USB1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_USB1_OFST))
5096
/* The lower bound address range of the ALT_USB1 component. */
5097
#define ALT_USB1_LB_ADDR ALT_USB1_ADDR
5098
/* The upper bound address range of the ALT_USB1 component. */
5099
#define ALT_USB1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_USB1_ADDR) + 0x40000) - 1))
5100
5101
5102
5103
* Component Instance : nandregs
5104
5105
* Instance nandregs of component ALT_NAND.
5106
5107
5108
5109
5110
* Register Group Instance : config
5111
5112
* Instance config of register group ALT_NAND_CFG.
5113
5114
5115
5116
/* The address of the ALT_NAND_CFG_DEVICE_RST register for the ALT_NAND_CFG instance. */
5117
#define ALT_NAND_CFG_DEVICE_RST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DEVICE_RST_OFST))
5118
/* The address of the ALT_NAND_CFG_TFR_SPARE_REG register for the ALT_NAND_CFG instance. */
5119
#define ALT_NAND_CFG_TFR_SPARE_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_TFR_SPARE_REG_OFST))
5120
/* The address of the ALT_NAND_CFG_LD_WAIT_CNT register for the ALT_NAND_CFG instance. */
5121
#define ALT_NAND_CFG_LD_WAIT_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_LD_WAIT_CNT_OFST))
5122
/* The address of the ALT_NAND_CFG_PROGRAM_WAIT_CNT register for the ALT_NAND_CFG instance. */
5123
#define ALT_NAND_CFG_PROGRAM_WAIT_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_PROGRAM_WAIT_CNT_OFST))
5124
/* The address of the ALT_NAND_CFG_ERASE_WAIT_CNT register for the ALT_NAND_CFG instance. */
5125
#define ALT_NAND_CFG_ERASE_WAIT_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_ERASE_WAIT_CNT_OFST))
5126
/* The address of the ALT_NAND_CFG_INT_MON_CYCCNT register for the ALT_NAND_CFG instance. */
5127
#define ALT_NAND_CFG_INT_MON_CYCCNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_INT_MON_CYCCNT_OFST))
5128
/* The address of the ALT_NAND_CFG_RB_PIN_END register for the ALT_NAND_CFG instance. */
5129
#define ALT_NAND_CFG_RB_PIN_END_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RB_PIN_END_OFST))
5130
/* The address of the ALT_NAND_CFG_MULTIPLANE_OP register for the ALT_NAND_CFG instance. */
5131
#define ALT_NAND_CFG_MULTIPLANE_OP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_MULTIPLANE_OP_OFST))
5132
/* The address of the ALT_NAND_CFG_MULTIPLANE_RD_EN register for the ALT_NAND_CFG instance. */
5133
#define ALT_NAND_CFG_MULTIPLANE_RD_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_MULTIPLANE_RD_EN_OFST))
5134
/* The address of the ALT_NAND_CFG_COPYBACK_DIS register for the ALT_NAND_CFG instance. */
5135
#define ALT_NAND_CFG_COPYBACK_DIS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_COPYBACK_DIS_OFST))
5136
/* The address of the ALT_NAND_CFG_CACHE_WR_EN register for the ALT_NAND_CFG instance. */
5137
#define ALT_NAND_CFG_CACHE_WR_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_CACHE_WR_EN_OFST))
5138
/* The address of the ALT_NAND_CFG_CACHE_RD_EN register for the ALT_NAND_CFG instance. */
5139
#define ALT_NAND_CFG_CACHE_RD_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_CACHE_RD_EN_OFST))
5140
/* The address of the ALT_NAND_CFG_PREFETCH_MOD register for the ALT_NAND_CFG instance. */
5141
#define ALT_NAND_CFG_PREFETCH_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_PREFETCH_MOD_OFST))
5142
/* The address of the ALT_NAND_CFG_CHIP_EN_DONT_CARE register for the ALT_NAND_CFG instance. */
5143
#define ALT_NAND_CFG_CHIP_EN_DONT_CARE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_CHIP_EN_DONT_CARE_OFST))
5144
/* The address of the ALT_NAND_CFG_ECC_EN register for the ALT_NAND_CFG instance. */
5145
#define ALT_NAND_CFG_ECC_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_ECC_EN_OFST))
5146
/* The address of the ALT_NAND_CFG_GLOB_INT_EN register for the ALT_NAND_CFG instance. */
5147
#define ALT_NAND_CFG_GLOB_INT_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_GLOB_INT_EN_OFST))
5148
/* The address of the ALT_NAND_CFG_TWHR2_AND_WE_2_RE register for the ALT_NAND_CFG instance. */
5149
#define ALT_NAND_CFG_TWHR2_AND_WE_2_RE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_TWHR2_AND_WE_2_RE_OFST))
5150
/* The address of the ALT_NAND_CFG_TCWAW_AND_ADDR_2_DATA register for the ALT_NAND_CFG instance. */
5151
#define ALT_NAND_CFG_TCWAW_AND_ADDR_2_DATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_TCWAW_AND_ADDR_2_DATA_OFST))
5152
/* The address of the ALT_NAND_CFG_RE_2_WE register for the ALT_NAND_CFG instance. */
5153
#define ALT_NAND_CFG_RE_2_WE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RE_2_WE_OFST))
5154
/* The address of the ALT_NAND_CFG_ACC_CLKS register for the ALT_NAND_CFG instance. */
5155
#define ALT_NAND_CFG_ACC_CLKS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_ACC_CLKS_OFST))
5156
/* The address of the ALT_NAND_CFG_NUMBER_OF_PLANES register for the ALT_NAND_CFG instance. */
5157
#define ALT_NAND_CFG_NUMBER_OF_PLANES_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_NUMBER_OF_PLANES_OFST))
5158
/* The address of the ALT_NAND_CFG_PAGES_PER_BLOCK register for the ALT_NAND_CFG instance. */
5159
#define ALT_NAND_CFG_PAGES_PER_BLOCK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_PAGES_PER_BLOCK_OFST))
5160
/* The address of the ALT_NAND_CFG_DEVICE_WIDTH register for the ALT_NAND_CFG instance. */
5161
#define ALT_NAND_CFG_DEVICE_WIDTH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DEVICE_WIDTH_OFST))
5162
/* The address of the ALT_NAND_CFG_DEVICE_MAIN_AREA_SIZE register for the ALT_NAND_CFG instance. */
5163
#define ALT_NAND_CFG_DEVICE_MAIN_AREA_SIZE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DEVICE_MAIN_AREA_SIZE_OFST))
5164
/* The address of the ALT_NAND_CFG_DEVICE_SPARE_AREA_SIZE register for the ALT_NAND_CFG instance. */
5165
#define ALT_NAND_CFG_DEVICE_SPARE_AREA_SIZE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DEVICE_SPARE_AREA_SIZE_OFST))
5166
/* The address of the ALT_NAND_CFG_TWO_ROW_ADDR_CYCLES register for the ALT_NAND_CFG instance. */
5167
#define ALT_NAND_CFG_TWO_ROW_ADDR_CYCLES_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_TWO_ROW_ADDR_CYCLES_OFST))
5168
/* The address of the ALT_NAND_CFG_MULTIPLANE_ADDR_RESTRICT register for the ALT_NAND_CFG instance. */
5169
#define ALT_NAND_CFG_MULTIPLANE_ADDR_RESTRICT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_MULTIPLANE_ADDR_RESTRICT_OFST))
5170
/* The address of the ALT_NAND_CFG_ECC_CORRECTION register for the ALT_NAND_CFG instance. */
5171
#define ALT_NAND_CFG_ECC_CORRECTION_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_ECC_CORRECTION_OFST))
5172
/* The address of the ALT_NAND_CFG_RD_MOD register for the ALT_NAND_CFG instance. */
5173
#define ALT_NAND_CFG_RD_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RD_MOD_OFST))
5174
/* The address of the ALT_NAND_CFG_WR_MOD register for the ALT_NAND_CFG instance. */
5175
#define ALT_NAND_CFG_WR_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_WR_MOD_OFST))
5176
/* The address of the ALT_NAND_CFG_COPYBACK_MOD register for the ALT_NAND_CFG instance. */
5177
#define ALT_NAND_CFG_COPYBACK_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_COPYBACK_MOD_OFST))
5178
/* The address of the ALT_NAND_CFG_RDWR_EN_LO_CNT register for the ALT_NAND_CFG instance. */
5179
#define ALT_NAND_CFG_RDWR_EN_LO_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RDWR_EN_LO_CNT_OFST))
5180
/* The address of the ALT_NAND_CFG_RDWR_EN_HI_CNT register for the ALT_NAND_CFG instance. */
5181
#define ALT_NAND_CFG_RDWR_EN_HI_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RDWR_EN_HI_CNT_OFST))
5182
/* The address of the ALT_NAND_CFG_MAX_RD_DELAY register for the ALT_NAND_CFG instance. */
5183
#define ALT_NAND_CFG_MAX_RD_DELAY_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_MAX_RD_DELAY_OFST))
5184
/* The address of the ALT_NAND_CFG_CS_SETUP_CNT register for the ALT_NAND_CFG instance. */
5185
#define ALT_NAND_CFG_CS_SETUP_CNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_CS_SETUP_CNT_OFST))
5186
/* The address of the ALT_NAND_CFG_SPARE_AREA_SKIP_BYTES register for the ALT_NAND_CFG instance. */
5187
#define ALT_NAND_CFG_SPARE_AREA_SKIP_BYTES_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_SPARE_AREA_SKIP_BYTES_OFST))
5188
/* The address of the ALT_NAND_CFG_SPARE_AREA_MARKER register for the ALT_NAND_CFG instance. */
5189
#define ALT_NAND_CFG_SPARE_AREA_MARKER_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_SPARE_AREA_MARKER_OFST))
5190
/* The address of the ALT_NAND_CFG_DEVICES_CONNECTED register for the ALT_NAND_CFG instance. */
5191
#define ALT_NAND_CFG_DEVICES_CONNECTED_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DEVICES_CONNECTED_OFST))
5192
/* The address of the ALT_NAND_CFG_DIE_MSK register for the ALT_NAND_CFG instance. */
5193
#define ALT_NAND_CFG_DIE_MSK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_DIE_MSK_OFST))
5194
/* The address of the ALT_NAND_CFG_FIRST_BLOCK_OF_NEXT_PLANE register for the ALT_NAND_CFG instance. */
5195
#define ALT_NAND_CFG_FIRST_BLOCK_OF_NEXT_PLANE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_FIRST_BLOCK_OF_NEXT_PLANE_OFST))
5196
/* The address of the ALT_NAND_CFG_WR_PROTECT register for the ALT_NAND_CFG instance. */
5197
#define ALT_NAND_CFG_WR_PROTECT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_WR_PROTECT_OFST))
5198
/* The address of the ALT_NAND_CFG_RE_2_RE register for the ALT_NAND_CFG instance. */
5199
#define ALT_NAND_CFG_RE_2_RE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_RE_2_RE_OFST))
5200
/* The address of the ALT_NAND_CFG_POR_RST_COUNT register for the ALT_NAND_CFG instance. */
5201
#define ALT_NAND_CFG_POR_RST_COUNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_POR_RST_COUNT_OFST))
5202
/* The address of the ALT_NAND_CFG_WD_RST_COUNT register for the ALT_NAND_CFG instance. */
5203
#define ALT_NAND_CFG_WD_RST_COUNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_CFG_ADDR) + ALT_NAND_CFG_WD_RST_COUNT_OFST))
5204
/* The base address byte offset for the start of the ALT_NAND_CFG component. */
5205
#define ALT_NAND_CFG_OFST 0x0
5206
/* The start address of the ALT_NAND_CFG component. */
5207
#define ALT_NAND_CFG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ADDR) + ALT_NAND_CFG_OFST))
5208
/* The lower bound address range of the ALT_NAND_CFG component. */
5209
#define ALT_NAND_CFG_LB_ADDR ALT_NAND_CFG_ADDR
5210
/* The upper bound address range of the ALT_NAND_CFG component. */
5211
#define ALT_NAND_CFG_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_CFG_ADDR) + 0x2b4) - 1))
5212
5213
5214
5215
* Register Group Instance : param
5216
5217
* Instance param of register group ALT_NAND_PARAM.
5218
5219
5220
5221
/* The address of the ALT_NAND_PARAM_MANUFACTURER_ID register for the ALT_NAND_PARAM instance. */
5222
#define ALT_NAND_PARAM_MANUFACTURER_ID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_MANUFACTURER_ID_OFST))
5223
/* The address of the ALT_NAND_PARAM_DEVICE_ID register for the ALT_NAND_PARAM instance. */
5224
#define ALT_NAND_PARAM_DEVICE_ID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_DEVICE_ID_OFST))
5225
/* The address of the ALT_NAND_PARAM_DEVICE_PARAM_0 register for the ALT_NAND_PARAM instance. */
5226
#define ALT_NAND_PARAM_DEVICE_PARAM_0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_DEVICE_PARAM_0_OFST))
5227
/* The address of the ALT_NAND_PARAM_DEVICE_PARAM_1 register for the ALT_NAND_PARAM instance. */
5228
#define ALT_NAND_PARAM_DEVICE_PARAM_1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_DEVICE_PARAM_1_OFST))
5229
/* The address of the ALT_NAND_PARAM_DEVICE_PARAM_2 register for the ALT_NAND_PARAM instance. */
5230
#define ALT_NAND_PARAM_DEVICE_PARAM_2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_DEVICE_PARAM_2_OFST))
5231
/* The address of the ALT_NAND_PARAM_LOGICAL_PAGE_DATA_SIZE register for the ALT_NAND_PARAM instance. */
5232
#define ALT_NAND_PARAM_LOGICAL_PAGE_DATA_SIZE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_LOGICAL_PAGE_DATA_SIZE_OFST))
5233
/* The address of the ALT_NAND_PARAM_LOGICAL_PAGE_SPARE_SIZE register for the ALT_NAND_PARAM instance. */
5234
#define ALT_NAND_PARAM_LOGICAL_PAGE_SPARE_SIZE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_LOGICAL_PAGE_SPARE_SIZE_OFST))
5235
/* The address of the ALT_NAND_PARAM_REVISION register for the ALT_NAND_PARAM instance. */
5236
#define ALT_NAND_PARAM_REVISION_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_REVISION_OFST))
5237
/* The address of the ALT_NAND_PARAM_ONFI_DEV_FEATURES register for the ALT_NAND_PARAM instance. */
5238
#define ALT_NAND_PARAM_ONFI_DEV_FEATURES_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_DEV_FEATURES_OFST))
5239
/* The address of the ALT_NAND_PARAM_ONFI_OPTIONAL_CMDS register for the ALT_NAND_PARAM instance. */
5240
#define ALT_NAND_PARAM_ONFI_OPTIONAL_CMDS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_OPTIONAL_CMDS_OFST))
5241
/* The address of the ALT_NAND_PARAM_ONFI_TIMING_MOD register for the ALT_NAND_PARAM instance. */
5242
#define ALT_NAND_PARAM_ONFI_TIMING_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_TIMING_MOD_OFST))
5243
/* The address of the ALT_NAND_PARAM_ONFI_PGM_CACHE_TIMING_MOD register for the ALT_NAND_PARAM instance. */
5244
#define ALT_NAND_PARAM_ONFI_PGM_CACHE_TIMING_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_PGM_CACHE_TIMING_MOD_OFST))
5245
/* The address of the ALT_NAND_PARAM_ONFI_DEV_NO_OF_LUNS register for the ALT_NAND_PARAM instance. */
5246
#define ALT_NAND_PARAM_ONFI_DEV_NO_OF_LUNS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_DEV_NO_OF_LUNS_OFST))
5247
/* The address of the ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_L register for the ALT_NAND_PARAM instance. */
5248
#define ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_L_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_L_OFST))
5249
/* The address of the ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_U register for the ALT_NAND_PARAM instance. */
5250
#define ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_U_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_ONFI_DEV_BLKS_PER_LUN_U_OFST))
5251
/* The address of the ALT_NAND_PARAM_FEATURES register for the ALT_NAND_PARAM instance. */
5252
#define ALT_NAND_PARAM_FEATURES_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + ALT_NAND_PARAM_FEATURES_OFST))
5253
/* The base address byte offset for the start of the ALT_NAND_PARAM component. */
5254
#define ALT_NAND_PARAM_OFST 0x300
5255
/* The start address of the ALT_NAND_PARAM component. */
5256
#define ALT_NAND_PARAM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ADDR) + ALT_NAND_PARAM_OFST))
5257
/* The lower bound address range of the ALT_NAND_PARAM component. */
5258
#define ALT_NAND_PARAM_LB_ADDR ALT_NAND_PARAM_ADDR
5259
/* The upper bound address range of the ALT_NAND_PARAM component. */
5260
#define ALT_NAND_PARAM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_PARAM_ADDR) + 0xf4) - 1))
5261
5262
5263
5264
* Register Group Instance : status
5265
5266
* Instance status of register group ALT_NAND_STAT.
5267
5268
5269
5270
/* The address of the ALT_NAND_STAT_TFR_MOD register for the ALT_NAND_STAT instance. */
5271
#define ALT_NAND_STAT_TFR_MOD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_TFR_MOD_OFST))
5272
/* The address of the ALT_NAND_STAT_INTR_STAT0 register for the ALT_NAND_STAT instance. */
5273
#define ALT_NAND_STAT_INTR_STAT0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_STAT0_OFST))
5274
/* The address of the ALT_NAND_STAT_INTR_EN0 register for the ALT_NAND_STAT instance. */
5275
#define ALT_NAND_STAT_INTR_EN0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_EN0_OFST))
5276
/* The address of the ALT_NAND_STAT_PAGE_CNT0 register for the ALT_NAND_STAT instance. */
5277
#define ALT_NAND_STAT_PAGE_CNT0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_PAGE_CNT0_OFST))
5278
/* The address of the ALT_NAND_STAT_ERR_PAGE_ADDR0 register for the ALT_NAND_STAT instance. */
5279
#define ALT_NAND_STAT_ERR_PAGE_ADDR0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_PAGE_ADDR0_OFST))
5280
/* The address of the ALT_NAND_STAT_ERR_BLOCK_ADDR0 register for the ALT_NAND_STAT instance. */
5281
#define ALT_NAND_STAT_ERR_BLOCK_ADDR0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_BLOCK_ADDR0_OFST))
5282
/* The address of the ALT_NAND_STAT_INTR_STAT1 register for the ALT_NAND_STAT instance. */
5283
#define ALT_NAND_STAT_INTR_STAT1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_STAT1_OFST))
5284
/* The address of the ALT_NAND_STAT_INTR_EN1 register for the ALT_NAND_STAT instance. */
5285
#define ALT_NAND_STAT_INTR_EN1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_EN1_OFST))
5286
/* The address of the ALT_NAND_STAT_PAGE_CNT1 register for the ALT_NAND_STAT instance. */
5287
#define ALT_NAND_STAT_PAGE_CNT1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_PAGE_CNT1_OFST))
5288
/* The address of the ALT_NAND_STAT_ERR_PAGE_ADDR1 register for the ALT_NAND_STAT instance. */
5289
#define ALT_NAND_STAT_ERR_PAGE_ADDR1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_PAGE_ADDR1_OFST))
5290
/* The address of the ALT_NAND_STAT_ERR_BLOCK_ADDR1 register for the ALT_NAND_STAT instance. */
5291
#define ALT_NAND_STAT_ERR_BLOCK_ADDR1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_BLOCK_ADDR1_OFST))
5292
/* The address of the ALT_NAND_STAT_INTR_STAT2 register for the ALT_NAND_STAT instance. */
5293
#define ALT_NAND_STAT_INTR_STAT2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_STAT2_OFST))
5294
/* The address of the ALT_NAND_STAT_INTR_EN2 register for the ALT_NAND_STAT instance. */
5295
#define ALT_NAND_STAT_INTR_EN2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_EN2_OFST))
5296
/* The address of the ALT_NAND_STAT_PAGE_CNT2 register for the ALT_NAND_STAT instance. */
5297
#define ALT_NAND_STAT_PAGE_CNT2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_PAGE_CNT2_OFST))
5298
/* The address of the ALT_NAND_STAT_ERR_PAGE_ADDR2 register for the ALT_NAND_STAT instance. */
5299
#define ALT_NAND_STAT_ERR_PAGE_ADDR2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_PAGE_ADDR2_OFST))
5300
/* The address of the ALT_NAND_STAT_ERR_BLOCK_ADDR2 register for the ALT_NAND_STAT instance. */
5301
#define ALT_NAND_STAT_ERR_BLOCK_ADDR2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_BLOCK_ADDR2_OFST))
5302
/* The address of the ALT_NAND_STAT_INTR_STAT3 register for the ALT_NAND_STAT instance. */
5303
#define ALT_NAND_STAT_INTR_STAT3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_STAT3_OFST))
5304
/* The address of the ALT_NAND_STAT_INTR_EN3 register for the ALT_NAND_STAT instance. */
5305
#define ALT_NAND_STAT_INTR_EN3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_INTR_EN3_OFST))
5306
/* The address of the ALT_NAND_STAT_PAGE_CNT3 register for the ALT_NAND_STAT instance. */
5307
#define ALT_NAND_STAT_PAGE_CNT3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_PAGE_CNT3_OFST))
5308
/* The address of the ALT_NAND_STAT_ERR_PAGE_ADDR3 register for the ALT_NAND_STAT instance. */
5309
#define ALT_NAND_STAT_ERR_PAGE_ADDR3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_PAGE_ADDR3_OFST))
5310
/* The address of the ALT_NAND_STAT_ERR_BLOCK_ADDR3 register for the ALT_NAND_STAT instance. */
5311
#define ALT_NAND_STAT_ERR_BLOCK_ADDR3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_STAT_ADDR) + ALT_NAND_STAT_ERR_BLOCK_ADDR3_OFST))
5312
/* The base address byte offset for the start of the ALT_NAND_STAT component. */
5313
#define ALT_NAND_STAT_OFST 0x400
5314
/* The start address of the ALT_NAND_STAT component. */
5315
#define ALT_NAND_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ADDR) + ALT_NAND_STAT_OFST))
5316
/* The lower bound address range of the ALT_NAND_STAT component. */
5317
#define ALT_NAND_STAT_LB_ADDR ALT_NAND_STAT_ADDR
5318
/* The upper bound address range of the ALT_NAND_STAT component. */
5319
#define ALT_NAND_STAT_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_STAT_ADDR) + 0x144) - 1))
5320
5321
5322
5323
* Register Group Instance : ecc
5324
5325
* Instance ecc of register group ALT_NAND_ECC.
5326
5327
5328
5329
/* The address of the ALT_NAND_ECC_ECCCORINFO_B01 register for the ALT_NAND_ECC instance. */
5330
#define ALT_NAND_ECC_ECCCORINFO_B01_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ECC_ADDR) + ALT_NAND_ECC_ECCCORINFO_B01_OFST))
5331
/* The address of the ALT_NAND_ECC_ECCCORINFO_B23 register for the ALT_NAND_ECC instance. */
5332
#define ALT_NAND_ECC_ECCCORINFO_B23_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ECC_ADDR) + ALT_NAND_ECC_ECCCORINFO_B23_OFST))
5333
/* The base address byte offset for the start of the ALT_NAND_ECC component. */
5334
#define ALT_NAND_ECC_OFST 0x650
5335
/* The start address of the ALT_NAND_ECC component. */
5336
#define ALT_NAND_ECC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ADDR) + ALT_NAND_ECC_OFST))
5337
/* The lower bound address range of the ALT_NAND_ECC component. */
5338
#define ALT_NAND_ECC_LB_ADDR ALT_NAND_ECC_ADDR
5339
/* The upper bound address range of the ALT_NAND_ECC component. */
5340
#define ALT_NAND_ECC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_ECC_ADDR) + 0x14) - 1))
5341
5342
5343
5344
* Register Group Instance : dma
5345
5346
* Instance dma of register group ALT_NAND_DMA.
5347
5348
5349
5350
/* The address of the ALT_NAND_DMA_DMA_EN register for the ALT_NAND_DMA instance. */
5351
#define ALT_NAND_DMA_DMA_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_DMA_EN_OFST))
5352
/* The address of the ALT_NAND_DMA_DMA_INTR register for the ALT_NAND_DMA instance. */
5353
#define ALT_NAND_DMA_DMA_INTR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_DMA_INTR_OFST))
5354
/* The address of the ALT_NAND_DMA_DMA_INTR_EN register for the ALT_NAND_DMA instance. */
5355
#define ALT_NAND_DMA_DMA_INTR_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_DMA_INTR_EN_OFST))
5356
/* The address of the ALT_NAND_DMA_TGT_ERR_ADDR_LO register for the ALT_NAND_DMA instance. */
5357
#define ALT_NAND_DMA_TGT_ERR_ADDR_LO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_TGT_ERR_ADDR_LO_OFST))
5358
/* The address of the ALT_NAND_DMA_TGT_ERR_ADDR_HI register for the ALT_NAND_DMA instance. */
5359
#define ALT_NAND_DMA_TGT_ERR_ADDR_HI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_TGT_ERR_ADDR_HI_OFST))
5360
/* The address of the ALT_NAND_DMA_FLSH_BURST_LEN register for the ALT_NAND_DMA instance. */
5361
#define ALT_NAND_DMA_FLSH_BURST_LEN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_FLSH_BURST_LEN_OFST))
5362
/* The address of the ALT_NAND_DMA_INTRLV register for the ALT_NAND_DMA instance. */
5363
#define ALT_NAND_DMA_INTRLV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_INTRLV_OFST))
5364
/* The address of the ALT_NAND_DMA_NO_OF_BLOCKS_PER_LUN register for the ALT_NAND_DMA instance. */
5365
#define ALT_NAND_DMA_NO_OF_BLOCKS_PER_LUN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_NO_OF_BLOCKS_PER_LUN_OFST))
5366
/* The address of the ALT_NAND_DMA_LUN_STAT_CMD register for the ALT_NAND_DMA instance. */
5367
#define ALT_NAND_DMA_LUN_STAT_CMD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_DMA_ADDR) + ALT_NAND_DMA_LUN_STAT_CMD_OFST))
5368
/* The base address byte offset for the start of the ALT_NAND_DMA component. */
5369
#define ALT_NAND_DMA_OFST 0x700
5370
/* The start address of the ALT_NAND_DMA component. */
5371
#define ALT_NAND_DMA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_NAND_ADDR) + ALT_NAND_DMA_OFST))
5372
/* The lower bound address range of the ALT_NAND_DMA component. */
5373
#define ALT_NAND_DMA_LB_ADDR ALT_NAND_DMA_ADDR
5374
/* The upper bound address range of the ALT_NAND_DMA component. */
5375
#define ALT_NAND_DMA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_DMA_ADDR) + 0xa4) - 1))
5376
5377
5378
/* The base address byte offset for the start of the ALT_NAND component. */
5379
#define ALT_NAND_OFST 0xffb80000
5380
/* The start address of the ALT_NAND component. */
5381
#define ALT_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_NAND_OFST))
5382
/* The lower bound address range of the ALT_NAND component. */
5383
#define ALT_NAND_LB_ADDR ALT_NAND_ADDR
5384
/* The upper bound address range of the ALT_NAND component. */
5385
#define ALT_NAND_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_NAND_ADDR) + 0x800) - 1))
5386
5387
5388
5389
* Component Instance : fpgamgrdata
5390
5391
* Instance fpgamgrdata of component ALT_FPGAMGRDATA.
5392
5393
5394
5395
/* The address of the ALT_FPGAMGRDATA_DATA register for the ALT_FPGAMGRDATA instance. */
5396
#define ALT_FPGAMGRDATA_DATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_FPGAMGRDATA_ADDR) + ALT_FPGAMGRDATA_DATA_OFST))
5397
/* The base address byte offset for the start of the ALT_FPGAMGRDATA component. */
5398
#define ALT_FPGAMGRDATA_OFST 0xffb90000
5399
/* The start address of the ALT_FPGAMGRDATA component. */
5400
#define ALT_FPGAMGRDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_FPGAMGRDATA_OFST))
5401
/* The lower bound address range of the ALT_FPGAMGRDATA component. */
5402
#define ALT_FPGAMGRDATA_LB_ADDR ALT_FPGAMGRDATA_ADDR
5403
/* The upper bound address range of the ALT_FPGAMGRDATA component. */
5404
#define ALT_FPGAMGRDATA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_FPGAMGRDATA_ADDR) + 0x4) - 1))
5405
5406
5407
5408
* Component Instance : can0
5409
5410
* Instance can0 of component ALT_CAN.
5411
5412
5413
5414
5415
* Register Group Instance : protogrp
5416
5417
* Instance protogrp of register group ALT_CAN_PROTO.
5418
5419
5420
5421
/* The address of the ALT_CAN_PROTO_CCTL register for the ALT_CAN0_PROTOGRP instance. */
5422
#define ALT_CAN0_PROTO_CCTL_ADDR ALT_CAN_PROTO_CCTL_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5423
/* The address of the ALT_CAN_PROTO_CSTS register for the ALT_CAN0_PROTOGRP instance. */
5424
#define ALT_CAN0_PROTO_CSTS_ADDR ALT_CAN_PROTO_CSTS_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5425
/* The address of the ALT_CAN_PROTO_CERC register for the ALT_CAN0_PROTOGRP instance. */
5426
#define ALT_CAN0_PROTO_CERC_ADDR ALT_CAN_PROTO_CERC_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5427
/* The address of the ALT_CAN_PROTO_CBT register for the ALT_CAN0_PROTOGRP instance. */
5428
#define ALT_CAN0_PROTO_CBT_ADDR ALT_CAN_PROTO_CBT_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5429
/* The address of the ALT_CAN_PROTO_CIR register for the ALT_CAN0_PROTOGRP instance. */
5430
#define ALT_CAN0_PROTO_CIR_ADDR ALT_CAN_PROTO_CIR_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5431
/* The address of the ALT_CAN_PROTO_CTR register for the ALT_CAN0_PROTOGRP instance. */
5432
#define ALT_CAN0_PROTO_CTR_ADDR ALT_CAN_PROTO_CTR_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5433
/* The address of the ALT_CAN_PROTO_CFR register for the ALT_CAN0_PROTOGRP instance. */
5434
#define ALT_CAN0_PROTO_CFR_ADDR ALT_CAN_PROTO_CFR_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5435
/* The address of the ALT_CAN_PROTO_CRR register for the ALT_CAN0_PROTOGRP instance. */
5436
#define ALT_CAN0_PROTO_CRR_ADDR ALT_CAN_PROTO_CRR_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5437
/* The address of the ALT_CAN_PROTO_HWS register for the ALT_CAN0_PROTOGRP instance. */
5438
#define ALT_CAN0_PROTO_HWS_ADDR ALT_CAN_PROTO_HWS_ADDR(ALT_CAN0_PROTOGRP_ADDR)
5439
/* The base address byte offset for the start of the ALT_CAN0_PROTOGRP component. */
5440
#define ALT_CAN0_PROTOGRP_OFST 0x0
5441
/* The start address of the ALT_CAN0_PROTOGRP component. */
5442
#define ALT_CAN0_PROTOGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN0_ADDR) + ALT_CAN0_PROTOGRP_OFST))
5443
/* The lower bound address range of the ALT_CAN0_PROTOGRP component. */
5444
#define ALT_CAN0_PROTOGRP_LB_ADDR ALT_CAN0_PROTOGRP_ADDR
5445
/* The upper bound address range of the ALT_CAN0_PROTOGRP component. */
5446
#define ALT_CAN0_PROTOGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN0_PROTOGRP_ADDR) + 0x28) - 1))
5447
5448
5449
5450
* Register Group Instance : msghandgrp
5451
5452
* Instance msghandgrp of register group ALT_CAN_MSGHAND.
