RTEMS 6.3
afec.c File Reference
#include "chip.h"
void AFEC_Initialize (Afec *pAFE, uint32_t dwID)
 Initialize the AFE controller.
uint32_t AFEC_SetClock (Afec *pAFE, uint32_t dwClk, uint32_t dwMck)
 Set AFE clock.
void AFEC_SetTiming (Afec *pAFE, uint32_t dwStartup, uint32_t dwTracking, uint32_t dwSettling)
 Set AFE timing.
void AFEC_SetTrigger (Afec *pAFE, uint32_t dwTrgSel)
 Set AFE trigger.
void AFEC_SetSleepMode (Afec *pAFE, uint8_t bEnDis)
 Enable/Disable sleep mode.
void AFEC_SetFastWakeup (Afec *pAFE, uint8_t bEnDis)
 Enable/Disable fast wake up.
void AFEC_SetSequenceMode (Afec *pAFE, uint8_t bEnDis)
 Enable/Disable sequence mode.
void AFEC_SetSequence (Afec *pAFE, uint32_t dwSEQ1, uint32_t dwSEQ2)
 Set channel sequence.
void AFEC_SetSequenceByList (Afec *pAFE, uint8_t ucChList[], uint8_t ucNumCh)
 Set channel sequence by given channel list.
void AFEC_SetAnalogChange (Afec *pAFE, uint8_t bEnDis)
 Set analog change. IF enabled, it allows different analog settings for each channel, otherwise, DIFF0, GAIN0 and OFF0 are used for all channels.
void AFEC_SetTagEnable (Afec *pAFE, uint8_t bEnDis)
 Set "TAG" mode, show channel number in last data or not.
void AFEC_SetCompareChannel (Afec *pAFE, uint32_t dwChannel)
 Set compare channel.
void AFEC_SetCompareMode (Afec *pAFE, uint32_t dwMode)
 Set compare mode.
void AFEC_SetComparisonWindow (Afec *pAFE, uint32_t dwHi_Lo)
 Set comparison window.
uint32_t AFEC_GetConvertedData (Afec *pAFE, uint32_t dwChannel)
 Return the Channel Converted Data.
void AFEC_SetStartupTime (Afec *pAFE, uint32_t dwUs)
void AFEC_SetTrackingTime (Afec *pAFE, uint32_t dwNs)
void AFEC_SetAnalogOffset (Afec *pAFE, uint32_t dwChannel, uint32_t aoffset)
 Set analog offset to be used for channel CSEL.
void AFEC_SetAnalogControl (Afec *pAFE, uint32_t control)
Implementation of Analog-to-Digital Converter (AFE).
◆ AFEC_GetConvertedData()
uint32_t AFEC_GetConvertedData ( Afec * pAFE,
uint32_t dwChannel )
extern
Parameters
pAFEPointer to an AFE instance.
dwChannelchannel to get converted value
◆ AFEC_Initialize()
void AFEC_Initialize ( Afec * pAFE,
uint32_t dwID )
extern
Parameters
dwIDAFE Index
◆ AFEC_SetAnalogChange()
void AFEC_SetAnalogChange ( Afec * pAFE,
uint8_t bEnDis )
extern
Parameters
bEnDisEnable/Disable.
◆ AFEC_SetAnalogControl()
void AFEC_SetAnalogControl ( Afec * pAFE,
uint32_t control )
Parameters
afecBase address of the AFEC.
controlAnalog control value.
◆ AFEC_SetAnalogOffset()
void AFEC_SetAnalogOffset ( Afec * pAFE,
uint32_t dwChannel,
uint32_t aoffset )
Parameters
dwChannelAFEC channel number.
aoffsetAnalog offset value.
◆ AFEC_SetClock()
uint32_t AFEC_SetClock ( Afec * pAFE,
uint32_t dwClk,
uint32_t dwMck )
extern
Set AFE clock.
Parameters
dwPresprescale value
dwMckBoard MCK (Hz)
Returns
AFE clock
◆ AFEC_SetCompareChannel()
void AFEC_SetCompareChannel ( Afec * pAFE,
extern
Parameters
dwChannelchannel number to be set,16 for all channels
◆ AFEC_SetCompareMode()
void AFEC_SetCompareMode ( Afec * pAFE,
uint32_t dwMode )
extern
Set compare mode.
Parameters
dwModecompare mode
◆ AFEC_SetComparisonWindow()
void AFEC_SetComparisonWindow ( Afec * pAFE,
uint32_t dwHi_Lo )
extern
Parameters
dwHi_LoComparison Window
◆ AFEC_SetFastWakeup()
void AFEC_SetFastWakeup ( Afec * pAFE,
uint8_t bEnDis )
extern
Parameters
bEnDisEnable/Disable fast wake up in sleep mode.
◆ AFEC_SetSequence()
void AFEC_SetSequence ( Afec * pAFE,
uint32_t dwSEQ1,
uint32_t dwSEQ2 )
extern
Parameters
dwSEQ1Sequence 1 ~ 8 channel number.
dwSEQ2Sequence 9 ~ 16 channel number.
◆ AFEC_SetSequenceByList()
void AFEC_SetSequenceByList ( Afec * pAFE,
uint8_t ucChList[],
uint8_t ucNumCh )
extern
Parameters
ucChListChannel list.
ucNumChNumber of channels in list.
◆ AFEC_SetSequenceMode()
void AFEC_SetSequenceMode ( Afec * pAFE,
uint8_t bEnDis )
extern
Parameters
bEnDisEnable/Disable sequence mode.
◆ AFEC_SetSleepMode()
void AFEC_SetSleepMode ( Afec * pAFE,
uint8_t bEnDis )
extern
Parameters
bEnDisEnable/Disable sleep mode.
◆ AFEC_SetStartupTime()
void AFEC_SetStartupTime ( Afec * pAFE,
uint32_t dwUs )
Sets the AFE startup time.
Parameters
dwUsStartup time in uS.
◆ AFEC_SetTagEnable()
void AFEC_SetTagEnable ( Afec * pAFE,
uint8_t bEnDis )
extern
Parameters
bEnDisEnable/Disable TAG value.
◆ AFEC_SetTiming()
void AFEC_SetTiming ( Afec * pAFE,
uint32_t dwStartup,
uint32_t dwSettling )
extern
Set AFE timing.
Parameters
dwStartupstartup value
dwTrackingtracking value
dwSettlingsettling value
◆ AFEC_SetTrackingTime()
void AFEC_SetTrackingTime ( Afec * pAFE,
uint32_t dwNs )
Set AFE tracking time
Parameters
dwNsTracking time in nS.
◆ AFEC_SetTrigger()
void AFEC_SetTrigger ( Afec * pAFE,
uint32_t dwTrgSel )
extern
Set AFE trigger.
Parameters
dwTrgSelTrigger selection
