RTEMS 6.3
#include "chip.h"Go to the source code of this file.
| struct | AfeCmd |
| Spi Transfer Request prepared by the application upper layer. More... | |
| struct | AfeDma |
| #define | AFE_OK 0 |
| #define | AFE_ERROR 1 |
| #define | AFE_ERROR_LOCK 2 |
Typedefs | |
| typedef void(*) | AfeCallback(uint8_t, void *) |
| uint32_t | Afe_ConfigureDma (AfeDma *pAfed, Afec *pAfeHw, uint8_t AfeId, sXdmad *pXdmad) |
| Initializes the AfeDma structure and the corresponding AFE & DMA . hardware select value. The driver will uses DMA channel 0 for RX . The DMA channels are freed automatically when no DMA command processing. | |
| uint32_t | Afe_SendData (AfeDma *pAfed, AfeCmd *pCommand) |
| Starts a AFE transfer. This is a non blocking function. It will return as soon as the transfer is started. | |
Interface for configuration the Analog-to-Digital Converter (AFEC) peripheral.
| typedef void(*) AfeCallback(uint8_t, void *) |
AFE transfer complete callback.
| pAfed | Pointer to a AfeDma instance. |
| pAfeHw | Associated Afe peripheral. |
| AfeId | Afe peripheral identifier. |
| pDmad | Pointer to a Dmad instance. |
| pCommand | Pointer to the Afe command to execute. |