5453
5454
5455
5456
/* The address of the ALT_CAN_MSGHAND_MOTRX register for the ALT_CAN0_MSGHANDGRP instance. */
5457
#define ALT_CAN0_MSGHAND_MOTRX_ADDR ALT_CAN_MSGHAND_MOTRX_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5458
/* The address of the ALT_CAN_MSGHAND_MOTRA register for the ALT_CAN0_MSGHANDGRP instance. */
5459
#define ALT_CAN0_MSGHAND_MOTRA_ADDR ALT_CAN_MSGHAND_MOTRA_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5460
/* The address of the ALT_CAN_MSGHAND_MOTRB register for the ALT_CAN0_MSGHANDGRP instance. */
5461
#define ALT_CAN0_MSGHAND_MOTRB_ADDR ALT_CAN_MSGHAND_MOTRB_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5462
/* The address of the ALT_CAN_MSGHAND_MOTRC register for the ALT_CAN0_MSGHANDGRP instance. */
5463
#define ALT_CAN0_MSGHAND_MOTRC_ADDR ALT_CAN_MSGHAND_MOTRC_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5464
/* The address of the ALT_CAN_MSGHAND_MOTRD register for the ALT_CAN0_MSGHANDGRP instance. */
5465
#define ALT_CAN0_MSGHAND_MOTRD_ADDR ALT_CAN_MSGHAND_MOTRD_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5466
/* The address of the ALT_CAN_MSGHAND_MONDX register for the ALT_CAN0_MSGHANDGRP instance. */
5467
#define ALT_CAN0_MSGHAND_MONDX_ADDR ALT_CAN_MSGHAND_MONDX_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5468
/* The address of the ALT_CAN_MSGHAND_MONDA register for the ALT_CAN0_MSGHANDGRP instance. */
5469
#define ALT_CAN0_MSGHAND_MONDA_ADDR ALT_CAN_MSGHAND_MONDA_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5470
/* The address of the ALT_CAN_MSGHAND_MONDB register for the ALT_CAN0_MSGHANDGRP instance. */
5471
#define ALT_CAN0_MSGHAND_MONDB_ADDR ALT_CAN_MSGHAND_MONDB_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5472
/* The address of the ALT_CAN_MSGHAND_MONDC register for the ALT_CAN0_MSGHANDGRP instance. */
5473
#define ALT_CAN0_MSGHAND_MONDC_ADDR ALT_CAN_MSGHAND_MONDC_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5474
/* The address of the ALT_CAN_MSGHAND_MONDD register for the ALT_CAN0_MSGHANDGRP instance. */
5475
#define ALT_CAN0_MSGHAND_MONDD_ADDR ALT_CAN_MSGHAND_MONDD_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5476
/* The address of the ALT_CAN_MSGHAND_MOIPX register for the ALT_CAN0_MSGHANDGRP instance. */
5477
#define ALT_CAN0_MSGHAND_MOIPX_ADDR ALT_CAN_MSGHAND_MOIPX_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5478
/* The address of the ALT_CAN_MSGHAND_MOIPA register for the ALT_CAN0_MSGHANDGRP instance. */
5479
#define ALT_CAN0_MSGHAND_MOIPA_ADDR ALT_CAN_MSGHAND_MOIPA_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5480
/* The address of the ALT_CAN_MSGHAND_MOIPB register for the ALT_CAN0_MSGHANDGRP instance. */
5481
#define ALT_CAN0_MSGHAND_MOIPB_ADDR ALT_CAN_MSGHAND_MOIPB_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5482
/* The address of the ALT_CAN_MSGHAND_MOIPC register for the ALT_CAN0_MSGHANDGRP instance. */
5483
#define ALT_CAN0_MSGHAND_MOIPC_ADDR ALT_CAN_MSGHAND_MOIPC_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5484
/* The address of the ALT_CAN_MSGHAND_MOIPD register for the ALT_CAN0_MSGHANDGRP instance. */
5485
#define ALT_CAN0_MSGHAND_MOIPD_ADDR ALT_CAN_MSGHAND_MOIPD_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5486
/* The address of the ALT_CAN_MSGHAND_MOVALX register for the ALT_CAN0_MSGHANDGRP instance. */
5487
#define ALT_CAN0_MSGHAND_MOVALX_ADDR ALT_CAN_MSGHAND_MOVALX_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5488
/* The address of the ALT_CAN_MSGHAND_MOVALA register for the ALT_CAN0_MSGHANDGRP instance. */
5489
#define ALT_CAN0_MSGHAND_MOVALA_ADDR ALT_CAN_MSGHAND_MOVALA_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5490
/* The address of the ALT_CAN_MSGHAND_MOVALB register for the ALT_CAN0_MSGHANDGRP instance. */
5491
#define ALT_CAN0_MSGHAND_MOVALB_ADDR ALT_CAN_MSGHAND_MOVALB_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5492
/* The address of the ALT_CAN_MSGHAND_MOVALC register for the ALT_CAN0_MSGHANDGRP instance. */
5493
#define ALT_CAN0_MSGHAND_MOVALC_ADDR ALT_CAN_MSGHAND_MOVALC_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5494
/* The address of the ALT_CAN_MSGHAND_MOVALD register for the ALT_CAN0_MSGHANDGRP instance. */
5495
#define ALT_CAN0_MSGHAND_MOVALD_ADDR ALT_CAN_MSGHAND_MOVALD_ADDR(ALT_CAN0_MSGHANDGRP_ADDR)
5496
/* The base address byte offset for the start of the ALT_CAN0_MSGHANDGRP component. */
5497
#define ALT_CAN0_MSGHANDGRP_OFST 0x84
5498
/* The start address of the ALT_CAN0_MSGHANDGRP component. */
5499
#define ALT_CAN0_MSGHANDGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN0_ADDR) + ALT_CAN0_MSGHANDGRP_OFST))
5500
/* The lower bound address range of the ALT_CAN0_MSGHANDGRP component. */
5501
#define ALT_CAN0_MSGHANDGRP_LB_ADDR ALT_CAN0_MSGHANDGRP_ADDR
5502
/* The upper bound address range of the ALT_CAN0_MSGHANDGRP component. */
5503
#define ALT_CAN0_MSGHANDGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN0_MSGHANDGRP_ADDR) + 0x50) - 1))
5504
5505
5506
5507
* Register Group Instance : msgifgrp
5508
5509
* Instance msgifgrp of register group ALT_CAN_MSGIF.
5510
5511
5512
5513
/* The address of the ALT_CAN_MSGIF_IF1CMR register for the ALT_CAN0_MSGIFGRP instance. */
5514
#define ALT_CAN0_MSGIF_IF1CMR_ADDR ALT_CAN_MSGIF_IF1CMR_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5515
/* The address of the ALT_CAN_MSGIF_IF1MSK register for the ALT_CAN0_MSGIFGRP instance. */
5516
#define ALT_CAN0_MSGIF_IF1MSK_ADDR ALT_CAN_MSGIF_IF1MSK_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5517
/* The address of the ALT_CAN_MSGIF_IF1ARB register for the ALT_CAN0_MSGIFGRP instance. */
5518
#define ALT_CAN0_MSGIF_IF1ARB_ADDR ALT_CAN_MSGIF_IF1ARB_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5519
/* The address of the ALT_CAN_MSGIF_IF1MCTR register for the ALT_CAN0_MSGIFGRP instance. */
5520
#define ALT_CAN0_MSGIF_IF1MCTR_ADDR ALT_CAN_MSGIF_IF1MCTR_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5521
/* The address of the ALT_CAN_MSGIF_IF1DA register for the ALT_CAN0_MSGIFGRP instance. */
5522
#define ALT_CAN0_MSGIF_IF1DA_ADDR ALT_CAN_MSGIF_IF1DA_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5523
/* The address of the ALT_CAN_MSGIF_IF1DB register for the ALT_CAN0_MSGIFGRP instance. */
5524
#define ALT_CAN0_MSGIF_IF1DB_ADDR ALT_CAN_MSGIF_IF1DB_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5525
/* The address of the ALT_CAN_MSGIF_IF2CMR register for the ALT_CAN0_MSGIFGRP instance. */
5526
#define ALT_CAN0_MSGIF_IF2CMR_ADDR ALT_CAN_MSGIF_IF2CMR_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5527
/* The address of the ALT_CAN_MSGIF_IF2MSK register for the ALT_CAN0_MSGIFGRP instance. */
5528
#define ALT_CAN0_MSGIF_IF2MSK_ADDR ALT_CAN_MSGIF_IF2MSK_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5529
/* The address of the ALT_CAN_MSGIF_IF2ARB register for the ALT_CAN0_MSGIFGRP instance. */
5530
#define ALT_CAN0_MSGIF_IF2ARB_ADDR ALT_CAN_MSGIF_IF2ARB_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5531
/* The address of the ALT_CAN_MSGIF_IF2MCTR register for the ALT_CAN0_MSGIFGRP instance. */
5532
#define ALT_CAN0_MSGIF_IF2MCTR_ADDR ALT_CAN_MSGIF_IF2MCTR_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5533
/* The address of the ALT_CAN_MSGIF_IF2DA register for the ALT_CAN0_MSGIFGRP instance. */
5534
#define ALT_CAN0_MSGIF_IF2DA_ADDR ALT_CAN_MSGIF_IF2DA_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5535
/* The address of the ALT_CAN_MSGIF_IF2DB register for the ALT_CAN0_MSGIFGRP instance. */
5536
#define ALT_CAN0_MSGIF_IF2DB_ADDR ALT_CAN_MSGIF_IF2DB_ADDR(ALT_CAN0_MSGIFGRP_ADDR)
5537
/* The base address byte offset for the start of the ALT_CAN0_MSGIFGRP component. */
5538
#define ALT_CAN0_MSGIFGRP_OFST 0x100
5539
/* The start address of the ALT_CAN0_MSGIFGRP component. */
5540
#define ALT_CAN0_MSGIFGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN0_ADDR) + ALT_CAN0_MSGIFGRP_OFST))
5541
/* The lower bound address range of the ALT_CAN0_MSGIFGRP component. */
5542
#define ALT_CAN0_MSGIFGRP_LB_ADDR ALT_CAN0_MSGIFGRP_ADDR
5543
/* The upper bound address range of the ALT_CAN0_MSGIFGRP component. */
5544
#define ALT_CAN0_MSGIFGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN0_MSGIFGRP_ADDR) + 0x38) - 1))
5545
5546
5547
/* The base address byte offset for the start of the ALT_CAN0 component. */
5548
#define ALT_CAN0_OFST 0xffc00000
5549
/* The start address of the ALT_CAN0 component. */
5550
#define ALT_CAN0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_CAN0_OFST))
5551
/* The lower bound address range of the ALT_CAN0 component. */
5552
#define ALT_CAN0_LB_ADDR ALT_CAN0_ADDR
5553
/* The upper bound address range of the ALT_CAN0 component. */
5554
#define ALT_CAN0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN0_ADDR) + 0x200) - 1))
5555
5556
5557
5558
* Component Instance : can1
5559
5560
* Instance can1 of component ALT_CAN.
5561
5562
5563
5564
5565
5566
5567
5568
5569
5570
5571
/* The address of the ALT_CAN_PROTO_CCTL register for the ALT_CAN1_PROTOGRP instance. */
5572
#define ALT_CAN1_PROTO_CCTL_ADDR ALT_CAN_PROTO_CCTL_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5573
/* The address of the ALT_CAN_PROTO_CSTS register for the ALT_CAN1_PROTOGRP instance. */
5574
#define ALT_CAN1_PROTO_CSTS_ADDR ALT_CAN_PROTO_CSTS_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5575
/* The address of the ALT_CAN_PROTO_CERC register for the ALT_CAN1_PROTOGRP instance. */
5576
#define ALT_CAN1_PROTO_CERC_ADDR ALT_CAN_PROTO_CERC_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5577
/* The address of the ALT_CAN_PROTO_CBT register for the ALT_CAN1_PROTOGRP instance. */
5578
#define ALT_CAN1_PROTO_CBT_ADDR ALT_CAN_PROTO_CBT_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5579
/* The address of the ALT_CAN_PROTO_CIR register for the ALT_CAN1_PROTOGRP instance. */
5580
#define ALT_CAN1_PROTO_CIR_ADDR ALT_CAN_PROTO_CIR_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5581
/* The address of the ALT_CAN_PROTO_CTR register for the ALT_CAN1_PROTOGRP instance. */
5582
#define ALT_CAN1_PROTO_CTR_ADDR ALT_CAN_PROTO_CTR_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5583
/* The address of the ALT_CAN_PROTO_CFR register for the ALT_CAN1_PROTOGRP instance. */
5584
#define ALT_CAN1_PROTO_CFR_ADDR ALT_CAN_PROTO_CFR_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5585
/* The address of the ALT_CAN_PROTO_CRR register for the ALT_CAN1_PROTOGRP instance. */
5586
#define ALT_CAN1_PROTO_CRR_ADDR ALT_CAN_PROTO_CRR_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5587
/* The address of the ALT_CAN_PROTO_HWS register for the ALT_CAN1_PROTOGRP instance. */
5588
#define ALT_CAN1_PROTO_HWS_ADDR ALT_CAN_PROTO_HWS_ADDR(ALT_CAN1_PROTOGRP_ADDR)
5589
/* The base address byte offset for the start of the ALT_CAN1_PROTOGRP component. */
5590
#define ALT_CAN1_PROTOGRP_OFST 0x0
5591
/* The start address of the ALT_CAN1_PROTOGRP component. */
5592
#define ALT_CAN1_PROTOGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN1_ADDR) + ALT_CAN1_PROTOGRP_OFST))
5593
/* The lower bound address range of the ALT_CAN1_PROTOGRP component. */
5594
#define ALT_CAN1_PROTOGRP_LB_ADDR ALT_CAN1_PROTOGRP_ADDR
5595
/* The upper bound address range of the ALT_CAN1_PROTOGRP component. */
5596
#define ALT_CAN1_PROTOGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN1_PROTOGRP_ADDR) + 0x28) - 1))
5597
5598
5599
5600
5601
5602
5603
5604
5605
5606
/* The address of the ALT_CAN_MSGHAND_MOTRX register for the ALT_CAN1_MSGHANDGRP instance. */
5607
#define ALT_CAN1_MSGHAND_MOTRX_ADDR ALT_CAN_MSGHAND_MOTRX_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5608
/* The address of the ALT_CAN_MSGHAND_MOTRA register for the ALT_CAN1_MSGHANDGRP instance. */
5609
#define ALT_CAN1_MSGHAND_MOTRA_ADDR ALT_CAN_MSGHAND_MOTRA_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5610
/* The address of the ALT_CAN_MSGHAND_MOTRB register for the ALT_CAN1_MSGHANDGRP instance. */
5611
#define ALT_CAN1_MSGHAND_MOTRB_ADDR ALT_CAN_MSGHAND_MOTRB_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5612
/* The address of the ALT_CAN_MSGHAND_MOTRC register for the ALT_CAN1_MSGHANDGRP instance. */
5613
#define ALT_CAN1_MSGHAND_MOTRC_ADDR ALT_CAN_MSGHAND_MOTRC_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5614
/* The address of the ALT_CAN_MSGHAND_MOTRD register for the ALT_CAN1_MSGHANDGRP instance. */
5615
#define ALT_CAN1_MSGHAND_MOTRD_ADDR ALT_CAN_MSGHAND_MOTRD_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5616
/* The address of the ALT_CAN_MSGHAND_MONDX register for the ALT_CAN1_MSGHANDGRP instance. */
5617
#define ALT_CAN1_MSGHAND_MONDX_ADDR ALT_CAN_MSGHAND_MONDX_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5618
/* The address of the ALT_CAN_MSGHAND_MONDA register for the ALT_CAN1_MSGHANDGRP instance. */
5619
#define ALT_CAN1_MSGHAND_MONDA_ADDR ALT_CAN_MSGHAND_MONDA_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5620
/* The address of the ALT_CAN_MSGHAND_MONDB register for the ALT_CAN1_MSGHANDGRP instance. */
5621
#define ALT_CAN1_MSGHAND_MONDB_ADDR ALT_CAN_MSGHAND_MONDB_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5622
/* The address of the ALT_CAN_MSGHAND_MONDC register for the ALT_CAN1_MSGHANDGRP instance. */
5623
#define ALT_CAN1_MSGHAND_MONDC_ADDR ALT_CAN_MSGHAND_MONDC_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5624
/* The address of the ALT_CAN_MSGHAND_MONDD register for the ALT_CAN1_MSGHANDGRP instance. */
5625
#define ALT_CAN1_MSGHAND_MONDD_ADDR ALT_CAN_MSGHAND_MONDD_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5626
/* The address of the ALT_CAN_MSGHAND_MOIPX register for the ALT_CAN1_MSGHANDGRP instance. */
5627
#define ALT_CAN1_MSGHAND_MOIPX_ADDR ALT_CAN_MSGHAND_MOIPX_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5628
/* The address of the ALT_CAN_MSGHAND_MOIPA register for the ALT_CAN1_MSGHANDGRP instance. */
5629
#define ALT_CAN1_MSGHAND_MOIPA_ADDR ALT_CAN_MSGHAND_MOIPA_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5630
/* The address of the ALT_CAN_MSGHAND_MOIPB register for the ALT_CAN1_MSGHANDGRP instance. */
5631
#define ALT_CAN1_MSGHAND_MOIPB_ADDR ALT_CAN_MSGHAND_MOIPB_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5632
/* The address of the ALT_CAN_MSGHAND_MOIPC register for the ALT_CAN1_MSGHANDGRP instance. */
5633
#define ALT_CAN1_MSGHAND_MOIPC_ADDR ALT_CAN_MSGHAND_MOIPC_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5634
/* The address of the ALT_CAN_MSGHAND_MOIPD register for the ALT_CAN1_MSGHANDGRP instance. */
5635
#define ALT_CAN1_MSGHAND_MOIPD_ADDR ALT_CAN_MSGHAND_MOIPD_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5636
/* The address of the ALT_CAN_MSGHAND_MOVALX register for the ALT_CAN1_MSGHANDGRP instance. */
5637
#define ALT_CAN1_MSGHAND_MOVALX_ADDR ALT_CAN_MSGHAND_MOVALX_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5638
/* The address of the ALT_CAN_MSGHAND_MOVALA register for the ALT_CAN1_MSGHANDGRP instance. */
5639
#define ALT_CAN1_MSGHAND_MOVALA_ADDR ALT_CAN_MSGHAND_MOVALA_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5640
/* The address of the ALT_CAN_MSGHAND_MOVALB register for the ALT_CAN1_MSGHANDGRP instance. */
5641
#define ALT_CAN1_MSGHAND_MOVALB_ADDR ALT_CAN_MSGHAND_MOVALB_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5642
/* The address of the ALT_CAN_MSGHAND_MOVALC register for the ALT_CAN1_MSGHANDGRP instance. */
5643
#define ALT_CAN1_MSGHAND_MOVALC_ADDR ALT_CAN_MSGHAND_MOVALC_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5644
/* The address of the ALT_CAN_MSGHAND_MOVALD register for the ALT_CAN1_MSGHANDGRP instance. */
5645
#define ALT_CAN1_MSGHAND_MOVALD_ADDR ALT_CAN_MSGHAND_MOVALD_ADDR(ALT_CAN1_MSGHANDGRP_ADDR)
5646
/* The base address byte offset for the start of the ALT_CAN1_MSGHANDGRP component. */
5647
#define ALT_CAN1_MSGHANDGRP_OFST 0x84
5648
/* The start address of the ALT_CAN1_MSGHANDGRP component. */
5649
#define ALT_CAN1_MSGHANDGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN1_ADDR) + ALT_CAN1_MSGHANDGRP_OFST))
5650
/* The lower bound address range of the ALT_CAN1_MSGHANDGRP component. */
5651
#define ALT_CAN1_MSGHANDGRP_LB_ADDR ALT_CAN1_MSGHANDGRP_ADDR
5652
/* The upper bound address range of the ALT_CAN1_MSGHANDGRP component. */
5653
#define ALT_CAN1_MSGHANDGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN1_MSGHANDGRP_ADDR) + 0x50) - 1))
5654
5655
5656
5657
5658
5659
5660
5661
5662
5663
/* The address of the ALT_CAN_MSGIF_IF1CMR register for the ALT_CAN1_MSGIFGRP instance. */
5664
#define ALT_CAN1_MSGIF_IF1CMR_ADDR ALT_CAN_MSGIF_IF1CMR_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5665
/* The address of the ALT_CAN_MSGIF_IF1MSK register for the ALT_CAN1_MSGIFGRP instance. */
5666
#define ALT_CAN1_MSGIF_IF1MSK_ADDR ALT_CAN_MSGIF_IF1MSK_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5667
/* The address of the ALT_CAN_MSGIF_IF1ARB register for the ALT_CAN1_MSGIFGRP instance. */
5668
#define ALT_CAN1_MSGIF_IF1ARB_ADDR ALT_CAN_MSGIF_IF1ARB_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5669
/* The address of the ALT_CAN_MSGIF_IF1MCTR register for the ALT_CAN1_MSGIFGRP instance. */
5670
#define ALT_CAN1_MSGIF_IF1MCTR_ADDR ALT_CAN_MSGIF_IF1MCTR_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5671
/* The address of the ALT_CAN_MSGIF_IF1DA register for the ALT_CAN1_MSGIFGRP instance. */
5672
#define ALT_CAN1_MSGIF_IF1DA_ADDR ALT_CAN_MSGIF_IF1DA_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5673
/* The address of the ALT_CAN_MSGIF_IF1DB register for the ALT_CAN1_MSGIFGRP instance. */
5674
#define ALT_CAN1_MSGIF_IF1DB_ADDR ALT_CAN_MSGIF_IF1DB_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5675
/* The address of the ALT_CAN_MSGIF_IF2CMR register for the ALT_CAN1_MSGIFGRP instance. */
5676
#define ALT_CAN1_MSGIF_IF2CMR_ADDR ALT_CAN_MSGIF_IF2CMR_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5677
/* The address of the ALT_CAN_MSGIF_IF2MSK register for the ALT_CAN1_MSGIFGRP instance. */
5678
#define ALT_CAN1_MSGIF_IF2MSK_ADDR ALT_CAN_MSGIF_IF2MSK_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5679
/* The address of the ALT_CAN_MSGIF_IF2ARB register for the ALT_CAN1_MSGIFGRP instance. */
5680
#define ALT_CAN1_MSGIF_IF2ARB_ADDR ALT_CAN_MSGIF_IF2ARB_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5681
/* The address of the ALT_CAN_MSGIF_IF2MCTR register for the ALT_CAN1_MSGIFGRP instance. */
5682
#define ALT_CAN1_MSGIF_IF2MCTR_ADDR ALT_CAN_MSGIF_IF2MCTR_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5683
/* The address of the ALT_CAN_MSGIF_IF2DA register for the ALT_CAN1_MSGIFGRP instance. */
5684
#define ALT_CAN1_MSGIF_IF2DA_ADDR ALT_CAN_MSGIF_IF2DA_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5685
/* The address of the ALT_CAN_MSGIF_IF2DB register for the ALT_CAN1_MSGIFGRP instance. */
5686
#define ALT_CAN1_MSGIF_IF2DB_ADDR ALT_CAN_MSGIF_IF2DB_ADDR(ALT_CAN1_MSGIFGRP_ADDR)
5687
/* The base address byte offset for the start of the ALT_CAN1_MSGIFGRP component. */
5688
#define ALT_CAN1_MSGIFGRP_OFST 0x100
5689
/* The start address of the ALT_CAN1_MSGIFGRP component. */
5690
#define ALT_CAN1_MSGIFGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CAN1_ADDR) + ALT_CAN1_MSGIFGRP_OFST))
5691
/* The lower bound address range of the ALT_CAN1_MSGIFGRP component. */
5692
#define ALT_CAN1_MSGIFGRP_LB_ADDR ALT_CAN1_MSGIFGRP_ADDR
5693
/* The upper bound address range of the ALT_CAN1_MSGIFGRP component. */
5694
#define ALT_CAN1_MSGIFGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN1_MSGIFGRP_ADDR) + 0x38) - 1))
5695
5696
5697
/* The base address byte offset for the start of the ALT_CAN1 component. */
5698
#define ALT_CAN1_OFST 0xffc01000
5699
/* The start address of the ALT_CAN1 component. */
5700
#define ALT_CAN1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_CAN1_OFST))
5701
/* The lower bound address range of the ALT_CAN1 component. */
5702
#define ALT_CAN1_LB_ADDR ALT_CAN1_ADDR
5703
/* The upper bound address range of the ALT_CAN1 component. */
5704
#define ALT_CAN1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CAN1_ADDR) + 0x200) - 1))
5705
5706
5707
5708
* Component Instance : uart0
5709
5710
* Instance uart0 of component ALT_UART.
5711
5712
5713
5714
/* The address of the ALT_UART_RBR_THR_DLL register for the ALT_UART0 instance. */
5715
#define ALT_UART0_RBR_THR_DLL_ADDR ALT_UART_RBR_THR_DLL_ADDR(ALT_UART0_ADDR)
5716
/* The address of the ALT_UART_IER_DLH register for the ALT_UART0 instance. */
5717
#define ALT_UART0_IER_DLH_ADDR ALT_UART_IER_DLH_ADDR(ALT_UART0_ADDR)
5718
/* The address of the ALT_UART_IIR register for the ALT_UART0 instance. */
5719
#define ALT_UART0_IIR_ADDR ALT_UART_IIR_ADDR(ALT_UART0_ADDR)
5720
/* The address of the ALT_UART_FCR register for the ALT_UART0 instance. */
5721
#define ALT_UART0_FCR_ADDR ALT_UART_FCR_ADDR(ALT_UART0_ADDR)
5722
/* The address of the ALT_UART_LCR register for the ALT_UART0 instance. */
5723
#define ALT_UART0_LCR_ADDR ALT_UART_LCR_ADDR(ALT_UART0_ADDR)
5724
/* The address of the ALT_UART_MCR register for the ALT_UART0 instance. */
5725
#define ALT_UART0_MCR_ADDR ALT_UART_MCR_ADDR(ALT_UART0_ADDR)
5726
/* The address of the ALT_UART_LSR register for the ALT_UART0 instance. */
5727
#define ALT_UART0_LSR_ADDR ALT_UART_LSR_ADDR(ALT_UART0_ADDR)
5728
/* The address of the ALT_UART_MSR register for the ALT_UART0 instance. */
5729
#define ALT_UART0_MSR_ADDR ALT_UART_MSR_ADDR(ALT_UART0_ADDR)
5730
/* The address of the ALT_UART_SCR register for the ALT_UART0 instance. */
5731
#define ALT_UART0_SCR_ADDR ALT_UART_SCR_ADDR(ALT_UART0_ADDR)
5732
/* The address of the ALT_UART_SRBR register for the ALT_UART0 instance. */
5733
#define ALT_UART0_SRBR_ADDR ALT_UART_SRBR_ADDR(ALT_UART0_ADDR)
5734
/* The address of the ALT_UART_STHR register for the ALT_UART0 instance. */
5735
#define ALT_UART0_STHR_ADDR ALT_UART_STHR_ADDR(ALT_UART0_ADDR)
5736
/* The address of the ALT_UART_FAR register for the ALT_UART0 instance. */
5737
#define ALT_UART0_FAR_ADDR ALT_UART_FAR_ADDR(ALT_UART0_ADDR)
5738
/* The address of the ALT_UART_TFR register for the ALT_UART0 instance. */
5739
#define ALT_UART0_TFR_ADDR ALT_UART_TFR_ADDR(ALT_UART0_ADDR)
5740
/* The address of the ALT_UART_RFW register for the ALT_UART0 instance. */
5741
#define ALT_UART0_RFW_ADDR ALT_UART_RFW_ADDR(ALT_UART0_ADDR)
5742
/* The address of the ALT_UART_USR register for the ALT_UART0 instance. */
5743
#define ALT_UART0_USR_ADDR ALT_UART_USR_ADDR(ALT_UART0_ADDR)
5744
/* The address of the ALT_UART_TFL register for the ALT_UART0 instance. */
5745
#define ALT_UART0_TFL_ADDR ALT_UART_TFL_ADDR(ALT_UART0_ADDR)
5746
/* The address of the ALT_UART_RFL register for the ALT_UART0 instance. */
5747
#define ALT_UART0_RFL_ADDR ALT_UART_RFL_ADDR(ALT_UART0_ADDR)
5748
/* The address of the ALT_UART_SRR register for the ALT_UART0 instance. */
5749
#define ALT_UART0_SRR_ADDR ALT_UART_SRR_ADDR(ALT_UART0_ADDR)
5750
/* The address of the ALT_UART_SRTS register for the ALT_UART0 instance. */
5751
#define ALT_UART0_SRTS_ADDR ALT_UART_SRTS_ADDR(ALT_UART0_ADDR)
5752
/* The address of the ALT_UART_SBCR register for the ALT_UART0 instance. */
5753
#define ALT_UART0_SBCR_ADDR ALT_UART_SBCR_ADDR(ALT_UART0_ADDR)
5754
/* The address of the ALT_UART_SDMAM register for the ALT_UART0 instance. */
5755
#define ALT_UART0_SDMAM_ADDR ALT_UART_SDMAM_ADDR(ALT_UART0_ADDR)
5756
/* The address of the ALT_UART_SFE register for the ALT_UART0 instance. */
5757
#define ALT_UART0_SFE_ADDR ALT_UART_SFE_ADDR(ALT_UART0_ADDR)
5758
/* The address of the ALT_UART_SRT register for the ALT_UART0 instance. */
5759
#define ALT_UART0_SRT_ADDR ALT_UART_SRT_ADDR(ALT_UART0_ADDR)
5760
/* The address of the ALT_UART_STET register for the ALT_UART0 instance. */
5761
#define ALT_UART0_STET_ADDR ALT_UART_STET_ADDR(ALT_UART0_ADDR)
5762
/* The address of the ALT_UART_HTX register for the ALT_UART0 instance. */
5763
#define ALT_UART0_HTX_ADDR ALT_UART_HTX_ADDR(ALT_UART0_ADDR)
5764
/* The address of the ALT_UART_DMASA register for the ALT_UART0 instance. */
5765
#define ALT_UART0_DMASA_ADDR ALT_UART_DMASA_ADDR(ALT_UART0_ADDR)
5766
/* The address of the ALT_UART_CPR register for the ALT_UART0 instance. */
5767
#define ALT_UART0_CPR_ADDR ALT_UART_CPR_ADDR(ALT_UART0_ADDR)
5768
/* The address of the ALT_UART_UCV register for the ALT_UART0 instance. */
5769
#define ALT_UART0_UCV_ADDR ALT_UART_UCV_ADDR(ALT_UART0_ADDR)
5770
/* The address of the ALT_UART_CTR register for the ALT_UART0 instance. */
5771
#define ALT_UART0_CTR_ADDR ALT_UART_CTR_ADDR(ALT_UART0_ADDR)
5772
/* The base address byte offset for the start of the ALT_UART0 component. */
5773
#define ALT_UART0_OFST 0xffc02000
5774
/* The start address of the ALT_UART0 component. */
5775
#define ALT_UART0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_UART0_OFST))
5776
/* The lower bound address range of the ALT_UART0 component. */
5777
#define ALT_UART0_LB_ADDR ALT_UART0_ADDR
5778
/* The upper bound address range of the ALT_UART0 component. */
5779
#define ALT_UART0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_UART0_ADDR) + 0x100) - 1))
5780
5781
5782
5783
* Component Instance : uart1
5784
5785
* Instance uart1 of component ALT_UART.
