RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
afe_dma.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
49
#ifndef _AFE_DMA_
50
#define _AFE_DMA_
51
52
53
* Headers
54
55
56
#include "chip.h"
57
58
59
60
* Types
61
62
64
typedef
void (*
AfeCallback
)(uint8_t,
void
65
71
typedef
struct
73
uint32_t *
pRxBuff
75
uint16_t
RxSize
77
AfeCallback
callback
79
void
pArgument
80
AfeCmd
81
82
85
typedef
struct
87
Afec
pAfeHw
89
AfeCmd
pCurrentCommand
91
sXdmad
pXdmad
93
uint8_t
afeId
95
volatile
int8_t
semaphore
96
AfeDma
97
98
99
100
* Definitions
101
102
#define AFE_OK 0
103
#define AFE_ERROR 1
104
#define AFE_ERROR_LOCK 2
105
106
* Exported functions
107
108
extern
uint32_t
Afe_ConfigureDma
AfeDma
*pAfed ,
109
Afec
*pAfeHw ,
110
uint8_t AfeId,
111
sXdmad
*pXdmad);
112
extern
uint32_t
Afe_SendData
AfeDma
*pAfed,
AfeCmd
*pCommand);
113
114
115
#endif
/* #ifndef _AFE_DMA_ */
116
Afe_ConfigureDma
uint32_t Afe_ConfigureDma(AfeDma *pAfed, Afec *pAfeHw, uint8_t AfeId, sXdmad *pXdmad)
Initializes the AfeDma structure and the corresponding AFE & DMA . hardware select value....
Definition
afe_dma.c:198
Afe_SendData
uint32_t Afe_SendData(AfeDma *pAfed, AfeCmd *pCommand)
Starts a AFE transfer. This is a non blocking function. It will return as soon as the transfer is sta...
Definition
afe_dma.c:223
AfeCallback
void(*) AfeCallback(uint8_t, void *)
Definition
afe_dma.h:64
sXdmad
struct _Xdmad sXdmad
AfeCmd
Spi Transfer Request prepared by the application upper layer.
Definition
afe_dma.h:71
AfeCmd::pRxBuff
uint32_t * pRxBuff
Definition
afe_dma.h:73
AfeCmd::RxSize
uint16_t RxSize
Definition
afe_dma.h:75
AfeCmd::pArgument
void * pArgument
Definition
afe_dma.h:79
AfeCmd::callback
AfeCallback callback
Definition
afe_dma.h:77
AfeDma
Definition
afe_dma.h:85
AfeDma::pAfeHw
Afec * pAfeHw
Definition
afe_dma.h:87
AfeDma::pCurrentCommand
AfeCmd * pCurrentCommand
Definition
afe_dma.h:89
AfeDma::pXdmad
sXdmad * pXdmad
Definition
afe_dma.h:91
AfeDma::afeId
uint8_t afeId
Definition
afe_dma.h:93
AfeDma::semaphore
volatile int8_t semaphore
Definition
afe_dma.h:95
Afec
Afec hardware registers.
Definition
component_afec.h:41