5786
5787
5788
5789
/* The address of the ALT_UART_RBR_THR_DLL register for the ALT_UART1 instance. */
5790
#define ALT_UART1_RBR_THR_DLL_ADDR ALT_UART_RBR_THR_DLL_ADDR(ALT_UART1_ADDR)
5791
/* The address of the ALT_UART_IER_DLH register for the ALT_UART1 instance. */
5792
#define ALT_UART1_IER_DLH_ADDR ALT_UART_IER_DLH_ADDR(ALT_UART1_ADDR)
5793
/* The address of the ALT_UART_IIR register for the ALT_UART1 instance. */
5794
#define ALT_UART1_IIR_ADDR ALT_UART_IIR_ADDR(ALT_UART1_ADDR)
5795
/* The address of the ALT_UART_FCR register for the ALT_UART1 instance. */
5796
#define ALT_UART1_FCR_ADDR ALT_UART_FCR_ADDR(ALT_UART1_ADDR)
5797
/* The address of the ALT_UART_LCR register for the ALT_UART1 instance. */
5798
#define ALT_UART1_LCR_ADDR ALT_UART_LCR_ADDR(ALT_UART1_ADDR)
5799
/* The address of the ALT_UART_MCR register for the ALT_UART1 instance. */
5800
#define ALT_UART1_MCR_ADDR ALT_UART_MCR_ADDR(ALT_UART1_ADDR)
5801
/* The address of the ALT_UART_LSR register for the ALT_UART1 instance. */
5802
#define ALT_UART1_LSR_ADDR ALT_UART_LSR_ADDR(ALT_UART1_ADDR)
5803
/* The address of the ALT_UART_MSR register for the ALT_UART1 instance. */
5804
#define ALT_UART1_MSR_ADDR ALT_UART_MSR_ADDR(ALT_UART1_ADDR)
5805
/* The address of the ALT_UART_SCR register for the ALT_UART1 instance. */
5806
#define ALT_UART1_SCR_ADDR ALT_UART_SCR_ADDR(ALT_UART1_ADDR)
5807
/* The address of the ALT_UART_SRBR register for the ALT_UART1 instance. */
5808
#define ALT_UART1_SRBR_ADDR ALT_UART_SRBR_ADDR(ALT_UART1_ADDR)
5809
/* The address of the ALT_UART_STHR register for the ALT_UART1 instance. */
5810
#define ALT_UART1_STHR_ADDR ALT_UART_STHR_ADDR(ALT_UART1_ADDR)
5811
/* The address of the ALT_UART_FAR register for the ALT_UART1 instance. */
5812
#define ALT_UART1_FAR_ADDR ALT_UART_FAR_ADDR(ALT_UART1_ADDR)
5813
/* The address of the ALT_UART_TFR register for the ALT_UART1 instance. */
5814
#define ALT_UART1_TFR_ADDR ALT_UART_TFR_ADDR(ALT_UART1_ADDR)
5815
/* The address of the ALT_UART_RFW register for the ALT_UART1 instance. */
5816
#define ALT_UART1_RFW_ADDR ALT_UART_RFW_ADDR(ALT_UART1_ADDR)
5817
/* The address of the ALT_UART_USR register for the ALT_UART1 instance. */
5818
#define ALT_UART1_USR_ADDR ALT_UART_USR_ADDR(ALT_UART1_ADDR)
5819
/* The address of the ALT_UART_TFL register for the ALT_UART1 instance. */
5820
#define ALT_UART1_TFL_ADDR ALT_UART_TFL_ADDR(ALT_UART1_ADDR)
5821
/* The address of the ALT_UART_RFL register for the ALT_UART1 instance. */
5822
#define ALT_UART1_RFL_ADDR ALT_UART_RFL_ADDR(ALT_UART1_ADDR)
5823
/* The address of the ALT_UART_SRR register for the ALT_UART1 instance. */
5824
#define ALT_UART1_SRR_ADDR ALT_UART_SRR_ADDR(ALT_UART1_ADDR)
5825
/* The address of the ALT_UART_SRTS register for the ALT_UART1 instance. */
5826
#define ALT_UART1_SRTS_ADDR ALT_UART_SRTS_ADDR(ALT_UART1_ADDR)
5827
/* The address of the ALT_UART_SBCR register for the ALT_UART1 instance. */
5828
#define ALT_UART1_SBCR_ADDR ALT_UART_SBCR_ADDR(ALT_UART1_ADDR)
5829
/* The address of the ALT_UART_SDMAM register for the ALT_UART1 instance. */
5830
#define ALT_UART1_SDMAM_ADDR ALT_UART_SDMAM_ADDR(ALT_UART1_ADDR)
5831
/* The address of the ALT_UART_SFE register for the ALT_UART1 instance. */
5832
#define ALT_UART1_SFE_ADDR ALT_UART_SFE_ADDR(ALT_UART1_ADDR)
5833
/* The address of the ALT_UART_SRT register for the ALT_UART1 instance. */
5834
#define ALT_UART1_SRT_ADDR ALT_UART_SRT_ADDR(ALT_UART1_ADDR)
5835
/* The address of the ALT_UART_STET register for the ALT_UART1 instance. */
5836
#define ALT_UART1_STET_ADDR ALT_UART_STET_ADDR(ALT_UART1_ADDR)
5837
/* The address of the ALT_UART_HTX register for the ALT_UART1 instance. */
5838
#define ALT_UART1_HTX_ADDR ALT_UART_HTX_ADDR(ALT_UART1_ADDR)
5839
/* The address of the ALT_UART_DMASA register for the ALT_UART1 instance. */
5840
#define ALT_UART1_DMASA_ADDR ALT_UART_DMASA_ADDR(ALT_UART1_ADDR)
5841
/* The address of the ALT_UART_CPR register for the ALT_UART1 instance. */
5842
#define ALT_UART1_CPR_ADDR ALT_UART_CPR_ADDR(ALT_UART1_ADDR)
5843
/* The address of the ALT_UART_UCV register for the ALT_UART1 instance. */
5844
#define ALT_UART1_UCV_ADDR ALT_UART_UCV_ADDR(ALT_UART1_ADDR)
5845
/* The address of the ALT_UART_CTR register for the ALT_UART1 instance. */
5846
#define ALT_UART1_CTR_ADDR ALT_UART_CTR_ADDR(ALT_UART1_ADDR)
5847
/* The base address byte offset for the start of the ALT_UART1 component. */
5848
#define ALT_UART1_OFST 0xffc03000
5849
/* The start address of the ALT_UART1 component. */
5850
#define ALT_UART1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_UART1_OFST))
5851
/* The lower bound address range of the ALT_UART1 component. */
5852
#define ALT_UART1_LB_ADDR ALT_UART1_ADDR
5853
/* The upper bound address range of the ALT_UART1 component. */
5854
#define ALT_UART1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_UART1_ADDR) + 0x100) - 1))
5855
5856
5857
5858
* Component Instance : i2c0
5859
5860
* Instance i2c0 of component ALT_I2C.
5861
5862
5863
5864
/* The address of the ALT_I2C_CON register for the ALT_I2C0 instance. */
5865
#define ALT_I2C0_IC_CON_ADDR ALT_I2C_CON_ADDR(ALT_I2C0_ADDR)
5866
/* The address of the ALT_I2C_TAR register for the ALT_I2C0 instance. */
5867
#define ALT_I2C0_IC_TAR_ADDR ALT_I2C_TAR_ADDR(ALT_I2C0_ADDR)
5868
/* The address of the ALT_I2C_SAR register for the ALT_I2C0 instance. */
5869
#define ALT_I2C0_IC_SAR_ADDR ALT_I2C_SAR_ADDR(ALT_I2C0_ADDR)
5870
/* The address of the ALT_I2C_DATA_CMD register for the ALT_I2C0 instance. */
5871
#define ALT_I2C0_IC_DATA_CMD_ADDR ALT_I2C_DATA_CMD_ADDR(ALT_I2C0_ADDR)
5872
/* The address of the ALT_I2C_SS_SCL_HCNT register for the ALT_I2C0 instance. */
5873
#define ALT_I2C0_IC_SS_SCL_HCNT_ADDR ALT_I2C_SS_SCL_HCNT_ADDR(ALT_I2C0_ADDR)
5874
/* The address of the ALT_I2C_SS_SCL_LCNT register for the ALT_I2C0 instance. */
5875
#define ALT_I2C0_IC_SS_SCL_LCNT_ADDR ALT_I2C_SS_SCL_LCNT_ADDR(ALT_I2C0_ADDR)
5876
/* The address of the ALT_I2C_FS_SCL_HCNT register for the ALT_I2C0 instance. */
5877
#define ALT_I2C0_IC_FS_SCL_HCNT_ADDR ALT_I2C_FS_SCL_HCNT_ADDR(ALT_I2C0_ADDR)
5878
/* The address of the ALT_I2C_FS_SCL_LCNT register for the ALT_I2C0 instance. */
5879
#define ALT_I2C0_IC_FS_SCL_LCNT_ADDR ALT_I2C_FS_SCL_LCNT_ADDR(ALT_I2C0_ADDR)
5880
/* The address of the ALT_I2C_INTR_STAT register for the ALT_I2C0 instance. */
5881
#define ALT_I2C0_IC_INTR_STAT_ADDR ALT_I2C_INTR_STAT_ADDR(ALT_I2C0_ADDR)
5882
/* The address of the ALT_I2C_INTR_MSK register for the ALT_I2C0 instance. */
5883
#define ALT_I2C0_IC_INTR_MSK_ADDR ALT_I2C_INTR_MSK_ADDR(ALT_I2C0_ADDR)
5884
/* The address of the ALT_I2C_RAW_INTR_STAT register for the ALT_I2C0 instance. */
5885
#define ALT_I2C0_IC_RAW_INTR_STAT_ADDR ALT_I2C_RAW_INTR_STAT_ADDR(ALT_I2C0_ADDR)
5886
/* The address of the ALT_I2C_RX_TL register for the ALT_I2C0 instance. */
5887
#define ALT_I2C0_IC_RX_TL_ADDR ALT_I2C_RX_TL_ADDR(ALT_I2C0_ADDR)
5888
/* The address of the ALT_I2C_TX_TL register for the ALT_I2C0 instance. */
5889
#define ALT_I2C0_IC_TX_TL_ADDR ALT_I2C_TX_TL_ADDR(ALT_I2C0_ADDR)
5890
/* The address of the ALT_I2C_CLR_INTR register for the ALT_I2C0 instance. */
5891
#define ALT_I2C0_IC_CLR_INTR_ADDR ALT_I2C_CLR_INTR_ADDR(ALT_I2C0_ADDR)
5892
/* The address of the ALT_I2C_CLR_RX_UNDER register for the ALT_I2C0 instance. */
5893
#define ALT_I2C0_IC_CLR_RX_UNDER_ADDR ALT_I2C_CLR_RX_UNDER_ADDR(ALT_I2C0_ADDR)
5894
/* The address of the ALT_I2C_CLR_RX_OVER register for the ALT_I2C0 instance. */
5895
#define ALT_I2C0_IC_CLR_RX_OVER_ADDR ALT_I2C_CLR_RX_OVER_ADDR(ALT_I2C0_ADDR)
5896
/* The address of the ALT_I2C_CLR_TX_OVER register for the ALT_I2C0 instance. */
5897
#define ALT_I2C0_IC_CLR_TX_OVER_ADDR ALT_I2C_CLR_TX_OVER_ADDR(ALT_I2C0_ADDR)
5898
/* The address of the ALT_I2C_CLR_RD_REQ register for the ALT_I2C0 instance. */
5899
#define ALT_I2C0_IC_CLR_RD_REQ_ADDR ALT_I2C_CLR_RD_REQ_ADDR(ALT_I2C0_ADDR)
5900
/* The address of the ALT_I2C_CLR_TX_ABRT register for the ALT_I2C0 instance. */
5901
#define ALT_I2C0_IC_CLR_TX_ABRT_ADDR ALT_I2C_CLR_TX_ABRT_ADDR(ALT_I2C0_ADDR)
5902
/* The address of the ALT_I2C_CLR_RX_DONE register for the ALT_I2C0 instance. */
5903
#define ALT_I2C0_IC_CLR_RX_DONE_ADDR ALT_I2C_CLR_RX_DONE_ADDR(ALT_I2C0_ADDR)
5904
/* The address of the ALT_I2C_CLR_ACTIVITY register for the ALT_I2C0 instance. */
5905
#define ALT_I2C0_IC_CLR_ACTIVITY_ADDR ALT_I2C_CLR_ACTIVITY_ADDR(ALT_I2C0_ADDR)
5906
/* The address of the ALT_I2C_CLR_STOP_DET register for the ALT_I2C0 instance. */
5907
#define ALT_I2C0_IC_CLR_STOP_DET_ADDR ALT_I2C_CLR_STOP_DET_ADDR(ALT_I2C0_ADDR)
5908
/* The address of the ALT_I2C_CLR_START_DET register for the ALT_I2C0 instance. */
5909
#define ALT_I2C0_IC_CLR_START_DET_ADDR ALT_I2C_CLR_START_DET_ADDR(ALT_I2C0_ADDR)
5910
/* The address of the ALT_I2C_CLR_GEN_CALL register for the ALT_I2C0 instance. */
5911
#define ALT_I2C0_IC_CLR_GEN_CALL_ADDR ALT_I2C_CLR_GEN_CALL_ADDR(ALT_I2C0_ADDR)
5912
/* The address of the ALT_I2C_EN register for the ALT_I2C0 instance. */
5913
#define ALT_I2C0_IC_EN_ADDR ALT_I2C_EN_ADDR(ALT_I2C0_ADDR)
5914
/* The address of the ALT_I2C_STAT register for the ALT_I2C0 instance. */
5915
#define ALT_I2C0_IC_STAT_ADDR ALT_I2C_STAT_ADDR(ALT_I2C0_ADDR)
5916
/* The address of the ALT_I2C_TXFLR register for the ALT_I2C0 instance. */
5917
#define ALT_I2C0_IC_TXFLR_ADDR ALT_I2C_TXFLR_ADDR(ALT_I2C0_ADDR)
5918
/* The address of the ALT_I2C_RXFLR register for the ALT_I2C0 instance. */
5919
#define ALT_I2C0_IC_RXFLR_ADDR ALT_I2C_RXFLR_ADDR(ALT_I2C0_ADDR)
5920
/* The address of the ALT_I2C_SDA_HOLD register for the ALT_I2C0 instance. */
5921
#define ALT_I2C0_IC_SDA_HOLD_ADDR ALT_I2C_SDA_HOLD_ADDR(ALT_I2C0_ADDR)
5922
/* The address of the ALT_I2C_TX_ABRT_SRC register for the ALT_I2C0 instance. */
5923
#define ALT_I2C0_IC_TX_ABRT_SRC_ADDR ALT_I2C_TX_ABRT_SRC_ADDR(ALT_I2C0_ADDR)
5924
/* The address of the ALT_I2C_SLV_DATA_NACK_ONLY register for the ALT_I2C0 instance. */
5925
#define ALT_I2C0_IC_SLV_DATA_NACK_ONLY_ADDR ALT_I2C_SLV_DATA_NACK_ONLY_ADDR(ALT_I2C0_ADDR)
5926
/* The address of the ALT_I2C_DMA_CR register for the ALT_I2C0 instance. */
5927
#define ALT_I2C0_IC_DMA_CR_ADDR ALT_I2C_DMA_CR_ADDR(ALT_I2C0_ADDR)
5928
/* The address of the ALT_I2C_DMA_TDLR register for the ALT_I2C0 instance. */
5929
#define ALT_I2C0_IC_DMA_TDLR_ADDR ALT_I2C_DMA_TDLR_ADDR(ALT_I2C0_ADDR)
5930
/* The address of the ALT_I2C_DMA_RDLR register for the ALT_I2C0 instance. */
5931
#define ALT_I2C0_IC_DMA_RDLR_ADDR ALT_I2C_DMA_RDLR_ADDR(ALT_I2C0_ADDR)
5932
/* The address of the ALT_I2C_SDA_SETUP register for the ALT_I2C0 instance. */
5933
#define ALT_I2C0_IC_SDA_SETUP_ADDR ALT_I2C_SDA_SETUP_ADDR(ALT_I2C0_ADDR)
5934
/* The address of the ALT_I2C_ACK_GENERAL_CALL register for the ALT_I2C0 instance. */
5935
#define ALT_I2C0_IC_ACK_GENERAL_CALL_ADDR ALT_I2C_ACK_GENERAL_CALL_ADDR(ALT_I2C0_ADDR)
5936
/* The address of the ALT_I2C_EN_STAT register for the ALT_I2C0 instance. */
5937
#define ALT_I2C0_IC_EN_STAT_ADDR ALT_I2C_EN_STAT_ADDR(ALT_I2C0_ADDR)
5938
/* The address of the ALT_I2C_FS_SPKLEN register for the ALT_I2C0 instance. */
5939
#define ALT_I2C0_IC_FS_SPKLEN_ADDR ALT_I2C_FS_SPKLEN_ADDR(ALT_I2C0_ADDR)
5940
/* The address of the ALT_I2C_COMP_PARAM_1 register for the ALT_I2C0 instance. */
5941
#define ALT_I2C0_IC_COMP_PARAM_1_ADDR ALT_I2C_COMP_PARAM_1_ADDR(ALT_I2C0_ADDR)
5942
/* The address of the ALT_I2C_COMP_VER register for the ALT_I2C0 instance. */
5943
#define ALT_I2C0_IC_COMP_VER_ADDR ALT_I2C_COMP_VER_ADDR(ALT_I2C0_ADDR)
5944
/* The address of the ALT_I2C_COMP_TYPE register for the ALT_I2C0 instance. */
5945
#define ALT_I2C0_IC_COMP_TYPE_ADDR ALT_I2C_COMP_TYPE_ADDR(ALT_I2C0_ADDR)
5946
/* The base address byte offset for the start of the ALT_I2C0 component. */
5947
#define ALT_I2C0_OFST 0xffc04000
5948
/* The start address of the ALT_I2C0 component. */
5949
#define ALT_I2C0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_I2C0_OFST))
5950
/* The lower bound address range of the ALT_I2C0 component. */
5951
#define ALT_I2C0_LB_ADDR ALT_I2C0_ADDR
5952
/* The upper bound address range of the ALT_I2C0 component. */
5953
#define ALT_I2C0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_I2C0_ADDR) + 0x100) - 1))
5954
5955
5956
5957
* Component Instance : i2c1
5958
5959
* Instance i2c1 of component ALT_I2C.
5960
5961
5962
5963
/* The address of the ALT_I2C_CON register for the ALT_I2C1 instance. */
5964
#define ALT_I2C1_IC_CON_ADDR ALT_I2C_CON_ADDR(ALT_I2C1_ADDR)
5965
/* The address of the ALT_I2C_TAR register for the ALT_I2C1 instance. */
5966
#define ALT_I2C1_IC_TAR_ADDR ALT_I2C_TAR_ADDR(ALT_I2C1_ADDR)
5967
/* The address of the ALT_I2C_SAR register for the ALT_I2C1 instance. */
5968
#define ALT_I2C1_IC_SAR_ADDR ALT_I2C_SAR_ADDR(ALT_I2C1_ADDR)
5969
/* The address of the ALT_I2C_DATA_CMD register for the ALT_I2C1 instance. */
5970
#define ALT_I2C1_IC_DATA_CMD_ADDR ALT_I2C_DATA_CMD_ADDR(ALT_I2C1_ADDR)
5971
/* The address of the ALT_I2C_SS_SCL_HCNT register for the ALT_I2C1 instance. */
5972
#define ALT_I2C1_IC_SS_SCL_HCNT_ADDR ALT_I2C_SS_SCL_HCNT_ADDR(ALT_I2C1_ADDR)
5973
/* The address of the ALT_I2C_SS_SCL_LCNT register for the ALT_I2C1 instance. */
5974
#define ALT_I2C1_IC_SS_SCL_LCNT_ADDR ALT_I2C_SS_SCL_LCNT_ADDR(ALT_I2C1_ADDR)
5975
/* The address of the ALT_I2C_FS_SCL_HCNT register for the ALT_I2C1 instance. */
5976
#define ALT_I2C1_IC_FS_SCL_HCNT_ADDR ALT_I2C_FS_SCL_HCNT_ADDR(ALT_I2C1_ADDR)
5977
/* The address of the ALT_I2C_FS_SCL_LCNT register for the ALT_I2C1 instance. */
5978
#define ALT_I2C1_IC_FS_SCL_LCNT_ADDR ALT_I2C_FS_SCL_LCNT_ADDR(ALT_I2C1_ADDR)
5979
/* The address of the ALT_I2C_INTR_STAT register for the ALT_I2C1 instance. */
5980
#define ALT_I2C1_IC_INTR_STAT_ADDR ALT_I2C_INTR_STAT_ADDR(ALT_I2C1_ADDR)
5981
/* The address of the ALT_I2C_INTR_MSK register for the ALT_I2C1 instance. */
5982
#define ALT_I2C1_IC_INTR_MSK_ADDR ALT_I2C_INTR_MSK_ADDR(ALT_I2C1_ADDR)
5983
/* The address of the ALT_I2C_RAW_INTR_STAT register for the ALT_I2C1 instance. */
5984
#define ALT_I2C1_IC_RAW_INTR_STAT_ADDR ALT_I2C_RAW_INTR_STAT_ADDR(ALT_I2C1_ADDR)
5985
/* The address of the ALT_I2C_RX_TL register for the ALT_I2C1 instance. */
5986
#define ALT_I2C1_IC_RX_TL_ADDR ALT_I2C_RX_TL_ADDR(ALT_I2C1_ADDR)
5987
/* The address of the ALT_I2C_TX_TL register for the ALT_I2C1 instance. */
5988
#define ALT_I2C1_IC_TX_TL_ADDR ALT_I2C_TX_TL_ADDR(ALT_I2C1_ADDR)
5989
/* The address of the ALT_I2C_CLR_INTR register for the ALT_I2C1 instance. */
5990
#define ALT_I2C1_IC_CLR_INTR_ADDR ALT_I2C_CLR_INTR_ADDR(ALT_I2C1_ADDR)
5991
/* The address of the ALT_I2C_CLR_RX_UNDER register for the ALT_I2C1 instance. */
5992
#define ALT_I2C1_IC_CLR_RX_UNDER_ADDR ALT_I2C_CLR_RX_UNDER_ADDR(ALT_I2C1_ADDR)
5993
/* The address of the ALT_I2C_CLR_RX_OVER register for the ALT_I2C1 instance. */
5994
#define ALT_I2C1_IC_CLR_RX_OVER_ADDR ALT_I2C_CLR_RX_OVER_ADDR(ALT_I2C1_ADDR)
5995
/* The address of the ALT_I2C_CLR_TX_OVER register for the ALT_I2C1 instance. */
5996
#define ALT_I2C1_IC_CLR_TX_OVER_ADDR ALT_I2C_CLR_TX_OVER_ADDR(ALT_I2C1_ADDR)
5997
/* The address of the ALT_I2C_CLR_RD_REQ register for the ALT_I2C1 instance. */
5998
#define ALT_I2C1_IC_CLR_RD_REQ_ADDR ALT_I2C_CLR_RD_REQ_ADDR(ALT_I2C1_ADDR)
5999
/* The address of the ALT_I2C_CLR_TX_ABRT register for the ALT_I2C1 instance. */
6000
#define ALT_I2C1_IC_CLR_TX_ABRT_ADDR ALT_I2C_CLR_TX_ABRT_ADDR(ALT_I2C1_ADDR)
6001
/* The address of the ALT_I2C_CLR_RX_DONE register for the ALT_I2C1 instance. */
6002
#define ALT_I2C1_IC_CLR_RX_DONE_ADDR ALT_I2C_CLR_RX_DONE_ADDR(ALT_I2C1_ADDR)
6003
/* The address of the ALT_I2C_CLR_ACTIVITY register for the ALT_I2C1 instance. */
6004
#define ALT_I2C1_IC_CLR_ACTIVITY_ADDR ALT_I2C_CLR_ACTIVITY_ADDR(ALT_I2C1_ADDR)
6005
/* The address of the ALT_I2C_CLR_STOP_DET register for the ALT_I2C1 instance. */
6006
#define ALT_I2C1_IC_CLR_STOP_DET_ADDR ALT_I2C_CLR_STOP_DET_ADDR(ALT_I2C1_ADDR)
6007
/* The address of the ALT_I2C_CLR_START_DET register for the ALT_I2C1 instance. */
6008
#define ALT_I2C1_IC_CLR_START_DET_ADDR ALT_I2C_CLR_START_DET_ADDR(ALT_I2C1_ADDR)
6009
/* The address of the ALT_I2C_CLR_GEN_CALL register for the ALT_I2C1 instance. */
6010
#define ALT_I2C1_IC_CLR_GEN_CALL_ADDR ALT_I2C_CLR_GEN_CALL_ADDR(ALT_I2C1_ADDR)
6011
/* The address of the ALT_I2C_EN register for the ALT_I2C1 instance. */
6012
#define ALT_I2C1_IC_EN_ADDR ALT_I2C_EN_ADDR(ALT_I2C1_ADDR)
6013
/* The address of the ALT_I2C_STAT register for the ALT_I2C1 instance. */
6014
#define ALT_I2C1_IC_STAT_ADDR ALT_I2C_STAT_ADDR(ALT_I2C1_ADDR)
6015
/* The address of the ALT_I2C_TXFLR register for the ALT_I2C1 instance. */
6016
#define ALT_I2C1_IC_TXFLR_ADDR ALT_I2C_TXFLR_ADDR(ALT_I2C1_ADDR)
6017
/* The address of the ALT_I2C_RXFLR register for the ALT_I2C1 instance. */
6018
#define ALT_I2C1_IC_RXFLR_ADDR ALT_I2C_RXFLR_ADDR(ALT_I2C1_ADDR)
6019
/* The address of the ALT_I2C_SDA_HOLD register for the ALT_I2C1 instance. */
6020
#define ALT_I2C1_IC_SDA_HOLD_ADDR ALT_I2C_SDA_HOLD_ADDR(ALT_I2C1_ADDR)
6021
/* The address of the ALT_I2C_TX_ABRT_SRC register for the ALT_I2C1 instance. */
6022
#define ALT_I2C1_IC_TX_ABRT_SRC_ADDR ALT_I2C_TX_ABRT_SRC_ADDR(ALT_I2C1_ADDR)
6023
/* The address of the ALT_I2C_SLV_DATA_NACK_ONLY register for the ALT_I2C1 instance. */
6024
#define ALT_I2C1_IC_SLV_DATA_NACK_ONLY_ADDR ALT_I2C_SLV_DATA_NACK_ONLY_ADDR(ALT_I2C1_ADDR)
6025
/* The address of the ALT_I2C_DMA_CR register for the ALT_I2C1 instance. */
6026
#define ALT_I2C1_IC_DMA_CR_ADDR ALT_I2C_DMA_CR_ADDR(ALT_I2C1_ADDR)
6027
/* The address of the ALT_I2C_DMA_TDLR register for the ALT_I2C1 instance. */
6028
#define ALT_I2C1_IC_DMA_TDLR_ADDR ALT_I2C_DMA_TDLR_ADDR(ALT_I2C1_ADDR)
6029
/* The address of the ALT_I2C_DMA_RDLR register for the ALT_I2C1 instance. */
6030
#define ALT_I2C1_IC_DMA_RDLR_ADDR ALT_I2C_DMA_RDLR_ADDR(ALT_I2C1_ADDR)
6031
/* The address of the ALT_I2C_SDA_SETUP register for the ALT_I2C1 instance. */
6032
#define ALT_I2C1_IC_SDA_SETUP_ADDR ALT_I2C_SDA_SETUP_ADDR(ALT_I2C1_ADDR)
6033
/* The address of the ALT_I2C_ACK_GENERAL_CALL register for the ALT_I2C1 instance. */
6034
#define ALT_I2C1_IC_ACK_GENERAL_CALL_ADDR ALT_I2C_ACK_GENERAL_CALL_ADDR(ALT_I2C1_ADDR)
6035
/* The address of the ALT_I2C_EN_STAT register for the ALT_I2C1 instance. */
6036
#define ALT_I2C1_IC_EN_STAT_ADDR ALT_I2C_EN_STAT_ADDR(ALT_I2C1_ADDR)
6037
/* The address of the ALT_I2C_FS_SPKLEN register for the ALT_I2C1 instance. */
6038
#define ALT_I2C1_IC_FS_SPKLEN_ADDR ALT_I2C_FS_SPKLEN_ADDR(ALT_I2C1_ADDR)
6039
/* The address of the ALT_I2C_COMP_PARAM_1 register for the ALT_I2C1 instance. */
6040
#define ALT_I2C1_IC_COMP_PARAM_1_ADDR ALT_I2C_COMP_PARAM_1_ADDR(ALT_I2C1_ADDR)
6041
/* The address of the ALT_I2C_COMP_VER register for the ALT_I2C1 instance. */
6042
#define ALT_I2C1_IC_COMP_VER_ADDR ALT_I2C_COMP_VER_ADDR(ALT_I2C1_ADDR)
6043
/* The address of the ALT_I2C_COMP_TYPE register for the ALT_I2C1 instance. */
6044
#define ALT_I2C1_IC_COMP_TYPE_ADDR ALT_I2C_COMP_TYPE_ADDR(ALT_I2C1_ADDR)
6045
/* The base address byte offset for the start of the ALT_I2C1 component. */
6046
#define ALT_I2C1_OFST 0xffc05000
6047
/* The start address of the ALT_I2C1 component. */
6048
#define ALT_I2C1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_I2C1_OFST))
6049
/* The lower bound address range of the ALT_I2C1 component. */
6050
#define ALT_I2C1_LB_ADDR ALT_I2C1_ADDR
6051
/* The upper bound address range of the ALT_I2C1 component. */
6052
#define ALT_I2C1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_I2C1_ADDR) + 0x100) - 1))
6053
6054
6055
6056
* Component Instance : i2c2
6057
6058
* Instance i2c2 of component ALT_I2C.
6059
6060
6061
6062
/* The address of the ALT_I2C_CON register for the ALT_I2C2 instance. */
6063
#define ALT_I2C2_IC_CON_ADDR ALT_I2C_CON_ADDR(ALT_I2C2_ADDR)
6064
/* The address of the ALT_I2C_TAR register for the ALT_I2C2 instance. */
6065
#define ALT_I2C2_IC_TAR_ADDR ALT_I2C_TAR_ADDR(ALT_I2C2_ADDR)
6066
/* The address of the ALT_I2C_SAR register for the ALT_I2C2 instance. */
6067
#define ALT_I2C2_IC_SAR_ADDR ALT_I2C_SAR_ADDR(ALT_I2C2_ADDR)
6068
/* The address of the ALT_I2C_DATA_CMD register for the ALT_I2C2 instance. */
6069
#define ALT_I2C2_IC_DATA_CMD_ADDR ALT_I2C_DATA_CMD_ADDR(ALT_I2C2_ADDR)
6070
/* The address of the ALT_I2C_SS_SCL_HCNT register for the ALT_I2C2 instance. */
6071
#define ALT_I2C2_IC_SS_SCL_HCNT_ADDR ALT_I2C_SS_SCL_HCNT_ADDR(ALT_I2C2_ADDR)
6072
/* The address of the ALT_I2C_SS_SCL_LCNT register for the ALT_I2C2 instance. */
6073
#define ALT_I2C2_IC_SS_SCL_LCNT_ADDR ALT_I2C_SS_SCL_LCNT_ADDR(ALT_I2C2_ADDR)
6074
/* The address of the ALT_I2C_FS_SCL_HCNT register for the ALT_I2C2 instance. */
6075
#define ALT_I2C2_IC_FS_SCL_HCNT_ADDR ALT_I2C_FS_SCL_HCNT_ADDR(ALT_I2C2_ADDR)
6076
/* The address of the ALT_I2C_FS_SCL_LCNT register for the ALT_I2C2 instance. */
6077
#define ALT_I2C2_IC_FS_SCL_LCNT_ADDR ALT_I2C_FS_SCL_LCNT_ADDR(ALT_I2C2_ADDR)
6078
/* The address of the ALT_I2C_INTR_STAT register for the ALT_I2C2 instance. */
6079
#define ALT_I2C2_IC_INTR_STAT_ADDR ALT_I2C_INTR_STAT_ADDR(ALT_I2C2_ADDR)
6080
/* The address of the ALT_I2C_INTR_MSK register for the ALT_I2C2 instance. */
6081
#define ALT_I2C2_IC_INTR_MSK_ADDR ALT_I2C_INTR_MSK_ADDR(ALT_I2C2_ADDR)
6082
/* The address of the ALT_I2C_RAW_INTR_STAT register for the ALT_I2C2 instance. */
6083
#define ALT_I2C2_IC_RAW_INTR_STAT_ADDR ALT_I2C_RAW_INTR_STAT_ADDR(ALT_I2C2_ADDR)
6084
/* The address of the ALT_I2C_RX_TL register for the ALT_I2C2 instance. */
6085
#define ALT_I2C2_IC_RX_TL_ADDR ALT_I2C_RX_TL_ADDR(ALT_I2C2_ADDR)
6086
/* The address of the ALT_I2C_TX_TL register for the ALT_I2C2 instance. */
6087
#define ALT_I2C2_IC_TX_TL_ADDR ALT_I2C_TX_TL_ADDR(ALT_I2C2_ADDR)
6088
/* The address of the ALT_I2C_CLR_INTR register for the ALT_I2C2 instance. */
6089
#define ALT_I2C2_IC_CLR_INTR_ADDR ALT_I2C_CLR_INTR_ADDR(ALT_I2C2_ADDR)
6090
/* The address of the ALT_I2C_CLR_RX_UNDER register for the ALT_I2C2 instance. */
6091
#define ALT_I2C2_IC_CLR_RX_UNDER_ADDR ALT_I2C_CLR_RX_UNDER_ADDR(ALT_I2C2_ADDR)
6092
/* The address of the ALT_I2C_CLR_RX_OVER register for the ALT_I2C2 instance. */
6093
#define ALT_I2C2_IC_CLR_RX_OVER_ADDR ALT_I2C_CLR_RX_OVER_ADDR(ALT_I2C2_ADDR)
6094
/* The address of the ALT_I2C_CLR_TX_OVER register for the ALT_I2C2 instance. */
6095
#define ALT_I2C2_IC_CLR_TX_OVER_ADDR ALT_I2C_CLR_TX_OVER_ADDR(ALT_I2C2_ADDR)
6096
/* The address of the ALT_I2C_CLR_RD_REQ register for the ALT_I2C2 instance. */
6097
#define ALT_I2C2_IC_CLR_RD_REQ_ADDR ALT_I2C_CLR_RD_REQ_ADDR(ALT_I2C2_ADDR)
6098
/* The address of the ALT_I2C_CLR_TX_ABRT register for the ALT_I2C2 instance. */
6099
#define ALT_I2C2_IC_CLR_TX_ABRT_ADDR ALT_I2C_CLR_TX_ABRT_ADDR(ALT_I2C2_ADDR)
6100
/* The address of the ALT_I2C_CLR_RX_DONE register for the ALT_I2C2 instance. */
6101
#define ALT_I2C2_IC_CLR_RX_DONE_ADDR ALT_I2C_CLR_RX_DONE_ADDR(ALT_I2C2_ADDR)
6102
/* The address of the ALT_I2C_CLR_ACTIVITY register for the ALT_I2C2 instance. */
6103
#define ALT_I2C2_IC_CLR_ACTIVITY_ADDR ALT_I2C_CLR_ACTIVITY_ADDR(ALT_I2C2_ADDR)
6104
/* The address of the ALT_I2C_CLR_STOP_DET register for the ALT_I2C2 instance. */
6105
#define ALT_I2C2_IC_CLR_STOP_DET_ADDR ALT_I2C_CLR_STOP_DET_ADDR(ALT_I2C2_ADDR)
6106
/* The address of the ALT_I2C_CLR_START_DET register for the ALT_I2C2 instance. */
6107
#define ALT_I2C2_IC_CLR_START_DET_ADDR ALT_I2C_CLR_START_DET_ADDR(ALT_I2C2_ADDR)
6108
/* The address of the ALT_I2C_CLR_GEN_CALL register for the ALT_I2C2 instance. */
6109
#define ALT_I2C2_IC_CLR_GEN_CALL_ADDR ALT_I2C_CLR_GEN_CALL_ADDR(ALT_I2C2_ADDR)
6110
/* The address of the ALT_I2C_EN register for the ALT_I2C2 instance. */
6111
#define ALT_I2C2_IC_EN_ADDR ALT_I2C_EN_ADDR(ALT_I2C2_ADDR)
6112
/* The address of the ALT_I2C_STAT register for the ALT_I2C2 instance. */
6113
#define ALT_I2C2_IC_STAT_ADDR ALT_I2C_STAT_ADDR(ALT_I2C2_ADDR)
6114
/* The address of the ALT_I2C_TXFLR register for the ALT_I2C2 instance. */
6115
#define ALT_I2C2_IC_TXFLR_ADDR ALT_I2C_TXFLR_ADDR(ALT_I2C2_ADDR)
6116
/* The address of the ALT_I2C_RXFLR register for the ALT_I2C2 instance. */
6117
#define ALT_I2C2_IC_RXFLR_ADDR ALT_I2C_RXFLR_ADDR(ALT_I2C2_ADDR)
6118
/* The address of the ALT_I2C_SDA_HOLD register for the ALT_I2C2 instance. */
6119
#define ALT_I2C2_IC_SDA_HOLD_ADDR ALT_I2C_SDA_HOLD_ADDR(ALT_I2C2_ADDR)
6120
/* The address of the ALT_I2C_TX_ABRT_SRC register for the ALT_I2C2 instance. */
6121
#define ALT_I2C2_IC_TX_ABRT_SRC_ADDR ALT_I2C_TX_ABRT_SRC_ADDR(ALT_I2C2_ADDR)
6122
/* The address of the ALT_I2C_SLV_DATA_NACK_ONLY register for the ALT_I2C2 instance. */
6123
#define ALT_I2C2_IC_SLV_DATA_NACK_ONLY_ADDR ALT_I2C_SLV_DATA_NACK_ONLY_ADDR(ALT_I2C2_ADDR)
6124
/* The address of the ALT_I2C_DMA_CR register for the ALT_I2C2 instance. */
6125
#define ALT_I2C2_IC_DMA_CR_ADDR ALT_I2C_DMA_CR_ADDR(ALT_I2C2_ADDR)
6126
/* The address of the ALT_I2C_DMA_TDLR register for the ALT_I2C2 instance. */
6127
#define ALT_I2C2_IC_DMA_TDLR_ADDR ALT_I2C_DMA_TDLR_ADDR(ALT_I2C2_ADDR)
6128
/* The address of the ALT_I2C_DMA_RDLR register for the ALT_I2C2 instance. */
6129
#define ALT_I2C2_IC_DMA_RDLR_ADDR ALT_I2C_DMA_RDLR_ADDR(ALT_I2C2_ADDR)
6130
/* The address of the ALT_I2C_SDA_SETUP register for the ALT_I2C2 instance. */
6131
#define ALT_I2C2_IC_SDA_SETUP_ADDR ALT_I2C_SDA_SETUP_ADDR(ALT_I2C2_ADDR)
6132
/* The address of the ALT_I2C_ACK_GENERAL_CALL register for the ALT_I2C2 instance. */
6133
#define ALT_I2C2_IC_ACK_GENERAL_CALL_ADDR ALT_I2C_ACK_GENERAL_CALL_ADDR(ALT_I2C2_ADDR)
6134
/* The address of the ALT_I2C_EN_STAT register for the ALT_I2C2 instance. */
6135
#define ALT_I2C2_IC_EN_STAT_ADDR ALT_I2C_EN_STAT_ADDR(ALT_I2C2_ADDR)
6136
/* The address of the ALT_I2C_FS_SPKLEN register for the ALT_I2C2 instance. */
6137
#define ALT_I2C2_IC_FS_SPKLEN_ADDR ALT_I2C_FS_SPKLEN_ADDR(ALT_I2C2_ADDR)
6138
/* The address of the ALT_I2C_COMP_PARAM_1 register for the ALT_I2C2 instance. */
6139
#define ALT_I2C2_IC_COMP_PARAM_1_ADDR ALT_I2C_COMP_PARAM_1_ADDR(ALT_I2C2_ADDR)
6140
/* The address of the ALT_I2C_COMP_VER register for the ALT_I2C2 instance. */
6141
#define ALT_I2C2_IC_COMP_VER_ADDR ALT_I2C_COMP_VER_ADDR(ALT_I2C2_ADDR)
6142
/* The address of the ALT_I2C_COMP_TYPE register for the ALT_I2C2 instance. */
6143
#define ALT_I2C2_IC_COMP_TYPE_ADDR ALT_I2C_COMP_TYPE_ADDR(ALT_I2C2_ADDR)
6144
/* The base address byte offset for the start of the ALT_I2C2 component. */
6145
#define ALT_I2C2_OFST 0xffc06000
6146
/* The start address of the ALT_I2C2 component. */
6147
#define ALT_I2C2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_I2C2_OFST))
6148
/* The lower bound address range of the ALT_I2C2 component. */
6149
#define ALT_I2C2_LB_ADDR ALT_I2C2_ADDR
6150
/* The upper bound address range of the ALT_I2C2 component. */
6151
#define ALT_I2C2_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_I2C2_ADDR) + 0x100) - 1))
6152
6153
6154
6155
* Component Instance : i2c3
6156
6157
* Instance i2c3 of component ALT_I2C.
6158
6159
6160
6161
/* The address of the ALT_I2C_CON register for the ALT_I2C3 instance. */
6162
#define ALT_I2C3_IC_CON_ADDR ALT_I2C_CON_ADDR(ALT_I2C3_ADDR)
6163
/* The address of the ALT_I2C_TAR register for the ALT_I2C3 instance. */
6164
#define ALT_I2C3_IC_TAR_ADDR ALT_I2C_TAR_ADDR(ALT_I2C3_ADDR)
6165
/* The address of the ALT_I2C_SAR register for the ALT_I2C3 instance. */
6166
#define ALT_I2C3_IC_SAR_ADDR ALT_I2C_SAR_ADDR(ALT_I2C3_ADDR)
6167
/* The address of the ALT_I2C_DATA_CMD register for the ALT_I2C3 instance. */
6168
#define ALT_I2C3_IC_DATA_CMD_ADDR ALT_I2C_DATA_CMD_ADDR(ALT_I2C3_ADDR)
6169
/* The address of the ALT_I2C_SS_SCL_HCNT register for the ALT_I2C3 instance. */
6170
#define ALT_I2C3_IC_SS_SCL_HCNT_ADDR ALT_I2C_SS_SCL_HCNT_ADDR(ALT_I2C3_ADDR)
6171
/* The address of the ALT_I2C_SS_SCL_LCNT register for the ALT_I2C3 instance. */
6172
#define ALT_I2C3_IC_SS_SCL_LCNT_ADDR ALT_I2C_SS_SCL_LCNT_ADDR(ALT_I2C3_ADDR)
6173
/* The address of the ALT_I2C_FS_SCL_HCNT register for the ALT_I2C3 instance. */
6174
#define ALT_I2C3_IC_FS_SCL_HCNT_ADDR ALT_I2C_FS_SCL_HCNT_ADDR(ALT_I2C3_ADDR)
6175
/* The address of the ALT_I2C_FS_SCL_LCNT register for the ALT_I2C3 instance. */
6176
#define ALT_I2C3_IC_FS_SCL_LCNT_ADDR ALT_I2C_FS_SCL_LCNT_ADDR(ALT_I2C3_ADDR)
6177
/* The address of the ALT_I2C_INTR_STAT register for the ALT_I2C3 instance. */
6178
#define ALT_I2C3_IC_INTR_STAT_ADDR ALT_I2C_INTR_STAT_ADDR(ALT_I2C3_ADDR)
6179
/* The address of the ALT_I2C_INTR_MSK register for the ALT_I2C3 instance. */
6180
#define ALT_I2C3_IC_INTR_MSK_ADDR ALT_I2C_INTR_MSK_ADDR(ALT_I2C3_ADDR)
6181
/* The address of the ALT_I2C_RAW_INTR_STAT register for the ALT_I2C3 instance. */
6182
#define ALT_I2C3_IC_RAW_INTR_STAT_ADDR ALT_I2C_RAW_INTR_STAT_ADDR(ALT_I2C3_ADDR)
6183
/* The address of the ALT_I2C_RX_TL register for the ALT_I2C3 instance. */
6184
#define ALT_I2C3_IC_RX_TL_ADDR ALT_I2C_RX_TL_ADDR(ALT_I2C3_ADDR)
6185
/* The address of the ALT_I2C_TX_TL register for the ALT_I2C3 instance. */
6186
#define ALT_I2C3_IC_TX_TL_ADDR ALT_I2C_TX_TL_ADDR(ALT_I2C3_ADDR)
6187
/* The address of the ALT_I2C_CLR_INTR register for the ALT_I2C3 instance. */
6188
#define ALT_I2C3_IC_CLR_INTR_ADDR ALT_I2C_CLR_INTR_ADDR(ALT_I2C3_ADDR)
6189
/* The address of the ALT_I2C_CLR_RX_UNDER register for the ALT_I2C3 instance. */
6190
#define ALT_I2C3_IC_CLR_RX_UNDER_ADDR ALT_I2C_CLR_RX_UNDER_ADDR(ALT_I2C3_ADDR)
6191
/* The address of the ALT_I2C_CLR_RX_OVER register for the ALT_I2C3 instance. */
6192
#define ALT_I2C3_IC_CLR_RX_OVER_ADDR ALT_I2C_CLR_RX_OVER_ADDR(ALT_I2C3_ADDR)
6193
/* The address of the ALT_I2C_CLR_TX_OVER register for the ALT_I2C3 instance. */
6194
#define ALT_I2C3_IC_CLR_TX_OVER_ADDR ALT_I2C_CLR_TX_OVER_ADDR(ALT_I2C3_ADDR)
6195
/* The address of the ALT_I2C_CLR_RD_REQ register for the ALT_I2C3 instance. */
6196
#define ALT_I2C3_IC_CLR_RD_REQ_ADDR ALT_I2C_CLR_RD_REQ_ADDR(ALT_I2C3_ADDR)
6197
/* The address of the ALT_I2C_CLR_TX_ABRT register for the ALT_I2C3 instance. */
6198
#define ALT_I2C3_IC_CLR_TX_ABRT_ADDR ALT_I2C_CLR_TX_ABRT_ADDR(ALT_I2C3_ADDR)
6199
/* The address of the ALT_I2C_CLR_RX_DONE register for the ALT_I2C3 instance. */
6200
#define ALT_I2C3_IC_CLR_RX_DONE_ADDR ALT_I2C_CLR_RX_DONE_ADDR(ALT_I2C3_ADDR)
6201
/* The address of the ALT_I2C_CLR_ACTIVITY register for the ALT_I2C3 instance. */
6202
#define ALT_I2C3_IC_CLR_ACTIVITY_ADDR ALT_I2C_CLR_ACTIVITY_ADDR(ALT_I2C3_ADDR)
6203
/* The address of the ALT_I2C_CLR_STOP_DET register for the ALT_I2C3 instance. */
6204
#define ALT_I2C3_IC_CLR_STOP_DET_ADDR ALT_I2C_CLR_STOP_DET_ADDR(ALT_I2C3_ADDR)
6205
/* The address of the ALT_I2C_CLR_START_DET register for the ALT_I2C3 instance. */
6206
#define ALT_I2C3_IC_CLR_START_DET_ADDR ALT_I2C_CLR_START_DET_ADDR(ALT_I2C3_ADDR)
6207
/* The address of the ALT_I2C_CLR_GEN_CALL register for the ALT_I2C3 instance. */
6208
#define ALT_I2C3_IC_CLR_GEN_CALL_ADDR ALT_I2C_CLR_GEN_CALL_ADDR(ALT_I2C3_ADDR)
6209
/* The address of the ALT_I2C_EN register for the ALT_I2C3 instance. */
6210
#define ALT_I2C3_IC_EN_ADDR ALT_I2C_EN_ADDR(ALT_I2C3_ADDR)
6211
/* The address of the ALT_I2C_STAT register for the ALT_I2C3 instance. */
6212
#define ALT_I2C3_IC_STAT_ADDR ALT_I2C_STAT_ADDR(ALT_I2C3_ADDR)
6213
/* The address of the ALT_I2C_TXFLR register for the ALT_I2C3 instance. */
6214
#define ALT_I2C3_IC_TXFLR_ADDR ALT_I2C_TXFLR_ADDR(ALT_I2C3_ADDR)
6215
/* The address of the ALT_I2C_RXFLR register for the ALT_I2C3 instance. */
6216
#define ALT_I2C3_IC_RXFLR_ADDR ALT_I2C_RXFLR_ADDR(ALT_I2C3_ADDR)
6217
/* The address of the ALT_I2C_SDA_HOLD register for the ALT_I2C3 instance. */
6218
#define ALT_I2C3_IC_SDA_HOLD_ADDR ALT_I2C_SDA_HOLD_ADDR(ALT_I2C3_ADDR)
6219
/* The address of the ALT_I2C_TX_ABRT_SRC register for the ALT_I2C3 instance. */
6220
#define ALT_I2C3_IC_TX_ABRT_SRC_ADDR ALT_I2C_TX_ABRT_SRC_ADDR(ALT_I2C3_ADDR)
6221
/* The address of the ALT_I2C_SLV_DATA_NACK_ONLY register for the ALT_I2C3 instance. */
6222
#define ALT_I2C3_IC_SLV_DATA_NACK_ONLY_ADDR ALT_I2C_SLV_DATA_NACK_ONLY_ADDR(ALT_I2C3_ADDR)
6223
/* The address of the ALT_I2C_DMA_CR register for the ALT_I2C3 instance. */
6224
#define ALT_I2C3_IC_DMA_CR_ADDR ALT_I2C_DMA_CR_ADDR(ALT_I2C3_ADDR)
6225
/* The address of the ALT_I2C_DMA_TDLR register for the ALT_I2C3 instance. */
6226
#define ALT_I2C3_IC_DMA_TDLR_ADDR ALT_I2C_DMA_TDLR_ADDR(ALT_I2C3_ADDR)
6227
/* The address of the ALT_I2C_DMA_RDLR register for the ALT_I2C3 instance. */
6228
#define ALT_I2C3_IC_DMA_RDLR_ADDR ALT_I2C_DMA_RDLR_ADDR(ALT_I2C3_ADDR)
6229
/* The address of the ALT_I2C_SDA_SETUP register for the ALT_I2C3 instance. */
6230
#define ALT_I2C3_IC_SDA_SETUP_ADDR ALT_I2C_SDA_SETUP_ADDR(ALT_I2C3_ADDR)
6231
/* The address of the ALT_I2C_ACK_GENERAL_CALL register for the ALT_I2C3 instance. */
6232
#define ALT_I2C3_IC_ACK_GENERAL_CALL_ADDR ALT_I2C_ACK_GENERAL_CALL_ADDR(ALT_I2C3_ADDR)
6233
/* The address of the ALT_I2C_EN_STAT register for the ALT_I2C3 instance. */
6234
#define ALT_I2C3_IC_EN_STAT_ADDR ALT_I2C_EN_STAT_ADDR(ALT_I2C3_ADDR)
6235
/* The address of the ALT_I2C_FS_SPKLEN register for the ALT_I2C3 instance. */
6236
#define ALT_I2C3_IC_FS_SPKLEN_ADDR ALT_I2C_FS_SPKLEN_ADDR(ALT_I2C3_ADDR)
6237
/* The address of the ALT_I2C_COMP_PARAM_1 register for the ALT_I2C3 instance. */
6238
#define ALT_I2C3_IC_COMP_PARAM_1_ADDR ALT_I2C_COMP_PARAM_1_ADDR(ALT_I2C3_ADDR)
6239
/* The address of the ALT_I2C_COMP_VER register for the ALT_I2C3 instance. */
6240
#define ALT_I2C3_IC_COMP_VER_ADDR ALT_I2C_COMP_VER_ADDR(ALT_I2C3_ADDR)
6241
/* The address of the ALT_I2C_COMP_TYPE register for the ALT_I2C3 instance. */
6242
#define ALT_I2C3_IC_COMP_TYPE_ADDR ALT_I2C_COMP_TYPE_ADDR(ALT_I2C3_ADDR)
6243
/* The base address byte offset for the start of the ALT_I2C3 component. */
6244
#define ALT_I2C3_OFST 0xffc07000
6245
/* The start address of the ALT_I2C3 component. */
6246
#define ALT_I2C3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_I2C3_OFST))
6247
/* The lower bound address range of the ALT_I2C3 component. */
6248
#define ALT_I2C3_LB_ADDR ALT_I2C3_ADDR
6249
/* The upper bound address range of the ALT_I2C3 component. */
6250
#define ALT_I2C3_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_I2C3_ADDR) + 0x100) - 1))
6251
6252
6253
6254
* Component Instance : sptimer0
6255
6256
* Instance sptimer0 of component ALT_TMR.
6257
6258
6259
6260
/* The address of the ALT_TMR_TMR1LDCOUNT register for the ALT_SPTMR0 instance. */
6261
#define ALT_SPTMR0_TMR1LDCOUNT_ADDR ALT_TMR_TMR1LDCOUNT_ADDR(ALT_SPTMR0_ADDR)
6262
/* The address of the ALT_TMR_TMR1CURVAL register for the ALT_SPTMR0 instance. */
6263
#define ALT_SPTMR0_TMR1CURVAL_ADDR ALT_TMR_TMR1CURVAL_ADDR(ALT_SPTMR0_ADDR)
6264
/* The address of the ALT_TMR_TMR1CTLREG register for the ALT_SPTMR0 instance. */
6265
#define ALT_SPTMR0_TMR1CTLREG_ADDR ALT_TMR_TMR1CTLREG_ADDR(ALT_SPTMR0_ADDR)
6266
/* The address of the ALT_TMR_TMR1EOI register for the ALT_SPTMR0 instance. */
6267
#define ALT_SPTMR0_TMR1EOI_ADDR ALT_TMR_TMR1EOI_ADDR(ALT_SPTMR0_ADDR)
6268
/* The address of the ALT_TMR_TMR1INTSTAT register for the ALT_SPTMR0 instance. */
6269
#define ALT_SPTMR0_TMR1INTSTAT_ADDR ALT_TMR_TMR1INTSTAT_ADDR(ALT_SPTMR0_ADDR)
6270
/* The address of the ALT_TMR_TMRSINTSTAT register for the ALT_SPTMR0 instance. */
6271
#define ALT_SPTMR0_TMRSINTSTAT_ADDR ALT_TMR_TMRSINTSTAT_ADDR(ALT_SPTMR0_ADDR)
6272
/* The address of the ALT_TMR_TMRSEOI register for the ALT_SPTMR0 instance. */
6273
#define ALT_SPTMR0_TMRSEOI_ADDR ALT_TMR_TMRSEOI_ADDR(ALT_SPTMR0_ADDR)
6274
/* The address of the ALT_TMR_TMRSRAWINTSTAT register for the ALT_SPTMR0 instance. */
6275
#define ALT_SPTMR0_TMRSRAWINTSTAT_ADDR ALT_TMR_TMRSRAWINTSTAT_ADDR(ALT_SPTMR0_ADDR)
6276
/* The address of the ALT_TMR_TMRSCOMPVER register for the ALT_SPTMR0 instance. */
6277
#define ALT_SPTMR0_TMRSCOMPVER_ADDR ALT_TMR_TMRSCOMPVER_ADDR(ALT_SPTMR0_ADDR)
6278
/* The base address byte offset for the start of the ALT_SPTMR0 component. */
6279
#define ALT_SPTMR0_OFST 0xffc08000
6280
/* The start address of the ALT_SPTMR0 component. */
6281
#define ALT_SPTMR0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPTMR0_OFST))
6282
/* The lower bound address range of the ALT_SPTMR0 component. */
6283
#define ALT_SPTMR0_LB_ADDR ALT_SPTMR0_ADDR
6284
/* The upper bound address range of the ALT_SPTMR0 component. */
6285
#define ALT_SPTMR0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPTMR0_ADDR) + 0x100) - 1))
6286
6287
6288
6289
* Component Instance : sptimer1
6290
6291
* Instance sptimer1 of component ALT_TMR.
6292
6293
6294
6295
/* The address of the ALT_TMR_TMR1LDCOUNT register for the ALT_SPTMR1 instance. */
6296
#define ALT_SPTMR1_TMR1LDCOUNT_ADDR ALT_TMR_TMR1LDCOUNT_ADDR(ALT_SPTMR1_ADDR)
6297
/* The address of the ALT_TMR_TMR1CURVAL register for the ALT_SPTMR1 instance. */
6298
#define ALT_SPTMR1_TMR1CURVAL_ADDR ALT_TMR_TMR1CURVAL_ADDR(ALT_SPTMR1_ADDR)
6299
/* The address of the ALT_TMR_TMR1CTLREG register for the ALT_SPTMR1 instance. */
6300
#define ALT_SPTMR1_TMR1CTLREG_ADDR ALT_TMR_TMR1CTLREG_ADDR(ALT_SPTMR1_ADDR)
6301
/* The address of the ALT_TMR_TMR1EOI register for the ALT_SPTMR1 instance. */
6302
#define ALT_SPTMR1_TMR1EOI_ADDR ALT_TMR_TMR1EOI_ADDR(ALT_SPTMR1_ADDR)
6303
/* The address of the ALT_TMR_TMR1INTSTAT register for the ALT_SPTMR1 instance. */
6304
#define ALT_SPTMR1_TMR1INTSTAT_ADDR ALT_TMR_TMR1INTSTAT_ADDR(ALT_SPTMR1_ADDR)
6305
/* The address of the ALT_TMR_TMRSINTSTAT register for the ALT_SPTMR1 instance. */
6306
#define ALT_SPTMR1_TMRSINTSTAT_ADDR ALT_TMR_TMRSINTSTAT_ADDR(ALT_SPTMR1_ADDR)
6307
/* The address of the ALT_TMR_TMRSEOI register for the ALT_SPTMR1 instance. */
6308
#define ALT_SPTMR1_TMRSEOI_ADDR ALT_TMR_TMRSEOI_ADDR(ALT_SPTMR1_ADDR)
6309
/* The address of the ALT_TMR_TMRSRAWINTSTAT register for the ALT_SPTMR1 instance. */
6310
#define ALT_SPTMR1_TMRSRAWINTSTAT_ADDR ALT_TMR_TMRSRAWINTSTAT_ADDR(ALT_SPTMR1_ADDR)
6311
/* The address of the ALT_TMR_TMRSCOMPVER register for the ALT_SPTMR1 instance. */
6312
#define ALT_SPTMR1_TMRSCOMPVER_ADDR ALT_TMR_TMRSCOMPVER_ADDR(ALT_SPTMR1_ADDR)
6313
/* The base address byte offset for the start of the ALT_SPTMR1 component. */
6314
#define ALT_SPTMR1_OFST 0xffc09000
6315
/* The start address of the ALT_SPTMR1 component. */
6316
#define ALT_SPTMR1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPTMR1_OFST))
6317
/* The lower bound address range of the ALT_SPTMR1 component. */
6318
#define ALT_SPTMR1_LB_ADDR ALT_SPTMR1_ADDR
6319
/* The upper bound address range of the ALT_SPTMR1 component. */
6320
#define ALT_SPTMR1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPTMR1_ADDR) + 0x100) - 1))
6321
6322
6323
6324
* Component Instance : sdr
6325
6326
* Instance sdr of component ALT_SDR.
6327
6328
6329
6330
6331
* Register Group Instance : ctrlgrp
6332
6333
* Instance ctrlgrp of register group ALT_SDR_CTL.
6334
6335
6336
6337
/* The address of the ALT_SDR_CTL_CTLCFG register for the ALT_SDR_CTL instance. */
6338
#define ALT_SDR_CTL_CTLCFG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_CTLCFG_OFST))
6339
/* The address of the ALT_SDR_CTL_DRAMTIMING1 register for the ALT_SDR_CTL instance. */
6340
#define ALT_SDR_CTL_DRAMTIMING1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMTIMING1_OFST))
6341
/* The address of the ALT_SDR_CTL_DRAMTIMING2 register for the ALT_SDR_CTL instance. */
6342
#define ALT_SDR_CTL_DRAMTIMING2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMTIMING2_OFST))
6343
/* The address of the ALT_SDR_CTL_DRAMTIMING3 register for the ALT_SDR_CTL instance. */
6344
#define ALT_SDR_CTL_DRAMTIMING3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMTIMING3_OFST))
6345
/* The address of the ALT_SDR_CTL_DRAMTIMING4 register for the ALT_SDR_CTL instance. */
6346
#define ALT_SDR_CTL_DRAMTIMING4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMTIMING4_OFST))
6347
/* The address of the ALT_SDR_CTL_LOWPWRTIMING register for the ALT_SDR_CTL instance. */
6348
#define ALT_SDR_CTL_LOWPWRTIMING_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_LOWPWRTIMING_OFST))
6349
/* The address of the ALT_SDR_CTL_DRAMODT register for the ALT_SDR_CTL instance. */
6350
#define ALT_SDR_CTL_DRAMODT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMODT_OFST))
6351
/* The address of the ALT_SDR_CTL_DRAMADDRW register for the ALT_SDR_CTL instance. */
6352
#define ALT_SDR_CTL_DRAMADDRW_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMADDRW_OFST))
6353
/* The address of the ALT_SDR_CTL_DRAMIFWIDTH register for the ALT_SDR_CTL instance. */
6354
#define ALT_SDR_CTL_DRAMIFWIDTH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMIFWIDTH_OFST))
6355
/* The address of the ALT_SDR_CTL_DRAMDEVWIDTH register for the ALT_SDR_CTL instance. */
6356
#define ALT_SDR_CTL_DRAMDEVWIDTH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMDEVWIDTH_OFST))
6357
/* The address of the ALT_SDR_CTL_DRAMSTS register for the ALT_SDR_CTL instance. */
6358
#define ALT_SDR_CTL_DRAMSTS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMSTS_OFST))
6359
/* The address of the ALT_SDR_CTL_DRAMINTR register for the ALT_SDR_CTL instance. */
6360
#define ALT_SDR_CTL_DRAMINTR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DRAMINTR_OFST))
6361
/* The address of the ALT_SDR_CTL_SBECOUNT register for the ALT_SDR_CTL instance. */
6362
#define ALT_SDR_CTL_SBECOUNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_SBECOUNT_OFST))
6363
/* The address of the ALT_SDR_CTL_DBECOUNT register for the ALT_SDR_CTL instance. */
6364
#define ALT_SDR_CTL_DBECOUNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DBECOUNT_OFST))
6365
/* The address of the ALT_SDR_CTL_ERRADDR register for the ALT_SDR_CTL instance. */
6366
#define ALT_SDR_CTL_ERRADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_ERRADDR_OFST))
6367
/* The address of the ALT_SDR_CTL_DROPCOUNT register for the ALT_SDR_CTL instance. */
6368
#define ALT_SDR_CTL_DROPCOUNT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DROPCOUNT_OFST))
6369
/* The address of the ALT_SDR_CTL_DROPADDR register for the ALT_SDR_CTL instance. */
6370
#define ALT_SDR_CTL_DROPADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_DROPADDR_OFST))
6371
/* The address of the ALT_SDR_CTL_LOWPWREQ register for the ALT_SDR_CTL instance. */
6372
#define ALT_SDR_CTL_LOWPWREQ_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_LOWPWREQ_OFST))
6373
/* The address of the ALT_SDR_CTL_LOWPWRACK register for the ALT_SDR_CTL instance. */
6374
#define ALT_SDR_CTL_LOWPWRACK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_LOWPWRACK_OFST))
6375
/* The address of the ALT_SDR_CTL_STATICCFG register for the ALT_SDR_CTL instance. */
6376
#define ALT_SDR_CTL_STATICCFG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_STATICCFG_OFST))
6377
/* The address of the ALT_SDR_CTL_CTLWIDTH register for the ALT_SDR_CTL instance. */
6378
#define ALT_SDR_CTL_CTLWIDTH_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_CTLWIDTH_OFST))
6379
/* The address of the ALT_SDR_CTL_PORTCFG register for the ALT_SDR_CTL instance. */
6380
#define ALT_SDR_CTL_PORTCFG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PORTCFG_OFST))
6381
/* The address of the ALT_SDR_CTL_FPGAPORTRST register for the ALT_SDR_CTL instance. */
6382
#define ALT_SDR_CTL_FPGAPORTRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_FPGAPORTRST_OFST))
6383
/* The address of the ALT_SDR_CTL_PROTPORTDEFAULT register for the ALT_SDR_CTL instance. */
6384
#define ALT_SDR_CTL_PROTPORTDEFAULT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PROTPORTDEFAULT_OFST))
6385
/* The address of the ALT_SDR_CTL_PROTRULEADDR register for the ALT_SDR_CTL instance. */
6386
#define ALT_SDR_CTL_PROTRULEADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PROTRULEADDR_OFST))
6387
/* The address of the ALT_SDR_CTL_PROTRULEID register for the ALT_SDR_CTL instance. */
6388
#define ALT_SDR_CTL_PROTRULEID_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PROTRULEID_OFST))
6389
/* The address of the ALT_SDR_CTL_PROTRULEDATA register for the ALT_SDR_CTL instance. */
6390
#define ALT_SDR_CTL_PROTRULEDATA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PROTRULEDATA_OFST))
6391
/* The address of the ALT_SDR_CTL_PROTRULERDWR register for the ALT_SDR_CTL instance. */
6392
#define ALT_SDR_CTL_PROTRULERDWR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_PROTRULERDWR_OFST))
6393
/* The address of the ALT_SDR_CTL_QOSLOWPRI register for the ALT_SDR_CTL instance. */
6394
#define ALT_SDR_CTL_QOSLOWPRI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_QOSLOWPRI_OFST))
6395
/* The address of the ALT_SDR_CTL_QOSHIGHPRI register for the ALT_SDR_CTL instance. */
6396
#define ALT_SDR_CTL_QOSHIGHPRI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_QOSHIGHPRI_OFST))
6397
/* The address of the ALT_SDR_CTL_QOSPRIORITYEN register for the ALT_SDR_CTL instance. */
6398
#define ALT_SDR_CTL_QOSPRIORITYEN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_QOSPRIORITYEN_OFST))
6399
/* The address of the ALT_SDR_CTL_MPPRIORITY register for the ALT_SDR_CTL instance. */
6400
#define ALT_SDR_CTL_MPPRIORITY_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_MPPRIORITY_OFST))
6401
/* The address of the ALT_SDR_CTL_REMAPPRIORITY register for the ALT_SDR_CTL instance. */
6402
#define ALT_SDR_CTL_REMAPPRIORITY_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_REMAPPRIORITY_OFST))
6403
6404
* Register Group Instance : ctrlgrp_mpweight
6405
6406
* Instance ctrlgrp_mpweight of register group ALT_SDR_CTL_MPWT.
6407
6408
6409
6410
/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4 register for the ALT_SDR_CTL_CTL_MPWEIGHT instance. */
6411
#define ALT_SDR_CTL_CTL_MPWEIGHT_MPWEIGHT_0_4_ADDR ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_ADDR(ALT_SDR_CTL_CTL_MPWEIGHT_ADDR)
6412
/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4 register for the ALT_SDR_CTL_CTL_MPWEIGHT instance. */
6413
#define ALT_SDR_CTL_CTL_MPWEIGHT_MPWEIGHT_1_4_ADDR ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_ADDR(ALT_SDR_CTL_CTL_MPWEIGHT_ADDR)
6414
/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4 register for the ALT_SDR_CTL_CTL_MPWEIGHT instance. */
6415
#define ALT_SDR_CTL_CTL_MPWEIGHT_MPWEIGHT_2_4_ADDR ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_ADDR(ALT_SDR_CTL_CTL_MPWEIGHT_ADDR)
6416
/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4 register for the ALT_SDR_CTL_CTL_MPWEIGHT instance. */
6417
#define ALT_SDR_CTL_CTL_MPWEIGHT_MPWEIGHT_3_4_ADDR ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_ADDR(ALT_SDR_CTL_CTL_MPWEIGHT_ADDR)
6418
/* The base address byte offset for the start of the ALT_SDR_CTL_CTL_MPWEIGHT component. */
6419
#define ALT_SDR_CTL_CTL_MPWEIGHT_OFST 0xb0
6420
/* The start address of the ALT_SDR_CTL_CTL_MPWEIGHT component. */
6421
#define ALT_SDR_CTL_CTL_MPWEIGHT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_CTL_ADDR) + ALT_SDR_CTL_CTL_MPWEIGHT_OFST))
6422
/* The lower bound address range of the ALT_SDR_CTL_CTL_MPWEIGHT component. */
6423
#define ALT_SDR_CTL_CTL_MPWEIGHT_LB_ADDR ALT_SDR_CTL_CTL_MPWEIGHT_ADDR
6424
/* The upper bound address range of the ALT_SDR_CTL_CTL_MPWEIGHT component. */
6425
#define ALT_SDR_CTL_CTL_MPWEIGHT_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SDR_CTL_CTL_MPWEIGHT_ADDR) + 0x10) - 1))
6426
6427
6428
/* The base address byte offset for the start of the ALT_SDR_CTL component. */
6429
#define ALT_SDR_CTL_OFST 0x5000
6430
/* The start address of the ALT_SDR_CTL component. */
6431
#define ALT_SDR_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SDR_ADDR) + ALT_SDR_CTL_OFST))
6432
/* The lower bound address range of the ALT_SDR_CTL component. */
6433
#define ALT_SDR_CTL_LB_ADDR ALT_SDR_CTL_ADDR
6434
/* The upper bound address range of the ALT_SDR_CTL component. */
6435
#define ALT_SDR_CTL_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SDR_CTL_ADDR) + 0x1000) - 1))
6436
6437
6438
/* The base address byte offset for the start of the ALT_SDR component. */
6439
#define ALT_SDR_OFST 0xffc20000
6440
/* The start address of the ALT_SDR component. */
6441
#define ALT_SDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SDR_OFST))
6442
/* The lower bound address range of the ALT_SDR component. */
6443
#define ALT_SDR_LB_ADDR ALT_SDR_ADDR
6444
/* The upper bound address range of the ALT_SDR component. */
6445
#define ALT_SDR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SDR_ADDR) + 0x20000) - 1))
6446
6447
6448
6449
* Component Instance : osc1timer0
6450
6451
* Instance osc1timer0 of component ALT_TMR.
6452
6453
6454
6455
/* The address of the ALT_TMR_TMR1LDCOUNT register for the ALT_OSC1TMR0 instance. */
6456
#define ALT_OSC1TMR0_TMR1LDCOUNT_ADDR ALT_TMR_TMR1LDCOUNT_ADDR(ALT_OSC1TMR0_ADDR)
6457
/* The address of the ALT_TMR_TMR1CURVAL register for the ALT_OSC1TMR0 instance. */
6458
#define ALT_OSC1TMR0_TMR1CURVAL_ADDR ALT_TMR_TMR1CURVAL_ADDR(ALT_OSC1TMR0_ADDR)
6459
/* The address of the ALT_TMR_TMR1CTLREG register for the ALT_OSC1TMR0 instance. */
6460
#define ALT_OSC1TMR0_TMR1CTLREG_ADDR ALT_TMR_TMR1CTLREG_ADDR(ALT_OSC1TMR0_ADDR)
6461
/* The address of the ALT_TMR_TMR1EOI register for the ALT_OSC1TMR0 instance. */
6462
#define ALT_OSC1TMR0_TMR1EOI_ADDR ALT_TMR_TMR1EOI_ADDR(ALT_OSC1TMR0_ADDR)
6463
/* The address of the ALT_TMR_TMR1INTSTAT register for the ALT_OSC1TMR0 instance. */
6464
#define ALT_OSC1TMR0_TMR1INTSTAT_ADDR ALT_TMR_TMR1INTSTAT_ADDR(ALT_OSC1TMR0_ADDR)
6465
/* The address of the ALT_TMR_TMRSINTSTAT register for the ALT_OSC1TMR0 instance. */
6466
#define ALT_OSC1TMR0_TMRSINTSTAT_ADDR ALT_TMR_TMRSINTSTAT_ADDR(ALT_OSC1TMR0_ADDR)
6467
/* The address of the ALT_TMR_TMRSEOI register for the ALT_OSC1TMR0 instance. */
6468
#define ALT_OSC1TMR0_TMRSEOI_ADDR ALT_TMR_TMRSEOI_ADDR(ALT_OSC1TMR0_ADDR)
6469
/* The address of the ALT_TMR_TMRSRAWINTSTAT register for the ALT_OSC1TMR0 instance. */
6470
#define ALT_OSC1TMR0_TMRSRAWINTSTAT_ADDR ALT_TMR_TMRSRAWINTSTAT_ADDR(ALT_OSC1TMR0_ADDR)
6471
/* The address of the ALT_TMR_TMRSCOMPVER register for the ALT_OSC1TMR0 instance. */
6472
#define ALT_OSC1TMR0_TMRSCOMPVER_ADDR ALT_TMR_TMRSCOMPVER_ADDR(ALT_OSC1TMR0_ADDR)
6473
/* The base address byte offset for the start of the ALT_OSC1TMR0 component. */
6474
#define ALT_OSC1TMR0_OFST 0xffd00000
6475
/* The start address of the ALT_OSC1TMR0 component. */
6476
#define ALT_OSC1TMR0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_OSC1TMR0_OFST))
6477
/* The lower bound address range of the ALT_OSC1TMR0 component. */
6478
#define ALT_OSC1TMR0_LB_ADDR ALT_OSC1TMR0_ADDR
6479
/* The upper bound address range of the ALT_OSC1TMR0 component. */
6480
#define ALT_OSC1TMR0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_OSC1TMR0_ADDR) + 0x100) - 1))
6481
6482
6483
6484
* Component Instance : osc1timer1
6485
6486
* Instance osc1timer1 of component ALT_TMR.
6487
6488
6489
6490
/* The address of the ALT_TMR_TMR1LDCOUNT register for the ALT_OSC1TMR1 instance. */
6491
#define ALT_OSC1TMR1_TMR1LDCOUNT_ADDR ALT_TMR_TMR1LDCOUNT_ADDR(ALT_OSC1TMR1_ADDR)
6492
/* The address of the ALT_TMR_TMR1CURVAL register for the ALT_OSC1TMR1 instance. */
6493
#define ALT_OSC1TMR1_TMR1CURVAL_ADDR ALT_TMR_TMR1CURVAL_ADDR(ALT_OSC1TMR1_ADDR)
6494
/* The address of the ALT_TMR_TMR1CTLREG register for the ALT_OSC1TMR1 instance. */
6495
#define ALT_OSC1TMR1_TMR1CTLREG_ADDR ALT_TMR_TMR1CTLREG_ADDR(ALT_OSC1TMR1_ADDR)
6496
/* The address of the ALT_TMR_TMR1EOI register for the ALT_OSC1TMR1 instance. */
6497
#define ALT_OSC1TMR1_TMR1EOI_ADDR ALT_TMR_TMR1EOI_ADDR(ALT_OSC1TMR1_ADDR)
6498
/* The address of the ALT_TMR_TMR1INTSTAT register for the ALT_OSC1TMR1 instance. */
6499
#define ALT_OSC1TMR1_TMR1INTSTAT_ADDR ALT_TMR_TMR1INTSTAT_ADDR(ALT_OSC1TMR1_ADDR)
6500
/* The address of the ALT_TMR_TMRSINTSTAT register for the ALT_OSC1TMR1 instance. */
6501
#define ALT_OSC1TMR1_TMRSINTSTAT_ADDR ALT_TMR_TMRSINTSTAT_ADDR(ALT_OSC1TMR1_ADDR)
6502
/* The address of the ALT_TMR_TMRSEOI register for the ALT_OSC1TMR1 instance. */
6503
#define ALT_OSC1TMR1_TMRSEOI_ADDR ALT_TMR_TMRSEOI_ADDR(ALT_OSC1TMR1_ADDR)
6504
/* The address of the ALT_TMR_TMRSRAWINTSTAT register for the ALT_OSC1TMR1 instance. */
6505
#define ALT_OSC1TMR1_TMRSRAWINTSTAT_ADDR ALT_TMR_TMRSRAWINTSTAT_ADDR(ALT_OSC1TMR1_ADDR)
6506
/* The address of the ALT_TMR_TMRSCOMPVER register for the ALT_OSC1TMR1 instance. */
6507
#define ALT_OSC1TMR1_TMRSCOMPVER_ADDR ALT_TMR_TMRSCOMPVER_ADDR(ALT_OSC1TMR1_ADDR)
6508
/* The base address byte offset for the start of the ALT_OSC1TMR1 component. */
6509
#define ALT_OSC1TMR1_OFST 0xffd01000
6510
/* The start address of the ALT_OSC1TMR1 component. */
6511
#define ALT_OSC1TMR1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_OSC1TMR1_OFST))
6512
/* The lower bound address range of the ALT_OSC1TMR1 component. */
6513
#define ALT_OSC1TMR1_LB_ADDR ALT_OSC1TMR1_ADDR
6514
/* The upper bound address range of the ALT_OSC1TMR1 component. */
6515
#define ALT_OSC1TMR1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_OSC1TMR1_ADDR) + 0x100) - 1))
6516
6517
6518
6519
* Component Instance : l4wd0
6520
6521
* Instance l4wd0 of component ALT_L4WD.
6522
6523
6524
6525
/* The address of the ALT_L4WD_CR register for the ALT_L4WD0 instance. */
6526
#define ALT_L4WD0_WDT_CR_ADDR ALT_L4WD_CR_ADDR(ALT_L4WD0_ADDR)
6527
/* The address of the ALT_L4WD_TORR register for the ALT_L4WD0 instance. */
6528
#define ALT_L4WD0_WDT_TORR_ADDR ALT_L4WD_TORR_ADDR(ALT_L4WD0_ADDR)
6529
/* The address of the ALT_L4WD_CCVR register for the ALT_L4WD0 instance. */
6530
#define ALT_L4WD0_WDT_CCVR_ADDR ALT_L4WD_CCVR_ADDR(ALT_L4WD0_ADDR)
6531
/* The address of the ALT_L4WD_CRR register for the ALT_L4WD0 instance. */
6532
#define ALT_L4WD0_WDT_CRR_ADDR ALT_L4WD_CRR_ADDR(ALT_L4WD0_ADDR)
6533
/* The address of the ALT_L4WD_STAT register for the ALT_L4WD0 instance. */
6534
#define ALT_L4WD0_WDT_STAT_ADDR ALT_L4WD_STAT_ADDR(ALT_L4WD0_ADDR)
6535
/* The address of the ALT_L4WD_EOI register for the ALT_L4WD0 instance. */
6536
#define ALT_L4WD0_WDT_EOI_ADDR ALT_L4WD_EOI_ADDR(ALT_L4WD0_ADDR)
6537
/* The address of the ALT_L4WD_CP_WDT_USER_TOP_MAX register for the ALT_L4WD0 instance. */
6538
#define ALT_L4WD0_CP_WDT_USER_TOP_MAX_ADDR ALT_L4WD_CP_WDT_USER_TOP_MAX_ADDR(ALT_L4WD0_ADDR)
6539
/* The address of the ALT_L4WD_CP_WDT_USER_TOP_INIT_MAX register for the ALT_L4WD0 instance. */
6540
#define ALT_L4WD0_CP_WDT_USER_TOP_INIT_MAX_ADDR ALT_L4WD_CP_WDT_USER_TOP_INIT_MAX_ADDR(ALT_L4WD0_ADDR)
6541
/* The address of the ALT_L4WD_CD_WDT_TOP_RST register for the ALT_L4WD0 instance. */
6542
#define ALT_L4WD0_CD_WDT_TOP_RST_ADDR ALT_L4WD_CD_WDT_TOP_RST_ADDR(ALT_L4WD0_ADDR)
6543
/* The address of the ALT_L4WD_CP_WDT_CNT_RST register for the ALT_L4WD0 instance. */
6544
#define ALT_L4WD0_CP_WDT_CNT_RST_ADDR ALT_L4WD_CP_WDT_CNT_RST_ADDR(ALT_L4WD0_ADDR)
6545
/* The address of the ALT_L4WD_COMP_PARAM_1 register for the ALT_L4WD0 instance. */
6546
#define ALT_L4WD0_WDT_COMP_PARAM_1_ADDR ALT_L4WD_COMP_PARAM_1_ADDR(ALT_L4WD0_ADDR)
6547
/* The address of the ALT_L4WD_COMP_VER register for the ALT_L4WD0 instance. */
6548
#define ALT_L4WD0_WDT_COMP_VER_ADDR ALT_L4WD_COMP_VER_ADDR(ALT_L4WD0_ADDR)
6549
/* The address of the ALT_L4WD_COMP_TYPE register for the ALT_L4WD0 instance. */
6550
#define ALT_L4WD0_WDT_COMP_TYPE_ADDR ALT_L4WD_COMP_TYPE_ADDR(ALT_L4WD0_ADDR)
6551
/* The base address byte offset for the start of the ALT_L4WD0 component. */
6552
#define ALT_L4WD0_OFST 0xffd02000
6553
/* The start address of the ALT_L4WD0 component. */
6554
#define ALT_L4WD0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_L4WD0_OFST))
6555
/* The lower bound address range of the ALT_L4WD0 component. */
6556
#define ALT_L4WD0_LB_ADDR ALT_L4WD0_ADDR
6557
/* The upper bound address range of the ALT_L4WD0 component. */
6558
#define ALT_L4WD0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L4WD0_ADDR) + 0x100) - 1))
6559
6560
6561
6562
* Component Instance : l4wd1
6563
6564
* Instance l4wd1 of component ALT_L4WD.
6565
6566
6567
6568
/* The address of the ALT_L4WD_CR register for the ALT_L4WD1 instance. */
6569
#define ALT_L4WD1_WDT_CR_ADDR ALT_L4WD_CR_ADDR(ALT_L4WD1_ADDR)
6570
/* The address of the ALT_L4WD_TORR register for the ALT_L4WD1 instance. */
6571
#define ALT_L4WD1_WDT_TORR_ADDR ALT_L4WD_TORR_ADDR(ALT_L4WD1_ADDR)
6572
/* The address of the ALT_L4WD_CCVR register for the ALT_L4WD1 instance. */
6573
#define ALT_L4WD1_WDT_CCVR_ADDR ALT_L4WD_CCVR_ADDR(ALT_L4WD1_ADDR)
6574
/* The address of the ALT_L4WD_CRR register for the ALT_L4WD1 instance. */
6575
#define ALT_L4WD1_WDT_CRR_ADDR ALT_L4WD_CRR_ADDR(ALT_L4WD1_ADDR)
6576
/* The address of the ALT_L4WD_STAT register for the ALT_L4WD1 instance. */
6577
#define ALT_L4WD1_WDT_STAT_ADDR ALT_L4WD_STAT_ADDR(ALT_L4WD1_ADDR)
6578
/* The address of the ALT_L4WD_EOI register for the ALT_L4WD1 instance. */
6579
#define ALT_L4WD1_WDT_EOI_ADDR ALT_L4WD_EOI_ADDR(ALT_L4WD1_ADDR)
6580
/* The address of the ALT_L4WD_CP_WDT_USER_TOP_MAX register for the ALT_L4WD1 instance. */
6581
#define ALT_L4WD1_CP_WDT_USER_TOP_MAX_ADDR ALT_L4WD_CP_WDT_USER_TOP_MAX_ADDR(ALT_L4WD1_ADDR)
6582
/* The address of the ALT_L4WD_CP_WDT_USER_TOP_INIT_MAX register for the ALT_L4WD1 instance. */
6583
#define ALT_L4WD1_CP_WDT_USER_TOP_INIT_MAX_ADDR ALT_L4WD_CP_WDT_USER_TOP_INIT_MAX_ADDR(ALT_L4WD1_ADDR)
6584
/* The address of the ALT_L4WD_CD_WDT_TOP_RST register for the ALT_L4WD1 instance. */
6585
#define ALT_L4WD1_CD_WDT_TOP_RST_ADDR ALT_L4WD_CD_WDT_TOP_RST_ADDR(ALT_L4WD1_ADDR)
6586
/* The address of the ALT_L4WD_CP_WDT_CNT_RST register for the ALT_L4WD1 instance. */
6587
#define ALT_L4WD1_CP_WDT_CNT_RST_ADDR ALT_L4WD_CP_WDT_CNT_RST_ADDR(ALT_L4WD1_ADDR)
6588
/* The address of the ALT_L4WD_COMP_PARAM_1 register for the ALT_L4WD1 instance. */
6589
#define ALT_L4WD1_WDT_COMP_PARAM_1_ADDR ALT_L4WD_COMP_PARAM_1_ADDR(ALT_L4WD1_ADDR)
6590
/* The address of the ALT_L4WD_COMP_VER register for the ALT_L4WD1 instance. */
6591
#define ALT_L4WD1_WDT_COMP_VER_ADDR ALT_L4WD_COMP_VER_ADDR(ALT_L4WD1_ADDR)
6592
/* The address of the ALT_L4WD_COMP_TYPE register for the ALT_L4WD1 instance. */
6593
#define ALT_L4WD1_WDT_COMP_TYPE_ADDR ALT_L4WD_COMP_TYPE_ADDR(ALT_L4WD1_ADDR)
6594
/* The base address byte offset for the start of the ALT_L4WD1 component. */
6595
#define ALT_L4WD1_OFST 0xffd03000
6596
/* The start address of the ALT_L4WD1 component. */
6597
#define ALT_L4WD1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_L4WD1_OFST))
6598
/* The lower bound address range of the ALT_L4WD1 component. */
6599
#define ALT_L4WD1_LB_ADDR ALT_L4WD1_ADDR
6600
/* The upper bound address range of the ALT_L4WD1 component. */
6601
#define ALT_L4WD1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_L4WD1_ADDR) + 0x100) - 1))
6602
6603
6604
6605
* Component Instance : clkmgr
6606
6607
* Instance clkmgr of component ALT_CLKMGR.
6608
6609
6610
6611
/* The address of the ALT_CLKMGR_CTL register for the ALT_CLKMGR instance. */
6612
#define ALT_CLKMGR_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_CTL_OFST))
6613
/* The address of the ALT_CLKMGR_BYPASS register for the ALT_CLKMGR instance. */
6614
#define ALT_CLKMGR_BYPASS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_BYPASS_OFST))
6615
/* The address of the ALT_CLKMGR_INTER register for the ALT_CLKMGR instance. */
6616
#define ALT_CLKMGR_INTER_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_INTER_OFST))
6617
/* The address of the ALT_CLKMGR_INTREN register for the ALT_CLKMGR instance. */
6618
#define ALT_CLKMGR_INTREN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_INTREN_OFST))
6619
/* The address of the ALT_CLKMGR_DBCTL register for the ALT_CLKMGR instance. */
6620
#define ALT_CLKMGR_DBCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_DBCTL_OFST))
6621
/* The address of the ALT_CLKMGR_STAT register for the ALT_CLKMGR instance. */
6622
#define ALT_CLKMGR_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_STAT_OFST))
6623
6624
* Register Group Instance : mainpllgrp
6625
6626
* Instance mainpllgrp of register group ALT_CLKMGR_MAINPLL.
6627
6628
6629
6630
/* The address of the ALT_CLKMGR_MAINPLL_VCO register for the ALT_CLKMGR_MAINPLL instance. */
6631
#define ALT_CLKMGR_MAINPLL_VCO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_VCO_OFST))
6632
/* The address of the ALT_CLKMGR_MAINPLL_MISC register for the ALT_CLKMGR_MAINPLL instance. */
6633
#define ALT_CLKMGR_MAINPLL_MISC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MISC_OFST))
6634
/* The address of the ALT_CLKMGR_MAINPLL_MPUCLK register for the ALT_CLKMGR_MAINPLL instance. */
6635
#define ALT_CLKMGR_MAINPLL_MPUCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MPUCLK_OFST))
6636
/* The address of the ALT_CLKMGR_MAINPLL_MAINCLK register for the ALT_CLKMGR_MAINPLL instance. */
6637
#define ALT_CLKMGR_MAINPLL_MAINCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MAINCLK_OFST))
6638
/* The address of the ALT_CLKMGR_MAINPLL_DBGATCLK register for the ALT_CLKMGR_MAINPLL instance. */
6639
#define ALT_CLKMGR_MAINPLL_DBGATCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_DBGATCLK_OFST))
6640
/* The address of the ALT_CLKMGR_MAINPLL_MAINQSPICLK register for the ALT_CLKMGR_MAINPLL instance. */
6641
#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MAINQSPICLK_OFST))
6642
/* The address of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK register for the ALT_CLKMGR_MAINPLL instance. */
6643
#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_OFST))
6644
/* The address of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK register for the ALT_CLKMGR_MAINPLL instance. */
6645
#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_OFST))
6646
/* The address of the ALT_CLKMGR_MAINPLL_EN register for the ALT_CLKMGR_MAINPLL instance. */
6647
#define ALT_CLKMGR_MAINPLL_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_EN_OFST))
6648
/* The address of the ALT_CLKMGR_MAINPLL_MAINDIV register for the ALT_CLKMGR_MAINPLL instance. */
6649
#define ALT_CLKMGR_MAINPLL_MAINDIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_MAINDIV_OFST))
6650
/* The address of the ALT_CLKMGR_MAINPLL_DBGDIV register for the ALT_CLKMGR_MAINPLL instance. */
6651
#define ALT_CLKMGR_MAINPLL_DBGDIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_DBGDIV_OFST))
6652
/* The address of the ALT_CLKMGR_MAINPLL_TRACEDIV register for the ALT_CLKMGR_MAINPLL instance. */
6653
#define ALT_CLKMGR_MAINPLL_TRACEDIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_TRACEDIV_OFST))
6654
/* The address of the ALT_CLKMGR_MAINPLL_L4SRC register for the ALT_CLKMGR_MAINPLL instance. */
6655
#define ALT_CLKMGR_MAINPLL_L4SRC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_L4SRC_OFST))
6656
/* The address of the ALT_CLKMGR_MAINPLL_STAT register for the ALT_CLKMGR_MAINPLL instance. */
6657
#define ALT_CLKMGR_MAINPLL_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + ALT_CLKMGR_MAINPLL_STAT_OFST))
6658
/* The base address byte offset for the start of the ALT_CLKMGR_MAINPLL component. */
6659
#define ALT_CLKMGR_MAINPLL_OFST 0x40
6660
/* The start address of the ALT_CLKMGR_MAINPLL component. */
6661
#define ALT_CLKMGR_MAINPLL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_MAINPLL_OFST))
6662
/* The lower bound address range of the ALT_CLKMGR_MAINPLL component. */
6663
#define ALT_CLKMGR_MAINPLL_LB_ADDR ALT_CLKMGR_MAINPLL_ADDR
6664
/* The upper bound address range of the ALT_CLKMGR_MAINPLL component. */
6665
#define ALT_CLKMGR_MAINPLL_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CLKMGR_MAINPLL_ADDR) + 0x40) - 1))
6666
6667
6668
6669
* Register Group Instance : perpllgrp
6670
6671
* Instance perpllgrp of register group ALT_CLKMGR_PERPLL.
6672
6673
6674
6675
/* The address of the ALT_CLKMGR_PERPLL_VCO register for the ALT_CLKMGR_PERPLL instance. */
6676
#define ALT_CLKMGR_PERPLL_VCO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_VCO_OFST))
6677
/* The address of the ALT_CLKMGR_PERPLL_MISC register for the ALT_CLKMGR_PERPLL instance. */
6678
#define ALT_CLKMGR_PERPLL_MISC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_MISC_OFST))
6679
/* The address of the ALT_CLKMGR_PERPLL_EMAC0CLK register for the ALT_CLKMGR_PERPLL instance. */
6680
#define ALT_CLKMGR_PERPLL_EMAC0CLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_EMAC0CLK_OFST))
6681
/* The address of the ALT_CLKMGR_PERPLL_EMAC1CLK register for the ALT_CLKMGR_PERPLL instance. */
6682
#define ALT_CLKMGR_PERPLL_EMAC1CLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_EMAC1CLK_OFST))
6683
/* The address of the ALT_CLKMGR_PERPLL_PERQSPICLK register for the ALT_CLKMGR_PERPLL instance. */
6684
#define ALT_CLKMGR_PERPLL_PERQSPICLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_PERQSPICLK_OFST))
6685
/* The address of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK register for the ALT_CLKMGR_PERPLL instance. */
6686
#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_OFST))
6687
/* The address of the ALT_CLKMGR_PERPLL_PERBASECLK register for the ALT_CLKMGR_PERPLL instance. */
6688
#define ALT_CLKMGR_PERPLL_PERBASECLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_PERBASECLK_OFST))
6689
/* The address of the ALT_CLKMGR_PERPLL_S2FUSER1CLK register for the ALT_CLKMGR_PERPLL instance. */
6690
#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_S2FUSER1CLK_OFST))
6691
/* The address of the ALT_CLKMGR_PERPLL_EN register for the ALT_CLKMGR_PERPLL instance. */
6692
#define ALT_CLKMGR_PERPLL_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_EN_OFST))
6693
/* The address of the ALT_CLKMGR_PERPLL_DIV register for the ALT_CLKMGR_PERPLL instance. */
6694
#define ALT_CLKMGR_PERPLL_DIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_DIV_OFST))
6695
/* The address of the ALT_CLKMGR_PERPLL_GPIODIV register for the ALT_CLKMGR_PERPLL instance. */
6696
#define ALT_CLKMGR_PERPLL_GPIODIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_GPIODIV_OFST))
6697
/* The address of the ALT_CLKMGR_PERPLL_SRC register for the ALT_CLKMGR_PERPLL instance. */
6698
#define ALT_CLKMGR_PERPLL_SRC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_SRC_OFST))
6699
/* The address of the ALT_CLKMGR_PERPLL_STAT register for the ALT_CLKMGR_PERPLL instance. */
6700
#define ALT_CLKMGR_PERPLL_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + ALT_CLKMGR_PERPLL_STAT_OFST))
6701
/* The base address byte offset for the start of the ALT_CLKMGR_PERPLL component. */
6702
#define ALT_CLKMGR_PERPLL_OFST 0x80
6703
/* The start address of the ALT_CLKMGR_PERPLL component. */
6704
#define ALT_CLKMGR_PERPLL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_PERPLL_OFST))
6705
/* The lower bound address range of the ALT_CLKMGR_PERPLL component. */
6706
#define ALT_CLKMGR_PERPLL_LB_ADDR ALT_CLKMGR_PERPLL_ADDR
6707
/* The upper bound address range of the ALT_CLKMGR_PERPLL component. */
6708
#define ALT_CLKMGR_PERPLL_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CLKMGR_PERPLL_ADDR) + 0x40) - 1))
6709
6710
6711
6712
* Register Group Instance : sdrpllgrp
6713
6714
* Instance sdrpllgrp of register group ALT_CLKMGR_SDRPLL.
6715
6716
6717
6718
/* The address of the ALT_CLKMGR_SDRPLL_VCO register for the ALT_CLKMGR_SDRPLL instance. */
6719
#define ALT_CLKMGR_SDRPLL_VCO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_VCO_OFST))
6720
/* The address of the ALT_CLKMGR_SDRPLL_CTL register for the ALT_CLKMGR_SDRPLL instance. */
6721
#define ALT_CLKMGR_SDRPLL_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_CTL_OFST))
6722
/* The address of the ALT_CLKMGR_SDRPLL_DDRDQSCLK register for the ALT_CLKMGR_SDRPLL instance. */
6723
#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_DDRDQSCLK_OFST))
6724
/* The address of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK register for the ALT_CLKMGR_SDRPLL instance. */
6725
#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_OFST))
6726
/* The address of the ALT_CLKMGR_SDRPLL_DDRDQCLK register for the ALT_CLKMGR_SDRPLL instance. */
6727
#define ALT_CLKMGR_SDRPLL_DDRDQCLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_DDRDQCLK_OFST))
6728
/* The address of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK register for the ALT_CLKMGR_SDRPLL instance. */
6729
#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_S2FUSER2CLK_OFST))
6730
/* The address of the ALT_CLKMGR_SDRPLL_EN register for the ALT_CLKMGR_SDRPLL instance. */
6731
#define ALT_CLKMGR_SDRPLL_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_EN_OFST))
6732
/* The address of the ALT_CLKMGR_SDRPLL_STAT register for the ALT_CLKMGR_SDRPLL instance. */
6733
#define ALT_CLKMGR_SDRPLL_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + ALT_CLKMGR_SDRPLL_STAT_OFST))
6734
/* The base address byte offset for the start of the ALT_CLKMGR_SDRPLL component. */
6735
#define ALT_CLKMGR_SDRPLL_OFST 0xc0
6736
/* The start address of the ALT_CLKMGR_SDRPLL component. */
6737
#define ALT_CLKMGR_SDRPLL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_CLKMGR_ADDR) + ALT_CLKMGR_SDRPLL_OFST))
6738
/* The lower bound address range of the ALT_CLKMGR_SDRPLL component. */
6739
#define ALT_CLKMGR_SDRPLL_LB_ADDR ALT_CLKMGR_SDRPLL_ADDR
6740
/* The upper bound address range of the ALT_CLKMGR_SDRPLL component. */
6741
#define ALT_CLKMGR_SDRPLL_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CLKMGR_SDRPLL_ADDR) + 0x20) - 1))
6742
6743
6744
/* The base address byte offset for the start of the ALT_CLKMGR component. */
6745
#define ALT_CLKMGR_OFST 0xffd04000
6746
/* The start address of the ALT_CLKMGR component. */
6747
#define ALT_CLKMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_CLKMGR_OFST))
6748
/* The lower bound address range of the ALT_CLKMGR component. */
6749
#define ALT_CLKMGR_LB_ADDR ALT_CLKMGR_ADDR
6750
/* The upper bound address range of the ALT_CLKMGR component. */
6751
#define ALT_CLKMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_CLKMGR_ADDR) + 0x200) - 1))
6752
6753
6754
6755
* Component Instance : rstmgr
6756
6757
* Instance rstmgr of component ALT_RSTMGR.
6758
6759
6760
6761
/* The address of the ALT_RSTMGR_STAT register for the ALT_RSTMGR instance. */
6762
#define ALT_RSTMGR_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_STAT_OFST))
6763
/* The address of the ALT_RSTMGR_CTL register for the ALT_RSTMGR instance. */
6764
#define ALT_RSTMGR_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_CTL_OFST))
6765
/* The address of the ALT_RSTMGR_COUNTS register for the ALT_RSTMGR instance. */
6766
#define ALT_RSTMGR_COUNTS_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_COUNTS_OFST))
6767
/* The address of the ALT_RSTMGR_MPUMODRST register for the ALT_RSTMGR instance. */
6768
#define ALT_RSTMGR_MPUMODRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_MPUMODRST_OFST))
6769
/* The address of the ALT_RSTMGR_PERMODRST register for the ALT_RSTMGR instance. */
6770
#define ALT_RSTMGR_PERMODRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_PERMODRST_OFST))
6771
/* The address of the ALT_RSTMGR_PER2MODRST register for the ALT_RSTMGR instance. */
6772
#define ALT_RSTMGR_PER2MODRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_PER2MODRST_OFST))
6773
/* The address of the ALT_RSTMGR_BRGMODRST register for the ALT_RSTMGR instance. */
6774
#define ALT_RSTMGR_BRGMODRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_BRGMODRST_OFST))
6775
/* The address of the ALT_RSTMGR_MISCMODRST register for the ALT_RSTMGR instance. */
6776
#define ALT_RSTMGR_MISCMODRST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_RSTMGR_ADDR) + ALT_RSTMGR_MISCMODRST_OFST))
6777
/* The base address byte offset for the start of the ALT_RSTMGR component. */
6778
#define ALT_RSTMGR_OFST 0xffd05000
6779
/* The start address of the ALT_RSTMGR component. */
6780
#define ALT_RSTMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_RSTMGR_OFST))
6781
/* The lower bound address range of the ALT_RSTMGR component. */
6782
#define ALT_RSTMGR_LB_ADDR ALT_RSTMGR_ADDR
6783
/* The upper bound address range of the ALT_RSTMGR component. */
6784
#define ALT_RSTMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_RSTMGR_ADDR) + 0x100) - 1))
6785
6786
6787
6788
* Component Instance : sysmgr
6789
6790
* Instance sysmgr of component ALT_SYSMGR.
6791
6792
6793
6794
/* The address of the ALT_SYSMGR_SILICONID1 register for the ALT_SYSMGR instance. */
6795
#define ALT_SYSMGR_SILICONID1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_SILICONID1_OFST))
6796
/* The address of the ALT_SYSMGR_SILICONID2 register for the ALT_SYSMGR instance. */
6797
#define ALT_SYSMGR_SILICONID2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_SILICONID2_OFST))
6798
/* The address of the ALT_SYSMGR_WDDBG register for the ALT_SYSMGR instance. */
6799
#define ALT_SYSMGR_WDDBG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_WDDBG_OFST))
6800
/* The address of the ALT_SYSMGR_BOOT register for the ALT_SYSMGR instance. */
6801
#define ALT_SYSMGR_BOOT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_BOOT_OFST))
6802
/* The address of the ALT_SYSMGR_HPSINFO register for the ALT_SYSMGR instance. */
6803
#define ALT_SYSMGR_HPSINFO_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_HPSINFO_OFST))
6804
/* The address of the ALT_SYSMGR_PARITYINJ register for the ALT_SYSMGR instance. */
6805
#define ALT_SYSMGR_PARITYINJ_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_PARITYINJ_OFST))
6806
6807
* Register Group Instance : fpgaintfgrp
6808
6809
* Instance fpgaintfgrp of register group ALT_SYSMGR_FPGAINTF.
6810
6811
6812
6813
/* The address of the ALT_SYSMGR_FPGAINTF_GBL register for the ALT_SYSMGR_FPGAINTF instance. */
6814
#define ALT_SYSMGR_FPGAINTF_GBL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FPGAINTF_ADDR) + ALT_SYSMGR_FPGAINTF_GBL_OFST))
6815
/* The address of the ALT_SYSMGR_FPGAINTF_INDIV register for the ALT_SYSMGR_FPGAINTF instance. */
6816
#define ALT_SYSMGR_FPGAINTF_INDIV_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FPGAINTF_ADDR) + ALT_SYSMGR_FPGAINTF_INDIV_OFST))
6817
/* The address of the ALT_SYSMGR_FPGAINTF_MODULE register for the ALT_SYSMGR_FPGAINTF instance. */
6818
#define ALT_SYSMGR_FPGAINTF_MODULE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FPGAINTF_ADDR) + ALT_SYSMGR_FPGAINTF_MODULE_OFST))
6819
/* The base address byte offset for the start of the ALT_SYSMGR_FPGAINTF component. */
6820
#define ALT_SYSMGR_FPGAINTF_OFST 0x20
6821
/* The start address of the ALT_SYSMGR_FPGAINTF component. */
6822
#define ALT_SYSMGR_FPGAINTF_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_FPGAINTF_OFST))
6823
/* The lower bound address range of the ALT_SYSMGR_FPGAINTF component. */
6824
#define ALT_SYSMGR_FPGAINTF_LB_ADDR ALT_SYSMGR_FPGAINTF_ADDR
6825
/* The upper bound address range of the ALT_SYSMGR_FPGAINTF component. */
6826
#define ALT_SYSMGR_FPGAINTF_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_FPGAINTF_ADDR) + 0x10) - 1))
6827
6828
6829
6830
* Register Group Instance : scanmgrgrp
6831
6832
* Instance scanmgrgrp of register group ALT_SYSMGR_SCANMGR.
6833
6834
6835
6836
/* The address of the ALT_SYSMGR_SCANMGR_CTL register for the ALT_SYSMGR_SCANMGR instance. */
6837
#define ALT_SYSMGR_SCANMGR_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_SCANMGR_ADDR) + ALT_SYSMGR_SCANMGR_CTL_OFST))
6838
/* The base address byte offset for the start of the ALT_SYSMGR_SCANMGR component. */
6839
#define ALT_SYSMGR_SCANMGR_OFST 0x30
6840
/* The start address of the ALT_SYSMGR_SCANMGR component. */
6841
#define ALT_SYSMGR_SCANMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_SCANMGR_OFST))
6842
/* The lower bound address range of the ALT_SYSMGR_SCANMGR component. */
6843
#define ALT_SYSMGR_SCANMGR_LB_ADDR ALT_SYSMGR_SCANMGR_ADDR
6844
/* The upper bound address range of the ALT_SYSMGR_SCANMGR component. */
6845
#define ALT_SYSMGR_SCANMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_SCANMGR_ADDR) + 0x4) - 1))
6846
6847
6848
6849
* Register Group Instance : frzctrl
6850
6851
* Instance frzctrl of register group ALT_SYSMGR_FRZCTL.
6852
6853
6854
6855
/* The address of the ALT_SYSMGR_FRZCTL_VIOCTL register for the ALT_SYSMGR_FRZCTL instance. */
6856
#define ALT_SYSMGR_FRZCTL_VIOCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FRZCTL_ADDR) + ALT_SYSMGR_FRZCTL_VIOCTL_OFST))
6857
/* The address of the ALT_SYSMGR_FRZCTL_HIOCTL register for the ALT_SYSMGR_FRZCTL instance. */
6858
#define ALT_SYSMGR_FRZCTL_HIOCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FRZCTL_ADDR) + ALT_SYSMGR_FRZCTL_HIOCTL_OFST))
6859
/* The address of the ALT_SYSMGR_FRZCTL_SRC register for the ALT_SYSMGR_FRZCTL instance. */
6860
#define ALT_SYSMGR_FRZCTL_SRC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FRZCTL_ADDR) + ALT_SYSMGR_FRZCTL_SRC_OFST))
6861
/* The address of the ALT_SYSMGR_FRZCTL_HWCTL register for the ALT_SYSMGR_FRZCTL instance. */
6862
#define ALT_SYSMGR_FRZCTL_HWCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_FRZCTL_ADDR) + ALT_SYSMGR_FRZCTL_HWCTL_OFST))
6863
/* The base address byte offset for the start of the ALT_SYSMGR_FRZCTL component. */
6864
#define ALT_SYSMGR_FRZCTL_OFST 0x40
6865
/* The start address of the ALT_SYSMGR_FRZCTL component. */
6866
#define ALT_SYSMGR_FRZCTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_FRZCTL_OFST))
6867
/* The lower bound address range of the ALT_SYSMGR_FRZCTL component. */
6868
#define ALT_SYSMGR_FRZCTL_LB_ADDR ALT_SYSMGR_FRZCTL_ADDR
6869
/* The upper bound address range of the ALT_SYSMGR_FRZCTL component. */
6870
#define ALT_SYSMGR_FRZCTL_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_FRZCTL_ADDR) + 0x20) - 1))
6871
6872
6873
6874
* Register Group Instance : emacgrp
6875
6876
* Instance emacgrp of register group ALT_SYSMGR_EMAC.
6877
6878
6879
6880
/* The address of the ALT_SYSMGR_EMAC_CTL register for the ALT_SYSMGR_EMAC instance. */
6881
#define ALT_SYSMGR_EMAC_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_EMAC_ADDR) + ALT_SYSMGR_EMAC_CTL_OFST))
6882
/* The address of the ALT_SYSMGR_EMAC_L3MST register for the ALT_SYSMGR_EMAC instance. */
6883
#define ALT_SYSMGR_EMAC_L3MST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_EMAC_ADDR) + ALT_SYSMGR_EMAC_L3MST_OFST))
6884
/* The base address byte offset for the start of the ALT_SYSMGR_EMAC component. */
6885
#define ALT_SYSMGR_EMAC_OFST 0x60
6886
/* The start address of the ALT_SYSMGR_EMAC component. */
6887
#define ALT_SYSMGR_EMAC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_EMAC_OFST))
6888
/* The lower bound address range of the ALT_SYSMGR_EMAC component. */
6889
#define ALT_SYSMGR_EMAC_LB_ADDR ALT_SYSMGR_EMAC_ADDR
6890
/* The upper bound address range of the ALT_SYSMGR_EMAC component. */
6891
#define ALT_SYSMGR_EMAC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_EMAC_ADDR) + 0x10) - 1))
6892
6893
6894
6895
* Register Group Instance : dmagrp
6896
6897
* Instance dmagrp of register group ALT_SYSMGR_DMA.
6898
6899
6900
6901
/* The address of the ALT_SYSMGR_DMA_CTL register for the ALT_SYSMGR_DMA instance. */
6902
#define ALT_SYSMGR_DMA_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_DMA_ADDR) + ALT_SYSMGR_DMA_CTL_OFST))
6903
/* The address of the ALT_SYSMGR_DMA_PERSECURITY register for the ALT_SYSMGR_DMA instance. */
6904
#define ALT_SYSMGR_DMA_PERSECURITY_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_DMA_ADDR) + ALT_SYSMGR_DMA_PERSECURITY_OFST))
6905
/* The base address byte offset for the start of the ALT_SYSMGR_DMA component. */
6906
#define ALT_SYSMGR_DMA_OFST 0x70
6907
/* The start address of the ALT_SYSMGR_DMA component. */
6908
#define ALT_SYSMGR_DMA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_DMA_OFST))
6909
/* The lower bound address range of the ALT_SYSMGR_DMA component. */
6910
#define ALT_SYSMGR_DMA_LB_ADDR ALT_SYSMGR_DMA_ADDR
6911
/* The upper bound address range of the ALT_SYSMGR_DMA component. */
6912
#define ALT_SYSMGR_DMA_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_DMA_ADDR) + 0x8) - 1))
6913
6914
6915
6916
* Register Group Instance : iswgrp
6917
6918
* Instance iswgrp of register group ALT_SYSMGR_ISW.
6919
6920
6921
6922
/* The address of the ALT_SYSMGR_ISW_HANDOFF register for the ALT_SYSMGR_ISW instance. */
6923
#define ALT_SYSMGR_ISW_HANDOFF_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ISW_ADDR) + ALT_SYSMGR_ISW_HANDOFF_OFST))
6924
/* The base address byte offset for the start of the ALT_SYSMGR_ISW component. */
6925
#define ALT_SYSMGR_ISW_OFST 0x80
6926
/* The start address of the ALT_SYSMGR_ISW component. */
6927
#define ALT_SYSMGR_ISW_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_ISW_OFST))
6928
/* The lower bound address range of the ALT_SYSMGR_ISW component. */
6929
#define ALT_SYSMGR_ISW_LB_ADDR ALT_SYSMGR_ISW_ADDR
6930
/* The upper bound address range of the ALT_SYSMGR_ISW component. */
6931
#define ALT_SYSMGR_ISW_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ISW_ADDR) + 0x20) - 1))
6932
6933
6934
6935
* Register Group Instance : romcodegrp
6936
6937
* Instance romcodegrp of register group ALT_SYSMGR_ROMCODE.
6938
6939
6940
6941
/* The address of the ALT_SYSMGR_ROMCODE_CTL register for the ALT_SYSMGR_ROMCODE instance. */
6942
#define ALT_SYSMGR_ROMCODE_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_CTL_OFST))
6943
/* The address of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR register for the ALT_SYSMGR_ROMCODE instance. */
6944
#define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_CPU1STARTADDR_OFST))
6945
/* The address of the ALT_SYSMGR_ROMCODE_INITSWSTATE register for the ALT_SYSMGR_ROMCODE instance. */
6946
#define ALT_SYSMGR_ROMCODE_INITSWSTATE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_INITSWSTATE_OFST))
6947
/* The address of the ALT_SYSMGR_ROMCODE_INITSWLASTLD register for the ALT_SYSMGR_ROMCODE instance. */
6948
#define ALT_SYSMGR_ROMCODE_INITSWLASTLD_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_INITSWLASTLD_OFST))
6949
/* The address of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE register for the ALT_SYSMGR_ROMCODE instance. */
6950
#define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_OFST))
6951
6952
* Register Group Instance : romcodegrp_warmramgrp
6953
6954
* Instance romcodegrp_warmramgrp of register group ALT_SYSMGR_ROMCODE_WARMRAM.
6955
6956
6957
6958
/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_EN register for the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP instance. */
6959
#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAM_EN_ADDR ALT_SYSMGR_ROMCODE_WARMRAM_EN_ADDR(ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR)
6960
/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART register for the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP instance. */
6961
#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAM_DATASTART_ADDR ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_ADDR(ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR)
6962
/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN register for the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP instance. */
6963
#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAM_LEN_ADDR ALT_SYSMGR_ROMCODE_WARMRAM_LEN_ADDR(ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR)
6964
/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION register for the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP instance. */
6965
#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAM_EXECUTION_ADDR ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_ADDR(ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR)
6966
/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC register for the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP instance. */
6967
#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAM_CRC_ADDR ALT_SYSMGR_ROMCODE_WARMRAM_CRC_ADDR(ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR)
6968
/* The base address byte offset for the start of the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP component. */
6969
#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_OFST 0x20
6970
/* The start address of the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP component. */
6971
#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_OFST))
6972
/* The lower bound address range of the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP component. */
6973
#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_LB_ADDR ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR
6974
/* The upper bound address range of the ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP component. */
6975
#define ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ROMCODE_WARMRAMGRP_ADDR) + 0x20) - 1))
6976
6977
6978
/* The base address byte offset for the start of the ALT_SYSMGR_ROMCODE component. */
6979
#define ALT_SYSMGR_ROMCODE_OFST 0xc0
6980
/* The start address of the ALT_SYSMGR_ROMCODE component. */
6981
#define ALT_SYSMGR_ROMCODE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_ROMCODE_OFST))
6982
/* The lower bound address range of the ALT_SYSMGR_ROMCODE component. */
6983
#define ALT_SYSMGR_ROMCODE_LB_ADDR ALT_SYSMGR_ROMCODE_ADDR
6984
/* The upper bound address range of the ALT_SYSMGR_ROMCODE component. */
6985
#define ALT_SYSMGR_ROMCODE_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ROMCODE_ADDR) + 0x40) - 1))
6986
6987
6988
6989
* Register Group Instance : romhwgrp
6990
6991
* Instance romhwgrp of register group ALT_SYSMGR_ROMHW.
6992
6993
6994
6995
/* The address of the ALT_SYSMGR_ROMHW_CTL register for the ALT_SYSMGR_ROMHW instance. */
6996
#define ALT_SYSMGR_ROMHW_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ROMHW_ADDR) + ALT_SYSMGR_ROMHW_CTL_OFST))
6997
/* The base address byte offset for the start of the ALT_SYSMGR_ROMHW component. */
6998
#define ALT_SYSMGR_ROMHW_OFST 0x100
6999
/* The start address of the ALT_SYSMGR_ROMHW component. */
7000
#define ALT_SYSMGR_ROMHW_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_ROMHW_OFST))
7001
/* The lower bound address range of the ALT_SYSMGR_ROMHW component. */
7002
#define ALT_SYSMGR_ROMHW_LB_ADDR ALT_SYSMGR_ROMHW_ADDR
7003
/* The upper bound address range of the ALT_SYSMGR_ROMHW component. */
7004
#define ALT_SYSMGR_ROMHW_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ROMHW_ADDR) + 0x4) - 1))
7005
7006
7007
7008
* Register Group Instance : sdmmcgrp
7009
7010
* Instance sdmmcgrp of register group ALT_SYSMGR_SDMMC.
7011
7012
7013
7014
/* The address of the ALT_SYSMGR_SDMMC_CTL register for the ALT_SYSMGR_SDMMC instance. */
7015
#define ALT_SYSMGR_SDMMC_CTL_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_SDMMC_ADDR) + ALT_SYSMGR_SDMMC_CTL_OFST))
7016
/* The address of the ALT_SYSMGR_SDMMC_L3MST register for the ALT_SYSMGR_SDMMC instance. */
7017
#define ALT_SYSMGR_SDMMC_L3MST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_SDMMC_ADDR) + ALT_SYSMGR_SDMMC_L3MST_OFST))
7018
/* The base address byte offset for the start of the ALT_SYSMGR_SDMMC component. */
7019
#define ALT_SYSMGR_SDMMC_OFST 0x108
7020
/* The start address of the ALT_SYSMGR_SDMMC component. */
7021
#define ALT_SYSMGR_SDMMC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_SDMMC_OFST))
7022
/* The lower bound address range of the ALT_SYSMGR_SDMMC component. */
7023
#define ALT_SYSMGR_SDMMC_LB_ADDR ALT_SYSMGR_SDMMC_ADDR
7024
/* The upper bound address range of the ALT_SYSMGR_SDMMC component. */
7025
#define ALT_SYSMGR_SDMMC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_SDMMC_ADDR) + 0x8) - 1))
7026
7027
7028
7029
* Register Group Instance : nandgrp
7030
7031
* Instance nandgrp of register group ALT_SYSMGR_NAND.
7032
7033
7034
7035
/* The address of the ALT_SYSMGR_NAND_BOOTSTRAP register for the ALT_SYSMGR_NAND instance. */
7036
#define ALT_SYSMGR_NAND_BOOTSTRAP_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_NAND_ADDR) + ALT_SYSMGR_NAND_BOOTSTRAP_OFST))
7037
/* The address of the ALT_SYSMGR_NAND_L3MST register for the ALT_SYSMGR_NAND instance. */
7038
#define ALT_SYSMGR_NAND_L3MST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_NAND_ADDR) + ALT_SYSMGR_NAND_L3MST_OFST))
7039
/* The base address byte offset for the start of the ALT_SYSMGR_NAND component. */
7040
#define ALT_SYSMGR_NAND_OFST 0x110
7041
/* The start address of the ALT_SYSMGR_NAND component. */
7042
#define ALT_SYSMGR_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_NAND_OFST))
7043
/* The lower bound address range of the ALT_SYSMGR_NAND component. */
7044
#define ALT_SYSMGR_NAND_LB_ADDR ALT_SYSMGR_NAND_ADDR
7045
/* The upper bound address range of the ALT_SYSMGR_NAND component. */
7046
#define ALT_SYSMGR_NAND_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_NAND_ADDR) + 0x8) - 1))
7047
7048
7049
7050
* Register Group Instance : usbgrp
7051
7052
* Instance usbgrp of register group ALT_SYSMGR_USB.
7053
7054
7055
7056
/* The address of the ALT_SYSMGR_USB_L3MST register for the ALT_SYSMGR_USB instance. */
7057
#define ALT_SYSMGR_USB_L3MST_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_USB_ADDR) + ALT_SYSMGR_USB_L3MST_OFST))
7058
/* The base address byte offset for the start of the ALT_SYSMGR_USB component. */
7059
#define ALT_SYSMGR_USB_OFST 0x118
7060
/* The start address of the ALT_SYSMGR_USB component. */
7061
#define ALT_SYSMGR_USB_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_USB_OFST))
7062
/* The lower bound address range of the ALT_SYSMGR_USB component. */
7063
#define ALT_SYSMGR_USB_LB_ADDR ALT_SYSMGR_USB_ADDR
7064
/* The upper bound address range of the ALT_SYSMGR_USB component. */
7065
#define ALT_SYSMGR_USB_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_USB_ADDR) + 0x4) - 1))
7066
7067
7068
7069
* Register Group Instance : eccgrp
7070
7071
* Instance eccgrp of register group ALT_SYSMGR_ECC.
7072
7073
7074
7075
/* The address of the ALT_SYSMGR_ECC_L2 register for the ALT_SYSMGR_ECC instance. */
7076
#define ALT_SYSMGR_ECC_L2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_L2_OFST))
7077
/* The address of the ALT_SYSMGR_ECC_OCRAM register for the ALT_SYSMGR_ECC instance. */
7078
#define ALT_SYSMGR_ECC_OCRAM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_OCRAM_OFST))
7079
/* The address of the ALT_SYSMGR_ECC_USB0 register for the ALT_SYSMGR_ECC instance. */
7080
#define ALT_SYSMGR_ECC_USB0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_USB0_OFST))
7081
/* The address of the ALT_SYSMGR_ECC_USB1 register for the ALT_SYSMGR_ECC instance. */
7082
#define ALT_SYSMGR_ECC_USB1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_USB1_OFST))
7083
/* The address of the ALT_SYSMGR_ECC_EMAC0 register for the ALT_SYSMGR_ECC instance. */
7084
#define ALT_SYSMGR_ECC_EMAC0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_EMAC0_OFST))
7085
/* The address of the ALT_SYSMGR_ECC_EMAC1 register for the ALT_SYSMGR_ECC instance. */
7086
#define ALT_SYSMGR_ECC_EMAC1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_EMAC1_OFST))
7087
/* The address of the ALT_SYSMGR_ECC_DMA register for the ALT_SYSMGR_ECC instance. */
7088
#define ALT_SYSMGR_ECC_DMA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_DMA_OFST))
7089
/* The address of the ALT_SYSMGR_ECC_CAN0 register for the ALT_SYSMGR_ECC instance. */
7090
#define ALT_SYSMGR_ECC_CAN0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_CAN0_OFST))
7091
/* The address of the ALT_SYSMGR_ECC_CAN1 register for the ALT_SYSMGR_ECC instance. */
7092
#define ALT_SYSMGR_ECC_CAN1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_CAN1_OFST))
7093
/* The address of the ALT_SYSMGR_ECC_NAND register for the ALT_SYSMGR_ECC instance. */
7094
#define ALT_SYSMGR_ECC_NAND_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_NAND_OFST))
7095
/* The address of the ALT_SYSMGR_ECC_QSPI register for the ALT_SYSMGR_ECC instance. */
7096
#define ALT_SYSMGR_ECC_QSPI_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_QSPI_OFST))
7097
/* The address of the ALT_SYSMGR_ECC_SDMMC register for the ALT_SYSMGR_ECC instance. */
7098
#define ALT_SYSMGR_ECC_SDMMC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + ALT_SYSMGR_ECC_SDMMC_OFST))
7099
/* The base address byte offset for the start of the ALT_SYSMGR_ECC component. */
7100
#define ALT_SYSMGR_ECC_OFST 0x140
7101
/* The start address of the ALT_SYSMGR_ECC component. */
7102
#define ALT_SYSMGR_ECC_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_ECC_OFST))
7103
/* The lower bound address range of the ALT_SYSMGR_ECC component. */
7104
#define ALT_SYSMGR_ECC_LB_ADDR ALT_SYSMGR_ECC_ADDR
7105
/* The upper bound address range of the ALT_SYSMGR_ECC component. */
7106
#define ALT_SYSMGR_ECC_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ECC_ADDR) + 0x40) - 1))
7107
7108
7109
7110
* Register Group Instance : pinmuxgrp
7111
7112
* Instance pinmuxgrp of register group ALT_SYSMGR_PINMUX.
7113
7114
7115
7116
/* The address of the ALT_SYSMGR_PINMUX_EMACIO0 register for the ALT_SYSMGR_PINMUX instance. */
7117
#define ALT_SYSMGR_PINMUX_EMACIO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO0_OFST))
7118
/* The address of the ALT_SYSMGR_PINMUX_EMACIO1 register for the ALT_SYSMGR_PINMUX instance. */
7119
#define ALT_SYSMGR_PINMUX_EMACIO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO1_OFST))
7120
/* The address of the ALT_SYSMGR_PINMUX_EMACIO2 register for the ALT_SYSMGR_PINMUX instance. */
7121
#define ALT_SYSMGR_PINMUX_EMACIO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO2_OFST))
7122
/* The address of the ALT_SYSMGR_PINMUX_EMACIO3 register for the ALT_SYSMGR_PINMUX instance. */
7123
#define ALT_SYSMGR_PINMUX_EMACIO3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO3_OFST))
7124
/* The address of the ALT_SYSMGR_PINMUX_EMACIO4 register for the ALT_SYSMGR_PINMUX instance. */
7125
#define ALT_SYSMGR_PINMUX_EMACIO4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO4_OFST))
7126
/* The address of the ALT_SYSMGR_PINMUX_EMACIO5 register for the ALT_SYSMGR_PINMUX instance. */
7127
#define ALT_SYSMGR_PINMUX_EMACIO5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO5_OFST))
7128
/* The address of the ALT_SYSMGR_PINMUX_EMACIO6 register for the ALT_SYSMGR_PINMUX instance. */
7129
#define ALT_SYSMGR_PINMUX_EMACIO6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO6_OFST))
7130
/* The address of the ALT_SYSMGR_PINMUX_EMACIO7 register for the ALT_SYSMGR_PINMUX instance. */
7131
#define ALT_SYSMGR_PINMUX_EMACIO7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO7_OFST))
7132
/* The address of the ALT_SYSMGR_PINMUX_EMACIO8 register for the ALT_SYSMGR_PINMUX instance. */
7133
#define ALT_SYSMGR_PINMUX_EMACIO8_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO8_OFST))
7134
/* The address of the ALT_SYSMGR_PINMUX_EMACIO9 register for the ALT_SYSMGR_PINMUX instance. */
7135
#define ALT_SYSMGR_PINMUX_EMACIO9_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO9_OFST))
7136
/* The address of the ALT_SYSMGR_PINMUX_EMACIO10 register for the ALT_SYSMGR_PINMUX instance. */
7137
#define ALT_SYSMGR_PINMUX_EMACIO10_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO10_OFST))
7138
/* The address of the ALT_SYSMGR_PINMUX_EMACIO11 register for the ALT_SYSMGR_PINMUX instance. */
7139
#define ALT_SYSMGR_PINMUX_EMACIO11_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO11_OFST))
7140
/* The address of the ALT_SYSMGR_PINMUX_EMACIO12 register for the ALT_SYSMGR_PINMUX instance. */
7141
#define ALT_SYSMGR_PINMUX_EMACIO12_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO12_OFST))
7142
/* The address of the ALT_SYSMGR_PINMUX_EMACIO13 register for the ALT_SYSMGR_PINMUX instance. */
7143
#define ALT_SYSMGR_PINMUX_EMACIO13_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO13_OFST))
7144
/* The address of the ALT_SYSMGR_PINMUX_EMACIO14 register for the ALT_SYSMGR_PINMUX instance. */
7145
#define ALT_SYSMGR_PINMUX_EMACIO14_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO14_OFST))
7146
/* The address of the ALT_SYSMGR_PINMUX_EMACIO15 register for the ALT_SYSMGR_PINMUX instance. */
7147
#define ALT_SYSMGR_PINMUX_EMACIO15_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO15_OFST))
7148
/* The address of the ALT_SYSMGR_PINMUX_EMACIO16 register for the ALT_SYSMGR_PINMUX instance. */
7149
#define ALT_SYSMGR_PINMUX_EMACIO16_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO16_OFST))
7150
/* The address of the ALT_SYSMGR_PINMUX_EMACIO17 register for the ALT_SYSMGR_PINMUX instance. */
7151
#define ALT_SYSMGR_PINMUX_EMACIO17_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO17_OFST))
7152
/* The address of the ALT_SYSMGR_PINMUX_EMACIO18 register for the ALT_SYSMGR_PINMUX instance. */
7153
#define ALT_SYSMGR_PINMUX_EMACIO18_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO18_OFST))
7154
/* The address of the ALT_SYSMGR_PINMUX_EMACIO19 register for the ALT_SYSMGR_PINMUX instance. */
7155
#define ALT_SYSMGR_PINMUX_EMACIO19_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_EMACIO19_OFST))
7156
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO0 register for the ALT_SYSMGR_PINMUX instance. */
7157
#define ALT_SYSMGR_PINMUX_FLSHIO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO0_OFST))
7158
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO1 register for the ALT_SYSMGR_PINMUX instance. */
7159
#define ALT_SYSMGR_PINMUX_FLSHIO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO1_OFST))
7160
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO2 register for the ALT_SYSMGR_PINMUX instance. */
7161
#define ALT_SYSMGR_PINMUX_FLSHIO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO2_OFST))
7162
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO3 register for the ALT_SYSMGR_PINMUX instance. */
7163
#define ALT_SYSMGR_PINMUX_FLSHIO3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO3_OFST))
7164
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO4 register for the ALT_SYSMGR_PINMUX instance. */
7165
#define ALT_SYSMGR_PINMUX_FLSHIO4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO4_OFST))
7166
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO5 register for the ALT_SYSMGR_PINMUX instance. */
7167
#define ALT_SYSMGR_PINMUX_FLSHIO5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO5_OFST))
7168
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO6 register for the ALT_SYSMGR_PINMUX instance. */
7169
#define ALT_SYSMGR_PINMUX_FLSHIO6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO6_OFST))
7170
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO7 register for the ALT_SYSMGR_PINMUX instance. */
7171
#define ALT_SYSMGR_PINMUX_FLSHIO7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO7_OFST))
7172
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO8 register for the ALT_SYSMGR_PINMUX instance. */
7173
#define ALT_SYSMGR_PINMUX_FLSHIO8_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO8_OFST))
7174
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO9 register for the ALT_SYSMGR_PINMUX instance. */
7175
#define ALT_SYSMGR_PINMUX_FLSHIO9_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO9_OFST))
7176
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO10 register for the ALT_SYSMGR_PINMUX instance. */
7177
#define ALT_SYSMGR_PINMUX_FLSHIO10_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO10_OFST))
7178
/* The address of the ALT_SYSMGR_PINMUX_FLSHIO11 register for the ALT_SYSMGR_PINMUX instance. */
7179
#define ALT_SYSMGR_PINMUX_FLSHIO11_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_FLSHIO11_OFST))
7180
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO0 register for the ALT_SYSMGR_PINMUX instance. */
7181
#define ALT_SYSMGR_PINMUX_GENERALIO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO0_OFST))
7182
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO1 register for the ALT_SYSMGR_PINMUX instance. */
7183
#define ALT_SYSMGR_PINMUX_GENERALIO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO1_OFST))
7184
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO2 register for the ALT_SYSMGR_PINMUX instance. */
7185
#define ALT_SYSMGR_PINMUX_GENERALIO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO2_OFST))
7186
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO3 register for the ALT_SYSMGR_PINMUX instance. */
7187
#define ALT_SYSMGR_PINMUX_GENERALIO3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO3_OFST))
7188
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO4 register for the ALT_SYSMGR_PINMUX instance. */
7189
#define ALT_SYSMGR_PINMUX_GENERALIO4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO4_OFST))
7190
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO5 register for the ALT_SYSMGR_PINMUX instance. */
7191
#define ALT_SYSMGR_PINMUX_GENERALIO5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO5_OFST))
7192
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO6 register for the ALT_SYSMGR_PINMUX instance. */
7193
#define ALT_SYSMGR_PINMUX_GENERALIO6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO6_OFST))
7194
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO7 register for the ALT_SYSMGR_PINMUX instance. */
7195
#define ALT_SYSMGR_PINMUX_GENERALIO7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO7_OFST))
7196
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO8 register for the ALT_SYSMGR_PINMUX instance. */
7197
#define ALT_SYSMGR_PINMUX_GENERALIO8_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO8_OFST))
7198
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO9 register for the ALT_SYSMGR_PINMUX instance. */
7199
#define ALT_SYSMGR_PINMUX_GENERALIO9_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO9_OFST))
7200
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO10 register for the ALT_SYSMGR_PINMUX instance. */
7201
#define ALT_SYSMGR_PINMUX_GENERALIO10_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO10_OFST))
7202
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO11 register for the ALT_SYSMGR_PINMUX instance. */
7203
#define ALT_SYSMGR_PINMUX_GENERALIO11_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO11_OFST))
7204
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO12 register for the ALT_SYSMGR_PINMUX instance. */
7205
#define ALT_SYSMGR_PINMUX_GENERALIO12_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO12_OFST))
7206
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO13 register for the ALT_SYSMGR_PINMUX instance. */
7207
#define ALT_SYSMGR_PINMUX_GENERALIO13_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO13_OFST))
7208
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO14 register for the ALT_SYSMGR_PINMUX instance. */
7209
#define ALT_SYSMGR_PINMUX_GENERALIO14_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO14_OFST))
7210
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO15 register for the ALT_SYSMGR_PINMUX instance. */
7211
#define ALT_SYSMGR_PINMUX_GENERALIO15_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO15_OFST))
7212
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO16 register for the ALT_SYSMGR_PINMUX instance. */
7213
#define ALT_SYSMGR_PINMUX_GENERALIO16_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO16_OFST))
7214
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO17 register for the ALT_SYSMGR_PINMUX instance. */
7215
#define ALT_SYSMGR_PINMUX_GENERALIO17_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO17_OFST))
7216
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO18 register for the ALT_SYSMGR_PINMUX instance. */
7217
#define ALT_SYSMGR_PINMUX_GENERALIO18_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO18_OFST))
7218
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO19 register for the ALT_SYSMGR_PINMUX instance. */
7219
#define ALT_SYSMGR_PINMUX_GENERALIO19_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO19_OFST))
7220
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO20 register for the ALT_SYSMGR_PINMUX instance. */
7221
#define ALT_SYSMGR_PINMUX_GENERALIO20_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO20_OFST))
7222
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO21 register for the ALT_SYSMGR_PINMUX instance. */
7223
#define ALT_SYSMGR_PINMUX_GENERALIO21_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO21_OFST))
7224
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO22 register for the ALT_SYSMGR_PINMUX instance. */
7225
#define ALT_SYSMGR_PINMUX_GENERALIO22_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO22_OFST))
7226
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO23 register for the ALT_SYSMGR_PINMUX instance. */
7227
#define ALT_SYSMGR_PINMUX_GENERALIO23_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO23_OFST))
7228
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO24 register for the ALT_SYSMGR_PINMUX instance. */
7229
#define ALT_SYSMGR_PINMUX_GENERALIO24_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO24_OFST))
7230
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO25 register for the ALT_SYSMGR_PINMUX instance. */
7231
#define ALT_SYSMGR_PINMUX_GENERALIO25_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO25_OFST))
7232
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO26 register for the ALT_SYSMGR_PINMUX instance. */
7233
#define ALT_SYSMGR_PINMUX_GENERALIO26_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO26_OFST))
7234
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO27 register for the ALT_SYSMGR_PINMUX instance. */
7235
#define ALT_SYSMGR_PINMUX_GENERALIO27_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO27_OFST))
7236
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO28 register for the ALT_SYSMGR_PINMUX instance. */
7237
#define ALT_SYSMGR_PINMUX_GENERALIO28_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO28_OFST))
7238
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO29 register for the ALT_SYSMGR_PINMUX instance. */
7239
#define ALT_SYSMGR_PINMUX_GENERALIO29_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO29_OFST))
7240
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO30 register for the ALT_SYSMGR_PINMUX instance. */
7241
#define ALT_SYSMGR_PINMUX_GENERALIO30_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO30_OFST))
7242
/* The address of the ALT_SYSMGR_PINMUX_GENERALIO31 register for the ALT_SYSMGR_PINMUX instance. */
7243
#define ALT_SYSMGR_PINMUX_GENERALIO31_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GENERALIO31_OFST))
7244
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO0 register for the ALT_SYSMGR_PINMUX instance. */
7245
#define ALT_SYSMGR_PINMUX_MIXED1IO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO0_OFST))
7246
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO1 register for the ALT_SYSMGR_PINMUX instance. */
7247
#define ALT_SYSMGR_PINMUX_MIXED1IO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO1_OFST))
7248
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO2 register for the ALT_SYSMGR_PINMUX instance. */
7249
#define ALT_SYSMGR_PINMUX_MIXED1IO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO2_OFST))
7250
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO3 register for the ALT_SYSMGR_PINMUX instance. */
7251
#define ALT_SYSMGR_PINMUX_MIXED1IO3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO3_OFST))
7252
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO4 register for the ALT_SYSMGR_PINMUX instance. */
7253
#define ALT_SYSMGR_PINMUX_MIXED1IO4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO4_OFST))
7254
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO5 register for the ALT_SYSMGR_PINMUX instance. */
7255
#define ALT_SYSMGR_PINMUX_MIXED1IO5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO5_OFST))
7256
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO6 register for the ALT_SYSMGR_PINMUX instance. */
7257
#define ALT_SYSMGR_PINMUX_MIXED1IO6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO6_OFST))
7258
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO7 register for the ALT_SYSMGR_PINMUX instance. */
7259
#define ALT_SYSMGR_PINMUX_MIXED1IO7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO7_OFST))
7260
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO8 register for the ALT_SYSMGR_PINMUX instance. */
7261
#define ALT_SYSMGR_PINMUX_MIXED1IO8_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO8_OFST))
7262
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO9 register for the ALT_SYSMGR_PINMUX instance. */
7263
#define ALT_SYSMGR_PINMUX_MIXED1IO9_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO9_OFST))
7264
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO10 register for the ALT_SYSMGR_PINMUX instance. */
7265
#define ALT_SYSMGR_PINMUX_MIXED1IO10_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO10_OFST))
7266
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO11 register for the ALT_SYSMGR_PINMUX instance. */
7267
#define ALT_SYSMGR_PINMUX_MIXED1IO11_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO11_OFST))
7268
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO12 register for the ALT_SYSMGR_PINMUX instance. */
7269
#define ALT_SYSMGR_PINMUX_MIXED1IO12_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO12_OFST))
7270
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO13 register for the ALT_SYSMGR_PINMUX instance. */
7271
#define ALT_SYSMGR_PINMUX_MIXED1IO13_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO13_OFST))
7272
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO14 register for the ALT_SYSMGR_PINMUX instance. */
7273
#define ALT_SYSMGR_PINMUX_MIXED1IO14_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO14_OFST))
7274
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO15 register for the ALT_SYSMGR_PINMUX instance. */
7275
#define ALT_SYSMGR_PINMUX_MIXED1IO15_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO15_OFST))
7276
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO16 register for the ALT_SYSMGR_PINMUX instance. */
7277
#define ALT_SYSMGR_PINMUX_MIXED1IO16_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO16_OFST))
7278
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO17 register for the ALT_SYSMGR_PINMUX instance. */
7279
#define ALT_SYSMGR_PINMUX_MIXED1IO17_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO17_OFST))
7280
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO18 register for the ALT_SYSMGR_PINMUX instance. */
7281
#define ALT_SYSMGR_PINMUX_MIXED1IO18_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO18_OFST))
7282
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO19 register for the ALT_SYSMGR_PINMUX instance. */
7283
#define ALT_SYSMGR_PINMUX_MIXED1IO19_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO19_OFST))
7284
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO20 register for the ALT_SYSMGR_PINMUX instance. */
7285
#define ALT_SYSMGR_PINMUX_MIXED1IO20_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO20_OFST))
7286
/* The address of the ALT_SYSMGR_PINMUX_MIXED1IO21 register for the ALT_SYSMGR_PINMUX instance. */
7287
#define ALT_SYSMGR_PINMUX_MIXED1IO21_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED1IO21_OFST))
7288
/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO0 register for the ALT_SYSMGR_PINMUX instance. */
7289
#define ALT_SYSMGR_PINMUX_MIXED2IO0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO0_OFST))
7290
/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO1 register for the ALT_SYSMGR_PINMUX instance. */
7291
#define ALT_SYSMGR_PINMUX_MIXED2IO1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO1_OFST))
7292
/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO2 register for the ALT_SYSMGR_PINMUX instance. */
7293
#define ALT_SYSMGR_PINMUX_MIXED2IO2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO2_OFST))
7294
/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO3 register for the ALT_SYSMGR_PINMUX instance. */
7295
#define ALT_SYSMGR_PINMUX_MIXED2IO3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO3_OFST))
7296
/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO4 register for the ALT_SYSMGR_PINMUX instance. */
7297
#define ALT_SYSMGR_PINMUX_MIXED2IO4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO4_OFST))
7298
/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO5 register for the ALT_SYSMGR_PINMUX instance. */
7299
#define ALT_SYSMGR_PINMUX_MIXED2IO5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO5_OFST))
7300
/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO6 register for the ALT_SYSMGR_PINMUX instance. */
7301
#define ALT_SYSMGR_PINMUX_MIXED2IO6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO6_OFST))
7302
/* The address of the ALT_SYSMGR_PINMUX_MIXED2IO7 register for the ALT_SYSMGR_PINMUX instance. */
7303
#define ALT_SYSMGR_PINMUX_MIXED2IO7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_MIXED2IO7_OFST))
7304
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX48 register for the ALT_SYSMGR_PINMUX instance. */
7305
#define ALT_SYSMGR_PINMUX_GPLINMUX48_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX48_OFST))
7306
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX49 register for the ALT_SYSMGR_PINMUX instance. */
7307
#define ALT_SYSMGR_PINMUX_GPLINMUX49_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX49_OFST))
7308
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX50 register for the ALT_SYSMGR_PINMUX instance. */
7309
#define ALT_SYSMGR_PINMUX_GPLINMUX50_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX50_OFST))
7310
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX51 register for the ALT_SYSMGR_PINMUX instance. */
7311
#define ALT_SYSMGR_PINMUX_GPLINMUX51_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX51_OFST))
7312
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX52 register for the ALT_SYSMGR_PINMUX instance. */
7313
#define ALT_SYSMGR_PINMUX_GPLINMUX52_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX52_OFST))
7314
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX53 register for the ALT_SYSMGR_PINMUX instance. */
7315
#define ALT_SYSMGR_PINMUX_GPLINMUX53_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX53_OFST))
7316
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX54 register for the ALT_SYSMGR_PINMUX instance. */
7317
#define ALT_SYSMGR_PINMUX_GPLINMUX54_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX54_OFST))
7318
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX55 register for the ALT_SYSMGR_PINMUX instance. */
7319
#define ALT_SYSMGR_PINMUX_GPLINMUX55_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX55_OFST))
7320
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX56 register for the ALT_SYSMGR_PINMUX instance. */
7321
#define ALT_SYSMGR_PINMUX_GPLINMUX56_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX56_OFST))
7322
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX57 register for the ALT_SYSMGR_PINMUX instance. */
7323
#define ALT_SYSMGR_PINMUX_GPLINMUX57_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX57_OFST))
7324
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX58 register for the ALT_SYSMGR_PINMUX instance. */
7325
#define ALT_SYSMGR_PINMUX_GPLINMUX58_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX58_OFST))
7326
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX59 register for the ALT_SYSMGR_PINMUX instance. */
7327
#define ALT_SYSMGR_PINMUX_GPLINMUX59_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX59_OFST))
7328
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX60 register for the ALT_SYSMGR_PINMUX instance. */
7329
#define ALT_SYSMGR_PINMUX_GPLINMUX60_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX60_OFST))
7330
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX61 register for the ALT_SYSMGR_PINMUX instance. */
7331
#define ALT_SYSMGR_PINMUX_GPLINMUX61_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX61_OFST))
7332
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX62 register for the ALT_SYSMGR_PINMUX instance. */
7333
#define ALT_SYSMGR_PINMUX_GPLINMUX62_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX62_OFST))
7334
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX63 register for the ALT_SYSMGR_PINMUX instance. */
7335
#define ALT_SYSMGR_PINMUX_GPLINMUX63_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX63_OFST))
7336
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX64 register for the ALT_SYSMGR_PINMUX instance. */
7337
#define ALT_SYSMGR_PINMUX_GPLINMUX64_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX64_OFST))
7338
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX65 register for the ALT_SYSMGR_PINMUX instance. */
7339
#define ALT_SYSMGR_PINMUX_GPLINMUX65_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX65_OFST))
7340
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX66 register for the ALT_SYSMGR_PINMUX instance. */
7341
#define ALT_SYSMGR_PINMUX_GPLINMUX66_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX66_OFST))
7342
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX67 register for the ALT_SYSMGR_PINMUX instance. */
7343
#define ALT_SYSMGR_PINMUX_GPLINMUX67_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX67_OFST))
7344
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX68 register for the ALT_SYSMGR_PINMUX instance. */
7345
#define ALT_SYSMGR_PINMUX_GPLINMUX68_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX68_OFST))
7346
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX69 register for the ALT_SYSMGR_PINMUX instance. */
7347
#define ALT_SYSMGR_PINMUX_GPLINMUX69_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX69_OFST))
7348
/* The address of the ALT_SYSMGR_PINMUX_GPLINMUX70 register for the ALT_SYSMGR_PINMUX instance. */
7349
#define ALT_SYSMGR_PINMUX_GPLINMUX70_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLINMUX70_OFST))
7350
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX0 register for the ALT_SYSMGR_PINMUX instance. */
7351
#define ALT_SYSMGR_PINMUX_GPLMUX0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX0_OFST))
7352
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX1 register for the ALT_SYSMGR_PINMUX instance. */
7353
#define ALT_SYSMGR_PINMUX_GPLMUX1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX1_OFST))
7354
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX2 register for the ALT_SYSMGR_PINMUX instance. */
7355
#define ALT_SYSMGR_PINMUX_GPLMUX2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX2_OFST))
7356
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX3 register for the ALT_SYSMGR_PINMUX instance. */
7357
#define ALT_SYSMGR_PINMUX_GPLMUX3_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX3_OFST))
7358
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX4 register for the ALT_SYSMGR_PINMUX instance. */
7359
#define ALT_SYSMGR_PINMUX_GPLMUX4_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX4_OFST))
7360
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX5 register for the ALT_SYSMGR_PINMUX instance. */
7361
#define ALT_SYSMGR_PINMUX_GPLMUX5_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX5_OFST))
7362
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX6 register for the ALT_SYSMGR_PINMUX instance. */
7363
#define ALT_SYSMGR_PINMUX_GPLMUX6_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX6_OFST))
7364
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX7 register for the ALT_SYSMGR_PINMUX instance. */
7365
#define ALT_SYSMGR_PINMUX_GPLMUX7_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX7_OFST))
7366
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX8 register for the ALT_SYSMGR_PINMUX instance. */
7367
#define ALT_SYSMGR_PINMUX_GPLMUX8_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX8_OFST))
7368
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX9 register for the ALT_SYSMGR_PINMUX instance. */
7369
#define ALT_SYSMGR_PINMUX_GPLMUX9_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX9_OFST))
7370
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX10 register for the ALT_SYSMGR_PINMUX instance. */
7371
#define ALT_SYSMGR_PINMUX_GPLMUX10_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX10_OFST))
7372
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX11 register for the ALT_SYSMGR_PINMUX instance. */
7373
#define ALT_SYSMGR_PINMUX_GPLMUX11_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX11_OFST))
7374
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX12 register for the ALT_SYSMGR_PINMUX instance. */
7375
#define ALT_SYSMGR_PINMUX_GPLMUX12_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX12_OFST))
7376
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX13 register for the ALT_SYSMGR_PINMUX instance. */
7377
#define ALT_SYSMGR_PINMUX_GPLMUX13_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX13_OFST))
7378
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX14 register for the ALT_SYSMGR_PINMUX instance. */
7379
#define ALT_SYSMGR_PINMUX_GPLMUX14_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX14_OFST))
7380
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX15 register for the ALT_SYSMGR_PINMUX instance. */
7381
#define ALT_SYSMGR_PINMUX_GPLMUX15_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX15_OFST))
7382
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX16 register for the ALT_SYSMGR_PINMUX instance. */
7383
#define ALT_SYSMGR_PINMUX_GPLMUX16_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX16_OFST))
7384
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX17 register for the ALT_SYSMGR_PINMUX instance. */
7385
#define ALT_SYSMGR_PINMUX_GPLMUX17_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX17_OFST))
7386
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX18 register for the ALT_SYSMGR_PINMUX instance. */
7387
#define ALT_SYSMGR_PINMUX_GPLMUX18_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX18_OFST))
7388
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX19 register for the ALT_SYSMGR_PINMUX instance. */
7389
#define ALT_SYSMGR_PINMUX_GPLMUX19_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX19_OFST))
7390
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX20 register for the ALT_SYSMGR_PINMUX instance. */
7391
#define ALT_SYSMGR_PINMUX_GPLMUX20_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX20_OFST))
7392
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX21 register for the ALT_SYSMGR_PINMUX instance. */
7393
#define ALT_SYSMGR_PINMUX_GPLMUX21_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX21_OFST))
7394
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX22 register for the ALT_SYSMGR_PINMUX instance. */
7395
#define ALT_SYSMGR_PINMUX_GPLMUX22_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX22_OFST))
7396
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX23 register for the ALT_SYSMGR_PINMUX instance. */
7397
#define ALT_SYSMGR_PINMUX_GPLMUX23_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX23_OFST))
7398
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX24 register for the ALT_SYSMGR_PINMUX instance. */
7399
#define ALT_SYSMGR_PINMUX_GPLMUX24_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX24_OFST))
7400
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX25 register for the ALT_SYSMGR_PINMUX instance. */
7401
#define ALT_SYSMGR_PINMUX_GPLMUX25_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX25_OFST))
7402
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX26 register for the ALT_SYSMGR_PINMUX instance. */
7403
#define ALT_SYSMGR_PINMUX_GPLMUX26_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX26_OFST))
7404
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX27 register for the ALT_SYSMGR_PINMUX instance. */
7405
#define ALT_SYSMGR_PINMUX_GPLMUX27_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX27_OFST))
7406
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX28 register for the ALT_SYSMGR_PINMUX instance. */
7407
#define ALT_SYSMGR_PINMUX_GPLMUX28_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX28_OFST))
7408
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX29 register for the ALT_SYSMGR_PINMUX instance. */
7409
#define ALT_SYSMGR_PINMUX_GPLMUX29_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX29_OFST))
7410
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX30 register for the ALT_SYSMGR_PINMUX instance. */
7411
#define ALT_SYSMGR_PINMUX_GPLMUX30_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX30_OFST))
7412
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX31 register for the ALT_SYSMGR_PINMUX instance. */
7413
#define ALT_SYSMGR_PINMUX_GPLMUX31_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX31_OFST))
7414
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX32 register for the ALT_SYSMGR_PINMUX instance. */
7415
#define ALT_SYSMGR_PINMUX_GPLMUX32_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX32_OFST))
7416
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX33 register for the ALT_SYSMGR_PINMUX instance. */
7417
#define ALT_SYSMGR_PINMUX_GPLMUX33_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX33_OFST))
7418
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX34 register for the ALT_SYSMGR_PINMUX instance. */
7419
#define ALT_SYSMGR_PINMUX_GPLMUX34_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX34_OFST))
7420
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX35 register for the ALT_SYSMGR_PINMUX instance. */
7421
#define ALT_SYSMGR_PINMUX_GPLMUX35_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX35_OFST))
7422
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX36 register for the ALT_SYSMGR_PINMUX instance. */
7423
#define ALT_SYSMGR_PINMUX_GPLMUX36_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX36_OFST))
7424
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX37 register for the ALT_SYSMGR_PINMUX instance. */
7425
#define ALT_SYSMGR_PINMUX_GPLMUX37_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX37_OFST))
7426
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX38 register for the ALT_SYSMGR_PINMUX instance. */
7427
#define ALT_SYSMGR_PINMUX_GPLMUX38_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX38_OFST))
7428
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX39 register for the ALT_SYSMGR_PINMUX instance. */
7429
#define ALT_SYSMGR_PINMUX_GPLMUX39_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX39_OFST))
7430
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX40 register for the ALT_SYSMGR_PINMUX instance. */
7431
#define ALT_SYSMGR_PINMUX_GPLMUX40_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX40_OFST))
7432
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX41 register for the ALT_SYSMGR_PINMUX instance. */
7433
#define ALT_SYSMGR_PINMUX_GPLMUX41_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX41_OFST))
7434
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX42 register for the ALT_SYSMGR_PINMUX instance. */
7435
#define ALT_SYSMGR_PINMUX_GPLMUX42_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX42_OFST))
7436
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX43 register for the ALT_SYSMGR_PINMUX instance. */
7437
#define ALT_SYSMGR_PINMUX_GPLMUX43_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX43_OFST))
7438
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX44 register for the ALT_SYSMGR_PINMUX instance. */
7439
#define ALT_SYSMGR_PINMUX_GPLMUX44_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX44_OFST))
7440
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX45 register for the ALT_SYSMGR_PINMUX instance. */
7441
#define ALT_SYSMGR_PINMUX_GPLMUX45_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX45_OFST))
7442
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX46 register for the ALT_SYSMGR_PINMUX instance. */
7443
#define ALT_SYSMGR_PINMUX_GPLMUX46_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX46_OFST))
7444
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX47 register for the ALT_SYSMGR_PINMUX instance. */
7445
#define ALT_SYSMGR_PINMUX_GPLMUX47_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX47_OFST))
7446
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX48 register for the ALT_SYSMGR_PINMUX instance. */
7447
#define ALT_SYSMGR_PINMUX_GPLMUX48_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX48_OFST))
7448
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX49 register for the ALT_SYSMGR_PINMUX instance. */
7449
#define ALT_SYSMGR_PINMUX_GPLMUX49_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX49_OFST))
7450
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX50 register for the ALT_SYSMGR_PINMUX instance. */
7451
#define ALT_SYSMGR_PINMUX_GPLMUX50_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX50_OFST))
7452
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX51 register for the ALT_SYSMGR_PINMUX instance. */
7453
#define ALT_SYSMGR_PINMUX_GPLMUX51_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX51_OFST))
7454
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX52 register for the ALT_SYSMGR_PINMUX instance. */
7455
#define ALT_SYSMGR_PINMUX_GPLMUX52_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX52_OFST))
7456
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX53 register for the ALT_SYSMGR_PINMUX instance. */
7457
#define ALT_SYSMGR_PINMUX_GPLMUX53_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX53_OFST))
7458
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX54 register for the ALT_SYSMGR_PINMUX instance. */
7459
#define ALT_SYSMGR_PINMUX_GPLMUX54_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX54_OFST))
7460
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX55 register for the ALT_SYSMGR_PINMUX instance. */
7461
#define ALT_SYSMGR_PINMUX_GPLMUX55_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX55_OFST))
7462
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX56 register for the ALT_SYSMGR_PINMUX instance. */
7463
#define ALT_SYSMGR_PINMUX_GPLMUX56_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX56_OFST))
7464
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX57 register for the ALT_SYSMGR_PINMUX instance. */
7465
#define ALT_SYSMGR_PINMUX_GPLMUX57_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX57_OFST))
7466
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX58 register for the ALT_SYSMGR_PINMUX instance. */
7467
#define ALT_SYSMGR_PINMUX_GPLMUX58_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX58_OFST))
7468
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX59 register for the ALT_SYSMGR_PINMUX instance. */
7469
#define ALT_SYSMGR_PINMUX_GPLMUX59_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX59_OFST))
7470
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX60 register for the ALT_SYSMGR_PINMUX instance. */
7471
#define ALT_SYSMGR_PINMUX_GPLMUX60_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX60_OFST))
7472
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX61 register for the ALT_SYSMGR_PINMUX instance. */
7473
#define ALT_SYSMGR_PINMUX_GPLMUX61_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX61_OFST))
7474
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX62 register for the ALT_SYSMGR_PINMUX instance. */
7475
#define ALT_SYSMGR_PINMUX_GPLMUX62_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX62_OFST))
7476
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX63 register for the ALT_SYSMGR_PINMUX instance. */
7477
#define ALT_SYSMGR_PINMUX_GPLMUX63_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX63_OFST))
7478
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX64 register for the ALT_SYSMGR_PINMUX instance. */
7479
#define ALT_SYSMGR_PINMUX_GPLMUX64_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX64_OFST))
7480
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX65 register for the ALT_SYSMGR_PINMUX instance. */
7481
#define ALT_SYSMGR_PINMUX_GPLMUX65_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX65_OFST))
7482
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX66 register for the ALT_SYSMGR_PINMUX instance. */
7483
#define ALT_SYSMGR_PINMUX_GPLMUX66_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX66_OFST))
7484
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX67 register for the ALT_SYSMGR_PINMUX instance. */
7485
#define ALT_SYSMGR_PINMUX_GPLMUX67_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX67_OFST))
7486
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX68 register for the ALT_SYSMGR_PINMUX instance. */
7487
#define ALT_SYSMGR_PINMUX_GPLMUX68_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX68_OFST))
7488
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX69 register for the ALT_SYSMGR_PINMUX instance. */
7489
#define ALT_SYSMGR_PINMUX_GPLMUX69_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX69_OFST))
7490
/* The address of the ALT_SYSMGR_PINMUX_GPLMUX70 register for the ALT_SYSMGR_PINMUX instance. */
7491
#define ALT_SYSMGR_PINMUX_GPLMUX70_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_GPLMUX70_OFST))
7492
/* The address of the ALT_SYSMGR_PINMUX_NANDUSEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7493
#define ALT_SYSMGR_PINMUX_NANDUSEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_NANDUSEFPGA_OFST))
7494
/* The address of the ALT_SYSMGR_PINMUX_RGMII1USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7495
#define ALT_SYSMGR_PINMUX_RGMII1USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_RGMII1USEFPGA_OFST))
7496
/* The address of the ALT_SYSMGR_PINMUX_I2C0USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7497
#define ALT_SYSMGR_PINMUX_I2C0USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_I2C0USEFPGA_OFST))
7498
/* The address of the ALT_SYSMGR_PINMUX_RGMII0USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7499
#define ALT_SYSMGR_PINMUX_RGMII0USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_RGMII0USEFPGA_OFST))
7500
/* The address of the ALT_SYSMGR_PINMUX_I2C3USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7501
#define ALT_SYSMGR_PINMUX_I2C3USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_I2C3USEFPGA_OFST))
7502
/* The address of the ALT_SYSMGR_PINMUX_I2C2USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7503
#define ALT_SYSMGR_PINMUX_I2C2USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_I2C2USEFPGA_OFST))
7504
/* The address of the ALT_SYSMGR_PINMUX_I2C1USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7505
#define ALT_SYSMGR_PINMUX_I2C1USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_I2C1USEFPGA_OFST))
7506
/* The address of the ALT_SYSMGR_PINMUX_SPIM1USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7507
#define ALT_SYSMGR_PINMUX_SPIM1USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_SPIM1USEFPGA_OFST))
7508
/* The address of the ALT_SYSMGR_PINMUX_SPIM0USEFPGA register for the ALT_SYSMGR_PINMUX instance. */
7509
#define ALT_SYSMGR_PINMUX_SPIM0USEFPGA_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + ALT_SYSMGR_PINMUX_SPIM0USEFPGA_OFST))
7510
/* The base address byte offset for the start of the ALT_SYSMGR_PINMUX component. */
7511
#define ALT_SYSMGR_PINMUX_OFST 0x400
7512
/* The start address of the ALT_SYSMGR_PINMUX component. */
7513
#define ALT_SYSMGR_PINMUX_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SYSMGR_ADDR) + ALT_SYSMGR_PINMUX_OFST))
7514
/* The lower bound address range of the ALT_SYSMGR_PINMUX component. */
7515
#define ALT_SYSMGR_PINMUX_LB_ADDR ALT_SYSMGR_PINMUX_ADDR
7516
/* The upper bound address range of the ALT_SYSMGR_PINMUX component. */
7517
#define ALT_SYSMGR_PINMUX_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_PINMUX_ADDR) + 0x400) - 1))
7518
7519
7520
/* The base address byte offset for the start of the ALT_SYSMGR component. */
7521
#define ALT_SYSMGR_OFST 0xffd08000
7522
/* The start address of the ALT_SYSMGR component. */
7523
#define ALT_SYSMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SYSMGR_OFST))
7524
/* The lower bound address range of the ALT_SYSMGR component. */
7525
#define ALT_SYSMGR_LB_ADDR ALT_SYSMGR_ADDR
7526
/* The upper bound address range of the ALT_SYSMGR component. */
7527
#define ALT_SYSMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SYSMGR_ADDR) + 0x4000) - 1))
7528
7529
7530
7531
* Component Instance : dmanonsecure
7532
7533
* Instance dmanonsecure of component ALT_DMANONSECURE.
7534
7535
7536
7537
/* The address of the ALT_DMANONSECURE_REG register for the ALT_DMANONSECURE instance. */
7538
#define ALT_DMANONSECURE_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_DMANONSECURE_ADDR) + ALT_DMANONSECURE_REG_OFST))
7539
/* The base address byte offset for the start of the ALT_DMANONSECURE component. */
7540
#define ALT_DMANONSECURE_OFST 0xffe00000
7541
/* The start address of the ALT_DMANONSECURE component. */
7542
#define ALT_DMANONSECURE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_DMANONSECURE_OFST))
7543
/* The lower bound address range of the ALT_DMANONSECURE component. */
7544
#define ALT_DMANONSECURE_LB_ADDR ALT_DMANONSECURE_ADDR
7545
/* The upper bound address range of the ALT_DMANONSECURE component. */
7546
#define ALT_DMANONSECURE_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_DMANONSECURE_ADDR) + 0x4) - 1))
7547
7548
7549
7550
* Component Instance : dmasecure
7551
7552
* Instance dmasecure of component ALT_DMASECURE.
7553
7554
7555
7556
/* The address of the ALT_DMASECURE_REG register for the ALT_DMASECURE instance. */
7557
#define ALT_DMASECURE_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_DMASECURE_ADDR) + ALT_DMASECURE_REG_OFST))
7558
/* The base address byte offset for the start of the ALT_DMASECURE component. */
7559
#define ALT_DMASECURE_OFST 0xffe01000
7560
/* The start address of the ALT_DMASECURE component. */
7561
#define ALT_DMASECURE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_DMASECURE_OFST))
7562
/* The lower bound address range of the ALT_DMASECURE component. */
7563
#define ALT_DMASECURE_LB_ADDR ALT_DMASECURE_ADDR
7564
/* The upper bound address range of the ALT_DMASECURE component. */
7565
#define ALT_DMASECURE_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_DMASECURE_ADDR) + 0x4) - 1))
7566
7567
7568
7569
* Component Instance : spis0
7570
7571
* Instance spis0 of component ALT_SPIS.
7572
7573
7574
7575
/* The address of the ALT_SPIS_CTLR0 register for the ALT_SPIS0 instance. */
7576
#define ALT_SPIS0_CTLR0_ADDR ALT_SPIS_CTLR0_ADDR(ALT_SPIS0_ADDR)
7577
/* The address of the ALT_SPIS_SPIENR register for the ALT_SPIS0 instance. */
7578
#define ALT_SPIS0_SPIENR_ADDR ALT_SPIS_SPIENR_ADDR(ALT_SPIS0_ADDR)
7579
/* The address of the ALT_SPIS_MWCR register for the ALT_SPIS0 instance. */
7580
#define ALT_SPIS0_MWCR_ADDR ALT_SPIS_MWCR_ADDR(ALT_SPIS0_ADDR)
7581
/* The address of the ALT_SPIS_TXFTLR register for the ALT_SPIS0 instance. */
7582
#define ALT_SPIS0_TXFTLR_ADDR ALT_SPIS_TXFTLR_ADDR(ALT_SPIS0_ADDR)
7583
/* The address of the ALT_SPIS_RXFTLR register for the ALT_SPIS0 instance. */
7584
#define ALT_SPIS0_RXFTLR_ADDR ALT_SPIS_RXFTLR_ADDR(ALT_SPIS0_ADDR)
7585
/* The address of the ALT_SPIS_TXFLR register for the ALT_SPIS0 instance. */
7586
#define ALT_SPIS0_TXFLR_ADDR ALT_SPIS_TXFLR_ADDR(ALT_SPIS0_ADDR)
7587
/* The address of the ALT_SPIS_RXFLR register for the ALT_SPIS0 instance. */
7588
#define ALT_SPIS0_RXFLR_ADDR ALT_SPIS_RXFLR_ADDR(ALT_SPIS0_ADDR)
7589
/* The address of the ALT_SPIS_SR register for the ALT_SPIS0 instance. */
7590
#define ALT_SPIS0_SR_ADDR ALT_SPIS_SR_ADDR(ALT_SPIS0_ADDR)
7591
/* The address of the ALT_SPIS_IMR register for the ALT_SPIS0 instance. */
7592
#define ALT_SPIS0_IMR_ADDR ALT_SPIS_IMR_ADDR(ALT_SPIS0_ADDR)
7593
/* The address of the ALT_SPIS_ISR register for the ALT_SPIS0 instance. */
7594
#define ALT_SPIS0_ISR_ADDR ALT_SPIS_ISR_ADDR(ALT_SPIS0_ADDR)
7595
/* The address of the ALT_SPIS_RISR register for the ALT_SPIS0 instance. */
7596
#define ALT_SPIS0_RISR_ADDR ALT_SPIS_RISR_ADDR(ALT_SPIS0_ADDR)
7597
/* The address of the ALT_SPIS_TXOICR register for the ALT_SPIS0 instance. */
7598
#define ALT_SPIS0_TXOICR_ADDR ALT_SPIS_TXOICR_ADDR(ALT_SPIS0_ADDR)
7599
/* The address of the ALT_SPIS_RXOICR register for the ALT_SPIS0 instance. */
7600
#define ALT_SPIS0_RXOICR_ADDR ALT_SPIS_RXOICR_ADDR(ALT_SPIS0_ADDR)
7601
/* The address of the ALT_SPIS_RXUICR register for the ALT_SPIS0 instance. */
7602
#define ALT_SPIS0_RXUICR_ADDR ALT_SPIS_RXUICR_ADDR(ALT_SPIS0_ADDR)
7603
/* The address of the ALT_SPIS_ICR register for the ALT_SPIS0 instance. */
7604
#define ALT_SPIS0_ICR_ADDR ALT_SPIS_ICR_ADDR(ALT_SPIS0_ADDR)
7605
/* The address of the ALT_SPIS_DMACR register for the ALT_SPIS0 instance. */
7606
#define ALT_SPIS0_DMACR_ADDR ALT_SPIS_DMACR_ADDR(ALT_SPIS0_ADDR)
7607
/* The address of the ALT_SPIS_DMATDLR register for the ALT_SPIS0 instance. */
7608
#define ALT_SPIS0_DMATDLR_ADDR ALT_SPIS_DMATDLR_ADDR(ALT_SPIS0_ADDR)
7609
/* The address of the ALT_SPIS_DMARDLR register for the ALT_SPIS0 instance. */
7610
#define ALT_SPIS0_DMARDLR_ADDR ALT_SPIS_DMARDLR_ADDR(ALT_SPIS0_ADDR)
7611
/* The address of the ALT_SPIS_IDR register for the ALT_SPIS0 instance. */
7612
#define ALT_SPIS0_IDR_ADDR ALT_SPIS_IDR_ADDR(ALT_SPIS0_ADDR)
7613
/* The address of the ALT_SPIS_SPI_VER_ID register for the ALT_SPIS0 instance. */
7614
#define ALT_SPIS0_SPI_VER_ID_ADDR ALT_SPIS_SPI_VER_ID_ADDR(ALT_SPIS0_ADDR)
7615
/* The address of the ALT_SPIS_DR register for the ALT_SPIS0 instance. */
7616
#define ALT_SPIS0_DR_ADDR ALT_SPIS_DR_ADDR(ALT_SPIS0_ADDR)
7617
/* The base address byte offset for the start of the ALT_SPIS0 component. */
7618
#define ALT_SPIS0_OFST 0xffe02000
7619
/* The start address of the ALT_SPIS0 component. */
7620
#define ALT_SPIS0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPIS0_OFST))
7621
/* The lower bound address range of the ALT_SPIS0 component. */
7622
#define ALT_SPIS0_LB_ADDR ALT_SPIS0_ADDR
7623
/* The upper bound address range of the ALT_SPIS0 component. */
7624
#define ALT_SPIS0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPIS0_ADDR) + 0x80) - 1))
7625
7626
7627
7628
* Component Instance : spis1
7629
7630
* Instance spis1 of component ALT_SPIS.
7631
7632
7633
7634
/* The address of the ALT_SPIS_CTLR0 register for the ALT_SPIS1 instance. */
7635
#define ALT_SPIS1_CTLR0_ADDR ALT_SPIS_CTLR0_ADDR(ALT_SPIS1_ADDR)
7636
/* The address of the ALT_SPIS_SPIENR register for the ALT_SPIS1 instance. */
7637
#define ALT_SPIS1_SPIENR_ADDR ALT_SPIS_SPIENR_ADDR(ALT_SPIS1_ADDR)
7638
/* The address of the ALT_SPIS_MWCR register for the ALT_SPIS1 instance. */
7639
#define ALT_SPIS1_MWCR_ADDR ALT_SPIS_MWCR_ADDR(ALT_SPIS1_ADDR)
7640
/* The address of the ALT_SPIS_TXFTLR register for the ALT_SPIS1 instance. */
7641
#define ALT_SPIS1_TXFTLR_ADDR ALT_SPIS_TXFTLR_ADDR(ALT_SPIS1_ADDR)
7642
/* The address of the ALT_SPIS_RXFTLR register for the ALT_SPIS1 instance. */
7643
#define ALT_SPIS1_RXFTLR_ADDR ALT_SPIS_RXFTLR_ADDR(ALT_SPIS1_ADDR)
7644
/* The address of the ALT_SPIS_TXFLR register for the ALT_SPIS1 instance. */
7645
#define ALT_SPIS1_TXFLR_ADDR ALT_SPIS_TXFLR_ADDR(ALT_SPIS1_ADDR)
7646
/* The address of the ALT_SPIS_RXFLR register for the ALT_SPIS1 instance. */
7647
#define ALT_SPIS1_RXFLR_ADDR ALT_SPIS_RXFLR_ADDR(ALT_SPIS1_ADDR)
7648
/* The address of the ALT_SPIS_SR register for the ALT_SPIS1 instance. */
7649
#define ALT_SPIS1_SR_ADDR ALT_SPIS_SR_ADDR(ALT_SPIS1_ADDR)
7650
/* The address of the ALT_SPIS_IMR register for the ALT_SPIS1 instance. */
7651
#define ALT_SPIS1_IMR_ADDR ALT_SPIS_IMR_ADDR(ALT_SPIS1_ADDR)
7652
/* The address of the ALT_SPIS_ISR register for the ALT_SPIS1 instance. */
7653
#define ALT_SPIS1_ISR_ADDR ALT_SPIS_ISR_ADDR(ALT_SPIS1_ADDR)
7654
/* The address of the ALT_SPIS_RISR register for the ALT_SPIS1 instance. */
7655
#define ALT_SPIS1_RISR_ADDR ALT_SPIS_RISR_ADDR(ALT_SPIS1_ADDR)
7656
/* The address of the ALT_SPIS_TXOICR register for the ALT_SPIS1 instance. */
7657
#define ALT_SPIS1_TXOICR_ADDR ALT_SPIS_TXOICR_ADDR(ALT_SPIS1_ADDR)
7658
/* The address of the ALT_SPIS_RXOICR register for the ALT_SPIS1 instance. */
7659
#define ALT_SPIS1_RXOICR_ADDR ALT_SPIS_RXOICR_ADDR(ALT_SPIS1_ADDR)
7660
/* The address of the ALT_SPIS_RXUICR register for the ALT_SPIS1 instance. */
7661
#define ALT_SPIS1_RXUICR_ADDR ALT_SPIS_RXUICR_ADDR(ALT_SPIS1_ADDR)
7662
/* The address of the ALT_SPIS_ICR register for the ALT_SPIS1 instance. */
7663
#define ALT_SPIS1_ICR_ADDR ALT_SPIS_ICR_ADDR(ALT_SPIS1_ADDR)
7664
/* The address of the ALT_SPIS_DMACR register for the ALT_SPIS1 instance. */
7665
#define ALT_SPIS1_DMACR_ADDR ALT_SPIS_DMACR_ADDR(ALT_SPIS1_ADDR)
7666
/* The address of the ALT_SPIS_DMATDLR register for the ALT_SPIS1 instance. */
7667
#define ALT_SPIS1_DMATDLR_ADDR ALT_SPIS_DMATDLR_ADDR(ALT_SPIS1_ADDR)
7668
/* The address of the ALT_SPIS_DMARDLR register for the ALT_SPIS1 instance. */
7669
#define ALT_SPIS1_DMARDLR_ADDR ALT_SPIS_DMARDLR_ADDR(ALT_SPIS1_ADDR)
7670
/* The address of the ALT_SPIS_IDR register for the ALT_SPIS1 instance. */
7671
#define ALT_SPIS1_IDR_ADDR ALT_SPIS_IDR_ADDR(ALT_SPIS1_ADDR)
7672
/* The address of the ALT_SPIS_SPI_VER_ID register for the ALT_SPIS1 instance. */
7673
#define ALT_SPIS1_SPI_VER_ID_ADDR ALT_SPIS_SPI_VER_ID_ADDR(ALT_SPIS1_ADDR)
7674
/* The address of the ALT_SPIS_DR register for the ALT_SPIS1 instance. */
7675
#define ALT_SPIS1_DR_ADDR ALT_SPIS_DR_ADDR(ALT_SPIS1_ADDR)
7676
/* The base address byte offset for the start of the ALT_SPIS1 component. */
7677
#define ALT_SPIS1_OFST 0xffe03000
7678
/* The start address of the ALT_SPIS1 component. */
7679
#define ALT_SPIS1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPIS1_OFST))
7680
/* The lower bound address range of the ALT_SPIS1 component. */
7681
#define ALT_SPIS1_LB_ADDR ALT_SPIS1_ADDR
7682
/* The upper bound address range of the ALT_SPIS1 component. */
7683
#define ALT_SPIS1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPIS1_ADDR) + 0x80) - 1))
7684
7685
7686
7687
* Component Instance : spim0
7688
7689
* Instance spim0 of component ALT_SPIM.
7690
7691
7692
7693
/* The address of the ALT_SPIM_CTLR0 register for the ALT_SPIM0 instance. */
7694
#define ALT_SPIM0_CTLR0_ADDR ALT_SPIM_CTLR0_ADDR(ALT_SPIM0_ADDR)
7695
/* The address of the ALT_SPIM_CTLR1 register for the ALT_SPIM0 instance. */
7696
#define ALT_SPIM0_CTLR1_ADDR ALT_SPIM_CTLR1_ADDR(ALT_SPIM0_ADDR)
7697
/* The address of the ALT_SPIM_SPIENR register for the ALT_SPIM0 instance. */
7698
#define ALT_SPIM0_SPIENR_ADDR ALT_SPIM_SPIENR_ADDR(ALT_SPIM0_ADDR)
7699
/* The address of the ALT_SPIM_MWCR register for the ALT_SPIM0 instance. */
7700
#define ALT_SPIM0_MWCR_ADDR ALT_SPIM_MWCR_ADDR(ALT_SPIM0_ADDR)
7701
/* The address of the ALT_SPIM_SER register for the ALT_SPIM0 instance. */
7702
#define ALT_SPIM0_SER_ADDR ALT_SPIM_SER_ADDR(ALT_SPIM0_ADDR)
7703
/* The address of the ALT_SPIM_BAUDR register for the ALT_SPIM0 instance. */
7704
#define ALT_SPIM0_BAUDR_ADDR ALT_SPIM_BAUDR_ADDR(ALT_SPIM0_ADDR)
7705
/* The address of the ALT_SPIM_TXFTLR register for the ALT_SPIM0 instance. */
7706
#define ALT_SPIM0_TXFTLR_ADDR ALT_SPIM_TXFTLR_ADDR(ALT_SPIM0_ADDR)
7707
/* The address of the ALT_SPIM_RXFTLR register for the ALT_SPIM0 instance. */
7708
#define ALT_SPIM0_RXFTLR_ADDR ALT_SPIM_RXFTLR_ADDR(ALT_SPIM0_ADDR)
7709
/* The address of the ALT_SPIM_TXFLR register for the ALT_SPIM0 instance. */
7710
#define ALT_SPIM0_TXFLR_ADDR ALT_SPIM_TXFLR_ADDR(ALT_SPIM0_ADDR)
7711
/* The address of the ALT_SPIM_RXFLR register for the ALT_SPIM0 instance. */
7712
#define ALT_SPIM0_RXFLR_ADDR ALT_SPIM_RXFLR_ADDR(ALT_SPIM0_ADDR)
7713
/* The address of the ALT_SPIM_SR register for the ALT_SPIM0 instance. */
7714
#define ALT_SPIM0_SR_ADDR ALT_SPIM_SR_ADDR(ALT_SPIM0_ADDR)
7715
/* The address of the ALT_SPIM_IMR register for the ALT_SPIM0 instance. */
7716
#define ALT_SPIM0_IMR_ADDR ALT_SPIM_IMR_ADDR(ALT_SPIM0_ADDR)
7717
/* The address of the ALT_SPIM_ISR register for the ALT_SPIM0 instance. */
7718
#define ALT_SPIM0_ISR_ADDR ALT_SPIM_ISR_ADDR(ALT_SPIM0_ADDR)
7719
/* The address of the ALT_SPIM_RISR register for the ALT_SPIM0 instance. */
7720
#define ALT_SPIM0_RISR_ADDR ALT_SPIM_RISR_ADDR(ALT_SPIM0_ADDR)
7721
/* The address of the ALT_SPIM_TXOICR register for the ALT_SPIM0 instance. */
7722
#define ALT_SPIM0_TXOICR_ADDR ALT_SPIM_TXOICR_ADDR(ALT_SPIM0_ADDR)
7723
/* The address of the ALT_SPIM_RXOICR register for the ALT_SPIM0 instance. */
7724
#define ALT_SPIM0_RXOICR_ADDR ALT_SPIM_RXOICR_ADDR(ALT_SPIM0_ADDR)
7725
/* The address of the ALT_SPIM_RXUICR register for the ALT_SPIM0 instance. */
7726
#define ALT_SPIM0_RXUICR_ADDR ALT_SPIM_RXUICR_ADDR(ALT_SPIM0_ADDR)
7727
/* The address of the ALT_SPIM_ICR register for the ALT_SPIM0 instance. */
7728
#define ALT_SPIM0_ICR_ADDR ALT_SPIM_ICR_ADDR(ALT_SPIM0_ADDR)
7729
/* The address of the ALT_SPIM_DMACR register for the ALT_SPIM0 instance. */
7730
#define ALT_SPIM0_DMACR_ADDR ALT_SPIM_DMACR_ADDR(ALT_SPIM0_ADDR)
7731
/* The address of the ALT_SPIM_DMATDLR register for the ALT_SPIM0 instance. */
7732
#define ALT_SPIM0_DMATDLR_ADDR ALT_SPIM_DMATDLR_ADDR(ALT_SPIM0_ADDR)
7733
/* The address of the ALT_SPIM_DMARDLR register for the ALT_SPIM0 instance. */
7734
#define ALT_SPIM0_DMARDLR_ADDR ALT_SPIM_DMARDLR_ADDR(ALT_SPIM0_ADDR)
7735
/* The address of the ALT_SPIM_IDR register for the ALT_SPIM0 instance. */
7736
#define ALT_SPIM0_IDR_ADDR ALT_SPIM_IDR_ADDR(ALT_SPIM0_ADDR)
7737
/* The address of the ALT_SPIM_SPI_VER_ID register for the ALT_SPIM0 instance. */
7738
#define ALT_SPIM0_SPI_VER_ID_ADDR ALT_SPIM_SPI_VER_ID_ADDR(ALT_SPIM0_ADDR)
7739
/* The address of the ALT_SPIM_DR register for the ALT_SPIM0 instance. */
7740
#define ALT_SPIM0_DR_ADDR ALT_SPIM_DR_ADDR(ALT_SPIM0_ADDR)
7741
/* The address of the ALT_SPIM_RX_SMPL_DLY register for the ALT_SPIM0 instance. */
7742
#define ALT_SPIM0_RX_SMPL_DLY_ADDR ALT_SPIM_RX_SMPL_DLY_ADDR(ALT_SPIM0_ADDR)
7743
/* The base address byte offset for the start of the ALT_SPIM0 component. */
7744
#define ALT_SPIM0_OFST 0xfff00000
7745
/* The start address of the ALT_SPIM0 component. */
7746
#define ALT_SPIM0_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPIM0_OFST))
7747
/* The lower bound address range of the ALT_SPIM0 component. */
7748
#define ALT_SPIM0_LB_ADDR ALT_SPIM0_ADDR
7749
/* The upper bound address range of the ALT_SPIM0 component. */
7750
#define ALT_SPIM0_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPIM0_ADDR) + 0x100) - 1))
7751
7752
7753
7754
* Component Instance : spim1
7755
7756
* Instance spim1 of component ALT_SPIM.
7757
7758
7759
7760
/* The address of the ALT_SPIM_CTLR0 register for the ALT_SPIM1 instance. */
7761
#define ALT_SPIM1_CTLR0_ADDR ALT_SPIM_CTLR0_ADDR(ALT_SPIM1_ADDR)
7762
/* The address of the ALT_SPIM_CTLR1 register for the ALT_SPIM1 instance. */
7763
#define ALT_SPIM1_CTLR1_ADDR ALT_SPIM_CTLR1_ADDR(ALT_SPIM1_ADDR)
7764
/* The address of the ALT_SPIM_SPIENR register for the ALT_SPIM1 instance. */
7765
#define ALT_SPIM1_SPIENR_ADDR ALT_SPIM_SPIENR_ADDR(ALT_SPIM1_ADDR)
7766
/* The address of the ALT_SPIM_MWCR register for the ALT_SPIM1 instance. */
7767
#define ALT_SPIM1_MWCR_ADDR ALT_SPIM_MWCR_ADDR(ALT_SPIM1_ADDR)
7768
/* The address of the ALT_SPIM_SER register for the ALT_SPIM1 instance. */
7769
#define ALT_SPIM1_SER_ADDR ALT_SPIM_SER_ADDR(ALT_SPIM1_ADDR)
7770
/* The address of the ALT_SPIM_BAUDR register for the ALT_SPIM1 instance. */
7771
#define ALT_SPIM1_BAUDR_ADDR ALT_SPIM_BAUDR_ADDR(ALT_SPIM1_ADDR)
7772
/* The address of the ALT_SPIM_TXFTLR register for the ALT_SPIM1 instance. */
7773
#define ALT_SPIM1_TXFTLR_ADDR ALT_SPIM_TXFTLR_ADDR(ALT_SPIM1_ADDR)
7774
/* The address of the ALT_SPIM_RXFTLR register for the ALT_SPIM1 instance. */
7775
#define ALT_SPIM1_RXFTLR_ADDR ALT_SPIM_RXFTLR_ADDR(ALT_SPIM1_ADDR)
7776
/* The address of the ALT_SPIM_TXFLR register for the ALT_SPIM1 instance. */
7777
#define ALT_SPIM1_TXFLR_ADDR ALT_SPIM_TXFLR_ADDR(ALT_SPIM1_ADDR)
7778
/* The address of the ALT_SPIM_RXFLR register for the ALT_SPIM1 instance. */
7779
#define ALT_SPIM1_RXFLR_ADDR ALT_SPIM_RXFLR_ADDR(ALT_SPIM1_ADDR)
7780
/* The address of the ALT_SPIM_SR register for the ALT_SPIM1 instance. */
7781
#define ALT_SPIM1_SR_ADDR ALT_SPIM_SR_ADDR(ALT_SPIM1_ADDR)
7782
/* The address of the ALT_SPIM_IMR register for the ALT_SPIM1 instance. */
7783
#define ALT_SPIM1_IMR_ADDR ALT_SPIM_IMR_ADDR(ALT_SPIM1_ADDR)
7784
/* The address of the ALT_SPIM_ISR register for the ALT_SPIM1 instance. */
7785
#define ALT_SPIM1_ISR_ADDR ALT_SPIM_ISR_ADDR(ALT_SPIM1_ADDR)
7786
/* The address of the ALT_SPIM_RISR register for the ALT_SPIM1 instance. */
7787
#define ALT_SPIM1_RISR_ADDR ALT_SPIM_RISR_ADDR(ALT_SPIM1_ADDR)
7788
/* The address of the ALT_SPIM_TXOICR register for the ALT_SPIM1 instance. */
7789
#define ALT_SPIM1_TXOICR_ADDR ALT_SPIM_TXOICR_ADDR(ALT_SPIM1_ADDR)
7790
/* The address of the ALT_SPIM_RXOICR register for the ALT_SPIM1 instance. */
7791
#define ALT_SPIM1_RXOICR_ADDR ALT_SPIM_RXOICR_ADDR(ALT_SPIM1_ADDR)
7792
/* The address of the ALT_SPIM_RXUICR register for the ALT_SPIM1 instance. */
7793
#define ALT_SPIM1_RXUICR_ADDR ALT_SPIM_RXUICR_ADDR(ALT_SPIM1_ADDR)
7794
/* The address of the ALT_SPIM_ICR register for the ALT_SPIM1 instance. */
7795
#define ALT_SPIM1_ICR_ADDR ALT_SPIM_ICR_ADDR(ALT_SPIM1_ADDR)
7796
/* The address of the ALT_SPIM_DMACR register for the ALT_SPIM1 instance. */
7797
#define ALT_SPIM1_DMACR_ADDR ALT_SPIM_DMACR_ADDR(ALT_SPIM1_ADDR)
7798
/* The address of the ALT_SPIM_DMATDLR register for the ALT_SPIM1 instance. */
7799
#define ALT_SPIM1_DMATDLR_ADDR ALT_SPIM_DMATDLR_ADDR(ALT_SPIM1_ADDR)
7800
/* The address of the ALT_SPIM_DMARDLR register for the ALT_SPIM1 instance. */
7801
#define ALT_SPIM1_DMARDLR_ADDR ALT_SPIM_DMARDLR_ADDR(ALT_SPIM1_ADDR)
7802
/* The address of the ALT_SPIM_IDR register for the ALT_SPIM1 instance. */
7803
#define ALT_SPIM1_IDR_ADDR ALT_SPIM_IDR_ADDR(ALT_SPIM1_ADDR)
7804
/* The address of the ALT_SPIM_SPI_VER_ID register for the ALT_SPIM1 instance. */
7805
#define ALT_SPIM1_SPI_VER_ID_ADDR ALT_SPIM_SPI_VER_ID_ADDR(ALT_SPIM1_ADDR)
7806
/* The address of the ALT_SPIM_DR register for the ALT_SPIM1 instance. */
7807
#define ALT_SPIM1_DR_ADDR ALT_SPIM_DR_ADDR(ALT_SPIM1_ADDR)
7808
/* The address of the ALT_SPIM_RX_SMPL_DLY register for the ALT_SPIM1 instance. */
7809
#define ALT_SPIM1_RX_SMPL_DLY_ADDR ALT_SPIM_RX_SMPL_DLY_ADDR(ALT_SPIM1_ADDR)
7810
/* The base address byte offset for the start of the ALT_SPIM1 component. */
7811
#define ALT_SPIM1_OFST 0xfff01000
7812
/* The start address of the ALT_SPIM1 component. */
7813
#define ALT_SPIM1_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SPIM1_OFST))
7814
/* The lower bound address range of the ALT_SPIM1 component. */
7815
#define ALT_SPIM1_LB_ADDR ALT_SPIM1_ADDR
7816
/* The upper bound address range of the ALT_SPIM1 component. */
7817
#define ALT_SPIM1_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SPIM1_ADDR) + 0x100) - 1))
7818
7819
7820
7821
* Component Instance : scanmgr
7822
7823
* Instance scanmgr of component ALT_SCANMGR.
7824
7825
7826
7827
/* The address of the ALT_SCANMGR_STAT register for the ALT_SCANMGR instance. */
7828
#define ALT_SCANMGR_STAT_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_STAT_OFST))
7829
/* The address of the ALT_SCANMGR_EN register for the ALT_SCANMGR instance. */
7830
#define ALT_SCANMGR_EN_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_EN_OFST))
7831
/* The address of the ALT_SCANMGR_FIFOSINGLEBYTE register for the ALT_SCANMGR instance. */
7832
#define ALT_SCANMGR_FIFOSINGLEBYTE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_FIFOSINGLEBYTE_OFST))
7833
/* The address of the ALT_SCANMGR_FIFODOUBLEBYTE register for the ALT_SCANMGR instance. */
7834
#define ALT_SCANMGR_FIFODOUBLEBYTE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_FIFODOUBLEBYTE_OFST))
7835
/* The address of the ALT_SCANMGR_FIFOTRIPLEBYTE register for the ALT_SCANMGR instance. */
7836
#define ALT_SCANMGR_FIFOTRIPLEBYTE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_FIFOTRIPLEBYTE_OFST))
7837
/* The address of the ALT_SCANMGR_FIFOQUADBYTE register for the ALT_SCANMGR instance. */
7838
#define ALT_SCANMGR_FIFOQUADBYTE_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_SCANMGR_ADDR) + ALT_SCANMGR_FIFOQUADBYTE_OFST))
7839
/* The base address byte offset for the start of the ALT_SCANMGR component. */
7840
#define ALT_SCANMGR_OFST 0xfff02000
7841
/* The start address of the ALT_SCANMGR component. */
7842
#define ALT_SCANMGR_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_SCANMGR_OFST))
7843
/* The lower bound address range of the ALT_SCANMGR component. */
7844
#define ALT_SCANMGR_LB_ADDR ALT_SCANMGR_ADDR
7845
/* The upper bound address range of the ALT_SCANMGR component. */
7846
#define ALT_SCANMGR_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_SCANMGR_ADDR) + 0x20) - 1))
7847
7848
7849
7850
* Component Instance : rom
7851
7852
* Instance rom of component ALT_ROM.
7853
7854
7855
7856
/* The base address byte offset for the start of the ALT_ROM component. */
7857
#define ALT_ROM_OFST 0xfffd0000
7858
/* The start address of the ALT_ROM component. */
7859
#define ALT_ROM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_ROM_OFST))
7860
/* The lower bound address range of the ALT_ROM component. */
7861
#define ALT_ROM_LB_ADDR ALT_ROM_ADDR
7862
/* The upper bound address range of the ALT_ROM component. */
7863
#define ALT_ROM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_ROM_ADDR) + 0x10000) - 1))
7864
7865
7866
7867
* Component Instance : mpuscu
7868
7869
* Instance mpuscu of component ALT_MPUSCU.
7870
7871
7872
7873
/* The address of the ALT_MPUSCU_REG register for the ALT_MPUSCU instance. */
7874
#define ALT_MPUSCU_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_MPUSCU_ADDR) + ALT_MPUSCU_REG_OFST))
7875
/* The base address byte offset for the start of the ALT_MPUSCU component. */
7876
#define ALT_MPUSCU_OFST 0xfffec000
7877
/* The start address of the ALT_MPUSCU component. */
7878
#define ALT_MPUSCU_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_MPUSCU_OFST))
7879
/* The lower bound address range of the ALT_MPUSCU component. */
7880
#define ALT_MPUSCU_LB_ADDR ALT_MPUSCU_ADDR
7881
/* The upper bound address range of the ALT_MPUSCU component. */
7882
#define ALT_MPUSCU_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_MPUSCU_ADDR) + 0x4) - 1))
7883
7884
7885
7886
* Component Instance : mpul2
7887
7888
* Instance mpul2 of component ALT_MPUL2.
7889
7890
7891
7892
/* The address of the ALT_MPUL2_REG register for the ALT_MPUL2 instance. */
7893
#define ALT_MPUL2_REG_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_MPUL2_ADDR) + ALT_MPUL2_REG_OFST))
7894
/* The base address byte offset for the start of the ALT_MPUL2 component. */
7895
#define ALT_MPUL2_OFST 0xfffef000
7896
/* The start address of the ALT_MPUL2 component. */
7897
#define ALT_MPUL2_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_MPUL2_OFST))
7898
/* The lower bound address range of the ALT_MPUL2 component. */
7899
#define ALT_MPUL2_LB_ADDR ALT_MPUL2_ADDR
7900
/* The upper bound address range of the ALT_MPUL2 component. */
7901
#define ALT_MPUL2_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_MPUL2_ADDR) + 0x4) - 1))
7902
7903
7904
7905
* Component Instance : ocram
7906
7907
* Instance ocram of component ALT_OCRAM.
7908
7909
7910
7911
/* The base address byte offset for the start of the ALT_OCRAM component. */
7912
#define ALT_OCRAM_OFST 0xffff0000
7913
/* The start address of the ALT_OCRAM component. */
7914
#define ALT_OCRAM_ADDR ALT_CAST(void *, (ALT_CAST(char *, ALT_HPS_ADDR) + ALT_OCRAM_OFST))
7915
/* The lower bound address range of the ALT_OCRAM component. */
7916
#define ALT_OCRAM_LB_ADDR ALT_OCRAM_ADDR
7917
/* The upper bound address range of the ALT_OCRAM component. */
7918
#define ALT_OCRAM_UB_ADDR ALT_CAST(void *, ((ALT_CAST(char *, ALT_OCRAM_ADDR) + 0x10000) - 1))
7919
7920
7921
7922
* Address Space : ALT_HPS
7923
7924
* Address Map
7925
7926
* Address Range | Component
7927
7928
* 0x00000000 - 0xfbffffff | Undefined
7929
* 0xfc000000 - 0xfc000003 | ALT_STM
7930
* 0xfc000004 - 0xfeffffff | Undefined
7931
* 0xff000000 - 0xff000003 | ALT_DAP
7932
* 0xff000004 - 0xff1fffff | Undefined
7933
* 0xff200000 - 0xff3fffff | ALT_LWFPGASLVS
7934
* 0xff400000 - 0xff47ffff | ALT_LWH2F
7935
* 0xff480000 - 0xff4fffff | Undefined
7936
* 0xff500000 - 0xff507fff | ALT_H2F
7937
* 0xff508000 - 0xff5fffff | Undefined
7938
* 0xff600000 - 0xff67ffff | ALT_F2H
7939
* 0xff680000 - 0xff6fffff | Undefined
7940
* 0xff700000 - 0xff701fff | ALT_EMAC0
7941
* 0xff702000 - 0xff703fff | ALT_EMAC1
7942
* 0xff704000 - 0xff7043ff | ALT_SDMMC
7943
* 0xff704400 - 0xff704fff | Undefined
7944
* 0xff705000 - 0xff7050ff | ALT_QSPI
7945
* 0xff705100 - 0xff705fff | Undefined
7946
* 0xff706000 - 0xff706fff | ALT_FPGAMGR
7947
* 0xff707000 - 0xff707fff | ALT_ACPIDMAP
7948
* 0xff708000 - 0xff70807f | ALT_GPIO0
7949
* 0xff708080 - 0xff708fff | Undefined
7950
* 0xff709000 - 0xff70907f | ALT_GPIO1
7951
* 0xff709080 - 0xff709fff | Undefined
7952
* 0xff70a000 - 0xff70a07f | ALT_GPIO2
7953
* 0xff70a080 - 0xff7fffff | Undefined
7954
* 0xff800000 - 0xff87ffff | ALT_L3
7955
* 0xff880000 - 0xff8fffff | Undefined
7956
* 0xff900000 - 0xff9fffff | ALT_NANDDATA
7957
* 0xffa00000 - 0xffafffff | ALT_QSPIDATA
7958
* 0xffb00000 - 0xffb3ffff | ALT_USB0
7959
* 0xffb40000 - 0xffb7ffff | ALT_USB1
7960
* 0xffb80000 - 0xffb807ff | ALT_NAND
7961
* 0xffb80800 - 0xffb8ffff | Undefined
7962
* 0xffb90000 - 0xffb90003 | ALT_FPGAMGRDATA
7963
* 0xffb90004 - 0xffbfffff | Undefined
7964
* 0xffc00000 - 0xffc001ff | ALT_CAN0
7965
* 0xffc00200 - 0xffc00fff | Undefined
7966
* 0xffc01000 - 0xffc011ff | ALT_CAN1
7967
* 0xffc01200 - 0xffc01fff | Undefined
7968
* 0xffc02000 - 0xffc020ff | ALT_UART0
7969
* 0xffc02100 - 0xffc02fff | Undefined
7970
* 0xffc03000 - 0xffc030ff | ALT_UART1
7971
* 0xffc03100 - 0xffc03fff | Undefined
7972
* 0xffc04000 - 0xffc040ff | ALT_I2C0
7973
* 0xffc04100 - 0xffc04fff | Undefined
7974
* 0xffc05000 - 0xffc050ff | ALT_I2C1
7975
* 0xffc05100 - 0xffc05fff | Undefined
7976
* 0xffc06000 - 0xffc060ff | ALT_I2C2
7977
* 0xffc06100 - 0xffc06fff | Undefined
7978
* 0xffc07000 - 0xffc070ff | ALT_I2C3
7979
* 0xffc07100 - 0xffc07fff | Undefined
7980
* 0xffc08000 - 0xffc080ff | ALT_SPTMR0
7981
* 0xffc08100 - 0xffc08fff | Undefined
7982
* 0xffc09000 - 0xffc090ff | ALT_SPTMR1
7983
* 0xffc09100 - 0xffc1ffff | Undefined
7984
* 0xffc20000 - 0xffc3ffff | ALT_SDR
7985
* 0xffc40000 - 0xffcfffff | Undefined
7986
* 0xffd00000 - 0xffd000ff | ALT_OSC1TMR0
7987
* 0xffd00100 - 0xffd00fff | Undefined
7988
* 0xffd01000 - 0xffd010ff | ALT_OSC1TMR1
7989
* 0xffd01100 - 0xffd01fff | Undefined
7990
* 0xffd02000 - 0xffd020ff | ALT_L4WD0
7991
* 0xffd02100 - 0xffd02fff | Undefined
7992
* 0xffd03000 - 0xffd030ff | ALT_L4WD1
7993
* 0xffd03100 - 0xffd03fff | Undefined
7994
* 0xffd04000 - 0xffd041ff | ALT_CLKMGR
7995
* 0xffd04200 - 0xffd04fff | Undefined
7996
* 0xffd05000 - 0xffd050ff | ALT_RSTMGR
7997
* 0xffd05100 - 0xffd07fff | Undefined
7998
* 0xffd08000 - 0xffd0bfff | ALT_SYSMGR
7999
* 0xffd0c000 - 0xffdfffff | Undefined
8000
* 0xffe00000 - 0xffe00003 | ALT_DMANONSECURE
8001
* 0xffe00004 - 0xffe00fff | Undefined
8002
* 0xffe01000 - 0xffe01003 | ALT_DMASECURE
8003
* 0xffe01004 - 0xffe01fff | Undefined
8004
* 0xffe02000 - 0xffe0207f | ALT_SPIS0
8005
* 0xffe02080 - 0xffe02fff | Undefined
8006
* 0xffe03000 - 0xffe0307f | ALT_SPIS1
8007
* 0xffe03080 - 0xffefffff | Undefined
8008
* 0xfff00000 - 0xfff000ff | ALT_SPIM0
8009
* 0xfff00100 - 0xfff00fff | Undefined
8010
* 0xfff01000 - 0xfff010ff | ALT_SPIM1
8011
* 0xfff01100 - 0xfff01fff | Undefined
8012
* 0xfff02000 - 0xfff0201f | ALT_SCANMGR
8013
* 0xfff02020 - 0xfffcffff | Undefined
8014
* 0xfffd0000 - 0xfffdffff | ALT_ROM
8015
* 0xfffe0000 - 0xfffebfff | Undefined
8016
* 0xfffec000 - 0xfffec003 | ALT_MPUSCU
8017
* 0xfffec004 - 0xfffeefff | Undefined
8018
* 0xfffef000 - 0xfffef003 | ALT_MPUL2
8019
* 0xfffef004 - 0xfffeffff | Undefined
8020
* 0xffff0000 - 0xffffffff | ALT_OCRAM
8021
8022
8023
#ifdef __ASSEMBLY__
8024
#define ALT_CAST(type, ptr) ptr
8025
#else
/* __ASSEMBLY__ */
8026
#define ALT_CAST(type, ptr) ((type) (ptr))
8027
#endif
/* __ASSEMBLY__ */
8028
#ifdef __cplusplus
8029
8030
#endif
/* __cplusplus */
8031
#endif
/* __ALTERA_HPS_H__ */
8032
